[U-Boot] [PATCH v2 1/3] mx53: Allow IPUv3 driver to also work on mx53
Adjust the IPU base registers so that ipuv3 driver can work on both mx51 and mx53 SoCs.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v1: - Properly implement the IPU offset scheme.
arch/arm/include/asm/arch-mx5/imx-regs.h | 8 ++++- drivers/video/ipu_regs.h | 42 +++++++++++++++--------------- 2 files changed, 27 insertions(+), 23 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx5/imx-regs.h b/arch/arm/include/asm/arch-mx5/imx-regs.h index cef4190..88fb7cb 100644 --- a/arch/arm/include/asm/arch-mx5/imx-regs.h +++ b/arch/arm/include/asm/arch-mx5/imx-regs.h @@ -25,7 +25,8 @@
#if defined(CONFIG_MX51) #define IRAM_BASE_ADDR 0x1FFE0000 /* internal ram */ -#define IPU_CTRL_BASE_ADDR 0x40000000 +#define IPU_SOC_BASE_ADDR 0x40000000 +#define IPU_SOC_OFFSET 0x1E000000 #define SPBA0_BASE_ADDR 0x70000000 #define AIPS1_BASE_ADDR 0x73F00000 #define AIPS2_BASE_ADDR 0x83F00000 @@ -34,7 +35,8 @@ #define NFC_BASE_ADDR_AXI 0xCFFF0000 #define CS1_BASE_ADDR 0xB8000000 #elif defined(CONFIG_MX53) -#define IPU_CTRL_BASE_ADDR 0x18000000 +#define IPU_SOC_BASE_ADDR 0x18000000 +#define IPU_SOC_OFFSET 0x06000000 #define SPBA0_BASE_ADDR 0x50000000 #define AIPS1_BASE_ADDR 0x53F00000 #define AIPS2_BASE_ADDR 0x63F00000 @@ -48,6 +50,8 @@ #error "CPU_TYPE not defined" #endif
+#define IPU_CTRL_BASE_ADDR IPU_SOC_BASE_ADDR + IPU_SOC_OFFSET + #define IRAM_SIZE 0x00020000 /* 128 KB */
/* diff --git a/drivers/video/ipu_regs.h b/drivers/video/ipu_regs.h index 9964c20..93b195f 100644 --- a/drivers/video/ipu_regs.h +++ b/drivers/video/ipu_regs.h @@ -33,27 +33,27 @@ #define IPU_DISP0_BASE 0x00000000 #define IPU_MCU_T_DEFAULT 8 #define IPU_DISP1_BASE (IPU_MCU_T_DEFAULT << 25) -#define IPU_CM_REG_BASE 0x1E000000 -#define IPU_STAT_REG_BASE 0x1E000200 -#define IPU_IDMAC_REG_BASE 0x1E008000 -#define IPU_ISP_REG_BASE 0x1E010000 -#define IPU_DP_REG_BASE 0x1E018000 -#define IPU_IC_REG_BASE 0x1E020000 -#define IPU_IRT_REG_BASE 0x1E028000 -#define IPU_CSI0_REG_BASE 0x1E030000 -#define IPU_CSI1_REG_BASE 0x1E038000 -#define IPU_DI0_REG_BASE 0x1E040000 -#define IPU_DI1_REG_BASE 0x1E048000 -#define IPU_SMFC_REG_BASE 0x1E050000 -#define IPU_DC_REG_BASE 0x1E058000 -#define IPU_DMFC_REG_BASE 0x1E060000 -#define IPU_CPMEM_REG_BASE 0x1F000000 -#define IPU_LUT_REG_BASE 0x1F020000 -#define IPU_SRM_REG_BASE 0x1F040000 -#define IPU_TPM_REG_BASE 0x1F060000 -#define IPU_DC_TMPL_REG_BASE 0x1F080000 -#define IPU_ISP_TBPR_REG_BASE 0x1F0C0000 -#define IPU_VDI_REG_BASE 0x1E068000 +#define IPU_CM_REG_BASE 0x00000000 +#define IPU_STAT_REG_BASE 0x00000200 +#define IPU_IDMAC_REG_BASE 0x00008000 +#define IPU_ISP_REG_BASE 0x00010000 +#define IPU_DP_REG_BASE 0x00018000 +#define IPU_IC_REG_BASE 0x00020000 +#define IPU_IRT_REG_BASE 0x00028000 +#define IPU_CSI0_REG_BASE 0x00030000 +#define IPU_CSI1_REG_BASE 0x00038000 +#define IPU_DI0_REG_BASE 0x00040000 +#define IPU_DI1_REG_BASE 0x00048000 +#define IPU_SMFC_REG_BASE 0x00050000 +#define IPU_DC_REG_BASE 0x00058000 +#define IPU_DMFC_REG_BASE 0x00060000 +#define IPU_CPMEM_REG_BASE 0x01000000 +#define IPU_LUT_REG_BASE 0x01020000 +#define IPU_SRM_REG_BASE 0x01040000 +#define IPU_TPM_REG_BASE 0x01060000 +#define IPU_DC_TMPL_REG_BASE 0x01080000 +#define IPU_ISP_TBPR_REG_BASE 0x010C0000 +#define IPU_VDI_REG_BASE 0x00680000
extern u32 *ipu_dc_tmpl_reg;
On Tue, 15 May 2012 15:01:16 -0300 Fabio Estevam fabio.estevam@freescale.com wrote:
Changes since v1:
Applied to u-boot-video/master, thanks!
Anatolij
Anatolij Gustschin
Fabio Estevam
