[U-Boot] [PATCH] ARM: DRA7: emif: Fix disabling/enabling of refreshes
clrsetbits_le32/clrbits_le32 takes mask of the bits as input that are needed to be set/clear. But emif driver passes the shift of the bits. Fixing it here.
Reported-by: Mark Mckeown m-mckeown@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/cpu/armv7/omap-common/emif-common.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap-common/emif-common.c b/arch/arm/cpu/armv7/omap-common/emif-common.c index f5b22f6..bf7bf26 100644 --- a/arch/arm/cpu/armv7/omap-common/emif-common.c +++ b/arch/arm/cpu/armv7/omap-common/emif-common.c @@ -294,8 +294,8 @@ static void dra7_ddr3_leveling(u32 base, const struct emif_regs *regs) EMIF_REG_PHY_FIFO_WE_IN_MISALINED_CLR);
/* Disable refreshed before leveling */ - clrsetbits_le32(&emif->emif_sdram_ref_ctrl, EMIF_REG_INITREF_DIS_SHIFT, - EMIF_REG_INITREF_DIS_SHIFT); + clrsetbits_le32(&emif->emif_sdram_ref_ctrl, EMIF_REG_INITREF_DIS_MASK, + EMIF_REG_INITREF_DIS_MASK);
/* Start Full leveling */ writel(DDR3_FULL_LVL, &emif->emif_rd_wr_lvl_ctl); @@ -309,7 +309,7 @@ static void dra7_ddr3_leveling(u32 base, const struct emif_regs *regs) }
/* Enable refreshes after leveling */ - clrbits_le32(&emif->emif_sdram_ref_ctrl, EMIF_REG_INITREF_DIS_SHIFT); + clrbits_le32(&emif->emif_sdram_ref_ctrl, EMIF_REG_INITREF_DIS_MASK);
debug("HW leveling success\n"); /*
Lokesh Vutla
