[PATCH 1/3] arm: mvebu: Fix default CONFIG_BUILD_TARGET
u-boot-with-spl.kwb is built only for SPL enabled 32-bit armada boards. u-boot.kwb is built for 32-bit armada and kirkwood boards but only for non-SPL targets.
So replace CONFIG_ARCH_MVEBU by CONFIG_ARMADA_32BIT (it implies CONFIG_ARCH_MVEBU) for u-boot-with-spl.kwb.
And add additional CONFIG_ARMADA_32BIT && !CONFIG_SPL for u-boot.kwb.
Signed-off-by: Pali Rohár pali@kernel.org --- Kconfig | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/Kconfig b/Kconfig index 0cdc9658f796..2243cc51c7cb 100644 --- a/Kconfig +++ b/Kconfig @@ -456,11 +456,11 @@ config BUILD_TARGET string "Build target special images" default "u-boot-with-spl.sfp" if TARGET_SOCFPGA_ARRIA10 default "u-boot-with-spl.sfp" if TARGET_SOCFPGA_GEN5 - default "u-boot-with-spl.kwb" if ARCH_MVEBU && SPL + default "u-boot-with-spl.kwb" if ARMADA_32BIT && SPL default "u-boot-elf.srec" if RCAR_GEN3 default "u-boot.itb" if !BINMAN && SPL_LOAD_FIT && (ARCH_ROCKCHIP || \ ARCH_SUNXI || RISCV || ARCH_ZYNQMP) - default "u-boot.kwb" if ARCH_KIRKWOOD + default "u-boot.kwb" if (ARCH_KIRKWOOD || ARMADA_32BIT) && !SPL default "u-boot-with-spl.bin" if ARCH_AT91 && SPL_NAND_SUPPORT default "u-boot-with-spl.imx" if ARCH_MX6 && SPL help
Final U-Boot binary for mpc85xx boards which use SPL and are not PBL-based based is u-boot-with-spl.bin. PBL is not used only on boards with e500v1 and e500v2 cores. Apparently CONFIG_E500 is set not only for e500 cores, but also for all other mpc85xx cores e500mc, e5500 and e5600. So do not use CONFIG_E500 and instead filter new cores with PBL based bootrom.
Signed-off-by: Pali Rohár pali@kernel.org --- Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/Kconfig b/Kconfig index 2243cc51c7cb..dedac5396918 100644 --- a/Kconfig +++ b/Kconfig @@ -461,6 +461,7 @@ config BUILD_TARGET default "u-boot.itb" if !BINMAN && SPL_LOAD_FIT && (ARCH_ROCKCHIP || \ ARCH_SUNXI || RISCV || ARCH_ZYNQMP) default "u-boot.kwb" if (ARCH_KIRKWOOD || ARMADA_32BIT) && !SPL + default "u-boot-with-spl.bin" if MPC85xx && !E500MC && !E5500 && !E6500 && SPL default "u-boot-with-spl.bin" if ARCH_AT91 && SPL_NAND_SUPPORT default "u-boot-with-spl.imx" if ARCH_MX6 && SPL help
CONFIG_SPL_TARGET should specify additional SPL make target. But u-boot-with-spl.bin is final U-Boot binary, not SPL binary in some custom format. Moreover u-boot-with-spl.bin is already set in CONFIG_BUILD_TARGET, so make will build it by default.
Signed-off-by: Pali Rohár pali@kernel.org --- configs/P1010RDB-PA_36BIT_NAND_defconfig | 1 - configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 1 - configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 1 - configs/P1010RDB-PA_NAND_defconfig | 1 - configs/P1010RDB-PA_SDCARD_defconfig | 1 - configs/P1010RDB-PA_SPIFLASH_defconfig | 1 - configs/P1010RDB-PB_36BIT_NAND_defconfig | 1 - configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 1 - configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 1 - configs/P1010RDB-PB_NAND_defconfig | 1 - configs/P1010RDB-PB_SDCARD_defconfig | 1 - configs/P1010RDB-PB_SPIFLASH_defconfig | 1 - configs/P1020RDB-PC_36BIT_NAND_defconfig | 1 - configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 1 - configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 1 - configs/P1020RDB-PC_NAND_defconfig | 1 - configs/P1020RDB-PC_SDCARD_defconfig | 1 - configs/P1020RDB-PC_SPIFLASH_defconfig | 1 - configs/P1020RDB-PD_NAND_defconfig | 1 - configs/P1020RDB-PD_SDCARD_defconfig | 1 - configs/P1020RDB-PD_SPIFLASH_defconfig | 1 - configs/P2020RDB-PC_36BIT_NAND_defconfig | 1 - configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 1 - configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 1 - configs/P2020RDB-PC_NAND_defconfig | 1 - configs/P2020RDB-PC_SDCARD_defconfig | 1 - configs/P2020RDB-PC_SPIFLASH_defconfig | 1 - 27 files changed, 27 deletions(-)
diff --git a/configs/P1010RDB-PA_36BIT_NAND_defconfig b/configs/P1010RDB-PA_36BIT_NAND_defconfig index e15ca5ea2b5d..7d8ed14db21d 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_defconfig @@ -49,7 +49,6 @@ CONFIG_TPL_RELOC_MALLOC=y CONFIG_TPL_RELOC_MALLOC_ADDR=0xd0034000 CONFIG_TPL_RELOC_MALLOC_SIZE=0xc000 CONFIG_SPL_NAND_SUPPORT=y -CONFIG_SPL_TARGET="u-boot-with-spl.bin" CONFIG_TPL=y CONFIG_TPL_DRIVERS_MISC=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig index 230c6d02831c..d562e442fd42 100644 --- a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig @@ -46,7 +46,6 @@ CONFIG_SPL_RELOC_MALLOC_SIZE=0x20000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y -CONFIG_SPL_TARGET="u-boot-with-spl.bin" CONFIG_HUSH_PARSER=y CONFIG_SYS_PBSIZE=276 CONFIG_CMD_IMLS=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig index 982420db74c4..03ddcc864352 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig @@ -48,7 +48,6 @@ CONFIG_SPL_RELOC_MALLOC_SIZE=0x20000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y -CONFIG_SPL_TARGET="u-boot-with-spl.bin" CONFIG_HUSH_PARSER=y CONFIG_SYS_PBSIZE=276 CONFIG_CMD_IMLS=y diff --git a/configs/P1010RDB-PA_NAND_defconfig b/configs/P1010RDB-PA_NAND_defconfig index b3af4450d00f..1e207e0cf09b 100644 --- a/configs/P1010RDB-PA_NAND_defconfig +++ b/configs/P1010RDB-PA_NAND_defconfig @@ -48,7 +48,6 @@ CONFIG_TPL_RELOC_MALLOC=y CONFIG_TPL_RELOC_MALLOC_ADDR=0xd0034000 CONFIG_TPL_RELOC_MALLOC_SIZE=0xc000 CONFIG_SPL_NAND_SUPPORT=y -CONFIG_SPL_TARGET="u-boot-with-spl.bin" CONFIG_TPL=y CONFIG_TPL_DRIVERS_MISC=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1010RDB-PA_SDCARD_defconfig b/configs/P1010RDB-PA_SDCARD_defconfig index dd9120970bab..ef790bf09ed0 100644 --- a/configs/P1010RDB-PA_SDCARD_defconfig +++ b/configs/P1010RDB-PA_SDCARD_defconfig @@ -45,7 +45,6 @@ CONFIG_SPL_RELOC_MALLOC_SIZE=0x20000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y -CONFIG_SPL_TARGET="u-boot-with-spl.bin" CONFIG_HUSH_PARSER=y CONFIG_SYS_PBSIZE=276 CONFIG_CMD_IMLS=y diff --git a/configs/P1010RDB-PA_SPIFLASH_defconfig b/configs/P1010RDB-PA_SPIFLASH_defconfig index ff7cfa246159..e6994aec2403 100644 --- a/configs/P1010RDB-PA_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_defconfig @@ -47,7 +47,6 @@ CONFIG_SPL_RELOC_MALLOC_SIZE=0x20000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y -CONFIG_SPL_TARGET="u-boot-with-spl.bin" CONFIG_HUSH_PARSER=y CONFIG_SYS_PBSIZE=276 CONFIG_CMD_IMLS=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_defconfig b/configs/P1010RDB-PB_36BIT_NAND_defconfig index a61f4d017a68..d4b14d49f29e 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_defconfig @@ -50,7 +50,6 @@ CONFIG_TPL_RELOC_MALLOC=y CONFIG_TPL_RELOC_MALLOC_ADDR=0xd0034000 CONFIG_TPL_RELOC_MALLOC_SIZE=0xc000 CONFIG_SPL_NAND_SUPPORT=y -CONFIG_SPL_TARGET="u-boot-with-spl.bin" CONFIG_TPL=y CONFIG_TPL_DRIVERS_MISC=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig index 84e2d3c587a4..e0b964e1cc84 100644 --- a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig @@ -47,7 +47,6 @@ CONFIG_SPL_RELOC_MALLOC_SIZE=0x20000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y -CONFIG_SPL_TARGET="u-boot-with-spl.bin" CONFIG_HUSH_PARSER=y CONFIG_SYS_PBSIZE=276 CONFIG_CMD_IMLS=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig index b883b81e0cd8..5ec89234f8ee 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig @@ -49,7 +49,6 @@ CONFIG_SPL_RELOC_MALLOC_SIZE=0x20000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y -CONFIG_SPL_TARGET="u-boot-with-spl.bin" CONFIG_HUSH_PARSER=y CONFIG_SYS_PBSIZE=276 CONFIG_CMD_IMLS=y diff --git a/configs/P1010RDB-PB_NAND_defconfig b/configs/P1010RDB-PB_NAND_defconfig index 7f7870d82c52..7b5f6089e1ce 100644 --- a/configs/P1010RDB-PB_NAND_defconfig +++ b/configs/P1010RDB-PB_NAND_defconfig @@ -49,7 +49,6 @@ CONFIG_TPL_RELOC_MALLOC=y CONFIG_TPL_RELOC_MALLOC_ADDR=0xd0034000 CONFIG_TPL_RELOC_MALLOC_SIZE=0xc000 CONFIG_SPL_NAND_SUPPORT=y -CONFIG_SPL_TARGET="u-boot-with-spl.bin" CONFIG_TPL=y CONFIG_TPL_DRIVERS_MISC=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1010RDB-PB_SDCARD_defconfig b/configs/P1010RDB-PB_SDCARD_defconfig index e985f8cd75d0..57cdd7a71b5c 100644 --- a/configs/P1010RDB-PB_SDCARD_defconfig +++ b/configs/P1010RDB-PB_SDCARD_defconfig @@ -46,7 +46,6 @@ CONFIG_SPL_RELOC_MALLOC_SIZE=0x20000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y -CONFIG_SPL_TARGET="u-boot-with-spl.bin" CONFIG_HUSH_PARSER=y CONFIG_SYS_PBSIZE=276 CONFIG_CMD_IMLS=y diff --git a/configs/P1010RDB-PB_SPIFLASH_defconfig b/configs/P1010RDB-PB_SPIFLASH_defconfig index 9f4ae14e0b23..43dcd13c9ab0 100644 --- a/configs/P1010RDB-PB_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_defconfig @@ -48,7 +48,6 @@ CONFIG_SPL_RELOC_MALLOC_SIZE=0x20000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y -CONFIG_SPL_TARGET="u-boot-with-spl.bin" CONFIG_HUSH_PARSER=y CONFIG_SYS_PBSIZE=276 CONFIG_CMD_IMLS=y diff --git a/configs/P1020RDB-PC_36BIT_NAND_defconfig b/configs/P1020RDB-PC_36BIT_NAND_defconfig index 3f93b318c92f..96035d45238d 100644 --- a/configs/P1020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1020RDB-PC_36BIT_NAND_defconfig @@ -50,7 +50,6 @@ CONFIG_TPL_RELOC_MALLOC=y CONFIG_TPL_RELOC_MALLOC_ADDR=0xf8fb4000 CONFIG_TPL_RELOC_MALLOC_SIZE=0xc000 CONFIG_SPL_NAND_SUPPORT=y -CONFIG_SPL_TARGET="u-boot-with-spl.bin" CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y CONFIG_TPL_I2C=y diff --git a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig index 3b3cf1ee7a5e..160355d98917 100644 --- a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig @@ -47,7 +47,6 @@ CONFIG_SPL_RELOC_MALLOC_SIZE=0x1b000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y -CONFIG_SPL_TARGET="u-boot-with-spl.bin" CONFIG_HUSH_PARSER=y # CONFIG_AUTO_COMPLETE is not set CONFIG_SYS_PBSIZE=276 diff --git a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig index aba5b9cedd43..4633f91b1ee5 100644 --- a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig @@ -49,7 +49,6 @@ CONFIG_SPL_RELOC_MALLOC_SIZE=0x1b000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y -CONFIG_SPL_TARGET="u-boot-with-spl.bin" CONFIG_HUSH_PARSER=y # CONFIG_AUTO_COMPLETE is not set CONFIG_SYS_PBSIZE=276 diff --git a/configs/P1020RDB-PC_NAND_defconfig b/configs/P1020RDB-PC_NAND_defconfig index f3fc4c82a54d..1646601c1236 100644 --- a/configs/P1020RDB-PC_NAND_defconfig +++ b/configs/P1020RDB-PC_NAND_defconfig @@ -49,7 +49,6 @@ CONFIG_TPL_RELOC_MALLOC=y CONFIG_TPL_RELOC_MALLOC_ADDR=0xf8fb4000 CONFIG_TPL_RELOC_MALLOC_SIZE=0xc000 CONFIG_SPL_NAND_SUPPORT=y -CONFIG_SPL_TARGET="u-boot-with-spl.bin" CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y CONFIG_TPL_I2C=y diff --git a/configs/P1020RDB-PC_SDCARD_defconfig b/configs/P1020RDB-PC_SDCARD_defconfig index 25eb5d5da74a..99089d1aae11 100644 --- a/configs/P1020RDB-PC_SDCARD_defconfig +++ b/configs/P1020RDB-PC_SDCARD_defconfig @@ -46,7 +46,6 @@ CONFIG_SPL_RELOC_MALLOC_SIZE=0x1b000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y -CONFIG_SPL_TARGET="u-boot-with-spl.bin" CONFIG_HUSH_PARSER=y # CONFIG_AUTO_COMPLETE is not set CONFIG_SYS_PBSIZE=276 diff --git a/configs/P1020RDB-PC_SPIFLASH_defconfig b/configs/P1020RDB-PC_SPIFLASH_defconfig index 054320f356cd..1832210b2734 100644 --- a/configs/P1020RDB-PC_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_SPIFLASH_defconfig @@ -48,7 +48,6 @@ CONFIG_SPL_RELOC_MALLOC_SIZE=0x1b000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y -CONFIG_SPL_TARGET="u-boot-with-spl.bin" CONFIG_HUSH_PARSER=y # CONFIG_AUTO_COMPLETE is not set CONFIG_SYS_PBSIZE=276 diff --git a/configs/P1020RDB-PD_NAND_defconfig b/configs/P1020RDB-PD_NAND_defconfig index cc02fe6a8ac9..6dd3e5395e54 100644 --- a/configs/P1020RDB-PD_NAND_defconfig +++ b/configs/P1020RDB-PD_NAND_defconfig @@ -49,7 +49,6 @@ CONFIG_TPL_RELOC_MALLOC=y CONFIG_TPL_RELOC_MALLOC_ADDR=0xf8fb4000 CONFIG_TPL_RELOC_MALLOC_SIZE=0xc000 CONFIG_SPL_NAND_SUPPORT=y -CONFIG_SPL_TARGET="u-boot-with-spl.bin" CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y CONFIG_TPL_I2C=y diff --git a/configs/P1020RDB-PD_SDCARD_defconfig b/configs/P1020RDB-PD_SDCARD_defconfig index dc82da81b816..9bbbfdd32eab 100644 --- a/configs/P1020RDB-PD_SDCARD_defconfig +++ b/configs/P1020RDB-PD_SDCARD_defconfig @@ -46,7 +46,6 @@ CONFIG_SPL_RELOC_MALLOC_SIZE=0x1b000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y -CONFIG_SPL_TARGET="u-boot-with-spl.bin" CONFIG_HUSH_PARSER=y # CONFIG_AUTO_COMPLETE is not set CONFIG_SYS_PBSIZE=276 diff --git a/configs/P1020RDB-PD_SPIFLASH_defconfig b/configs/P1020RDB-PD_SPIFLASH_defconfig index 7b80edeeeb92..8e4df6366c7e 100644 --- a/configs/P1020RDB-PD_SPIFLASH_defconfig +++ b/configs/P1020RDB-PD_SPIFLASH_defconfig @@ -48,7 +48,6 @@ CONFIG_SPL_RELOC_MALLOC_SIZE=0x1b000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y -CONFIG_SPL_TARGET="u-boot-with-spl.bin" CONFIG_HUSH_PARSER=y # CONFIG_AUTO_COMPLETE is not set CONFIG_SYS_PBSIZE=276 diff --git a/configs/P2020RDB-PC_36BIT_NAND_defconfig b/configs/P2020RDB-PC_36BIT_NAND_defconfig index 9162774ad70c..b018dfa2fa67 100644 --- a/configs/P2020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P2020RDB-PC_36BIT_NAND_defconfig @@ -50,7 +50,6 @@ CONFIG_TPL_RELOC_MALLOC=y CONFIG_TPL_RELOC_MALLOC_ADDR=0xf8fb4000 CONFIG_TPL_RELOC_MALLOC_SIZE=0xc000 CONFIG_SPL_NAND_SUPPORT=y -CONFIG_SPL_TARGET="u-boot-with-spl.bin" CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y CONFIG_TPL_I2C=y diff --git a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig index fd143b610b98..1633595da7f2 100644 --- a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig @@ -47,7 +47,6 @@ CONFIG_SPL_RELOC_MALLOC_SIZE=0x5b000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y -CONFIG_SPL_TARGET="u-boot-with-spl.bin" CONFIG_HUSH_PARSER=y # CONFIG_AUTO_COMPLETE is not set CONFIG_SYS_PBSIZE=276 diff --git a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig index edb8b9958eae..513d7f30a13e 100644 --- a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig @@ -49,7 +49,6 @@ CONFIG_SPL_RELOC_MALLOC_SIZE=0x5b000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y -CONFIG_SPL_TARGET="u-boot-with-spl.bin" CONFIG_HUSH_PARSER=y # CONFIG_AUTO_COMPLETE is not set CONFIG_SYS_PBSIZE=276 diff --git a/configs/P2020RDB-PC_NAND_defconfig b/configs/P2020RDB-PC_NAND_defconfig index 1269d22f90c6..a274b69e6292 100644 --- a/configs/P2020RDB-PC_NAND_defconfig +++ b/configs/P2020RDB-PC_NAND_defconfig @@ -49,7 +49,6 @@ CONFIG_TPL_RELOC_MALLOC=y CONFIG_TPL_RELOC_MALLOC_ADDR=0xf8fb4000 CONFIG_TPL_RELOC_MALLOC_SIZE=0xc000 CONFIG_SPL_NAND_SUPPORT=y -CONFIG_SPL_TARGET="u-boot-with-spl.bin" CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y CONFIG_TPL_I2C=y diff --git a/configs/P2020RDB-PC_SDCARD_defconfig b/configs/P2020RDB-PC_SDCARD_defconfig index b5394d05b7ff..0db1a7a9cc03 100644 --- a/configs/P2020RDB-PC_SDCARD_defconfig +++ b/configs/P2020RDB-PC_SDCARD_defconfig @@ -46,7 +46,6 @@ CONFIG_SPL_RELOC_MALLOC_SIZE=0x5b000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y -CONFIG_SPL_TARGET="u-boot-with-spl.bin" CONFIG_HUSH_PARSER=y # CONFIG_AUTO_COMPLETE is not set CONFIG_SYS_PBSIZE=276 diff --git a/configs/P2020RDB-PC_SPIFLASH_defconfig b/configs/P2020RDB-PC_SPIFLASH_defconfig index 431ca31302c9..77a58fef660e 100644 --- a/configs/P2020RDB-PC_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_SPIFLASH_defconfig @@ -48,7 +48,6 @@ CONFIG_SPL_RELOC_MALLOC_SIZE=0x5b000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y -CONFIG_SPL_TARGET="u-boot-with-spl.bin" CONFIG_HUSH_PARSER=y # CONFIG_AUTO_COMPLETE is not set CONFIG_SYS_PBSIZE=276
Pali Rohár
