[PATCH v4] bootstd: sata: Add bootstd support for ahci sata
Add ahci sata bootdev and corresponding hunting function.
Signed-off-by: Tony Dinh mibodhi@gmail.com ---
Changes in v4: - Revise logic in bootmeth_script() to set devtype to sata for non-scsi SATA device - Rewrite sata_rescan() logic to properly remove all devices before probing - Add description to sata_rescan() header
Changes in v3: - Correct drivers/ata/Makefile to compile sata_bootdev only if ahci sata is enabled.
Changes in v2: - set devtype to sata in bootmeth_script for non-scsi SATA device.
boot/bootmeth_script.c | 14 +++++++-- drivers/ata/Makefile | 2 +- drivers/ata/sata.c | 32 ++++++++++++++++++++ drivers/ata/sata_bootdev.c | 62 ++++++++++++++++++++++++++++++++++++++ include/sata.h | 6 ++++ 5 files changed, 112 insertions(+), 4 deletions(-) create mode 100644 drivers/ata/sata_bootdev.c
diff --git a/boot/bootmeth_script.c b/boot/bootmeth_script.c index 58c57a2d4b..96e0ec5efa 100644 --- a/boot/bootmeth_script.c +++ b/boot/bootmeth_script.c @@ -190,10 +190,18 @@ static int script_boot(struct udevice *dev, struct bootflow *bflow) ulong addr; int ret;
- if (desc->uclass_id == UCLASS_USB) + if (desc->uclass_id == UCLASS_USB) { ret = env_set("devtype", "usb"); - else - ret = env_set("devtype", blk_get_devtype(bflow->blk)); + } else { + /* If the uclass is AHCI, but the driver is ATA + * (not scsi), set devtype to sata + */ + if (!ret && IS_ENABLED(CONFIG_SATA) && + desc->uclass_id == UCLASS_AHCI) + ret = env_set("devtype", "sata"); + else + ret = env_set("devtype", blk_get_devtype(bflow->blk)); + } if (!ret) ret = env_set_hex("devnum", desc->devnum); if (!ret) diff --git a/drivers/ata/Makefile b/drivers/ata/Makefile index 6e30180b8b..0b6f91098a 100644 --- a/drivers/ata/Makefile +++ b/drivers/ata/Makefile @@ -10,7 +10,7 @@ obj-$(CONFIG_SCSI_AHCI) += ahci.o obj-$(CONFIG_DWC_AHSATA) += dwc_ahsata.o obj-$(CONFIG_FSL_SATA) += fsl_sata.o obj-$(CONFIG_LIBATA) += libata.o -obj-$(CONFIG_SATA) += sata.o +obj-$(CONFIG_SATA) += sata.o sata_bootdev.o obj-$(CONFIG_SATA_CEVA) += sata_ceva.o obj-$(CONFIG_SATA_MV) += sata_mv.o obj-$(CONFIG_SATA_SIL) += sata_sil.o diff --git a/drivers/ata/sata.c b/drivers/ata/sata.c index ce3e9b5a40..f126b84e05 100644 --- a/drivers/ata/sata.c +++ b/drivers/ata/sata.c @@ -15,6 +15,8 @@ #include <dm.h> #include <part.h> #include <sata.h> +#include <dm/device-internal.h> +#include <dm/uclass-internal.h>
#ifndef CONFIG_AHCI struct blk_desc sata_dev_desc[CONFIG_SYS_SATA_MAX_DEVICE]; @@ -50,6 +52,36 @@ int sata_scan(struct udevice *dev) return ops->scan(dev); }
+int sata_rescan(bool verbose) +{ + int ret; + struct udevice *dev; + + if (verbose) + printf("Removing devices on SATA bus...\n"); + + blk_unbind_all(UCLASS_AHCI); + + ret = uclass_find_first_device(UCLASS_AHCI, &dev); + if (ret || !dev) { + printf("Cannot find SATA device (err=%d)\n", ret); + return -ENOSYS; + } + + ret = device_remove(dev, DM_REMOVE_NORMAL); + if (ret) { + printf("Cannot remove SATA device '%s' (err=%d)\n", dev->name, ret); + return -ENOSYS; + } + + if (verbose) + printf("Rescanning SATA bus for devices...\n"); + + ret = uclass_probe_all(UCLASS_AHCI); + + return ret; +} + #ifndef CONFIG_AHCI #ifdef CONFIG_PARTITIONS struct blk_desc *sata_get_dev(int dev) diff --git a/drivers/ata/sata_bootdev.c b/drivers/ata/sata_bootdev.c new file mode 100644 index 0000000000..f638493ce0 --- /dev/null +++ b/drivers/ata/sata_bootdev.c @@ -0,0 +1,62 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Bootdev for sata + * + * Copyright 2023 Tony Dinh mibodhi@gmail.com + */ + +#include <common.h> +#include <ahci.h> +#include <bootdev.h> +#include <dm.h> +#include <init.h> +#include <sata.h> + +static int sata_bootdev_bind(struct udevice *dev) +{ + struct bootdev_uc_plat *ucp = dev_get_uclass_plat(dev); + + ucp->prio = BOOTDEVP_4_SCAN_FAST; + + return 0; +} + +static int sata_bootdev_hunt(struct bootdev_hunter *info, bool show) +{ + int ret; + + if (IS_ENABLED(CONFIG_PCI)) { + ret = pci_init(); + if (ret) + return ret; + } + + ret = sata_rescan(true); + if (ret) + return ret; + + return 0; +} + +struct bootdev_ops sata_bootdev_ops = { +}; + +static const struct udevice_id sata_bootdev_ids[] = { + { .compatible = "u-boot,bootdev-sata" }, + { } +}; + +U_BOOT_DRIVER(sata_bootdev) = { + .name = "sata_bootdev", + .id = UCLASS_BOOTDEV, + .ops = &sata_bootdev_ops, + .bind = sata_bootdev_bind, + .of_match = sata_bootdev_ids, +}; + +BOOTDEV_HUNTER(sata_bootdev_hunter) = { + .prio = BOOTDEVP_4_SCAN_FAST, + .uclass = UCLASS_AHCI, + .hunt = sata_bootdev_hunt, + .drv = DM_DRIVER_REF(sata_bootdev), +}; diff --git a/include/sata.h b/include/sata.h index d89f7a8a29..6111cf65d9 100644 --- a/include/sata.h +++ b/include/sata.h @@ -21,4 +21,10 @@ extern struct blk_desc sata_dev_desc[]; int sata_probe(int devnum); int sata_remove(int devnum);
+/* + * Remove existing AHCI SATA device uclass and all of its children, + * if any, and probe it again. + */ +int sata_rescan(bool verbose); + #endif
Changes in v4:
SATA device
Changes in v3:
Changes in v2:
Signed-off-by: Tony Dinh mibodhi@gmail.com Reviewed-by: Simon Glass sjg@chromium.org
Changes in v4:
SATA device
Changes in v3:
Changes in v2:
- if (desc->uclass_id == UCLASS_USB) { ret = env_set("devtype", "usb");
- else
- } else {
This is a warning here as ret is uninitalized at this point.
Hi Tom,
Changes in v4:
SATA device
Changes in v3:
Changes in v2:
else
} else {
Thanks! I'll send the v5 patch.
All the best , Tony
-- Tom
Tony Dinh
