[U-Boot] [PATCH 0/5] Enabling multi port ethernet support for keystone net
Keystone net has multiple slave ethernets, register each slave as individual ethernet so that tftp can be used on any of the ethernet ports.
Tested the series on K2HK, K2L, K2E (logs [1]). Also pushed a branch for testing [2]
With the patch series there is a checkpatch warning and it can be ignored as it is error log which helps to grep the text.
[1] - http://pastebin.ubuntu.com/21861232/ [2] - git://git.ti.com/~mugunthanvnm/ti-u-boot/mugunth-ti-u-boot.git k2net-multi-slave
WARNING: line over 80 characters #143: FILE: drivers/net/keystone_net.c:1011: + error("ks2_net - not able to bind slave interfaces\n");
total: 0 errors, 1 warnings, 0 checks, 276 lines checked
NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE PREFER_ETHER_ADDR_COPY USLEEP_RANGE
patches/multi-port-support/v1.00/0002-drivers-net-keystone_net-add-support-for-multi-slave.patch has style problems, please review.
Mugunthan V N (5): drivers: net: keystone_net: fix line termination with semi-colon drivers: net: keystone_net: add support for multi slave ethernet configs: k2hk_evm: add random eth address support configs: k2e_evm: add random eth address support configs: k2l_evm: add random eth address support
configs/k2e_evm_defconfig | 2 + configs/k2hk_evm_defconfig | 2 + configs/k2l_evm_defconfig | 2 + drivers/net/keystone_net.c | 228 +++++++++++++++++++++++++++++++++++---------- 4 files changed, 186 insertions(+), 48 deletions(-)
Each line should be terminated by semi-colon. It was not caught earlier as there is a proper statement. Fix it by changing the comma with semi-colon.
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- drivers/net/keystone_net.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/net/keystone_net.c b/drivers/net/keystone_net.c index 6b28df0..1756c09 100644 --- a/drivers/net/keystone_net.c +++ b/drivers/net/keystone_net.c @@ -906,9 +906,9 @@ static int ks2_eth_probe(struct udevice *dev) pll_pa_clk_sel();
- priv->net_rx_buffs.buff_ptr = rx_buffs, - priv->net_rx_buffs.num_buffs = RX_BUFF_NUMS, - priv->net_rx_buffs.buff_len = RX_BUFF_LEN, + priv->net_rx_buffs.buff_ptr = rx_buffs; + priv->net_rx_buffs.num_buffs = RX_BUFF_NUMS; + priv->net_rx_buffs.buff_len = RX_BUFF_LEN;
/* Register MDIO bus */ mdio_bus = mdio_alloc();
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com Reviewed-by: Tom Rini trini@konsulko.com
Keystone net can have multiple ethernet slaves, currently only slave 1 is supported by the driver. Register multiple slaves as individual ethernets to network framework.
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- drivers/net/keystone_net.c | 222 ++++++++++++++++++++++++++++++++++++--------- 1 file changed, 177 insertions(+), 45 deletions(-)
diff --git a/drivers/net/keystone_net.c b/drivers/net/keystone_net.c index 1756c09..e41b7d1 100644 --- a/drivers/net/keystone_net.c +++ b/drivers/net/keystone_net.c @@ -11,6 +11,7 @@ #include <console.h>
#include <dm.h> +#include <dm/lists.h>
#include <net.h> #include <phy.h> @@ -765,6 +766,8 @@ static int ks2_eth_start(struct udevice *dev) hw_config_streaming_switch();
if (priv->has_mdio) { + keystone2_mdio_reset(priv->mdio_bus); + phy_startup(priv->phydev); if (priv->phydev->link == 0) { error("phy startup failed\n"); @@ -910,23 +913,34 @@ static int ks2_eth_probe(struct udevice *dev) priv->net_rx_buffs.num_buffs = RX_BUFF_NUMS; priv->net_rx_buffs.buff_len = RX_BUFF_LEN;
- /* Register MDIO bus */ - mdio_bus = mdio_alloc(); - if (!mdio_bus) { - error("MDIO alloc failed\n"); - return -ENOMEM; - } - priv->mdio_bus = mdio_bus; - mdio_bus->read = keystone2_mdio_read; - mdio_bus->write = keystone2_mdio_write; - mdio_bus->reset = keystone2_mdio_reset; - mdio_bus->priv = priv->mdio_base; - sprintf(mdio_bus->name, "ethernet-mdio"); - - ret = mdio_register(mdio_bus); - if (ret) { - error("MDIO bus register failed\n"); - return ret; + if (priv->slave_port == 1) { + /* + * Register MDIO bus for slave 0 only, other slave have + * to re-use the same + */ + mdio_bus = mdio_alloc(); + if (!mdio_bus) { + error("MDIO alloc failed\n"); + return -ENOMEM; + } + priv->mdio_bus = mdio_bus; + mdio_bus->read = keystone2_mdio_read; + mdio_bus->write = keystone2_mdio_write; + mdio_bus->reset = keystone2_mdio_reset; + mdio_bus->priv = priv->mdio_base; + sprintf(mdio_bus->name, "ethernet-mdio"); + + ret = mdio_register(mdio_bus); + if (ret) { + error("MDIO bus register failed\n"); + return ret; + } + } else { + /* Get the MDIO bus from slave 0 device */ + struct ks2_eth_priv *parent_priv; + + parent_priv = dev_get_priv(dev->parent); + priv->mdio_bus = parent_priv->mdio_bus; }
#ifndef CONFIG_SOC_K2G @@ -935,8 +949,11 @@ static int ks2_eth_probe(struct udevice *dev)
priv->netcp_pktdma = &netcp_pktdma;
- priv->phydev = phy_connect(mdio_bus, priv->phy_addr, dev, priv->phy_if); - phy_config(priv->phydev); + if (priv->has_mdio) { + priv->phydev = phy_connect(priv->mdio_bus, priv->phy_addr, + dev, priv->phy_if); + phy_config(priv->phydev); + }
return 0; } @@ -962,39 +979,103 @@ static const struct eth_ops ks2_eth_ops = { .write_hwaddr = ks2_eth_write_hwaddr, };
- -static int ks2_eth_ofdata_to_platdata(struct udevice *dev) +static int ks2_eth_bind_slaves(struct udevice *dev, int gbe, int *gbe_0) { - struct ks2_eth_priv *priv = dev_get_priv(dev); - struct eth_pdata *pdata = dev_get_platdata(dev); const void *fdt = gd->fdt_blob; + struct udevice *sl_dev; int interfaces; - int interface_0; - int netcp_gbe_0; - int phy; + int sec_slave; + int slave; + int ret; + char *slave_name; + + interfaces = fdt_subnode_offset(fdt, gbe, "interfaces"); + fdt_for_each_subnode(fdt, slave, interfaces) { + int slave_no; + + slave_no = fdtdec_get_int(fdt, slave, "slave-port", -ENOENT); + if (slave_no == -ENOENT) + continue; + + if (slave_no == 0) { + /* This is the current eth device */ + *gbe_0 = slave; + } else { + /* Slave devices to be registered */ + slave_name = malloc(20); + snprintf(slave_name, 20, "netcp@slave-%d", slave_no); + ret = device_bind_driver_to_node(dev, "eth_ks2_sl", + slave_name, slave, + &sl_dev); + if (ret) { + error("ks2_net - not able to bind slave interfaces\n"); + return ret; + } + } + } + + sec_slave = fdt_subnode_offset(fdt, gbe, "secondary-slave-ports"); + fdt_for_each_subnode(fdt, slave, sec_slave) { + int slave_no; + + slave_no = fdtdec_get_int(fdt, slave, "slave-port", -ENOENT); + if (slave_no == -ENOENT) + continue; + + /* Slave devices to be registered */ + slave_name = malloc(20); + snprintf(slave_name, 20, "netcp@slave-%d", slave_no); + ret = device_bind_driver_to_node(dev, "eth_ks2_sl", slave_name, + slave, &sl_dev); + if (ret) { + error("ks2_net - not able to bind slave interfaces\n"); + return ret; + } + } + + return 0; +} + +static int ks2_eth_parse_slave_interface(int netcp, int slave, + struct ks2_eth_priv *priv, + struct eth_pdata *pdata) +{ + const void *fdt = gd->fdt_blob; int mdio; - u32 dma_channel[6]; + int phy; + int dma_count; + u32 dma_channel[8];
- interfaces = fdt_subnode_offset(fdt, dev->of_offset, - "netcp-interfaces"); - interface_0 = fdt_subnode_offset(fdt, interfaces, "interface-0"); + priv->slave_port = fdtdec_get_int(fdt, slave, "slave-port", -1); + priv->net_rx_buffs.rx_flow = priv->slave_port * 8;
- netcp_gbe_0 = fdtdec_lookup_phandle(fdt, interface_0, "netcp-gbe"); - priv->link_type = fdtdec_get_int(fdt, netcp_gbe_0, - "link-interface", -1); - priv->slave_port = fdtdec_get_int(fdt, netcp_gbe_0, "slave-port", -1); /* U-Boot slave port number starts with 1 instead of 0 */ priv->slave_port += 1;
- phy = fdtdec_lookup_phandle(fdt, netcp_gbe_0, "phy-handle"); - priv->phy_addr = fdtdec_get_int(fdt, phy, "reg", -1); + dma_count = fdtdec_get_int_array_count(fdt, netcp, + "ti,navigator-dmas", + dma_channel, 8);
- mdio = fdt_parent_offset(fdt, phy); - if (mdio < 0) { - error("mdio dt not found\n"); - return -ENODEV; + if (dma_count > (2 * priv->slave_port)) { + int dma_idx; + + dma_idx = priv->slave_port * 2 - 1; + priv->net_rx_buffs.rx_flow = dma_channel[dma_idx]; + } + + priv->link_type = fdtdec_get_int(fdt, slave, "link-interface", -1); + + phy = fdtdec_lookup_phandle(fdt, slave, "phy-handle"); + if (phy >= 0) { + priv->phy_addr = fdtdec_get_int(fdt, phy, "reg", -1); + + mdio = fdt_parent_offset(fdt, phy); + if (mdio < 0) { + error("mdio dt not found\n"); + return -ENODEV; + } + priv->mdio_base = (void *)fdtdec_get_addr(fdt, mdio, "reg"); } - priv->mdio_base = (void *)fdtdec_get_addr(fdt, mdio, "reg");
if (priv->link_type == LINK_TYPE_MAC_TO_PHY_MODE) { priv->phy_if = PHY_INTERFACE_MODE_SGMII; @@ -1002,11 +1083,51 @@ static int ks2_eth_ofdata_to_platdata(struct udevice *dev) priv->sgmii_link_type = SGMII_LINK_MAC_PHY; priv->has_mdio = true; } - pdata->iobase = dev_get_addr(dev);
- fdtdec_get_int_array(fdt, dev->of_offset, "ti,navigator-dmas", - dma_channel, 6); - priv->net_rx_buffs.rx_flow = dma_channel[1]; + return 0; +} + +static int ks2_sl_eth_ofdata_to_platdata(struct udevice *dev) +{ + struct ks2_eth_priv *priv = dev_get_priv(dev); + struct eth_pdata *pdata = dev_get_platdata(dev); + const void *fdt = gd->fdt_blob; + int slave = dev->of_offset; + int interfaces; + int gbe; + int netcp_devices; + int netcp; + + interfaces = fdt_parent_offset(fdt, slave); + gbe = fdt_parent_offset(fdt, interfaces); + netcp_devices = fdt_parent_offset(fdt, gbe); + netcp = fdt_parent_offset(fdt, netcp_devices); + + ks2_eth_parse_slave_interface(netcp, slave, priv, pdata); + + pdata->iobase = fdtdec_get_addr(fdt, netcp, "reg"); + + return 0; +} + +static int ks2_eth_ofdata_to_platdata(struct udevice *dev) +{ + struct ks2_eth_priv *priv = dev_get_priv(dev); + struct eth_pdata *pdata = dev_get_platdata(dev); + const void *fdt = gd->fdt_blob; + int gbe_0 = -ENODEV; + int netcp_devices; + int gbe; + + netcp_devices = fdt_subnode_offset(fdt, dev->of_offset, + "netcp-devices"); + gbe = fdt_subnode_offset(fdt, netcp_devices, "gbe"); + + ks2_eth_bind_slaves(dev, gbe, &gbe_0); + + ks2_eth_parse_slave_interface(dev->of_offset, gbe_0, priv, pdata); + + pdata->iobase = dev_get_addr(dev);
return 0; } @@ -1016,6 +1137,17 @@ static const struct udevice_id ks2_eth_ids[] = { { } };
+U_BOOT_DRIVER(eth_ks2_slave) = { + .name = "eth_ks2_sl", + .id = UCLASS_ETH, + .ofdata_to_platdata = ks2_sl_eth_ofdata_to_platdata, + .probe = ks2_eth_probe, + .remove = ks2_eth_remove, + .ops = &ks2_eth_ops, + .priv_auto_alloc_size = sizeof(struct ks2_eth_priv), + .platdata_auto_alloc_size = sizeof(struct eth_pdata), + .flags = DM_FLAG_ALLOC_PRIV_DMA, +};
U_BOOT_DRIVER(eth_ks2) = { .name = "eth_ks2",
There is only one ethernet mac address in e-fuse, but there are multiple slaves in keystone net, so enable random mac address support.
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- configs/k2hk_evm_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index 8623e1c..c050f07 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -37,3 +37,5 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y +CONFIG_LIB_RAND=y +CONFIG_NET_RANDOM_ETHADDR=y
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- configs/k2e_evm_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index 65561b1..04c52f0 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -37,3 +37,5 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y +CONFIG_LIB_RAND=y +CONFIG_NET_RANDOM_ETHADDR=y
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- configs/k2l_evm_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index 9aa429c..e1386f7 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -37,3 +37,5 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y +CONFIG_LIB_RAND=y +CONFIG_NET_RANDOM_ETHADDR=y
Mugunthan V N
