[PATCH] configs: rpi: set NR_DRAM_BANKS to four
With the new RPi4 which has 8 GB of RAM, we can have up to four DRAM banks. Bump up the configuration files to detect all the memory in U-Boot.
Signed-off-by: Matthias Brugger mbrugger@suse.com --- configs/rpi_4_32b_defconfig | 2 +- configs/rpi_4_defconfig | 2 +- configs/rpi_arm64_defconfig | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/configs/rpi_4_32b_defconfig b/configs/rpi_4_32b_defconfig index b22316cbcb..f369bb93bd 100644 --- a/configs/rpi_4_32b_defconfig +++ b/configs/rpi_4_32b_defconfig @@ -4,7 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x00008000 CONFIG_TARGET_RPI_4_32B=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ENV_SIZE=0x4000 -CONFIG_NR_DRAM_BANKS=2 +CONFIG_NR_DRAM_BANKS=4 CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y CONFIG_ARCH_FIXUP_FDT_MEMORY=y diff --git a/configs/rpi_4_defconfig b/configs/rpi_4_defconfig index 165e166bbd..9b90790f06 100644 --- a/configs/rpi_4_defconfig +++ b/configs/rpi_4_defconfig @@ -4,7 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x00080000 CONFIG_TARGET_RPI_4=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ENV_SIZE=0x4000 -CONFIG_NR_DRAM_BANKS=2 +CONFIG_NR_DRAM_BANKS=4 CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y CONFIG_ARCH_FIXUP_FDT_MEMORY=y diff --git a/configs/rpi_arm64_defconfig b/configs/rpi_arm64_defconfig index 0cc4efad70..db375eeba7 100644 --- a/configs/rpi_arm64_defconfig +++ b/configs/rpi_arm64_defconfig @@ -4,7 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x00080000 CONFIG_TARGET_RPI_ARM64=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ENV_SIZE=0x4000 -CONFIG_NR_DRAM_BANKS=2 +CONFIG_NR_DRAM_BANKS=4 CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y CONFIG_USE_PREBOOT=y
Hi Tom,
I just realized that 88bd5b1793 ("configs: Resync with savedefconfig")
Delete the CONFIG_NR_DRAM_BANKS entries as added in this patch, which leads to a regression in RPi4 (only one GB of memory visible to the kernel if you use Grub for booting).
Is it generally wrong to add CONFIG_NR_DRAM_BANKS to the config files? What is the correct approach then?
Regards, Matthias
On Wed, Jul 08, 2020 at 05:21:59PM +0200, Matthias Brugger wrote:
Hi Tom,
So, if savedefconfig removes an entry from the file, it's not needed. In this case we see: config NR_DRAM_BANKS int "Number of DRAM banks" default 1 if ARCH_SUNXI || ARCH_OWL default 4 help This defines the number of DRAM banks.
In the top-level Kconfig file. Since you set it as 4 and 4 is the default, that's what's used: $ make O=/tmp/rpi_4 rpi_4_config -sj $ grep NR_D /tmp/rpi_4/.config CONFIG_NR_DRAM_BANKS=4 $ grep ARCH_FIX /tmp/rpi_4/.config CONFIG_ARCH_FIXUP_FDT_MEMORY=y
Matthias Brugger
