[U-Boot] U-Boot 1.3.4 CONFIG_SILENT_CONSOLE Does Not Work?
I'm using U-Boot 1.3.4. When building I've defined "CONFIG_SILENT_CONSOLE" and "CFG_DEVICE_NULLDEV". My board is an at91sam9261ek.
My U-Boot environment looks like this via "printenv":
bootargs=mem=64M console=ttyS0,115200 mtdparts=atmel_nand:4M(kernel)ro,-(rootfs) root=/dev/mtdblock1 rw rootfstype=jffs2 bootcmd=nand read 0x22200000 0x00000000 0x0019757C; bootm 0x22200000 bootdelay=1 baudrate=115200 silent=1
However when I boot my device I see u-boot spiting out the same stuff it does even if "silent" isn't selected, as well as linux but I'm focusing on getting u- boot working as the README / README.silent suggests first.
I know I've seen a few others on this group with the exact same problem as me, and the official response was "RTFM", but, unless I'm missing something hidden in the README's I need a little help, or there is a bug with u-boot.
Anyone can suggest something? Should "silent" be set to a specific variable? Is the stuff I see below normal for "silent", and it is working as it should?
This is what I get on the hyperterminal with the above configuration:
U-Boot 1.3.4 (Sep 30 2010 - 12:33:45)
DRAM: 64 MB NAND: 256 MiB DataFlash:AT45DB642 Nb pages: 8192 Page Size: 1056 Size= 8650752 bytes Logical address: 0xC0000000 Area 0: C0000000 to C00041FF (RO) Bootstrap Area 1: C0004200 to C00083FF Environment Area 2: C0008400 to C0041FFF (RO) U-Boot Area 3: C0042000 to C0251FFF Kernel Area 4: C0252000 to C083FFFF FS In: serial Out: serial Err: serial Hit any key to stop autoboot: 0
NAND read: device 0 offset 0x0, size 0x19757c 1668476 bytes read: OK ## Booting kernel from Legacy Image at 22200000 ... Image Name: Angstrom/2.6.30/at91sam9261ek Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 1668412 Bytes = 1.6 MB Load Address: 20008000 Entry Point: 20008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK
Starting kernel ...
Uncompressing Linux............................................................. ............................................... [[[.SNIP.]]]
Dear NB,
You are aware that U-Boot 1.3.4 is moe than 2 years old and as such hopelessly obsolete, aren't you? Don;t expect much help for ancient versions like this...
I can only comment on current code...
No. The actual value of the "silent" environment variable is not checked, only if it exists or not.
No, you are not supposed to see that output.
Wolfgang Denk <wd <at> denx.de> writes:
Yeah. I've tried U-Boot 2010-06 but it doesn't have 9g10 support yet *which my custom board is using*, so I think I'm forced to use the linux4sam updated u-boot 1.3.4, or to port the patches myself; but my tests right now were just with uboot 1.3.4 and a 9261ek.
Basically I just wanted to know if I'm doing everything right and not missing a step, since others have posted with my same problems ~2 years ago when 1.3.4 was current, and it sounded like it was working from the replys.
I'm guessing now there is/was a bug but maybe it has already been fixed. When I get some free time I can re-build oe's uboot 2010-06 with SILENT support to see if it is working for a 9261ek.
If someone remembers anything about the "old" 1.3.4 + silent feature do mention it :)
Thanks
ive seen issues depending on the env location. if the env cannot be loaded early, the *default env* is consulted for its silent settings, and then things "work" once the saved env is relocated.
might also want to check CONSOLE_IS_IN_ENV is enabled.
otherwise, your options are: - trace the code yourself - upgrade, and then trace the code yourself -mike
Mike Frysinger <vapier <at> gentoo.org> writes:
ive seen issues depending on the env location. if the env cannot be loaded early, the *default env* is consulted for its silent settings, and then "work" once the saved env is relocated.
Yeah I think you are right. CONSOLE_IS_IN_ENV is enabled for me, but at91sam9261ek also has CONFIG_SKIP_LOWLEVEL_INIT and CONFIG_SKIP_RELOCATE_UBOOT, so that RELOCATE issue is probably what is hindering me.
I looked at the console_init function (part where it is doing if(getenv("silent") != NULL)... and that is always returning null, even if it is set dynamically and rebooted.
What I did was change the check so it looks at a jumper instead of the getenv("silent") since this is what I wanted it to do anyway and it seems to all work now :).
I do notice that U-Boot is silencing everything except the "uncompressing kernel.............................." but I see the file related to that and should be able to fix it.
Thanks for your help.
Mike Frysinger
NB
