[U-Boot] [PATCH] ARM: tegra: update colibri_t20 configuration
Bring the Colibri T20 configuration in-line with Apalis/Colibri T30. --- include/configs/colibri_t20.h | 31 +++++++++++++++++++++++++++---- 1 file changed, 27 insertions(+), 4 deletions(-)
diff --git a/include/configs/colibri_t20.h b/include/configs/colibri_t20.h index e80e9ed..c17f245 100644 --- a/include/configs/colibri_t20.h +++ b/include/configs/colibri_t20.h @@ -14,9 +14,12 @@ #define CONFIG_TEGRA_BOARD_STRING "Toradex Colibri T20"
/* Board-specific serial config */ +#define CONFIG_SERIAL_MULTI #define CONFIG_TEGRA_ENABLE_UARTA #define CONFIG_TEGRA_UARTA_SDIO1 -#define CONFIG_SYS_NS16550_COM1 NV_PA_APB_UARTA_BASE +#define CONFIG_SYS_NS16550_COM1 NV_PA_APB_UARTA_BASE + +#define CONFIG_MACH_TYPE MACH_TYPE_COLIBRI_T20
/* SD/MMC support */ #define CONFIG_MMC @@ -29,17 +32,17 @@ #define CONFIG_USB_EHCI_TEGRA #define CONFIG_USB_ULPI #define CONFIG_USB_ULPI_VIEWPORT -#define CONFIG_USB_STORAGE #define CONFIG_USB_MAX_CONTROLLER_COUNT 3 +#define CONFIG_USB_STORAGE #define CONFIG_CMD_USB
/* USB networking support */ #define CONFIG_USB_HOST_ETHER #define CONFIG_USB_ETHER_ASIX + +/* General networking support */ #define CONFIG_CMD_NET #define CONFIG_CMD_DHCP -#define CONFIG_CMD_NFS -#define CONFIG_CMD_PING
/* NAND support */ #define CONFIG_CMD_NAND @@ -56,6 +59,26 @@ #define CONFIG_CMD_BDI #define CONFIG_CMD_CACHE
+/* Miscellaneous commands */ +#define CONFIG_CMD_SETEXPR +#define CONFIG_FAT_WRITE + +/* Increase console I/O buffer size */ +#undef CONFIG_SYS_CBSIZE +#define CONFIG_SYS_CBSIZE 1024 + +/* Increase arguments buffer size */ +#undef CONFIG_SYS_BARGSIZE +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +/* Increase print buffer size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) + +/* Increase maximum number of arguments */ +#undef CONFIG_SYS_MAXARGS +#define CONFIG_SYS_MAXARGS 32 + +#include "tegra-common-usb-gadget.h" #include "tegra-common-post.h"
#endif /* __CONFIG_H */
Marcel Ziswiler
