[U-Boot] [PATCH 1/3] imx: mx6sololite: Add I2C1 pad settings
Add I2C1 SDA/SCL pad settings for mx6 sololite
Signed-off-by: Ye.Li B37916@freescale.com --- Changes since v1: - None
Changes since v2: - None
Changes since v3: - Split the I2C1 pad settings to a new patch since it is board independent.
arch/arm/include/asm/arch-mx6/mx6sl_pins.h | 5 +++++ 1 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx6/mx6sl_pins.h b/arch/arm/include/asm/arch-mx6/mx6sl_pins.h index 045ccc4..ac84270 100644 --- a/arch/arm/include/asm/arch-mx6/mx6sl_pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6sl_pins.h @@ -34,5 +34,10 @@ enum { MX6_PAD_FEC_REF_CLK__FEC_REF_OUT = IOMUX_PAD(0x424, 0x134, 0x10, 0x000, 0, 0), MX6_PAD_FEC_RX_ER__GPIO_4_19 = IOMUX_PAD(0x0428, 0x0138, 5, 0x0000, 0, 0), MX6_PAD_FEC_TX_CLK__GPIO_4_21 = IOMUX_PAD(0x0434, 0x0144, 5, 0x0000, 0, 0), + + MX6_PAD_I2C1_SDA__I2C1_SDA = IOMUX_PAD(0x0450, 0x0160, 0x10, 0x0720, 2, 0), + MX6_PAD_I2C1_SDA__GPIO_3_13 = IOMUX_PAD(0x0450, 0x0160, 5, 0x0000, 0, 0), + MX6_PAD_I2C1_SCL__I2C1_SCL = IOMUX_PAD(0x044C, 0x015C, 0x10, 0x071C, 2, 0), + MX6_PAD_I2C1_SCL__GPIO_3_12 = IOMUX_PAD(0x044C, 0x015C, 5, 0x0000, 0, 0), }; #endif /* __ASM_ARCH_MX6_MX6SL_PINS_H__ */
Enable the MXC I2C driver for mx6slevk and setup the I2C1.
Changes since v3: - Split the I2C1 pad setting to another new patch.
board/freescale/mx6slevk/mx6slevk.c | 26 ++++++++++++++++++++++++++ include/configs/mx6slevk.h | 6 ++++++ 2 files changed, 32 insertions(+), 0 deletions(-)
diff --git a/board/freescale/mx6slevk/mx6slevk.c b/board/freescale/mx6slevk/mx6slevk.c index a990b4c..fedd5c3 100644 --- a/board/freescale/mx6slevk/mx6slevk.c +++ b/board/freescale/mx6slevk/mx6slevk.c @@ -13,12 +13,14 @@ #include <asm/arch/sys_proto.h> #include <asm/gpio.h> #include <asm/imx-common/iomux-v3.h> +#include <asm/imx-common/mxc_i2c.h> #include <asm/io.h> #include <linux/sizes.h> #include <common.h> #include <fsl_esdhc.h> #include <mmc.h> #include <netdev.h> +#include <i2c.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -37,8 +39,29 @@ DECLARE_GLOBAL_DATA_PTR; #define SPI_PAD_CTRL (PAD_CTL_HYS | PAD_CTL_SPEED_MED | \ PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST)
+#define I2C_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ + PAD_CTL_ODE | PAD_CTL_SRE_FAST) + #define ETH_PHY_RESET IMX_GPIO_NR(4, 21)
+#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) + +/* I2C1 for PMIC */ +struct i2c_pads_info i2c_pad_info0 = { + .sda = { + .i2c_mode = MX6_PAD_I2C1_SDA__I2C1_SDA | PC, + .gpio_mode = MX6_PAD_I2C1_SDA__GPIO_3_13 | PC, + .gp = IMX_GPIO_NR(3, 13), + }, + .scl = { + .i2c_mode = MX6_PAD_I2C1_SCL__I2C1_SCL | PC, + .gpio_mode = MX6_PAD_I2C1_SCL__GPIO_3_12 | PC, + .gp = IMX_GPIO_NR(3, 12), + }, +}; + int dram_init(void) { gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE); @@ -162,6 +185,9 @@ int board_init(void) #ifdef CONFIG_FEC_MXC setup_fec(); #endif + + setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info0); + return 0; }
diff --git a/include/configs/mx6slevk.h b/include/configs/mx6slevk.h index 3d05a64..bf5066f 100644 --- a/include/configs/mx6slevk.h +++ b/include/configs/mx6slevk.h @@ -60,6 +60,12 @@ #define CONFIG_PHYLIB #define CONFIG_PHY_SMSC
+/* I2C Configs */ +#define CONFIG_CMD_I2C +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_SPEED 100000 + /* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE #define CONFIG_CONS_INDEX 1
Initialize the Pfuze on I2C1 at mx6slekv board late init.
Changes since v3: - Use the factorized pfuze common function in pfuze init
board/freescale/mx6slevk/mx6slevk.c | 22 ++++++++++++++++++++++ include/configs/mx6slevk.h | 7 +++++++ 2 files changed, 29 insertions(+), 0 deletions(-)
diff --git a/board/freescale/mx6slevk/mx6slevk.c b/board/freescale/mx6slevk/mx6slevk.c index fedd5c3..c027d08 100644 --- a/board/freescale/mx6slevk/mx6slevk.c +++ b/board/freescale/mx6slevk/mx6slevk.c @@ -21,6 +21,8 @@ #include <mmc.h> #include <netdev.h> #include <i2c.h> +#include <power/pmic.h> +#include "../common/pfuze.h"
@@ -48,6 +50,8 @@ DECLARE_GLOBAL_DATA_PTR;
+#define I2C_PMIC 0 + /* I2C1 for PMIC */ struct i2c_pads_info i2c_pad_info0 = { .sda = { @@ -191,6 +195,24 @@ int board_init(void) return 0; }
+static int pfuze_init(void) +{ + struct pmic *p; + + p = pfuze_common_init(I2C_PMIC); + if (!p) + return -ENODEV; + + return 0; +} + +int board_late_init(void) +{ + pfuze_init(); + + return 0; +} + u32 get_board_rev(void) { return get_cpu_rev(); diff --git a/include/configs/mx6slevk.h b/include/configs/mx6slevk.h index bf5066f..09d0896 100644 --- a/include/configs/mx6slevk.h +++ b/include/configs/mx6slevk.h @@ -30,6 +30,7 @@ #define CONFIG_SYS_MALLOC_LEN (3 * SZ_1M)
#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_BOARD_LATE_INIT #define CONFIG_MXC_GPIO
#define CONFIG_MXC_UART @@ -66,6 +67,12 @@ #define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_SPEED 100000
+/* PMIC */ +#define CONFIG_POWER +#define CONFIG_POWER_I2C +#define CONFIG_POWER_PFUZE100 +#define CONFIG_POWER_PFUZE100_I2C_ADDR 0x08 + /* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE #define CONFIG_CONS_INDEX 1
Ye.Li
