[PATCH 0/5] Add ESM driver support for AM64x R5
AM64x devices have a main ESM and a MCU ESM. The ESM driver enables routing of the error events from various sources to different processors or to reset hardware logic. Only the MCU ESM's high output can trigger reset logic. The main RTI0 WWDT output can be routed to the MCU highoutput to trigger reset through the main ESM. For this reset to occur CTRLMMR_MCU_RST_CTRL:MCU_ESM_ERROR_RESET_EN_Z is set to '0'.
AM64x Technical Reference Manual - https://www.ti.com/lit/pdf/spruim2
Hari Nagalla (5): misc: k3_esm: Add functionality to set and route error events within K3SoC arm: dts: k3-am64: Add support for ESM device nodes arch: arm: mach-k3: am642_init: Probe ESM nodes configs: am64x_evm_r5_defconfig: Add support for ESM driver configs: am64x_hs_evm_r5_defconfig: Add support for ESM driver
arch/arm/dts/k3-am64.dtsi | 1 + arch/arm/dts/k3-am642-r5-evm.dts | 19 +++++++++++ arch/arm/dts/k3-am642-r5-sk.dts | 19 +++++++++++ arch/arm/mach-k3/am642_init.c | 37 +++++++++++++++++++++ configs/am64x_evm_r5_defconfig | 1 + configs/am64x_hs_evm_r5_defconfig | 1 + drivers/misc/k3_esm.c | 53 +++++++++++++++++++++++++++++-- 7 files changed, 128 insertions(+), 3 deletions(-)
Sorry.. The patches are being re-submitted after rebasing.
Thanks
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Nagalla, Hari Sent: Wednesday, February 2, 2022 11:10 AM To: u-boot@lists.denx.de Cc: Menon, Nishanth nm@ti.com Subject: [PATCH 0/5] Add ESM driver support for AM64x R5
-- 2.17.1
Hi Hari
Am Mi., 2. Feb. 2022 um 18:50 Uhr schrieb Hari Nagalla hnagalla@ti.com:
Are there any plans to send out a V2 of this patch series? If not I can jump in (as I really want to see in U-Boot sooner than later).
Hi Christian,
I have a v2 series.. Will send out by Saturday.
Thanks Hari
-----Original Message----- From: Christian Gmeiner christian.gmeiner@gmail.com Sent: Wednesday, February 23, 2022 1:53 AM To: Nagalla, Hari hnagalla@ti.com Cc: U-Boot Mailing List u-boot@lists.denx.de; Menon, Nishanth nm@ti.com Subject: Re: [PATCH 0/5] Add ESM driver support for AM64x R5
Hi Hari
-- greets -- Christian Gmeiner, MSc
Christian Gmeiner
Hari Nagalla
Nagalla, Hari
