[PATCH] arm: mvebu: Fix booting from SATA
Use proper SATA macro for boot_device switch in spl_boot_device() function.
Signed-off-by: Pali Rohár pali@kernel.org Fixes: 2226ca173486 ("arm: mvebu: Load U-Boot proper binary in SPL code based on kwbimage header") --- arch/arm/mach-mvebu/spl.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-mvebu/spl.c b/arch/arm/mach-mvebu/spl.c index cad3f0a48893..73c4b9af3e6d 100644 --- a/arch/arm/mach-mvebu/spl.c +++ b/arch/arm/mach-mvebu/spl.c @@ -199,8 +199,8 @@ u32 spl_boot_device(void) return BOOT_DEVICE_MMC1; #endif #ifdef CONFIG_SPL_SATA - case BOOT_FROM_SATA: - return BOOT_FROM_SATA; + case BOOT_DEVICE_SATA: + return BOOT_DEVICE_SATA; #endif #ifdef CONFIG_SPL_SPI_FLASH_SUPPORT case BOOT_DEVICE_SPI:
Pali Rohár
