[U-Boot] [PATCH 0/2] Read default speed and mode values from DT
This serie generalize the commit 96907c0fe50a ("dm: spi: Read default speed and mode values from DT")
In case of DT boot, don't read default speed and mode for SPI from CONFIG_*, instead read from DT node. This will make sure that boards with multiple SPI/QSPI controllers can be probed at different bus frequencies and SPI modes.
Today it is only done in the command sf; this patch do the same for the other user of the spi_flash_probe(): spl and splash to avoid probe issue.
Patrick Delaunay (2): spl_spi: Read default speed and mode values from DT splash: sf: Read default speed and mode values from DT
common/spl/spl_spi.c | 9 ++++++++- common/splash_source.c | 8 ++++++++ 2 files changed, 16 insertions(+), 1 deletion(-)
Signed-off-by: Christophe Kerello christophe.kerello@st.com Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
common/spl/spl_spi.c | 9 ++++++++- 1 file changed, 8 insertions(+), 1 deletion(-)
diff --git a/common/spl/spl_spi.c b/common/spl/spl_spi.c index 8cd4830..3cefc9a 100644 --- a/common/spl/spl_spi.c +++ b/common/spl/spl_spi.c @@ -78,11 +78,18 @@ static int spl_spi_load_image(struct spl_image_info *spl_image, /* * Load U-Boot image from SPI flash into RAM */ - +#ifdef CONFIG_DM_SPI_FLASH + /* In DM mode defaults will be taken from DT */ + flash = spi_flash_probe(CONFIG_SF_DEFAULT_BUS, + CONFIG_SF_DEFAULT_CS, + 0, + 0); +#else flash = spi_flash_probe(CONFIG_SF_DEFAULT_BUS, CONFIG_SF_DEFAULT_CS, CONFIG_SF_DEFAULT_SPEED, CONFIG_SF_DEFAULT_MODE); +#endif if (!flash) { puts("SPI probe failed.\n"); return -ENODEV;
On Thu, Nov 8, 2018 at 5:58 PM Patrick Delaunay patrick.delaunay@st.com wrote:
0,
0);
Code duplication is never good. Wouldn't it be nicer to only have an #if for the two differing parameters (e.g. via local variables) instead of duplicating the function call?
Simon
+#else flash = spi_flash_probe(CONFIG_SF_DEFAULT_BUS, CONFIG_SF_DEFAULT_CS, CONFIG_SF_DEFAULT_SPEED, CONFIG_SF_DEFAULT_MODE); +#endif if (!flash) { puts("SPI probe failed.\n"); return -ENODEV; -- 2.7.4
Hi Simon,
From: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Sent: vendredi 9 novembre 2018 07:45 Subject: Re: [PATCH 1/2] spl_spi: Read default speed and mode values from DT Importance: High
*spl_image,
0,
0);
Ok. I take the point and I will update the patchset with local variable in v2. I just wait few day to be sure it is the only remark.
Simon
Regards Patrick
common/splash_source.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/common/splash_source.c b/common/splash_source.c index 62763b9..f0b3407 100644 --- a/common/splash_source.c +++ b/common/splash_source.c @@ -25,10 +25,18 @@ static struct spi_flash *sf; static int splash_sf_read_raw(u32 bmp_load_addr, int offset, size_t read_size) { if (!sf) { +#ifdef CONFIG_DM_SPI_FLASH + /* In DM mode defaults will be taken from DT */ + sf = spi_flash_probe(CONFIG_SF_DEFAULT_BUS, + CONFIG_SF_DEFAULT_CS, + 0, + 0); +#else sf = spi_flash_probe(CONFIG_SF_DEFAULT_BUS, CONFIG_SF_DEFAULT_CS, CONFIG_SF_DEFAULT_SPEED, CONFIG_SF_DEFAULT_MODE); +#endif if (!sf) return -ENODEV; }
Patrick DELAUNAY
Patrick Delaunay
Simon Goldschmidt
