Re: [DNX#2006033142000481] [U-Boot-Users] Resend: [PATCH]:correct flash base [...]
Hello list,
inside the automatic U-Boot patch tracking system a new ticket [DNX#2006033142000481] was created:
<snip>
Hi, Sorry, have to resend, the patch missed some lines. Here it is. Please ignore the previous one. Sorry for inconvenience.
This is a patch for MPC8349E ADS board readme in README.mpc83xxads. This patch corrects u-boot base address described in the README.mpc83xxads to be the same as text base set in the source code.
Log Entry:
- Patched by Neil Chu, Oct 2005 Correct the flash base address in README.mpc83xx so that it is the
same as TEXT base address setting in u-boot source code.
diff -Nur u-boot-1.1.3/doc/README.mpc83xxads u-boot-1.1.3- after/doc/README.mpc83xxads --- u-boot-1.1.3/doc/README.mpc83xxads 2005-08-14 07:53:35.000000000 +0800 +++ u-boot-1.1.3-after/doc/README.mpc83xxads 2005-10-14 10:34:19.871711464 +0800 @@ -83,15 +83,15 @@ 5.1 Reflash U-boot Image using U-boot
tftp 10000 u-boot.bin
- protect off fe000000 fe09ffff
- erase fe000000 fe09ffff
- protect off all
- erase fe700000 fe73ffff
- cp.b 10000 fe000000 xxxx
- cp.b 10000 fe700000 xxxx
or
- cp.b 10000 fe000000 a0000
- cp.b 10000 fe700000 40000
-You might have to supply the correct byte count for 'xxxx' from -the TFTP. Maybe a0000 will work too, that corresponds to the +You might have to supply the correct byte count in hex for 'xxxx' from +the TFTP. Maybe 40000 will work too, that corresponds to the erased sectors.
This SF.Net email is sponsored by: Power Architecture Resource Center: Free content, downloads, discussions, and more. http://solutions.newsforge.com/ibmarch.tmpl _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
</snip>
Your U-Boot support team
DENX Support System
