[U-Boot] [GIT PULL] Xilinx changes
Hi Tom,
please pull these changes to your tree. There are several things in this PR like DTS cleanups, Topic NL board with extending mkimage format and nand driver.
I have run buildman over it and there is not an issue. ./tools/buildman/buildman -b master zynq -C
Thanks, Michal
The following changes since commit 29e0cfb4f77f7aa369136302cee14a91e22dca71:
Prepare v2016.11 (2016-11-14 11:27:11 -0500)
git://www.denx.de/git/u-boot-microblaze.git master
for you to fetch changes up to 688d1be5ba63be281c2894e74b27209133598e2e:
ARM64: zynqmp: Adding prefetchable memory space to pcie (2016-11-15 15:30:41 +0100)
---------------------------------------------------------------- Anurag Kumar Vulisha (1): ARM64: zynqmp: Add device tree properties for ZynqMP GT core
Bharat Kumar Gogada (2): ARM64: zynqmp: pci: Updating device tree as per upstream ARM64: zynqmp: Adding prefetchable memory space to pcie
Filip Drazic (4): ARM64: zynqmp: DT: Remove unused DDR PM domain ARM64: zynqmp: DT: Remove unused PM domains for PLL ARM64: zynqmp: DT: Add PM domains for GPU and PCIE ARM64: zynqmp: Support for multiple PM IDs assigned to a PM domain
Hyun Kwon (1): ARM64: zynqmp: drm: Add DMA index
Kedareswara rao Appana (3): ARM64: zynqmp: Add clocks for LPDDMA ARM64: zynqmp: Add description for LPDDMA channel usage ARM64: zynqmp: Add clocks for LPDDMA
Michal Simek (18): tools: mkimage: Check if file is regular file zynq: nand: Runtime detection of nand buswidth through slcr ARM: zynq: Add support for Zynq 7000S 7007s/7012s/7014s devices ARM64: zynqmp: Record board name as serial number for DFU/FASTBOOT ARM64: zynqmp: Fix secondary bootmode enabling ARM64: zynqmp: Ignore warnings from autogenerated files ARM: zynq: Remove DTC 1.4.2 warnings ARM64: zynqmp: Remove DTC 1.4.2 warnings ARM64: zynqmp: Enable gpio-led as heartbeat on zcu102 ARM64: zynqmp: Add gpio-keys for zcu102 ARM64: zynqmp: Add dcc port to dtsi ARM64: zynqmp: Remove note about level shifter on zcu102 ARM64: zynqmp: Remove xlnx,id property ARM64: zynqmp: Sync gpio node properties Revert "ARM64: zynqmp: Add serdes address space dp driver" ARM64: zynqmp: List all SMMU ids Revert "ARM64: zynqmp: Added broken-tuning property to SD, eMMC nodes" ARM64: zynqmp: Use 64bit size cell format for main amba bus
Mike Looijmans (3): tools: mkimage: Add support for initialization table for Zynq and ZynqMP ARM: zynq: Make SYS_VENDOR configurable ARM: zynq: Add support for the topic-miami system-on-modules and carrier boards
Naga Sureshkumar Relli (3): ARM64: zynqmp: Enable can1 for ep108 ARM64: zynqmp: Add cortexa53 edac node ARM64: zynqmp: Add ocm node in dtsi
Nava kishore Manne (1): ARM64: zynqmp: Add support for zynqmp fpga manager
Sai Krishna Potthuri (1): ARM64: zynqmp: change sdhci compatible string.
Siva Durga Prasad Paladugu (7): mtd: nand: zynq_nand: Add nand driver support for zynq zynq: nand: Enable Nand flash controller driver a zynq board nand: arasan_nfc: Clear ecc on bit while sending read command net: zynq_gem: Modify the nwcfg bit definitions net: zynq_gem: Correct SGMII enable bit setting ARM64: zynqmp: Add support for SD1 with level shifters bootmode ARM64: zynqmp: Correct the sdhci minimum frequency for ep108
Soren Brinkmann (1): ARM64: zynqmp: Adjust to new SMC interface to get silicon version
VNSL Durga (1): ARM64: zynqmp: Added clocks to DT for ep108
arch/arm/cpu/armv8/zynqmp/Kconfig | 7 + arch/arm/cpu/armv8/zynqmp/spl.c | 6 +- arch/arm/dts/Makefile | 2 + arch/arm/dts/zynq-7000.dtsi | 7 +- arch/arm/dts/zynq-microzed.dts | 2 +- arch/arm/dts/zynq-picozed.dts | 2 +- arch/arm/dts/zynq-topic-miami.dts | 97 +++++++++++++ arch/arm/dts/zynq-topic-miamiplus.dts | 17 +++ arch/arm/dts/zynq-zc702.dts | 2 +- arch/arm/dts/zynq-zc706.dts | 2 +- arch/arm/dts/zynq-zc770-xm010.dts | 2 +- arch/arm/dts/zynq-zc770-xm011.dts | 2 +- arch/arm/dts/zynq-zed.dts | 2 +- arch/arm/dts/zynq-zybo.dts | 2 +- arch/arm/dts/zynqmp-clk.dtsi | 32 +++++ arch/arm/dts/zynqmp-ep108-clk.dtsi | 48 +++++++ arch/arm/dts/zynqmp-ep108.dts | 8 +- arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts | 4 +- arch/arm/dts/zynqmp-zc1751-xm016-dc2.dts | 2 +- arch/arm/dts/zynqmp-zc1751-xm018-dc4.dts | 2 +- arch/arm/dts/zynqmp-zc1751-xm019-dc5.dts | 2 +- arch/arm/dts/zynqmp-zcu102.dts | 34 ++++- arch/arm/dts/zynqmp.dtsi | 341 ++++++++++++++++++++++++++++---------------- arch/arm/include/asm/arch-zynqmp/hardware.h | 1 + arch/arm/mach-zynq/Kconfig | 8 ++ arch/arm/mach-zynq/slcr.c | 25 ++++ board/topic/zynq/MAINTAINERS | 6 + board/topic/zynq/Makefile | 10 ++ board/topic/zynq/board.c | 1 + board/topic/zynq/ps7_init_common.c | 117 +++++++++++++++ board/topic/zynq/ps7_init_gpl.h | 34 +++++ board/topic/zynq/zynq-topic-miami/ps7_init_gpl.c | 227 +++++++++++++++++++++++++++++ board/topic/zynq/zynq-topic-miami/ps7_regs.txt | 61 ++++++++ board/topic/zynq/zynq-topic-miamiplus/ps7_init_gpl.c | 233 ++++++++++++++++++++++++++++++ board/topic/zynq/zynq-topic-miamiplus/ps7_regs.txt | 61 ++++++++ board/xilinx/zynq/board.c | 12 ++ board/xilinx/zynqmp/Makefile | 3 + board/xilinx/zynqmp/xil_io.h | 9 ++ board/xilinx/zynqmp/zynqmp.c | 21 +++ configs/topic_miami_defconfig | 49 +++++++ configs/topic_miamiplus_defconfig | 49 +++++++ configs/zynq_zc770_xm011_defconfig | 2 + drivers/mtd/nand/Kconfig | 7 + drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/arasan_nfc.c | 2 + drivers/mtd/nand/zynq_nand.c | 1186 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/net/zynq_gem.c | 16 +-- include/configs/topic_miami.h | 149 +++++++++++++++++++ include/configs/topic_miamiplus.h | 2 + include/configs/xilinx_zynqmp_ep.h | 2 +- include/configs/zynq-common.h | 7 + include/zynqmppl.h | 6 + include/zynqpl.h | 18 +++ scripts/Makefile.spl | 4 +- tools/zynqimage.c | 28 ++++ tools/zynqmpimage.c | 34 +++++ 58 files changed, 2865 insertions(+), 155 deletions(-) create mode 100644 arch/arm/dts/zynq-topic-miami.dts create mode 100644 arch/arm/dts/zynq-topic-miamiplus.dts create mode 100644 board/topic/zynq/MAINTAINERS create mode 100644 board/topic/zynq/Makefile create mode 100644 board/topic/zynq/board.c create mode 100644 board/topic/zynq/ps7_init_common.c create mode 100644 board/topic/zynq/ps7_init_gpl.h create mode 100644 board/topic/zynq/zynq-topic-miami/ps7_init_gpl.c create mode 100644 board/topic/zynq/zynq-topic-miami/ps7_regs.txt create mode 100644 board/topic/zynq/zynq-topic-miamiplus/ps7_init_gpl.c create mode 100644 board/topic/zynq/zynq-topic-miamiplus/ps7_regs.txt create mode 100644 configs/topic_miami_defconfig create mode 100644 configs/topic_miamiplus_defconfig create mode 100644 drivers/mtd/nand/zynq_nand.c create mode 100644 include/configs/topic_miami.h create mode 100644 include/configs/topic_miamiplus.h
Hi Michal
2016-11-16 2:59 GMT+09:00 Michal Simek monstr@monstr.eu:
Hi Tom,
Thanks, Michal
I thought you would pick up the following: http://patchwork.ozlabs.org/patch/681835/
Shall we ask Tom to apply it directly?
On 16.11.2016 01:26, Masahiro Yamada wrote:
Hi Michal
Hi Tom,
Thanks, Michal
It was the part of series that's why I expected it will be taken together not separately. As I see sunxi and uniphier patches are in and zynq is missing. I will take it to my branch and will send it in next PR. If Tom wants to take it directly he can - all ack lines are there already.
Thanks, Michal
On Tue, Nov 15, 2016 at 06:59:53PM +0100, Michal Simek wrote:
Hi Tom,
Thanks, Michal
Masahiro Yamada
Michal Simek
