[PATCH v1] [ZynqMP] Writing correct value to ANALOG_BUS.
The default register configuration after powerup for PSSYSMON_ANALOG_BUS register is incorrect. Hence, fix this in SPL by writing correct fixed value. It follows UG1085 chapter 'PS SYSMON Analog_Bus' and reflects commit sw_apps:zynq ("056ca65d44549ce27f716d423e8dfdefeee7440c") in Xilinx:embeddedsw[1].
[1] https://github.com/Xilinx/embeddedsw
Signed-off-by: Adrian Fiergolski adrian.fiergolski@fastree3d.com
--- Changes in v1: - fix patch log - based on v2021.07-rc4 branch
arch/arm/mach-zynqmp/include/mach/hardware.h | 5 +++++ board/xilinx/zynqmp/zynqmp.c | 11 +++++++++++ 2 files changed, 16 insertions(+)
diff --git a/arch/arm/mach-zynqmp/include/mach/hardware.h b/arch/arm/mach-zynqmp/include/mach/hardware.h index a0acfa2ff1..4774ed4089 100644 --- a/arch/arm/mach-zynqmp/include/mach/hardware.h +++ b/arch/arm/mach-zynqmp/include/mach/hardware.h @@ -15,6 +15,11 @@ #define ZYNQMP_CRL_APB_BOOT_PIN_CTRL_OUT_EN_SHIFT 0 #define ZYNQMP_CRL_APB_BOOT_PIN_CTRL_OUT_VAL_SHIFT 8
+#define ZYNQMP_AMS_PS_SYSMON_BASEADDR 0XFFA50800 +#define ZYNQMP_AMS_PS_SYSMON_ANALOG_BUS ((ZYNQMP_AMS_PS_SYSMON_BASEADDR) \ + + 0x00000114) +#define ZYNQMP_PS_SYSMON_ANALOG_BUS_VAL 0x00003210 + #define PS_MODE0 BIT(0) #define PS_MODE1 BIT(1) #define PS_MODE2 BIT(2)
diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index d05f0b2e12..ee4d0c85e6 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -287,6 +287,17 @@ int board_early_init_f(void) if (ret) return ret;
+ /* + * PS_SYSMON_ANALOG_BUS register determines mapping between SysMon + * supply sense channel to SysMon supply registers inside the IP. + * This register must be programmed to complete SysMon IP + * configuration. The default register configuration after + * power-up is incorrect. Hence, fix this by writing the + * correct value - 0x3210. + */ + writel(ZYNQMP_PS_SYSMON_ANALOG_BUS_VAL, + ZYNQMP_AMS_PS_SYSMON_ANALOG_BUS); + /* Delay is required for clocks to be propagated */ udelay(1000000); #endif
Changes in v1:
- fix patch log
+ 0x00000114)
- writel(ZYNQMP_PS_SYSMON_ANALOG_BUS_VAL,
- /* Delay is required for clocks to be propagated */ udelay(1000000);
#endif
I have added arm64: zynqmp: to subject and applied.
Thanks, Michal
Adrian Fiergolski
Michal Simek
