[U-Boot] placement for new clock drivers
I have a few questions regarding the UCLASS_CLK driver. I need to implement a clock driver for a new-ish platform, an ARMv7 based SoCFPGA Arria10.
I think going forward, it would make sense to place the driver to be of UCLASS_CLK and would go into drivers/clk/, instead of under arch/arm/mach-socfpga directory, Am I correct in assuming that?
My 2nd question is regarding the usage of uclass_get_device(UCLASS_CLK). If I have a DTS that is from: arch/arm/dts/socfpga.dtsi
Fragment of the clock portion from the DTS here:
clkmgr@ffd04000 { compatible = "altr,clk-mgr"; reg = <0xffd04000 0x1000>;
clocks { #address-cells = <1>; #size-cells = <0>;
osc1: osc1 { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <25000000>; };
osc2: osc2 { #clock-cells = <0>; compatible = "fixed-clock"; };
f2s_periph_ref_clk: f2s_periph_ref_clk { #clock-cells = <0>; compatible = "fixed-clock"; };
f2s_sdram_ref_clk: f2s_sdram_ref_clk { #clock-cells = <0>; compatible = "fixed-clock"; }; };
I tried calling uclass_get_device(UCLASS_CLK, 0, dev), thinking that it would return the "fixed-clock" clocks, then I can get the frequencies and move forward with calculating the rest of the clocks. But uclass_get_device() is returning an error for me. I'm sure I might have missed understood how the clock framework is supposed to work somewhere. Can you please point me in the right direction?
Thanks, Dinh
On 29 February 2016 at 09:56, Dinh Nguyen dinguyen@opensource.altera.com wrote:
Yes.
clocks { #address-cells = <1>; #size-cells = <0>; osc1: osc1 { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <25000000>; }; osc2: osc2 { #clock-cells = <0>; compatible = "fixed-clock"; }; f2s_periph_ref_clk: f2s_periph_ref_clk { #clock-cells = <0>; compatible = "fixed-clock"; }; f2s_sdram_ref_clk: f2s_sdram_ref_clk { #clock-cells = <0>; compatible = "fixed-clock"; };
Do you have a driver for altr,clk-mgr? If not you could add a driver, or maybe "simple-bus" to the compatible string.
If you add a driver, see simple_bus_post_bind() for the function you need to call to bind devices in sub-nodes.
Hi Simon,
Yes.
Do you see any benefits to moving an existing clock driver that is in arch/ to drivers/clk and making it UCLASS_CLK?
The reason I ask is that I think I will have to create a driver for "altr,clk-mgr" for the Arria10 platform, so I'm just wondering if I should do the same for a legacy clock manager.
Thanks, Dinh
Hi Dinh,
On 1 March 2016 at 15:16, Dinh Nguyen dinguyen@opensource.altera.com wrote:
Hi Simon,
Yes.
It moves it to the new world, so some benefit there.
What do you mean by legacy clock manager?
You'll only need this for driver model. Also, the driver can be very simple, like simple-bus.
Dinh Nguyen
