[U-Boot] [PATCH] pylibfdt: Add missing CC and LD to Makefile
Add missing CC and LDSHARED variables to the Makefile to pass the correct C compiler and linker path to the build of _libfdt.so .
Signed-off-by: Marek Vasut marex@denx.de Cc: Tom Rini trini@konsulko.com Cc: Masahiro Yamada yamada.masahiro@socionext.com Cc: Simon Glass sjg@chromium.org --- Note: This fixes the long standing issue when building U-Boot with OE for qemux86 or qemux86_64, where the build will try to use the host compiler, which OE will block and thus the build will crash on missing compiler/linker binary. With this patch, the OE will correctly pass in the compiler/linker generated during the build, just like it does for all the other tools. --- scripts/dtc/pylibfdt/Makefile | 1 + 1 file changed, 1 insertion(+)
diff --git a/scripts/dtc/pylibfdt/Makefile b/scripts/dtc/pylibfdt/Makefile index 01d5e0ffe3..e6f6e9f633 100644 --- a/scripts/dtc/pylibfdt/Makefile +++ b/scripts/dtc/pylibfdt/Makefile @@ -15,6 +15,7 @@ PYLIBFDT_srcs = $(addprefix $(LIBFDT_srcdir)/,$(LIBFDT_SRCS)) \
quiet_cmd_pymod = PYMOD $@ cmd_pymod = unset CC; unset CROSS_COMPILE; unset CFLAGS;\ + CC="$(HOSTCC)" LDSHARED="$(HOSTCC) -shared " \ LDFLAGS="$(HOSTLDFLAGS)" \ VERSION="u-boot-$(UBOOTVERSION)" \ CPPFLAGS="$(HOSTCFLAGS) -I$(LIBFDT_srcdir)" OBJDIR=$(obj) \
Please can you remove the 'unset CC'? It does not seem necessary since you set it later:
-- 2.16.2
Yeah.
-- 2.16.2
