[U-Boot] [PATCH V3] fsl: esdhc: support driver model
Support Driver Model for fsl esdhc driver.
1. Introduce a new structure struct fsl_esdhc_priv 2. Refactor fsl_esdhc_initialize which is originally used by board code. - Introduce fsl_esdhc_init to be common usage for DM and non-DM - Introduce fsl_esdhc_cfg_to_priv to build the bridge for non-DM part. - The original API for board code is still there, but we use 'fsl_esdhc_cfg_to_priv' and 'fsl_esdhc_init' to serve it. 3. All the functions are changed to use 'struct fsl_esdhc_priv', except fsl_esdhc_initialize. 4. Since clk driver is not implemented, use mxc_get_clock to geth the clk and fill 'priv->sdhc_clk'.
Has been tested on i.MX6UL 14X14 EVK board: " =>dm tree .... simple_bus [ + ] | `-- aips-bus@02100000 mmc [ + ] | |-- usdhc@02190000 mmc [ + ] | |-- usdhc@02194000 .... => mmc list FSL_SDHC: 0 (SD) FSL_SDHC: 1 (SD) "
Signed-off-by: Peng Fan van.freenix@gmail.com Cc: York Sun york.sun@nxp.com Cc: Yangbo Lu yangbo.lu@nxp.com Cc: Hector Palacios hector.palacios@digi.com Cc: Eric Nelson eric@nelint.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Pantelis Antoniou panto@antoniou-consulting.com Cc: Simon Glass sjg@chromium.org ---
V3: Fix build error reported by York for PPC.
V2: restructure the V1 patch. Introduce fsl_esdhc_priv structure. Introduce code to handle cd-gpios and non-removable.
drivers/mmc/fsl_esdhc.c | 253 ++++++++++++++++++++++++++++++++++++++++-------- 1 file changed, 213 insertions(+), 40 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index ea5f4bf..3acf9e8 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -20,6 +20,8 @@ #include <fsl_esdhc.h> #include <fdt_support.h> #include <asm/io.h> +#include <dm.h> +#include <asm-generic/gpio.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -72,6 +74,30 @@ struct fsl_esdhc { uint scr; /* eSDHC control register */ };
+/** + * struct fsl_esdhc_priv + * + * @esdhc_regs: registers of the sdhc controller + * @sdhc_clk: Current clk of the sdhc controller + * @bus_width: bus width, 1bit, 4bit or 8bit + * @cfg: mmc config + * @mmc: mmc + * Following is used when Driver Model is enabled for MMC + * @dev: pointer for the device + * @non_removable: 0: removable; 1: non-removable + * @cd_gpio: gpio for card detection + */ +struct fsl_esdhc_priv { + struct fsl_esdhc *esdhc_regs; + unsigned int sdhc_clk; + unsigned int bus_width; + struct mmc_config cfg; + struct mmc *mmc; + struct udevice *dev; + int non_removable; + struct gpio_desc cd_gpio; +}; + /* Return the XFERTYP flags for a given command and data packet */ static uint esdhc_xfertyp(struct mmc_cmd *cmd, struct mmc_data *data) { @@ -118,8 +144,8 @@ static uint esdhc_xfertyp(struct mmc_cmd *cmd, struct mmc_data *data) static void esdhc_pio_read_write(struct mmc *mmc, struct mmc_data *data) { - struct fsl_esdhc_cfg *cfg = mmc->priv; - struct fsl_esdhc *regs = (struct fsl_esdhc *)cfg->esdhc_base; + struct fsl_esdhc_priv *priv = mmc->priv; + struct fsl_esdhc *regs = priv->esdhc_regs; uint blocks; char *buffer; uint databuf; @@ -180,8 +206,8 @@ esdhc_pio_read_write(struct mmc *mmc, struct mmc_data *data) static int esdhc_setup_data(struct mmc *mmc, struct mmc_data *data) { int timeout; - struct fsl_esdhc_cfg *cfg = mmc->priv; - struct fsl_esdhc *regs = (struct fsl_esdhc *)cfg->esdhc_base; + struct fsl_esdhc_priv *priv = mmc->priv; + struct fsl_esdhc *regs = priv->esdhc_regs; #ifdef CONFIG_FSL_LAYERSCAPE dma_addr_t addr; #endif @@ -312,8 +338,8 @@ esdhc_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, struct mmc_data *data) int err = 0; uint xfertyp; uint irqstat; - struct fsl_esdhc_cfg *cfg = mmc->priv; - volatile struct fsl_esdhc *regs = (struct fsl_esdhc *)cfg->esdhc_base; + struct fsl_esdhc_priv *priv = mmc->priv; + struct fsl_esdhc *regs = priv->esdhc_regs;
#ifdef CONFIG_SYS_FSL_ERRATUM_ESDHC111 if (cmd->cmdidx == MMC_CMD_STOP_TRANSMISSION) @@ -482,9 +508,9 @@ out: static void set_sysctl(struct mmc *mmc, uint clock) { int div, pre_div; - struct fsl_esdhc_cfg *cfg = mmc->priv; - volatile struct fsl_esdhc *regs = (struct fsl_esdhc *)cfg->esdhc_base; - int sdhc_clk = cfg->sdhc_clk; + struct fsl_esdhc_priv *priv = mmc->priv; + struct fsl_esdhc *regs = priv->esdhc_regs; + int sdhc_clk = priv->sdhc_clk; uint clk;
if (clock < mmc->cfg->f_min) @@ -527,8 +553,8 @@ static void set_sysctl(struct mmc *mmc, uint clock) #ifdef CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK static void esdhc_clock_control(struct mmc *mmc, bool enable) { - struct fsl_esdhc_cfg *cfg = mmc->priv; - struct fsl_esdhc *regs = (struct fsl_esdhc *)cfg->esdhc_base; + struct fsl_esdhc_priv *priv = mmc->priv; + struct fsl_esdhc *regs = priv->esdhc_regs; u32 value; u32 time_out;
@@ -556,8 +582,8 @@ static void esdhc_clock_control(struct mmc *mmc, bool enable)
static void esdhc_set_ios(struct mmc *mmc) { - struct fsl_esdhc_cfg *cfg = mmc->priv; - struct fsl_esdhc *regs = (struct fsl_esdhc *)cfg->esdhc_base; + struct fsl_esdhc_priv *priv = mmc->priv; + struct fsl_esdhc *regs = priv->esdhc_regs;
#ifdef CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK /* Select to use peripheral clock */ @@ -580,8 +606,8 @@ static void esdhc_set_ios(struct mmc *mmc)
static int esdhc_init(struct mmc *mmc) { - struct fsl_esdhc_cfg *cfg = mmc->priv; - struct fsl_esdhc *regs = (struct fsl_esdhc *)cfg->esdhc_base; + struct fsl_esdhc_priv *priv = mmc->priv; + struct fsl_esdhc *regs = priv->esdhc_regs; int timeout = 1000;
/* Reset the entire host controller */ @@ -621,14 +647,23 @@ static int esdhc_init(struct mmc *mmc)
static int esdhc_getcd(struct mmc *mmc) { - struct fsl_esdhc_cfg *cfg = mmc->priv; - struct fsl_esdhc *regs = (struct fsl_esdhc *)cfg->esdhc_base; + struct fsl_esdhc_priv *priv = mmc->priv; + struct fsl_esdhc *regs = priv->esdhc_regs; int timeout = 1000;
#ifdef CONFIG_ESDHC_DETECT_QUIRK if (CONFIG_ESDHC_DETECT_QUIRK) return 1; #endif + +#ifdef CONFIG_DM_MMC + if (priv->non_removable) + return 1; + + if (dm_gpio_is_valid(&priv->cd_gpio)) + return dm_gpio_get_value(&priv->cd_gpio); +#endif + while (!(esdhc_read32(®s->prsstat) & PRSSTAT_CINS) && --timeout) udelay(1000);
@@ -656,16 +691,29 @@ static const struct mmc_ops esdhc_ops = { .getcd = esdhc_getcd, };
-int fsl_esdhc_initialize(bd_t *bis, struct fsl_esdhc_cfg *cfg) +static int fsl_esdhc_cfg_to_priv(struct fsl_esdhc_cfg *cfg, + struct fsl_esdhc_priv *priv) +{ + if (!cfg || !priv) + return -EINVAL; + + priv->esdhc_regs = (struct fsl_esdhc *)(unsigned long)(cfg->esdhc_base); + priv->bus_width = cfg->max_bus_width; + priv->sdhc_clk = cfg->sdhc_clk; + + return 0; +}; + +static int fsl_esdhc_init(struct fsl_esdhc_priv *priv) { struct fsl_esdhc *regs; struct mmc *mmc; u32 caps, voltage_caps;
- if (!cfg) - return -1; + if (!priv) + return -EINVAL;
- regs = (struct fsl_esdhc *)cfg->esdhc_base; + regs = priv->esdhc_regs;
/* First reset the eSDHC controller */ esdhc_reset(regs); @@ -676,7 +724,7 @@ int fsl_esdhc_initialize(bd_t *bis, struct fsl_esdhc_cfg *cfg) #endif
writel(SDHCI_IRQ_EN_BITS, ®s->irqstaten); - memset(&cfg->cfg, 0, sizeof(cfg->cfg)); + memset(&priv->cfg, 0, sizeof(priv->cfg));
voltage_caps = 0; caps = esdhc_read32(®s->hostcapblt); @@ -698,47 +746,83 @@ int fsl_esdhc_initialize(bd_t *bis, struct fsl_esdhc_cfg *cfg) if (caps & ESDHC_HOSTCAPBLT_VS33) voltage_caps |= MMC_VDD_32_33 | MMC_VDD_33_34;
- cfg->cfg.name = "FSL_SDHC"; - cfg->cfg.ops = &esdhc_ops; + priv->cfg.name = "FSL_SDHC"; + priv->cfg.ops = &esdhc_ops; #ifdef CONFIG_SYS_SD_VOLTAGE - cfg->cfg.voltages = CONFIG_SYS_SD_VOLTAGE; + priv->cfg.voltages = CONFIG_SYS_SD_VOLTAGE; #else - cfg->cfg.voltages = MMC_VDD_32_33 | MMC_VDD_33_34; + priv->cfg.voltages = MMC_VDD_32_33 | MMC_VDD_33_34; #endif - if ((cfg->cfg.voltages & voltage_caps) == 0) { + if ((priv->cfg.voltages & voltage_caps) == 0) { printf("voltage not supported by controller\n"); return -1; }
- cfg->cfg.host_caps = MMC_MODE_4BIT | MMC_MODE_8BIT; + if (priv->bus_width == 8) + priv->cfg.host_caps = MMC_MODE_4BIT | MMC_MODE_8BIT; + else if (priv->bus_width == 4) + priv->cfg.host_caps = MMC_MODE_4BIT; + + priv->cfg.host_caps = MMC_MODE_4BIT | MMC_MODE_8BIT; #ifdef CONFIG_SYS_FSL_ESDHC_HAS_DDR_MODE - cfg->cfg.host_caps |= MMC_MODE_DDR_52MHz; + priv->cfg.host_caps |= MMC_MODE_DDR_52MHz; #endif
- if (cfg->max_bus_width > 0) { - if (cfg->max_bus_width < 8) - cfg->cfg.host_caps &= ~MMC_MODE_8BIT; - if (cfg->max_bus_width < 4) - cfg->cfg.host_caps &= ~MMC_MODE_4BIT; + if (priv->bus_width > 0) { + if (priv->bus_width < 8) + priv->cfg.host_caps &= ~MMC_MODE_8BIT; + if (priv->bus_width < 4) + priv->cfg.host_caps &= ~MMC_MODE_4BIT; }
if (caps & ESDHC_HOSTCAPBLT_HSS) - cfg->cfg.host_caps |= MMC_MODE_HS_52MHz | MMC_MODE_HS; + priv->cfg.host_caps |= MMC_MODE_HS_52MHz | MMC_MODE_HS;
#ifdef CONFIG_ESDHC_DETECT_8_BIT_QUIRK if (CONFIG_ESDHC_DETECT_8_BIT_QUIRK) - cfg->cfg.host_caps &= ~MMC_MODE_8BIT; + priv->cfg.host_caps &= ~MMC_MODE_8BIT; #endif
- cfg->cfg.f_min = 400000; - cfg->cfg.f_max = min(cfg->sdhc_clk, (u32)52000000); + priv->cfg.f_min = 400000; + priv->cfg.f_max = min(priv->sdhc_clk, (u32)52000000);
- cfg->cfg.b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT; + priv->cfg.b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT;
- mmc = mmc_create(&cfg->cfg, cfg); + mmc = mmc_create(&priv->cfg, priv); if (mmc == NULL) return -1;
+ priv->mmc = mmc; + + return 0; +} + +int fsl_esdhc_initialize(bd_t *bis, struct fsl_esdhc_cfg *cfg) +{ + struct fsl_esdhc_priv *priv; + int ret; + + if (!cfg) + return -EINVAL; + + priv = calloc(sizeof(struct fsl_esdhc_priv), 1); + if (!priv) + return -ENOMEM; + + ret = fsl_esdhc_cfg_to_priv(cfg, priv); + if (ret) { + debug("%s xlate failure\n", __func__); + free(priv); + return ret; + } + + ret = fsl_esdhc_init(priv); + if (ret) { + debug("%s init failure\n", __func__); + free(priv); + return ret; + } + return 0; }
@@ -819,3 +903,92 @@ void fdt_fixup_esdhc(void *blob, bd_t *bd) 4 + 1, 1); } #endif + +#ifdef CONFIG_DM_MMC +#include <asm/arch/clock.h> +static int fsl_esdhc_probe(struct udevice *dev) +{ + struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); + struct fsl_esdhc_priv *priv = dev_get_priv(dev); + const void *fdt = gd->fdt_blob; + int node = dev->of_offset; + fdt_addr_t addr; + unsigned int val; + int ret; + + addr = dev_get_addr(dev); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + priv->esdhc_regs = (struct fsl_esdhc *)addr; + priv->dev = dev; + + val = fdtdec_get_int(fdt, node, "bus-width", -1); + if (val == 8) + priv->bus_width = 8; + else if (val == 4) + priv->bus_width = 4; + else + priv->bus_width = 1; + + if (fdt_get_property(fdt, node, "non-removable", NULL)) { + priv->non_removable = 1; + } else { + priv->non_removable = 0; + gpio_request_by_name_nodev(fdt, node, "cd-gpios", 0, + &priv->cd_gpio, GPIOD_IS_IN); + } + + /* + * TODO: + * Because lack of clk driver, if SDHC clk is not enabled, + * need to enable it first before this driver is invoked. + * + * we use MXC_ESDHC_CLK to get clk freq. + * If one would like to make this function work, + * the aliases should be provided in dts as this: + * + * aliases { + * mmc0 = &usdhc1; + * mmc1 = &usdhc2; + * mmc2 = &usdhc3; + * mmc3 = &usdhc4; + * }; + * Then if your board only supports mmc2 and mmc3, but we can + * correctly get the seq as 2 and 3, then let mxc_get_clock + * work as expected. + */ + priv->sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK + dev->seq); + if (priv->sdhc_clk <= 0) { + dev_err(dev, "Unable to get clk for %s\n", dev->name); + return -EINVAL; + } + + ret = fsl_esdhc_init(priv); + if (ret) { + dev_err(dev, "fsl_esdhc_init failure\n"); + return ret; + } + + upriv->mmc = priv->mmc; + + return 0; +} + +static const struct udevice_id fsl_esdhc_ids[] = { + { .compatible = "fsl,imx6ul-usdhc", }, + { .compatible = "fsl,imx6sx-usdhc", }, + { .compatible = "fsl,imx6sl-usdhc", }, + { .compatible = "fsl,imx6q-usdhc", }, + { .compatible = "fsl,imx7d-usdhc", }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(fsl_esdhc) = { + .name = "fsl-esdhc-mmc", + .id = UCLASS_MMC, + .of_match = fsl_esdhc_ids, + .probe = fsl_esdhc_probe, + .priv_auto_alloc_size = sizeof(struct fsl_esdhc_priv), +}; +#endif
Hi Peng,
- Introduce a new structure struct fsl_esdhc_priv
- Refactor fsl_esdhc_initialize which is originally used by board code.
- All the functions are changed to use 'struct fsl_esdhc_priv', except fsl_esdhc_initialize.
- Since clk driver is not implemented, use mxc_get_clock to geth the clk and fill 'priv->sdhc_clk'.
After pulling in device tree files from the mainline kernel, I was able to test this on a SABRE Lite, so you can add my:
Tested-By: Eric Nelson eric@nelint.com
Is somebody prepping patches to pull in support for i.MX6DQ?
Please advise,
Eric
Hi Eric,
On Fri, Mar 25, 2016 at 01:12:39PM -0700, Eric Nelson wrote:
Hi Peng,
Thanks, Eric.
I can not follow you on this? you mean adding dts files for i.MX6DQ or else?
Regards, Peng
Please advise,
Eric
Hi Peng,
Thanks, Eric.
Thank you for adding this support.
Yes, or at least the .dtsi and .h files from arch/arm/boot/dts/.
Your i.MX6UL patch pulled in the files needed for UL, and the same is needed for i.MX6DQ, i.MX6SX and such.
I have a patch pulling i.MX6DQ files from linux-stable (4.4), but don't want to jump in the middle if somebody else is doing this.
Regards,
Eric
Hi Eric,
On Sun, Mar 27, 2016 at 11:18:00AM -0700, Eric Nelson wrote:
Hi Peng,
Thanks, Eric.
That's great.
I have not began this. If you have patches, feel free to post them out:)
Thanks, Peng.
Regards,
Eric
Copy device tree headers and include (.dtsi) files for i.MX6 Dual and Quad variants.
These are copied as-is from Linux stable (4.4.1).
Signed-off-by: Eric Nelson eric@nelint.com --- Pulling these files in was sufficient to allow testing of Peng's driver model patch adding DM support to fsl_esdhc on SABRE Lite: http://lists.denx.de/pipermail/u-boot/2016-March/thread.html#249704
The card detect pin on SABRE Lite and Nitrogen is active low though, and this patch is needed to address that: https://patchwork.ozlabs.org/patch/602096/
In order to remove board-specific MMC initialization when DM is used, it can be conditionally included by adding a test in nitrogen6x.c:
#if defined(CONFIG_FSL_ESDHC) && !defined(CONFIG_DM)
arch/arm/dts/imx6dl-pinfunc.h | 1091 +++++++++++++++++++++++++ arch/arm/dts/imx6dl.dtsi | 128 +++ arch/arm/dts/imx6q-pinfunc.h | 1047 ++++++++++++++++++++++++ arch/arm/dts/imx6q.dtsi | 318 ++++++++ arch/arm/dts/imx6qdl.dtsi | 1247 +++++++++++++++++++++++++++++ include/dt-bindings/clock/imx6qdl-clock.h | 260 ++++++ 6 files changed, 4091 insertions(+) create mode 100644 arch/arm/dts/imx6dl-pinfunc.h create mode 100644 arch/arm/dts/imx6dl.dtsi create mode 100644 arch/arm/dts/imx6q-pinfunc.h create mode 100644 arch/arm/dts/imx6q.dtsi create mode 100644 arch/arm/dts/imx6qdl.dtsi create mode 100644 include/dt-bindings/clock/imx6qdl-clock.h
diff --git a/arch/arm/dts/imx6dl-pinfunc.h b/arch/arm/dts/imx6dl-pinfunc.h new file mode 100644 index 0000000..0ead323 --- /dev/null +++ b/arch/arm/dts/imx6dl-pinfunc.h @@ -0,0 +1,1091 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * + */ + +#ifndef __DTS_IMX6DL_PINFUNC_H +#define __DTS_IMX6DL_PINFUNC_H + +/* + * The pin function ID is a tuple of + * <mux_reg conf_reg input_reg mux_mode input_val> + */ +#define MX6QDL_PAD_CSI0_DAT10__IPU1_CSI0_DATA10 0x04c 0x360 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT10__AUD3_RXC 0x04c 0x360 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT10__ECSPI2_MISO 0x04c 0x360 0x7f8 0x2 0x0 +#define MX6QDL_PAD_CSI0_DAT10__UART1_TX_DATA 0x04c 0x360 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT10__UART1_RX_DATA 0x04c 0x360 0x8fc 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT10__GPIO5_IO28 0x04c 0x360 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT10__ARM_TRACE07 0x04c 0x360 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT11__IPU1_CSI0_DATA11 0x050 0x364 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT11__AUD3_RXFS 0x050 0x364 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT11__ECSPI2_SS0 0x050 0x364 0x800 0x2 0x0 +#define MX6QDL_PAD_CSI0_DAT11__UART1_RX_DATA 0x050 0x364 0x8fc 0x3 0x1 +#define MX6QDL_PAD_CSI0_DAT11__UART1_TX_DATA 0x050 0x364 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT11__GPIO5_IO29 0x050 0x364 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT11__ARM_TRACE08 0x050 0x364 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT12__IPU1_CSI0_DATA12 0x054 0x368 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT12__EIM_DATA08 0x054 0x368 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT12__UART4_TX_DATA 0x054 0x368 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT12__UART4_RX_DATA 0x054 0x368 0x914 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT12__GPIO5_IO30 0x054 0x368 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT12__ARM_TRACE09 0x054 0x368 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT13__IPU1_CSI0_DATA13 0x058 0x36c 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT13__EIM_DATA09 0x058 0x36c 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT13__UART4_RX_DATA 0x058 0x36c 0x914 0x3 0x1 +#define MX6QDL_PAD_CSI0_DAT13__UART4_TX_DATA 0x058 0x36c 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT13__GPIO5_IO31 0x058 0x36c 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT13__ARM_TRACE10 0x058 0x36c 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT14__IPU1_CSI0_DATA14 0x05c 0x370 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT14__EIM_DATA10 0x05c 0x370 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT14__UART5_TX_DATA 0x05c 0x370 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT14__UART5_RX_DATA 0x05c 0x370 0x91c 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT14__GPIO6_IO00 0x05c 0x370 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT14__ARM_TRACE11 0x05c 0x370 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT15__IPU1_CSI0_DATA15 0x060 0x374 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT15__EIM_DATA11 0x060 0x374 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT15__UART5_RX_DATA 0x060 0x374 0x91c 0x3 0x1 +#define MX6QDL_PAD_CSI0_DAT15__UART5_TX_DATA 0x060 0x374 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT15__GPIO6_IO01 0x060 0x374 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT15__ARM_TRACE12 0x060 0x374 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT16__IPU1_CSI0_DATA16 0x064 0x378 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT16__EIM_DATA12 0x064 0x378 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT16__UART4_RTS_B 0x064 0x378 0x910 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT16__UART4_CTS_B 0x064 0x378 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT16__GPIO6_IO02 0x064 0x378 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT16__ARM_TRACE13 0x064 0x378 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT17__IPU1_CSI0_DATA17 0x068 0x37c 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT17__EIM_DATA13 0x068 0x37c 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT17__UART4_CTS_B 0x068 0x37c 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT17__UART4_RTS_B 0x068 0x37c 0x910 0x3 0x1 +#define MX6QDL_PAD_CSI0_DAT17__GPIO6_IO03 0x068 0x37c 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT17__ARM_TRACE14 0x068 0x37c 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT18__IPU1_CSI0_DATA18 0x06c 0x380 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT18__EIM_DATA14 0x06c 0x380 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT18__UART5_RTS_B 0x06c 0x380 0x918 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT18__UART5_CTS_B 0x06c 0x380 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT18__GPIO6_IO04 0x06c 0x380 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT18__ARM_TRACE15 0x06c 0x380 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT19__IPU1_CSI0_DATA19 0x070 0x384 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT19__EIM_DATA15 0x070 0x384 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT19__UART5_CTS_B 0x070 0x384 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT19__UART5_RTS_B 0x070 0x384 0x918 0x3 0x1 +#define MX6QDL_PAD_CSI0_DAT19__GPIO6_IO05 0x070 0x384 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT4__IPU1_CSI0_DATA04 0x074 0x388 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT4__EIM_DATA02 0x074 0x388 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT4__ECSPI1_SCLK 0x074 0x388 0x7d8 0x2 0x0 +#define MX6QDL_PAD_CSI0_DAT4__KEY_COL5 0x074 0x388 0x8c0 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT4__AUD3_TXC 0x074 0x388 0x000 0x4 0x0 +#define MX6QDL_PAD_CSI0_DAT4__GPIO5_IO22 0x074 0x388 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT4__ARM_TRACE01 0x074 0x388 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT5__IPU1_CSI0_DATA05 0x078 0x38c 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT5__EIM_DATA03 0x078 0x38c 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT5__ECSPI1_MOSI 0x078 0x38c 0x7e0 0x2 0x0 +#define MX6QDL_PAD_CSI0_DAT5__KEY_ROW5 0x078 0x38c 0x8cc 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT5__AUD3_TXD 0x078 0x38c 0x000 0x4 0x0 +#define MX6QDL_PAD_CSI0_DAT5__GPIO5_IO23 0x078 0x38c 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT5__ARM_TRACE02 0x078 0x38c 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT6__IPU1_CSI0_DATA06 0x07c 0x390 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT6__EIM_DATA04 0x07c 0x390 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT6__ECSPI1_MISO 0x07c 0x390 0x7dc 0x2 0x0 +#define MX6QDL_PAD_CSI0_DAT6__KEY_COL6 0x07c 0x390 0x8c4 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT6__AUD3_TXFS 0x07c 0x390 0x000 0x4 0x0 +#define MX6QDL_PAD_CSI0_DAT6__GPIO5_IO24 0x07c 0x390 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT6__ARM_TRACE03 0x07c 0x390 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT7__IPU1_CSI0_DATA07 0x080 0x394 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT7__EIM_DATA05 0x080 0x394 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT7__ECSPI1_SS0 0x080 0x394 0x7e4 0x2 0x0 +#define MX6QDL_PAD_CSI0_DAT7__KEY_ROW6 0x080 0x394 0x8d0 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT7__AUD3_RXD 0x080 0x394 0x000 0x4 0x0 +#define MX6QDL_PAD_CSI0_DAT7__GPIO5_IO25 0x080 0x394 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT7__ARM_TRACE04 0x080 0x394 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT8__IPU1_CSI0_DATA08 0x084 0x398 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT8__EIM_DATA06 0x084 0x398 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT8__ECSPI2_SCLK 0x084 0x398 0x7f4 0x2 0x0 +#define MX6QDL_PAD_CSI0_DAT8__KEY_COL7 0x084 0x398 0x8c8 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT8__I2C1_SDA 0x084 0x398 0x86c 0x4 0x0 +#define MX6QDL_PAD_CSI0_DAT8__GPIO5_IO26 0x084 0x398 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT8__ARM_TRACE05 0x084 0x398 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT9__IPU1_CSI0_DATA09 0x088 0x39c 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT9__EIM_DATA07 0x088 0x39c 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT9__ECSPI2_MOSI 0x088 0x39c 0x7fc 0x2 0x0 +#define MX6QDL_PAD_CSI0_DAT9__KEY_ROW7 0x088 0x39c 0x8d4 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT9__I2C1_SCL 0x088 0x39c 0x868 0x4 0x0 +#define MX6QDL_PAD_CSI0_DAT9__GPIO5_IO27 0x088 0x39c 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT9__ARM_TRACE06 0x088 0x39c 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DATA_EN__IPU1_CSI0_DATA_EN 0x08c 0x3a0 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DATA_EN__EIM_DATA00 0x08c 0x3a0 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DATA_EN__GPIO5_IO20 0x08c 0x3a0 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DATA_EN__ARM_TRACE_CLK 0x08c 0x3a0 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_MCLK__IPU1_CSI0_HSYNC 0x090 0x3a4 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_MCLK__CCM_CLKO1 0x090 0x3a4 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_MCLK__GPIO5_IO19 0x090 0x3a4 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_MCLK__ARM_TRACE_CTL 0x090 0x3a4 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_PIXCLK__IPU1_CSI0_PIXCLK 0x094 0x3a8 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_PIXCLK__GPIO5_IO18 0x094 0x3a8 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_PIXCLK__ARM_EVENTO 0x094 0x3a8 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_VSYNC__IPU1_CSI0_VSYNC 0x098 0x3ac 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_VSYNC__EIM_DATA01 0x098 0x3ac 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_VSYNC__GPIO5_IO21 0x098 0x3ac 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_VSYNC__ARM_TRACE00 0x098 0x3ac 0x000 0x7 0x0 +#define MX6QDL_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK 0x09c 0x3b0 0x000 0x0 0x0 +#define MX6QDL_PAD_DI0_DISP_CLK__LCD_CLK 0x09c 0x3b0 0x000 0x1 0x0 +#define MX6QDL_PAD_DI0_DISP_CLK__GPIO4_IO16 0x09c 0x3b0 0x000 0x5 0x0 +#define MX6QDL_PAD_DI0_DISP_CLK__LCD_WR_RWN 0x09c 0x3b0 0x000 0x8 0x0 +#define MX6QDL_PAD_DI0_PIN15__IPU1_DI0_PIN15 0x0a0 0x3b4 0x000 0x0 0x0 +#define MX6QDL_PAD_DI0_PIN15__LCD_ENABLE 0x0a0 0x3b4 0x000 0x1 0x0 +#define MX6QDL_PAD_DI0_PIN15__AUD6_TXC 0x0a0 0x3b4 0x000 0x2 0x0 +#define MX6QDL_PAD_DI0_PIN15__GPIO4_IO17 0x0a0 0x3b4 0x000 0x5 0x0 +#define MX6QDL_PAD_DI0_PIN15__LCD_RD_E 0x0a0 0x3b4 0x000 0x8 0x0 +#define MX6QDL_PAD_DI0_PIN2__IPU1_DI0_PIN02 0x0a4 0x3b8 0x000 0x0 0x0 +#define MX6QDL_PAD_DI0_PIN2__LCD_HSYNC 0x0a4 0x3b8 0x8d8 0x1 0x0 +#define MX6QDL_PAD_DI0_PIN2__AUD6_TXD 0x0a4 0x3b8 0x000 0x2 0x0 +#define MX6QDL_PAD_DI0_PIN2__GPIO4_IO18 0x0a4 0x3b8 0x000 0x5 0x0 +#define MX6QDL_PAD_DI0_PIN2__LCD_RS 0x0a4 0x3b8 0x000 0x8 0x0 +#define MX6QDL_PAD_DI0_PIN3__IPU1_DI0_PIN03 0x0a8 0x3bc 0x000 0x0 0x0 +#define MX6QDL_PAD_DI0_PIN3__LCD_VSYNC 0x0a8 0x3bc 0x000 0x1 0x0 +#define MX6QDL_PAD_DI0_PIN3__AUD6_TXFS 0x0a8 0x3bc 0x000 0x2 0x0 +#define MX6QDL_PAD_DI0_PIN3__GPIO4_IO19 0x0a8 0x3bc 0x000 0x5 0x0 +#define MX6QDL_PAD_DI0_PIN3__LCD_CS 0x0a8 0x3bc 0x000 0x8 0x0 +#define MX6QDL_PAD_DI0_PIN4__IPU1_DI0_PIN04 0x0ac 0x3c0 0x000 0x0 0x0 +#define MX6QDL_PAD_DI0_PIN4__LCD_BUSY 0x0ac 0x3c0 0x8d8 0x1 0x1 +#define MX6QDL_PAD_DI0_PIN4__AUD6_RXD 0x0ac 0x3c0 0x000 0x2 0x0 +#define MX6QDL_PAD_DI0_PIN4__SD1_WP 0x0ac 0x3c0 0x92c 0x3 0x0 +#define MX6QDL_PAD_DI0_PIN4__GPIO4_IO20 0x0ac 0x3c0 0x000 0x5 0x0 +#define MX6QDL_PAD_DI0_PIN4__LCD_RESET 0x0ac 0x3c0 0x000 0x8 0x0 +#define MX6QDL_PAD_DISP0_DAT0__IPU1_DISP0_DATA00 0x0b0 0x3c4 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT0__LCD_DATA00 0x0b0 0x3c4 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT0__ECSPI3_SCLK 0x0b0 0x3c4 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT0__GPIO4_IO21 0x0b0 0x3c4 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT1__IPU1_DISP0_DATA01 0x0b4 0x3c8 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT1__LCD_DATA01 0x0b4 0x3c8 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT1__ECSPI3_MOSI 0x0b4 0x3c8 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT1__GPIO4_IO22 0x0b4 0x3c8 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT10__IPU1_DISP0_DATA10 0x0b8 0x3cc 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT10__LCD_DATA10 0x0b8 0x3cc 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT10__GPIO4_IO31 0x0b8 0x3cc 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT11__IPU1_DISP0_DATA11 0x0bc 0x3d0 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT11__LCD_DATA11 0x0bc 0x3d0 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT11__GPIO5_IO05 0x0bc 0x3d0 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT12__IPU1_DISP0_DATA12 0x0c0 0x3d4 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT12__LCD_DATA12 0x0c0 0x3d4 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT12__GPIO5_IO06 0x0c0 0x3d4 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT13__IPU1_DISP0_DATA13 0x0c4 0x3d8 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT13__LCD_DATA13 0x0c4 0x3d8 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT13__AUD5_RXFS 0x0c4 0x3d8 0x7bc 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT13__GPIO5_IO07 0x0c4 0x3d8 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT14__IPU1_DISP0_DATA14 0x0c8 0x3dc 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT14__LCD_DATA14 0x0c8 0x3dc 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT14__AUD5_RXC 0x0c8 0x3dc 0x7b8 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT14__GPIO5_IO08 0x0c8 0x3dc 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT15__IPU1_DISP0_DATA15 0x0cc 0x3e0 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT15__LCD_DATA15 0x0cc 0x3e0 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT15__ECSPI1_SS1 0x0cc 0x3e0 0x7e8 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT15__ECSPI2_SS1 0x0cc 0x3e0 0x804 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT15__GPIO5_IO09 0x0cc 0x3e0 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT16__IPU1_DISP0_DATA16 0x0d0 0x3e4 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT16__LCD_DATA16 0x0d0 0x3e4 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT16__ECSPI2_MOSI 0x0d0 0x3e4 0x7fc 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT16__AUD5_TXC 0x0d0 0x3e4 0x7c0 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT16__SDMA_EXT_EVENT0 0x0d0 0x3e4 0x8e8 0x4 0x0 +#define MX6QDL_PAD_DISP0_DAT16__GPIO5_IO10 0x0d0 0x3e4 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT17__IPU1_DISP0_DATA17 0x0d4 0x3e8 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT17__LCD_DATA17 0x0d4 0x3e8 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT17__ECSPI2_MISO 0x0d4 0x3e8 0x7f8 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT17__AUD5_TXD 0x0d4 0x3e8 0x7b4 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT17__SDMA_EXT_EVENT1 0x0d4 0x3e8 0x8ec 0x4 0x0 +#define MX6QDL_PAD_DISP0_DAT17__GPIO5_IO11 0x0d4 0x3e8 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT18__IPU1_DISP0_DATA18 0x0d8 0x3ec 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT18__LCD_DATA18 0x0d8 0x3ec 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT18__ECSPI2_SS0 0x0d8 0x3ec 0x800 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT18__AUD5_TXFS 0x0d8 0x3ec 0x7c4 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT18__AUD4_RXFS 0x0d8 0x3ec 0x7a4 0x4 0x0 +#define MX6QDL_PAD_DISP0_DAT18__GPIO5_IO12 0x0d8 0x3ec 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT18__EIM_CS2_B 0x0d8 0x3ec 0x000 0x7 0x0 +#define MX6QDL_PAD_DISP0_DAT19__IPU1_DISP0_DATA19 0x0dc 0x3f0 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT19__LCD_DATA19 0x0dc 0x3f0 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT19__ECSPI2_SCLK 0x0dc 0x3f0 0x7f4 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT19__AUD5_RXD 0x0dc 0x3f0 0x7b0 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT19__AUD4_RXC 0x0dc 0x3f0 0x7a0 0x4 0x0 +#define MX6QDL_PAD_DISP0_DAT19__GPIO5_IO13 0x0dc 0x3f0 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT19__EIM_CS3_B 0x0dc 0x3f0 0x000 0x7 0x0 +#define MX6QDL_PAD_DISP0_DAT2__IPU1_DISP0_DATA02 0x0e0 0x3f4 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT2__LCD_DATA02 0x0e0 0x3f4 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT2__ECSPI3_MISO 0x0e0 0x3f4 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT2__GPIO4_IO23 0x0e0 0x3f4 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT20__IPU1_DISP0_DATA20 0x0e4 0x3f8 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT20__LCD_DATA20 0x0e4 0x3f8 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT20__ECSPI1_SCLK 0x0e4 0x3f8 0x7d8 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT20__AUD4_TXC 0x0e4 0x3f8 0x7a8 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT20__GPIO5_IO14 0x0e4 0x3f8 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT21__IPU1_DISP0_DATA21 0x0e8 0x3fc 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT21__LCD_DATA21 0x0e8 0x3fc 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT21__ECSPI1_MOSI 0x0e8 0x3fc 0x7e0 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT21__AUD4_TXD 0x0e8 0x3fc 0x79c 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT21__GPIO5_IO15 0x0e8 0x3fc 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT22__IPU1_DISP0_DATA22 0x0ec 0x400 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT22__LCD_DATA22 0x0ec 0x400 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT22__ECSPI1_MISO 0x0ec 0x400 0x7dc 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT22__AUD4_TXFS 0x0ec 0x400 0x7ac 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT22__GPIO5_IO16 0x0ec 0x400 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT23__IPU1_DISP0_DATA23 0x0f0 0x404 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT23__LCD_DATA23 0x0f0 0x404 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT23__ECSPI1_SS0 0x0f0 0x404 0x7e4 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT23__AUD4_RXD 0x0f0 0x404 0x798 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT23__GPIO5_IO17 0x0f0 0x404 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT3__IPU1_DISP0_DATA03 0x0f4 0x408 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT3__LCD_DATA03 0x0f4 0x408 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT3__ECSPI3_SS0 0x0f4 0x408 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT3__GPIO4_IO24 0x0f4 0x408 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT4__IPU1_DISP0_DATA04 0x0f8 0x40c 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT4__LCD_DATA04 0x0f8 0x40c 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT4__ECSPI3_SS1 0x0f8 0x40c 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT4__GPIO4_IO25 0x0f8 0x40c 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT5__IPU1_DISP0_DATA05 0x0fc 0x410 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT5__LCD_DATA05 0x0fc 0x410 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT5__ECSPI3_SS2 0x0fc 0x410 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT5__AUD6_RXFS 0x0fc 0x410 0x000 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT5__GPIO4_IO26 0x0fc 0x410 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT6__IPU1_DISP0_DATA06 0x100 0x414 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT6__LCD_DATA06 0x100 0x414 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT6__ECSPI3_SS3 0x100 0x414 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT6__AUD6_RXC 0x100 0x414 0x000 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT6__GPIO4_IO27 0x100 0x414 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT7__IPU1_DISP0_DATA07 0x104 0x418 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT7__LCD_DATA07 0x104 0x418 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT7__ECSPI3_RDY 0x104 0x418 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT7__GPIO4_IO28 0x104 0x418 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT8__IPU1_DISP0_DATA08 0x108 0x41c 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT8__LCD_DATA08 0x108 0x41c 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT8__PWM1_OUT 0x108 0x41c 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT8__WDOG1_B 0x108 0x41c 0x000 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT8__GPIO4_IO29 0x108 0x41c 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT9__IPU1_DISP0_DATA09 0x10c 0x420 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT9__LCD_DATA09 0x10c 0x420 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT9__PWM2_OUT 0x10c 0x420 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT9__WDOG2_B 0x10c 0x420 0x000 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT9__GPIO4_IO30 0x10c 0x420 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A16__EIM_ADDR16 0x110 0x4e0 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A16__IPU1_DI1_DISP_CLK 0x110 0x4e0 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A16__IPU1_CSI1_PIXCLK 0x110 0x4e0 0x8b8 0x2 0x0 +#define MX6QDL_PAD_EIM_A16__GPIO2_IO22 0x110 0x4e0 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A16__SRC_BOOT_CFG16 0x110 0x4e0 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A16__EPDC_DATA00 0x110 0x4e0 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_A17__EIM_ADDR17 0x114 0x4e4 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A17__IPU1_DISP1_DATA12 0x114 0x4e4 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A17__IPU1_CSI1_DATA12 0x114 0x4e4 0x890 0x2 0x0 +#define MX6QDL_PAD_EIM_A17__GPIO2_IO21 0x114 0x4e4 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A17__SRC_BOOT_CFG17 0x114 0x4e4 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A17__EPDC_PWR_STAT 0x114 0x4e4 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_A18__EIM_ADDR18 0x118 0x4e8 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A18__IPU1_DISP1_DATA13 0x118 0x4e8 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A18__IPU1_CSI1_DATA13 0x118 0x4e8 0x894 0x2 0x0 +#define MX6QDL_PAD_EIM_A18__GPIO2_IO20 0x118 0x4e8 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A18__SRC_BOOT_CFG18 0x118 0x4e8 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A18__EPDC_PWR_CTRL0 0x118 0x4e8 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_A19__EIM_ADDR19 0x11c 0x4ec 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A19__IPU1_DISP1_DATA14 0x11c 0x4ec 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A19__IPU1_CSI1_DATA14 0x11c 0x4ec 0x898 0x2 0x0 +#define MX6QDL_PAD_EIM_A19__GPIO2_IO19 0x11c 0x4ec 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A19__SRC_BOOT_CFG19 0x11c 0x4ec 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A19__EPDC_PWR_CTRL1 0x11c 0x4ec 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_A20__EIM_ADDR20 0x120 0x4f0 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A20__IPU1_DISP1_DATA15 0x120 0x4f0 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A20__IPU1_CSI1_DATA15 0x120 0x4f0 0x89c 0x2 0x0 +#define MX6QDL_PAD_EIM_A20__GPIO2_IO18 0x120 0x4f0 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A20__SRC_BOOT_CFG20 0x120 0x4f0 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A20__EPDC_PWR_CTRL2 0x120 0x4f0 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_A21__EIM_ADDR21 0x124 0x4f4 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A21__IPU1_DISP1_DATA16 0x124 0x4f4 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A21__IPU1_CSI1_DATA16 0x124 0x4f4 0x8a0 0x2 0x0 +#define MX6QDL_PAD_EIM_A21__GPIO2_IO17 0x124 0x4f4 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A21__SRC_BOOT_CFG21 0x124 0x4f4 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A21__EPDC_GDCLK 0x124 0x4f4 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_A22__EIM_ADDR22 0x128 0x4f8 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A22__IPU1_DISP1_DATA17 0x128 0x4f8 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A22__IPU1_CSI1_DATA17 0x128 0x4f8 0x8a4 0x2 0x0 +#define MX6QDL_PAD_EIM_A22__GPIO2_IO16 0x128 0x4f8 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A22__SRC_BOOT_CFG22 0x128 0x4f8 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A22__EPDC_GDSP 0x128 0x4f8 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_A23__EIM_ADDR23 0x12c 0x4fc 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A23__IPU1_DISP1_DATA18 0x12c 0x4fc 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A23__IPU1_CSI1_DATA18 0x12c 0x4fc 0x8a8 0x2 0x0 +#define MX6QDL_PAD_EIM_A23__IPU1_SISG3 0x12c 0x4fc 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_A23__GPIO6_IO06 0x12c 0x4fc 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A23__SRC_BOOT_CFG23 0x12c 0x4fc 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A23__EPDC_GDOE 0x12c 0x4fc 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_A24__EIM_ADDR24 0x130 0x500 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A24__IPU1_DISP1_DATA19 0x130 0x500 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A24__IPU1_CSI1_DATA19 0x130 0x500 0x8ac 0x2 0x0 +#define MX6QDL_PAD_EIM_A24__IPU1_SISG2 0x130 0x500 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_A24__GPIO5_IO04 0x130 0x500 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A24__SRC_BOOT_CFG24 0x130 0x500 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A24__EPDC_GDRL 0x130 0x500 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_A25__EIM_ADDR25 0x134 0x504 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A25__ECSPI4_SS1 0x134 0x504 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A25__ECSPI2_RDY 0x134 0x504 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_A25__IPU1_DI1_PIN12 0x134 0x504 0x000 0x3 0x0 +#define MX6QDL_PAD_EIM_A25__IPU1_DI0_D1_CS 0x134 0x504 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_A25__GPIO5_IO02 0x134 0x504 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A25__HDMI_TX_CEC_LINE 0x134 0x504 0x85c 0x6 0x0 +#define MX6QDL_PAD_EIM_A25__EPDC_DATA15 0x134 0x504 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_A25__EIM_ACLK_FREERUN 0x134 0x504 0x000 0x9 0x0 +#define MX6QDL_PAD_EIM_BCLK__EIM_BCLK 0x138 0x508 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_BCLK__IPU1_DI1_PIN16 0x138 0x508 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_BCLK__GPIO6_IO31 0x138 0x508 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_BCLK__EPDC_SDCE9 0x138 0x508 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_CS0__EIM_CS0_B 0x13c 0x50c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_CS0__IPU1_DI1_PIN05 0x13c 0x50c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_CS0__ECSPI2_SCLK 0x13c 0x50c 0x7f4 0x2 0x2 +#define MX6QDL_PAD_EIM_CS0__GPIO2_IO23 0x13c 0x50c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_CS0__EPDC_DATA06 0x13c 0x50c 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_CS1__EIM_CS1_B 0x140 0x510 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_CS1__IPU1_DI1_PIN06 0x140 0x510 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_CS1__ECSPI2_MOSI 0x140 0x510 0x7fc 0x2 0x2 +#define MX6QDL_PAD_EIM_CS1__GPIO2_IO24 0x140 0x510 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_CS1__EPDC_DATA08 0x140 0x510 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_D16__EIM_DATA16 0x144 0x514 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D16__ECSPI1_SCLK 0x144 0x514 0x7d8 0x1 0x2 +#define MX6QDL_PAD_EIM_D16__IPU1_DI0_PIN05 0x144 0x514 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D16__IPU1_CSI1_DATA18 0x144 0x514 0x8a8 0x3 0x1 +#define MX6QDL_PAD_EIM_D16__HDMI_TX_DDC_SDA 0x144 0x514 0x864 0x4 0x0 +#define MX6QDL_PAD_EIM_D16__GPIO3_IO16 0x144 0x514 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D16__I2C2_SDA 0x144 0x514 0x874 0x6 0x0 +#define MX6QDL_PAD_EIM_D16__EPDC_DATA10 0x144 0x514 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_D17__EIM_DATA17 0x148 0x518 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D17__ECSPI1_MISO 0x148 0x518 0x7dc 0x1 0x2 +#define MX6QDL_PAD_EIM_D17__IPU1_DI0_PIN06 0x148 0x518 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D17__IPU1_CSI1_PIXCLK 0x148 0x518 0x8b8 0x3 0x1 +#define MX6QDL_PAD_EIM_D17__DCIC1_OUT 0x148 0x518 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D17__GPIO3_IO17 0x148 0x518 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D17__I2C3_SCL 0x148 0x518 0x878 0x6 0x0 +#define MX6QDL_PAD_EIM_D17__EPDC_VCOM0 0x148 0x518 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_D18__EIM_DATA18 0x14c 0x51c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D18__ECSPI1_MOSI 0x14c 0x51c 0x7e0 0x1 0x2 +#define MX6QDL_PAD_EIM_D18__IPU1_DI0_PIN07 0x14c 0x51c 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D18__IPU1_CSI1_DATA17 0x14c 0x51c 0x8a4 0x3 0x1 +#define MX6QDL_PAD_EIM_D18__IPU1_DI1_D0_CS 0x14c 0x51c 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D18__GPIO3_IO18 0x14c 0x51c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D18__I2C3_SDA 0x14c 0x51c 0x87c 0x6 0x0 +#define MX6QDL_PAD_EIM_D18__EPDC_VCOM1 0x14c 0x51c 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_D19__EIM_DATA19 0x150 0x520 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D19__ECSPI1_SS1 0x150 0x520 0x7e8 0x1 0x1 +#define MX6QDL_PAD_EIM_D19__IPU1_DI0_PIN08 0x150 0x520 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D19__IPU1_CSI1_DATA16 0x150 0x520 0x8a0 0x3 0x1 +#define MX6QDL_PAD_EIM_D19__UART1_CTS_B 0x150 0x520 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D19__UART1_RTS_B 0x150 0x520 0x8f8 0x4 0x0 +#define MX6QDL_PAD_EIM_D19__GPIO3_IO19 0x150 0x520 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D19__EPIT1_OUT 0x150 0x520 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_D19__EPDC_DATA12 0x150 0x520 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_D20__EIM_DATA20 0x154 0x524 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D20__ECSPI4_SS0 0x154 0x524 0x808 0x1 0x0 +#define MX6QDL_PAD_EIM_D20__IPU1_DI0_PIN16 0x154 0x524 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D20__IPU1_CSI1_DATA15 0x154 0x524 0x89c 0x3 0x1 +#define MX6QDL_PAD_EIM_D20__UART1_RTS_B 0x154 0x524 0x8f8 0x4 0x1 +#define MX6QDL_PAD_EIM_D20__UART1_CTS_B 0x154 0x524 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D20__GPIO3_IO20 0x154 0x524 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D20__EPIT2_OUT 0x154 0x524 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_D21__EIM_DATA21 0x158 0x528 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D21__ECSPI4_SCLK 0x158 0x528 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D21__IPU1_DI0_PIN17 0x158 0x528 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D21__IPU1_CSI1_DATA11 0x158 0x528 0x88c 0x3 0x0 +#define MX6QDL_PAD_EIM_D21__USB_OTG_OC 0x158 0x528 0x920 0x4 0x0 +#define MX6QDL_PAD_EIM_D21__GPIO3_IO21 0x158 0x528 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D21__I2C1_SCL 0x158 0x528 0x868 0x6 0x1 +#define MX6QDL_PAD_EIM_D21__SPDIF_IN 0x158 0x528 0x8f0 0x7 0x0 +#define MX6QDL_PAD_EIM_D22__EIM_DATA22 0x15c 0x52c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D22__ECSPI4_MISO 0x15c 0x52c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D22__IPU1_DI0_PIN01 0x15c 0x52c 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D22__IPU1_CSI1_DATA10 0x15c 0x52c 0x888 0x3 0x0 +#define MX6QDL_PAD_EIM_D22__USB_OTG_PWR 0x15c 0x52c 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D22__GPIO3_IO22 0x15c 0x52c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D22__SPDIF_OUT 0x15c 0x52c 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_D22__EPDC_SDCE6 0x15c 0x52c 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_D23__EIM_DATA23 0x160 0x530 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D23__IPU1_DI0_D0_CS 0x160 0x530 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D23__UART3_CTS_B 0x160 0x530 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D23__UART3_RTS_B 0x160 0x530 0x908 0x2 0x0 +#define MX6QDL_PAD_EIM_D23__UART1_DCD_B 0x160 0x530 0x000 0x3 0x0 +#define MX6QDL_PAD_EIM_D23__IPU1_CSI1_DATA_EN 0x160 0x530 0x8b0 0x4 0x0 +#define MX6QDL_PAD_EIM_D23__GPIO3_IO23 0x160 0x530 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D23__IPU1_DI1_PIN02 0x160 0x530 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_D23__IPU1_DI1_PIN14 0x160 0x530 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_D23__EPDC_DATA11 0x160 0x530 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_D24__EIM_DATA24 0x164 0x534 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D24__ECSPI4_SS2 0x164 0x534 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D24__UART3_TX_DATA 0x164 0x534 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D24__UART3_RX_DATA 0x164 0x534 0x90c 0x2 0x0 +#define MX6QDL_PAD_EIM_D24__ECSPI1_SS2 0x164 0x534 0x7ec 0x3 0x0 +#define MX6QDL_PAD_EIM_D24__ECSPI2_SS2 0x164 0x534 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D24__GPIO3_IO24 0x164 0x534 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D24__AUD5_RXFS 0x164 0x534 0x7bc 0x6 0x1 +#define MX6QDL_PAD_EIM_D24__UART1_DTR_B 0x164 0x534 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_D24__EPDC_SDCE7 0x164 0x534 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_D25__EIM_DATA25 0x168 0x538 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D25__ECSPI4_SS3 0x168 0x538 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D25__UART3_RX_DATA 0x168 0x538 0x90c 0x2 0x1 +#define MX6QDL_PAD_EIM_D25__UART3_TX_DATA 0x168 0x538 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D25__ECSPI1_SS3 0x168 0x538 0x7f0 0x3 0x0 +#define MX6QDL_PAD_EIM_D25__ECSPI2_SS3 0x168 0x538 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D25__GPIO3_IO25 0x168 0x538 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D25__AUD5_RXC 0x168 0x538 0x7b8 0x6 0x1 +#define MX6QDL_PAD_EIM_D25__UART1_DSR_B 0x168 0x538 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_D25__EPDC_SDCE8 0x168 0x538 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_D26__EIM_DATA26 0x16c 0x53c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D26__IPU1_DI1_PIN11 0x16c 0x53c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D26__IPU1_CSI0_DATA01 0x16c 0x53c 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D26__IPU1_CSI1_DATA14 0x16c 0x53c 0x898 0x3 0x1 +#define MX6QDL_PAD_EIM_D26__UART2_TX_DATA 0x16c 0x53c 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D26__UART2_RX_DATA 0x16c 0x53c 0x904 0x4 0x0 +#define MX6QDL_PAD_EIM_D26__GPIO3_IO26 0x16c 0x53c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D26__IPU1_SISG2 0x16c 0x53c 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_D26__IPU1_DISP1_DATA22 0x16c 0x53c 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_D26__EPDC_SDOED 0x16c 0x53c 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_D27__EIM_DATA27 0x170 0x540 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D27__IPU1_DI1_PIN13 0x170 0x540 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D27__IPU1_CSI0_DATA00 0x170 0x540 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D27__IPU1_CSI1_DATA13 0x170 0x540 0x894 0x3 0x1 +#define MX6QDL_PAD_EIM_D27__UART2_RX_DATA 0x170 0x540 0x904 0x4 0x1 +#define MX6QDL_PAD_EIM_D27__UART2_TX_DATA 0x170 0x540 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D27__GPIO3_IO27 0x170 0x540 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D27__IPU1_SISG3 0x170 0x540 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_D27__IPU1_DISP1_DATA23 0x170 0x540 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_D27__EPDC_SDOE 0x170 0x540 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_D28__EIM_DATA28 0x174 0x544 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D28__I2C1_SDA 0x174 0x544 0x86c 0x1 0x1 +#define MX6QDL_PAD_EIM_D28__ECSPI4_MOSI 0x174 0x544 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D28__IPU1_CSI1_DATA12 0x174 0x544 0x890 0x3 0x1 +#define MX6QDL_PAD_EIM_D28__UART2_CTS_B 0x174 0x544 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D28__UART2_RTS_B 0x174 0x544 0x900 0x4 0x0 +#define MX6QDL_PAD_EIM_D28__UART2_DTE_CTS_B 0x174 0x544 0x900 0x4 0x0 +#define MX6QDL_PAD_EIM_D28__UART2_DTE_RTS_B 0x174 0x544 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D28__GPIO3_IO28 0x174 0x544 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D28__IPU1_EXT_TRIG 0x174 0x544 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_D28__IPU1_DI0_PIN13 0x174 0x544 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_D28__EPDC_PWR_CTRL3 0x174 0x544 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_D29__EIM_DATA29 0x178 0x548 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D29__IPU1_DI1_PIN15 0x178 0x548 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D29__ECSPI4_SS0 0x178 0x548 0x808 0x2 0x1 +#define MX6QDL_PAD_EIM_D29__UART2_RTS_B 0x178 0x548 0x900 0x4 0x1 +#define MX6QDL_PAD_EIM_D29__UART2_CTS_B 0x178 0x548 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D29__UART2_DTE_RTS_B 0x178 0x548 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D29__UART2_DTE_CTS_B 0x178 0x548 0x900 0x4 0x1 +#define MX6QDL_PAD_EIM_D29__GPIO3_IO29 0x178 0x548 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D29__IPU1_CSI1_VSYNC 0x178 0x548 0x8bc 0x6 0x0 +#define MX6QDL_PAD_EIM_D29__IPU1_DI0_PIN14 0x178 0x548 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_D29__EPDC_PWR_WAKE 0x178 0x548 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_D30__EIM_DATA30 0x17c 0x54c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D30__IPU1_DISP1_DATA21 0x17c 0x54c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D30__IPU1_DI0_PIN11 0x17c 0x54c 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D30__IPU1_CSI0_DATA03 0x17c 0x54c 0x000 0x3 0x0 +#define MX6QDL_PAD_EIM_D30__UART3_CTS_B 0x17c 0x54c 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D30__UART3_RTS_B 0x17c 0x54c 0x908 0x4 0x1 +#define MX6QDL_PAD_EIM_D30__GPIO3_IO30 0x17c 0x54c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D30__USB_H1_OC 0x17c 0x54c 0x924 0x6 0x0 +#define MX6QDL_PAD_EIM_D30__EPDC_SDOEZ 0x17c 0x54c 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_D31__EIM_DATA31 0x180 0x550 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D31__IPU1_DISP1_DATA20 0x180 0x550 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D31__IPU1_DI0_PIN12 0x180 0x550 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D31__IPU1_CSI0_DATA02 0x180 0x550 0x000 0x3 0x0 +#define MX6QDL_PAD_EIM_D31__UART3_RTS_B 0x180 0x550 0x908 0x4 0x2 +#define MX6QDL_PAD_EIM_D31__UART3_CTS_B 0x180 0x550 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D31__GPIO3_IO31 0x180 0x550 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D31__USB_H1_PWR 0x180 0x550 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_D31__EPDC_SDCLK_P 0x180 0x550 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_D31__EIM_ACLK_FREERUN 0x180 0x550 0x000 0x9 0x0 +#define MX6QDL_PAD_EIM_DA0__EIM_AD00 0x184 0x554 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA0__IPU1_DISP1_DATA09 0x184 0x554 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA0__IPU1_CSI1_DATA09 0x184 0x554 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA0__GPIO3_IO00 0x184 0x554 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA0__SRC_BOOT_CFG00 0x184 0x554 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA0__EPDC_SDCLK_N 0x184 0x554 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_DA1__EIM_AD01 0x188 0x558 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA1__IPU1_DISP1_DATA08 0x188 0x558 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA1__IPU1_CSI1_DATA08 0x188 0x558 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA1__GPIO3_IO01 0x188 0x558 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA1__SRC_BOOT_CFG01 0x188 0x558 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA1__EPDC_SDLE 0x188 0x558 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_DA10__EIM_AD10 0x18c 0x55c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA10__IPU1_DI1_PIN15 0x18c 0x55c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA10__IPU1_CSI1_DATA_EN 0x18c 0x55c 0x8b0 0x2 0x1 +#define MX6QDL_PAD_EIM_DA10__GPIO3_IO10 0x18c 0x55c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA10__SRC_BOOT_CFG10 0x18c 0x55c 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA10__EPDC_DATA01 0x18c 0x55c 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_DA11__EIM_AD11 0x190 0x560 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA11__IPU1_DI1_PIN02 0x190 0x560 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA11__IPU1_CSI1_HSYNC 0x190 0x560 0x8b4 0x2 0x0 +#define MX6QDL_PAD_EIM_DA11__GPIO3_IO11 0x190 0x560 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA11__SRC_BOOT_CFG11 0x190 0x560 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA11__EPDC_DATA03 0x190 0x560 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_DA12__EIM_AD12 0x194 0x564 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA12__IPU1_DI1_PIN03 0x194 0x564 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA12__IPU1_CSI1_VSYNC 0x194 0x564 0x8bc 0x2 0x1 +#define MX6QDL_PAD_EIM_DA12__GPIO3_IO12 0x194 0x564 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA12__SRC_BOOT_CFG12 0x194 0x564 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA12__EPDC_DATA02 0x194 0x564 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_DA13__EIM_AD13 0x198 0x568 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA13__IPU1_DI1_D0_CS 0x198 0x568 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA13__GPIO3_IO13 0x198 0x568 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA13__SRC_BOOT_CFG13 0x198 0x568 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA13__EPDC_DATA13 0x198 0x568 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_DA14__EIM_AD14 0x19c 0x56c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA14__IPU1_DI1_D1_CS 0x19c 0x56c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA14__GPIO3_IO14 0x19c 0x56c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA14__SRC_BOOT_CFG14 0x19c 0x56c 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA14__EPDC_DATA14 0x19c 0x56c 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_DA15__EIM_AD15 0x1a0 0x570 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA15__IPU1_DI1_PIN01 0x1a0 0x570 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA15__IPU1_DI1_PIN04 0x1a0 0x570 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA15__GPIO3_IO15 0x1a0 0x570 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA15__SRC_BOOT_CFG15 0x1a0 0x570 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA15__EPDC_DATA09 0x1a0 0x570 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_DA2__EIM_AD02 0x1a4 0x574 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA2__IPU1_DISP1_DATA07 0x1a4 0x574 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA2__IPU1_CSI1_DATA07 0x1a4 0x574 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA2__GPIO3_IO02 0x1a4 0x574 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA2__SRC_BOOT_CFG02 0x1a4 0x574 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA2__EPDC_BDR0 0x1a4 0x574 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_DA3__EIM_AD03 0x1a8 0x578 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA3__IPU1_DISP1_DATA06 0x1a8 0x578 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA3__IPU1_CSI1_DATA06 0x1a8 0x578 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA3__GPIO3_IO03 0x1a8 0x578 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA3__SRC_BOOT_CFG03 0x1a8 0x578 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA3__EPDC_BDR1 0x1a8 0x578 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_DA4__EIM_AD04 0x1ac 0x57c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA4__IPU1_DISP1_DATA05 0x1ac 0x57c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA4__IPU1_CSI1_DATA05 0x1ac 0x57c 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA4__GPIO3_IO04 0x1ac 0x57c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA4__SRC_BOOT_CFG04 0x1ac 0x57c 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA4__EPDC_SDCE0 0x1ac 0x57c 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_DA5__EIM_AD05 0x1b0 0x580 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA5__IPU1_DISP1_DATA04 0x1b0 0x580 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA5__IPU1_CSI1_DATA04 0x1b0 0x580 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA5__GPIO3_IO05 0x1b0 0x580 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA5__SRC_BOOT_CFG05 0x1b0 0x580 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA5__EPDC_SDCE1 0x1b0 0x580 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_DA6__EIM_AD06 0x1b4 0x584 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA6__IPU1_DISP1_DATA03 0x1b4 0x584 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA6__IPU1_CSI1_DATA03 0x1b4 0x584 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA6__GPIO3_IO06 0x1b4 0x584 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA6__SRC_BOOT_CFG06 0x1b4 0x584 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA6__EPDC_SDCE2 0x1b4 0x584 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_DA7__EIM_AD07 0x1b8 0x588 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA7__IPU1_DISP1_DATA02 0x1b8 0x588 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA7__IPU1_CSI1_DATA02 0x1b8 0x588 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA7__GPIO3_IO07 0x1b8 0x588 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA7__SRC_BOOT_CFG07 0x1b8 0x588 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA7__EPDC_SDCE3 0x1b8 0x588 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_DA8__EIM_AD08 0x1bc 0x58c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA8__IPU1_DISP1_DATA01 0x1bc 0x58c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA8__IPU1_CSI1_DATA01 0x1bc 0x58c 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA8__GPIO3_IO08 0x1bc 0x58c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA8__SRC_BOOT_CFG08 0x1bc 0x58c 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA8__EPDC_SDCE4 0x1bc 0x58c 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_DA9__EIM_AD09 0x1c0 0x590 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA9__IPU1_DISP1_DATA00 0x1c0 0x590 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA9__IPU1_CSI1_DATA00 0x1c0 0x590 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA9__GPIO3_IO09 0x1c0 0x590 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA9__SRC_BOOT_CFG09 0x1c0 0x590 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA9__EPDC_SDCE5 0x1c0 0x590 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_EB0__EIM_EB0_B 0x1c4 0x594 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_EB0__IPU1_DISP1_DATA11 0x1c4 0x594 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_EB0__IPU1_CSI1_DATA11 0x1c4 0x594 0x88c 0x2 0x1 +#define MX6QDL_PAD_EIM_EB0__CCM_PMIC_READY 0x1c4 0x594 0x7d4 0x4 0x0 +#define MX6QDL_PAD_EIM_EB0__GPIO2_IO28 0x1c4 0x594 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_EB0__SRC_BOOT_CFG27 0x1c4 0x594 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_EB0__EPDC_PWR_COM 0x1c4 0x594 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_EB1__EIM_EB1_B 0x1c8 0x598 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_EB1__IPU1_DISP1_DATA10 0x1c8 0x598 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_EB1__IPU1_CSI1_DATA10 0x1c8 0x598 0x888 0x2 0x1 +#define MX6QDL_PAD_EIM_EB1__GPIO2_IO29 0x1c8 0x598 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_EB1__SRC_BOOT_CFG28 0x1c8 0x598 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_EB1__EPDC_SDSHR 0x1c8 0x598 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_EB2__EIM_EB2_B 0x1cc 0x59c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_EB2__ECSPI1_SS0 0x1cc 0x59c 0x7e4 0x1 0x2 +#define MX6QDL_PAD_EIM_EB2__IPU1_CSI1_DATA19 0x1cc 0x59c 0x8ac 0x3 0x1 +#define MX6QDL_PAD_EIM_EB2__HDMI_TX_DDC_SCL 0x1cc 0x59c 0x860 0x4 0x0 +#define MX6QDL_PAD_EIM_EB2__GPIO2_IO30 0x1cc 0x59c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_EB2__I2C2_SCL 0x1cc 0x59c 0x870 0x6 0x0 +#define MX6QDL_PAD_EIM_EB2__SRC_BOOT_CFG30 0x1cc 0x59c 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_EB2__EPDC_DATA05 0x1cc 0x59c 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_EB3__EIM_EB3_B 0x1d0 0x5a0 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_EB3__ECSPI4_RDY 0x1d0 0x5a0 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_EB3__UART3_RTS_B 0x1d0 0x5a0 0x908 0x2 0x3 +#define MX6QDL_PAD_EIM_EB3__UART3_CTS_B 0x1d0 0x5a0 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_EB3__UART1_RI_B 0x1d0 0x5a0 0x000 0x3 0x0 +#define MX6QDL_PAD_EIM_EB3__IPU1_CSI1_HSYNC 0x1d0 0x5a0 0x8b4 0x4 0x1 +#define MX6QDL_PAD_EIM_EB3__GPIO2_IO31 0x1d0 0x5a0 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_EB3__IPU1_DI1_PIN03 0x1d0 0x5a0 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_EB3__SRC_BOOT_CFG31 0x1d0 0x5a0 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_EB3__EPDC_SDCE0 0x1d0 0x5a0 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_EB3__EIM_ACLK_FREERUN 0x1d0 0x5a0 0x000 0x9 0x0 +#define MX6QDL_PAD_EIM_LBA__EIM_LBA_B 0x1d4 0x5a4 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_LBA__IPU1_DI1_PIN17 0x1d4 0x5a4 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_LBA__ECSPI2_SS1 0x1d4 0x5a4 0x804 0x2 0x1 +#define MX6QDL_PAD_EIM_LBA__GPIO2_IO27 0x1d4 0x5a4 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_LBA__SRC_BOOT_CFG26 0x1d4 0x5a4 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_LBA__EPDC_DATA04 0x1d4 0x5a4 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_OE__EIM_OE_B 0x1d8 0x5a8 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_OE__IPU1_DI1_PIN07 0x1d8 0x5a8 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_OE__ECSPI2_MISO 0x1d8 0x5a8 0x7f8 0x2 0x2 +#define MX6QDL_PAD_EIM_OE__GPIO2_IO25 0x1d8 0x5a8 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_OE__EPDC_PWR_IRQ 0x1d8 0x5a8 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_RW__EIM_RW 0x1dc 0x5ac 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_RW__IPU1_DI1_PIN08 0x1dc 0x5ac 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_RW__ECSPI2_SS0 0x1dc 0x5ac 0x800 0x2 0x2 +#define MX6QDL_PAD_EIM_RW__GPIO2_IO26 0x1dc 0x5ac 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_RW__SRC_BOOT_CFG29 0x1dc 0x5ac 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_RW__EPDC_DATA07 0x1dc 0x5ac 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_WAIT__EIM_WAIT_B 0x1e0 0x5b0 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_WAIT__EIM_DTACK_B 0x1e0 0x5b0 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_WAIT__GPIO5_IO00 0x1e0 0x5b0 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_WAIT__SRC_BOOT_CFG25 0x1e0 0x5b0 0x000 0x7 0x0 +#define MX6QDL_PAD_ENET_CRS_DV__ENET_RX_EN 0x1e4 0x5b4 0x828 0x1 0x0 +#define MX6QDL_PAD_ENET_CRS_DV__ESAI_TX_CLK 0x1e4 0x5b4 0x840 0x2 0x0 +#define MX6QDL_PAD_ENET_CRS_DV__SPDIF_EXT_CLK 0x1e4 0x5b4 0x8f4 0x3 0x0 +#define MX6QDL_PAD_ENET_CRS_DV__GPIO1_IO25 0x1e4 0x5b4 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_MDC__MLB_DATA 0x1e8 0x5b8 0x8e0 0x0 0x0 +#define MX6QDL_PAD_ENET_MDC__ENET_MDC 0x1e8 0x5b8 0x000 0x1 0x0 +#define MX6QDL_PAD_ENET_MDC__ESAI_TX5_RX0 0x1e8 0x5b8 0x858 0x2 0x0 +#define MX6QDL_PAD_ENET_MDC__ENET_1588_EVENT1_IN 0x1e8 0x5b8 0x000 0x4 0x0 +#define MX6QDL_PAD_ENET_MDC__GPIO1_IO31 0x1e8 0x5b8 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_MDIO__ENET_MDIO 0x1ec 0x5bc 0x810 0x1 0x0 +#define MX6QDL_PAD_ENET_MDIO__ESAI_RX_CLK 0x1ec 0x5bc 0x83c 0x2 0x0 +#define MX6QDL_PAD_ENET_MDIO__ENET_1588_EVENT1_OUT 0x1ec 0x5bc 0x000 0x4 0x0 +#define MX6QDL_PAD_ENET_MDIO__GPIO1_IO22 0x1ec 0x5bc 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_MDIO__SPDIF_LOCK 0x1ec 0x5bc 0x000 0x6 0x0 +#define MX6QDL_PAD_ENET_REF_CLK__ENET_TX_CLK 0x1f0 0x5c0 0x000 0x1 0x0 +#define MX6QDL_PAD_ENET_REF_CLK__ESAI_RX_FS 0x1f0 0x5c0 0x82c 0x2 0x0 +#define MX6QDL_PAD_ENET_REF_CLK__GPIO1_IO23 0x1f0 0x5c0 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_REF_CLK__SPDIF_SR_CLK 0x1f0 0x5c0 0x000 0x6 0x0 +#define MX6QDL_PAD_ENET_RX_ER__USB_OTG_ID 0x1f4 0x5c4 0x790 0x0 0x0 +#define MX6QDL_PAD_ENET_RX_ER__ENET_RX_ER 0x1f4 0x5c4 0x000 0x1 0x0 +#define MX6QDL_PAD_ENET_RX_ER__ESAI_RX_HF_CLK 0x1f4 0x5c4 0x834 0x2 0x0 +#define MX6QDL_PAD_ENET_RX_ER__SPDIF_IN 0x1f4 0x5c4 0x8f0 0x3 0x1 +#define MX6QDL_PAD_ENET_RX_ER__ENET_1588_EVENT2_OUT 0x1f4 0x5c4 0x000 0x4 0x0 +#define MX6QDL_PAD_ENET_RX_ER__GPIO1_IO24 0x1f4 0x5c4 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_RXD0__ENET_RX_DATA0 0x1f8 0x5c8 0x818 0x1 0x0 +#define MX6QDL_PAD_ENET_RXD0__ESAI_TX_HF_CLK 0x1f8 0x5c8 0x838 0x2 0x0 +#define MX6QDL_PAD_ENET_RXD0__SPDIF_OUT 0x1f8 0x5c8 0x000 0x3 0x0 +#define MX6QDL_PAD_ENET_RXD0__GPIO1_IO27 0x1f8 0x5c8 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_RXD1__MLB_SIG 0x1fc 0x5cc 0x8e4 0x0 0x0 +#define MX6QDL_PAD_ENET_RXD1__ENET_RX_DATA1 0x1fc 0x5cc 0x81c 0x1 0x0 +#define MX6QDL_PAD_ENET_RXD1__ESAI_TX_FS 0x1fc 0x5cc 0x830 0x2 0x0 +#define MX6QDL_PAD_ENET_RXD1__ENET_1588_EVENT3_OUT 0x1fc 0x5cc 0x000 0x4 0x0 +#define MX6QDL_PAD_ENET_RXD1__GPIO1_IO26 0x1fc 0x5cc 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_TX_EN__ENET_TX_EN 0x200 0x5d0 0x000 0x1 0x0 +#define MX6QDL_PAD_ENET_TX_EN__ESAI_TX3_RX2 0x200 0x5d0 0x850 0x2 0x0 +#define MX6QDL_PAD_ENET_TX_EN__GPIO1_IO28 0x200 0x5d0 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_TX_EN__I2C4_SCL 0x200 0x5d0 0x880 0x9 0x0 +#define MX6QDL_PAD_ENET_TXD0__ENET_TX_DATA0 0x204 0x5d4 0x000 0x1 0x0 +#define MX6QDL_PAD_ENET_TXD0__ESAI_TX4_RX1 0x204 0x5d4 0x854 0x2 0x0 +#define MX6QDL_PAD_ENET_TXD0__GPIO1_IO30 0x204 0x5d4 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_TXD1__MLB_CLK 0x208 0x5d8 0x8dc 0x0 0x0 +#define MX6QDL_PAD_ENET_TXD1__ENET_TX_DATA1 0x208 0x5d8 0x000 0x1 0x0 +#define MX6QDL_PAD_ENET_TXD1__ESAI_TX2_RX3 0x208 0x5d8 0x84c 0x2 0x0 +#define MX6QDL_PAD_ENET_TXD1__ENET_1588_EVENT0_IN 0x208 0x5d8 0x000 0x4 0x0 +#define MX6QDL_PAD_ENET_TXD1__GPIO1_IO29 0x208 0x5d8 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_TXD1__I2C4_SDA 0x208 0x5d8 0x884 0x9 0x0 +#define MX6QDL_PAD_GPIO_0__CCM_CLKO1 0x20c 0x5dc 0x000 0x0 0x0 +#define MX6QDL_PAD_GPIO_0__KEY_COL5 0x20c 0x5dc 0x8c0 0x2 0x1 +#define MX6QDL_PAD_GPIO_0__ASRC_EXT_CLK 0x20c 0x5dc 0x794 0x3 0x0 +#define MX6QDL_PAD_GPIO_0__EPIT1_OUT 0x20c 0x5dc 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_0__GPIO1_IO00 0x20c 0x5dc 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_0__USB_H1_PWR 0x20c 0x5dc 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_0__SNVS_VIO_5 0x20c 0x5dc 0x000 0x7 0x0 +#define MX6QDL_PAD_GPIO_1__ESAI_RX_CLK 0x210 0x5e0 0x83c 0x0 0x1 +#define MX6QDL_PAD_GPIO_1__WDOG2_B 0x210 0x5e0 0x000 0x1 0x0 +#define MX6QDL_PAD_GPIO_1__KEY_ROW5 0x210 0x5e0 0x8cc 0x2 0x1 +#define MX6QDL_PAD_GPIO_1__USB_OTG_ID 0x210 0x5e0 0x790 0x3 0x1 +#define MX6QDL_PAD_GPIO_1__PWM2_OUT 0x210 0x5e0 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_1__GPIO1_IO01 0x210 0x5e0 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_1__SD1_CD_B 0x210 0x5e0 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_16__ESAI_TX3_RX2 0x214 0x5e4 0x850 0x0 0x1 +#define MX6QDL_PAD_GPIO_16__ENET_1588_EVENT2_IN 0x214 0x5e4 0x000 0x1 0x0 +#define MX6QDL_PAD_GPIO_16__ENET_REF_CLK 0x214 0x5e4 0x80c 0x2 0x0 +#define MX6QDL_PAD_GPIO_16__SD1_LCTL 0x214 0x5e4 0x000 0x3 0x0 +#define MX6QDL_PAD_GPIO_16__SPDIF_IN 0x214 0x5e4 0x8f0 0x4 0x2 +#define MX6QDL_PAD_GPIO_16__GPIO7_IO11 0x214 0x5e4 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_16__I2C3_SDA 0x214 0x5e4 0x87c 0x6 0x1 +#define MX6QDL_PAD_GPIO_16__JTAG_DE_B 0x214 0x5e4 0x000 0x7 0x0 +#define MX6QDL_PAD_GPIO_17__ESAI_TX0 0x218 0x5e8 0x844 0x0 0x0 +#define MX6QDL_PAD_GPIO_17__ENET_1588_EVENT3_IN 0x218 0x5e8 0x000 0x1 0x0 +#define MX6QDL_PAD_GPIO_17__CCM_PMIC_READY 0x218 0x5e8 0x7d4 0x2 0x1 +#define MX6QDL_PAD_GPIO_17__SDMA_EXT_EVENT0 0x218 0x5e8 0x8e8 0x3 0x1 +#define MX6QDL_PAD_GPIO_17__SPDIF_OUT 0x218 0x5e8 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_17__GPIO7_IO12 0x218 0x5e8 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_18__ESAI_TX1 0x21c 0x5ec 0x848 0x0 0x0 +#define MX6QDL_PAD_GPIO_18__ENET_RX_CLK 0x21c 0x5ec 0x814 0x1 0x0 +#define MX6QDL_PAD_GPIO_18__SD3_VSELECT 0x21c 0x5ec 0x000 0x2 0x0 +#define MX6QDL_PAD_GPIO_18__SDMA_EXT_EVENT1 0x21c 0x5ec 0x8ec 0x3 0x1 +#define MX6QDL_PAD_GPIO_18__ASRC_EXT_CLK 0x21c 0x5ec 0x794 0x4 0x1 +#define MX6QDL_PAD_GPIO_18__GPIO7_IO13 0x21c 0x5ec 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_18__SNVS_VIO_5_CTL 0x21c 0x5ec 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_19__KEY_COL5 0x220 0x5f0 0x8c0 0x0 0x2 +#define MX6QDL_PAD_GPIO_19__ENET_1588_EVENT0_OUT 0x220 0x5f0 0x000 0x1 0x0 +#define MX6QDL_PAD_GPIO_19__SPDIF_OUT 0x220 0x5f0 0x000 0x2 0x0 +#define MX6QDL_PAD_GPIO_19__CCM_CLKO1 0x220 0x5f0 0x000 0x3 0x0 +#define MX6QDL_PAD_GPIO_19__ECSPI1_RDY 0x220 0x5f0 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_19__GPIO4_IO05 0x220 0x5f0 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_19__ENET_TX_ER 0x220 0x5f0 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_2__ESAI_TX_FS 0x224 0x5f4 0x830 0x0 0x1 +#define MX6QDL_PAD_GPIO_2__KEY_ROW6 0x224 0x5f4 0x8d0 0x2 0x1 +#define MX6QDL_PAD_GPIO_2__GPIO1_IO02 0x224 0x5f4 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_2__SD2_WP 0x224 0x5f4 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_2__MLB_DATA 0x224 0x5f4 0x8e0 0x7 0x1 +#define MX6QDL_PAD_GPIO_3__ESAI_RX_HF_CLK 0x228 0x5f8 0x834 0x0 0x1 +#define MX6QDL_PAD_GPIO_3__I2C3_SCL 0x228 0x5f8 0x878 0x2 0x1 +#define MX6QDL_PAD_GPIO_3__XTALOSC_REF_CLK_24M 0x228 0x5f8 0x000 0x3 0x0 +#define MX6QDL_PAD_GPIO_3__CCM_CLKO2 0x228 0x5f8 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_3__GPIO1_IO03 0x228 0x5f8 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_3__USB_H1_OC 0x228 0x5f8 0x924 0x6 0x1 +#define MX6QDL_PAD_GPIO_3__MLB_CLK 0x228 0x5f8 0x8dc 0x7 0x1 +#define MX6QDL_PAD_GPIO_4__ESAI_TX_HF_CLK 0x22c 0x5fc 0x838 0x0 0x1 +#define MX6QDL_PAD_GPIO_4__KEY_COL7 0x22c 0x5fc 0x8c8 0x2 0x1 +#define MX6QDL_PAD_GPIO_4__GPIO1_IO04 0x22c 0x5fc 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_4__SD2_CD_B 0x22c 0x5fc 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_5__ESAI_TX2_RX3 0x230 0x600 0x84c 0x0 0x1 +#define MX6QDL_PAD_GPIO_5__KEY_ROW7 0x230 0x600 0x8d4 0x2 0x1 +#define MX6QDL_PAD_GPIO_5__CCM_CLKO1 0x230 0x600 0x000 0x3 0x0 +#define MX6QDL_PAD_GPIO_5__GPIO1_IO05 0x230 0x600 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_5__I2C3_SCL 0x230 0x600 0x878 0x6 0x2 +#define MX6QDL_PAD_GPIO_5__ARM_EVENTI 0x230 0x600 0x000 0x7 0x0 +#define MX6QDL_PAD_GPIO_6__ESAI_TX_CLK 0x234 0x604 0x840 0x0 0x1 +#define MX6QDL_PAD_GPIO_6__ENET_IRQ 0x234 0x604 0x03c 0x11 0xff000609 +#define MX6QDL_PAD_GPIO_6__I2C3_SDA 0x234 0x604 0x87c 0x2 0x2 +#define MX6QDL_PAD_GPIO_6__GPIO1_IO06 0x234 0x604 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_6__SD2_LCTL 0x234 0x604 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_6__MLB_SIG 0x234 0x604 0x8e4 0x7 0x1 +#define MX6QDL_PAD_GPIO_7__ESAI_TX4_RX1 0x238 0x608 0x854 0x0 0x1 +#define MX6QDL_PAD_GPIO_7__EPIT1_OUT 0x238 0x608 0x000 0x2 0x0 +#define MX6QDL_PAD_GPIO_7__FLEXCAN1_TX 0x238 0x608 0x000 0x3 0x0 +#define MX6QDL_PAD_GPIO_7__UART2_TX_DATA 0x238 0x608 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_7__UART2_RX_DATA 0x238 0x608 0x904 0x4 0x2 +#define MX6QDL_PAD_GPIO_7__GPIO1_IO07 0x238 0x608 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_7__SPDIF_LOCK 0x238 0x608 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_7__USB_OTG_HOST_MODE 0x238 0x608 0x000 0x7 0x0 +#define MX6QDL_PAD_GPIO_7__I2C4_SCL 0x238 0x608 0x880 0x8 0x1 +#define MX6QDL_PAD_GPIO_8__ESAI_TX5_RX0 0x23c 0x60c 0x858 0x0 0x1 +#define MX6QDL_PAD_GPIO_8__XTALOSC_REF_CLK_32K 0x23c 0x60c 0x000 0x1 0x0 +#define MX6QDL_PAD_GPIO_8__EPIT2_OUT 0x23c 0x60c 0x000 0x2 0x0 +#define MX6QDL_PAD_GPIO_8__FLEXCAN1_RX 0x23c 0x60c 0x7c8 0x3 0x0 +#define MX6QDL_PAD_GPIO_8__UART2_RX_DATA 0x23c 0x60c 0x904 0x4 0x3 +#define MX6QDL_PAD_GPIO_8__UART2_TX_DATA 0x23c 0x60c 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_8__GPIO1_IO08 0x23c 0x60c 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_8__SPDIF_SR_CLK 0x23c 0x60c 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_8__USB_OTG_PWR_CTL_WAKE 0x23c 0x60c 0x000 0x7 0x0 +#define MX6QDL_PAD_GPIO_8__I2C4_SDA 0x23c 0x60c 0x884 0x8 0x1 +#define MX6QDL_PAD_GPIO_9__ESAI_RX_FS 0x240 0x610 0x82c 0x0 0x1 +#define MX6QDL_PAD_GPIO_9__WDOG1_B 0x240 0x610 0x000 0x1 0x0 +#define MX6QDL_PAD_GPIO_9__KEY_COL6 0x240 0x610 0x8c4 0x2 0x1 +#define MX6QDL_PAD_GPIO_9__CCM_REF_EN_B 0x240 0x610 0x000 0x3 0x0 +#define MX6QDL_PAD_GPIO_9__PWM1_OUT 0x240 0x610 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_9__GPIO1_IO09 0x240 0x610 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_9__SD1_WP 0x240 0x610 0x92c 0x6 0x1 +#define MX6QDL_PAD_KEY_COL0__ECSPI1_SCLK 0x244 0x62c 0x7d8 0x0 0x3 +#define MX6QDL_PAD_KEY_COL0__ENET_RX_DATA3 0x244 0x62c 0x824 0x1 0x0 +#define MX6QDL_PAD_KEY_COL0__AUD5_TXC 0x244 0x62c 0x7c0 0x2 0x1 +#define MX6QDL_PAD_KEY_COL0__KEY_COL0 0x244 0x62c 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_COL0__UART4_TX_DATA 0x244 0x62c 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_COL0__UART4_RX_DATA 0x244 0x62c 0x914 0x4 0x2 +#define MX6QDL_PAD_KEY_COL0__GPIO4_IO06 0x244 0x62c 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_COL0__DCIC1_OUT 0x244 0x62c 0x000 0x6 0x0 +#define MX6QDL_PAD_KEY_COL1__ECSPI1_MISO 0x248 0x630 0x7dc 0x0 0x3 +#define MX6QDL_PAD_KEY_COL1__ENET_MDIO 0x248 0x630 0x810 0x1 0x1 +#define MX6QDL_PAD_KEY_COL1__AUD5_TXFS 0x248 0x630 0x7c4 0x2 0x1 +#define MX6QDL_PAD_KEY_COL1__KEY_COL1 0x248 0x630 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_COL1__UART5_TX_DATA 0x248 0x630 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_COL1__UART5_RX_DATA 0x248 0x630 0x91c 0x4 0x2 +#define MX6QDL_PAD_KEY_COL1__GPIO4_IO08 0x248 0x630 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_COL1__SD1_VSELECT 0x248 0x630 0x000 0x6 0x0 +#define MX6QDL_PAD_KEY_COL2__ECSPI1_SS1 0x24c 0x634 0x7e8 0x0 0x2 +#define MX6QDL_PAD_KEY_COL2__ENET_RX_DATA2 0x24c 0x634 0x820 0x1 0x0 +#define MX6QDL_PAD_KEY_COL2__FLEXCAN1_TX 0x24c 0x634 0x000 0x2 0x0 +#define MX6QDL_PAD_KEY_COL2__KEY_COL2 0x24c 0x634 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_COL2__ENET_MDC 0x24c 0x634 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_COL2__GPIO4_IO10 0x24c 0x634 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_COL2__USB_H1_PWR_CTL_WAKE 0x24c 0x634 0x000 0x6 0x0 +#define MX6QDL_PAD_KEY_COL3__ECSPI1_SS3 0x250 0x638 0x7f0 0x0 0x1 +#define MX6QDL_PAD_KEY_COL3__ENET_CRS 0x250 0x638 0x000 0x1 0x0 +#define MX6QDL_PAD_KEY_COL3__HDMI_TX_DDC_SCL 0x250 0x638 0x860 0x2 0x1 +#define MX6QDL_PAD_KEY_COL3__KEY_COL3 0x250 0x638 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_COL3__I2C2_SCL 0x250 0x638 0x870 0x4 0x1 +#define MX6QDL_PAD_KEY_COL3__GPIO4_IO12 0x250 0x638 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_COL3__SPDIF_IN 0x250 0x638 0x8f0 0x6 0x3 +#define MX6QDL_PAD_KEY_COL4__FLEXCAN2_TX 0x254 0x63c 0x000 0x0 0x0 +#define MX6QDL_PAD_KEY_COL4__IPU1_SISG4 0x254 0x63c 0x000 0x1 0x0 +#define MX6QDL_PAD_KEY_COL4__USB_OTG_OC 0x254 0x63c 0x920 0x2 0x1 +#define MX6QDL_PAD_KEY_COL4__KEY_COL4 0x254 0x63c 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_COL4__UART5_RTS_B 0x254 0x63c 0x918 0x4 0x2 +#define MX6QDL_PAD_KEY_COL4__UART5_CTS_B 0x254 0x63c 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_COL4__GPIO4_IO14 0x254 0x63c 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_ROW0__ECSPI1_MOSI 0x258 0x640 0x7e0 0x0 0x3 +#define MX6QDL_PAD_KEY_ROW0__ENET_TX_DATA3 0x258 0x640 0x000 0x1 0x0 +#define MX6QDL_PAD_KEY_ROW0__AUD5_TXD 0x258 0x640 0x7b4 0x2 0x1 +#define MX6QDL_PAD_KEY_ROW0__KEY_ROW0 0x258 0x640 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_ROW0__UART4_RX_DATA 0x258 0x640 0x914 0x4 0x3 +#define MX6QDL_PAD_KEY_ROW0__UART4_TX_DATA 0x258 0x640 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_ROW0__GPIO4_IO07 0x258 0x640 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_ROW0__DCIC2_OUT 0x258 0x640 0x000 0x6 0x0 +#define MX6QDL_PAD_KEY_ROW1__ECSPI1_SS0 0x25c 0x644 0x7e4 0x0 0x3 +#define MX6QDL_PAD_KEY_ROW1__ENET_COL 0x25c 0x644 0x000 0x1 0x0 +#define MX6QDL_PAD_KEY_ROW1__AUD5_RXD 0x25c 0x644 0x7b0 0x2 0x1 +#define MX6QDL_PAD_KEY_ROW1__KEY_ROW1 0x25c 0x644 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_ROW1__UART5_RX_DATA 0x25c 0x644 0x91c 0x4 0x3 +#define MX6QDL_PAD_KEY_ROW1__UART5_TX_DATA 0x25c 0x644 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_ROW1__GPIO4_IO09 0x25c 0x644 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_ROW1__SD2_VSELECT 0x25c 0x644 0x000 0x6 0x0 +#define MX6QDL_PAD_KEY_ROW2__ECSPI1_SS2 0x260 0x648 0x7ec 0x0 0x1 +#define MX6QDL_PAD_KEY_ROW2__ENET_TX_DATA2 0x260 0x648 0x000 0x1 0x0 +#define MX6QDL_PAD_KEY_ROW2__FLEXCAN1_RX 0x260 0x648 0x7c8 0x2 0x1 +#define MX6QDL_PAD_KEY_ROW2__KEY_ROW2 0x260 0x648 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_ROW2__SD2_VSELECT 0x260 0x648 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_ROW2__GPIO4_IO11 0x260 0x648 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_ROW2__HDMI_TX_CEC_LINE 0x260 0x648 0x85c 0x6 0x1 +#define MX6QDL_PAD_KEY_ROW3__ASRC_EXT_CLK 0x264 0x64c 0x794 0x1 0x2 +#define MX6QDL_PAD_KEY_ROW3__HDMI_TX_DDC_SDA 0x264 0x64c 0x864 0x2 0x1 +#define MX6QDL_PAD_KEY_ROW3__KEY_ROW3 0x264 0x64c 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_ROW3__I2C2_SDA 0x264 0x64c 0x874 0x4 0x1 +#define MX6QDL_PAD_KEY_ROW3__GPIO4_IO13 0x264 0x64c 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_ROW3__SD1_VSELECT 0x264 0x64c 0x000 0x6 0x0 +#define MX6QDL_PAD_KEY_ROW4__FLEXCAN2_RX 0x268 0x650 0x7cc 0x0 0x0 +#define MX6QDL_PAD_KEY_ROW4__IPU1_SISG5 0x268 0x650 0x000 0x1 0x0 +#define MX6QDL_PAD_KEY_ROW4__USB_OTG_PWR 0x268 0x650 0x000 0x2 0x0 +#define MX6QDL_PAD_KEY_ROW4__KEY_ROW4 0x268 0x650 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_ROW4__UART5_CTS_B 0x268 0x650 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_ROW4__UART5_RTS_B 0x268 0x650 0x918 0x4 0x3 +#define MX6QDL_PAD_KEY_ROW4__GPIO4_IO15 0x268 0x650 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_ALE__NAND_ALE 0x26c 0x654 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_ALE__SD4_RESET 0x26c 0x654 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_ALE__GPIO6_IO08 0x26c 0x654 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_CLE__NAND_CLE 0x270 0x658 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_CLE__GPIO6_IO07 0x270 0x658 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_CS0__NAND_CE0_B 0x274 0x65c 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_CS0__GPIO6_IO11 0x274 0x65c 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_CS1__NAND_CE1_B 0x278 0x660 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_CS1__SD4_VSELECT 0x278 0x660 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_CS1__SD3_VSELECT 0x278 0x660 0x000 0x2 0x0 +#define MX6QDL_PAD_NANDF_CS1__GPIO6_IO14 0x278 0x660 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_CS2__NAND_CE2_B 0x27c 0x664 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_CS2__IPU1_SISG0 0x27c 0x664 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_CS2__ESAI_TX0 0x27c 0x664 0x844 0x2 0x1 +#define MX6QDL_PAD_NANDF_CS2__EIM_CRE 0x27c 0x664 0x000 0x3 0x0 +#define MX6QDL_PAD_NANDF_CS2__CCM_CLKO2 0x27c 0x664 0x000 0x4 0x0 +#define MX6QDL_PAD_NANDF_CS2__GPIO6_IO15 0x27c 0x664 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_CS3__NAND_CE3_B 0x280 0x668 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_CS3__IPU1_SISG1 0x280 0x668 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_CS3__ESAI_TX1 0x280 0x668 0x848 0x2 0x1 +#define MX6QDL_PAD_NANDF_CS3__EIM_ADDR26 0x280 0x668 0x000 0x3 0x0 +#define MX6QDL_PAD_NANDF_CS3__GPIO6_IO16 0x280 0x668 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_CS3__I2C4_SDA 0x280 0x668 0x884 0x9 0x2 +#define MX6QDL_PAD_NANDF_D0__NAND_DATA00 0x284 0x66c 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D0__SD1_DATA4 0x284 0x66c 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D0__GPIO2_IO00 0x284 0x66c 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_D1__NAND_DATA01 0x288 0x670 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D1__SD1_DATA5 0x288 0x670 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D1__GPIO2_IO01 0x288 0x670 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_D2__NAND_DATA02 0x28c 0x674 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D2__SD1_DATA6 0x28c 0x674 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D2__GPIO2_IO02 0x28c 0x674 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_D3__NAND_DATA03 0x290 0x678 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D3__SD1_DATA7 0x290 0x678 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D3__GPIO2_IO03 0x290 0x678 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_D4__NAND_DATA04 0x294 0x67c 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D4__SD2_DATA4 0x294 0x67c 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D4__GPIO2_IO04 0x294 0x67c 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_D5__NAND_DATA05 0x298 0x680 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D5__SD2_DATA5 0x298 0x680 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D5__GPIO2_IO05 0x298 0x680 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_D6__NAND_DATA06 0x29c 0x684 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D6__SD2_DATA6 0x29c 0x684 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D6__GPIO2_IO06 0x29c 0x684 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_D7__NAND_DATA07 0x2a0 0x688 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D7__SD2_DATA7 0x2a0 0x688 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D7__GPIO2_IO07 0x2a0 0x688 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_RB0__NAND_READY_B 0x2a4 0x68c 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_RB0__GPIO6_IO10 0x2a4 0x68c 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_WP_B__NAND_WP_B 0x2a8 0x690 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_WP_B__GPIO6_IO09 0x2a8 0x690 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_WP_B__I2C4_SCL 0x2a8 0x690 0x880 0x9 0x2 +#define MX6QDL_PAD_RGMII_RD0__HSI_RX_READY 0x2ac 0x694 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_RD0__RGMII_RD0 0x2ac 0x694 0x818 0x1 0x1 +#define MX6QDL_PAD_RGMII_RD0__GPIO6_IO25 0x2ac 0x694 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_RD1__HSI_TX_FLAG 0x2b0 0x698 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_RD1__RGMII_RD1 0x2b0 0x698 0x81c 0x1 0x1 +#define MX6QDL_PAD_RGMII_RD1__GPIO6_IO27 0x2b0 0x698 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_RD2__HSI_TX_DATA 0x2b4 0x69c 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_RD2__RGMII_RD2 0x2b4 0x69c 0x820 0x1 0x1 +#define MX6QDL_PAD_RGMII_RD2__GPIO6_IO28 0x2b4 0x69c 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_RD3__HSI_TX_WAKE 0x2b8 0x6a0 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_RD3__RGMII_RD3 0x2b8 0x6a0 0x824 0x1 0x1 +#define MX6QDL_PAD_RGMII_RD3__GPIO6_IO29 0x2b8 0x6a0 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_RX_CTL__USB_H3_DATA 0x2bc 0x6a4 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_RX_CTL__RGMII_RX_CTL 0x2bc 0x6a4 0x828 0x1 0x1 +#define MX6QDL_PAD_RGMII_RX_CTL__GPIO6_IO24 0x2bc 0x6a4 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_RXC__USB_H3_STROBE 0x2c0 0x6a8 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_RXC__RGMII_RXC 0x2c0 0x6a8 0x814 0x1 0x1 +#define MX6QDL_PAD_RGMII_RXC__GPIO6_IO30 0x2c0 0x6a8 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_TD0__HSI_TX_READY 0x2c4 0x6ac 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_TD0__RGMII_TD0 0x2c4 0x6ac 0x000 0x1 0x0 +#define MX6QDL_PAD_RGMII_TD0__GPIO6_IO20 0x2c4 0x6ac 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_TD1__HSI_RX_FLAG 0x2c8 0x6b0 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_TD1__RGMII_TD1 0x2c8 0x6b0 0x000 0x1 0x0 +#define MX6QDL_PAD_RGMII_TD1__GPIO6_IO21 0x2c8 0x6b0 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_TD2__HSI_RX_DATA 0x2cc 0x6b4 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_TD2__RGMII_TD2 0x2cc 0x6b4 0x000 0x1 0x0 +#define MX6QDL_PAD_RGMII_TD2__GPIO6_IO22 0x2cc 0x6b4 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_TD3__HSI_RX_WAKE 0x2d0 0x6b8 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_TD3__RGMII_TD3 0x2d0 0x6b8 0x000 0x1 0x0 +#define MX6QDL_PAD_RGMII_TD3__GPIO6_IO23 0x2d0 0x6b8 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_TX_CTL__USB_H2_STROBE 0x2d4 0x6bc 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_TX_CTL__RGMII_TX_CTL 0x2d4 0x6bc 0x000 0x1 0x0 +#define MX6QDL_PAD_RGMII_TX_CTL__GPIO6_IO26 0x2d4 0x6bc 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_TX_CTL__ENET_REF_CLK 0x2d4 0x6bc 0x80c 0x7 0x1 +#define MX6QDL_PAD_RGMII_TXC__USB_H2_DATA 0x2d8 0x6c0 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_TXC__RGMII_TXC 0x2d8 0x6c0 0x000 0x1 0x0 +#define MX6QDL_PAD_RGMII_TXC__SPDIF_EXT_CLK 0x2d8 0x6c0 0x8f4 0x2 0x1 +#define MX6QDL_PAD_RGMII_TXC__GPIO6_IO19 0x2d8 0x6c0 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_TXC__XTALOSC_REF_CLK_24M 0x2d8 0x6c0 0x000 0x7 0x0 +#define MX6QDL_PAD_SD1_CLK__SD1_CLK 0x2dc 0x6c4 0x928 0x0 0x1 +#define MX6QDL_PAD_SD1_CLK__OSC32K_32K_OUT 0x2dc 0x6c4 0x000 0x2 0x0 +#define MX6QDL_PAD_SD1_CLK__GPT_CLKIN 0x2dc 0x6c4 0x000 0x3 0x0 +#define MX6QDL_PAD_SD1_CLK__GPIO1_IO20 0x2dc 0x6c4 0x000 0x5 0x0 +#define MX6QDL_PAD_SD1_CMD__SD1_CMD 0x2e0 0x6c8 0x000 0x0 0x0 +#define MX6QDL_PAD_SD1_CMD__PWM4_OUT 0x2e0 0x6c8 0x000 0x2 0x0 +#define MX6QDL_PAD_SD1_CMD__GPT_COMPARE1 0x2e0 0x6c8 0x000 0x3 0x0 +#define MX6QDL_PAD_SD1_CMD__GPIO1_IO18 0x2e0 0x6c8 0x000 0x5 0x0 +#define MX6QDL_PAD_SD1_DAT0__SD1_DATA0 0x2e4 0x6cc 0x000 0x0 0x0 +#define MX6QDL_PAD_SD1_DAT0__GPT_CAPTURE1 0x2e4 0x6cc 0x000 0x3 0x0 +#define MX6QDL_PAD_SD1_DAT0__GPIO1_IO16 0x2e4 0x6cc 0x000 0x5 0x0 +#define MX6QDL_PAD_SD1_DAT1__SD1_DATA1 0x2e8 0x6d0 0x000 0x0 0x0 +#define MX6QDL_PAD_SD1_DAT1__PWM3_OUT 0x2e8 0x6d0 0x000 0x2 0x0 +#define MX6QDL_PAD_SD1_DAT1__GPT_CAPTURE2 0x2e8 0x6d0 0x000 0x3 0x0 +#define MX6QDL_PAD_SD1_DAT1__GPIO1_IO17 0x2e8 0x6d0 0x000 0x5 0x0 +#define MX6QDL_PAD_SD1_DAT2__SD1_DATA2 0x2ec 0x6d4 0x000 0x0 0x0 +#define MX6QDL_PAD_SD1_DAT2__GPT_COMPARE2 0x2ec 0x6d4 0x000 0x2 0x0 +#define MX6QDL_PAD_SD1_DAT2__PWM2_OUT 0x2ec 0x6d4 0x000 0x3 0x0 +#define MX6QDL_PAD_SD1_DAT2__WDOG1_B 0x2ec 0x6d4 0x000 0x4 0x0 +#define MX6QDL_PAD_SD1_DAT2__GPIO1_IO19 0x2ec 0x6d4 0x000 0x5 0x0 +#define MX6QDL_PAD_SD1_DAT2__WDOG1_RESET_B_DEB 0x2ec 0x6d4 0x000 0x6 0x0 +#define MX6QDL_PAD_SD1_DAT3__SD1_DATA3 0x2f0 0x6d8 0x000 0x0 0x0 +#define MX6QDL_PAD_SD1_DAT3__GPT_COMPARE3 0x2f0 0x6d8 0x000 0x2 0x0 +#define MX6QDL_PAD_SD1_DAT3__PWM1_OUT 0x2f0 0x6d8 0x000 0x3 0x0 +#define MX6QDL_PAD_SD1_DAT3__WDOG2_B 0x2f0 0x6d8 0x000 0x4 0x0 +#define MX6QDL_PAD_SD1_DAT3__GPIO1_IO21 0x2f0 0x6d8 0x000 0x5 0x0 +#define MX6QDL_PAD_SD1_DAT3__WDOG2_RESET_B_DEB 0x2f0 0x6d8 0x000 0x6 0x0 +#define MX6QDL_PAD_SD2_CLK__SD2_CLK 0x2f4 0x6dc 0x930 0x0 0x1 +#define MX6QDL_PAD_SD2_CLK__KEY_COL5 0x2f4 0x6dc 0x8c0 0x2 0x3 +#define MX6QDL_PAD_SD2_CLK__AUD4_RXFS 0x2f4 0x6dc 0x7a4 0x3 0x1 +#define MX6QDL_PAD_SD2_CLK__GPIO1_IO10 0x2f4 0x6dc 0x000 0x5 0x0 +#define MX6QDL_PAD_SD2_CMD__SD2_CMD 0x2f8 0x6e0 0x000 0x0 0x0 +#define MX6QDL_PAD_SD2_CMD__KEY_ROW5 0x2f8 0x6e0 0x8cc 0x2 0x2 +#define MX6QDL_PAD_SD2_CMD__AUD4_RXC 0x2f8 0x6e0 0x7a0 0x3 0x1 +#define MX6QDL_PAD_SD2_CMD__GPIO1_IO11 0x2f8 0x6e0 0x000 0x5 0x0 +#define MX6QDL_PAD_SD2_DAT0__SD2_DATA0 0x2fc 0x6e4 0x000 0x0 0x0 +#define MX6QDL_PAD_SD2_DAT0__AUD4_RXD 0x2fc 0x6e4 0x798 0x3 0x1 +#define MX6QDL_PAD_SD2_DAT0__KEY_ROW7 0x2fc 0x6e4 0x8d4 0x4 0x2 +#define MX6QDL_PAD_SD2_DAT0__GPIO1_IO15 0x2fc 0x6e4 0x000 0x5 0x0 +#define MX6QDL_PAD_SD2_DAT0__DCIC2_OUT 0x2fc 0x6e4 0x000 0x6 0x0 +#define MX6QDL_PAD_SD2_DAT1__SD2_DATA1 0x300 0x6e8 0x000 0x0 0x0 +#define MX6QDL_PAD_SD2_DAT1__EIM_CS2_B 0x300 0x6e8 0x000 0x2 0x0 +#define MX6QDL_PAD_SD2_DAT1__AUD4_TXFS 0x300 0x6e8 0x7ac 0x3 0x1 +#define MX6QDL_PAD_SD2_DAT1__KEY_COL7 0x300 0x6e8 0x8c8 0x4 0x2 +#define MX6QDL_PAD_SD2_DAT1__GPIO1_IO14 0x300 0x6e8 0x000 0x5 0x0 +#define MX6QDL_PAD_SD2_DAT2__SD2_DATA2 0x304 0x6ec 0x000 0x0 0x0 +#define MX6QDL_PAD_SD2_DAT2__EIM_CS3_B 0x304 0x6ec 0x000 0x2 0x0 +#define MX6QDL_PAD_SD2_DAT2__AUD4_TXD 0x304 0x6ec 0x79c 0x3 0x1 +#define MX6QDL_PAD_SD2_DAT2__KEY_ROW6 0x304 0x6ec 0x8d0 0x4 0x2 +#define MX6QDL_PAD_SD2_DAT2__GPIO1_IO13 0x304 0x6ec 0x000 0x5 0x0 +#define MX6QDL_PAD_SD2_DAT3__SD2_DATA3 0x308 0x6f0 0x000 0x0 0x0 +#define MX6QDL_PAD_SD2_DAT3__KEY_COL6 0x308 0x6f0 0x8c4 0x2 0x2 +#define MX6QDL_PAD_SD2_DAT3__AUD4_TXC 0x308 0x6f0 0x7a8 0x3 0x1 +#define MX6QDL_PAD_SD2_DAT3__GPIO1_IO12 0x308 0x6f0 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_CLK__SD3_CLK 0x30c 0x6f4 0x934 0x0 0x1 +#define MX6QDL_PAD_SD3_CLK__UART2_RTS_B 0x30c 0x6f4 0x900 0x1 0x2 +#define MX6QDL_PAD_SD3_CLK__UART2_CTS_B 0x30c 0x6f4 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_CLK__FLEXCAN1_RX 0x30c 0x6f4 0x7c8 0x2 0x2 +#define MX6QDL_PAD_SD3_CLK__GPIO7_IO03 0x30c 0x6f4 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_CMD__SD3_CMD 0x310 0x6f8 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_CMD__UART2_CTS_B 0x310 0x6f8 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_CMD__UART2_RTS_B 0x310 0x6f8 0x900 0x1 0x3 +#define MX6QDL_PAD_SD3_CMD__FLEXCAN1_TX 0x310 0x6f8 0x000 0x2 0x0 +#define MX6QDL_PAD_SD3_CMD__GPIO7_IO02 0x310 0x6f8 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT0__SD3_DATA0 0x314 0x6fc 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT0__UART1_CTS_B 0x314 0x6fc 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_DAT0__UART1_RTS_B 0x314 0x6fc 0x8f8 0x1 0x2 +#define MX6QDL_PAD_SD3_DAT0__FLEXCAN2_TX 0x314 0x6fc 0x000 0x2 0x0 +#define MX6QDL_PAD_SD3_DAT0__GPIO7_IO04 0x314 0x6fc 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT1__SD3_DATA1 0x318 0x700 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT1__UART1_RTS_B 0x318 0x700 0x8f8 0x1 0x3 +#define MX6QDL_PAD_SD3_DAT1__UART1_CTS_B 0x318 0x700 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_DAT1__FLEXCAN2_RX 0x318 0x700 0x7cc 0x2 0x1 +#define MX6QDL_PAD_SD3_DAT1__GPIO7_IO05 0x318 0x700 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT2__SD3_DATA2 0x31c 0x704 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT2__GPIO7_IO06 0x31c 0x704 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT3__SD3_DATA3 0x320 0x708 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT3__UART3_CTS_B 0x320 0x708 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_DAT3__UART3_RTS_B 0x320 0x708 0x908 0x1 0x4 +#define MX6QDL_PAD_SD3_DAT3__GPIO7_IO07 0x320 0x708 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT4__SD3_DATA4 0x324 0x70c 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT4__UART2_RX_DATA 0x324 0x70c 0x904 0x1 0x4 +#define MX6QDL_PAD_SD3_DAT4__UART2_TX_DATA 0x324 0x70c 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_DAT4__GPIO7_IO01 0x324 0x70c 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT5__SD3_DATA5 0x328 0x710 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT5__UART2_TX_DATA 0x328 0x710 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_DAT5__UART2_RX_DATA 0x328 0x710 0x904 0x1 0x5 +#define MX6QDL_PAD_SD3_DAT5__GPIO7_IO00 0x328 0x710 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT6__SD3_DATA6 0x32c 0x714 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT6__UART1_RX_DATA 0x32c 0x714 0x8fc 0x1 0x2 +#define MX6QDL_PAD_SD3_DAT6__UART1_TX_DATA 0x32c 0x714 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_DAT6__GPIO6_IO18 0x32c 0x714 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT7__SD3_DATA7 0x330 0x718 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT7__UART1_TX_DATA 0x330 0x718 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_DAT7__UART1_RX_DATA 0x330 0x718 0x8fc 0x1 0x3 +#define MX6QDL_PAD_SD3_DAT7__GPIO6_IO17 0x330 0x718 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_RST__SD3_RESET 0x334 0x71c 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_RST__UART3_RTS_B 0x334 0x71c 0x908 0x1 0x5 +#define MX6QDL_PAD_SD3_RST__UART3_CTS_B 0x334 0x71c 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_RST__GPIO7_IO08 0x334 0x71c 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_CLK__SD4_CLK 0x338 0x720 0x938 0x0 0x1 +#define MX6QDL_PAD_SD4_CLK__NAND_WE_B 0x338 0x720 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_CLK__UART3_RX_DATA 0x338 0x720 0x90c 0x2 0x2 +#define MX6QDL_PAD_SD4_CLK__UART3_TX_DATA 0x338 0x720 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_CLK__GPIO7_IO10 0x338 0x720 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_CMD__SD4_CMD 0x33c 0x724 0x000 0x0 0x0 +#define MX6QDL_PAD_SD4_CMD__NAND_RE_B 0x33c 0x724 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_CMD__UART3_TX_DATA 0x33c 0x724 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_CMD__UART3_RX_DATA 0x33c 0x724 0x90c 0x2 0x3 +#define MX6QDL_PAD_SD4_CMD__GPIO7_IO09 0x33c 0x724 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT0__SD4_DATA0 0x340 0x728 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT0__NAND_DQS 0x340 0x728 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_DAT0__GPIO2_IO08 0x340 0x728 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT1__SD4_DATA1 0x344 0x72c 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT1__PWM3_OUT 0x344 0x72c 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_DAT1__GPIO2_IO09 0x344 0x72c 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT2__SD4_DATA2 0x348 0x730 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT2__PWM4_OUT 0x348 0x730 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_DAT2__GPIO2_IO10 0x348 0x730 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT3__SD4_DATA3 0x34c 0x734 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT3__GPIO2_IO11 0x34c 0x734 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT4__SD4_DATA4 0x350 0x738 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT4__UART2_RX_DATA 0x350 0x738 0x904 0x2 0x6 +#define MX6QDL_PAD_SD4_DAT4__UART2_TX_DATA 0x350 0x738 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_DAT4__GPIO2_IO12 0x350 0x738 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT5__SD4_DATA5 0x354 0x73c 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT5__UART2_RTS_B 0x354 0x73c 0x900 0x2 0x4 +#define MX6QDL_PAD_SD4_DAT5__UART2_CTS_B 0x354 0x73c 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_DAT5__GPIO2_IO13 0x354 0x73c 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT6__SD4_DATA6 0x358 0x740 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT6__UART2_CTS_B 0x358 0x740 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_DAT6__UART2_RTS_B 0x358 0x740 0x900 0x2 0x5 +#define MX6QDL_PAD_SD4_DAT6__GPIO2_IO14 0x358 0x740 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT7__SD4_DATA7 0x35c 0x744 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT7__UART2_TX_DATA 0x35c 0x744 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_DAT7__UART2_RX_DATA 0x35c 0x744 0x904 0x2 0x7 +#define MX6QDL_PAD_SD4_DAT7__GPIO2_IO15 0x35c 0x744 0x000 0x5 0x0 + +#endif /* __DTS_IMX6DL_PINFUNC_H */ diff --git a/arch/arm/dts/imx6dl.dtsi b/arch/arm/dts/imx6dl.dtsi new file mode 100644 index 0000000..4b0ec07 --- /dev/null +++ b/arch/arm/dts/imx6dl.dtsi @@ -0,0 +1,128 @@ + +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * + */ + +#include <dt-bindings/interrupt-controller/irq.h> +#include "imx6dl-pinfunc.h" +#include "imx6qdl.dtsi" + +/ { + aliases { + i2c3 = &i2c4; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + compatible = "arm,cortex-a9"; + device_type = "cpu"; + reg = <0>; + next-level-cache = <&L2>; + operating-points = < + /* kHz uV */ + 996000 1250000 + 792000 1175000 + 396000 1075000 + >; + fsl,soc-operating-points = < + /* ARM kHz SOC-PU uV */ + 996000 1175000 + 792000 1175000 + 396000 1175000 + >; + clock-latency = <61036>; /* two CLK32 periods */ + clocks = <&clks IMX6QDL_CLK_ARM>, + <&clks IMX6QDL_CLK_PLL2_PFD2_396M>, + <&clks IMX6QDL_CLK_STEP>, + <&clks IMX6QDL_CLK_PLL1_SW>, + <&clks IMX6QDL_CLK_PLL1_SYS>; + clock-names = "arm", "pll2_pfd2_396m", "step", + "pll1_sw", "pll1_sys"; + arm-supply = <®_arm>; + pu-supply = <®_pu>; + soc-supply = <®_soc>; + }; + + cpu@1 { + compatible = "arm,cortex-a9"; + device_type = "cpu"; + reg = <1>; + next-level-cache = <&L2>; + }; + }; + + soc { + ocram: sram@00900000 { + compatible = "mmio-sram"; + reg = <0x00900000 0x20000>; + clocks = <&clks IMX6QDL_CLK_OCRAM>; + }; + + aips1: aips-bus@02000000 { + iomuxc: iomuxc@020e0000 { + compatible = "fsl,imx6dl-iomuxc"; + }; + + pxp: pxp@020f0000 { + reg = <0x020f0000 0x4000>; + interrupts = <0 98 IRQ_TYPE_LEVEL_HIGH>; + }; + + epdc: epdc@020f4000 { + reg = <0x020f4000 0x4000>; + interrupts = <0 97 IRQ_TYPE_LEVEL_HIGH>; + }; + + lcdif: lcdif@020f8000 { + reg = <0x020f8000 0x4000>; + interrupts = <0 39 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + aips2: aips-bus@02100000 { + i2c4: i2c@021f8000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx6q-i2c", "fsl,imx21-i2c"; + reg = <0x021f8000 0x4000>; + interrupts = <0 35 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6DL_CLK_I2C4>; + status = "disabled"; + }; + }; + }; + + display-subsystem { + compatible = "fsl,imx-display-subsystem"; + ports = <&ipu1_di0>, <&ipu1_di1>; + }; +}; + +&gpt { + compatible = "fsl,imx6dl-gpt", "fsl,imx6q-gpt"; +}; + +&hdmi { + compatible = "fsl,imx6dl-hdmi"; +}; + +&ldb { + clocks = <&clks IMX6QDL_CLK_LDB_DI0_SEL>, <&clks IMX6QDL_CLK_LDB_DI1_SEL>, + <&clks IMX6QDL_CLK_IPU1_DI0_SEL>, <&clks IMX6QDL_CLK_IPU1_DI1_SEL>, + <&clks IMX6QDL_CLK_LDB_DI0>, <&clks IMX6QDL_CLK_LDB_DI1>; + clock-names = "di0_pll", "di1_pll", + "di0_sel", "di1_sel", + "di0", "di1"; +}; + +&vpu { + compatible = "fsl,imx6dl-vpu", "cnm,coda960"; +}; diff --git a/arch/arm/dts/imx6q-pinfunc.h b/arch/arm/dts/imx6q-pinfunc.h new file mode 100644 index 0000000..9fc6120 --- /dev/null +++ b/arch/arm/dts/imx6q-pinfunc.h @@ -0,0 +1,1047 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * + */ + +#ifndef __DTS_IMX6Q_PINFUNC_H +#define __DTS_IMX6Q_PINFUNC_H + +/* + * The pin function ID is a tuple of + * <mux_reg conf_reg input_reg mux_mode input_val> + */ +#define MX6QDL_PAD_SD2_DAT1__SD2_DATA1 0x04c 0x360 0x000 0x0 0x0 +#define MX6QDL_PAD_SD2_DAT1__ECSPI5_SS0 0x04c 0x360 0x834 0x1 0x0 +#define MX6QDL_PAD_SD2_DAT1__EIM_CS2_B 0x04c 0x360 0x000 0x2 0x0 +#define MX6QDL_PAD_SD2_DAT1__AUD4_TXFS 0x04c 0x360 0x7c8 0x3 0x0 +#define MX6QDL_PAD_SD2_DAT1__KEY_COL7 0x04c 0x360 0x8f0 0x4 0x0 +#define MX6QDL_PAD_SD2_DAT1__GPIO1_IO14 0x04c 0x360 0x000 0x5 0x0 +#define MX6QDL_PAD_SD2_DAT2__SD2_DATA2 0x050 0x364 0x000 0x0 0x0 +#define MX6QDL_PAD_SD2_DAT2__ECSPI5_SS1 0x050 0x364 0x838 0x1 0x0 +#define MX6QDL_PAD_SD2_DAT2__EIM_CS3_B 0x050 0x364 0x000 0x2 0x0 +#define MX6QDL_PAD_SD2_DAT2__AUD4_TXD 0x050 0x364 0x7b8 0x3 0x0 +#define MX6QDL_PAD_SD2_DAT2__KEY_ROW6 0x050 0x364 0x8f8 0x4 0x0 +#define MX6QDL_PAD_SD2_DAT2__GPIO1_IO13 0x050 0x364 0x000 0x5 0x0 +#define MX6QDL_PAD_SD2_DAT0__SD2_DATA0 0x054 0x368 0x000 0x0 0x0 +#define MX6QDL_PAD_SD2_DAT0__ECSPI5_MISO 0x054 0x368 0x82c 0x1 0x0 +#define MX6QDL_PAD_SD2_DAT0__AUD4_RXD 0x054 0x368 0x7b4 0x3 0x0 +#define MX6QDL_PAD_SD2_DAT0__KEY_ROW7 0x054 0x368 0x8fc 0x4 0x0 +#define MX6QDL_PAD_SD2_DAT0__GPIO1_IO15 0x054 0x368 0x000 0x5 0x0 +#define MX6QDL_PAD_SD2_DAT0__DCIC2_OUT 0x054 0x368 0x000 0x6 0x0 +#define MX6QDL_PAD_RGMII_TXC__USB_H2_DATA 0x058 0x36c 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_TXC__RGMII_TXC 0x058 0x36c 0x000 0x1 0x0 +#define MX6QDL_PAD_RGMII_TXC__SPDIF_EXT_CLK 0x058 0x36c 0x918 0x2 0x0 +#define MX6QDL_PAD_RGMII_TXC__GPIO6_IO19 0x058 0x36c 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_TXC__XTALOSC_REF_CLK_24M 0x058 0x36c 0x000 0x7 0x0 +#define MX6QDL_PAD_RGMII_TD0__HSI_TX_READY 0x05c 0x370 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_TD0__RGMII_TD0 0x05c 0x370 0x000 0x1 0x0 +#define MX6QDL_PAD_RGMII_TD0__GPIO6_IO20 0x05c 0x370 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_TD1__HSI_RX_FLAG 0x060 0x374 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_TD1__RGMII_TD1 0x060 0x374 0x000 0x1 0x0 +#define MX6QDL_PAD_RGMII_TD1__GPIO6_IO21 0x060 0x374 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_TD2__HSI_RX_DATA 0x064 0x378 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_TD2__RGMII_TD2 0x064 0x378 0x000 0x1 0x0 +#define MX6QDL_PAD_RGMII_TD2__GPIO6_IO22 0x064 0x378 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_TD3__HSI_RX_WAKE 0x068 0x37c 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_TD3__RGMII_TD3 0x068 0x37c 0x000 0x1 0x0 +#define MX6QDL_PAD_RGMII_TD3__GPIO6_IO23 0x068 0x37c 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_RX_CTL__USB_H3_DATA 0x06c 0x380 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_RX_CTL__RGMII_RX_CTL 0x06c 0x380 0x858 0x1 0x0 +#define MX6QDL_PAD_RGMII_RX_CTL__GPIO6_IO24 0x06c 0x380 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_RD0__HSI_RX_READY 0x070 0x384 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_RD0__RGMII_RD0 0x070 0x384 0x848 0x1 0x0 +#define MX6QDL_PAD_RGMII_RD0__GPIO6_IO25 0x070 0x384 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_TX_CTL__USB_H2_STROBE 0x074 0x388 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_TX_CTL__RGMII_TX_CTL 0x074 0x388 0x000 0x1 0x0 +#define MX6QDL_PAD_RGMII_TX_CTL__GPIO6_IO26 0x074 0x388 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_TX_CTL__ENET_REF_CLK 0x074 0x388 0x83c 0x7 0x0 +#define MX6QDL_PAD_RGMII_RD1__HSI_TX_FLAG 0x078 0x38c 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_RD1__RGMII_RD1 0x078 0x38c 0x84c 0x1 0x0 +#define MX6QDL_PAD_RGMII_RD1__GPIO6_IO27 0x078 0x38c 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_RD2__HSI_TX_DATA 0x07c 0x390 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_RD2__RGMII_RD2 0x07c 0x390 0x850 0x1 0x0 +#define MX6QDL_PAD_RGMII_RD2__GPIO6_IO28 0x07c 0x390 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_RD3__HSI_TX_WAKE 0x080 0x394 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_RD3__RGMII_RD3 0x080 0x394 0x854 0x1 0x0 +#define MX6QDL_PAD_RGMII_RD3__GPIO6_IO29 0x080 0x394 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_RXC__USB_H3_STROBE 0x084 0x398 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_RXC__RGMII_RXC 0x084 0x398 0x844 0x1 0x0 +#define MX6QDL_PAD_RGMII_RXC__GPIO6_IO30 0x084 0x398 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A25__EIM_ADDR25 0x088 0x39c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A25__ECSPI4_SS1 0x088 0x39c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A25__ECSPI2_RDY 0x088 0x39c 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_A25__IPU1_DI1_PIN12 0x088 0x39c 0x000 0x3 0x0 +#define MX6QDL_PAD_EIM_A25__IPU1_DI0_D1_CS 0x088 0x39c 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_A25__GPIO5_IO02 0x088 0x39c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A25__HDMI_TX_CEC_LINE 0x088 0x39c 0x88c 0x6 0x0 +#define MX6QDL_PAD_EIM_EB2__EIM_EB2_B 0x08c 0x3a0 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_EB2__ECSPI1_SS0 0x08c 0x3a0 0x800 0x1 0x0 +#define MX6QDL_PAD_EIM_EB2__IPU2_CSI1_DATA19 0x08c 0x3a0 0x8d4 0x3 0x0 +#define MX6QDL_PAD_EIM_EB2__HDMI_TX_DDC_SCL 0x08c 0x3a0 0x890 0x4 0x0 +#define MX6QDL_PAD_EIM_EB2__GPIO2_IO30 0x08c 0x3a0 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_EB2__I2C2_SCL 0x08c 0x3a0 0x8a0 0x6 0x0 +#define MX6QDL_PAD_EIM_EB2__SRC_BOOT_CFG30 0x08c 0x3a0 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_D16__EIM_DATA16 0x090 0x3a4 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D16__ECSPI1_SCLK 0x090 0x3a4 0x7f4 0x1 0x0 +#define MX6QDL_PAD_EIM_D16__IPU1_DI0_PIN05 0x090 0x3a4 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D16__IPU2_CSI1_DATA18 0x090 0x3a4 0x8d0 0x3 0x0 +#define MX6QDL_PAD_EIM_D16__HDMI_TX_DDC_SDA 0x090 0x3a4 0x894 0x4 0x0 +#define MX6QDL_PAD_EIM_D16__GPIO3_IO16 0x090 0x3a4 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D16__I2C2_SDA 0x090 0x3a4 0x8a4 0x6 0x0 +#define MX6QDL_PAD_EIM_D17__EIM_DATA17 0x094 0x3a8 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D17__ECSPI1_MISO 0x094 0x3a8 0x7f8 0x1 0x0 +#define MX6QDL_PAD_EIM_D17__IPU1_DI0_PIN06 0x094 0x3a8 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D17__IPU2_CSI1_PIXCLK 0x094 0x3a8 0x8e0 0x3 0x0 +#define MX6QDL_PAD_EIM_D17__DCIC1_OUT 0x094 0x3a8 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D17__GPIO3_IO17 0x094 0x3a8 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D17__I2C3_SCL 0x094 0x3a8 0x8a8 0x6 0x0 +#define MX6QDL_PAD_EIM_D18__EIM_DATA18 0x098 0x3ac 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D18__ECSPI1_MOSI 0x098 0x3ac 0x7fc 0x1 0x0 +#define MX6QDL_PAD_EIM_D18__IPU1_DI0_PIN07 0x098 0x3ac 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D18__IPU2_CSI1_DATA17 0x098 0x3ac 0x8cc 0x3 0x0 +#define MX6QDL_PAD_EIM_D18__IPU1_DI1_D0_CS 0x098 0x3ac 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D18__GPIO3_IO18 0x098 0x3ac 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D18__I2C3_SDA 0x098 0x3ac 0x8ac 0x6 0x0 +#define MX6QDL_PAD_EIM_D19__EIM_DATA19 0x09c 0x3b0 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D19__ECSPI1_SS1 0x09c 0x3b0 0x804 0x1 0x0 +#define MX6QDL_PAD_EIM_D19__IPU1_DI0_PIN08 0x09c 0x3b0 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D19__IPU2_CSI1_DATA16 0x09c 0x3b0 0x8c8 0x3 0x0 +#define MX6QDL_PAD_EIM_D19__UART1_CTS_B 0x09c 0x3b0 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D19__UART1_RTS_B 0x09c 0x3b0 0x91c 0x4 0x0 +#define MX6QDL_PAD_EIM_D19__GPIO3_IO19 0x09c 0x3b0 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D19__EPIT1_OUT 0x09c 0x3b0 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_D20__EIM_DATA20 0x0a0 0x3b4 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D20__ECSPI4_SS0 0x0a0 0x3b4 0x824 0x1 0x0 +#define MX6QDL_PAD_EIM_D20__IPU1_DI0_PIN16 0x0a0 0x3b4 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D20__IPU2_CSI1_DATA15 0x0a0 0x3b4 0x8c4 0x3 0x0 +#define MX6QDL_PAD_EIM_D20__UART1_RTS_B 0x0a0 0x3b4 0x91c 0x4 0x1 +#define MX6QDL_PAD_EIM_D20__UART1_CTS_B 0x0a0 0x3b4 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D20__GPIO3_IO20 0x0a0 0x3b4 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D20__EPIT2_OUT 0x0a0 0x3b4 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_D21__EIM_DATA21 0x0a4 0x3b8 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D21__ECSPI4_SCLK 0x0a4 0x3b8 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D21__IPU1_DI0_PIN17 0x0a4 0x3b8 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D21__IPU2_CSI1_DATA11 0x0a4 0x3b8 0x8b4 0x3 0x0 +#define MX6QDL_PAD_EIM_D21__USB_OTG_OC 0x0a4 0x3b8 0x944 0x4 0x0 +#define MX6QDL_PAD_EIM_D21__GPIO3_IO21 0x0a4 0x3b8 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D21__I2C1_SCL 0x0a4 0x3b8 0x898 0x6 0x0 +#define MX6QDL_PAD_EIM_D21__SPDIF_IN 0x0a4 0x3b8 0x914 0x7 0x0 +#define MX6QDL_PAD_EIM_D22__EIM_DATA22 0x0a8 0x3bc 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D22__ECSPI4_MISO 0x0a8 0x3bc 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D22__IPU1_DI0_PIN01 0x0a8 0x3bc 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D22__IPU2_CSI1_DATA10 0x0a8 0x3bc 0x8b0 0x3 0x0 +#define MX6QDL_PAD_EIM_D22__USB_OTG_PWR 0x0a8 0x3bc 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D22__GPIO3_IO22 0x0a8 0x3bc 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D22__SPDIF_OUT 0x0a8 0x3bc 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_D23__EIM_DATA23 0x0ac 0x3c0 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D23__IPU1_DI0_D0_CS 0x0ac 0x3c0 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D23__UART3_CTS_B 0x0ac 0x3c0 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D23__UART3_RTS_B 0x0ac 0x3c0 0x92c 0x2 0x0 +#define MX6QDL_PAD_EIM_D23__UART1_DCD_B 0x0ac 0x3c0 0x000 0x3 0x0 +#define MX6QDL_PAD_EIM_D23__IPU2_CSI1_DATA_EN 0x0ac 0x3c0 0x8d8 0x4 0x0 +#define MX6QDL_PAD_EIM_D23__GPIO3_IO23 0x0ac 0x3c0 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D23__IPU1_DI1_PIN02 0x0ac 0x3c0 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_D23__IPU1_DI1_PIN14 0x0ac 0x3c0 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_EB3__EIM_EB3_B 0x0b0 0x3c4 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_EB3__ECSPI4_RDY 0x0b0 0x3c4 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_EB3__UART3_RTS_B 0x0b0 0x3c4 0x92c 0x2 0x1 +#define MX6QDL_PAD_EIM_EB3__UART3_CTS_B 0x0b0 0x3c4 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_EB3__UART1_RI_B 0x0b0 0x3c4 0x000 0x3 0x0 +#define MX6QDL_PAD_EIM_EB3__IPU2_CSI1_HSYNC 0x0b0 0x3c4 0x8dc 0x4 0x0 +#define MX6QDL_PAD_EIM_EB3__GPIO2_IO31 0x0b0 0x3c4 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_EB3__IPU1_DI1_PIN03 0x0b0 0x3c4 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_EB3__SRC_BOOT_CFG31 0x0b0 0x3c4 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_D24__EIM_DATA24 0x0b4 0x3c8 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D24__ECSPI4_SS2 0x0b4 0x3c8 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D24__UART3_TX_DATA 0x0b4 0x3c8 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D24__UART3_RX_DATA 0x0b4 0x3c8 0x930 0x2 0x0 +#define MX6QDL_PAD_EIM_D24__ECSPI1_SS2 0x0b4 0x3c8 0x808 0x3 0x0 +#define MX6QDL_PAD_EIM_D24__ECSPI2_SS2 0x0b4 0x3c8 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D24__GPIO3_IO24 0x0b4 0x3c8 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D24__AUD5_RXFS 0x0b4 0x3c8 0x7d8 0x6 0x0 +#define MX6QDL_PAD_EIM_D24__UART1_DTR_B 0x0b4 0x3c8 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_D25__EIM_DATA25 0x0b8 0x3cc 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D25__ECSPI4_SS3 0x0b8 0x3cc 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D25__UART3_RX_DATA 0x0b8 0x3cc 0x930 0x2 0x1 +#define MX6QDL_PAD_EIM_D25__UART3_TX_DATA 0x0b8 0x3cc 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D25__ECSPI1_SS3 0x0b8 0x3cc 0x80c 0x3 0x0 +#define MX6QDL_PAD_EIM_D25__ECSPI2_SS3 0x0b8 0x3cc 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D25__GPIO3_IO25 0x0b8 0x3cc 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D25__AUD5_RXC 0x0b8 0x3cc 0x7d4 0x6 0x0 +#define MX6QDL_PAD_EIM_D25__UART1_DSR_B 0x0b8 0x3cc 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_D26__EIM_DATA26 0x0bc 0x3d0 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D26__IPU1_DI1_PIN11 0x0bc 0x3d0 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D26__IPU1_CSI0_DATA01 0x0bc 0x3d0 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D26__IPU2_CSI1_DATA14 0x0bc 0x3d0 0x8c0 0x3 0x0 +#define MX6QDL_PAD_EIM_D26__UART2_TX_DATA 0x0bc 0x3d0 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D26__UART2_RX_DATA 0x0bc 0x3d0 0x928 0x4 0x0 +#define MX6QDL_PAD_EIM_D26__GPIO3_IO26 0x0bc 0x3d0 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D26__IPU1_SISG2 0x0bc 0x3d0 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_D26__IPU1_DISP1_DATA22 0x0bc 0x3d0 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_D27__EIM_DATA27 0x0c0 0x3d4 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D27__IPU1_DI1_PIN13 0x0c0 0x3d4 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D27__IPU1_CSI0_DATA00 0x0c0 0x3d4 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D27__IPU2_CSI1_DATA13 0x0c0 0x3d4 0x8bc 0x3 0x0 +#define MX6QDL_PAD_EIM_D27__UART2_RX_DATA 0x0c0 0x3d4 0x928 0x4 0x1 +#define MX6QDL_PAD_EIM_D27__UART2_TX_DATA 0x0c0 0x3d4 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D27__GPIO3_IO27 0x0c0 0x3d4 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D27__IPU1_SISG3 0x0c0 0x3d4 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_D27__IPU1_DISP1_DATA23 0x0c0 0x3d4 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_D28__EIM_DATA28 0x0c4 0x3d8 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D28__I2C1_SDA 0x0c4 0x3d8 0x89c 0x1 0x0 +#define MX6QDL_PAD_EIM_D28__ECSPI4_MOSI 0x0c4 0x3d8 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D28__IPU2_CSI1_DATA12 0x0c4 0x3d8 0x8b8 0x3 0x0 +#define MX6QDL_PAD_EIM_D28__UART2_CTS_B 0x0c4 0x3d8 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D28__UART2_RTS_B 0x0c4 0x3d8 0x924 0x4 0x0 +#define MX6QDL_PAD_EIM_D28__UART2_DTE_CTS_B 0x0c4 0x3d8 0x924 0x4 0x0 +#define MX6QDL_PAD_EIM_D28__UART2_DTE_RTS_B 0x0c4 0x3d8 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D28__GPIO3_IO28 0x0c4 0x3d8 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D28__IPU1_EXT_TRIG 0x0c4 0x3d8 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_D28__IPU1_DI0_PIN13 0x0c4 0x3d8 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_D29__EIM_DATA29 0x0c8 0x3dc 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D29__IPU1_DI1_PIN15 0x0c8 0x3dc 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D29__ECSPI4_SS0 0x0c8 0x3dc 0x824 0x2 0x1 +#define MX6QDL_PAD_EIM_D29__UART2_RTS_B 0x0c8 0x3dc 0x924 0x4 0x1 +#define MX6QDL_PAD_EIM_D29__UART2_CTS_B 0x0c8 0x3dc 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D29__UART2_DTE_RTS_B 0x0c8 0x3dc 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D29__UART2_DTE_CTS_B 0x0c8 0x3dc 0x924 0x4 0x1 +#define MX6QDL_PAD_EIM_D29__GPIO3_IO29 0x0c8 0x3dc 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D29__IPU2_CSI1_VSYNC 0x0c8 0x3dc 0x8e4 0x6 0x0 +#define MX6QDL_PAD_EIM_D29__IPU1_DI0_PIN14 0x0c8 0x3dc 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_D30__EIM_DATA30 0x0cc 0x3e0 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D30__IPU1_DISP1_DATA21 0x0cc 0x3e0 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D30__IPU1_DI0_PIN11 0x0cc 0x3e0 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D30__IPU1_CSI0_DATA03 0x0cc 0x3e0 0x000 0x3 0x0 +#define MX6QDL_PAD_EIM_D30__UART3_CTS_B 0x0cc 0x3e0 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D30__UART3_RTS_B 0x0cc 0x3e0 0x92c 0x4 0x2 +#define MX6QDL_PAD_EIM_D30__GPIO3_IO30 0x0cc 0x3e0 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D30__USB_H1_OC 0x0cc 0x3e0 0x948 0x6 0x0 +#define MX6QDL_PAD_EIM_D31__EIM_DATA31 0x0d0 0x3e4 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D31__IPU1_DISP1_DATA20 0x0d0 0x3e4 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D31__IPU1_DI0_PIN12 0x0d0 0x3e4 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D31__IPU1_CSI0_DATA02 0x0d0 0x3e4 0x000 0x3 0x0 +#define MX6QDL_PAD_EIM_D31__UART3_RTS_B 0x0d0 0x3e4 0x92c 0x4 0x3 +#define MX6QDL_PAD_EIM_D31__UART3_CTS_B 0x0d0 0x3e4 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D31__GPIO3_IO31 0x0d0 0x3e4 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D31__USB_H1_PWR 0x0d0 0x3e4 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_A24__EIM_ADDR24 0x0d4 0x3e8 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A24__IPU1_DISP1_DATA19 0x0d4 0x3e8 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A24__IPU2_CSI1_DATA19 0x0d4 0x3e8 0x8d4 0x2 0x1 +#define MX6QDL_PAD_EIM_A24__IPU2_SISG2 0x0d4 0x3e8 0x000 0x3 0x0 +#define MX6QDL_PAD_EIM_A24__IPU1_SISG2 0x0d4 0x3e8 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_A24__GPIO5_IO04 0x0d4 0x3e8 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A24__SRC_BOOT_CFG24 0x0d4 0x3e8 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A23__EIM_ADDR23 0x0d8 0x3ec 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A23__IPU1_DISP1_DATA18 0x0d8 0x3ec 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A23__IPU2_CSI1_DATA18 0x0d8 0x3ec 0x8d0 0x2 0x1 +#define MX6QDL_PAD_EIM_A23__IPU2_SISG3 0x0d8 0x3ec 0x000 0x3 0x0 +#define MX6QDL_PAD_EIM_A23__IPU1_SISG3 0x0d8 0x3ec 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_A23__GPIO6_IO06 0x0d8 0x3ec 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A23__SRC_BOOT_CFG23 0x0d8 0x3ec 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A22__EIM_ADDR22 0x0dc 0x3f0 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A22__IPU1_DISP1_DATA17 0x0dc 0x3f0 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A22__IPU2_CSI1_DATA17 0x0dc 0x3f0 0x8cc 0x2 0x1 +#define MX6QDL_PAD_EIM_A22__GPIO2_IO16 0x0dc 0x3f0 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A22__SRC_BOOT_CFG22 0x0dc 0x3f0 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A21__EIM_ADDR21 0x0e0 0x3f4 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A21__IPU1_DISP1_DATA16 0x0e0 0x3f4 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A21__IPU2_CSI1_DATA16 0x0e0 0x3f4 0x8c8 0x2 0x1 +#define MX6QDL_PAD_EIM_A21__GPIO2_IO17 0x0e0 0x3f4 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A21__SRC_BOOT_CFG21 0x0e0 0x3f4 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A20__EIM_ADDR20 0x0e4 0x3f8 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A20__IPU1_DISP1_DATA15 0x0e4 0x3f8 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A20__IPU2_CSI1_DATA15 0x0e4 0x3f8 0x8c4 0x2 0x1 +#define MX6QDL_PAD_EIM_A20__GPIO2_IO18 0x0e4 0x3f8 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A20__SRC_BOOT_CFG20 0x0e4 0x3f8 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A19__EIM_ADDR19 0x0e8 0x3fc 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A19__IPU1_DISP1_DATA14 0x0e8 0x3fc 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A19__IPU2_CSI1_DATA14 0x0e8 0x3fc 0x8c0 0x2 0x1 +#define MX6QDL_PAD_EIM_A19__GPIO2_IO19 0x0e8 0x3fc 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A19__SRC_BOOT_CFG19 0x0e8 0x3fc 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A18__EIM_ADDR18 0x0ec 0x400 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A18__IPU1_DISP1_DATA13 0x0ec 0x400 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A18__IPU2_CSI1_DATA13 0x0ec 0x400 0x8bc 0x2 0x1 +#define MX6QDL_PAD_EIM_A18__GPIO2_IO20 0x0ec 0x400 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A18__SRC_BOOT_CFG18 0x0ec 0x400 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A17__EIM_ADDR17 0x0f0 0x404 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A17__IPU1_DISP1_DATA12 0x0f0 0x404 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A17__IPU2_CSI1_DATA12 0x0f0 0x404 0x8b8 0x2 0x1 +#define MX6QDL_PAD_EIM_A17__GPIO2_IO21 0x0f0 0x404 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A17__SRC_BOOT_CFG17 0x0f0 0x404 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A16__EIM_ADDR16 0x0f4 0x408 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A16__IPU1_DI1_DISP_CLK 0x0f4 0x408 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A16__IPU2_CSI1_PIXCLK 0x0f4 0x408 0x8e0 0x2 0x1 +#define MX6QDL_PAD_EIM_A16__GPIO2_IO22 0x0f4 0x408 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A16__SRC_BOOT_CFG16 0x0f4 0x408 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_CS0__EIM_CS0_B 0x0f8 0x40c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_CS0__IPU1_DI1_PIN05 0x0f8 0x40c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_CS0__ECSPI2_SCLK 0x0f8 0x40c 0x810 0x2 0x0 +#define MX6QDL_PAD_EIM_CS0__GPIO2_IO23 0x0f8 0x40c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_CS1__EIM_CS1_B 0x0fc 0x410 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_CS1__IPU1_DI1_PIN06 0x0fc 0x410 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_CS1__ECSPI2_MOSI 0x0fc 0x410 0x818 0x2 0x0 +#define MX6QDL_PAD_EIM_CS1__GPIO2_IO24 0x0fc 0x410 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_OE__EIM_OE_B 0x100 0x414 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_OE__IPU1_DI1_PIN07 0x100 0x414 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_OE__ECSPI2_MISO 0x100 0x414 0x814 0x2 0x0 +#define MX6QDL_PAD_EIM_OE__GPIO2_IO25 0x100 0x414 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_RW__EIM_RW 0x104 0x418 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_RW__IPU1_DI1_PIN08 0x104 0x418 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_RW__ECSPI2_SS0 0x104 0x418 0x81c 0x2 0x0 +#define MX6QDL_PAD_EIM_RW__GPIO2_IO26 0x104 0x418 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_RW__SRC_BOOT_CFG29 0x104 0x418 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_LBA__EIM_LBA_B 0x108 0x41c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_LBA__IPU1_DI1_PIN17 0x108 0x41c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_LBA__ECSPI2_SS1 0x108 0x41c 0x820 0x2 0x0 +#define MX6QDL_PAD_EIM_LBA__GPIO2_IO27 0x108 0x41c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_LBA__SRC_BOOT_CFG26 0x108 0x41c 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_EB0__EIM_EB0_B 0x10c 0x420 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_EB0__IPU1_DISP1_DATA11 0x10c 0x420 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_EB0__IPU2_CSI1_DATA11 0x10c 0x420 0x8b4 0x2 0x1 +#define MX6QDL_PAD_EIM_EB0__CCM_PMIC_READY 0x10c 0x420 0x7f0 0x4 0x0 +#define MX6QDL_PAD_EIM_EB0__GPIO2_IO28 0x10c 0x420 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_EB0__SRC_BOOT_CFG27 0x10c 0x420 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_EB1__EIM_EB1_B 0x110 0x424 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_EB1__IPU1_DISP1_DATA10 0x110 0x424 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_EB1__IPU2_CSI1_DATA10 0x110 0x424 0x8b0 0x2 0x1 +#define MX6QDL_PAD_EIM_EB1__GPIO2_IO29 0x110 0x424 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_EB1__SRC_BOOT_CFG28 0x110 0x424 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA0__EIM_AD00 0x114 0x428 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA0__IPU1_DISP1_DATA09 0x114 0x428 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA0__IPU2_CSI1_DATA09 0x114 0x428 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA0__GPIO3_IO00 0x114 0x428 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA0__SRC_BOOT_CFG00 0x114 0x428 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA1__EIM_AD01 0x118 0x42c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA1__IPU1_DISP1_DATA08 0x118 0x42c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA1__IPU2_CSI1_DATA08 0x118 0x42c 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA1__GPIO3_IO01 0x118 0x42c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA1__SRC_BOOT_CFG01 0x118 0x42c 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA2__EIM_AD02 0x11c 0x430 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA2__IPU1_DISP1_DATA07 0x11c 0x430 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA2__IPU2_CSI1_DATA07 0x11c 0x430 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA2__GPIO3_IO02 0x11c 0x430 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA2__SRC_BOOT_CFG02 0x11c 0x430 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA3__EIM_AD03 0x120 0x434 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA3__IPU1_DISP1_DATA06 0x120 0x434 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA3__IPU2_CSI1_DATA06 0x120 0x434 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA3__GPIO3_IO03 0x120 0x434 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA3__SRC_BOOT_CFG03 0x120 0x434 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA4__EIM_AD04 0x124 0x438 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA4__IPU1_DISP1_DATA05 0x124 0x438 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA4__IPU2_CSI1_DATA05 0x124 0x438 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA4__GPIO3_IO04 0x124 0x438 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA4__SRC_BOOT_CFG04 0x124 0x438 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA5__EIM_AD05 0x128 0x43c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA5__IPU1_DISP1_DATA04 0x128 0x43c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA5__IPU2_CSI1_DATA04 0x128 0x43c 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA5__GPIO3_IO05 0x128 0x43c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA5__SRC_BOOT_CFG05 0x128 0x43c 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA6__EIM_AD06 0x12c 0x440 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA6__IPU1_DISP1_DATA03 0x12c 0x440 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA6__IPU2_CSI1_DATA03 0x12c 0x440 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA6__GPIO3_IO06 0x12c 0x440 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA6__SRC_BOOT_CFG06 0x12c 0x440 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA7__EIM_AD07 0x130 0x444 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA7__IPU1_DISP1_DATA02 0x130 0x444 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA7__IPU2_CSI1_DATA02 0x130 0x444 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA7__GPIO3_IO07 0x130 0x444 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA7__SRC_BOOT_CFG07 0x130 0x444 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA8__EIM_AD08 0x134 0x448 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA8__IPU1_DISP1_DATA01 0x134 0x448 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA8__IPU2_CSI1_DATA01 0x134 0x448 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA8__GPIO3_IO08 0x134 0x448 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA8__SRC_BOOT_CFG08 0x134 0x448 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA9__EIM_AD09 0x138 0x44c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA9__IPU1_DISP1_DATA00 0x138 0x44c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA9__IPU2_CSI1_DATA00 0x138 0x44c 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA9__GPIO3_IO09 0x138 0x44c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA9__SRC_BOOT_CFG09 0x138 0x44c 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA10__EIM_AD10 0x13c 0x450 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA10__IPU1_DI1_PIN15 0x13c 0x450 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA10__IPU2_CSI1_DATA_EN 0x13c 0x450 0x8d8 0x2 0x1 +#define MX6QDL_PAD_EIM_DA10__GPIO3_IO10 0x13c 0x450 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA10__SRC_BOOT_CFG10 0x13c 0x450 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA11__EIM_AD11 0x140 0x454 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA11__IPU1_DI1_PIN02 0x140 0x454 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA11__IPU2_CSI1_HSYNC 0x140 0x454 0x8dc 0x2 0x1 +#define MX6QDL_PAD_EIM_DA11__GPIO3_IO11 0x140 0x454 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA11__SRC_BOOT_CFG11 0x140 0x454 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA12__EIM_AD12 0x144 0x458 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA12__IPU1_DI1_PIN03 0x144 0x458 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA12__IPU2_CSI1_VSYNC 0x144 0x458 0x8e4 0x2 0x1 +#define MX6QDL_PAD_EIM_DA12__GPIO3_IO12 0x144 0x458 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA12__SRC_BOOT_CFG12 0x144 0x458 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA13__EIM_AD13 0x148 0x45c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA13__IPU1_DI1_D0_CS 0x148 0x45c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA13__GPIO3_IO13 0x148 0x45c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA13__SRC_BOOT_CFG13 0x148 0x45c 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA14__EIM_AD14 0x14c 0x460 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA14__IPU1_DI1_D1_CS 0x14c 0x460 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA14__GPIO3_IO14 0x14c 0x460 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA14__SRC_BOOT_CFG14 0x14c 0x460 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA15__EIM_AD15 0x150 0x464 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA15__IPU1_DI1_PIN01 0x150 0x464 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA15__IPU1_DI1_PIN04 0x150 0x464 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA15__GPIO3_IO15 0x150 0x464 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA15__SRC_BOOT_CFG15 0x150 0x464 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_WAIT__EIM_WAIT_B 0x154 0x468 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_WAIT__EIM_DTACK_B 0x154 0x468 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_WAIT__GPIO5_IO00 0x154 0x468 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_WAIT__SRC_BOOT_CFG25 0x154 0x468 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_BCLK__EIM_BCLK 0x158 0x46c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_BCLK__IPU1_DI1_PIN16 0x158 0x46c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_BCLK__GPIO6_IO31 0x158 0x46c 0x000 0x5 0x0 +#define MX6QDL_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK 0x15c 0x470 0x000 0x0 0x0 +#define MX6QDL_PAD_DI0_DISP_CLK__IPU2_DI0_DISP_CLK 0x15c 0x470 0x000 0x1 0x0 +#define MX6QDL_PAD_DI0_DISP_CLK__GPIO4_IO16 0x15c 0x470 0x000 0x5 0x0 +#define MX6QDL_PAD_DI0_PIN15__IPU1_DI0_PIN15 0x160 0x474 0x000 0x0 0x0 +#define MX6QDL_PAD_DI0_PIN15__IPU2_DI0_PIN15 0x160 0x474 0x000 0x1 0x0 +#define MX6QDL_PAD_DI0_PIN15__AUD6_TXC 0x160 0x474 0x000 0x2 0x0 +#define MX6QDL_PAD_DI0_PIN15__GPIO4_IO17 0x160 0x474 0x000 0x5 0x0 +#define MX6QDL_PAD_DI0_PIN2__IPU1_DI0_PIN02 0x164 0x478 0x000 0x0 0x0 +#define MX6QDL_PAD_DI0_PIN2__IPU2_DI0_PIN02 0x164 0x478 0x000 0x1 0x0 +#define MX6QDL_PAD_DI0_PIN2__AUD6_TXD 0x164 0x478 0x000 0x2 0x0 +#define MX6QDL_PAD_DI0_PIN2__GPIO4_IO18 0x164 0x478 0x000 0x5 0x0 +#define MX6QDL_PAD_DI0_PIN3__IPU1_DI0_PIN03 0x168 0x47c 0x000 0x0 0x0 +#define MX6QDL_PAD_DI0_PIN3__IPU2_DI0_PIN03 0x168 0x47c 0x000 0x1 0x0 +#define MX6QDL_PAD_DI0_PIN3__AUD6_TXFS 0x168 0x47c 0x000 0x2 0x0 +#define MX6QDL_PAD_DI0_PIN3__GPIO4_IO19 0x168 0x47c 0x000 0x5 0x0 +#define MX6QDL_PAD_DI0_PIN4__IPU1_DI0_PIN04 0x16c 0x480 0x000 0x0 0x0 +#define MX6QDL_PAD_DI0_PIN4__IPU2_DI0_PIN04 0x16c 0x480 0x000 0x1 0x0 +#define MX6QDL_PAD_DI0_PIN4__AUD6_RXD 0x16c 0x480 0x000 0x2 0x0 +#define MX6QDL_PAD_DI0_PIN4__SD1_WP 0x16c 0x480 0x94c 0x3 0x0 +#define MX6QDL_PAD_DI0_PIN4__GPIO4_IO20 0x16c 0x480 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT0__IPU1_DISP0_DATA00 0x170 0x484 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT0__IPU2_DISP0_DATA00 0x170 0x484 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT0__ECSPI3_SCLK 0x170 0x484 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT0__GPIO4_IO21 0x170 0x484 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT1__IPU1_DISP0_DATA01 0x174 0x488 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT1__IPU2_DISP0_DATA01 0x174 0x488 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT1__ECSPI3_MOSI 0x174 0x488 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT1__GPIO4_IO22 0x174 0x488 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT2__IPU1_DISP0_DATA02 0x178 0x48c 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT2__IPU2_DISP0_DATA02 0x178 0x48c 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT2__ECSPI3_MISO 0x178 0x48c 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT2__GPIO4_IO23 0x178 0x48c 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT3__IPU1_DISP0_DATA03 0x17c 0x490 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT3__IPU2_DISP0_DATA03 0x17c 0x490 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT3__ECSPI3_SS0 0x17c 0x490 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT3__GPIO4_IO24 0x17c 0x490 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT4__IPU1_DISP0_DATA04 0x180 0x494 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT4__IPU2_DISP0_DATA04 0x180 0x494 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT4__ECSPI3_SS1 0x180 0x494 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT4__GPIO4_IO25 0x180 0x494 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT5__IPU1_DISP0_DATA05 0x184 0x498 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT5__IPU2_DISP0_DATA05 0x184 0x498 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT5__ECSPI3_SS2 0x184 0x498 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT5__AUD6_RXFS 0x184 0x498 0x000 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT5__GPIO4_IO26 0x184 0x498 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT6__IPU1_DISP0_DATA06 0x188 0x49c 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT6__IPU2_DISP0_DATA06 0x188 0x49c 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT6__ECSPI3_SS3 0x188 0x49c 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT6__AUD6_RXC 0x188 0x49c 0x000 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT6__GPIO4_IO27 0x188 0x49c 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT7__IPU1_DISP0_DATA07 0x18c 0x4a0 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT7__IPU2_DISP0_DATA07 0x18c 0x4a0 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT7__ECSPI3_RDY 0x18c 0x4a0 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT7__GPIO4_IO28 0x18c 0x4a0 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT8__IPU1_DISP0_DATA08 0x190 0x4a4 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT8__IPU2_DISP0_DATA08 0x190 0x4a4 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT8__PWM1_OUT 0x190 0x4a4 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT8__WDOG1_B 0x190 0x4a4 0x000 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT8__GPIO4_IO29 0x190 0x4a4 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT9__IPU1_DISP0_DATA09 0x194 0x4a8 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT9__IPU2_DISP0_DATA09 0x194 0x4a8 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT9__PWM2_OUT 0x194 0x4a8 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT9__WDOG2_B 0x194 0x4a8 0x000 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT9__GPIO4_IO30 0x194 0x4a8 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT10__IPU1_DISP0_DATA10 0x198 0x4ac 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT10__IPU2_DISP0_DATA10 0x198 0x4ac 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT10__GPIO4_IO31 0x198 0x4ac 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT11__IPU1_DISP0_DATA11 0x19c 0x4b0 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT11__IPU2_DISP0_DATA11 0x19c 0x4b0 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT11__GPIO5_IO05 0x19c 0x4b0 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT12__IPU1_DISP0_DATA12 0x1a0 0x4b4 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT12__IPU2_DISP0_DATA12 0x1a0 0x4b4 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT12__GPIO5_IO06 0x1a0 0x4b4 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT13__IPU1_DISP0_DATA13 0x1a4 0x4b8 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT13__IPU2_DISP0_DATA13 0x1a4 0x4b8 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT13__AUD5_RXFS 0x1a4 0x4b8 0x7d8 0x3 0x1 +#define MX6QDL_PAD_DISP0_DAT13__GPIO5_IO07 0x1a4 0x4b8 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT14__IPU1_DISP0_DATA14 0x1a8 0x4bc 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT14__IPU2_DISP0_DATA14 0x1a8 0x4bc 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT14__AUD5_RXC 0x1a8 0x4bc 0x7d4 0x3 0x1 +#define MX6QDL_PAD_DISP0_DAT14__GPIO5_IO08 0x1a8 0x4bc 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT15__IPU1_DISP0_DATA15 0x1ac 0x4c0 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT15__IPU2_DISP0_DATA15 0x1ac 0x4c0 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT15__ECSPI1_SS1 0x1ac 0x4c0 0x804 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT15__ECSPI2_SS1 0x1ac 0x4c0 0x820 0x3 0x1 +#define MX6QDL_PAD_DISP0_DAT15__GPIO5_IO09 0x1ac 0x4c0 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT16__IPU1_DISP0_DATA16 0x1b0 0x4c4 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT16__IPU2_DISP0_DATA16 0x1b0 0x4c4 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT16__ECSPI2_MOSI 0x1b0 0x4c4 0x818 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT16__AUD5_TXC 0x1b0 0x4c4 0x7dc 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT16__SDMA_EXT_EVENT0 0x1b0 0x4c4 0x90c 0x4 0x0 +#define MX6QDL_PAD_DISP0_DAT16__GPIO5_IO10 0x1b0 0x4c4 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT17__IPU1_DISP0_DATA17 0x1b4 0x4c8 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT17__IPU2_DISP0_DATA17 0x1b4 0x4c8 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT17__ECSPI2_MISO 0x1b4 0x4c8 0x814 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT17__AUD5_TXD 0x1b4 0x4c8 0x7d0 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT17__SDMA_EXT_EVENT1 0x1b4 0x4c8 0x910 0x4 0x0 +#define MX6QDL_PAD_DISP0_DAT17__GPIO5_IO11 0x1b4 0x4c8 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT18__IPU1_DISP0_DATA18 0x1b8 0x4cc 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT18__IPU2_DISP0_DATA18 0x1b8 0x4cc 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT18__ECSPI2_SS0 0x1b8 0x4cc 0x81c 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT18__AUD5_TXFS 0x1b8 0x4cc 0x7e0 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT18__AUD4_RXFS 0x1b8 0x4cc 0x7c0 0x4 0x0 +#define MX6QDL_PAD_DISP0_DAT18__GPIO5_IO12 0x1b8 0x4cc 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT18__EIM_CS2_B 0x1b8 0x4cc 0x000 0x7 0x0 +#define MX6QDL_PAD_DISP0_DAT19__IPU1_DISP0_DATA19 0x1bc 0x4d0 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT19__IPU2_DISP0_DATA19 0x1bc 0x4d0 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT19__ECSPI2_SCLK 0x1bc 0x4d0 0x810 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT19__AUD5_RXD 0x1bc 0x4d0 0x7cc 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT19__AUD4_RXC 0x1bc 0x4d0 0x7bc 0x4 0x0 +#define MX6QDL_PAD_DISP0_DAT19__GPIO5_IO13 0x1bc 0x4d0 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT19__EIM_CS3_B 0x1bc 0x4d0 0x000 0x7 0x0 +#define MX6QDL_PAD_DISP0_DAT20__IPU1_DISP0_DATA20 0x1c0 0x4d4 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT20__IPU2_DISP0_DATA20 0x1c0 0x4d4 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT20__ECSPI1_SCLK 0x1c0 0x4d4 0x7f4 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT20__AUD4_TXC 0x1c0 0x4d4 0x7c4 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT20__GPIO5_IO14 0x1c0 0x4d4 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT21__IPU1_DISP0_DATA21 0x1c4 0x4d8 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT21__IPU2_DISP0_DATA21 0x1c4 0x4d8 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT21__ECSPI1_MOSI 0x1c4 0x4d8 0x7fc 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT21__AUD4_TXD 0x1c4 0x4d8 0x7b8 0x3 0x1 +#define MX6QDL_PAD_DISP0_DAT21__GPIO5_IO15 0x1c4 0x4d8 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT22__IPU1_DISP0_DATA22 0x1c8 0x4dc 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT22__IPU2_DISP0_DATA22 0x1c8 0x4dc 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT22__ECSPI1_MISO 0x1c8 0x4dc 0x7f8 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT22__AUD4_TXFS 0x1c8 0x4dc 0x7c8 0x3 0x1 +#define MX6QDL_PAD_DISP0_DAT22__GPIO5_IO16 0x1c8 0x4dc 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT23__IPU1_DISP0_DATA23 0x1cc 0x4e0 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT23__IPU2_DISP0_DATA23 0x1cc 0x4e0 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT23__ECSPI1_SS0 0x1cc 0x4e0 0x800 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT23__AUD4_RXD 0x1cc 0x4e0 0x7b4 0x3 0x1 +#define MX6QDL_PAD_DISP0_DAT23__GPIO5_IO17 0x1cc 0x4e0 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_MDIO__ENET_MDIO 0x1d0 0x4e4 0x840 0x1 0x0 +#define MX6QDL_PAD_ENET_MDIO__ESAI_RX_CLK 0x1d0 0x4e4 0x86c 0x2 0x0 +#define MX6QDL_PAD_ENET_MDIO__ENET_1588_EVENT1_OUT 0x1d0 0x4e4 0x000 0x4 0x0 +#define MX6QDL_PAD_ENET_MDIO__GPIO1_IO22 0x1d0 0x4e4 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_MDIO__SPDIF_LOCK 0x1d0 0x4e4 0x000 0x6 0x0 +#define MX6QDL_PAD_ENET_REF_CLK__ENET_TX_CLK 0x1d4 0x4e8 0x000 0x1 0x0 +#define MX6QDL_PAD_ENET_REF_CLK__ESAI_RX_FS 0x1d4 0x4e8 0x85c 0x2 0x0 +#define MX6QDL_PAD_ENET_REF_CLK__GPIO1_IO23 0x1d4 0x4e8 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_REF_CLK__SPDIF_SR_CLK 0x1d4 0x4e8 0x000 0x6 0x0 +#define MX6QDL_PAD_ENET_RX_ER__USB_OTG_ID 0x1d8 0x4ec 0x004 0x0 0xff0d0100 +#define MX6QDL_PAD_ENET_RX_ER__ENET_RX_ER 0x1d8 0x4ec 0x000 0x1 0x0 +#define MX6QDL_PAD_ENET_RX_ER__ESAI_RX_HF_CLK 0x1d8 0x4ec 0x864 0x2 0x0 +#define MX6QDL_PAD_ENET_RX_ER__SPDIF_IN 0x1d8 0x4ec 0x914 0x3 0x1 +#define MX6QDL_PAD_ENET_RX_ER__ENET_1588_EVENT2_OUT 0x1d8 0x4ec 0x000 0x4 0x0 +#define MX6QDL_PAD_ENET_RX_ER__GPIO1_IO24 0x1d8 0x4ec 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_CRS_DV__ENET_RX_EN 0x1dc 0x4f0 0x858 0x1 0x1 +#define MX6QDL_PAD_ENET_CRS_DV__ESAI_TX_CLK 0x1dc 0x4f0 0x870 0x2 0x0 +#define MX6QDL_PAD_ENET_CRS_DV__SPDIF_EXT_CLK 0x1dc 0x4f0 0x918 0x3 0x1 +#define MX6QDL_PAD_ENET_CRS_DV__GPIO1_IO25 0x1dc 0x4f0 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_RXD1__MLB_SIG 0x1e0 0x4f4 0x908 0x0 0x0 +#define MX6QDL_PAD_ENET_RXD1__ENET_RX_DATA1 0x1e0 0x4f4 0x84c 0x1 0x1 +#define MX6QDL_PAD_ENET_RXD1__ESAI_TX_FS 0x1e0 0x4f4 0x860 0x2 0x0 +#define MX6QDL_PAD_ENET_RXD1__ENET_1588_EVENT3_OUT 0x1e0 0x4f4 0x000 0x4 0x0 +#define MX6QDL_PAD_ENET_RXD1__GPIO1_IO26 0x1e0 0x4f4 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_RXD0__ENET_RX_DATA0 0x1e4 0x4f8 0x848 0x1 0x1 +#define MX6QDL_PAD_ENET_RXD0__ESAI_TX_HF_CLK 0x1e4 0x4f8 0x868 0x2 0x0 +#define MX6QDL_PAD_ENET_RXD0__SPDIF_OUT 0x1e4 0x4f8 0x000 0x3 0x0 +#define MX6QDL_PAD_ENET_RXD0__GPIO1_IO27 0x1e4 0x4f8 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_TX_EN__ENET_TX_EN 0x1e8 0x4fc 0x000 0x1 0x0 +#define MX6QDL_PAD_ENET_TX_EN__ESAI_TX3_RX2 0x1e8 0x4fc 0x880 0x2 0x0 +#define MX6QDL_PAD_ENET_TX_EN__GPIO1_IO28 0x1e8 0x4fc 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_TXD1__MLB_CLK 0x1ec 0x500 0x900 0x0 0x0 +#define MX6QDL_PAD_ENET_TXD1__ENET_TX_DATA1 0x1ec 0x500 0x000 0x1 0x0 +#define MX6QDL_PAD_ENET_TXD1__ESAI_TX2_RX3 0x1ec 0x500 0x87c 0x2 0x0 +#define MX6QDL_PAD_ENET_TXD1__ENET_1588_EVENT0_IN 0x1ec 0x500 0x000 0x4 0x0 +#define MX6QDL_PAD_ENET_TXD1__GPIO1_IO29 0x1ec 0x500 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_TXD0__ENET_TX_DATA0 0x1f0 0x504 0x000 0x1 0x0 +#define MX6QDL_PAD_ENET_TXD0__ESAI_TX4_RX1 0x1f0 0x504 0x884 0x2 0x0 +#define MX6QDL_PAD_ENET_TXD0__GPIO1_IO30 0x1f0 0x504 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_MDC__MLB_DATA 0x1f4 0x508 0x904 0x0 0x0 +#define MX6QDL_PAD_ENET_MDC__ENET_MDC 0x1f4 0x508 0x000 0x1 0x0 +#define MX6QDL_PAD_ENET_MDC__ESAI_TX5_RX0 0x1f4 0x508 0x888 0x2 0x0 +#define MX6QDL_PAD_ENET_MDC__ENET_1588_EVENT1_IN 0x1f4 0x508 0x000 0x4 0x0 +#define MX6QDL_PAD_ENET_MDC__GPIO1_IO31 0x1f4 0x508 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_COL0__ECSPI1_SCLK 0x1f8 0x5c8 0x7f4 0x0 0x2 +#define MX6QDL_PAD_KEY_COL0__ENET_RX_DATA3 0x1f8 0x5c8 0x854 0x1 0x1 +#define MX6QDL_PAD_KEY_COL0__AUD5_TXC 0x1f8 0x5c8 0x7dc 0x2 0x1 +#define MX6QDL_PAD_KEY_COL0__KEY_COL0 0x1f8 0x5c8 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_COL0__UART4_TX_DATA 0x1f8 0x5c8 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_COL0__UART4_RX_DATA 0x1f8 0x5c8 0x938 0x4 0x0 +#define MX6QDL_PAD_KEY_COL0__GPIO4_IO06 0x1f8 0x5c8 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_COL0__DCIC1_OUT 0x1f8 0x5c8 0x000 0x6 0x0 +#define MX6QDL_PAD_KEY_ROW0__ECSPI1_MOSI 0x1fc 0x5cc 0x7fc 0x0 0x2 +#define MX6QDL_PAD_KEY_ROW0__ENET_TX_DATA3 0x1fc 0x5cc 0x000 0x1 0x0 +#define MX6QDL_PAD_KEY_ROW0__AUD5_TXD 0x1fc 0x5cc 0x7d0 0x2 0x1 +#define MX6QDL_PAD_KEY_ROW0__KEY_ROW0 0x1fc 0x5cc 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_ROW0__UART4_RX_DATA 0x1fc 0x5cc 0x938 0x4 0x1 +#define MX6QDL_PAD_KEY_ROW0__UART4_TX_DATA 0x1fc 0x5cc 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_ROW0__GPIO4_IO07 0x1fc 0x5cc 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_ROW0__DCIC2_OUT 0x1fc 0x5cc 0x000 0x6 0x0 +#define MX6QDL_PAD_KEY_COL1__ECSPI1_MISO 0x200 0x5d0 0x7f8 0x0 0x2 +#define MX6QDL_PAD_KEY_COL1__ENET_MDIO 0x200 0x5d0 0x840 0x1 0x1 +#define MX6QDL_PAD_KEY_COL1__AUD5_TXFS 0x200 0x5d0 0x7e0 0x2 0x1 +#define MX6QDL_PAD_KEY_COL1__KEY_COL1 0x200 0x5d0 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_COL1__UART5_TX_DATA 0x200 0x5d0 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_COL1__UART5_RX_DATA 0x200 0x5d0 0x940 0x4 0x0 +#define MX6QDL_PAD_KEY_COL1__GPIO4_IO08 0x200 0x5d0 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_COL1__SD1_VSELECT 0x200 0x5d0 0x000 0x6 0x0 +#define MX6QDL_PAD_KEY_ROW1__ECSPI1_SS0 0x204 0x5d4 0x800 0x0 0x2 +#define MX6QDL_PAD_KEY_ROW1__ENET_COL 0x204 0x5d4 0x000 0x1 0x0 +#define MX6QDL_PAD_KEY_ROW1__AUD5_RXD 0x204 0x5d4 0x7cc 0x2 0x1 +#define MX6QDL_PAD_KEY_ROW1__KEY_ROW1 0x204 0x5d4 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_ROW1__UART5_RX_DATA 0x204 0x5d4 0x940 0x4 0x1 +#define MX6QDL_PAD_KEY_ROW1__UART5_TX_DATA 0x204 0x5d4 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_ROW1__GPIO4_IO09 0x204 0x5d4 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_ROW1__SD2_VSELECT 0x204 0x5d4 0x000 0x6 0x0 +#define MX6QDL_PAD_KEY_COL2__ECSPI1_SS1 0x208 0x5d8 0x804 0x0 0x2 +#define MX6QDL_PAD_KEY_COL2__ENET_RX_DATA2 0x208 0x5d8 0x850 0x1 0x1 +#define MX6QDL_PAD_KEY_COL2__FLEXCAN1_TX 0x208 0x5d8 0x000 0x2 0x0 +#define MX6QDL_PAD_KEY_COL2__KEY_COL2 0x208 0x5d8 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_COL2__ENET_MDC 0x208 0x5d8 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_COL2__GPIO4_IO10 0x208 0x5d8 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_COL2__USB_H1_PWR_CTL_WAKE 0x208 0x5d8 0x000 0x6 0x0 +#define MX6QDL_PAD_KEY_ROW2__ECSPI1_SS2 0x20c 0x5dc 0x808 0x0 0x1 +#define MX6QDL_PAD_KEY_ROW2__ENET_TX_DATA2 0x20c 0x5dc 0x000 0x1 0x0 +#define MX6QDL_PAD_KEY_ROW2__FLEXCAN1_RX 0x20c 0x5dc 0x7e4 0x2 0x0 +#define MX6QDL_PAD_KEY_ROW2__KEY_ROW2 0x20c 0x5dc 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_ROW2__SD2_VSELECT 0x20c 0x5dc 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_ROW2__GPIO4_IO11 0x20c 0x5dc 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_ROW2__HDMI_TX_CEC_LINE 0x20c 0x5dc 0x88c 0x6 0x1 +#define MX6QDL_PAD_KEY_COL3__ECSPI1_SS3 0x210 0x5e0 0x80c 0x0 0x1 +#define MX6QDL_PAD_KEY_COL3__ENET_CRS 0x210 0x5e0 0x000 0x1 0x0 +#define MX6QDL_PAD_KEY_COL3__HDMI_TX_DDC_SCL 0x210 0x5e0 0x890 0x2 0x1 +#define MX6QDL_PAD_KEY_COL3__KEY_COL3 0x210 0x5e0 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_COL3__I2C2_SCL 0x210 0x5e0 0x8a0 0x4 0x1 +#define MX6QDL_PAD_KEY_COL3__GPIO4_IO12 0x210 0x5e0 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_COL3__SPDIF_IN 0x210 0x5e0 0x914 0x6 0x2 +#define MX6QDL_PAD_KEY_ROW3__ASRC_EXT_CLK 0x214 0x5e4 0x7b0 0x1 0x0 +#define MX6QDL_PAD_KEY_ROW3__HDMI_TX_DDC_SDA 0x214 0x5e4 0x894 0x2 0x1 +#define MX6QDL_PAD_KEY_ROW3__KEY_ROW3 0x214 0x5e4 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_ROW3__I2C2_SDA 0x214 0x5e4 0x8a4 0x4 0x1 +#define MX6QDL_PAD_KEY_ROW3__GPIO4_IO13 0x214 0x5e4 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_ROW3__SD1_VSELECT 0x214 0x5e4 0x000 0x6 0x0 +#define MX6QDL_PAD_KEY_COL4__FLEXCAN2_TX 0x218 0x5e8 0x000 0x0 0x0 +#define MX6QDL_PAD_KEY_COL4__IPU1_SISG4 0x218 0x5e8 0x000 0x1 0x0 +#define MX6QDL_PAD_KEY_COL4__USB_OTG_OC 0x218 0x5e8 0x944 0x2 0x1 +#define MX6QDL_PAD_KEY_COL4__KEY_COL4 0x218 0x5e8 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_COL4__UART5_RTS_B 0x218 0x5e8 0x93c 0x4 0x0 +#define MX6QDL_PAD_KEY_COL4__UART5_CTS_B 0x218 0x5e8 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_COL4__GPIO4_IO14 0x218 0x5e8 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_ROW4__FLEXCAN2_RX 0x21c 0x5ec 0x7e8 0x0 0x0 +#define MX6QDL_PAD_KEY_ROW4__IPU1_SISG5 0x21c 0x5ec 0x000 0x1 0x0 +#define MX6QDL_PAD_KEY_ROW4__USB_OTG_PWR 0x21c 0x5ec 0x000 0x2 0x0 +#define MX6QDL_PAD_KEY_ROW4__KEY_ROW4 0x21c 0x5ec 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_ROW4__UART5_CTS_B 0x21c 0x5ec 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_ROW4__UART5_RTS_B 0x21c 0x5ec 0x93c 0x4 0x1 +#define MX6QDL_PAD_KEY_ROW4__GPIO4_IO15 0x21c 0x5ec 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_0__CCM_CLKO1 0x220 0x5f0 0x000 0x0 0x0 +#define MX6QDL_PAD_GPIO_0__KEY_COL5 0x220 0x5f0 0x8e8 0x2 0x0 +#define MX6QDL_PAD_GPIO_0__ASRC_EXT_CLK 0x220 0x5f0 0x7b0 0x3 0x1 +#define MX6QDL_PAD_GPIO_0__EPIT1_OUT 0x220 0x5f0 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_0__GPIO1_IO00 0x220 0x5f0 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_0__USB_H1_PWR 0x220 0x5f0 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_0__SNVS_VIO_5 0x220 0x5f0 0x000 0x7 0x0 +#define MX6QDL_PAD_GPIO_1__ESAI_RX_CLK 0x224 0x5f4 0x86c 0x0 0x1 +#define MX6QDL_PAD_GPIO_1__WDOG2_B 0x224 0x5f4 0x000 0x1 0x0 +#define MX6QDL_PAD_GPIO_1__KEY_ROW5 0x224 0x5f4 0x8f4 0x2 0x0 +#define MX6QDL_PAD_GPIO_1__USB_OTG_ID 0x224 0x5f4 0x004 0x3 0xff0d0101 +#define MX6QDL_PAD_GPIO_1__PWM2_OUT 0x224 0x5f4 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_1__GPIO1_IO01 0x224 0x5f4 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_1__SD1_CD_B 0x224 0x5f4 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_9__ESAI_RX_FS 0x228 0x5f8 0x85c 0x0 0x1 +#define MX6QDL_PAD_GPIO_9__WDOG1_B 0x228 0x5f8 0x000 0x1 0x0 +#define MX6QDL_PAD_GPIO_9__KEY_COL6 0x228 0x5f8 0x8ec 0x2 0x0 +#define MX6QDL_PAD_GPIO_9__CCM_REF_EN_B 0x228 0x5f8 0x000 0x3 0x0 +#define MX6QDL_PAD_GPIO_9__PWM1_OUT 0x228 0x5f8 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_9__GPIO1_IO09 0x228 0x5f8 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_9__SD1_WP 0x228 0x5f8 0x94c 0x6 0x1 +#define MX6QDL_PAD_GPIO_3__ESAI_RX_HF_CLK 0x22c 0x5fc 0x864 0x0 0x1 +#define MX6QDL_PAD_GPIO_3__I2C3_SCL 0x22c 0x5fc 0x8a8 0x2 0x1 +#define MX6QDL_PAD_GPIO_3__XTALOSC_REF_CLK_24M 0x22c 0x5fc 0x000 0x3 0x0 +#define MX6QDL_PAD_GPIO_3__CCM_CLKO2 0x22c 0x5fc 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_3__GPIO1_IO03 0x22c 0x5fc 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_3__USB_H1_OC 0x22c 0x5fc 0x948 0x6 0x1 +#define MX6QDL_PAD_GPIO_3__MLB_CLK 0x22c 0x5fc 0x900 0x7 0x1 +#define MX6QDL_PAD_GPIO_6__ESAI_TX_CLK 0x230 0x600 0x870 0x0 0x1 +#define MX6QDL_PAD_GPIO_6__ENET_IRQ 0x230 0x600 0x03c 0x11 0xff000609 +#define MX6QDL_PAD_GPIO_6__I2C3_SDA 0x230 0x600 0x8ac 0x2 0x1 +#define MX6QDL_PAD_GPIO_6__GPIO1_IO06 0x230 0x600 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_6__SD2_LCTL 0x230 0x600 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_6__MLB_SIG 0x230 0x600 0x908 0x7 0x1 +#define MX6QDL_PAD_GPIO_2__ESAI_TX_FS 0x234 0x604 0x860 0x0 0x1 +#define MX6QDL_PAD_GPIO_2__KEY_ROW6 0x234 0x604 0x8f8 0x2 0x1 +#define MX6QDL_PAD_GPIO_2__GPIO1_IO02 0x234 0x604 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_2__SD2_WP 0x234 0x604 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_2__MLB_DATA 0x234 0x604 0x904 0x7 0x1 +#define MX6QDL_PAD_GPIO_4__ESAI_TX_HF_CLK 0x238 0x608 0x868 0x0 0x1 +#define MX6QDL_PAD_GPIO_4__KEY_COL7 0x238 0x608 0x8f0 0x2 0x1 +#define MX6QDL_PAD_GPIO_4__GPIO1_IO04 0x238 0x608 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_4__SD2_CD_B 0x238 0x608 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_5__ESAI_TX2_RX3 0x23c 0x60c 0x87c 0x0 0x1 +#define MX6QDL_PAD_GPIO_5__KEY_ROW7 0x23c 0x60c 0x8fc 0x2 0x1 +#define MX6QDL_PAD_GPIO_5__CCM_CLKO1 0x23c 0x60c 0x000 0x3 0x0 +#define MX6QDL_PAD_GPIO_5__GPIO1_IO05 0x23c 0x60c 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_5__I2C3_SCL 0x23c 0x60c 0x8a8 0x6 0x2 +#define MX6QDL_PAD_GPIO_5__ARM_EVENTI 0x23c 0x60c 0x000 0x7 0x0 +#define MX6QDL_PAD_GPIO_7__ESAI_TX4_RX1 0x240 0x610 0x884 0x0 0x1 +#define MX6QDL_PAD_GPIO_7__ECSPI5_RDY 0x240 0x610 0x000 0x1 0x0 +#define MX6QDL_PAD_GPIO_7__EPIT1_OUT 0x240 0x610 0x000 0x2 0x0 +#define MX6QDL_PAD_GPIO_7__FLEXCAN1_TX 0x240 0x610 0x000 0x3 0x0 +#define MX6QDL_PAD_GPIO_7__UART2_TX_DATA 0x240 0x610 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_7__UART2_RX_DATA 0x240 0x610 0x928 0x4 0x2 +#define MX6QDL_PAD_GPIO_7__GPIO1_IO07 0x240 0x610 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_7__SPDIF_LOCK 0x240 0x610 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_7__USB_OTG_HOST_MODE 0x240 0x610 0x000 0x7 0x0 +#define MX6QDL_PAD_GPIO_8__ESAI_TX5_RX0 0x244 0x614 0x888 0x0 0x1 +#define MX6QDL_PAD_GPIO_8__XTALOSC_REF_CLK_32K 0x244 0x614 0x000 0x1 0x0 +#define MX6QDL_PAD_GPIO_8__EPIT2_OUT 0x244 0x614 0x000 0x2 0x0 +#define MX6QDL_PAD_GPIO_8__FLEXCAN1_RX 0x244 0x614 0x7e4 0x3 0x1 +#define MX6QDL_PAD_GPIO_8__UART2_RX_DATA 0x244 0x614 0x928 0x4 0x3 +#define MX6QDL_PAD_GPIO_8__UART2_TX_DATA 0x244 0x614 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_8__GPIO1_IO08 0x244 0x614 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_8__SPDIF_SR_CLK 0x244 0x614 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_8__USB_OTG_PWR_CTL_WAKE 0x244 0x614 0x000 0x7 0x0 +#define MX6QDL_PAD_GPIO_16__ESAI_TX3_RX2 0x248 0x618 0x880 0x0 0x1 +#define MX6QDL_PAD_GPIO_16__ENET_1588_EVENT2_IN 0x248 0x618 0x000 0x1 0x0 +#define MX6QDL_PAD_GPIO_16__ENET_REF_CLK 0x248 0x618 0x83c 0x2 0x1 +#define MX6QDL_PAD_GPIO_16__SD1_LCTL 0x248 0x618 0x000 0x3 0x0 +#define MX6QDL_PAD_GPIO_16__SPDIF_IN 0x248 0x618 0x914 0x4 0x3 +#define MX6QDL_PAD_GPIO_16__GPIO7_IO11 0x248 0x618 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_16__I2C3_SDA 0x248 0x618 0x8ac 0x6 0x2 +#define MX6QDL_PAD_GPIO_16__JTAG_DE_B 0x248 0x618 0x000 0x7 0x0 +#define MX6QDL_PAD_GPIO_17__ESAI_TX0 0x24c 0x61c 0x874 0x0 0x0 +#define MX6QDL_PAD_GPIO_17__ENET_1588_EVENT3_IN 0x24c 0x61c 0x000 0x1 0x0 +#define MX6QDL_PAD_GPIO_17__CCM_PMIC_READY 0x24c 0x61c 0x7f0 0x2 0x1 +#define MX6QDL_PAD_GPIO_17__SDMA_EXT_EVENT0 0x24c 0x61c 0x90c 0x3 0x1 +#define MX6QDL_PAD_GPIO_17__SPDIF_OUT 0x24c 0x61c 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_17__GPIO7_IO12 0x24c 0x61c 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_18__ESAI_TX1 0x250 0x620 0x878 0x0 0x0 +#define MX6QDL_PAD_GPIO_18__ENET_RX_CLK 0x250 0x620 0x844 0x1 0x1 +#define MX6QDL_PAD_GPIO_18__SD3_VSELECT 0x250 0x620 0x000 0x2 0x0 +#define MX6QDL_PAD_GPIO_18__SDMA_EXT_EVENT1 0x250 0x620 0x910 0x3 0x1 +#define MX6QDL_PAD_GPIO_18__ASRC_EXT_CLK 0x250 0x620 0x7b0 0x4 0x2 +#define MX6QDL_PAD_GPIO_18__GPIO7_IO13 0x250 0x620 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_18__SNVS_VIO_5_CTL 0x250 0x620 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_19__KEY_COL5 0x254 0x624 0x8e8 0x0 0x1 +#define MX6QDL_PAD_GPIO_19__ENET_1588_EVENT0_OUT 0x254 0x624 0x000 0x1 0x0 +#define MX6QDL_PAD_GPIO_19__SPDIF_OUT 0x254 0x624 0x000 0x2 0x0 +#define MX6QDL_PAD_GPIO_19__CCM_CLKO1 0x254 0x624 0x000 0x3 0x0 +#define MX6QDL_PAD_GPIO_19__ECSPI1_RDY 0x254 0x624 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_19__GPIO4_IO05 0x254 0x624 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_19__ENET_TX_ER 0x254 0x624 0x000 0x6 0x0 +#define MX6QDL_PAD_CSI0_PIXCLK__IPU1_CSI0_PIXCLK 0x258 0x628 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_PIXCLK__GPIO5_IO18 0x258 0x628 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_PIXCLK__ARM_EVENTO 0x258 0x628 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_MCLK__IPU1_CSI0_HSYNC 0x25c 0x62c 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_MCLK__CCM_CLKO1 0x25c 0x62c 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_MCLK__GPIO5_IO19 0x25c 0x62c 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_MCLK__ARM_TRACE_CTL 0x25c 0x62c 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DATA_EN__IPU1_CSI0_DATA_EN 0x260 0x630 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DATA_EN__EIM_DATA00 0x260 0x630 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DATA_EN__GPIO5_IO20 0x260 0x630 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DATA_EN__ARM_TRACE_CLK 0x260 0x630 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_VSYNC__IPU1_CSI0_VSYNC 0x264 0x634 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_VSYNC__EIM_DATA01 0x264 0x634 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_VSYNC__GPIO5_IO21 0x264 0x634 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_VSYNC__ARM_TRACE00 0x264 0x634 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT4__IPU1_CSI0_DATA04 0x268 0x638 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT4__EIM_DATA02 0x268 0x638 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT4__ECSPI1_SCLK 0x268 0x638 0x7f4 0x2 0x3 +#define MX6QDL_PAD_CSI0_DAT4__KEY_COL5 0x268 0x638 0x8e8 0x3 0x2 +#define MX6QDL_PAD_CSI0_DAT4__AUD3_TXC 0x268 0x638 0x000 0x4 0x0 +#define MX6QDL_PAD_CSI0_DAT4__GPIO5_IO22 0x268 0x638 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT4__ARM_TRACE01 0x268 0x638 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT5__IPU1_CSI0_DATA05 0x26c 0x63c 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT5__EIM_DATA03 0x26c 0x63c 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT5__ECSPI1_MOSI 0x26c 0x63c 0x7fc 0x2 0x3 +#define MX6QDL_PAD_CSI0_DAT5__KEY_ROW5 0x26c 0x63c 0x8f4 0x3 0x1 +#define MX6QDL_PAD_CSI0_DAT5__AUD3_TXD 0x26c 0x63c 0x000 0x4 0x0 +#define MX6QDL_PAD_CSI0_DAT5__GPIO5_IO23 0x26c 0x63c 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT5__ARM_TRACE02 0x26c 0x63c 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT6__IPU1_CSI0_DATA06 0x270 0x640 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT6__EIM_DATA04 0x270 0x640 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT6__ECSPI1_MISO 0x270 0x640 0x7f8 0x2 0x3 +#define MX6QDL_PAD_CSI0_DAT6__KEY_COL6 0x270 0x640 0x8ec 0x3 0x1 +#define MX6QDL_PAD_CSI0_DAT6__AUD3_TXFS 0x270 0x640 0x000 0x4 0x0 +#define MX6QDL_PAD_CSI0_DAT6__GPIO5_IO24 0x270 0x640 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT6__ARM_TRACE03 0x270 0x640 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT7__IPU1_CSI0_DATA07 0x274 0x644 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT7__EIM_DATA05 0x274 0x644 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT7__ECSPI1_SS0 0x274 0x644 0x800 0x2 0x3 +#define MX6QDL_PAD_CSI0_DAT7__KEY_ROW6 0x274 0x644 0x8f8 0x3 0x2 +#define MX6QDL_PAD_CSI0_DAT7__AUD3_RXD 0x274 0x644 0x000 0x4 0x0 +#define MX6QDL_PAD_CSI0_DAT7__GPIO5_IO25 0x274 0x644 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT7__ARM_TRACE04 0x274 0x644 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT8__IPU1_CSI0_DATA08 0x278 0x648 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT8__EIM_DATA06 0x278 0x648 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT8__ECSPI2_SCLK 0x278 0x648 0x810 0x2 0x2 +#define MX6QDL_PAD_CSI0_DAT8__KEY_COL7 0x278 0x648 0x8f0 0x3 0x2 +#define MX6QDL_PAD_CSI0_DAT8__I2C1_SDA 0x278 0x648 0x89c 0x4 0x1 +#define MX6QDL_PAD_CSI0_DAT8__GPIO5_IO26 0x278 0x648 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT8__ARM_TRACE05 0x278 0x648 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT9__IPU1_CSI0_DATA09 0x27c 0x64c 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT9__EIM_DATA07 0x27c 0x64c 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT9__ECSPI2_MOSI 0x27c 0x64c 0x818 0x2 0x2 +#define MX6QDL_PAD_CSI0_DAT9__KEY_ROW7 0x27c 0x64c 0x8fc 0x3 0x2 +#define MX6QDL_PAD_CSI0_DAT9__I2C1_SCL 0x27c 0x64c 0x898 0x4 0x1 +#define MX6QDL_PAD_CSI0_DAT9__GPIO5_IO27 0x27c 0x64c 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT9__ARM_TRACE06 0x27c 0x64c 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT10__IPU1_CSI0_DATA10 0x280 0x650 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT10__AUD3_RXC 0x280 0x650 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT10__ECSPI2_MISO 0x280 0x650 0x814 0x2 0x2 +#define MX6QDL_PAD_CSI0_DAT10__UART1_TX_DATA 0x280 0x650 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT10__UART1_RX_DATA 0x280 0x650 0x920 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT10__GPIO5_IO28 0x280 0x650 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT10__ARM_TRACE07 0x280 0x650 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT11__IPU1_CSI0_DATA11 0x284 0x654 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT11__AUD3_RXFS 0x284 0x654 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT11__ECSPI2_SS0 0x284 0x654 0x81c 0x2 0x2 +#define MX6QDL_PAD_CSI0_DAT11__UART1_RX_DATA 0x284 0x654 0x920 0x3 0x1 +#define MX6QDL_PAD_CSI0_DAT11__UART1_TX_DATA 0x284 0x654 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT11__GPIO5_IO29 0x284 0x654 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT11__ARM_TRACE08 0x284 0x654 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT12__IPU1_CSI0_DATA12 0x288 0x658 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT12__EIM_DATA08 0x288 0x658 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT12__UART4_TX_DATA 0x288 0x658 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT12__UART4_RX_DATA 0x288 0x658 0x938 0x3 0x2 +#define MX6QDL_PAD_CSI0_DAT12__GPIO5_IO30 0x288 0x658 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT12__ARM_TRACE09 0x288 0x658 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT13__IPU1_CSI0_DATA13 0x28c 0x65c 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT13__EIM_DATA09 0x28c 0x65c 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT13__UART4_RX_DATA 0x28c 0x65c 0x938 0x3 0x3 +#define MX6QDL_PAD_CSI0_DAT13__UART4_TX_DATA 0x28c 0x65c 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT13__GPIO5_IO31 0x28c 0x65c 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT13__ARM_TRACE10 0x28c 0x65c 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT14__IPU1_CSI0_DATA14 0x290 0x660 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT14__EIM_DATA10 0x290 0x660 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT14__UART5_TX_DATA 0x290 0x660 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT14__UART5_RX_DATA 0x290 0x660 0x940 0x3 0x2 +#define MX6QDL_PAD_CSI0_DAT14__GPIO6_IO00 0x290 0x660 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT14__ARM_TRACE11 0x290 0x660 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT15__IPU1_CSI0_DATA15 0x294 0x664 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT15__EIM_DATA11 0x294 0x664 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT15__UART5_RX_DATA 0x294 0x664 0x940 0x3 0x3 +#define MX6QDL_PAD_CSI0_DAT15__UART5_TX_DATA 0x294 0x664 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT15__GPIO6_IO01 0x294 0x664 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT15__ARM_TRACE12 0x294 0x664 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT16__IPU1_CSI0_DATA16 0x298 0x668 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT16__EIM_DATA12 0x298 0x668 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT16__UART4_RTS_B 0x298 0x668 0x934 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT16__UART4_CTS_B 0x298 0x668 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT16__GPIO6_IO02 0x298 0x668 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT16__ARM_TRACE13 0x298 0x668 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT17__IPU1_CSI0_DATA17 0x29c 0x66c 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT17__EIM_DATA13 0x29c 0x66c 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT17__UART4_CTS_B 0x29c 0x66c 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT17__UART4_RTS_B 0x29c 0x66c 0x934 0x3 0x1 +#define MX6QDL_PAD_CSI0_DAT17__GPIO6_IO03 0x29c 0x66c 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT17__ARM_TRACE14 0x29c 0x66c 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT18__IPU1_CSI0_DATA18 0x2a0 0x670 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT18__EIM_DATA14 0x2a0 0x670 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT18__UART5_RTS_B 0x2a0 0x670 0x93c 0x3 0x2 +#define MX6QDL_PAD_CSI0_DAT18__UART5_CTS_B 0x2a0 0x670 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT18__GPIO6_IO04 0x2a0 0x670 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT18__ARM_TRACE15 0x2a0 0x670 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT19__IPU1_CSI0_DATA19 0x2a4 0x674 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT19__EIM_DATA15 0x2a4 0x674 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT19__UART5_CTS_B 0x2a4 0x674 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT19__UART5_RTS_B 0x2a4 0x674 0x93c 0x3 0x3 +#define MX6QDL_PAD_CSI0_DAT19__GPIO6_IO05 0x2a4 0x674 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT7__SD3_DATA7 0x2a8 0x690 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT7__UART1_TX_DATA 0x2a8 0x690 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_DAT7__UART1_RX_DATA 0x2a8 0x690 0x920 0x1 0x2 +#define MX6QDL_PAD_SD3_DAT7__GPIO6_IO17 0x2a8 0x690 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT6__SD3_DATA6 0x2ac 0x694 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT6__UART1_RX_DATA 0x2ac 0x694 0x920 0x1 0x3 +#define MX6QDL_PAD_SD3_DAT6__UART1_TX_DATA 0x2ac 0x694 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_DAT6__GPIO6_IO18 0x2ac 0x694 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT5__SD3_DATA5 0x2b0 0x698 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT5__UART2_TX_DATA 0x2b0 0x698 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_DAT5__UART2_RX_DATA 0x2b0 0x698 0x928 0x1 0x4 +#define MX6QDL_PAD_SD3_DAT5__GPIO7_IO00 0x2b0 0x698 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT4__SD3_DATA4 0x2b4 0x69c 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT4__UART2_RX_DATA 0x2b4 0x69c 0x928 0x1 0x5 +#define MX6QDL_PAD_SD3_DAT4__UART2_TX_DATA 0x2b4 0x69c 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_DAT4__GPIO7_IO01 0x2b4 0x69c 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_CMD__SD3_CMD 0x2b8 0x6a0 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_CMD__UART2_CTS_B 0x2b8 0x6a0 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_CMD__UART2_RTS_B 0x2b8 0x6a0 0x924 0x1 0x2 +#define MX6QDL_PAD_SD3_CMD__FLEXCAN1_TX 0x2b8 0x6a0 0x000 0x2 0x0 +#define MX6QDL_PAD_SD3_CMD__GPIO7_IO02 0x2b8 0x6a0 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_CLK__SD3_CLK 0x2bc 0x6a4 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_CLK__UART2_RTS_B 0x2bc 0x6a4 0x924 0x1 0x3 +#define MX6QDL_PAD_SD3_CLK__UART2_CTS_B 0x2bc 0x6a4 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_CLK__FLEXCAN1_RX 0x2bc 0x6a4 0x7e4 0x2 0x2 +#define MX6QDL_PAD_SD3_CLK__GPIO7_IO03 0x2bc 0x6a4 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT0__SD3_DATA0 0x2c0 0x6a8 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT0__UART1_CTS_B 0x2c0 0x6a8 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_DAT0__UART1_RTS_B 0x2c0 0x6a8 0x91c 0x1 0x2 +#define MX6QDL_PAD_SD3_DAT0__FLEXCAN2_TX 0x2c0 0x6a8 0x000 0x2 0x0 +#define MX6QDL_PAD_SD3_DAT0__GPIO7_IO04 0x2c0 0x6a8 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT1__SD3_DATA1 0x2c4 0x6ac 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT1__UART1_RTS_B 0x2c4 0x6ac 0x91c 0x1 0x3 +#define MX6QDL_PAD_SD3_DAT1__UART1_CTS_B 0x2c4 0x6ac 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_DAT1__FLEXCAN2_RX 0x2c4 0x6ac 0x7e8 0x2 0x1 +#define MX6QDL_PAD_SD3_DAT1__GPIO7_IO05 0x2c4 0x6ac 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT2__SD3_DATA2 0x2c8 0x6b0 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT2__GPIO7_IO06 0x2c8 0x6b0 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT3__SD3_DATA3 0x2cc 0x6b4 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT3__UART3_CTS_B 0x2cc 0x6b4 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_DAT3__UART3_RTS_B 0x2cc 0x6b4 0x92c 0x1 0x4 +#define MX6QDL_PAD_SD3_DAT3__GPIO7_IO07 0x2cc 0x6b4 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_RST__SD3_RESET 0x2d0 0x6b8 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_RST__UART3_RTS_B 0x2d0 0x6b8 0x92c 0x1 0x5 +#define MX6QDL_PAD_SD3_RST__UART3_CTS_B 0x2d0 0x6b8 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_RST__GPIO7_IO08 0x2d0 0x6b8 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_CLE__NAND_CLE 0x2d4 0x6bc 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_CLE__IPU2_SISG4 0x2d4 0x6bc 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_CLE__GPIO6_IO07 0x2d4 0x6bc 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_ALE__NAND_ALE 0x2d8 0x6c0 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_ALE__SD4_RESET 0x2d8 0x6c0 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_ALE__GPIO6_IO08 0x2d8 0x6c0 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_WP_B__NAND_WP_B 0x2dc 0x6c4 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_WP_B__IPU2_SISG5 0x2dc 0x6c4 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_WP_B__GPIO6_IO09 0x2dc 0x6c4 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_RB0__NAND_READY_B 0x2e0 0x6c8 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_RB0__IPU2_DI0_PIN01 0x2e0 0x6c8 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_RB0__GPIO6_IO10 0x2e0 0x6c8 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_CS0__NAND_CE0_B 0x2e4 0x6cc 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_CS0__GPIO6_IO11 0x2e4 0x6cc 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_CS1__NAND_CE1_B 0x2e8 0x6d0 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_CS1__SD4_VSELECT 0x2e8 0x6d0 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_CS1__SD3_VSELECT 0x2e8 0x6d0 0x000 0x2 0x0 +#define MX6QDL_PAD_NANDF_CS1__GPIO6_IO14 0x2e8 0x6d0 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_CS2__NAND_CE2_B 0x2ec 0x6d4 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_CS2__IPU1_SISG0 0x2ec 0x6d4 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_CS2__ESAI_TX0 0x2ec 0x6d4 0x874 0x2 0x1 +#define MX6QDL_PAD_NANDF_CS2__EIM_CRE 0x2ec 0x6d4 0x000 0x3 0x0 +#define MX6QDL_PAD_NANDF_CS2__CCM_CLKO2 0x2ec 0x6d4 0x000 0x4 0x0 +#define MX6QDL_PAD_NANDF_CS2__GPIO6_IO15 0x2ec 0x6d4 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_CS2__IPU2_SISG0 0x2ec 0x6d4 0x000 0x6 0x0 +#define MX6QDL_PAD_NANDF_CS3__NAND_CE3_B 0x2f0 0x6d8 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_CS3__IPU1_SISG1 0x2f0 0x6d8 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_CS3__ESAI_TX1 0x2f0 0x6d8 0x878 0x2 0x1 +#define MX6QDL_PAD_NANDF_CS3__EIM_ADDR26 0x2f0 0x6d8 0x000 0x3 0x0 +#define MX6QDL_PAD_NANDF_CS3__GPIO6_IO16 0x2f0 0x6d8 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_CS3__IPU2_SISG1 0x2f0 0x6d8 0x000 0x6 0x0 +#define MX6QDL_PAD_SD4_CMD__SD4_CMD 0x2f4 0x6dc 0x000 0x0 0x0 +#define MX6QDL_PAD_SD4_CMD__NAND_RE_B 0x2f4 0x6dc 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_CMD__UART3_TX_DATA 0x2f4 0x6dc 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_CMD__UART3_RX_DATA 0x2f4 0x6dc 0x930 0x2 0x2 +#define MX6QDL_PAD_SD4_CMD__GPIO7_IO09 0x2f4 0x6dc 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_CLK__SD4_CLK 0x2f8 0x6e0 0x000 0x0 0x0 +#define MX6QDL_PAD_SD4_CLK__NAND_WE_B 0x2f8 0x6e0 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_CLK__UART3_RX_DATA 0x2f8 0x6e0 0x930 0x2 0x3 +#define MX6QDL_PAD_SD4_CLK__UART3_TX_DATA 0x2f8 0x6e0 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_CLK__GPIO7_IO10 0x2f8 0x6e0 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_D0__NAND_DATA00 0x2fc 0x6e4 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D0__SD1_DATA4 0x2fc 0x6e4 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D0__GPIO2_IO00 0x2fc 0x6e4 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_D1__NAND_DATA01 0x300 0x6e8 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D1__SD1_DATA5 0x300 0x6e8 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D1__GPIO2_IO01 0x300 0x6e8 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_D2__NAND_DATA02 0x304 0x6ec 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D2__SD1_DATA6 0x304 0x6ec 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D2__GPIO2_IO02 0x304 0x6ec 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_D3__NAND_DATA03 0x308 0x6f0 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D3__SD1_DATA7 0x308 0x6f0 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D3__GPIO2_IO03 0x308 0x6f0 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_D4__NAND_DATA04 0x30c 0x6f4 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D4__SD2_DATA4 0x30c 0x6f4 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D4__GPIO2_IO04 0x30c 0x6f4 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_D5__NAND_DATA05 0x310 0x6f8 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D5__SD2_DATA5 0x310 0x6f8 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D5__GPIO2_IO05 0x310 0x6f8 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_D6__NAND_DATA06 0x314 0x6fc 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D6__SD2_DATA6 0x314 0x6fc 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D6__GPIO2_IO06 0x314 0x6fc 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_D7__NAND_DATA07 0x318 0x700 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D7__SD2_DATA7 0x318 0x700 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D7__GPIO2_IO07 0x318 0x700 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT0__SD4_DATA0 0x31c 0x704 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT0__NAND_DQS 0x31c 0x704 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_DAT0__GPIO2_IO08 0x31c 0x704 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT1__SD4_DATA1 0x320 0x708 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT1__PWM3_OUT 0x320 0x708 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_DAT1__GPIO2_IO09 0x320 0x708 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT2__SD4_DATA2 0x324 0x70c 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT2__PWM4_OUT 0x324 0x70c 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_DAT2__GPIO2_IO10 0x324 0x70c 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT3__SD4_DATA3 0x328 0x710 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT3__GPIO2_IO11 0x328 0x710 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT4__SD4_DATA4 0x32c 0x714 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT4__UART2_RX_DATA 0x32c 0x714 0x928 0x2 0x6 +#define MX6QDL_PAD_SD4_DAT4__UART2_TX_DATA 0x32c 0x714 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_DAT4__GPIO2_IO12 0x32c 0x714 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT5__SD4_DATA5 0x330 0x718 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT5__UART2_RTS_B 0x330 0x718 0x924 0x2 0x4 +#define MX6QDL_PAD_SD4_DAT5__UART2_CTS_B 0x330 0x718 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_DAT5__GPIO2_IO13 0x330 0x718 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT6__SD4_DATA6 0x334 0x71c 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT6__UART2_CTS_B 0x334 0x71c 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_DAT6__UART2_RTS_B 0x334 0x71c 0x924 0x2 0x5 +#define MX6QDL_PAD_SD4_DAT6__GPIO2_IO14 0x334 0x71c 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT7__SD4_DATA7 0x338 0x720 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT7__UART2_TX_DATA 0x338 0x720 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_DAT7__UART2_RX_DATA 0x338 0x720 0x928 0x2 0x7 +#define MX6QDL_PAD_SD4_DAT7__GPIO2_IO15 0x338 0x720 0x000 0x5 0x0 +#define MX6QDL_PAD_SD1_DAT1__SD1_DATA1 0x33c 0x724 0x000 0x0 0x0 +#define MX6QDL_PAD_SD1_DAT1__ECSPI5_SS0 0x33c 0x724 0x834 0x1 0x1 +#define MX6QDL_PAD_SD1_DAT1__PWM3_OUT 0x33c 0x724 0x000 0x2 0x0 +#define MX6QDL_PAD_SD1_DAT1__GPT_CAPTURE2 0x33c 0x724 0x000 0x3 0x0 +#define MX6QDL_PAD_SD1_DAT1__GPIO1_IO17 0x33c 0x724 0x000 0x5 0x0 +#define MX6QDL_PAD_SD1_DAT0__SD1_DATA0 0x340 0x728 0x000 0x0 0x0 +#define MX6QDL_PAD_SD1_DAT0__ECSPI5_MISO 0x340 0x728 0x82c 0x1 0x1 +#define MX6QDL_PAD_SD1_DAT0__GPT_CAPTURE1 0x340 0x728 0x000 0x3 0x0 +#define MX6QDL_PAD_SD1_DAT0__GPIO1_IO16 0x340 0x728 0x000 0x5 0x0 +#define MX6QDL_PAD_SD1_DAT3__SD1_DATA3 0x344 0x72c 0x000 0x0 0x0 +#define MX6QDL_PAD_SD1_DAT3__ECSPI5_SS2 0x344 0x72c 0x000 0x1 0x0 +#define MX6QDL_PAD_SD1_DAT3__GPT_COMPARE3 0x344 0x72c 0x000 0x2 0x0 +#define MX6QDL_PAD_SD1_DAT3__PWM1_OUT 0x344 0x72c 0x000 0x3 0x0 +#define MX6QDL_PAD_SD1_DAT3__WDOG2_B 0x344 0x72c 0x000 0x4 0x0 +#define MX6QDL_PAD_SD1_DAT3__GPIO1_IO21 0x344 0x72c 0x000 0x5 0x0 +#define MX6QDL_PAD_SD1_DAT3__WDOG2_RESET_B_DEB 0x344 0x72c 0x000 0x6 0x0 +#define MX6QDL_PAD_SD1_CMD__SD1_CMD 0x348 0x730 0x000 0x0 0x0 +#define MX6QDL_PAD_SD1_CMD__ECSPI5_MOSI 0x348 0x730 0x830 0x1 0x0 +#define MX6QDL_PAD_SD1_CMD__PWM4_OUT 0x348 0x730 0x000 0x2 0x0 +#define MX6QDL_PAD_SD1_CMD__GPT_COMPARE1 0x348 0x730 0x000 0x3 0x0 +#define MX6QDL_PAD_SD1_CMD__GPIO1_IO18 0x348 0x730 0x000 0x5 0x0 +#define MX6QDL_PAD_SD1_DAT2__SD1_DATA2 0x34c 0x734 0x000 0x0 0x0 +#define MX6QDL_PAD_SD1_DAT2__ECSPI5_SS1 0x34c 0x734 0x838 0x1 0x1 +#define MX6QDL_PAD_SD1_DAT2__GPT_COMPARE2 0x34c 0x734 0x000 0x2 0x0 +#define MX6QDL_PAD_SD1_DAT2__PWM2_OUT 0x34c 0x734 0x000 0x3 0x0 +#define MX6QDL_PAD_SD1_DAT2__WDOG1_B 0x34c 0x734 0x000 0x4 0x0 +#define MX6QDL_PAD_SD1_DAT2__GPIO1_IO19 0x34c 0x734 0x000 0x5 0x0 +#define MX6QDL_PAD_SD1_DAT2__WDOG1_RESET_B_DEB 0x34c 0x734 0x000 0x6 0x0 +#define MX6QDL_PAD_SD1_CLK__SD1_CLK 0x350 0x738 0x000 0x0 0x0 +#define MX6QDL_PAD_SD1_CLK__ECSPI5_SCLK 0x350 0x738 0x828 0x1 0x0 +#define MX6QDL_PAD_SD1_CLK__OSC32K_32K_OUT 0x350 0x738 0x000 0x2 0x0 +#define MX6QDL_PAD_SD1_CLK__GPT_CLKIN 0x350 0x738 0x000 0x3 0x0 +#define MX6QDL_PAD_SD1_CLK__GPIO1_IO20 0x350 0x738 0x000 0x5 0x0 +#define MX6QDL_PAD_SD2_CLK__SD2_CLK 0x354 0x73c 0x000 0x0 0x0 +#define MX6QDL_PAD_SD2_CLK__ECSPI5_SCLK 0x354 0x73c 0x828 0x1 0x1 +#define MX6QDL_PAD_SD2_CLK__KEY_COL5 0x354 0x73c 0x8e8 0x2 0x3 +#define MX6QDL_PAD_SD2_CLK__AUD4_RXFS 0x354 0x73c 0x7c0 0x3 0x1 +#define MX6QDL_PAD_SD2_CLK__GPIO1_IO10 0x354 0x73c 0x000 0x5 0x0 +#define MX6QDL_PAD_SD2_CMD__SD2_CMD 0x358 0x740 0x000 0x0 0x0 +#define MX6QDL_PAD_SD2_CMD__ECSPI5_MOSI 0x358 0x740 0x830 0x1 0x1 +#define MX6QDL_PAD_SD2_CMD__KEY_ROW5 0x358 0x740 0x8f4 0x2 0x2 +#define MX6QDL_PAD_SD2_CMD__AUD4_RXC 0x358 0x740 0x7bc 0x3 0x1 +#define MX6QDL_PAD_SD2_CMD__GPIO1_IO11 0x358 0x740 0x000 0x5 0x0 +#define MX6QDL_PAD_SD2_DAT3__SD2_DATA3 0x35c 0x744 0x000 0x0 0x0 +#define MX6QDL_PAD_SD2_DAT3__ECSPI5_SS3 0x35c 0x744 0x000 0x1 0x0 +#define MX6QDL_PAD_SD2_DAT3__KEY_COL6 0x35c 0x744 0x8ec 0x2 0x2 +#define MX6QDL_PAD_SD2_DAT3__AUD4_TXC 0x35c 0x744 0x7c4 0x3 0x1 +#define MX6QDL_PAD_SD2_DAT3__GPIO1_IO12 0x35c 0x744 0x000 0x5 0x0 + +#endif /* __DTS_IMX6Q_PINFUNC_H */ diff --git a/arch/arm/dts/imx6q.dtsi b/arch/arm/dts/imx6q.dtsi new file mode 100644 index 0000000..399103b --- /dev/null +++ b/arch/arm/dts/imx6q.dtsi @@ -0,0 +1,318 @@ + +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * + */ + +#include <dt-bindings/interrupt-controller/irq.h> +#include "imx6q-pinfunc.h" +#include "imx6qdl.dtsi" + +/ { + aliases { + spi4 = &ecspi5; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + compatible = "arm,cortex-a9"; + device_type = "cpu"; + reg = <0>; + next-level-cache = <&L2>; + operating-points = < + /* kHz uV */ + 1200000 1275000 + 996000 1250000 + 852000 1250000 + 792000 1175000 + 396000 975000 + >; + fsl,soc-operating-points = < + /* ARM kHz SOC-PU uV */ + 1200000 1275000 + 996000 1250000 + 852000 1250000 + 792000 1175000 + 396000 1175000 + >; + clock-latency = <61036>; /* two CLK32 periods */ + clocks = <&clks IMX6QDL_CLK_ARM>, + <&clks IMX6QDL_CLK_PLL2_PFD2_396M>, + <&clks IMX6QDL_CLK_STEP>, + <&clks IMX6QDL_CLK_PLL1_SW>, + <&clks IMX6QDL_CLK_PLL1_SYS>; + clock-names = "arm", "pll2_pfd2_396m", "step", + "pll1_sw", "pll1_sys"; + arm-supply = <®_arm>; + pu-supply = <®_pu>; + soc-supply = <®_soc>; + }; + + cpu@1 { + compatible = "arm,cortex-a9"; + device_type = "cpu"; + reg = <1>; + next-level-cache = <&L2>; + }; + + cpu@2 { + compatible = "arm,cortex-a9"; + device_type = "cpu"; + reg = <2>; + next-level-cache = <&L2>; + }; + + cpu@3 { + compatible = "arm,cortex-a9"; + device_type = "cpu"; + reg = <3>; + next-level-cache = <&L2>; + }; + }; + + soc { + ocram: sram@00900000 { + compatible = "mmio-sram"; + reg = <0x00900000 0x40000>; + clocks = <&clks IMX6QDL_CLK_OCRAM>; + }; + + aips-bus@02000000 { /* AIPS1 */ + spba-bus@02000000 { + ecspi5: ecspi@02018000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx6q-ecspi", "fsl,imx51-ecspi"; + reg = <0x02018000 0x4000>; + interrupts = <0 35 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6Q_CLK_ECSPI5>, + <&clks IMX6Q_CLK_ECSPI5>; + clock-names = "ipg", "per"; + dmas = <&sdma 11 7 1>, <&sdma 12 7 2>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + }; + + iomuxc: iomuxc@020e0000 { + compatible = "fsl,imx6q-iomuxc"; + + ipu2 { + pinctrl_ipu2_1: ipu2grp-1 { + fsl,pins = < + MX6QDL_PAD_DI0_DISP_CLK__IPU2_DI0_DISP_CLK 0x10 + MX6QDL_PAD_DI0_PIN15__IPU2_DI0_PIN15 0x10 + MX6QDL_PAD_DI0_PIN2__IPU2_DI0_PIN02 0x10 + MX6QDL_PAD_DI0_PIN3__IPU2_DI0_PIN03 0x10 + MX6QDL_PAD_DI0_PIN4__IPU2_DI0_PIN04 0x80000000 + MX6QDL_PAD_DISP0_DAT0__IPU2_DISP0_DATA00 0x10 + MX6QDL_PAD_DISP0_DAT1__IPU2_DISP0_DATA01 0x10 + MX6QDL_PAD_DISP0_DAT2__IPU2_DISP0_DATA02 0x10 + MX6QDL_PAD_DISP0_DAT3__IPU2_DISP0_DATA03 0x10 + MX6QDL_PAD_DISP0_DAT4__IPU2_DISP0_DATA04 0x10 + MX6QDL_PAD_DISP0_DAT5__IPU2_DISP0_DATA05 0x10 + MX6QDL_PAD_DISP0_DAT6__IPU2_DISP0_DATA06 0x10 + MX6QDL_PAD_DISP0_DAT7__IPU2_DISP0_DATA07 0x10 + MX6QDL_PAD_DISP0_DAT8__IPU2_DISP0_DATA08 0x10 + MX6QDL_PAD_DISP0_DAT9__IPU2_DISP0_DATA09 0x10 + MX6QDL_PAD_DISP0_DAT10__IPU2_DISP0_DATA10 0x10 + MX6QDL_PAD_DISP0_DAT11__IPU2_DISP0_DATA11 0x10 + MX6QDL_PAD_DISP0_DAT12__IPU2_DISP0_DATA12 0x10 + MX6QDL_PAD_DISP0_DAT13__IPU2_DISP0_DATA13 0x10 + MX6QDL_PAD_DISP0_DAT14__IPU2_DISP0_DATA14 0x10 + MX6QDL_PAD_DISP0_DAT15__IPU2_DISP0_DATA15 0x10 + MX6QDL_PAD_DISP0_DAT16__IPU2_DISP0_DATA16 0x10 + MX6QDL_PAD_DISP0_DAT17__IPU2_DISP0_DATA17 0x10 + MX6QDL_PAD_DISP0_DAT18__IPU2_DISP0_DATA18 0x10 + MX6QDL_PAD_DISP0_DAT19__IPU2_DISP0_DATA19 0x10 + MX6QDL_PAD_DISP0_DAT20__IPU2_DISP0_DATA20 0x10 + MX6QDL_PAD_DISP0_DAT21__IPU2_DISP0_DATA21 0x10 + MX6QDL_PAD_DISP0_DAT22__IPU2_DISP0_DATA22 0x10 + MX6QDL_PAD_DISP0_DAT23__IPU2_DISP0_DATA23 0x10 + >; + }; + }; + }; + }; + + sata: sata@02200000 { + compatible = "fsl,imx6q-ahci"; + reg = <0x02200000 0x4000>; + interrupts = <0 39 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_SATA>, + <&clks IMX6QDL_CLK_SATA_REF_100M>, + <&clks IMX6QDL_CLK_AHB>; + clock-names = "sata", "sata_ref", "ahb"; + status = "disabled"; + }; + + ipu2: ipu@02800000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx6q-ipu"; + reg = <0x02800000 0x400000>; + interrupts = <0 8 IRQ_TYPE_LEVEL_HIGH>, + <0 7 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_IPU2>, + <&clks IMX6QDL_CLK_IPU2_DI0>, + <&clks IMX6QDL_CLK_IPU2_DI1>; + clock-names = "bus", "di0", "di1"; + resets = <&src 4>; + + ipu2_csi0: port@0 { + reg = <0>; + }; + + ipu2_csi1: port@1 { + reg = <1>; + }; + + ipu2_di0: port@2 { + #address-cells = <1>; + #size-cells = <0>; + reg = <2>; + + ipu2_di0_disp0: endpoint@0 { + }; + + ipu2_di0_hdmi: endpoint@1 { + remote-endpoint = <&hdmi_mux_2>; + }; + + ipu2_di0_mipi: endpoint@2 { + }; + + ipu2_di0_lvds0: endpoint@3 { + remote-endpoint = <&lvds0_mux_2>; + }; + + ipu2_di0_lvds1: endpoint@4 { + remote-endpoint = <&lvds1_mux_2>; + }; + }; + + ipu2_di1: port@3 { + #address-cells = <1>; + #size-cells = <0>; + reg = <3>; + + ipu2_di1_hdmi: endpoint@1 { + remote-endpoint = <&hdmi_mux_3>; + }; + + ipu2_di1_mipi: endpoint@2 { + }; + + ipu2_di1_lvds0: endpoint@3 { + remote-endpoint = <&lvds0_mux_3>; + }; + + ipu2_di1_lvds1: endpoint@4 { + remote-endpoint = <&lvds1_mux_3>; + }; + }; + }; + }; + + display-subsystem { + compatible = "fsl,imx-display-subsystem"; + ports = <&ipu1_di0>, <&ipu1_di1>, <&ipu2_di0>, <&ipu2_di1>; + }; +}; + +&hdmi { + compatible = "fsl,imx6q-hdmi"; + + port@2 { + reg = <2>; + + hdmi_mux_2: endpoint { + remote-endpoint = <&ipu2_di0_hdmi>; + }; + }; + + port@3 { + reg = <3>; + + hdmi_mux_3: endpoint { + remote-endpoint = <&ipu2_di1_hdmi>; + }; + }; +}; + +&ldb { + clocks = <&clks IMX6QDL_CLK_LDB_DI0_SEL>, <&clks IMX6QDL_CLK_LDB_DI1_SEL>, + <&clks IMX6QDL_CLK_IPU1_DI0_SEL>, <&clks IMX6QDL_CLK_IPU1_DI1_SEL>, + <&clks IMX6QDL_CLK_IPU2_DI0_SEL>, <&clks IMX6QDL_CLK_IPU2_DI1_SEL>, + <&clks IMX6QDL_CLK_LDB_DI0>, <&clks IMX6QDL_CLK_LDB_DI1>; + clock-names = "di0_pll", "di1_pll", + "di0_sel", "di1_sel", "di2_sel", "di3_sel", + "di0", "di1"; + + lvds-channel@0 { + port@2 { + reg = <2>; + + lvds0_mux_2: endpoint { + remote-endpoint = <&ipu2_di0_lvds0>; + }; + }; + + port@3 { + reg = <3>; + + lvds0_mux_3: endpoint { + remote-endpoint = <&ipu2_di1_lvds0>; + }; + }; + }; + + lvds-channel@1 { + port@2 { + reg = <2>; + + lvds1_mux_2: endpoint { + remote-endpoint = <&ipu2_di0_lvds1>; + }; + }; + + port@3 { + reg = <3>; + + lvds1_mux_3: endpoint { + remote-endpoint = <&ipu2_di1_lvds1>; + }; + }; + }; +}; + +&mipi_dsi { + ports { + port@2 { + reg = <2>; + + mipi_mux_2: endpoint { + remote-endpoint = <&ipu2_di0_mipi>; + }; + }; + + port@3 { + reg = <3>; + + mipi_mux_3: endpoint { + remote-endpoint = <&ipu2_di1_mipi>; + }; + }; + }; +}; + +&vpu { + compatible = "fsl,imx6q-vpu", "cnm,coda960"; +}; diff --git a/arch/arm/dts/imx6qdl.dtsi b/arch/arm/dts/imx6qdl.dtsi new file mode 100644 index 0000000..2b6cc8b --- /dev/null +++ b/arch/arm/dts/imx6qdl.dtsi @@ -0,0 +1,1247 @@ +/* + * Copyright 2011 Freescale Semiconductor, Inc. + * Copyright 2011 Linaro Ltd. + * + * The code contained herein is licensed under the GNU General Public + * License. You may obtain a copy of the GNU General Public License + * Version 2 or later at the following locations: + * + * http://www.opensource.org/licenses/gpl-license.html + * http://www.gnu.org/copyleft/gpl.html + */ + +#include <dt-bindings/clock/imx6qdl-clock.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> + +#include "skeleton.dtsi" + +/ { + aliases { + ethernet0 = &fec; + can0 = &can1; + can1 = &can2; + gpio0 = &gpio1; + gpio1 = &gpio2; + gpio2 = &gpio3; + gpio3 = &gpio4; + gpio4 = &gpio5; + gpio5 = &gpio6; + gpio6 = &gpio7; + i2c0 = &i2c1; + i2c1 = &i2c2; + i2c2 = &i2c3; + mmc0 = &usdhc1; + mmc1 = &usdhc2; + mmc2 = &usdhc3; + mmc3 = &usdhc4; + serial0 = &uart1; + serial1 = &uart2; + serial2 = &uart3; + serial3 = &uart4; + serial4 = &uart5; + spi0 = &ecspi1; + spi1 = &ecspi2; + spi2 = &ecspi3; + spi3 = &ecspi4; + usbphy0 = &usbphy1; + usbphy1 = &usbphy2; + }; + + intc: interrupt-controller@00a01000 { + compatible = "arm,cortex-a9-gic"; + #interrupt-cells = <3>; + interrupt-controller; + reg = <0x00a01000 0x1000>, + <0x00a00100 0x100>; + interrupt-parent = <&intc>; + }; + + clocks { + #address-cells = <1>; + #size-cells = <0>; + + ckil { + compatible = "fsl,imx-ckil", "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <32768>; + }; + + ckih1 { + compatible = "fsl,imx-ckih1", "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + }; + + osc { + compatible = "fsl,imx-osc", "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <24000000>; + }; + }; + + soc { + #address-cells = <1>; + #size-cells = <1>; + compatible = "simple-bus"; + interrupt-parent = <&gpc>; + ranges; + + dma_apbh: dma-apbh@00110000 { + compatible = "fsl,imx6q-dma-apbh", "fsl,imx28-dma-apbh"; + reg = <0x00110000 0x2000>; + interrupts = <0 13 IRQ_TYPE_LEVEL_HIGH>, + <0 13 IRQ_TYPE_LEVEL_HIGH>, + <0 13 IRQ_TYPE_LEVEL_HIGH>, + <0 13 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "gpmi0", "gpmi1", "gpmi2", "gpmi3"; + #dma-cells = <1>; + dma-channels = <4>; + clocks = <&clks IMX6QDL_CLK_APBH_DMA>; + }; + + gpmi: gpmi-nand@00112000 { + compatible = "fsl,imx6q-gpmi-nand"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x00112000 0x2000>, <0x00114000 0x2000>; + reg-names = "gpmi-nand", "bch"; + interrupts = <0 15 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "bch"; + clocks = <&clks IMX6QDL_CLK_GPMI_IO>, + <&clks IMX6QDL_CLK_GPMI_APB>, + <&clks IMX6QDL_CLK_GPMI_BCH>, + <&clks IMX6QDL_CLK_GPMI_BCH_APB>, + <&clks IMX6QDL_CLK_PER1_BCH>; + clock-names = "gpmi_io", "gpmi_apb", "gpmi_bch", + "gpmi_bch_apb", "per1_bch"; + dmas = <&dma_apbh 0>; + dma-names = "rx-tx"; + status = "disabled"; + }; + + hdmi: hdmi@0120000 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x00120000 0x9000>; + interrupts = <0 115 0x04>; + gpr = <&gpr>; + clocks = <&clks IMX6QDL_CLK_HDMI_IAHB>, + <&clks IMX6QDL_CLK_HDMI_ISFR>; + clock-names = "iahb", "isfr"; + status = "disabled"; + + port@0 { + reg = <0>; + + hdmi_mux_0: endpoint { + remote-endpoint = <&ipu1_di0_hdmi>; + }; + }; + + port@1 { + reg = <1>; + + hdmi_mux_1: endpoint { + remote-endpoint = <&ipu1_di1_hdmi>; + }; + }; + }; + + timer@00a00600 { + compatible = "arm,cortex-a9-twd-timer"; + reg = <0x00a00600 0x20>; + interrupts = <1 13 0xf01>; + interrupt-parent = <&intc>; + clocks = <&clks IMX6QDL_CLK_TWD>; + }; + + L2: l2-cache@00a02000 { + compatible = "arm,pl310-cache"; + reg = <0x00a02000 0x1000>; + interrupts = <0 92 IRQ_TYPE_LEVEL_HIGH>; + cache-unified; + cache-level = <2>; + arm,tag-latency = <4 2 3>; + arm,data-latency = <4 2 3>; + }; + + pcie: pcie@0x01000000 { + compatible = "fsl,imx6q-pcie", "snps,dw-pcie"; + reg = <0x01ffc000 0x04000>, + <0x01f00000 0x80000>; + reg-names = "dbi", "config"; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + ranges = <0x00000800 0 0x01f00000 0x01f00000 0 0x00080000 /* configuration space */ + 0x81000000 0 0 0x01f80000 0 0x00010000 /* downstream I/O */ + 0x82000000 0 0x01000000 0x01000000 0 0x00f00000>; /* non-prefetchable memory */ + num-lanes = <1>; + interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "msi"; + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 0 0x7>; + interrupt-map = <0 0 0 1 &gpc GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>, + <0 0 0 2 &gpc GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>, + <0 0 0 3 &gpc GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>, + <0 0 0 4 &gpc GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_PCIE_AXI>, + <&clks IMX6QDL_CLK_LVDS1_GATE>, + <&clks IMX6QDL_CLK_PCIE_REF_125M>; + clock-names = "pcie", "pcie_bus", "pcie_phy"; + status = "disabled"; + }; + + pmu { + compatible = "arm,cortex-a9-pmu"; + interrupts = <0 94 IRQ_TYPE_LEVEL_HIGH>; + }; + + aips-bus@02000000 { /* AIPS1 */ + compatible = "fsl,aips-bus", "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x02000000 0x100000>; + ranges; + + spba-bus@02000000 { + compatible = "fsl,spba-bus", "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x02000000 0x40000>; + ranges; + + spdif: spdif@02004000 { + compatible = "fsl,imx35-spdif"; + reg = <0x02004000 0x4000>; + interrupts = <0 52 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&sdma 14 18 0>, + <&sdma 15 18 0>; + dma-names = "rx", "tx"; + clocks = <&clks IMX6QDL_CLK_SPDIF_GCLK>, <&clks IMX6QDL_CLK_OSC>, + <&clks IMX6QDL_CLK_SPDIF>, <&clks IMX6QDL_CLK_ASRC>, + <&clks IMX6QDL_CLK_DUMMY>, <&clks IMX6QDL_CLK_ESAI_EXTAL>, + <&clks IMX6QDL_CLK_IPG>, <&clks IMX6QDL_CLK_MLB>, + <&clks IMX6QDL_CLK_DUMMY>, <&clks IMX6QDL_CLK_SPBA>; + clock-names = "core", "rxtx0", + "rxtx1", "rxtx2", + "rxtx3", "rxtx4", + "rxtx5", "rxtx6", + "rxtx7", "dma"; + status = "disabled"; + }; + + ecspi1: ecspi@02008000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx6q-ecspi", "fsl,imx51-ecspi"; + reg = <0x02008000 0x4000>; + interrupts = <0 31 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_ECSPI1>, + <&clks IMX6QDL_CLK_ECSPI1>; + clock-names = "ipg", "per"; + dmas = <&sdma 3 7 1>, <&sdma 4 7 2>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + ecspi2: ecspi@0200c000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx6q-ecspi", "fsl,imx51-ecspi"; + reg = <0x0200c000 0x4000>; + interrupts = <0 32 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_ECSPI2>, + <&clks IMX6QDL_CLK_ECSPI2>; + clock-names = "ipg", "per"; + dmas = <&sdma 5 7 1>, <&sdma 6 7 2>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + ecspi3: ecspi@02010000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx6q-ecspi", "fsl,imx51-ecspi"; + reg = <0x02010000 0x4000>; + interrupts = <0 33 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_ECSPI3>, + <&clks IMX6QDL_CLK_ECSPI3>; + clock-names = "ipg", "per"; + dmas = <&sdma 7 7 1>, <&sdma 8 7 2>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + ecspi4: ecspi@02014000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx6q-ecspi", "fsl,imx51-ecspi"; + reg = <0x02014000 0x4000>; + interrupts = <0 34 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_ECSPI4>, + <&clks IMX6QDL_CLK_ECSPI4>; + clock-names = "ipg", "per"; + dmas = <&sdma 9 7 1>, <&sdma 10 7 2>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + uart1: serial@02020000 { + compatible = "fsl,imx6q-uart", "fsl,imx21-uart"; + reg = <0x02020000 0x4000>; + interrupts = <0 26 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_UART_IPG>, + <&clks IMX6QDL_CLK_UART_SERIAL>; + clock-names = "ipg", "per"; + dmas = <&sdma 25 4 0>, <&sdma 26 4 0>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + esai: esai@02024000 { + #sound-dai-cells = <0>; + compatible = "fsl,imx35-esai"; + reg = <0x02024000 0x4000>; + interrupts = <0 51 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_ESAI_IPG>, + <&clks IMX6QDL_CLK_ESAI_MEM>, + <&clks IMX6QDL_CLK_ESAI_EXTAL>, + <&clks IMX6QDL_CLK_ESAI_IPG>, + <&clks IMX6QDL_CLK_SPBA>; + clock-names = "core", "mem", "extal", "fsys", "dma"; + dmas = <&sdma 23 21 0>, <&sdma 24 21 0>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + ssi1: ssi@02028000 { + #sound-dai-cells = <0>; + compatible = "fsl,imx6q-ssi", + "fsl,imx51-ssi"; + reg = <0x02028000 0x4000>; + interrupts = <0 46 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_SSI1_IPG>, + <&clks IMX6QDL_CLK_SSI1>; + clock-names = "ipg", "baud"; + dmas = <&sdma 37 1 0>, + <&sdma 38 1 0>; + dma-names = "rx", "tx"; + fsl,fifo-depth = <15>; + status = "disabled"; + }; + + ssi2: ssi@0202c000 { + #sound-dai-cells = <0>; + compatible = "fsl,imx6q-ssi", + "fsl,imx51-ssi"; + reg = <0x0202c000 0x4000>; + interrupts = <0 47 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_SSI2_IPG>, + <&clks IMX6QDL_CLK_SSI2>; + clock-names = "ipg", "baud"; + dmas = <&sdma 41 1 0>, + <&sdma 42 1 0>; + dma-names = "rx", "tx"; + fsl,fifo-depth = <15>; + status = "disabled"; + }; + + ssi3: ssi@02030000 { + #sound-dai-cells = <0>; + compatible = "fsl,imx6q-ssi", + "fsl,imx51-ssi"; + reg = <0x02030000 0x4000>; + interrupts = <0 48 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_SSI3_IPG>, + <&clks IMX6QDL_CLK_SSI3>; + clock-names = "ipg", "baud"; + dmas = <&sdma 45 1 0>, + <&sdma 46 1 0>; + dma-names = "rx", "tx"; + fsl,fifo-depth = <15>; + status = "disabled"; + }; + + asrc: asrc@02034000 { + compatible = "fsl,imx53-asrc"; + reg = <0x02034000 0x4000>; + interrupts = <0 50 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_ASRC_IPG>, + <&clks IMX6QDL_CLK_ASRC_MEM>, <&clks 0>, + <&clks 0>, <&clks 0>, <&clks 0>, <&clks 0>, + <&clks 0>, <&clks 0>, <&clks 0>, <&clks 0>, + <&clks 0>, <&clks 0>, <&clks 0>, <&clks 0>, + <&clks IMX6QDL_CLK_ASRC>, <&clks 0>, <&clks 0>, + <&clks IMX6QDL_CLK_SPBA>; + clock-names = "mem", "ipg", "asrck_0", + "asrck_1", "asrck_2", "asrck_3", "asrck_4", + "asrck_5", "asrck_6", "asrck_7", "asrck_8", + "asrck_9", "asrck_a", "asrck_b", "asrck_c", + "asrck_d", "asrck_e", "asrck_f", "dma"; + dmas = <&sdma 17 23 1>, <&sdma 18 23 1>, <&sdma 19 23 1>, + <&sdma 20 23 1>, <&sdma 21 23 1>, <&sdma 22 23 1>; + dma-names = "rxa", "rxb", "rxc", + "txa", "txb", "txc"; + fsl,asrc-rate = <48000>; + fsl,asrc-width = <16>; + status = "okay"; + }; + + spba@0203c000 { + reg = <0x0203c000 0x4000>; + }; + }; + + vpu: vpu@02040000 { + compatible = "cnm,coda960"; + reg = <0x02040000 0x3c000>; + interrupts = <0 12 IRQ_TYPE_LEVEL_HIGH>, + <0 3 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "bit", "jpeg"; + clocks = <&clks IMX6QDL_CLK_VPU_AXI>, + <&clks IMX6QDL_CLK_MMDC_CH0_AXI>; + clock-names = "per", "ahb"; + power-domains = <&gpc 1>; + resets = <&src 1>; + iram = <&ocram>; + }; + + aipstz@0207c000 { /* AIPSTZ1 */ + reg = <0x0207c000 0x4000>; + }; + + pwm1: pwm@02080000 { + #pwm-cells = <2>; + compatible = "fsl,imx6q-pwm", "fsl,imx27-pwm"; + reg = <0x02080000 0x4000>; + interrupts = <0 83 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_IPG>, + <&clks IMX6QDL_CLK_PWM1>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + pwm2: pwm@02084000 { + #pwm-cells = <2>; + compatible = "fsl,imx6q-pwm", "fsl,imx27-pwm"; + reg = <0x02084000 0x4000>; + interrupts = <0 84 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_IPG>, + <&clks IMX6QDL_CLK_PWM2>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + pwm3: pwm@02088000 { + #pwm-cells = <2>; + compatible = "fsl,imx6q-pwm", "fsl,imx27-pwm"; + reg = <0x02088000 0x4000>; + interrupts = <0 85 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_IPG>, + <&clks IMX6QDL_CLK_PWM3>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + pwm4: pwm@0208c000 { + #pwm-cells = <2>; + compatible = "fsl,imx6q-pwm", "fsl,imx27-pwm"; + reg = <0x0208c000 0x4000>; + interrupts = <0 86 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_IPG>, + <&clks IMX6QDL_CLK_PWM4>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + can1: flexcan@02090000 { + compatible = "fsl,imx6q-flexcan"; + reg = <0x02090000 0x4000>; + interrupts = <0 110 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_CAN1_IPG>, + <&clks IMX6QDL_CLK_CAN1_SERIAL>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + can2: flexcan@02094000 { + compatible = "fsl,imx6q-flexcan"; + reg = <0x02094000 0x4000>; + interrupts = <0 111 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_CAN2_IPG>, + <&clks IMX6QDL_CLK_CAN2_SERIAL>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + gpt: gpt@02098000 { + compatible = "fsl,imx6q-gpt", "fsl,imx31-gpt"; + reg = <0x02098000 0x4000>; + interrupts = <0 55 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_GPT_IPG>, + <&clks IMX6QDL_CLK_GPT_IPG_PER>, + <&clks IMX6QDL_CLK_GPT_3M>; + clock-names = "ipg", "per", "osc_per"; + }; + + gpio1: gpio@0209c000 { + compatible = "fsl,imx6q-gpio", "fsl,imx35-gpio"; + reg = <0x0209c000 0x4000>; + interrupts = <0 66 IRQ_TYPE_LEVEL_HIGH>, + <0 67 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio2: gpio@020a0000 { + compatible = "fsl,imx6q-gpio", "fsl,imx35-gpio"; + reg = <0x020a0000 0x4000>; + interrupts = <0 68 IRQ_TYPE_LEVEL_HIGH>, + <0 69 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio3: gpio@020a4000 { + compatible = "fsl,imx6q-gpio", "fsl,imx35-gpio"; + reg = <0x020a4000 0x4000>; + interrupts = <0 70 IRQ_TYPE_LEVEL_HIGH>, + <0 71 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio4: gpio@020a8000 { + compatible = "fsl,imx6q-gpio", "fsl,imx35-gpio"; + reg = <0x020a8000 0x4000>; + interrupts = <0 72 IRQ_TYPE_LEVEL_HIGH>, + <0 73 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio5: gpio@020ac000 { + compatible = "fsl,imx6q-gpio", "fsl,imx35-gpio"; + reg = <0x020ac000 0x4000>; + interrupts = <0 74 IRQ_TYPE_LEVEL_HIGH>, + <0 75 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio6: gpio@020b0000 { + compatible = "fsl,imx6q-gpio", "fsl,imx35-gpio"; + reg = <0x020b0000 0x4000>; + interrupts = <0 76 IRQ_TYPE_LEVEL_HIGH>, + <0 77 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio7: gpio@020b4000 { + compatible = "fsl,imx6q-gpio", "fsl,imx35-gpio"; + reg = <0x020b4000 0x4000>; + interrupts = <0 78 IRQ_TYPE_LEVEL_HIGH>, + <0 79 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + kpp: kpp@020b8000 { + compatible = "fsl,imx6q-kpp", "fsl,imx21-kpp"; + reg = <0x020b8000 0x4000>; + interrupts = <0 82 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_IPG>; + status = "disabled"; + }; + + wdog1: wdog@020bc000 { + compatible = "fsl,imx6q-wdt", "fsl,imx21-wdt"; + reg = <0x020bc000 0x4000>; + interrupts = <0 80 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_DUMMY>; + }; + + wdog2: wdog@020c0000 { + compatible = "fsl,imx6q-wdt", "fsl,imx21-wdt"; + reg = <0x020c0000 0x4000>; + interrupts = <0 81 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_DUMMY>; + status = "disabled"; + }; + + clks: ccm@020c4000 { + compatible = "fsl,imx6q-ccm"; + reg = <0x020c4000 0x4000>; + interrupts = <0 87 IRQ_TYPE_LEVEL_HIGH>, + <0 88 IRQ_TYPE_LEVEL_HIGH>; + #clock-cells = <1>; + }; + + anatop: anatop@020c8000 { + compatible = "fsl,imx6q-anatop", "syscon", "simple-bus"; + reg = <0x020c8000 0x1000>; + interrupts = <0 49 IRQ_TYPE_LEVEL_HIGH>, + <0 54 IRQ_TYPE_LEVEL_HIGH>, + <0 127 IRQ_TYPE_LEVEL_HIGH>; + + regulator-1p1@110 { + compatible = "fsl,anatop-regulator"; + regulator-name = "vdd1p1"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1375000>; + regulator-always-on; + anatop-reg-offset = <0x110>; + anatop-vol-bit-shift = <8>; + anatop-vol-bit-width = <5>; + anatop-min-bit-val = <4>; + anatop-min-voltage = <800000>; + anatop-max-voltage = <1375000>; + }; + + regulator-3p0@120 { + compatible = "fsl,anatop-regulator"; + regulator-name = "vdd3p0"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <3150000>; + regulator-always-on; + anatop-reg-offset = <0x120>; + anatop-vol-bit-shift = <8>; + anatop-vol-bit-width = <5>; + anatop-min-bit-val = <0>; + anatop-min-voltage = <2625000>; + anatop-max-voltage = <3400000>; + }; + + regulator-2p5@130 { + compatible = "fsl,anatop-regulator"; + regulator-name = "vdd2p5"; + regulator-min-microvolt = <2000000>; + regulator-max-microvolt = <2750000>; + regulator-always-on; + anatop-reg-offset = <0x130>; + anatop-vol-bit-shift = <8>; + anatop-vol-bit-width = <5>; + anatop-min-bit-val = <0>; + anatop-min-voltage = <2000000>; + anatop-max-voltage = <2750000>; + }; + + reg_arm: regulator-vddcore@140 { + compatible = "fsl,anatop-regulator"; + regulator-name = "vddarm"; + regulator-min-microvolt = <725000>; + regulator-max-microvolt = <1450000>; + regulator-always-on; + anatop-reg-offset = <0x140>; + anatop-vol-bit-shift = <0>; + anatop-vol-bit-width = <5>; + anatop-delay-reg-offset = <0x170>; + anatop-delay-bit-shift = <24>; + anatop-delay-bit-width = <2>; + anatop-min-bit-val = <1>; + anatop-min-voltage = <725000>; + anatop-max-voltage = <1450000>; + }; + + reg_pu: regulator-vddpu@140 { + compatible = "fsl,anatop-regulator"; + regulator-name = "vddpu"; + regulator-min-microvolt = <725000>; + regulator-max-microvolt = <1450000>; + regulator-enable-ramp-delay = <150>; + anatop-reg-offset = <0x140>; + anatop-vol-bit-shift = <9>; + anatop-vol-bit-width = <5>; + anatop-delay-reg-offset = <0x170>; + anatop-delay-bit-shift = <26>; + anatop-delay-bit-width = <2>; + anatop-min-bit-val = <1>; + anatop-min-voltage = <725000>; + anatop-max-voltage = <1450000>; + }; + + reg_soc: regulator-vddsoc@140 { + compatible = "fsl,anatop-regulator"; + regulator-name = "vddsoc"; + regulator-min-microvolt = <725000>; + regulator-max-microvolt = <1450000>; + regulator-always-on; + anatop-reg-offset = <0x140>; + anatop-vol-bit-shift = <18>; + anatop-vol-bit-width = <5>; + anatop-delay-reg-offset = <0x170>; + anatop-delay-bit-shift = <28>; + anatop-delay-bit-width = <2>; + anatop-min-bit-val = <1>; + anatop-min-voltage = <725000>; + anatop-max-voltage = <1450000>; + }; + }; + + tempmon: tempmon { + compatible = "fsl,imx6q-tempmon"; + interrupts = <0 49 IRQ_TYPE_LEVEL_HIGH>; + fsl,tempmon = <&anatop>; + fsl,tempmon-data = <&ocotp>; + clocks = <&clks IMX6QDL_CLK_PLL3_USB_OTG>; + }; + + usbphy1: usbphy@020c9000 { + compatible = "fsl,imx6q-usbphy", "fsl,imx23-usbphy"; + reg = <0x020c9000 0x1000>; + interrupts = <0 44 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_USBPHY1>; + fsl,anatop = <&anatop>; + }; + + usbphy2: usbphy@020ca000 { + compatible = "fsl,imx6q-usbphy", "fsl,imx23-usbphy"; + reg = <0x020ca000 0x1000>; + interrupts = <0 45 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_USBPHY2>; + fsl,anatop = <&anatop>; + }; + + snvs: snvs@020cc000 { + compatible = "fsl,sec-v4.0-mon", "syscon", "simple-mfd"; + reg = <0x020cc000 0x4000>; + + snvs_rtc: snvs-rtc-lp { + compatible = "fsl,sec-v4.0-mon-rtc-lp"; + regmap = <&snvs>; + offset = <0x34>; + interrupts = <0 19 IRQ_TYPE_LEVEL_HIGH>, + <0 20 IRQ_TYPE_LEVEL_HIGH>; + }; + + snvs_poweroff: snvs-poweroff { + compatible = "syscon-poweroff"; + regmap = <&snvs>; + offset = <0x38>; + mask = <0x60>; + status = "disabled"; + }; + }; + + epit1: epit@020d0000 { /* EPIT1 */ + reg = <0x020d0000 0x4000>; + interrupts = <0 56 IRQ_TYPE_LEVEL_HIGH>; + }; + + epit2: epit@020d4000 { /* EPIT2 */ + reg = <0x020d4000 0x4000>; + interrupts = <0 57 IRQ_TYPE_LEVEL_HIGH>; + }; + + src: src@020d8000 { + compatible = "fsl,imx6q-src", "fsl,imx51-src"; + reg = <0x020d8000 0x4000>; + interrupts = <0 91 IRQ_TYPE_LEVEL_HIGH>, + <0 96 IRQ_TYPE_LEVEL_HIGH>; + #reset-cells = <1>; + }; + + gpc: gpc@020dc000 { + compatible = "fsl,imx6q-gpc"; + reg = <0x020dc000 0x4000>; + interrupt-controller; + #interrupt-cells = <3>; + interrupts = <0 89 IRQ_TYPE_LEVEL_HIGH>, + <0 90 IRQ_TYPE_LEVEL_HIGH>; + interrupt-parent = <&intc>; + pu-supply = <®_pu>; + clocks = <&clks IMX6QDL_CLK_GPU3D_CORE>, + <&clks IMX6QDL_CLK_GPU3D_SHADER>, + <&clks IMX6QDL_CLK_GPU2D_CORE>, + <&clks IMX6QDL_CLK_GPU2D_AXI>, + <&clks IMX6QDL_CLK_OPENVG_AXI>, + <&clks IMX6QDL_CLK_VPU_AXI>; + #power-domain-cells = <1>; + }; + + gpr: iomuxc-gpr@020e0000 { + compatible = "fsl,imx6q-iomuxc-gpr", "syscon"; + reg = <0x020e0000 0x38>; + }; + + iomuxc: iomuxc@020e0000 { + compatible = "fsl,imx6dl-iomuxc", "fsl,imx6q-iomuxc"; + reg = <0x020e0000 0x4000>; + }; + + ldb: ldb@020e0008 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx6q-ldb", "fsl,imx53-ldb"; + gpr = <&gpr>; + status = "disabled"; + + lvds-channel@0 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0>; + status = "disabled"; + + port@0 { + reg = <0>; + + lvds0_mux_0: endpoint { + remote-endpoint = <&ipu1_di0_lvds0>; + }; + }; + + port@1 { + reg = <1>; + + lvds0_mux_1: endpoint { + remote-endpoint = <&ipu1_di1_lvds0>; + }; + }; + }; + + lvds-channel@1 { + #address-cells = <1>; + #size-cells = <0>; + reg = <1>; + status = "disabled"; + + port@0 { + reg = <0>; + + lvds1_mux_0: endpoint { + remote-endpoint = <&ipu1_di0_lvds1>; + }; + }; + + port@1 { + reg = <1>; + + lvds1_mux_1: endpoint { + remote-endpoint = <&ipu1_di1_lvds1>; + }; + }; + }; + }; + + dcic1: dcic@020e4000 { + reg = <0x020e4000 0x4000>; + interrupts = <0 124 IRQ_TYPE_LEVEL_HIGH>; + }; + + dcic2: dcic@020e8000 { + reg = <0x020e8000 0x4000>; + interrupts = <0 125 IRQ_TYPE_LEVEL_HIGH>; + }; + + sdma: sdma@020ec000 { + compatible = "fsl,imx6q-sdma", "fsl,imx35-sdma"; + reg = <0x020ec000 0x4000>; + interrupts = <0 2 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_SDMA>, + <&clks IMX6QDL_CLK_SDMA>; + clock-names = "ipg", "ahb"; + #dma-cells = <3>; + fsl,sdma-ram-script-name = "imx/sdma/sdma-imx6q.bin"; + }; + }; + + aips-bus@02100000 { /* AIPS2 */ + compatible = "fsl,aips-bus", "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x02100000 0x100000>; + ranges; + + crypto: caam@2100000 { + compatible = "fsl,sec-v4.0"; + fsl,sec-era = <4>; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x2100000 0x10000>; + ranges = <0 0x2100000 0x10000>; + interrupt-parent = <&intc>; + clocks = <&clks IMX6QDL_CLK_CAAM_MEM>, + <&clks IMX6QDL_CLK_CAAM_ACLK>, + <&clks IMX6QDL_CLK_CAAM_IPG>, + <&clks IMX6QDL_CLK_EIM_SLOW>; + clock-names = "mem", "aclk", "ipg", "emi_slow"; + + sec_jr0: jr0@1000 { + compatible = "fsl,sec-v4.0-job-ring"; + reg = <0x1000 0x1000>; + interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; + }; + + sec_jr1: jr1@2000 { + compatible = "fsl,sec-v4.0-job-ring"; + reg = <0x2000 0x1000>; + interrupts = <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + aipstz@0217c000 { /* AIPSTZ2 */ + reg = <0x0217c000 0x4000>; + }; + + usbotg: usb@02184000 { + compatible = "fsl,imx6q-usb", "fsl,imx27-usb"; + reg = <0x02184000 0x200>; + interrupts = <0 43 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_USBOH3>; + fsl,usbphy = <&usbphy1>; + fsl,usbmisc = <&usbmisc 0>; + status = "disabled"; + }; + + usbh1: usb@02184200 { + compatible = "fsl,imx6q-usb", "fsl,imx27-usb"; + reg = <0x02184200 0x200>; + interrupts = <0 40 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_USBOH3>; + fsl,usbphy = <&usbphy2>; + fsl,usbmisc = <&usbmisc 1>; + dr_mode = "host"; + status = "disabled"; + }; + + usbh2: usb@02184400 { + compatible = "fsl,imx6q-usb", "fsl,imx27-usb"; + reg = <0x02184400 0x200>; + interrupts = <0 41 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_USBOH3>; + fsl,usbmisc = <&usbmisc 2>; + dr_mode = "host"; + status = "disabled"; + }; + + usbh3: usb@02184600 { + compatible = "fsl,imx6q-usb", "fsl,imx27-usb"; + reg = <0x02184600 0x200>; + interrupts = <0 42 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_USBOH3>; + fsl,usbmisc = <&usbmisc 3>; + dr_mode = "host"; + status = "disabled"; + }; + + usbmisc: usbmisc@02184800 { + #index-cells = <1>; + compatible = "fsl,imx6q-usbmisc"; + reg = <0x02184800 0x200>; + clocks = <&clks IMX6QDL_CLK_USBOH3>; + }; + + fec: ethernet@02188000 { + compatible = "fsl,imx6q-fec"; + reg = <0x02188000 0x4000>; + interrupts-extended = + <&intc 0 118 IRQ_TYPE_LEVEL_HIGH>, + <&intc 0 119 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_ENET>, + <&clks IMX6QDL_CLK_ENET>, + <&clks IMX6QDL_CLK_ENET_REF>; + clock-names = "ipg", "ahb", "ptp"; + status = "disabled"; + }; + + mlb@0218c000 { + reg = <0x0218c000 0x4000>; + interrupts = <0 53 IRQ_TYPE_LEVEL_HIGH>, + <0 117 IRQ_TYPE_LEVEL_HIGH>, + <0 126 IRQ_TYPE_LEVEL_HIGH>; + }; + + usdhc1: usdhc@02190000 { + compatible = "fsl,imx6q-usdhc"; + reg = <0x02190000 0x4000>; + interrupts = <0 22 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_USDHC1>, + <&clks IMX6QDL_CLK_USDHC1>, + <&clks IMX6QDL_CLK_USDHC1>; + clock-names = "ipg", "ahb", "per"; + bus-width = <4>; + status = "disabled"; + }; + + usdhc2: usdhc@02194000 { + compatible = "fsl,imx6q-usdhc"; + reg = <0x02194000 0x4000>; + interrupts = <0 23 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_USDHC2>, + <&clks IMX6QDL_CLK_USDHC2>, + <&clks IMX6QDL_CLK_USDHC2>; + clock-names = "ipg", "ahb", "per"; + bus-width = <4>; + status = "disabled"; + }; + + usdhc3: usdhc@02198000 { + compatible = "fsl,imx6q-usdhc"; + reg = <0x02198000 0x4000>; + interrupts = <0 24 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_USDHC3>, + <&clks IMX6QDL_CLK_USDHC3>, + <&clks IMX6QDL_CLK_USDHC3>; + clock-names = "ipg", "ahb", "per"; + bus-width = <4>; + status = "disabled"; + }; + + usdhc4: usdhc@0219c000 { + compatible = "fsl,imx6q-usdhc"; + reg = <0x0219c000 0x4000>; + interrupts = <0 25 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_USDHC4>, + <&clks IMX6QDL_CLK_USDHC4>, + <&clks IMX6QDL_CLK_USDHC4>; + clock-names = "ipg", "ahb", "per"; + bus-width = <4>; + status = "disabled"; + }; + + i2c1: i2c@021a0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx6q-i2c", "fsl,imx21-i2c"; + reg = <0x021a0000 0x4000>; + interrupts = <0 36 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_I2C1>; + status = "disabled"; + }; + + i2c2: i2c@021a4000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx6q-i2c", "fsl,imx21-i2c"; + reg = <0x021a4000 0x4000>; + interrupts = <0 37 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_I2C2>; + status = "disabled"; + }; + + i2c3: i2c@021a8000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx6q-i2c", "fsl,imx21-i2c"; + reg = <0x021a8000 0x4000>; + interrupts = <0 38 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_I2C3>; + status = "disabled"; + }; + + romcp@021ac000 { + reg = <0x021ac000 0x4000>; + }; + + mmdc0: mmdc@021b0000 { /* MMDC0 */ + compatible = "fsl,imx6q-mmdc"; + reg = <0x021b0000 0x4000>; + }; + + mmdc1: mmdc@021b4000 { /* MMDC1 */ + reg = <0x021b4000 0x4000>; + }; + + weim: weim@021b8000 { + compatible = "fsl,imx6q-weim"; + reg = <0x021b8000 0x4000>; + interrupts = <0 14 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_EIM_SLOW>; + }; + + ocotp: ocotp@021bc000 { + compatible = "fsl,imx6q-ocotp", "syscon"; + reg = <0x021bc000 0x4000>; + }; + + tzasc@021d0000 { /* TZASC1 */ + reg = <0x021d0000 0x4000>; + interrupts = <0 108 IRQ_TYPE_LEVEL_HIGH>; + }; + + tzasc@021d4000 { /* TZASC2 */ + reg = <0x021d4000 0x4000>; + interrupts = <0 109 IRQ_TYPE_LEVEL_HIGH>; + }; + + audmux: audmux@021d8000 { + compatible = "fsl,imx6q-audmux", "fsl,imx31-audmux"; + reg = <0x021d8000 0x4000>; + status = "disabled"; + }; + + mipi_csi: mipi@021dc000 { + reg = <0x021dc000 0x4000>; + }; + + mipi_dsi: mipi@021e0000 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x021e0000 0x4000>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + mipi_mux_0: endpoint { + remote-endpoint = <&ipu1_di0_mipi>; + }; + }; + + port@1 { + reg = <1>; + + mipi_mux_1: endpoint { + remote-endpoint = <&ipu1_di1_mipi>; + }; + }; + }; + }; + + vdoa@021e4000 { + reg = <0x021e4000 0x4000>; + interrupts = <0 18 IRQ_TYPE_LEVEL_HIGH>; + }; + + uart2: serial@021e8000 { + compatible = "fsl,imx6q-uart", "fsl,imx21-uart"; + reg = <0x021e8000 0x4000>; + interrupts = <0 27 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_UART_IPG>, + <&clks IMX6QDL_CLK_UART_SERIAL>; + clock-names = "ipg", "per"; + dmas = <&sdma 27 4 0>, <&sdma 28 4 0>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + uart3: serial@021ec000 { + compatible = "fsl,imx6q-uart", "fsl,imx21-uart"; + reg = <0x021ec000 0x4000>; + interrupts = <0 28 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_UART_IPG>, + <&clks IMX6QDL_CLK_UART_SERIAL>; + clock-names = "ipg", "per"; + dmas = <&sdma 29 4 0>, <&sdma 30 4 0>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + uart4: serial@021f0000 { + compatible = "fsl,imx6q-uart", "fsl,imx21-uart"; + reg = <0x021f0000 0x4000>; + interrupts = <0 29 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_UART_IPG>, + <&clks IMX6QDL_CLK_UART_SERIAL>; + clock-names = "ipg", "per"; + dmas = <&sdma 31 4 0>, <&sdma 32 4 0>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + uart5: serial@021f4000 { + compatible = "fsl,imx6q-uart", "fsl,imx21-uart"; + reg = <0x021f4000 0x4000>; + interrupts = <0 30 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_UART_IPG>, + <&clks IMX6QDL_CLK_UART_SERIAL>; + clock-names = "ipg", "per"; + dmas = <&sdma 33 4 0>, <&sdma 34 4 0>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + }; + + ipu1: ipu@02400000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx6q-ipu"; + reg = <0x02400000 0x400000>; + interrupts = <0 6 IRQ_TYPE_LEVEL_HIGH>, + <0 5 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_IPU1>, + <&clks IMX6QDL_CLK_IPU1_DI0>, + <&clks IMX6QDL_CLK_IPU1_DI1>; + clock-names = "bus", "di0", "di1"; + resets = <&src 2>; + + ipu1_csi0: port@0 { + reg = <0>; + }; + + ipu1_csi1: port@1 { + reg = <1>; + }; + + ipu1_di0: port@2 { + #address-cells = <1>; + #size-cells = <0>; + reg = <2>; + + ipu1_di0_disp0: endpoint@0 { + }; + + ipu1_di0_hdmi: endpoint@1 { + remote-endpoint = <&hdmi_mux_0>; + }; + + ipu1_di0_mipi: endpoint@2 { + remote-endpoint = <&mipi_mux_0>; + }; + + ipu1_di0_lvds0: endpoint@3 { + remote-endpoint = <&lvds0_mux_0>; + }; + + ipu1_di0_lvds1: endpoint@4 { + remote-endpoint = <&lvds1_mux_0>; + }; + }; + + ipu1_di1: port@3 { + #address-cells = <1>; + #size-cells = <0>; + reg = <3>; + + ipu1_di0_disp1: endpoint@0 { + }; + + ipu1_di1_hdmi: endpoint@1 { + remote-endpoint = <&hdmi_mux_1>; + }; + + ipu1_di1_mipi: endpoint@2 { + remote-endpoint = <&mipi_mux_1>; + }; + + ipu1_di1_lvds0: endpoint@3 { + remote-endpoint = <&lvds0_mux_1>; + }; + + ipu1_di1_lvds1: endpoint@4 { + remote-endpoint = <&lvds1_mux_1>; + }; + }; + }; + }; +}; diff --git a/include/dt-bindings/clock/imx6qdl-clock.h b/include/dt-bindings/clock/imx6qdl-clock.h new file mode 100644 index 0000000..77985cc --- /dev/null +++ b/include/dt-bindings/clock/imx6qdl-clock.h @@ -0,0 +1,260 @@ +/* + * Copyright 2014 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +#ifndef __DT_BINDINGS_CLOCK_IMX6QDL_H +#define __DT_BINDINGS_CLOCK_IMX6QDL_H + +#define IMX6QDL_CLK_DUMMY 0 +#define IMX6QDL_CLK_CKIL 1 +#define IMX6QDL_CLK_CKIH 2 +#define IMX6QDL_CLK_OSC 3 +#define IMX6QDL_CLK_PLL2_PFD0_352M 4 +#define IMX6QDL_CLK_PLL2_PFD1_594M 5 +#define IMX6QDL_CLK_PLL2_PFD2_396M 6 +#define IMX6QDL_CLK_PLL3_PFD0_720M 7 +#define IMX6QDL_CLK_PLL3_PFD1_540M 8 +#define IMX6QDL_CLK_PLL3_PFD2_508M 9 +#define IMX6QDL_CLK_PLL3_PFD3_454M 10 +#define IMX6QDL_CLK_PLL2_198M 11 +#define IMX6QDL_CLK_PLL3_120M 12 +#define IMX6QDL_CLK_PLL3_80M 13 +#define IMX6QDL_CLK_PLL3_60M 14 +#define IMX6QDL_CLK_TWD 15 +#define IMX6QDL_CLK_STEP 16 +#define IMX6QDL_CLK_PLL1_SW 17 +#define IMX6QDL_CLK_PERIPH_PRE 18 +#define IMX6QDL_CLK_PERIPH2_PRE 19 +#define IMX6QDL_CLK_PERIPH_CLK2_SEL 20 +#define IMX6QDL_CLK_PERIPH2_CLK2_SEL 21 +#define IMX6QDL_CLK_AXI_SEL 22 +#define IMX6QDL_CLK_ESAI_SEL 23 +#define IMX6QDL_CLK_ASRC_SEL 24 +#define IMX6QDL_CLK_SPDIF_SEL 25 +#define IMX6QDL_CLK_GPU2D_AXI 26 +#define IMX6QDL_CLK_GPU3D_AXI 27 +#define IMX6QDL_CLK_GPU2D_CORE_SEL 28 +#define IMX6QDL_CLK_GPU3D_CORE_SEL 29 +#define IMX6QDL_CLK_GPU3D_SHADER_SEL 30 +#define IMX6QDL_CLK_IPU1_SEL 31 +#define IMX6QDL_CLK_IPU2_SEL 32 +#define IMX6QDL_CLK_LDB_DI0_SEL 33 +#define IMX6QDL_CLK_LDB_DI1_SEL 34 +#define IMX6QDL_CLK_IPU1_DI0_PRE_SEL 35 +#define IMX6QDL_CLK_IPU1_DI1_PRE_SEL 36 +#define IMX6QDL_CLK_IPU2_DI0_PRE_SEL 37 +#define IMX6QDL_CLK_IPU2_DI1_PRE_SEL 38 +#define IMX6QDL_CLK_IPU1_DI0_SEL 39 +#define IMX6QDL_CLK_IPU1_DI1_SEL 40 +#define IMX6QDL_CLK_IPU2_DI0_SEL 41 +#define IMX6QDL_CLK_IPU2_DI1_SEL 42 +#define IMX6QDL_CLK_HSI_TX_SEL 43 +#define IMX6QDL_CLK_PCIE_AXI_SEL 44 +#define IMX6QDL_CLK_SSI1_SEL 45 +#define IMX6QDL_CLK_SSI2_SEL 46 +#define IMX6QDL_CLK_SSI3_SEL 47 +#define IMX6QDL_CLK_USDHC1_SEL 48 +#define IMX6QDL_CLK_USDHC2_SEL 49 +#define IMX6QDL_CLK_USDHC3_SEL 50 +#define IMX6QDL_CLK_USDHC4_SEL 51 +#define IMX6QDL_CLK_ENFC_SEL 52 +#define IMX6QDL_CLK_EIM_SEL 53 +#define IMX6QDL_CLK_EIM_SLOW_SEL 54 +#define IMX6QDL_CLK_VDO_AXI_SEL 55 +#define IMX6QDL_CLK_VPU_AXI_SEL 56 +#define IMX6QDL_CLK_CKO1_SEL 57 +#define IMX6QDL_CLK_PERIPH 58 +#define IMX6QDL_CLK_PERIPH2 59 +#define IMX6QDL_CLK_PERIPH_CLK2 60 +#define IMX6QDL_CLK_PERIPH2_CLK2 61 +#define IMX6QDL_CLK_IPG 62 +#define IMX6QDL_CLK_IPG_PER 63 +#define IMX6QDL_CLK_ESAI_PRED 64 +#define IMX6QDL_CLK_ESAI_PODF 65 +#define IMX6QDL_CLK_ASRC_PRED 66 +#define IMX6QDL_CLK_ASRC_PODF 67 +#define IMX6QDL_CLK_SPDIF_PRED 68 +#define IMX6QDL_CLK_SPDIF_PODF 69 +#define IMX6QDL_CLK_CAN_ROOT 70 +#define IMX6QDL_CLK_ECSPI_ROOT 71 +#define IMX6QDL_CLK_GPU2D_CORE_PODF 72 +#define IMX6QDL_CLK_GPU3D_CORE_PODF 73 +#define IMX6QDL_CLK_GPU3D_SHADER 74 +#define IMX6QDL_CLK_IPU1_PODF 75 +#define IMX6QDL_CLK_IPU2_PODF 76 +#define IMX6QDL_CLK_LDB_DI0_PODF 77 +#define IMX6QDL_CLK_LDB_DI1_PODF 78 +#define IMX6QDL_CLK_IPU1_DI0_PRE 79 +#define IMX6QDL_CLK_IPU1_DI1_PRE 80 +#define IMX6QDL_CLK_IPU2_DI0_PRE 81 +#define IMX6QDL_CLK_IPU2_DI1_PRE 82 +#define IMX6QDL_CLK_HSI_TX_PODF 83 +#define IMX6QDL_CLK_SSI1_PRED 84 +#define IMX6QDL_CLK_SSI1_PODF 85 +#define IMX6QDL_CLK_SSI2_PRED 86 +#define IMX6QDL_CLK_SSI2_PODF 87 +#define IMX6QDL_CLK_SSI3_PRED 88 +#define IMX6QDL_CLK_SSI3_PODF 89 +#define IMX6QDL_CLK_UART_SERIAL_PODF 90 +#define IMX6QDL_CLK_USDHC1_PODF 91 +#define IMX6QDL_CLK_USDHC2_PODF 92 +#define IMX6QDL_CLK_USDHC3_PODF 93 +#define IMX6QDL_CLK_USDHC4_PODF 94 +#define IMX6QDL_CLK_ENFC_PRED 95 +#define IMX6QDL_CLK_ENFC_PODF 96 +#define IMX6QDL_CLK_EIM_PODF 97 +#define IMX6QDL_CLK_EIM_SLOW_PODF 98 +#define IMX6QDL_CLK_VPU_AXI_PODF 99 +#define IMX6QDL_CLK_CKO1_PODF 100 +#define IMX6QDL_CLK_AXI 101 +#define IMX6QDL_CLK_MMDC_CH0_AXI_PODF 102 +#define IMX6QDL_CLK_MMDC_CH1_AXI_PODF 103 +#define IMX6QDL_CLK_ARM 104 +#define IMX6QDL_CLK_AHB 105 +#define IMX6QDL_CLK_APBH_DMA 106 +#define IMX6QDL_CLK_ASRC 107 +#define IMX6QDL_CLK_CAN1_IPG 108 +#define IMX6QDL_CLK_CAN1_SERIAL 109 +#define IMX6QDL_CLK_CAN2_IPG 110 +#define IMX6QDL_CLK_CAN2_SERIAL 111 +#define IMX6QDL_CLK_ECSPI1 112 +#define IMX6QDL_CLK_ECSPI2 113 +#define IMX6QDL_CLK_ECSPI3 114 +#define IMX6QDL_CLK_ECSPI4 115 +#define IMX6Q_CLK_ECSPI5 116 +#define IMX6DL_CLK_I2C4 116 +#define IMX6QDL_CLK_ENET 117 +#define IMX6QDL_CLK_ESAI_EXTAL 118 +#define IMX6QDL_CLK_GPT_IPG 119 +#define IMX6QDL_CLK_GPT_IPG_PER 120 +#define IMX6QDL_CLK_GPU2D_CORE 121 +#define IMX6QDL_CLK_GPU3D_CORE 122 +#define IMX6QDL_CLK_HDMI_IAHB 123 +#define IMX6QDL_CLK_HDMI_ISFR 124 +#define IMX6QDL_CLK_I2C1 125 +#define IMX6QDL_CLK_I2C2 126 +#define IMX6QDL_CLK_I2C3 127 +#define IMX6QDL_CLK_IIM 128 +#define IMX6QDL_CLK_ENFC 129 +#define IMX6QDL_CLK_IPU1 130 +#define IMX6QDL_CLK_IPU1_DI0 131 +#define IMX6QDL_CLK_IPU1_DI1 132 +#define IMX6QDL_CLK_IPU2 133 +#define IMX6QDL_CLK_IPU2_DI0 134 +#define IMX6QDL_CLK_LDB_DI0 135 +#define IMX6QDL_CLK_LDB_DI1 136 +#define IMX6QDL_CLK_IPU2_DI1 137 +#define IMX6QDL_CLK_HSI_TX 138 +#define IMX6QDL_CLK_MLB 139 +#define IMX6QDL_CLK_MMDC_CH0_AXI 140 +#define IMX6QDL_CLK_MMDC_CH1_AXI 141 +#define IMX6QDL_CLK_OCRAM 142 +#define IMX6QDL_CLK_OPENVG_AXI 143 +#define IMX6QDL_CLK_PCIE_AXI 144 +#define IMX6QDL_CLK_PWM1 145 +#define IMX6QDL_CLK_PWM2 146 +#define IMX6QDL_CLK_PWM3 147 +#define IMX6QDL_CLK_PWM4 148 +#define IMX6QDL_CLK_PER1_BCH 149 +#define IMX6QDL_CLK_GPMI_BCH_APB 150 +#define IMX6QDL_CLK_GPMI_BCH 151 +#define IMX6QDL_CLK_GPMI_IO 152 +#define IMX6QDL_CLK_GPMI_APB 153 +#define IMX6QDL_CLK_SATA 154 +#define IMX6QDL_CLK_SDMA 155 +#define IMX6QDL_CLK_SPBA 156 +#define IMX6QDL_CLK_SSI1 157 +#define IMX6QDL_CLK_SSI2 158 +#define IMX6QDL_CLK_SSI3 159 +#define IMX6QDL_CLK_UART_IPG 160 +#define IMX6QDL_CLK_UART_SERIAL 161 +#define IMX6QDL_CLK_USBOH3 162 +#define IMX6QDL_CLK_USDHC1 163 +#define IMX6QDL_CLK_USDHC2 164 +#define IMX6QDL_CLK_USDHC3 165 +#define IMX6QDL_CLK_USDHC4 166 +#define IMX6QDL_CLK_VDO_AXI 167 +#define IMX6QDL_CLK_VPU_AXI 168 +#define IMX6QDL_CLK_CKO1 169 +#define IMX6QDL_CLK_PLL1_SYS 170 +#define IMX6QDL_CLK_PLL2_BUS 171 +#define IMX6QDL_CLK_PLL3_USB_OTG 172 +#define IMX6QDL_CLK_PLL4_AUDIO 173 +#define IMX6QDL_CLK_PLL5_VIDEO 174 +#define IMX6QDL_CLK_PLL8_MLB 175 +#define IMX6QDL_CLK_PLL7_USB_HOST 176 +#define IMX6QDL_CLK_PLL6_ENET 177 +#define IMX6QDL_CLK_SSI1_IPG 178 +#define IMX6QDL_CLK_SSI2_IPG 179 +#define IMX6QDL_CLK_SSI3_IPG 180 +#define IMX6QDL_CLK_ROM 181 +#define IMX6QDL_CLK_USBPHY1 182 +#define IMX6QDL_CLK_USBPHY2 183 +#define IMX6QDL_CLK_LDB_DI0_DIV_3_5 184 +#define IMX6QDL_CLK_LDB_DI1_DIV_3_5 185 +#define IMX6QDL_CLK_SATA_REF 186 +#define IMX6QDL_CLK_SATA_REF_100M 187 +#define IMX6QDL_CLK_PCIE_REF 188 +#define IMX6QDL_CLK_PCIE_REF_125M 189 +#define IMX6QDL_CLK_ENET_REF 190 +#define IMX6QDL_CLK_USBPHY1_GATE 191 +#define IMX6QDL_CLK_USBPHY2_GATE 192 +#define IMX6QDL_CLK_PLL4_POST_DIV 193 +#define IMX6QDL_CLK_PLL5_POST_DIV 194 +#define IMX6QDL_CLK_PLL5_VIDEO_DIV 195 +#define IMX6QDL_CLK_EIM_SLOW 196 +#define IMX6QDL_CLK_SPDIF 197 +#define IMX6QDL_CLK_CKO2_SEL 198 +#define IMX6QDL_CLK_CKO2_PODF 199 +#define IMX6QDL_CLK_CKO2 200 +#define IMX6QDL_CLK_CKO 201 +#define IMX6QDL_CLK_VDOA 202 +#define IMX6QDL_CLK_PLL4_AUDIO_DIV 203 +#define IMX6QDL_CLK_LVDS1_SEL 204 +#define IMX6QDL_CLK_LVDS2_SEL 205 +#define IMX6QDL_CLK_LVDS1_GATE 206 +#define IMX6QDL_CLK_LVDS2_GATE 207 +#define IMX6QDL_CLK_ESAI_IPG 208 +#define IMX6QDL_CLK_ESAI_MEM 209 +#define IMX6QDL_CLK_ASRC_IPG 210 +#define IMX6QDL_CLK_ASRC_MEM 211 +#define IMX6QDL_CLK_LVDS1_IN 212 +#define IMX6QDL_CLK_LVDS2_IN 213 +#define IMX6QDL_CLK_ANACLK1 214 +#define IMX6QDL_CLK_ANACLK2 215 +#define IMX6QDL_PLL1_BYPASS_SRC 216 +#define IMX6QDL_PLL2_BYPASS_SRC 217 +#define IMX6QDL_PLL3_BYPASS_SRC 218 +#define IMX6QDL_PLL4_BYPASS_SRC 219 +#define IMX6QDL_PLL5_BYPASS_SRC 220 +#define IMX6QDL_PLL6_BYPASS_SRC 221 +#define IMX6QDL_PLL7_BYPASS_SRC 222 +#define IMX6QDL_CLK_PLL1 223 +#define IMX6QDL_CLK_PLL2 224 +#define IMX6QDL_CLK_PLL3 225 +#define IMX6QDL_CLK_PLL4 226 +#define IMX6QDL_CLK_PLL5 227 +#define IMX6QDL_CLK_PLL6 228 +#define IMX6QDL_CLK_PLL7 229 +#define IMX6QDL_PLL1_BYPASS 230 +#define IMX6QDL_PLL2_BYPASS 231 +#define IMX6QDL_PLL3_BYPASS 232 +#define IMX6QDL_PLL4_BYPASS 233 +#define IMX6QDL_PLL5_BYPASS 234 +#define IMX6QDL_PLL6_BYPASS 235 +#define IMX6QDL_PLL7_BYPASS 236 +#define IMX6QDL_CLK_GPT_3M 237 +#define IMX6QDL_CLK_VIDEO_27M 238 +#define IMX6QDL_CLK_MIPI_CORE_CFG 239 +#define IMX6QDL_CLK_MIPI_IPG 240 +#define IMX6QDL_CLK_CAAM_MEM 241 +#define IMX6QDL_CLK_CAAM_ACLK 242 +#define IMX6QDL_CLK_CAAM_IPG 243 +#define IMX6QDL_CLK_SPDIF_GCLK 244 +#define IMX6QDL_CLK_END 245 + +#endif /* __DT_BINDINGS_CLOCK_IMX6QDL_H */
On 03/28/2016 10:26 AM, Eric Nelson wrote:
Copy device tree headers and include (.dtsi) files for i.MX6 Dual and Quad variants.
These are copied as-is from Linux stable (4.4.1).
This is the only patch in the set.
Sorry for not catching the "Patch 1/9" in the header.
I pulled this out of the tree I was working on for the block cache.
Hi York,
Could you test this patch for PPC and layerscape platform? Since I only test this on i.MX6 platform, I do not want to break PPC or else.
Thanks, Peng.
On Fri, Mar 25, 2016 at 02:16:56PM +0800, Peng Fan wrote:
Support Driver Model for fsl esdhc driver.
- Introduce a new structure struct fsl_esdhc_priv
- Refactor fsl_esdhc_initialize which is originally used by board code.
- Introduce fsl_esdhc_init to be common usage for DM and non-DM
- Introduce fsl_esdhc_cfg_to_priv to build the bridge for non-DM part.
- The original API for board code is still there, but we use 'fsl_esdhc_cfg_to_priv' and 'fsl_esdhc_init' to serve it.
- All the functions are changed to use 'struct fsl_esdhc_priv', except
fsl_esdhc_initialize. 4. Since clk driver is not implemented, use mxc_get_clock to geth the clk and fill 'priv->sdhc_clk'.
Has been tested on i.MX6UL 14X14 EVK board: " =>dm tree .... simple_bus [ + ] | `-- aips-bus@02100000 mmc [ + ] | |-- usdhc@02190000 mmc [ + ] | |-- usdhc@02194000 .... => mmc list FSL_SDHC: 0 (SD) FSL_SDHC: 1 (SD) "
Signed-off-by: Peng Fan van.freenix@gmail.com Cc: York Sun york.sun@nxp.com Cc: Yangbo Lu yangbo.lu@nxp.com Cc: Hector Palacios hector.palacios@digi.com Cc: Eric Nelson eric@nelint.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Pantelis Antoniou panto@antoniou-consulting.com Cc: Simon Glass sjg@chromium.org
V3: Fix build error reported by York for PPC.
V2: restructure the V1 patch. Introduce fsl_esdhc_priv structure. Introduce code to handle cd-gpios and non-removable.
drivers/mmc/fsl_esdhc.c | 253 ++++++++++++++++++++++++++++++++++++++++-------- 1 file changed, 213 insertions(+), 40 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index ea5f4bf..3acf9e8 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -20,6 +20,8 @@ #include <fsl_esdhc.h> #include <fdt_support.h> #include <asm/io.h> +#include <dm.h> +#include <asm-generic/gpio.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -72,6 +74,30 @@ struct fsl_esdhc { uint scr; /* eSDHC control register */ };
- struct fsl_esdhc_priv
- @esdhc_regs: registers of the sdhc controller
- @sdhc_clk: Current clk of the sdhc controller
- @bus_width: bus width, 1bit, 4bit or 8bit
- @cfg: mmc config
- @mmc: mmc
- Following is used when Driver Model is enabled for MMC
- @dev: pointer for the device
- @non_removable: 0: removable; 1: non-removable
- @cd_gpio: gpio for card detection
+struct fsl_esdhc_priv {
- struct fsl_esdhc *esdhc_regs;
- unsigned int sdhc_clk;
- unsigned int bus_width;
- struct mmc_config cfg;
- struct mmc *mmc;
- struct udevice *dev;
- int non_removable;
- struct gpio_desc cd_gpio;
/* Return the XFERTYP flags for a given command and data packet */ static uint esdhc_xfertyp(struct mmc_cmd *cmd, struct mmc_data *data) { @@ -118,8 +144,8 @@ static uint esdhc_xfertyp(struct mmc_cmd *cmd, struct mmc_data *data) static void esdhc_pio_read_write(struct mmc *mmc, struct mmc_data *data) {
- struct fsl_esdhc_cfg *cfg = mmc->priv;
- struct fsl_esdhc *regs = (struct fsl_esdhc *)cfg->esdhc_base;
- struct fsl_esdhc_priv *priv = mmc->priv;
- struct fsl_esdhc *regs = priv->esdhc_regs; uint blocks; char *buffer; uint databuf;
@@ -180,8 +206,8 @@ esdhc_pio_read_write(struct mmc *mmc, struct mmc_data *data) static int esdhc_setup_data(struct mmc *mmc, struct mmc_data *data) { int timeout;
#ifdef CONFIG_FSL_LAYERSCAPE dma_addr_t addr; #endif @@ -312,8 +338,8 @@ esdhc_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, struct mmc_data *data) int err = 0; uint xfertyp; uint irqstat;
- volatile struct fsl_esdhc *regs = (struct fsl_esdhc *)cfg->esdhc_base;
#ifdef CONFIG_SYS_FSL_ERRATUM_ESDHC111 if (cmd->cmdidx == MMC_CMD_STOP_TRANSMISSION) @@ -482,9 +508,9 @@ out: static void set_sysctl(struct mmc *mmc, uint clock) { int div, pre_div;
- int sdhc_clk = cfg->sdhc_clk;
int sdhc_clk = priv->sdhc_clk; uint clk;
if (clock < mmc->cfg->f_min)
@@ -527,8 +553,8 @@ static void set_sysctl(struct mmc *mmc, uint clock) #ifdef CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK static void esdhc_clock_control(struct mmc *mmc, bool enable) {
- struct fsl_esdhc *regs = priv->esdhc_regs; u32 value; u32 time_out;
@@ -556,8 +582,8 @@ static void esdhc_clock_control(struct mmc *mmc, bool enable)
static void esdhc_set_ios(struct mmc *mmc) {
#ifdef CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK /* Select to use peripheral clock */ @@ -580,8 +606,8 @@ static void esdhc_set_ios(struct mmc *mmc)
static int esdhc_init(struct mmc *mmc) {
struct fsl_esdhc *regs = priv->esdhc_regs; int timeout = 1000;
/* Reset the entire host controller */
@@ -621,14 +647,23 @@ static int esdhc_init(struct mmc *mmc)
static int esdhc_getcd(struct mmc *mmc) {
- struct fsl_esdhc *regs = priv->esdhc_regs; int timeout = 1000;
#ifdef CONFIG_ESDHC_DETECT_QUIRK if (CONFIG_ESDHC_DETECT_QUIRK) return 1; #endif
+#ifdef CONFIG_DM_MMC
- if (priv->non_removable)
return 1;
- if (dm_gpio_is_valid(&priv->cd_gpio))
return dm_gpio_get_value(&priv->cd_gpio);
- while (!(esdhc_read32(®s->prsstat) & PRSSTAT_CINS) && --timeout) udelay(1000);
@@ -656,16 +691,29 @@ static const struct mmc_ops esdhc_ops = { .getcd = esdhc_getcd, };
-int fsl_esdhc_initialize(bd_t *bis, struct fsl_esdhc_cfg *cfg) +static int fsl_esdhc_cfg_to_priv(struct fsl_esdhc_cfg *cfg,
struct fsl_esdhc_priv *priv)
- if (!cfg || !priv)
return -EINVAL;
- priv->esdhc_regs = (struct fsl_esdhc *)(unsigned long)(cfg->esdhc_base);
- priv->bus_width = cfg->max_bus_width;
- priv->sdhc_clk = cfg->sdhc_clk;
+static int fsl_esdhc_init(struct fsl_esdhc_priv *priv) { struct fsl_esdhc *regs; struct mmc *mmc; u32 caps, voltage_caps;
- if (!cfg)
return -1;
- if (!priv)
return -EINVAL;
- regs = (struct fsl_esdhc *)cfg->esdhc_base;
/* First reset the eSDHC controller */ esdhc_reset(regs);
@@ -676,7 +724,7 @@ int fsl_esdhc_initialize(bd_t *bis, struct fsl_esdhc_cfg *cfg) #endif
writel(SDHCI_IRQ_EN_BITS, ®s->irqstaten);
- memset(&cfg->cfg, 0, sizeof(cfg->cfg));
memset(&priv->cfg, 0, sizeof(priv->cfg));
voltage_caps = 0; caps = esdhc_read32(®s->hostcapblt);
@@ -698,47 +746,83 @@ int fsl_esdhc_initialize(bd_t *bis, struct fsl_esdhc_cfg *cfg) if (caps & ESDHC_HOSTCAPBLT_VS33) voltage_caps |= MMC_VDD_32_33 | MMC_VDD_33_34;
- cfg->cfg.name = "FSL_SDHC";
- cfg->cfg.ops = &esdhc_ops;
- priv->cfg.name = "FSL_SDHC";
- priv->cfg.ops = &esdhc_ops;
#ifdef CONFIG_SYS_SD_VOLTAGE
- cfg->cfg.voltages = CONFIG_SYS_SD_VOLTAGE;
- priv->cfg.voltages = CONFIG_SYS_SD_VOLTAGE;
#else
- cfg->cfg.voltages = MMC_VDD_32_33 | MMC_VDD_33_34;
- priv->cfg.voltages = MMC_VDD_32_33 | MMC_VDD_33_34;
#endif
- if ((cfg->cfg.voltages & voltage_caps) == 0) {
- if ((priv->cfg.voltages & voltage_caps) == 0) { printf("voltage not supported by controller\n"); return -1; }
- cfg->cfg.host_caps = MMC_MODE_4BIT | MMC_MODE_8BIT;
- if (priv->bus_width == 8)
priv->cfg.host_caps = MMC_MODE_4BIT | MMC_MODE_8BIT;
- else if (priv->bus_width == 4)
priv->cfg.host_caps = MMC_MODE_4BIT;
- priv->cfg.host_caps = MMC_MODE_4BIT | MMC_MODE_8BIT;
#ifdef CONFIG_SYS_FSL_ESDHC_HAS_DDR_MODE
- cfg->cfg.host_caps |= MMC_MODE_DDR_52MHz;
- priv->cfg.host_caps |= MMC_MODE_DDR_52MHz;
#endif
- if (cfg->max_bus_width > 0) {
if (cfg->max_bus_width < 8)
cfg->cfg.host_caps &= ~MMC_MODE_8BIT;
if (cfg->max_bus_width < 4)
cfg->cfg.host_caps &= ~MMC_MODE_4BIT;
if (priv->bus_width > 0) {
if (priv->bus_width < 8)
priv->cfg.host_caps &= ~MMC_MODE_8BIT;
if (priv->bus_width < 4)
priv->cfg.host_caps &= ~MMC_MODE_4BIT;
if (caps & ESDHC_HOSTCAPBLT_HSS)
cfg->cfg.host_caps |= MMC_MODE_HS_52MHz | MMC_MODE_HS;
priv->cfg.host_caps |= MMC_MODE_HS_52MHz | MMC_MODE_HS;
#ifdef CONFIG_ESDHC_DETECT_8_BIT_QUIRK if (CONFIG_ESDHC_DETECT_8_BIT_QUIRK)
#endif
- cfg->cfg.f_min = 400000;
- cfg->cfg.f_max = min(cfg->sdhc_clk, (u32)52000000);
- priv->cfg.f_min = 400000;
- priv->cfg.f_max = min(priv->sdhc_clk, (u32)52000000);
- cfg->cfg.b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT;
- priv->cfg.b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT;
- mmc = mmc_create(&cfg->cfg, cfg);
mmc = mmc_create(&priv->cfg, priv); if (mmc == NULL) return -1;
priv->mmc = mmc;
+int fsl_esdhc_initialize(bd_t *bis, struct fsl_esdhc_cfg *cfg) +{
- struct fsl_esdhc_priv *priv;
- int ret;
- if (!cfg)
return -EINVAL;
- priv = calloc(sizeof(struct fsl_esdhc_priv), 1);
- if (!priv)
return -ENOMEM;
- ret = fsl_esdhc_cfg_to_priv(cfg, priv);
- if (ret) {
debug("%s xlate failure\n", __func__);
free(priv);
return ret;
- ret = fsl_esdhc_init(priv);
- if (ret) {
debug("%s init failure\n", __func__);
free(priv);
return ret;
@@ -819,3 +903,92 @@ void fdt_fixup_esdhc(void *blob, bd_t *bd) 4 + 1, 1); } #endif
+#ifdef CONFIG_DM_MMC +#include <asm/arch/clock.h> +static int fsl_esdhc_probe(struct udevice *dev) +{
- struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev);
- struct fsl_esdhc_priv *priv = dev_get_priv(dev);
- const void *fdt = gd->fdt_blob;
- int node = dev->of_offset;
- fdt_addr_t addr;
- unsigned int val;
- int ret;
- addr = dev_get_addr(dev);
- if (addr == FDT_ADDR_T_NONE)
return -EINVAL;
- priv->esdhc_regs = (struct fsl_esdhc *)addr;
- priv->dev = dev;
- val = fdtdec_get_int(fdt, node, "bus-width", -1);
- if (val == 8)
priv->bus_width = 8;
- else if (val == 4)
priv->bus_width = 4;
- else
priv->bus_width = 1;
- if (fdt_get_property(fdt, node, "non-removable", NULL)) {
priv->non_removable = 1;
} else {
priv->non_removable = 0;
gpio_request_by_name_nodev(fdt, node, "cd-gpios", 0,
&priv->cd_gpio, GPIOD_IS_IN);
* TODO:
* Because lack of clk driver, if SDHC clk is not enabled,
* need to enable it first before this driver is invoked.
* we use MXC_ESDHC_CLK to get clk freq.
* If one would like to make this function work,
* the aliases should be provided in dts as this:
* aliases {
* mmc0 = &usdhc1;
* mmc1 = &usdhc2;
* mmc2 = &usdhc3;
* mmc3 = &usdhc4;
* Then if your board only supports mmc2 and mmc3, but we can
* correctly get the seq as 2 and 3, then let mxc_get_clock
* work as expected.
- priv->sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK + dev->seq);
- if (priv->sdhc_clk <= 0) {
dev_err(dev, "Unable to get clk for %s\n", dev->name);
return -EINVAL;
- if (ret) {
dev_err(dev, "fsl_esdhc_init failure\n");
return ret;
- upriv->mmc = priv->mmc;
+static const struct udevice_id fsl_esdhc_ids[] = {
- { .compatible = "fsl,imx6ul-usdhc", },
- { .compatible = "fsl,imx6sx-usdhc", },
- { .compatible = "fsl,imx6sl-usdhc", },
- { .compatible = "fsl,imx6q-usdhc", },
- { .compatible = "fsl,imx7d-usdhc", },
- { /* sentinel */ }
+U_BOOT_DRIVER(fsl_esdhc) = {
- .name = "fsl-esdhc-mmc",
- .id = UCLASS_MMC,
- .of_match = fsl_esdhc_ids,
- .probe = fsl_esdhc_probe,
- .priv_auto_alloc_size = sizeof(struct fsl_esdhc_priv),
2.6.2
(Sorry for top posting. Using OWA)
Yes, I can compile it for PPC and spot check on selected boards.
York
________________________________________ From: Peng Fan van.freenix@gmail.com Sent: Sunday, March 27, 2016 7:59 AM To: york sun; panto@antoniou-consulting.com; sbabic@denx.de; sjg@chromium.org Cc: u-boot@lists.denx.de; Yangbo Lu; Hector Palacios; Eric Nelson; Fabio Estevam Subject: Re: [PATCH V3] fsl: esdhc: support driver model
Hi York,
Thanks, Peng.
- @cfg: mmc config
- @mmc: mmc
struct mmc *mmc;
int non_removable;
int sdhc_clk = priv->sdhc_clk; uint clk; if (clock < mmc->cfg->f_min)
struct fsl_esdhc *regs = priv->esdhc_regs; int timeout = 1000; /* Reset the entire host controller */
return 1;
if (!cfg || !priv)
return -EINVAL;
if (!cfg)
return -1;
if (!priv)
return -EINVAL;
regs = priv->esdhc_regs; /* First reset the eSDHC controller */ esdhc_reset(regs);
memset(&priv->cfg, 0, sizeof(priv->cfg)); voltage_caps = 0; caps = esdhc_read32(®s->hostcapblt);
#else
#endif
#endif
priv->cfg.host_caps &= ~MMC_MODE_4BIT; } if (caps & ESDHC_HOSTCAPBLT_HSS)
#endif
priv->mmc = mmc;
int ret;
if (!cfg)
return -EINVAL;
if (!priv)
return -ENOMEM;
if (ret) {
free(priv);
return ret;
if (ret) {
free(priv);
return ret;
fdt_addr_t addr;
unsigned int val;
int ret;
return -EINVAL;
priv->dev = dev;
if (val == 8)
else if (val == 4)
else
} else {
* TODO:
* aliases {
* mmc0 = &usdhc1;
* mmc1 = &usdhc2;
* mmc2 = &usdhc3;
* mmc3 = &usdhc4;
* work as expected.
return -EINVAL;
if (ret) {
return ret;
{ /* sentinel */ }
.id = UCLASS_MMC,
2.6.2
On 03/27/2016 08:02 AM, Peng Fan wrote:
Hi York,
Thanks, Peng.
<snip>
- fdt_addr_t addr;
- unsigned int val;
- int ret;
return -EINVAL;
- priv->dev = dev;
- if (val == 8)
- else
} else {
* TODO:
* aliases {
* mmc0 = &usdhc1;
* mmc1 = &usdhc2;
* mmc2 = &usdhc3;
* mmc3 = &usdhc4;
* work as expected.
return -EINVAL;
- if (ret) {
return ret;
- .id = UCLASS_MMC,
2.6.2
Peng,
You are not breaking PPC yet. The new function you added fsl_esdhc_probe() is gated by CONFIG_DM_MMC. This macro is not defined for any PPC platform.
York
Hi York,
Hi York,
Thanks, Peng.
<snip>
- fdt_addr_t addr;
- unsigned int val;
- int ret;
return -EINVAL;
- priv->dev = dev;
- if (val == 8)
- else
} else {
* TODO:
* aliases {
* mmc0 = &usdhc1;
* mmc1 = &usdhc2;
* mmc2 = &usdhc3;
* mmc3 = &usdhc4;
* work as expected.
return -EINVAL;
- if (ret) {
return ret;
- .id = UCLASS_MMC,
2.6.2
Peng,
Thanks for the test. If CONFIG_DM_MMC is enabled for PPC, I think the only thing that may break PPC is mxc_get_clock, because this function is only defined for i.MX.
I am not very sure whether we need a more complicated clk driver following linux, since it may make board/soc bringup work more complicated. Anyway, later when PPC want to enable CONFIG_DM_MMC, mxc_get_clock should be refined to support i.MX and PPC or we develop a general function to support both.
Thanks, Peng.
York
- All the functions are changed to use 'struct fsl_esdhc_priv', except fsl_esdhc_initialize.
- Since clk driver is not implemented, use mxc_get_clock to geth the clk and fill 'priv->sdhc_clk'.
Applied to u-boot-fsl-qoriq master. Awaiting upstream. Thanks.
York
Eric Nelson
Peng Fan
York Sun
york sun
