[PATCH 1/2] ARM64: dts: marvell: cn9310: Use appropriate label for spi1 pins
The CN9130-DB uses the SPI1 interface but had the pinctrl node labelled as "cp0_spi0_pins". Use the label "cp0_spi1_pins" and update the node name to "cp0-spi-pins-1" to avoid confusion with the pinctrl options for SPI0.
Signed-off-by: Chris Packham judge.packham@gmail.com ---
arch/arm/dts/cn9130-db.dtsi | 2 +- arch/arm/dts/cn9130.dtsi | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/cn9130-db.dtsi b/arch/arm/dts/cn9130-db.dtsi index 1b28732ee752..4b21ff46d507 100644 --- a/arch/arm/dts/cn9130-db.dtsi +++ b/arch/arm/dts/cn9130-db.dtsi @@ -183,7 +183,7 @@ /* U55 */ &cp0_spi1 { pinctrl-names = "default"; - pinctrl-0 = <&cp0_spi0_pins>; + pinctrl-0 = <&cp0_spi1_pins>; reg = <0x700680 0x50>, /* control */ <0x2000000 0x1000000>, /* CS0 */ <0 0xffffffff>, /* CS1 */ diff --git a/arch/arm/dts/cn9130.dtsi b/arch/arm/dts/cn9130.dtsi index 68b767a70639..efcb2e906b91 100644 --- a/arch/arm/dts/cn9130.dtsi +++ b/arch/arm/dts/cn9130.dtsi @@ -66,7 +66,7 @@ marvell,pins = < 56 57 58 59 60 61 >; marvell,function = <14>; }; - cp0_spi0_pins: cp0-spi-pins-0 { + cp0_spi1_pins: cp0-spi-pins-1 { marvell,pins = < 13 14 15 16 >; marvell,function = <3>; };
The cn9130.dtsi defines a pinctrl node for SPI1 (until recently it was mislabeled as spi0). Use this instead of having a duplicate definition with a different label.
arch/arm/dts/cn9130-crb.dtsi | 7 +------ 1 file changed, 1 insertion(+), 6 deletions(-)
diff --git a/arch/arm/dts/cn9130-crb.dtsi b/arch/arm/dts/cn9130-crb.dtsi index b229725184a9..7dd36cae282b 100644 --- a/arch/arm/dts/cn9130-crb.dtsi +++ b/arch/arm/dts/cn9130-crb.dtsi @@ -125,11 +125,6 @@ marvell,function = <0>; };
- cp0_spi1_pins_crb: cp0-spi-pins-crb { - marvell,pins = < 13 14 15 16 >; - marvell,function = <3>; - }; - cp0_smi_pins_crb: cp0-smi-pins-crb { marvell,pins = < 40 41 >; marvell,function = <8>; @@ -170,7 +165,7 @@
&cp0_spi1 { pinctrl-names = "default"; - pinctrl-0 = <&cp0_spi1_pins_crb>; + pinctrl-0 = <&cp0_spi1_pins>; reg = <0x700680 0x50>, /* control */ <0x2000000 0x1000000>, /* CS0 */ <0 0xffffffff>, /* CS1 */
Thanks, Stefan
@@ -170,7 +165,7 @@
- pinctrl-0 = <&cp0_spi1_pins>; reg = <0x700680 0x50>, /* control */ <0x2000000 0x1000000>, /* CS0 */ <0 0xffffffff>, /* CS1 */
Viele Grüße, Stefan Roese
Applied to u-boot-marvell/master
Thanks, Stefan
Thanks, Stefan
diff --git a/arch/arm/dts/cn9130-crb.dtsi b/arch/arm/dts/cn9130-crb.dtsi index b229725184a9..7dd36cae282b 100644 --- a/arch/arm/dts/cn9130-crb.dtsi +++ b/arch/arm/dts/cn9130-crb.dtsi @@ -125,11 +125,6 @@ marvell,function = <0>; }; - cp0_spi1_pins_crb: cp0-spi-pins-crb { - marvell,pins = < 13 14 15 16 >; - marvell,function = <3>; - };
cp0_smi_pins_crb: cp0-smi-pins-crb { marvell,pins = < 40 41 >; marvell,function = <8>; @@ -170,7 +165,7 @@ &cp0_spi1 { pinctrl-names = "default"; - pinctrl-0 = <&cp0_spi1_pins_crb>; + pinctrl-0 = <&cp0_spi1_pins>; reg = <0x700680 0x50>, /* control */ <0x2000000 0x1000000>, /* CS0 */ <0 0xffffffff>, /* CS1 */
Thanks, Stefan
- cp0_spi1_pins: cp0-spi-pins-1 { marvell,pins = < 13 14 15 16 >; marvell,function = <3>; };
Thanks, Stefan
Thanks, Stefan
Chris Packham
Stefan Roese
