systemd-boot counting logic requires [0] to be implemented.
Is anybody already working on this?
If not we plan to add the functionality in fs/fs.c and fs/fat - correct?
Cheers Manuel
[0] https://elixir.bootlin.com/u-boot/v2025.01-rc1/source/lib/efi_loader/efi_fil...
Hello Manuel,
On Tue, 12 Nov 2024 at 15:21, Traut Manuel LCPF-CH Manuel.Traut@mt.com wrote:
I am not aware of any patches
We don't have plans for it, but explaining any use cases you have might help
Cheers /Ilias
Cheers Manuel
On 12.11.24 14:46, Ilias Apalodimas wrote:
Hello Manuel,
Cheers /Ilias
Cheers Manuel
Hello Manuel,
The file system layer in fs/fat/fat_write.c does not support renaming, yet.
You would have to start your contributions there.
Best regards
Heinrich
Hi Ilias,
On Tue, Nov 12, 2024 at 03:46:48PM +0200, Ilias Apalodimas wrote:
Hello Manuel,
thanks for the quick response.
systemd-boot is able to do bootcounting by renaming the UKI image [0] the code that triggers the not implemented code section is here [1].
With this it is possible to have watchdog based A/B switching on systems without a writeable u-boot environment. And therefore it is a nice method to implement measured boot.
Regards Manuel
[0] https://uapi-group.org/specifications/specs/boot_loader_specification/#boot-... [1] https://github.com/systemd/systemd/blob/3304a029b847e87da51f7a8ad8c118111508...
Cheers /Ilias
Cheers Manuel
On Tue, 12 Nov 2024 at 16:22, Traut Manuel LCPF-CH Manuel.Traut@mt.com wrote:
Hi Ilias,
Hello Manuel,
The A/B is ok, but I cant understand how that realted to measured boot. The TPM access, UKI infrastucture etc, will work fine without A/B
Thanks /Ilias
Regards Manuel
Cheers /Ilias
Cheers Manuel
Yes, TPM, UKI works fine right now :)
systemd-boot is renaming the UKI before it starts it, by increasing the bootcounter that is part of the filename. If the system is fully booted the file gets renamed again to reset the bootcounter.
If the bootcounter exceeds systemd-boot tries the next UKI. The UKIs can be signed and are still valid after rename.
I expect that changes to the u-boot env will change a PCR measurement. At least it should be like this, since it might alter the boot path?
For trusted systems it would be nice to have a meaurement of the EFI variables and beside that have no dynamic environment.
Hope this explenation is understandable? Manuel
On Tue, 12 Nov 2024 at 16:55, Traut Manuel LCPF-CH Manuel.Traut@mt.com wrote:
No env changes are not and IIRC it isnt necesarry. We measure what's described in the PC client spec. So the loaded image PCRs would change, but that's a user decision (which PCRS to use and seal secrets)
We do measure EFI variables and Boot#### variables in PCR7
Hope this explanation is understandable?
Yes thanks
/Ilias
Manuel
Just to double check as I didn't find more after this thread. There was any advance regarding this topic? I might also be interested in help on this.
Thanks, Enric
On Tue, Nov 12, 2024 at 4:05 PM Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Yes thanks
/Ilias
Manuel
Enric Balletbo i Serra
Ilias Apalodimas
