[PATCH v4 00/11] Fixes for Rockchip NFC driver part 1
This serie contains fixes for the Rockchip NFC driver, which was ported to U-boot and merged with little review and testing it seems. Part 1 aims at passing the probe function without errors.
Fixed are: 64bit FDT parsing compatible string removal add missing layout structure add missing flash_node pointer add missing chip ID
Changed V4: fix cast and divider in syscon-uclass.c
Changed V3: use dev_read_addr_ptr fix oobfree
Johan Jonker (10): include: fdtdec: decouple fdt_addr_t and phys_addr_t size include: dm: ofnode: fix headers core: remap: convert regmap_init_mem_plat() input to phys_addr_t rockchip: adc: rockchip-saradc: use dev_read_addr_ptr rockchip: timer: dw-apb-timer: convert dev_read_addr output to phys_addr_t mtd: nand: raw: rockchip_nfc: use dev_read_addr_ptr mtd: nand: raw: rockchip_nfc: remove the compatible string "rockchip,rk3308-nfc" mtd: nand: raw: rockchip_nfc: add layout structure mtd: nand: raw: rockchip_nfc: add flash_node to chip structure mtd: nand: raw: rockchip_nfc: fix oobfree offset and description
Paweł Jarosz (1): mtd: nand: add support for the Sandisk SDTNQGAMA chip
Kconfig | 8 +++ drivers/adc/rockchip-saradc.c | 4 +- drivers/core/regmap.c | 2 +- drivers/core/syscon-uclass.c | 4 +- drivers/mtd/nand/raw/nand_ids.c | 3 ++ drivers/mtd/nand/raw/rockchip_nfc.c | 78 ++++++++++------------------- drivers/ram/rockchip/sdram_rk3066.c | 2 +- drivers/ram/rockchip/sdram_rk3188.c | 2 +- drivers/ram/rockchip/sdram_rk322x.c | 2 +- drivers/ram/rockchip/sdram_rk3288.c | 2 +- drivers/ram/rockchip/sdram_rk3328.c | 2 +- drivers/ram/rockchip/sdram_rk3399.c | 2 +- drivers/timer/dw-apb-timer.c | 4 +- include/dm/ofnode.h | 16 +++--- include/fdtdec.h | 13 +++-- include/regmap.h | 2 +- include/syscon.h | 13 ++--- 17 files changed, 76 insertions(+), 83 deletions(-)
-- 2.20.1
The DT specification supports CPUs with both 32-bit and 64-bit addressing capabilities. In U-boot the fdt_addr_t and phys_addr_t size are coupled by a typedef. The MTD NAND drivers for 32-bit CPU's can describe partitions with a 64-bit reg property. These partitions synced from Linux end up with the wrong offset and sizes when only the lower 32-bit is passed. Decouple the fdt_addr_t and phys_addr_t size as they don't necessary match.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Kever Yang kever.yang@rock-chips.com ---
Changed V2: reword
Note: Most drivers still assume that FDT and CPU capabilities are identical. In order to use these variables a cast is needed. --- Kconfig | 8 ++++++++ include/fdtdec.h | 13 +++++++++---- 2 files changed, 17 insertions(+), 4 deletions(-)
diff --git a/Kconfig b/Kconfig index a75cce7e..7697dade 100644 --- a/Kconfig +++ b/Kconfig @@ -422,11 +422,19 @@ endif # EXPERT
config PHYS_64BIT bool "64bit physical address support" + select FDT_64BIT help Say Y here to support 64bit physical memory address. This can be used not only for 64bit SoCs, but also for large physical address extension on 32bit SoCs.
+config FDT_64BIT + bool "64bit fdt address support" + help + Say Y here to support 64bit fdt addresses. + This can be used not only for 64bit SoCs, but also + for large address extensions on 32bit SoCs. + config HAS_ROM bool select BINMAN diff --git a/include/fdtdec.h b/include/fdtdec.h index 12355afd..af29ac0c 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -18,15 +18,18 @@ #include <pci.h>
/* - * A typedef for a physical address. Note that fdt data is always big + * Support for 64bit fdt addresses. + * This can be used not only for 64bit SoCs, but also + * for large address extensions on 32bit SoCs. + * Note that fdt data is always big * endian even on a litle endian machine. */ -typedef phys_addr_t fdt_addr_t; -typedef phys_size_t fdt_size_t;
#define FDT_SIZE_T_NONE (-1U)
-#ifdef CONFIG_PHYS_64BIT +#ifdef CONFIG_FDT_64BIT +typedef u64 fdt_addr_t; +typedef u64 fdt_size_t; #define FDT_ADDR_T_NONE ((ulong)(-1))
#define fdt_addr_to_cpu(reg) be64_to_cpu(reg) @@ -35,6 +38,8 @@ typedef phys_size_t fdt_size_t; #define cpu_to_fdt_size(reg) cpu_to_be64(reg) typedef fdt64_t fdt_val_t; #else +typedef u32 fdt_addr_t; +typedef u32 fdt_size_t; #define FDT_ADDR_T_NONE (-1U)
#define fdt_addr_to_cpu(reg) be32_to_cpu(reg) -- 2.20.1
Hi Johan,
This update will cause below error on evb-ast2500/2600:
$ tools/buildman/buildman -o ${UBOOT_TRAVIS_BUILD_DIR} -w -E -W -e --board ${TEST_PY_BD} ${OVERRIDE} Building current source for 1 boards (1 thread, 24 jobs per thread) arm: + evb-ast2600 +drivers/spi/spi-aspeed-smc.c: In function 'apseed_spi_of_to_plat': +drivers/spi/spi-aspeed-smc.c:1154:22: error: format '%lx' expects argument of type 'long unsigned int', but argument 4 has type 'fdt_size_t' {aka 'unsigned int'} [-Werror=format=] + 1154 | dev_dbg(bus, "ctrl_base = 0x%x, ahb_base = 0x%p, size = 0x%lx\n", + | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ + 1155 | (u32)priv->regs, plat->ahb_base, plat->ahb_sz); + | ~~~~~~~~~~~~ + | | + | fdt_size_t {aka unsigned int} +include/dm/device_compat.h:50:24: note: in definition of macro 'dev_printk_emit' + 50 | printf(fmt, ##__VA_ARGS__); \ + | ^~~ +include/dm/device_compat.h:117:9: note: in expansion of macro '__dev_printk' + 117 | __dev_printk(LOGL_DEBUG, dev, fmt, ##__VA_ARGS__) + | ^~~~~~~~~~~~ +drivers/spi/spi-aspeed-smc.c:1154:9: note: in expansion of macro 'dev_dbg' + | ^~~~~~~ +drivers/spi/spi-aspeed-smc.c:1154:69: note: format string is defined here + | ~~^ + | | + | long unsigned int + | %x +In file included from include/linux/printk.h:4, + from include/linux/kernel.h:5, + from arch/arm/include/asm/io.h:14, + from drivers/spi/spi-aspeed-smc.c:13: +include/log.h:222:24: note: in definition of macro 'log' + 222 | printf(_fmt, ##_args); \ + | ^~~~ +include/dm/device_compat.h:85:17: note: in expansion of macro 'dev_printk_emit' + 85 | dev_printk_emit(LOG_CATEGORY, level, fmt, ##__VA_ARGS__); \ + | ^~~~~~~~~~~~~~~ +include/dm/device_compat.h:54:24: note: in definition of macro 'dev_printk_emit' + 54 | printf(fmt, ##__VA_ARGS__); \ +include/dm/device_compat.h:91:41: error: format '%lx' expects argument of type 'long unsigned int', but argument 6 has type 'fdt_size_t' {aka 'unsigned int'} [-Werror=format=] + 91 | "%s %s: " fmt, \ + | ^~~~~~~~~ +include/dm/device_compat.h:90:25: note: in expansion of macro 'dev_printk_emit' + 90 | dev_printk_emit(__dev->driver->id, level, \ + | ^~~~~~~~~~~~~~~ +include/dm/device_compat.h:96:41: error: format '%lx' expects argument of type 'long unsigned int', but argument 6 has type 'fdt_size_t' {aka 'unsigned int'} [-Werror=format=] + 96 | "%s %s: " fmt, \ +include/dm/device_compat.h:95:25: note: in expansion of macro 'dev_printk_emit' + 95 | dev_printk_emit(LOG_CATEGORY, level, \ +cc1: all warnings being treated as errors +make[3]: *** [scripts/Makefile.build:256: drivers/spi/spi-aspeed-smc.o] Error 1 +make[2]: *** [scripts/Makefile.build:397: drivers/spi] Error 2 +make[1]: *** [Makefile:1846: drivers] Error 2 +make: *** [Makefile:177: sub-make] Error 2 0 0 1 /1 evb-ast2600
Thanks,
- Kever
Changed V2: reword
- select FDT_64BIT help Say Y here to support 64bit physical memory address. This can be used not only for 64bit SoCs, but also for large physical address extension on 32bit SoCs.
+config FDT_64BIT
- bool "64bit fdt address support"
- help
- config HAS_ROM bool select BINMAN
- A typedef for a physical address. Note that fdt data is always big
- Support for 64bit fdt addresses.
- This can be used not only for 64bit SoCs, but also
- for large address extensions on 32bit SoCs.
- Note that fdt data is always big
- endian even on a litle endian machine.
2.20.1
The fdt_addr_t and phys_addr_t size have been decoupled. A 32bit CPU can expect 64-bit data from the device tree parser, so convert devfdt_get_addr_index output to phys_addr_t in the spi-aspeed-smc.c file. Also fix dev_dbg to be able to handle both sizes.
Signed-off-by: Johan Jonker jbx6244@gmail.com ---
Note:
This is needed for a Rockchip patch serie to pass the test and must be merged before by Rockchip maintainers:
[PATCH v4 00/11] Fixes for Rockchip NFC driver part 1 https://lore.kernel.org/u-boot/f3dba231-4a55-0a94-dfab-5cab1419d132@gmail.co...
Request for hardware test by Aspeed people. --- drivers/spi/spi-aspeed-smc.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/spi/spi-aspeed-smc.c b/drivers/spi/spi-aspeed-smc.c index a3c96333..17696441 100644 --- a/drivers/spi/spi-aspeed-smc.c +++ b/drivers/spi/spi-aspeed-smc.c @@ -1125,14 +1125,14 @@ static int apseed_spi_of_to_plat(struct udevice *bus) int ret; struct clk hclk;
- priv->regs = (void __iomem *)devfdt_get_addr_index(bus, 0); + priv->regs = (void __iomem *)((phys_addr_t)devfdt_get_addr_index(bus, 0)); if ((u32)priv->regs == FDT_ADDR_T_NONE) { dev_err(bus, "wrong ctrl base\n"); return -ENODEV; }
plat->ahb_base = - (void __iomem *)devfdt_get_addr_size_index(bus, 1, &plat->ahb_sz); + (void __iomem *)((phys_addr_t)devfdt_get_addr_size_index(bus, 1, &plat->ahb_sz)); if ((u32)plat->ahb_base == FDT_ADDR_T_NONE) { dev_err(bus, "wrong AHB base\n"); return -ENODEV; @@ -1151,8 +1151,8 @@ static int apseed_spi_of_to_plat(struct udevice *bus) plat->hclk_rate = clk_get_rate(&hclk); clk_free(&hclk);
- dev_dbg(bus, "ctrl_base = 0x%x, ahb_base = 0x%p, size = 0x%lx\n", - (u32)priv->regs, plat->ahb_base, plat->ahb_sz); + dev_dbg(bus, "ctrl_base = 0x%x, ahb_base = 0x%p, size = 0x%llx\n", + (u32)priv->regs, plat->ahb_base, (fdt64_t)plat->ahb_sz); dev_dbg(bus, "hclk = %dMHz, max_cs = %d\n", plat->hclk_rate / 1000000, plat->max_cs);
-- 2.20.1
Hi Johan
Note:
devfdt_get_addr_index_ptr is not the right way?
if ((u32)priv->regs == FDT_ADDR_T_NONE) { dev_err(bus, "wrong ctrl base\n"); return -ENODEV; } plat->ahb_base =
devfdt_get_addr_index_ptr, same here
Michael
2.20.1
On 2/25/23 10:26, Michael Nazzareno Trimarchi wrote:
Hi Johan
Note:
That may work.
fdt_addr_t devfdt_get_addr_size_index(const struct udevice *dev, int index, fdt_size_t *size) vs
void *devfdt_get_addr_index_ptr(const struct udevice *dev, int index)
devfdt_get_addr_index_ptr does not offer the ahb_sz size.
https://elixir.bootlin.com/u-boot/latest/source/drivers/core/fdtaddr.c#L112
This function is used for that in devfdt_get_addr_size_index:
fdtdec_get_addr_size_auto_noparent(gd->fdt_blob, dev_of_offset(dev), "reg", index, size, false);
What would you suggest? Keep the cast or use fdtdec_get_addr_size_auto_noparent ?
I'm a little bit "reluctant" to poke in code that I don't have hardware for.
Johan
Michael
2.20.1
Hi Johan
Hi Johan
Note:
That may work.
Something like this
diff --git a/drivers/core/fdtaddr.c b/drivers/core/fdtaddr.c index 91bcd1a2c2..d18749c3fd 100644 --- a/drivers/core/fdtaddr.c +++ b/drivers/core/fdtaddr.c @@ -122,6 +122,14 @@ fdt_addr_t devfdt_get_addr_size_index(const struct udevice *dev, int index, #endif }
+void *devfdt_get_addr_size_index_ptr(const struct udevice *dev, int index, + fdt_size_t *size) +{ + fdt_addr_t addr = devfdt_get_addr_size_index(dev, index, size); + + return (addr == FDT_ADDR_T_NONE) ? NULL : (void *)(uintptr_t)addr; +} +
Michael
Johan
Michael
2.20.1
Hi Johan
On Sat, Feb 25, 2023 at 10:53 AM Michael Nazzareno Trimarchi michael@amarulasolutions.com wrote:
Hi Johan
Hi Johan
Note:
That may work.
Something like this
fdt_size_t *size)
Michael
Is this ok? if so you can repost with changes
Michael
Johan
Michael
2.20.1
-- Michael Nazzareno Trimarchi Co-Founder & Chief Executive Officer M. +39 347 913 2170 michael@amarulasolutions.com __________________________________
Amarula Solutions BV Joop Geesinkweg 125, 1114 AB, Amsterdam, NL T. +31 (0)85 111 9172 info@amarulasolutions.com www.amarulasolutions.com
On 2/23/23 01:47, Kever Yang wrote:
Hi Johan,
Hi Kever, Simon,
For "spi-aspeed-smc.c" I have submitted a patch proposal. The changes in patch 1 possible involves a lot more boards that might need a change to which the external MAINTAINERS may or may not respond to. As that becomes a lengthy time consuming process. Is it maybe possible to skip patch 1 for now and get at least the more essential patches 2-11 merged? Please advise what's the best option here to get forward.
Johan
- 1154 | dev_dbg(bus, "ctrl_base = 0x%x, ahb_base = 0x%p, size = 0x%lx\n",
- 1155 | (u32)priv->regs, plat->ahb_base, plat->ahb_sz);
- | long unsigned int
- | %x
Thanks,
- Kever
Changed V2: reword
2.20.1
Hi Johan
Hi Johan,
Hi Kever, Simon,
Johan
Please point to the patch you mentioned.
Kever if you are going to pick the nand patches part let me know
Michael
- 50 | printf(fmt, ##__VA_ARGS__); \
- 117 | __dev_printk(LOGL_DEBUG, dev, fmt, ##__VA_ARGS__)
- | %x
- 222 | printf(_fmt, ##_args); \
- 85 | dev_printk_emit(LOG_CATEGORY, level, fmt, ##__VA_ARGS__); \
- 54 | printf(fmt, ##__VA_ARGS__); \
- 91 | "%s %s: " fmt, \
- 90 | dev_printk_emit(__dev->driver->id, level, \
- 96 | "%s %s: " fmt, \
- 95 | dev_printk_emit(LOG_CATEGORY, level, \
Thanks,
- Kever
Changed V2: reword
+config FDT_64BIT
- help
2.20.1
On 2/25/23 10:15, Michael Nazzareno Trimarchi wrote:
Hi Johan
Hi Johan,
Hi Kever, Simon,
Johan
[PATCH v1] spi: spi-aspeed-smc: convert devfdt_get_addr_index output to phys_addr_t https://lore.kernel.org/u-boot/f3dba231-4a55-0a94-dfab-5cab1419d132@gmail.co...
Michael
- | %x
Thanks,
- Kever
Changed V2: reword
+config FDT_64BIT
- help
2.20.1
Add devfdt_get_addr_size_index_ptr function with the same functionality as devfdt_get_addr_size_index, but instead a return pointer is given.
Suggested-by: Michael Nazzareno Trimarchi michael@amarulasolutions.com Signed-off-by: Johan Jonker jbx6244@gmail.com --- drivers/core/fdtaddr.c | 8 ++++++++ include/dm/fdtaddr.h | 15 +++++++++++++++ 2 files changed, 23 insertions(+)
diff --git a/drivers/core/fdtaddr.c b/drivers/core/fdtaddr.c index 91bcd1a2..84bb8d8b 100644 --- a/drivers/core/fdtaddr.c +++ b/drivers/core/fdtaddr.c @@ -122,6 +122,14 @@ fdt_addr_t devfdt_get_addr_size_index(const struct udevice *dev, int index, #endif }
+void *devfdt_get_addr_size_index_ptr(const struct udevice *dev, int index, + fdt_size_t *size) +{ + fdt_addr_t addr = devfdt_get_addr_size_index(dev, index, size); + + return (addr == FDT_ADDR_T_NONE) ? NULL : (void *)(uintptr_t)addr; +} + fdt_addr_t devfdt_get_addr_name(const struct udevice *dev, const char *name) { #if CONFIG_IS_ENABLED(OF_CONTROL) diff --git a/include/dm/fdtaddr.h b/include/dm/fdtaddr.h index c9d2b27b..7fc3ea5c 100644 --- a/include/dm/fdtaddr.h +++ b/include/dm/fdtaddr.h @@ -119,6 +119,21 @@ void *devfdt_get_addr_index_ptr(const struct udevice *dev, int index); fdt_addr_t devfdt_get_addr_size_index(const struct udevice *dev, int index, fdt_size_t *size);
+/** + * devfdt_get_addr_size_index_ptr() - Return indexed pointer to the address of the + * reg property of a device + * + * @dev: Pointer to a device + * @index: the 'reg' property can hold a list of <addr, size> pairs + * and @index is used to select which one is required + * @size: Pointer to size varible - this function returns the size + * specified in the 'reg' property here + * + * Return: Pointer to addr, or NULL if there is no such property + */ +void *devfdt_get_addr_size_index_ptr(const struct udevice *dev, int index, + fdt_size_t *size); + /** * devfdt_get_addr_name() - Get the reg property of a device, indexed by name * -- 2.20.1
The fdt_addr_t and phys_addr_t size have been decoupled. A 32bit CPU can expect 64-bit data from the device tree parser, so use devfdt_get_addr_index_ptr and devfdt_get_addr_size_index_ptr function in the spi-aspeed-smc.c file. Also fix dev_dbg to be able to handle both sizes.
Note:
Changed V2: Use devfdt_get_addr_index_ptr and devfdt_get_addr_size_index_ptr --- drivers/spi/spi-aspeed-smc.c | 13 ++++++------- 1 file changed, 6 insertions(+), 7 deletions(-)
diff --git a/drivers/spi/spi-aspeed-smc.c b/drivers/spi/spi-aspeed-smc.c index a3c96333..fedcaad6 100644 --- a/drivers/spi/spi-aspeed-smc.c +++ b/drivers/spi/spi-aspeed-smc.c @@ -1125,15 +1125,14 @@ static int apseed_spi_of_to_plat(struct udevice *bus) int ret; struct clk hclk;
- priv->regs = (void __iomem *)devfdt_get_addr_index(bus, 0); - if ((u32)priv->regs == FDT_ADDR_T_NONE) { + priv->regs = devfdt_get_addr_index_ptr(bus, 0); + if (!priv->regs) { dev_err(bus, "wrong ctrl base\n"); return -ENODEV; }
- plat->ahb_base = - (void __iomem *)devfdt_get_addr_size_index(bus, 1, &plat->ahb_sz); - if ((u32)plat->ahb_base == FDT_ADDR_T_NONE) { + plat->ahb_base = devfdt_get_addr_size_index_ptr(bus, 1, &plat->ahb_sz); + if (!plat->ahb_base) { dev_err(bus, "wrong AHB base\n"); return -ENODEV; } @@ -1151,8 +1150,8 @@ static int apseed_spi_of_to_plat(struct udevice *bus) plat->hclk_rate = clk_get_rate(&hclk); clk_free(&hclk);
-- 2.20.1
Hi
Note:
plat->ahb_base =
-- 2.20.1
Reviewed-By: Michael Trimarchi michael@amarulasolutions.com
Hi
fdt_size_t *size)
- devfdt_get_addr_size_index_ptr() - Return indexed pointer to the address of the
- @dev: Pointer to a device
- @index: the 'reg' property can hold a list of <addr, size> pairs
- @size: Pointer to size varible - this function returns the size
- Return: Pointer to addr, or NULL if there is no such property
fdt_size_t *size);
- devfdt_get_addr_name() - Get the reg property of a device, indexed by name
-- 2.20.1
Reviewed-by: Michael Trimarchi michael@amarulasolutions.com
Hi Johan
On Sat, Feb 25, 2023 at 12:47 PM Michael Nazzareno Trimarchi michael@amarulasolutions.com wrote:
Hi
[snip]
fdt_size_t *size);
-- 2.20.1
git grep "== FDT_ADDR_T_NONE"
I think using both function some of use cases can be rewritten now
MIchael
The fdt_addr_t and phys_addr_t size have been decoupled. A 32bit CPU can expect 64-bit data from the device tree parser, so use dev_read_addr_index_ptr instead of the dev_read_addr_index function in the various files in the drivers directory that cast to a pointer.
Note:
Replacement command used: find . -type f -exec sed -i 's/*)dev_read_addr_index(/ *)dev_read_addr_index_ptr(/g' {} + --- drivers/mtd/nand/raw/cortina_nand.c | 4 ++-- drivers/net/dm9000x.c | 2 +- drivers/net/dwmac_meson8b.c | 4 ++-- drivers/pci/pcie_dw_meson.c | 4 ++-- drivers/pci/pcie_dw_rockchip.c | 4 ++-- drivers/watchdog/sbsa_gwdt.c | 12 ++++++------ 6 files changed, 15 insertions(+), 15 deletions(-)
diff --git a/drivers/mtd/nand/raw/cortina_nand.c b/drivers/mtd/nand/raw/cortina_nand.c index 88798f23..b03f3821 100644 --- a/drivers/mtd/nand/raw/cortina_nand.c +++ b/drivers/mtd/nand/raw/cortina_nand.c @@ -1175,8 +1175,8 @@ static int fdt_decode_nand(struct udevice *dev, struct nand_drv *info) int ecc_strength;
info->reg = (struct nand_ctlr *)dev_read_addr(dev); - info->dma_glb = (struct dma_global *)dev_read_addr_index(dev, 1); - info->dma_nand = (struct dma_ssp *)dev_read_addr_index(dev, 2); + info->dma_glb = (struct dma_global *)dev_read_addr_index_ptr(dev, 1); + info->dma_nand = (struct dma_ssp *)dev_read_addr_index_ptr(dev, 2); info->config.enabled = dev_read_enabled(dev); ecc_strength = dev_read_u32_default(dev, "nand-ecc-strength", 16); info->flash_base = diff --git a/drivers/net/dm9000x.c b/drivers/net/dm9000x.c index b46bdeb2..5855f16b 100644 --- a/drivers/net/dm9000x.c +++ b/drivers/net/dm9000x.c @@ -651,7 +651,7 @@ static int dm9000_of_to_plat(struct udevice *dev)
pdata->iobase = dev_read_addr_index(dev, 0); db->base_io = (void __iomem *)pdata->iobase; - db->base_data = (void __iomem *)dev_read_addr_index(dev, 1); + db->base_data = (void __iomem *)dev_read_addr_index_ptr(dev, 1);
return 0; } diff --git a/drivers/net/dwmac_meson8b.c b/drivers/net/dwmac_meson8b.c index ddbaa87d..871171e1 100644 --- a/drivers/net/dwmac_meson8b.c +++ b/drivers/net/dwmac_meson8b.c @@ -41,8 +41,8 @@ static int dwmac_meson8b_of_to_plat(struct udevice *dev) { struct dwmac_meson8b_plat *pdata = dev_get_plat(dev);
- pdata->regs = (void *)dev_read_addr_index(dev, 1); - if ((fdt_addr_t)pdata->regs == FDT_ADDR_T_NONE) + pdata->regs = dev_read_addr_index_ptr(dev, 1); + if (!pdata->regs) return -EINVAL;
pdata->dwmac_setup = (void *)dev_get_driver_data(dev); diff --git a/drivers/pci/pcie_dw_meson.c b/drivers/pci/pcie_dw_meson.c index 07da9fa5..59567883 100644 --- a/drivers/pci/pcie_dw_meson.c +++ b/drivers/pci/pcie_dw_meson.c @@ -337,13 +337,13 @@ static int meson_pcie_parse_dt(struct udevice *dev) struct meson_pcie *priv = dev_get_priv(dev); int ret;
- priv->dw.dbi_base = (void *)dev_read_addr_index(dev, 0); + priv->dw.dbi_base = dev_read_addr_index_ptr(dev, 0); if (!priv->dw.dbi_base) return -ENODEV;
dev_dbg(dev, "ELBI address is 0x%p\n", priv->dw.dbi_base);
- priv->meson_cfg_base = (void *)dev_read_addr_index(dev, 1); + priv->meson_cfg_base = dev_read_addr_index_ptr(dev, 1); if (!priv->meson_cfg_base) return -ENODEV;
diff --git a/drivers/pci/pcie_dw_rockchip.c b/drivers/pci/pcie_dw_rockchip.c index 9322e735..2608106b 100644 --- a/drivers/pci/pcie_dw_rockchip.c +++ b/drivers/pci/pcie_dw_rockchip.c @@ -353,13 +353,13 @@ static int rockchip_pcie_parse_dt(struct udevice *dev) struct rk_pcie *priv = dev_get_priv(dev); int ret;
dev_dbg(dev, "DBI address is 0x%p\n", priv->dw.dbi_base);
- priv->apb_base = (void *)dev_read_addr_index(dev, 1); + priv->apb_base = dev_read_addr_index_ptr(dev, 1); if (!priv->apb_base) return -ENODEV;
diff --git a/drivers/watchdog/sbsa_gwdt.c b/drivers/watchdog/sbsa_gwdt.c index f43cd3fd..ef402898 100644 --- a/drivers/watchdog/sbsa_gwdt.c +++ b/drivers/watchdog/sbsa_gwdt.c @@ -98,13 +98,13 @@ static int sbsa_gwdt_of_to_plat(struct udevice *dev) { struct sbsa_gwdt_priv *priv = dev_get_priv(dev);
- priv->reg_control = (void __iomem *)dev_read_addr_index(dev, 0); - if (IS_ERR(priv->reg_control)) - return PTR_ERR(priv->reg_control); + priv->reg_control = (void __iomem *)dev_read_addr_index_ptr(dev, 0); + if (!priv->reg_control) + return -EINVAL;
- priv->reg_refresh = (void __iomem *)dev_read_addr_index(dev, 1); - if (IS_ERR(priv->reg_refresh)) - return PTR_ERR(priv->reg_refresh); + priv->reg_refresh = (void __iomem *)dev_read_addr_index_ptr(dev, 1); + if (!priv->reg_refresh) + return -EINVAL;
return 0; } -- 2.20.1
The fdt_addr_t and phys_addr_t size have been decoupled. A 32bit CPU can expect 64-bit data from the device tree parser, so use dev_read_addr_ptr instead of the dev_read_addr function in the various files in the drivers directory that cast to a pointer.
Note:
Replacement command used: find . -type f -exec sed -i 's/*)dev_read_addr(/ *)dev_read_addr_ptr(/g' {} + --- drivers/ata/dwc_ahsata.c | 2 +- drivers/cache/cache-l2x0.c | 2 +- drivers/cache/cache-v5l2.c | 2 +- drivers/gpio/mscc_sgpio.c | 2 +- drivers/gpio/tegra_gpio.c | 4 ++-- drivers/gpio/xilinx_gpio.c | 2 +- drivers/i2c/i2c-cdns.c | 2 +- drivers/i2c/tegra_i2c.c | 4 ++-- drivers/mmc/am654_sdhci.c | 2 +- drivers/mmc/davinci_mmc.c | 2 +- drivers/mmc/piton_mmc.c | 2 +- drivers/mmc/tegra_mmc.c | 2 +- drivers/mmc/zynq_sdhci.c | 6 +++--- drivers/mtd/nand/raw/arasan_nfc.c | 2 +- drivers/mtd/nand/raw/cortina_nand.c | 2 +- drivers/mtd/nand/raw/mxic_nand.c | 2 +- drivers/mtd/nand/raw/tegra_nand.c | 2 +- drivers/mtd/nand/raw/zynq_nand.c | 2 +- drivers/net/mvmdio.c | 2 +- drivers/net/qe/dm_qe_uec_phy.c | 2 +- drivers/pci/pci-aardvark.c | 4 ++-- drivers/phy/allwinner/phy-sun50i-usb3.c | 6 +++--- drivers/phy/qcom/phy-qcom-usb-hs-28nm.c | 4 ++-- drivers/phy/qcom/phy-qcom-usb-ss.c | 4 ++-- drivers/phy/rockchip/phy-rockchip-snps-pcie3.c | 4 ++-- drivers/phy/rockchip/phy-rockchip-typec.c | 6 +++--- drivers/pwm/tegra_pwm.c | 2 +- drivers/serial/serial_zynq.c | 6 +++--- drivers/spi/mpc8xxx_spi.c | 2 +- drivers/spi/mscc_bb_spi.c | 2 +- drivers/spi/sh_qspi.c | 2 +- drivers/spi/spi-mxic.c | 2 +- drivers/spi/xilinx_spi.c | 2 +- drivers/ufs/ufs.c | 2 +- drivers/usb/host/ehci-tegra.c | 2 +- drivers/video/dw_mipi_dsi.c | 4 ++-- drivers/video/rockchip/rk_vop.c | 2 +- drivers/video/stm32/stm32_dsi.c | 4 ++-- drivers/video/stm32/stm32_ltdc.c | 4 ++-- drivers/video/tegra124/display.c | 2 +- drivers/video/tegra124/sor.c | 6 +++--- drivers/watchdog/cdns_wdt.c | 6 +++--- drivers/watchdog/sp805_wdt.c | 6 +++--- drivers/watchdog/xilinx_tb_wdt.c | 6 +++--- 44 files changed, 69 insertions(+), 69 deletions(-)
diff --git a/drivers/ata/dwc_ahsata.c b/drivers/ata/dwc_ahsata.c index 167b5a39..9ed7348b 100644 --- a/drivers/ata/dwc_ahsata.c +++ b/drivers/ata/dwc_ahsata.c @@ -912,7 +912,7 @@ int dwc_ahsata_probe(struct udevice *dev) #endif uc_priv->host_flags = ATA_FLAG_SATA | ATA_FLAG_NO_LEGACY | ATA_FLAG_MMIO | ATA_FLAG_PIO_DMA | ATA_FLAG_NO_ATAPI; - uc_priv->mmio_base = (void __iomem *)dev_read_addr(dev); + uc_priv->mmio_base = (void __iomem *)dev_read_addr_ptr(dev);
/* initialize adapter */ ret = ahci_host_init(uc_priv); diff --git a/drivers/cache/cache-l2x0.c b/drivers/cache/cache-l2x0.c index a1556fbf..70b31899 100644 --- a/drivers/cache/cache-l2x0.c +++ b/drivers/cache/cache-l2x0.c @@ -13,7 +13,7 @@ static void l2c310_of_parse_and_init(struct udevice *dev) { u32 tag[3] = { 0, 0, 0 }; u32 saved_reg, prefetch; - struct pl310_regs *regs = (struct pl310_regs *)dev_read_addr(dev); + struct pl310_regs *regs = (struct pl310_regs *)dev_read_addr_ptr(dev);
/* Disable the L2 Cache */ clrbits_le32(®s->pl310_ctrl, L2X0_CTRL_EN); diff --git a/drivers/cache/cache-v5l2.c b/drivers/cache/cache-v5l2.c index bbdb76bd..fd7dd51b 100644 --- a/drivers/cache/cache-v5l2.c +++ b/drivers/cache/cache-v5l2.c @@ -110,7 +110,7 @@ static int v5l2_of_to_plat(struct udevice *dev) struct v5l2_plat *plat = dev_get_plat(dev); struct l2cache *regs;
- regs = (struct l2cache *)dev_read_addr(dev); + regs = (struct l2cache *)dev_read_addr_ptr(dev); plat->regs = regs;
plat->iprefetch = -EINVAL; diff --git a/drivers/gpio/mscc_sgpio.c b/drivers/gpio/mscc_sgpio.c index 1cbcc434..980f9f1e 100644 --- a/drivers/gpio/mscc_sgpio.c +++ b/drivers/gpio/mscc_sgpio.c @@ -232,7 +232,7 @@ static int mscc_sgpio_probe(struct udevice *dev) debug("probe: gpios = %d, bit-count = %d\n", uc_priv->gpio_count, priv->bitcount);
- priv->regs = (u32 __iomem *)dev_read_addr(dev); + priv->regs = (u32 __iomem *)dev_read_addr_ptr(dev); uc_priv->bank_name = "sgpio";
sgpio_clrsetbits(priv, REG_SIO_CONFIG, 0, diff --git a/drivers/gpio/tegra_gpio.c b/drivers/gpio/tegra_gpio.c index 4291e496..f7a41b39 100644 --- a/drivers/gpio/tegra_gpio.c +++ b/drivers/gpio/tegra_gpio.c @@ -339,8 +339,8 @@ static int gpio_tegra_bind(struct udevice *parent) if (len < 0) return len; bank_count = len / 3 / sizeof(u32); - ctlr = (struct gpio_ctlr *)dev_read_addr(parent); - if ((ulong)ctlr == FDT_ADDR_T_NONE) + ctlr = (struct gpio_ctlr *)dev_read_addr_ptr(parent); + if (!ctlr) return -EINVAL; } #endif diff --git a/drivers/gpio/xilinx_gpio.c b/drivers/gpio/xilinx_gpio.c index 510838d2..55ae0536 100644 --- a/drivers/gpio/xilinx_gpio.c +++ b/drivers/gpio/xilinx_gpio.c @@ -268,7 +268,7 @@ static int xilinx_gpio_of_to_plat(struct udevice *dev) struct xilinx_gpio_plat *plat = dev_get_plat(dev); int is_dual;
- plat->regs = (struct gpio_regs *)dev_read_addr(dev); + plat->regs = (struct gpio_regs *)dev_read_addr_ptr(dev);
plat->bank_max[0] = dev_read_u32_default(dev, "xlnx,gpio-width", 0); plat->bank_input[0] = dev_read_u32_default(dev, "xlnx,all-inputs", 0); diff --git a/drivers/i2c/i2c-cdns.c b/drivers/i2c/i2c-cdns.c index 0da9f6f3..f3d05cb4 100644 --- a/drivers/i2c/i2c-cdns.c +++ b/drivers/i2c/i2c-cdns.c @@ -477,7 +477,7 @@ static int cdns_i2c_of_to_plat(struct udevice *dev) struct clk clk; int ret;
- i2c_bus->regs = (struct cdns_i2c_regs *)dev_read_addr(dev); + i2c_bus->regs = (struct cdns_i2c_regs *)dev_read_addr_ptr(dev); if (!i2c_bus->regs) return -ENOMEM;
diff --git a/drivers/i2c/tegra_i2c.c b/drivers/i2c/tegra_i2c.c index 2394e9d0..7e3a2da1 100644 --- a/drivers/i2c/tegra_i2c.c +++ b/drivers/i2c/tegra_i2c.c @@ -364,8 +364,8 @@ static int tegra_i2c_probe(struct udevice *dev)
i2c_bus->id = dev_seq(dev); i2c_bus->type = dev_get_driver_data(dev); - i2c_bus->regs = (struct i2c_ctlr *)dev_read_addr(dev); - if ((ulong)i2c_bus->regs == FDT_ADDR_T_NONE) { + i2c_bus->regs = (struct i2c_ctlr *)dev_read_addr_ptr(dev); + if (!i2c_bus->regs) { debug("%s: Cannot get regs address\n", __func__); return -EINVAL; } diff --git a/drivers/mmc/am654_sdhci.c b/drivers/mmc/am654_sdhci.c index 42a61343..fd667aea 100644 --- a/drivers/mmc/am654_sdhci.c +++ b/drivers/mmc/am654_sdhci.c @@ -584,7 +584,7 @@ static int am654_sdhci_of_to_plat(struct udevice *dev) int ret;
host->name = dev->name; - host->ioaddr = (void *)dev_read_addr(dev); + host->ioaddr = dev_read_addr_ptr(dev); plat->non_removable = dev_read_bool(dev, "non-removable");
if (plat->flags & DLL_PRESENT) { diff --git a/drivers/mmc/davinci_mmc.c b/drivers/mmc/davinci_mmc.c index 05ca3612..407289fa 100644 --- a/drivers/mmc/davinci_mmc.c +++ b/drivers/mmc/davinci_mmc.c @@ -506,7 +506,7 @@ static int davinci_mmc_of_to_plat(struct udevice *dev) struct davinci_mmc_plat *plat = dev_get_plat(dev); struct mmc_config *cfg = &plat->cfg;
- plat->reg_base = (struct davinci_mmc_regs *)dev_read_addr(dev); + plat->reg_base = (struct davinci_mmc_regs *)dev_read_addr_ptr(dev); cfg->f_min = 200000; cfg->f_max = 25000000; cfg->voltages = MMC_VDD_32_33 | MMC_VDD_33_34, diff --git a/drivers/mmc/piton_mmc.c b/drivers/mmc/piton_mmc.c index 9f5da6d6..a330bbf8 100644 --- a/drivers/mmc/piton_mmc.c +++ b/drivers/mmc/piton_mmc.c @@ -74,7 +74,7 @@ static int piton_mmc_ofdata_to_platdata(struct udevice *dev) struct mmc *mmc; struct blk_desc *bdesc;
- priv->base_addr = (void *)dev_read_addr(dev); + priv->base_addr = dev_read_addr_ptr(dev); cfg = &plat->cfg; cfg->name = "PITON MMC"; cfg->host_caps = MMC_MODE_8BIT; diff --git a/drivers/mmc/tegra_mmc.c b/drivers/mmc/tegra_mmc.c index 760eca40..f76fee3e 100644 --- a/drivers/mmc/tegra_mmc.c +++ b/drivers/mmc/tegra_mmc.c @@ -708,7 +708,7 @@ static int tegra_mmc_probe(struct udevice *dev)
cfg->b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT;
- priv->reg = (void *)dev_read_addr(dev); + priv->reg = dev_read_addr_ptr(dev);
ret = reset_get_by_name(dev, "sdhci", &priv->reset_ctl); if (ret) { diff --git a/drivers/mmc/zynq_sdhci.c b/drivers/mmc/zynq_sdhci.c index 7dcf6ad8..dfc8d146 100644 --- a/drivers/mmc/zynq_sdhci.c +++ b/drivers/mmc/zynq_sdhci.c @@ -910,9 +910,9 @@ static int arasan_sdhci_of_to_plat(struct udevice *dev) arasan_dt_parse_clk_phases(dev); #endif
- priv->host->ioaddr = (void *)dev_read_addr(dev); - if (IS_ERR(priv->host->ioaddr)) - return PTR_ERR(priv->host->ioaddr); + priv->host->ioaddr = dev_read_addr_ptr(dev); + if (!priv->host->ioaddr) + return -EINVAL;
priv->bank = dev_read_u32_default(dev, "xlnx,mio-bank", 0); priv->no_1p8 = dev_read_bool(dev, "no-1-8-v"); diff --git a/drivers/mtd/nand/raw/arasan_nfc.c b/drivers/mtd/nand/raw/arasan_nfc.c index 4621bfb0..03faa961 100644 --- a/drivers/mtd/nand/raw/arasan_nfc.c +++ b/drivers/mtd/nand/raw/arasan_nfc.c @@ -1232,7 +1232,7 @@ static int arasan_probe(struct udevice *dev) struct mtd_info *mtd; int err = -1;
- info->reg = (struct nand_regs *)dev_read_addr(dev); + info->reg = (struct nand_regs *)dev_read_addr_ptr(dev); mtd = nand_to_mtd(nand_chip); nand_set_controller_data(nand_chip, &arasan->nand_ctrl);
diff --git a/drivers/mtd/nand/raw/cortina_nand.c b/drivers/mtd/nand/raw/cortina_nand.c index b03f3821..8095d2e1 100644 --- a/drivers/mtd/nand/raw/cortina_nand.c +++ b/drivers/mtd/nand/raw/cortina_nand.c @@ -1174,7 +1174,7 @@ static int fdt_decode_nand(struct udevice *dev, struct nand_drv *info) { int ecc_strength;
- info->reg = (struct nand_ctlr *)dev_read_addr(dev); + info->reg = (struct nand_ctlr *)dev_read_addr_ptr(dev); info->dma_glb = (struct dma_global *)dev_read_addr_index_ptr(dev, 1); info->dma_nand = (struct dma_ssp *)dev_read_addr_index_ptr(dev, 2); info->config.enabled = dev_read_enabled(dev); diff --git a/drivers/mtd/nand/raw/mxic_nand.c b/drivers/mtd/nand/raw/mxic_nand.c index e54df461..6abdc24b 100644 --- a/drivers/mtd/nand/raw/mxic_nand.c +++ b/drivers/mtd/nand/raw/mxic_nand.c @@ -538,7 +538,7 @@ static int mxic_nfc_probe(struct udevice *dev) ofnode child; int err;
- nfc->regs = (void *)dev_read_addr(dev); + nfc->regs = dev_read_addr_ptr(dev);
nfc->send_clk = devm_clk_get(dev, "send"); if (IS_ERR(nfc->send_clk)) diff --git a/drivers/mtd/nand/raw/tegra_nand.c b/drivers/mtd/nand/raw/tegra_nand.c index d2801d48..316f18bc 100644 --- a/drivers/mtd/nand/raw/tegra_nand.c +++ b/drivers/mtd/nand/raw/tegra_nand.c @@ -906,7 +906,7 @@ static int fdt_decode_nand(struct udevice *dev, struct fdt_nand *config) { int err;
- config->reg = (struct nand_ctlr *)dev_read_addr(dev); + config->reg = (struct nand_ctlr *)dev_read_addr_ptr(dev); config->enabled = dev_read_enabled(dev); config->width = dev_read_u32_default(dev, "nvidia,nand-width", 8); err = gpio_request_by_name(dev, "nvidia,wp-gpios", 0, &config->wp_gpio, diff --git a/drivers/mtd/nand/raw/zynq_nand.c b/drivers/mtd/nand/raw/zynq_nand.c index 14cb2ba7..b57785d9 100644 --- a/drivers/mtd/nand/raw/zynq_nand.c +++ b/drivers/mtd/nand/raw/zynq_nand.c @@ -1085,7 +1085,7 @@ static int zynq_nand_probe(struct udevice *dev) int ondie_ecc_enabled = 0; int is_16bit_bw;
- smc->reg = (struct zynq_nand_smc_regs *)dev_read_addr(dev); + smc->reg = (struct zynq_nand_smc_regs *)dev_read_addr_ptr(dev); of_nand = dev_read_subnode(dev, "nand-controller@0,0"); if (!ofnode_valid(of_nand)) { of_nand = dev_read_subnode(dev, "flash@e1000000"); diff --git a/drivers/net/mvmdio.c b/drivers/net/mvmdio.c index 6fb8a985..c0ebcdb1 100644 --- a/drivers/net/mvmdio.c +++ b/drivers/net/mvmdio.c @@ -208,7 +208,7 @@ static int mvmdio_probe(struct udevice *dev) { struct mvmdio_priv *priv = dev_get_priv(dev);
- priv->mdio_base = (void *)dev_read_addr(dev); + priv->mdio_base = dev_read_addr_ptr(dev); priv->type = (enum mvmdio_bus_type)dev_get_driver_data(dev);
return 0; diff --git a/drivers/net/qe/dm_qe_uec_phy.c b/drivers/net/qe/dm_qe_uec_phy.c index 038b8104..e1a8bf16 100644 --- a/drivers/net/qe/dm_qe_uec_phy.c +++ b/drivers/net/qe/dm_qe_uec_phy.c @@ -97,7 +97,7 @@ static int qe_uec_mdio_probe(struct udevice *dev) u32 num = 0; int ret = -ENODEV;
- priv->base = (struct ucc_mii_mng *)dev_read_addr(dev); + priv->base = (struct ucc_mii_mng *)dev_read_addr_ptr(dev); base = (fdt_size_t)priv->base;
/* diff --git a/drivers/pci/pci-aardvark.c b/drivers/pci/pci-aardvark.c index b0fc9caa..af0e55cd 100644 --- a/drivers/pci/pci-aardvark.c +++ b/drivers/pci/pci-aardvark.c @@ -983,8 +983,8 @@ static int pcie_advk_of_to_plat(struct udevice *dev) struct pcie_advk *pcie = dev_get_priv(dev);
/* Get the register base address */ - pcie->base = (void *)dev_read_addr(dev); - if ((fdt_addr_t)pcie->base == FDT_ADDR_T_NONE) + pcie->base = dev_read_addr_ptr(dev); + if (!pcie->base) return -EINVAL;
return 0; diff --git a/drivers/phy/allwinner/phy-sun50i-usb3.c b/drivers/phy/allwinner/phy-sun50i-usb3.c index e5a3d2d9..e88df8f9 100644 --- a/drivers/phy/allwinner/phy-sun50i-usb3.c +++ b/drivers/phy/allwinner/phy-sun50i-usb3.c @@ -149,9 +149,9 @@ static int sun50i_usb3_phy_probe(struct udevice *dev) return ret; }
- priv->regs = (void __iomem *)dev_read_addr(dev); - if (IS_ERR(priv->regs)) - return PTR_ERR(priv->regs); + priv->regs = (void __iomem *)dev_read_addr_ptr(dev); + if (!priv->regs) + return -EINVAL;
return 0; } diff --git a/drivers/phy/qcom/phy-qcom-usb-hs-28nm.c b/drivers/phy/qcom/phy-qcom-usb-hs-28nm.c index 14c3d839..05a9a2cf 100644 --- a/drivers/phy/qcom/phy-qcom-usb-hs-28nm.c +++ b/drivers/phy/qcom/phy-qcom-usb-hs-28nm.c @@ -184,8 +184,8 @@ static int hsphy_probe(struct udevice *dev) struct hsphy_priv *priv = dev_get_priv(dev); int ret;
- priv->base = (void *)dev_read_addr(dev); - if ((ulong)priv->base == FDT_ADDR_T_NONE) + priv->base = dev_read_addr_ptr(dev); + if (!priv->base) return -EINVAL;
ret = reset_get_by_name(dev, "phy", &priv->phy_rst); diff --git a/drivers/phy/qcom/phy-qcom-usb-ss.c b/drivers/phy/qcom/phy-qcom-usb-ss.c index 4e816879..1b03a3c4 100644 --- a/drivers/phy/qcom/phy-qcom-usb-ss.c +++ b/drivers/phy/qcom/phy-qcom-usb-ss.c @@ -115,8 +115,8 @@ static int ssphy_probe(struct udevice *dev) struct ssphy_priv *priv = dev_get_priv(dev); int ret;
ret = ssphy_clk_init(dev, priv); diff --git a/drivers/phy/rockchip/phy-rockchip-snps-pcie3.c b/drivers/phy/rockchip/phy-rockchip-snps-pcie3.c index 5ae41fbe..64cf00fd 100644 --- a/drivers/phy/rockchip/phy-rockchip-snps-pcie3.c +++ b/drivers/phy/rockchip/phy-rockchip-snps-pcie3.c @@ -93,8 +93,8 @@ static int rockchip_p3phy_probe(struct udevice *dev) struct udevice *syscon; int ret;
- priv->mmio = (void __iomem *)dev_read_addr(dev); - if ((fdt_addr_t)priv->mmio == FDT_ADDR_T_NONE) + priv->mmio = (void __iomem *)dev_read_addr_ptr(dev); + if (!priv->mmio) return -EINVAL;
ret = uclass_get_device_by_phandle(UCLASS_SYSCON, dev, diff --git a/drivers/phy/rockchip/phy-rockchip-typec.c b/drivers/phy/rockchip/phy-rockchip-typec.c index ca63b856..c4d4d4c7 100644 --- a/drivers/phy/rockchip/phy-rockchip-typec.c +++ b/drivers/phy/rockchip/phy-rockchip-typec.c @@ -674,9 +674,9 @@ static int rockchip_tcphy_probe(struct udevice *dev) unsigned int reg; int index, ret;
- priv->reg_base = (void __iomem *)dev_read_addr(dev); - if (IS_ERR(priv->reg_base)) - return PTR_ERR(priv->reg_base); + priv->reg_base = (void __iomem *)dev_read_addr_ptr(dev); + if (!priv->reg_base) + return -EINVAL;
ret = dev_read_u32_index(dev, "reg", 1, ®); if (ret) { diff --git a/drivers/pwm/tegra_pwm.c b/drivers/pwm/tegra_pwm.c index 36c35c60..0d6ac44f 100644 --- a/drivers/pwm/tegra_pwm.c +++ b/drivers/pwm/tegra_pwm.c @@ -57,7 +57,7 @@ static int tegra_pwm_of_to_plat(struct udevice *dev) { struct tegra_pwm_priv *priv = dev_get_priv(dev);
- priv->regs = (struct pwm_ctlr *)dev_read_addr(dev); + priv->regs = (struct pwm_ctlr *)dev_read_addr_ptr(dev);
return 0; } diff --git a/drivers/serial/serial_zynq.c b/drivers/serial/serial_zynq.c index 4b181831..4e43afd1 100644 --- a/drivers/serial/serial_zynq.c +++ b/drivers/serial/serial_zynq.c @@ -259,9 +259,9 @@ static int zynq_serial_of_to_plat(struct udevice *dev) { struct zynq_uart_plat *plat = dev_get_plat(dev);
- plat->regs = (struct uart_zynq *)dev_read_addr(dev); - if (IS_ERR(plat->regs)) - return PTR_ERR(plat->regs); + plat->regs = (struct uart_zynq *)dev_read_addr_ptr(dev); + if (!plat->regs) + return -EINVAL;
return 0; } diff --git a/drivers/spi/mpc8xxx_spi.c b/drivers/spi/mpc8xxx_spi.c index 6869d60d..60b850f8 100644 --- a/drivers/spi/mpc8xxx_spi.c +++ b/drivers/spi/mpc8xxx_spi.c @@ -54,7 +54,7 @@ static int mpc8xxx_spi_of_to_plat(struct udevice *dev) struct clk clk; int ret;
- priv->spi = (spi8xxx_t *)dev_read_addr(dev); + priv->spi = (spi8xxx_t *)dev_read_addr_ptr(dev);
ret = gpio_request_list_by_name(dev, "gpios", priv->gpios, ARRAY_SIZE(priv->gpios), GPIOD_IS_OUT | GPIOD_ACTIVE_LOW); diff --git a/drivers/spi/mscc_bb_spi.c b/drivers/spi/mscc_bb_spi.c index 2a01ea06..5819af5e 100644 --- a/drivers/spi/mscc_bb_spi.c +++ b/drivers/spi/mscc_bb_spi.c @@ -217,7 +217,7 @@ static int mscc_bb_spi_probe(struct udevice *bus)
debug("%s: loaded, priv %p\n", __func__, priv);
- priv->regs = (void __iomem *)dev_read_addr(bus); + priv->regs = (void __iomem *)dev_read_addr_ptr(bus);
priv->deactivate_delay_us = dev_read_u32_default(bus, "spi-deactivate-delay", 0); diff --git a/drivers/spi/sh_qspi.c b/drivers/spi/sh_qspi.c index 5ba8a8ea..eca180aa 100644 --- a/drivers/spi/sh_qspi.c +++ b/drivers/spi/sh_qspi.c @@ -332,7 +332,7 @@ static int sh_qspi_of_to_plat(struct udevice *dev) { struct sh_qspi_slave *plat = dev_get_plat(dev);
- plat->regs = (struct sh_qspi_regs *)dev_read_addr(dev); + plat->regs = (struct sh_qspi_regs *)dev_read_addr_ptr(dev);
return 0; } diff --git a/drivers/spi/spi-mxic.c b/drivers/spi/spi-mxic.c index 6aae9f79..f663b9dc 100644 --- a/drivers/spi/spi-mxic.c +++ b/drivers/spi/spi-mxic.c @@ -508,7 +508,7 @@ static int mxic_spi_probe(struct udevice *bus) { struct mxic_spi_priv *priv = dev_get_priv(bus);
- priv->regs = (void *)dev_read_addr(bus); + priv->regs = dev_read_addr_ptr(bus);
priv->send_clk = devm_clk_get(bus, "send_clk"); if (IS_ERR(priv->send_clk)) diff --git a/drivers/spi/xilinx_spi.c b/drivers/spi/xilinx_spi.c index 4e9115da..72ee9214 100644 --- a/drivers/spi/xilinx_spi.c +++ b/drivers/spi/xilinx_spi.c @@ -114,7 +114,7 @@ static int xilinx_spi_probe(struct udevice *bus) struct xilinx_spi_priv *priv = dev_get_priv(bus); struct xilinx_spi_regs *regs = priv->regs;
- priv->regs = (struct xilinx_spi_regs *)dev_read_addr(bus); + priv->regs = (struct xilinx_spi_regs *)dev_read_addr_ptr(bus);
priv->fifo_depth = dev_read_u32_default(bus, "fifo-size", 0);
diff --git a/drivers/ufs/ufs.c b/drivers/ufs/ufs.c index 13e730b8..8dd29edd 100644 --- a/drivers/ufs/ufs.c +++ b/drivers/ufs/ufs.c @@ -1880,7 +1880,7 @@ int ufshcd_probe(struct udevice *ufs_dev, struct ufs_hba_ops *hba_ops)
hba->dev = ufs_dev; hba->ops = hba_ops; - hba->mmio_base = (void *)dev_read_addr(ufs_dev); + hba->mmio_base = dev_read_addr_ptr(ufs_dev);
/* Set descriptor lengths to specification defaults */ ufshcd_def_desc_sizes(hba); diff --git a/drivers/usb/host/ehci-tegra.c b/drivers/usb/host/ehci-tegra.c index b02ee89c..7cc564f8 100644 --- a/drivers/usb/host/ehci-tegra.c +++ b/drivers/usb/host/ehci-tegra.c @@ -695,7 +695,7 @@ static int fdt_decode_usb(struct udevice *dev, struct fdt_usb *config) { const char *phy, *mode;
- config->reg = (struct usb_ctlr *)dev_read_addr(dev); + config->reg = (struct usb_ctlr *)dev_read_addr_ptr(dev); debug("reg=%p\n", config->reg); mode = dev_read_string(dev, "dr_mode"); if (mode) { diff --git a/drivers/video/dw_mipi_dsi.c b/drivers/video/dw_mipi_dsi.c index 6d9c5a94..7c6892cf 100644 --- a/drivers/video/dw_mipi_dsi.c +++ b/drivers/video/dw_mipi_dsi.c @@ -800,8 +800,8 @@ static int dw_mipi_dsi_init(struct udevice *dev, dsi->dsi_host.ops = &dw_mipi_dsi_host_ops; device->host = &dsi->dsi_host;
- dsi->base = (void *)dev_read_addr(device->dev); - if ((fdt_addr_t)dsi->base == FDT_ADDR_T_NONE) { + dsi->base = dev_read_addr_ptr(device->dev); + if ((!dsi->base) { dev_err(device->dev, "dsi dt register address error\n"); return -EINVAL; } diff --git a/drivers/video/rockchip/rk_vop.c b/drivers/video/rockchip/rk_vop.c index bc98ab68..246eb10c 100644 --- a/drivers/video/rockchip/rk_vop.c +++ b/drivers/video/rockchip/rk_vop.c @@ -446,7 +446,7 @@ int rk_vop_probe(struct udevice *dev) efi_add_memory_map(plat->base, plat->size, EFI_RESERVED_MEMORY_TYPE); #endif
- priv->regs = (struct rk3288_vop *)dev_read_addr(dev); + priv->regs = (struct rk3288_vop *)dev_read_addr_ptr(dev);
/* * Try all the ports until we find one that works. In practice this diff --git a/drivers/video/stm32/stm32_dsi.c b/drivers/video/stm32/stm32_dsi.c index e6347bb8..a7420fb2 100644 --- a/drivers/video/stm32/stm32_dsi.c +++ b/drivers/video/stm32/stm32_dsi.c @@ -427,8 +427,8 @@ static int stm32_dsi_probe(struct udevice *dev)
device->dev = dev;
- priv->base = (void *)dev_read_addr(dev); - if ((fdt_addr_t)priv->base == FDT_ADDR_T_NONE) { + priv->base = dev_read_addr_ptr(dev); + if (!priv->base) { dev_err(dev, "dsi dt register address error\n"); return -EINVAL; } diff --git a/drivers/video/stm32/stm32_ltdc.c b/drivers/video/stm32/stm32_ltdc.c index 58b6434a..f48badc5 100644 --- a/drivers/video/stm32/stm32_ltdc.c +++ b/drivers/video/stm32/stm32_ltdc.c @@ -507,8 +507,8 @@ static int stm32_ltdc_probe(struct udevice *dev) ulong rate; int ret;
- priv->regs = (void *)dev_read_addr(dev); - if ((fdt_addr_t)priv->regs == FDT_ADDR_T_NONE) { + priv->regs = dev_read_addr_ptr(dev); + if (!priv->regs) { dev_err(dev, "ltdc dt register address error\n"); return -EINVAL; } diff --git a/drivers/video/tegra124/display.c b/drivers/video/tegra124/display.c index 78ab3f99..e769b31b 100644 --- a/drivers/video/tegra124/display.c +++ b/drivers/video/tegra124/display.c @@ -361,7 +361,7 @@ static int display_init(struct udevice *dev, void *lcdbase, return ret; }
- dc_ctlr = (struct dc_ctlr *)dev_read_addr(dev); + dc_ctlr = (struct dc_ctlr *)dev_read_addr_ptr(dev); if (ofnode_decode_display_timing(dev_ofnode(dev), 0, timing)) { debug("%s: Failed to decode display timing\n", __func__); return -EINVAL; diff --git a/drivers/video/tegra124/sor.c b/drivers/video/tegra124/sor.c index ef1a2e6d..96854b7a 100644 --- a/drivers/video/tegra124/sor.c +++ b/drivers/video/tegra124/sor.c @@ -765,7 +765,7 @@ int tegra_dc_sor_attach(struct udevice *dc_dev, struct udevice *dev,
/* Use the first display controller */ debug("%s\n", __func__); - disp_ctrl = (struct dc_ctlr *)dev_read_addr(dc_dev); + disp_ctrl = (struct dc_ctlr *)dev_read_addr_ptr(dc_dev);
tegra_dc_sor_enable_dc(disp_ctrl); tegra_dc_sor_config_panel(sor, 0, link_cfg, timing); @@ -978,7 +978,7 @@ int tegra_dc_sor_detach(struct udevice *dc_dev, struct udevice *dev)
debug("%s\n", __func__); /* Use the first display controller */ - disp_ctrl = (struct dc_ctlr *)dev_read_addr(dev); + disp_ctrl = (struct dc_ctlr *)dev_read_addr_ptr(dev);
/* Sleep mode */ tegra_sor_writel(sor, SUPER_STATE1, SUPER_STATE1_ASY_HEAD_OP_SLEEP | @@ -1047,7 +1047,7 @@ static int tegra_sor_of_to_plat(struct udevice *dev) struct tegra_dc_sor_data *priv = dev_get_priv(dev); int ret;
- priv->base = (void *)dev_read_addr(dev); + priv->base = dev_read_addr_ptr(dev);
priv->pmc_base = (void *)syscon_get_first_range(TEGRA_SYSCON_PMC); if (IS_ERR(priv->pmc_base)) diff --git a/drivers/watchdog/cdns_wdt.c b/drivers/watchdog/cdns_wdt.c index 6dfdd31c..a6537c1a 100644 --- a/drivers/watchdog/cdns_wdt.c +++ b/drivers/watchdog/cdns_wdt.c @@ -271,9 +271,9 @@ static int cdns_wdt_of_to_plat(struct udevice *dev) { struct cdns_wdt_priv *priv = dev_get_priv(dev);
- priv->regs = (struct cdns_regs *)dev_read_addr(dev); - if (IS_ERR(priv->regs)) - return PTR_ERR(priv->regs); + priv->regs = (struct cdns_regs *)dev_read_addr_ptr(dev); + if (!priv->regs) + return -EINVAL;
priv->rst = dev_read_bool(dev, "reset-on-timeout");
diff --git a/drivers/watchdog/sp805_wdt.c b/drivers/watchdog/sp805_wdt.c index 0d6fb120..e4e0797c 100644 --- a/drivers/watchdog/sp805_wdt.c +++ b/drivers/watchdog/sp805_wdt.c @@ -116,9 +116,9 @@ static int sp805_wdt_of_to_plat(struct udevice *dev) struct sp805_wdt_priv *priv = dev_get_priv(dev); struct clk clk;
- priv->reg = (void __iomem *)dev_read_addr(dev); - if (IS_ERR(priv->reg)) - return PTR_ERR(priv->reg); + priv->reg = (void __iomem *)dev_read_addr_ptr(dev); + if (!priv->reg) + return -EINVAL;
if (!clk_get_by_index(dev, 0, &clk)) priv->clk_rate = clk_get_rate(&clk); diff --git a/drivers/watchdog/xilinx_tb_wdt.c b/drivers/watchdog/xilinx_tb_wdt.c index 1687a459..9dce5a99 100644 --- a/drivers/watchdog/xilinx_tb_wdt.c +++ b/drivers/watchdog/xilinx_tb_wdt.c @@ -94,9 +94,9 @@ static int xlnx_wdt_of_to_plat(struct udevice *dev) { struct xlnx_wdt_plat *plat = dev_get_plat(dev);
- plat->regs = (struct watchdog_regs *)dev_read_addr(dev); - if (IS_ERR(plat->regs)) - return PTR_ERR(plat->regs); + plat->regs = (struct watchdog_regs *)dev_read_addr_ptr(dev); + if (!plat->regs) + return -EINVAL;
plat->enable_once = dev_read_u32_default(dev, "xlnx,wdt-enable-once", 0); -- 2.20.1
Note:
- dsi->base = dev_read_addr_ptr(device->dev);
- if ((!dsi->base) {
if (!dsi->base) {
Oops typo, sorry..
[..] 0);
-- 2.20.1
The fdt_addr_t and phys_addr_t size have been decoupled. A 32bit CPU can expect 64-bit data from the device tree parser, so use devfdt_get_addr_size_index_ptr instead of the devfdt_get_addr_size_index function in the various files in the drivers directory that cast to a pointer.
Note:
Replacement command used: find . -type f -exec sed -i 's/*)devfdt_get_addr_size_index(/ *)devfdt_get_addr_size_index_ptr(/g' {} + --- drivers/pci/pcie_dw_mvebu.c | 6 +++--- drivers/spi/cadence_qspi.c | 3 +-- 2 files changed, 4 insertions(+), 5 deletions(-)
diff --git a/drivers/pci/pcie_dw_mvebu.c b/drivers/pci/pcie_dw_mvebu.c index a0b82c78..3b2ada54 100644 --- a/drivers/pci/pcie_dw_mvebu.c +++ b/drivers/pci/pcie_dw_mvebu.c @@ -569,9 +569,9 @@ static int pcie_dw_mvebu_of_to_plat(struct udevice *dev) return -EINVAL;
/* Get the config space base address and size */ - pcie->cfg_base = (void *)devfdt_get_addr_size_index(dev, 1, - &pcie->cfg_size); - if ((fdt_addr_t)pcie->cfg_base == FDT_ADDR_T_NONE) + pcie->cfg_base = devfdt_get_addr_size_index_ptr(dev, 1, + &pcie->cfg_size); + if (!pcie->cfg_base) return -EINVAL;
return 0; diff --git a/drivers/spi/cadence_qspi.c b/drivers/spi/cadence_qspi.c index ab0a681c..93e57a54 100644 --- a/drivers/spi/cadence_qspi.c +++ b/drivers/spi/cadence_qspi.c @@ -378,8 +378,7 @@ static int cadence_spi_of_to_plat(struct udevice *bus) ofnode subnode;
plat->regbase = (void *)devfdt_get_addr_index(bus, 0); - plat->ahbbase = (void *)devfdt_get_addr_size_index(bus, 1, - &plat->ahbsize); + plat->ahbbase = devfdt_get_addr_size_index_ptr(bus, 1, &plat->ahbsize); plat->is_decoded_cs = dev_read_bool(bus, "cdns,is-decoded-cs"); plat->fifo_depth = dev_read_u32_default(bus, "cdns,fifo-depth", 128); plat->fifo_width = dev_read_u32_default(bus, "cdns,fifo-width", 4); -- 2.20.1
Hi
Nice if you use more size for each line ;)
Note:
&pcie->cfg_size);
&pcie->cfg_size);
if (!pcie->cfg_base) return -EINVAL; return 0;
&plat->ahbsize);
hope that ahbbase then is checked if is NULL
-- 2.20.1
Hi Johan,
Note:
&pcie->cfg_size);
&pcie->cfg_size);
&plat->ahbsize);
Please rebase the series on master (I have fixed a conflict) and test with buildman. The CI pipeline outputs this error:
Building current source for 1 boards (1 thread, 64 jobs per thread) 52 aarch64: + xilinx_versal_virt 53+drivers/spi/cadence_qspi.c: In function 'cadence_spi_of_to_plat': 54+drivers/spi/cadence_qspi.c:387:25: error: implicit declaration of function 'devfdt_get_addr_size_index_ptr'; did you mean 'devfdt_get_addr_size_index'? [-Werror=implicit-function-declaration] 55+ 387 | plat->ahbbase = devfdt_get_addr_size_index_ptr(bus, 1, &plat->ahbsize); 56+ | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ 57+ | devfdt_get_addr_size_index 58+drivers/spi/cadence_qspi.c:387:23: error: assignment to 'void *' from 'int' makes pointer from integer without a cast [-Werror=int-conversion]
Thanks and regards, Dario
-- 2.20.1
The fdt_addr_t and phys_addr_t size have been decoupled. A 32bit CPU can expect 64-bit data from the device tree parser, so use devfdt_get_addr_index_ptr instead of the devfdt_get_addr_index function in the various files in the drivers directory that cast to a pointer.
Note:
Replacement command used: find . -type f -exec sed -i 's/*)devfdt_get_addr_index(/ *)devfdt_get_addr_index_ptr(/g' {} + --- drivers/clk/clk-hsdk-cgu.c | 4 ++-- drivers/ddr/altera/sdram_gen5.c | 2 +- drivers/mmc/xenon_sdhci.c | 2 +- drivers/net/mvpp2.c | 24 ++++++++++++------------ drivers/pci/pcie_dw_mvebu.c | 4 ++-- drivers/pci/pcie_imx.c | 4 ++-- drivers/pci/pcie_layerscape_ep.c | 4 ++-- drivers/phy/marvell/comphy_core.c | 12 ++++++------ drivers/spi/cadence_qspi.c | 2 +- drivers/usb/musb-new/ti-musb.c | 2 +- 10 files changed, 30 insertions(+), 30 deletions(-)
diff --git a/drivers/clk/clk-hsdk-cgu.c b/drivers/clk/clk-hsdk-cgu.c index 26b0aa9a..cf3d0fd3 100644 --- a/drivers/clk/clk-hsdk-cgu.c +++ b/drivers/clk/clk-hsdk-cgu.c @@ -753,11 +753,11 @@ static int hsdk_cgu_clk_probe(struct udevice *dev) else hsdk_clk->map = hsdk_4xd_clk_map;
- hsdk_clk->cgu_regs = (void __iomem *)devfdt_get_addr_index(dev, 0); + hsdk_clk->cgu_regs = (void __iomem *)devfdt_get_addr_index_ptr(dev, 0); if (!hsdk_clk->cgu_regs) return -EINVAL;
- hsdk_clk->creg_regs = (void __iomem *)devfdt_get_addr_index(dev, 1); + hsdk_clk->creg_regs = (void __iomem *)devfdt_get_addr_index_ptr(dev, 1); if (!hsdk_clk->creg_regs) return -EINVAL;
diff --git a/drivers/ddr/altera/sdram_gen5.c b/drivers/ddr/altera/sdram_gen5.c index 8d3ce495..2cdfdd42 100644 --- a/drivers/ddr/altera/sdram_gen5.c +++ b/drivers/ddr/altera/sdram_gen5.c @@ -567,7 +567,7 @@ static int altera_gen5_sdram_of_to_plat(struct udevice *dev) { struct altera_gen5_sdram_plat *plat = dev_get_plat(dev);
- plat->sdr = (struct socfpga_sdr *)devfdt_get_addr_index(dev, 0); + plat->sdr = (struct socfpga_sdr *)devfdt_get_addr_index_ptr(dev, 0); if (!plat->sdr) return -ENODEV;
diff --git a/drivers/mmc/xenon_sdhci.c b/drivers/mmc/xenon_sdhci.c index 2f880509..16ac84a2 100644 --- a/drivers/mmc/xenon_sdhci.c +++ b/drivers/mmc/xenon_sdhci.c @@ -537,7 +537,7 @@ static int xenon_sdhci_of_to_plat(struct udevice *dev) host->ioaddr = dev_read_addr_ptr(dev);
if (device_is_compatible(dev, "marvell,armada-3700-sdhci")) - priv->pad_ctrl_reg = (void *)devfdt_get_addr_index(dev, 1); + priv->pad_ctrl_reg = devfdt_get_addr_index_ptr(dev, 1);
name = fdt_getprop(gd->fdt_blob, dev_of_offset(dev), "marvell,pad-type", NULL); diff --git a/drivers/net/mvpp2.c b/drivers/net/mvpp2.c index 8c9afdf7..907d826d 100644 --- a/drivers/net/mvpp2.c +++ b/drivers/net/mvpp2.c @@ -5351,18 +5351,18 @@ static int mvpp2_base_probe(struct udevice *dev) }
/* Save base addresses for later use */ - priv->base = (void *)devfdt_get_addr_index(dev, 0); - if (IS_ERR(priv->base)) - return PTR_ERR(priv->base); + priv->base = devfdt_get_addr_index_ptr(dev, 0); + if (!priv->base) + return -EINVAL;
if (priv->hw_version == MVPP21) { - priv->lms_base = (void *)devfdt_get_addr_index(dev, 1); - if (IS_ERR(priv->lms_base)) - return PTR_ERR(priv->lms_base); + priv->lms_base = devfdt_get_addr_index_ptr(dev, 1); + if (!priv->lms_base) + return -EINVAL; } else { - priv->iface_base = (void *)devfdt_get_addr_index(dev, 1); - if (IS_ERR(priv->iface_base)) - return PTR_ERR(priv->iface_base); + priv->iface_base = devfdt_get_addr_index_ptr(dev, 1); + if (!priv->iface_base) + return -EINVAL;
/* Store common base addresses for all ports */ priv->mpcs_base = priv->iface_base + MVPP22_MPCS; @@ -5401,10 +5401,10 @@ static int mvpp2_probe(struct udevice *dev) if (priv->hw_version == MVPP21) { int priv_common_regs_num = 2;
- port->base = (void __iomem *)devfdt_get_addr_index( + port->base = (void __iomem *)devfdt_get_addr_index_ptr( dev->parent, priv_common_regs_num + port->id); - if (IS_ERR(port->base)) - return PTR_ERR(port->base); + if (!port->base) + return -EINVAL; } else { port->gop_id = fdtdec_get_int(gd->fdt_blob, dev_of_offset(dev), "gop-port-id", -1); diff --git a/drivers/pci/pcie_dw_mvebu.c b/drivers/pci/pcie_dw_mvebu.c index 3b2ada54..c41f3f15 100644 --- a/drivers/pci/pcie_dw_mvebu.c +++ b/drivers/pci/pcie_dw_mvebu.c @@ -564,8 +564,8 @@ static int pcie_dw_mvebu_of_to_plat(struct udevice *dev) struct pcie_dw_mvebu *pcie = dev_get_priv(dev);
/* Get the controller base address */ - pcie->ctrl_base = (void *)devfdt_get_addr_index(dev, 0); - if ((fdt_addr_t)pcie->ctrl_base == FDT_ADDR_T_NONE) + pcie->ctrl_base = devfdt_get_addr_index_ptr(dev, 0); + if (!pcie->ctrl_base) return -EINVAL;
/* Get the config space base address and size */ diff --git a/drivers/pci/pcie_imx.c b/drivers/pci/pcie_imx.c index da484664..bf1ca5b6 100644 --- a/drivers/pci/pcie_imx.c +++ b/drivers/pci/pcie_imx.c @@ -751,8 +751,8 @@ static int imx_pcie_of_to_plat(struct udevice *dev) { struct imx_pcie_priv *priv = dev_get_priv(dev);
- priv->dbi_base = (void __iomem *)devfdt_get_addr_index(dev, 0); - priv->cfg_base = (void __iomem *)devfdt_get_addr_index(dev, 1); + priv->dbi_base = (void __iomem *)devfdt_get_addr_index_ptr(dev, 0); + priv->cfg_base = (void __iomem *)devfdt_get_addr_index_ptr(dev, 1); if (!priv->dbi_base || !priv->cfg_base) return -EINVAL;
diff --git a/drivers/pci/pcie_layerscape_ep.c b/drivers/pci/pcie_layerscape_ep.c index ff26a5cd..f4a0d1f2 100644 --- a/drivers/pci/pcie_layerscape_ep.c +++ b/drivers/pci/pcie_layerscape_ep.c @@ -250,11 +250,11 @@ static int ls_pcie_ep_probe(struct udevice *dev)
pcie_ep->pcie = pcie;
- pcie->dbi = (void __iomem *)devfdt_get_addr_index(dev, 0); + pcie->dbi = (void __iomem *)devfdt_get_addr_index_ptr(dev, 0); if (!pcie->dbi) return -ENOMEM;
- pcie->ctrl = (void __iomem *)devfdt_get_addr_index(dev, 1); + pcie->ctrl = (void __iomem *)devfdt_get_addr_index_ptr(dev, 1); if (!pcie->ctrl) return -ENOMEM;
diff --git a/drivers/phy/marvell/comphy_core.c b/drivers/phy/marvell/comphy_core.c index df2460db..7272dfb9 100644 --- a/drivers/phy/marvell/comphy_core.c +++ b/drivers/phy/marvell/comphy_core.c @@ -88,13 +88,13 @@ static int comphy_probe(struct udevice *dev) int res;
/* Save base addresses for later use */ - chip_cfg->comphy_base_addr = (void *)devfdt_get_addr_index(dev, 0); - if (IS_ERR(chip_cfg->comphy_base_addr)) - return PTR_ERR(chip_cfg->comphy_base_addr); + chip_cfg->comphy_base_addr = devfdt_get_addr_index_ptr(dev, 0); + if (!chip_cfg->comphy_base_addr) + return -EINVAL;
- chip_cfg->hpipe3_base_addr = (void *)devfdt_get_addr_index(dev, 1); - if (IS_ERR(chip_cfg->hpipe3_base_addr)) - return PTR_ERR(chip_cfg->hpipe3_base_addr); + chip_cfg->hpipe3_base_addr = devfdt_get_addr_index_ptr(dev, 1); + if (!chip_cfg->hpipe3_base_addr) + return -EINVAL;
if (device_is_compatible(dev, "marvell,comphy-a3700")) { chip_cfg->comphy_init_map = comphy_a3700_init_serdes_map; diff --git a/drivers/spi/cadence_qspi.c b/drivers/spi/cadence_qspi.c index 93e57a54..ce069b96 100644 --- a/drivers/spi/cadence_qspi.c +++ b/drivers/spi/cadence_qspi.c @@ -377,7 +377,7 @@ static int cadence_spi_of_to_plat(struct udevice *bus) struct cadence_spi_priv *priv = dev_get_priv(bus); ofnode subnode;
- plat->regbase = (void *)devfdt_get_addr_index(bus, 0); + plat->regbase = devfdt_get_addr_index_ptr(bus, 0); plat->ahbbase = devfdt_get_addr_size_index_ptr(bus, 1, &plat->ahbsize); plat->is_decoded_cs = dev_read_bool(bus, "cdns,is-decoded-cs"); plat->fifo_depth = dev_read_u32_default(bus, "cdns,fifo-depth", 128); diff --git a/drivers/usb/musb-new/ti-musb.c b/drivers/usb/musb-new/ti-musb.c index 91042935..3be3f93d 100644 --- a/drivers/usb/musb-new/ti-musb.c +++ b/drivers/usb/musb-new/ti-musb.c @@ -88,7 +88,7 @@ static int ti_musb_of_to_plat(struct udevice *dev) int usb_index; struct musb_hdrc_config *musb_config;
- plat->base = (void *)devfdt_get_addr_index(dev, 1); + plat->base = devfdt_get_addr_index_ptr(dev, 1);
phys = fdtdec_lookup_phandle(fdt, node, "phys"); ctrl_mod = fdtdec_lookup_phandle(fdt, phys, "ti,ctrl_mod"); -- 2.20.1
Hi Johan
Thank you. We should wait now Simon on those patches
Michael
Note:
priv->pad_ctrl_reg = devfdt_get_addr_index_ptr(dev, 1); name = fdt_getprop(gd->fdt_blob, dev_of_offset(dev), "marvell,pad-type", NULL);
if (!priv->base)
return -EINVAL; if (priv->hw_version == MVPP21) {
return -EINVAL; /* Store common base addresses for all ports */ priv->mpcs_base = priv->iface_base + MVPP22_MPCS;
if (!port->base)
if (!pcie->ctrl_base) return -EINVAL; /* Get the config space base address and size */
return -EINVAL;
return -EINVAL; if (device_is_compatible(dev, "marvell,comphy-a3700")) { chip_cfg->comphy_init_map = comphy_a3700_init_serdes_map;
plat->base = devfdt_get_addr_index_ptr(dev, 1); phys = fdtdec_lookup_phandle(fdt, node, "phys"); ctrl_mod = fdtdec_lookup_phandle(fdt, phys, "ti,ctrl_mod");
-- 2.20.1
I think you can use a bit more of 60 chars x line
Note:
db->base_data = (void __iomem *)dev_read_addr_index_ptr(dev, 1); return 0;
if (!pdata->regs) return -EINVAL; pdata->dwmac_setup = (void *)dev_get_driver_data(dev);
priv->dw.dbi_base = dev_read_addr_index_ptr(dev, 0); if (!priv->dw.dbi_base) return -ENODEV; dev_dbg(dev, "ELBI address is 0x%p\n", priv->dw.dbi_base);
priv->dw.dbi_base = dev_read_addr_index_ptr(dev, 0); if (!priv->dw.dbi_base) return -ENODEV; dev_dbg(dev, "DBI address is 0x%p\n", priv->dw.dbi_base);
return -EINVAL;
return -EINVAL;
2.20.1
When fdt_addr_t and phys_addr_t are split it turns out that the header don't match the functions, so fix the headers.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Kever Yang kever.yang@rock-chips.com --- include/dm/ofnode.h | 16 ++++++++-------- 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/include/dm/ofnode.h b/include/dm/ofnode.h index fa986560..287b0c35 100644 --- a/include/dm/ofnode.h +++ b/include/dm/ofnode.h @@ -678,8 +678,8 @@ int ofnode_read_size(ofnode node, const char *propname); * @size: Pointer to size of the address * Return: address, or FDT_ADDR_T_NONE if not present or invalid */ -phys_addr_t ofnode_get_addr_size_index(ofnode node, int index, - fdt_size_t *size); +fdt_addr_t ofnode_get_addr_size_index(ofnode node, int index, + fdt_size_t *size);
/** * ofnode_get_addr_size_index_notrans() - get an address/size from a node @@ -695,8 +695,8 @@ phys_addr_t ofnode_get_addr_size_index(ofnode node, int index, * @size: Pointer to size of the address * Return: address, or FDT_ADDR_T_NONE if not present or invalid */ -phys_addr_t ofnode_get_addr_size_index_notrans(ofnode node, int index, - fdt_size_t *size); +fdt_addr_t ofnode_get_addr_size_index_notrans(ofnode node, int index, + fdt_size_t *size);
/** * ofnode_get_addr_index() - get an address from a node @@ -707,7 +707,7 @@ phys_addr_t ofnode_get_addr_size_index_notrans(ofnode node, int index, * @index: Index of address to read (0 for first) * Return: address, or FDT_ADDR_T_NONE if not present or invalid */ -phys_addr_t ofnode_get_addr_index(ofnode node, int index); +fdt_addr_t ofnode_get_addr_index(ofnode node, int index);
/** * ofnode_get_addr() - get an address from a node @@ -717,7 +717,7 @@ phys_addr_t ofnode_get_addr_index(ofnode node, int index); * @node: node to read from * Return: address, or FDT_ADDR_T_NONE if not present or invalid */ -phys_addr_t ofnode_get_addr(ofnode node); +fdt_addr_t ofnode_get_addr(ofnode node);
/** * ofnode_get_size() - get size from a node @@ -1055,8 +1055,8 @@ const void *ofprop_get_property(const struct ofprop *prop, * @sizep: place to put size value (on success) * Return: address value, or FDT_ADDR_T_NONE on error */ -phys_addr_t ofnode_get_addr_size(ofnode node, const char *propname, - phys_size_t *sizep); +fdt_addr_t ofnode_get_addr_size(ofnode node, const char *propname, + fdt_size_t *sizep);
/** * ofnode_read_u8_array_ptr() - find an 8-bit array -- 2.20.1
The fdt_addr_t and phys_addr_t size have been decoupled. A 32bit CPU can expect 64-bit data from the device tree parser, so convert regmap_init_mem_plat() input to phys_addr_t in files that use this function. Also correct struct syscon_base_plat depending on CONFIG_PHYS_64BIT setting and fix ARRAY_SIZE divider.
Changed V4: Fix cast and divider in syscon-uclass.c --- drivers/core/regmap.c | 2 +- drivers/core/syscon-uclass.c | 4 ++-- drivers/ram/rockchip/sdram_rk3066.c | 2 +- drivers/ram/rockchip/sdram_rk3188.c | 2 +- drivers/ram/rockchip/sdram_rk322x.c | 2 +- drivers/ram/rockchip/sdram_rk3288.c | 2 +- drivers/ram/rockchip/sdram_rk3328.c | 2 +- drivers/ram/rockchip/sdram_rk3399.c | 2 +- include/regmap.h | 2 +- include/syscon.h | 13 +++++++------ 10 files changed, 17 insertions(+), 16 deletions(-)
diff --git a/drivers/core/regmap.c b/drivers/core/regmap.c index e33bb9d7..37da64b2 100644 --- a/drivers/core/regmap.c +++ b/drivers/core/regmap.c @@ -79,7 +79,7 @@ static struct regmap *regmap_alloc(int count) }
#if CONFIG_IS_ENABLED(OF_PLATDATA) -int regmap_init_mem_plat(struct udevice *dev, fdt_val_t *reg, int count, +int regmap_init_mem_plat(struct udevice *dev, phys_addr_t *reg, int count, struct regmap **mapp) { struct regmap_range *range; diff --git a/drivers/core/syscon-uclass.c b/drivers/core/syscon-uclass.c index 25fdb66e..b557a24f 100644 --- a/drivers/core/syscon-uclass.c +++ b/drivers/core/syscon-uclass.c @@ -58,8 +58,8 @@ static int syscon_pre_probe(struct udevice *dev) #if CONFIG_IS_ENABLED(OF_PLATDATA) struct syscon_base_plat *plat = dev_get_plat(dev);
- return regmap_init_mem_plat(dev, plat->reg, ARRAY_SIZE(plat->reg), - &priv->regmap); + return regmap_init_mem_plat(dev, (phys_addr_t *)plat->reg, + ARRAY_SIZE(plat->reg) / 2, &priv->regmap); #else return regmap_init_mem(dev_ofnode(dev), &priv->regmap); #endif diff --git a/drivers/ram/rockchip/sdram_rk3066.c b/drivers/ram/rockchip/sdram_rk3066.c index a2425f22..9bb26b64 100644 --- a/drivers/ram/rockchip/sdram_rk3066.c +++ b/drivers/ram/rockchip/sdram_rk3066.c @@ -801,7 +801,7 @@ static int rk3066_dmc_conv_of_plat(struct udevice *dev) memcpy(&plat->base, of_plat->rockchip_sdram_params, sizeof(plat->base)); /* RK3066 supports dual-channel, set default channel num to 2. */ plat->num_channels = 1; - ret = regmap_init_mem_plat(dev, of_plat->reg, + ret = regmap_init_mem_plat(dev, (phys_addr_t *)of_plat->reg, ARRAY_SIZE(of_plat->reg) / 2, &plat->map); if (ret) return ret; diff --git a/drivers/ram/rockchip/sdram_rk3188.c b/drivers/ram/rockchip/sdram_rk3188.c index 272b1b2d..1838985c 100644 --- a/drivers/ram/rockchip/sdram_rk3188.c +++ b/drivers/ram/rockchip/sdram_rk3188.c @@ -867,7 +867,7 @@ static int conv_of_plat(struct udevice *dev) memcpy(&plat->base, of_plat->rockchip_sdram_params, sizeof(plat->base)); /* rk3188 supports dual-channel, set default channel num to 2 */ plat->num_channels = 1; - ret = regmap_init_mem_plat(dev, of_plat->reg, + ret = regmap_init_mem_plat(dev, (phys_addr_t *)of_plat->reg, ARRAY_SIZE(of_plat->reg) / 2, &plat->map); if (ret) return ret; diff --git a/drivers/ram/rockchip/sdram_rk322x.c b/drivers/ram/rockchip/sdram_rk322x.c index 1b204fb5..33599dc5 100644 --- a/drivers/ram/rockchip/sdram_rk322x.c +++ b/drivers/ram/rockchip/sdram_rk322x.c @@ -769,7 +769,7 @@ static int conv_of_plat(struct udevice *dev) memcpy(&plat->base, of_plat->rockchip_sdram_params, sizeof(plat->base));
plat->num_channels = 1; - ret = regmap_init_mem_plat(dev, of_plat->reg, + ret = regmap_init_mem_plat(dev, (phys_addr_t *)of_plat->reg, ARRAY_SIZE(of_plat->reg) / 2, &plat->map); if (ret) return ret; diff --git a/drivers/ram/rockchip/sdram_rk3288.c b/drivers/ram/rockchip/sdram_rk3288.c index 83778ad1..1a548da5 100644 --- a/drivers/ram/rockchip/sdram_rk3288.c +++ b/drivers/ram/rockchip/sdram_rk3288.c @@ -1029,7 +1029,7 @@ static int conv_of_plat(struct udevice *dev) memcpy(&plat->base, of_plat->rockchip_sdram_params, sizeof(plat->base)); /* Rk3288 supports dual-channel, set default channel num to 2 */ plat->num_channels = 2; - ret = regmap_init_mem_plat(dev, of_plat->reg, + ret = regmap_init_mem_plat(dev, (phys_addr_t *)of_plat->reg, ARRAY_SIZE(of_plat->reg) / 2, &plat->map); if (ret) return ret; diff --git a/drivers/ram/rockchip/sdram_rk3328.c b/drivers/ram/rockchip/sdram_rk3328.c index b511c6bf..2427efe0 100644 --- a/drivers/ram/rockchip/sdram_rk3328.c +++ b/drivers/ram/rockchip/sdram_rk3328.c @@ -54,7 +54,7 @@ static int conv_of_plat(struct udevice *dev) struct dtd_rockchip_rk3328_dmc *dtplat = &plat->dtplat; int ret;
- ret = regmap_init_mem_plat(dev, dtplat->reg, + ret = regmap_init_mem_plat(dev, (phys_addr_t *)dtplat->reg, ARRAY_SIZE(dtplat->reg) / 2, &plat->map); if (ret) return ret; diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 136e4ede..c88fdbb3 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -3049,7 +3049,7 @@ static int conv_of_plat(struct udevice *dev) struct dtd_rockchip_rk3399_dmc *dtplat = &plat->dtplat; int ret;
- ret = regmap_init_mem_plat(dev, dtplat->reg, + ret = regmap_init_mem_plat(dev, (phys_addr_t *)dtplat->reg, ARRAY_SIZE(dtplat->reg) / 2, &plat->map); if (ret) return ret; diff --git a/include/regmap.h b/include/regmap.h index e81a3602..a274fb27 100644 --- a/include/regmap.h +++ b/include/regmap.h @@ -388,7 +388,7 @@ int regmap_init_mem(ofnode node, struct regmap **mapp); * Use regmap_uninit() to free it. * */ -int regmap_init_mem_plat(struct udevice *dev, fdt_val_t *reg, int count, +int regmap_init_mem_plat(struct udevice *dev, phys_addr_t *reg, int count, struct regmap **mapp);
int regmap_init_mem_index(ofnode node, struct regmap **mapp, int index); diff --git a/include/syscon.h b/include/syscon.h index f5e6cc1a..836ae07c 100644 --- a/include/syscon.h +++ b/include/syscon.h @@ -27,14 +27,15 @@ struct syscon_ops {
#if CONFIG_IS_ENABLED(OF_PLATDATA) /* - * We don't support 64-bit machines. If they are so resource-contrained that - * they need to use OF_PLATDATA, something is horribly wrong with the - * education of our hardware engineers. - * - * Update: 64-bit is now supported and we have an education crisis. + * Support for 64bit or 32bit fdt addresses + * depending on the physical SoC properties. */ struct syscon_base_plat { - fdt_val_t reg[2]; +#ifdef CONFIG_PHYS_64BIT + fdt64_t reg[2]; +#else + fdt32_t reg[2]; +#endif }; #endif
-- 2.20.1
Thanks, - Kever
&priv->regmap);
- return regmap_init_mem_plat(dev, (phys_addr_t *)plat->reg,
#else return regmap_init_mem(dev_ofnode(dev), &priv->regmap); #endifARRAY_SIZE(plat->reg) / 2, &priv->regmap);
- ret = regmap_init_mem_plat(dev, (phys_addr_t *)of_plat->reg, ARRAY_SIZE(of_plat->reg) / 2, &plat->map); if (ret) return ret;
- ret = regmap_init_mem_plat(dev, (phys_addr_t *)dtplat->reg, ARRAY_SIZE(dtplat->reg) / 2, &plat->map); if (ret) return ret;
- Use regmap_uninit() to free it.
- We don't support 64-bit machines. If they are so resource-contrained that
- they need to use OF_PLATDATA, something is horribly wrong with the
- education of our hardware engineers.
- Update: 64-bit is now supported and we have an education crisis.
- Support for 64bit or 32bit fdt addresses
- depending on the physical SoC properties.
- fdt_val_t reg[2];
- fdt64_t reg[2];
+#else
- fdt32_t reg[2];
+#endif }; #endif
-- 2.20.1
The fdt_addr_t and phys_addr_t size have been decoupled. A 32bit CPU can expext 64-bit data from the device tree parser, so use dev_read_addr_ptr in the rockchip-saradc.c file.
Signed-off-by: Johan Jonker jbx6244@gmail.com --- drivers/adc/rockchip-saradc.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/adc/rockchip-saradc.c b/drivers/adc/rockchip-saradc.c index 760f8fe6..de9298a2 100644 --- a/drivers/adc/rockchip-saradc.c +++ b/drivers/adc/rockchip-saradc.c @@ -145,8 +145,8 @@ int rockchip_saradc_of_to_plat(struct udevice *dev) struct rockchip_saradc_data *data;
data = (struct rockchip_saradc_data *)dev_get_driver_data(dev); - priv->regs = (struct rockchip_saradc_regs *)dev_read_addr(dev); - if (priv->regs == (struct rockchip_saradc_regs *)FDT_ADDR_T_NONE) { + priv->regs = (struct rockchip_saradc_regs *)dev_read_addr_ptr(dev); + if (!priv->regs) { pr_err("Dev: %s - can't get address!", dev->name); return -ENODATA; } -- 2.20.1
Thanks, - Kever
- priv->regs = (struct rockchip_saradc_regs *)dev_read_addr_ptr(dev);
- if (!priv->regs) { pr_err("Dev: %s - can't get address!", dev->name); return -ENODATA; }
-- 2.20.1
The fdt_addr_t and phys_addr_t size have been decoupled. A 32bit CPU can expect 64-bit data from the device tree parser, so convert dev_read_addr output to phys_addr_t in the dw-apb-timer.c file.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- drivers/timer/dw-apb-timer.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/timer/dw-apb-timer.c b/drivers/timer/dw-apb-timer.c index 10f0a9f6..f55a3c54 100644 --- a/drivers/timer/dw-apb-timer.c +++ b/drivers/timer/dw-apb-timer.c @@ -23,7 +23,7 @@ #define DW_APB_CTRL 0x8
struct dw_apb_timer_priv { - fdt_addr_t regs; + phys_addr_t regs; struct reset_ctl_bulk resets; };
@@ -92,7 +92,7 @@ static int dw_apb_timer_of_to_plat(struct udevice *dev) if (CONFIG_IS_ENABLED(OF_REAL)) { struct dw_apb_timer_priv *priv = dev_get_priv(dev);
- priv->regs = dev_read_addr(dev); + priv->regs = (phys_addr_t)dev_read_addr(dev); }
return 0; -- 2.20.1
The fdt_addr_t and phys_addr_t size have been decoupled. A 32bit CPU can expext 64-bit data from the device tree parser, so use dev_read_addr_ptr in the rockchip_nfc.c file.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-By: Michael Trimarchi michael@amarulasolutions.com --- drivers/mtd/nand/raw/rockchip_nfc.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/nand/raw/rockchip_nfc.c b/drivers/mtd/nand/raw/rockchip_nfc.c index d016d255..5d444133 100644 --- a/drivers/mtd/nand/raw/rockchip_nfc.c +++ b/drivers/mtd/nand/raw/rockchip_nfc.c @@ -1180,9 +1180,9 @@ static int rk_nfc_probe(struct udevice *dev) nfc->cfg = (void *)dev_get_driver_data(dev); nfc->dev = dev;
- nfc->regs = (void *)dev_read_addr(dev); - if (IS_ERR(nfc->regs)) { - ret = PTR_ERR(nfc->regs); + nfc->regs = dev_read_addr_ptr(dev); + if (!nfc->regs) { + ret = -ENODATA; goto release_nfc; }
-- 2.20.1
The compatible string for rk3308 has as fallback string "rockchip,rv1108-nfc". As there is no logic in probe priority between the SoC orientated string and the fall back, so remove the compatible string "rockchip,rk3308-nfc" from the driver.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Kever Yang kever.yang@rock-chips.com Reviewed-by: Michael Trimarchi michael@amarulasolutions.com --- drivers/mtd/nand/raw/rockchip_nfc.c | 4 ---- 1 file changed, 4 deletions(-)
diff --git a/drivers/mtd/nand/raw/rockchip_nfc.c b/drivers/mtd/nand/raw/rockchip_nfc.c index 5d444133..a8ec6bfc 100644 --- a/drivers/mtd/nand/raw/rockchip_nfc.c +++ b/drivers/mtd/nand/raw/rockchip_nfc.c @@ -1165,10 +1165,6 @@ static const struct udevice_id rk_nfc_id_table[] = { .compatible = "rockchip,rv1108-nfc", .data = (unsigned long)&nfc_v8_cfg }, - { - .compatible = "rockchip,rk3308-nfc", - .data = (unsigned long)&nfc_v8_cfg - }, { /* sentinel */ } };
-- 2.20.1
The MTD framework in U-boot is not identical for drivers ported from Linux. The rockchip_nfc driver was ported with OOB ops functions while the framework expects a layout structure per chip. Fix by adding a structure with OOB data and remove unused functions.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Kever Yang kever.yang@rock-chips.com Reviewed-by: Michael Trimarchi michael@amarulasolutions.com --- drivers/mtd/nand/raw/rockchip_nfc.c | 61 ++++++++++------------------- 1 file changed, 20 insertions(+), 41 deletions(-)
diff --git a/drivers/mtd/nand/raw/rockchip_nfc.c b/drivers/mtd/nand/raw/rockchip_nfc.c index a8ec6bfc..ab13e52c 100644 --- a/drivers/mtd/nand/raw/rockchip_nfc.c +++ b/drivers/mtd/nand/raw/rockchip_nfc.c @@ -814,47 +814,9 @@ static void rk_nfc_disable_clks(struct rk_nfc *nfc) clk_disable_unprepare(nfc->ahb_clk); }
-static int rk_nfc_ooblayout_free(struct mtd_info *mtd, int section, - struct mtd_oob_region *oob_region) -{ - struct nand_chip *chip = mtd_to_nand(mtd); - struct rk_nfc_nand_chip *rknand = rk_nfc_to_rknand(chip); - - if (section) - return -ERANGE; - - /* - * The beginning of the OOB area stores the reserved data for the NFC, - * the size of the reserved data is NFC_SYS_DATA_SIZE bytes. - */ - oob_region->length = rknand->metadata_size - NFC_SYS_DATA_SIZE - 2; - oob_region->offset = NFC_SYS_DATA_SIZE + 2; - - return 0; -} - -static int rk_nfc_ooblayout_ecc(struct mtd_info *mtd, int section, - struct mtd_oob_region *oob_region) -{ - struct nand_chip *chip = mtd_to_nand(mtd); - struct rk_nfc_nand_chip *rknand = rk_nfc_to_rknand(chip); - - if (section) - return -ERANGE; - - oob_region->length = mtd->oobsize - rknand->metadata_size; - oob_region->offset = rknand->metadata_size; - - return 0; -} - -static const struct mtd_ooblayout_ops rk_nfc_ooblayout_ops = { - .rfree = rk_nfc_ooblayout_free, - .ecc = rk_nfc_ooblayout_ecc, -}; - static int rk_nfc_ecc_init(struct rk_nfc *nfc, struct nand_chip *chip) { + struct rk_nfc_nand_chip *rknand = rk_nfc_to_rknand(chip); const u8 *strengths = nfc->cfg->ecc_strengths; struct mtd_info *mtd = nand_to_mtd(chip); struct nand_ecc_ctrl *ecc = &chip->ecc; @@ -892,6 +854,21 @@ static int rk_nfc_ecc_init(struct rk_nfc *nfc, struct nand_chip *chip) ecc->steps = mtd->writesize / ecc->size; ecc->bytes = DIV_ROUND_UP(ecc->strength * fls(8 * chip->ecc.size), 8);
+ if (ecc->bytes * ecc->steps > mtd->oobsize - rknand->metadata_size) + return -EINVAL; + + ecc->layout = kzalloc(sizeof(*ecc->layout), GFP_KERNEL); + if (!ecc->layout) + return -ENOMEM; + + ecc->layout->eccbytes = ecc->bytes * ecc->steps; + + for (i = 0; i < ecc->layout->eccbytes; i++) + ecc->layout->eccpos[i] = rknand->metadata_size + i; + + ecc->layout->oobfree[0].length = rknand->metadata_size - NFC_SYS_DATA_SIZE - 2; + ecc->layout->oobfree[0].offset = NFC_SYS_DATA_SIZE + 2; + return 0; }
@@ -969,7 +946,6 @@ static int rk_nfc_nand_chip_init(ofnode node, struct rk_nfc *nfc, int devnum) chip->bbt_options = NAND_BBT_USE_FLASH | NAND_BBT_NO_OOB; chip->options |= NAND_NO_SUBPAGE_WRITE | NAND_USE_BOUNCE_BUFFER;
- mtd_set_ooblayout(mtd, &rk_nfc_ooblayout_ops); rk_nfc_hw_init(nfc); ret = nand_scan_ident(mtd, nsels, NULL); if (ret) @@ -998,13 +974,16 @@ static int rk_nfc_nand_chip_init(ofnode node, struct rk_nfc *nfc, int devnum)
if (!nfc->page_buf) { nfc->page_buf = kzalloc(NFC_MAX_PAGE_SIZE, GFP_KERNEL); - if (!nfc->page_buf) + if (!nfc->page_buf) { + kfree(ecc->layout); return -ENOMEM; + } }
if (!nfc->oob_buf) { nfc->oob_buf = kzalloc(NFC_MAX_OOB_SIZE, GFP_KERNEL); if (!nfc->oob_buf) { + kfree(ecc->layout); kfree(nfc->page_buf); nfc->page_buf = NULL; return -ENOMEM; -- 2.20.1
Add flash_node to the rockchip_nfc driver chip structure in order to find the partitions in the add_mtd_partitions_of() function.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Kever Yang kever.yang@rock-chips.com Reviewed-by: Michael Trimarchi michael@amarulasolutions.com --- drivers/mtd/nand/raw/rockchip_nfc.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/mtd/nand/raw/rockchip_nfc.c b/drivers/mtd/nand/raw/rockchip_nfc.c index ab13e52c..ca5e7313 100644 --- a/drivers/mtd/nand/raw/rockchip_nfc.c +++ b/drivers/mtd/nand/raw/rockchip_nfc.c @@ -934,6 +934,7 @@ static int rk_nfc_nand_chip_init(ofnode node, struct rk_nfc *nfc, int devnum)
nand_set_controller_data(chip, nfc);
+ chip->flash_node = node; chip->chip_delay = NFC_RB_DELAY_US; chip->select_chip = rk_nfc_select_chip; chip->cmd_ctrl = rk_nfc_cmd; -- 2.20.1
Sandisk SDTNQGAMA is a 8GB size, 3.3V 8 bit chip with 16KB page size, 1KB write size and 40 bit ecc support
Signed-off-by: Paweł Jarosz paweljarosz3691@gmail.com Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- drivers/mtd/nand/raw/nand_ids.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/mtd/nand/raw/nand_ids.c b/drivers/mtd/nand/raw/nand_ids.c index d0cfacc6..22ea5e2f 100644 --- a/drivers/mtd/nand/raw/nand_ids.c +++ b/drivers/mtd/nand/raw/nand_ids.c @@ -48,6 +48,9 @@ struct nand_flash_dev nand_flash_ids[] = { {"TC58NVG6D2 64G 3.3V 8-bit", { .id = {0x98, 0xde, 0x94, 0x82, 0x76, 0x56, 0x04, 0x20} }, SZ_8K, SZ_8K, SZ_2M, 0, 8, 640, NAND_ECC_INFO(40, SZ_1K) }, + {"SDTNQGAMA 64G 3.3V 8-bit", + { .id = {0x45, 0xde, 0x94, 0x93, 0x76, 0x57} }, + SZ_16K, SZ_8K, SZ_4M, 0, 6, 1280, NAND_ECC_INFO(40, SZ_1K) }, {"SDTNRGAMA 64G 3.3V 8-bit", { .id = {0x45, 0xde, 0x94, 0x93, 0x76, 0x50} }, SZ_16K, SZ_8K, SZ_4M, 0, 6, 1280, NAND_ECC_INFO(40, SZ_1K) }, -- 2.20.1
The MTD framework reserves 1 or 2 bytes for the bad block marker depending on the bus size. The rockchip_nfc driver currently only supports a 8 bit bus, but reserves standard 2 bytes for the BBM. The first free OOB byte is therefore OOB2 at offset 2. Page address(PA) bytes are moved to the last 4 positions before ECC. Update the description for U-boot.
Signed-off-by: Johan Jonker jbx6244@gmail.com --- drivers/mtd/nand/raw/rockchip_nfc.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/mtd/nand/raw/rockchip_nfc.c b/drivers/mtd/nand/raw/rockchip_nfc.c index ca5e7313..5ca7eeb8 100644 --- a/drivers/mtd/nand/raw/rockchip_nfc.c +++ b/drivers/mtd/nand/raw/rockchip_nfc.c @@ -487,10 +487,10 @@ static int rk_nfc_write_page_raw(struct mtd_info *mtd, * * BBM OOB1 OOB2 OOB3 |......| PA0 PA1 PA2 PA3 * - * The rk_nfc_ooblayout_free() function already has reserved - * these 4 bytes with: + * The oobfree structure already has reserved these 4 bytes + * together with 2 bytes for BBM by reducing it's length: * - * oob_region->offset = NFC_SYS_DATA_SIZE + 2; + * oobfree[0].length = rknand->metadata_size - NFC_SYS_DATA_SIZE - 2; */ if (!i) memcpy(rk_nfc_oob_ptr(chip, i), @@ -867,7 +867,7 @@ static int rk_nfc_ecc_init(struct rk_nfc *nfc, struct nand_chip *chip) ecc->layout->eccpos[i] = rknand->metadata_size + i;
ecc->layout->oobfree[0].length = rknand->metadata_size - NFC_SYS_DATA_SIZE - 2; - ecc->layout->oobfree[0].offset = NFC_SYS_DATA_SIZE + 2; + ecc->layout->oobfree[0].offset = 2;
Thanks, - Kever
*/ if (!i) memcpy(rk_nfc_oob_ptr(chip, i),* oobfree[0].length = rknand->metadata_size - NFC_SYS_DATA_SIZE - 2;
return 0; }
-- 2.20.1
Dario Binacchi
Johan Jonker
Kever Yang
Michael Nazzareno Trimarchi
