[U-Boot] [PATCH]ppc4xx/Canyonlands added USB board callbacks
Functions added to support board callbacks for USB init. This isolates USB manipulations such that it is only touched if USB is used by U-Boot.
Signed-off-by: Dave Mitchell dmitchell@appliedmicro.com Signed-off-by: Rupjyoti Sarmah rsarmah@appliedmicro.com --- board/amcc/canyonlands/canyonlands.c | 79 +++++++++++++++++++++++++++------- include/configs/canyonlands.h | 1 + 2 files changed, 64 insertions(+), 16 deletions(-)
diff --git a/board/amcc/canyonlands/canyonlands.c b/board/amcc/canyonlands/canyonlands.c index 23874d2..2e30a32 100644 --- a/board/amcc/canyonlands/canyonlands.c +++ b/board/amcc/canyonlands/canyonlands.c @@ -34,6 +34,18 @@ extern flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; /* info for FLASH ch
DECLARE_GLOBAL_DATA_PTR;
+ +struct ep460c_bcsr { + u8 cpld_rev, + led_user, + board_status, + reset_ctrl, + flash_ctrl, + eth_ctrl, + usb_ctrl, + irq_ctrl; +}; + #define CONFIG_SYS_BCSR3_PCIE 0x10
#define BOARD_CANYONLANDS_PCIE 1 @@ -41,6 +53,14 @@ DECLARE_GLOBAL_DATA_PTR; #define BOARD_GLACIER 3 #define BOARD_ARCHES 4
+#define BCSR_CPLDREV 0x00 +#define BCSR_BRDSTS 0x03 +#define BCSR_FLASHCTRL 0x05 +#define BCSR_ETHCTRL 0x06 +#define BCSR_USBCTRL 0x07 +#define BCSR_USBCTRL_OTG_RST 0x32 +#define BCSR_USBCTRL_HOST_RST 0x01 + /* * Override the default functions in arch/powerpc/cpu/ppc4xx/44x_spd_ddr2.c with * board specific values. @@ -112,6 +132,9 @@ int board_early_init_f(void) { #if !defined(CONFIG_ARCHES) u32 sdr0_cust0; + struct ep460c_bcsr *bcsr_data = + (struct ep460c_bcsr *)CONFIG_SYS_BCSR_BASE; + #endif
/* @@ -172,13 +195,11 @@ int board_early_init_f(void)
#if !defined(CONFIG_ARCHES) /* Enable ethernet and take out of reset */ + out_8((void *)CONFIG_SYS_BCSR_BASE + 6, 0);
/* Remove NOR-FLASH, NAND-FLASH & EEPROM hardware write protection */ - out_8((void *)CONFIG_SYS_BCSR_BASE + 5, 0); - - /* Enable USB host & USB-OTG */ - out_8((void *)CONFIG_SYS_BCSR_BASE + 7, 0); + bcsr_data->flash_ctrl = 0;
mtsdr(SDR0_SRST1, 0); /* Pull AHB out of reset default=1 */
@@ -186,21 +207,45 @@ int board_early_init_f(void) mtdcr(AHB_TOP, 0x8000004B); mtdcr(AHB_BOT, 0x8000004B);
- if (pvr_460ex()) { - /* - * Configure USB-STP pins as alternate and not GPIO - * It seems to be neccessary to configure the STP pins as GPIO - * input at powerup (perhaps while USB reset is asserted). So - * we configure those pins to their "real" function now. - */ - gpio_config(16, GPIO_OUT, GPIO_ALT1, GPIO_OUT_1); - gpio_config(19, GPIO_OUT, GPIO_ALT1, GPIO_OUT_1); - } #endif
return 0; }
+#if defined(CONFIG_USB_OHCI_NEW) && defined(CONFIG_SYS_USB_OHCI_BOARD_INIT) +int usb_board_init(void) +{ + struct ep460c_bcsr *bcsr_data = + (struct ep460c_bcsr *)CONFIG_SYS_BCSR_BASE; + + /* Enable USB host & USB-OTG */ + bcsr_data->usb_ctrl &= ~(BCSR_USBCTRL_OTG_RST | BCSR_USBCTRL_HOST_RST); + + /* + * Configure USB-STP pins as alternate and not GPIO. + */ + gpio_config(16, GPIO_OUT, GPIO_ALT1, GPIO_OUT_1); + gpio_config(19, GPIO_OUT, GPIO_ALT1, GPIO_OUT_1); + + return 0; +} + +int usb_board_stop(void) +{ + struct ep460c_bcsr *bcsr_data = + (struct ep460c_bcsr *)CONFIG_SYS_BCSR_BASE; + + /* Disable USB host & USB-OTG */ + bcsr_data->usb_ctrl |= (BCSR_USBCTRL_OTG_RST | BCSR_USBCTRL_HOST_RST); + return 0; +} + +int usb_board_init_fail(void) +{ + return usb_board_stop(); +} +#endif /* CONFIG_USB_OHCI_NEW && CONFIG_SYS_USB_OHCI_BOARD_INIT */ + #if !defined(CONFIG_ARCHES) static void canyonlands_sata_init(int board_type) { @@ -244,11 +289,13 @@ int get_cpu_num(void) #if !defined(CONFIG_ARCHES) int checkboard(void) { + struct ep460c_bcsr *bcsr_data = + (struct ep460c_bcsr *)CONFIG_SYS_BCSR_BASE; char *s = getenv("serial#");
if (pvr_460ex()) { printf("Board: Canyonlands - AMCC PPC460EX Evaluation Board"); - if (in_8((void *)(CONFIG_SYS_BCSR_BASE + 3)) & CONFIG_SYS_BCSR3_PCIE) + if (bcsr_data->board_status & CONFIG_SYS_BCSR3_PCIE) gd->board_type = BOARD_CANYONLANDS_PCIE; else gd->board_type = BOARD_CANYONLANDS_SATA; @@ -268,7 +315,7 @@ int checkboard(void) break; }
- printf(", Rev. %X", in_8((void *)(CONFIG_SYS_BCSR_BASE + 0))); + printf(", Rev. %X", bcsr_data->cpld_rev);
if (s != NULL) { puts(", serial# "); diff --git a/include/configs/canyonlands.h b/include/configs/canyonlands.h index ac9b3c5..6a70160 100644 --- a/include/configs/canyonlands.h +++ b/include/configs/canyonlands.h @@ -417,6 +417,7 @@ #define CONFIG_SYS_USB_OHCI_REGS_BASE (CONFIG_SYS_AHB_BASE | 0xd0000) #define CONFIG_SYS_USB_OHCI_SLOT_NAME "ppc440" #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 15 +#define CONFIG_SYS_USB_OHCI_BOARD_INIT #endif
Dear Rupjyoti Sarmah,
- u8 cpld_rev,
led_user,
board_status,
reset_ctrl,
flash_ctrl,
eth_ctrl,
usb_ctrl,
irq_ctrl;
Please use standard style to describe structs, and mind indetation, i. e. write:
struct ep460c_bcsr { u8 cpld_rev, u8 led_user, u8 board_status, ... u8 irq_ctrl, };
CONFIG_SYS_* variable sshould not be defined in board code; they are intended to be used in board config files only.
Please add comments what these magic numbers do.
- out_8((void *)CONFIG_SYS_BCSR_BASE + 6, 0);
Remove this blank line, please.
- bcsr_data->flash_ctrl = 0;
NAK. Please always use proper I/O accessors to access device registers.
I am not sure if this is really a good idea to remove this code here.
- bcsr_data->usb_ctrl &= ~(BCSR_USBCTRL_OTG_RST | BCSR_USBCTRL_HOST_RST);
Please always use proper I/O accessors! Fix globally!
Isn't this too late? And maybe you want to keep the comment that explains what is being done, and why?
Thanks for your inputs. I will do the necessary changes are resubmit.
Regards, Rup
-----Original Message----- From: Wolfgang Denk [mailto:wd@denx.de] Sent: Thursday, June 17, 2010 1:24 AM To: Rupjyoti Sarmah Cc: u-boot@lists.denx.de; rupjyoti.sarmah@gmail.com; sr@denx.de; rsarmah@apm.com Subject: Re: [U-Boot] [PATCH]ppc4xx/Canyonlands added USB board callbacks
- u8 cpld_rev,
led_user,
board_status,
reset_ctrl,
flash_ctrl,
eth_ctrl,
usb_ctrl,
irq_ctrl;
GPIO
So
Rupjyoti Sarmah
Rupjyoti Sarmah
