[PATCH] driver: video: Check allocated pointers
The codes that call STBTT_malloc() / stbtt__new_active() do not check the return value at present which may cause segfault.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
drivers/video/stb_truetype.h | 18 ++++++++++++++---- 1 file changed, 14 insertions(+), 4 deletions(-)
diff --git a/drivers/video/stb_truetype.h b/drivers/video/stb_truetype.h index 26f4ac2ca8..438bfce468 100644 --- a/drivers/video/stb_truetype.h +++ b/drivers/video/stb_truetype.h @@ -1768,10 +1768,13 @@ static void stbtt__rasterize_sorted_edges(stbtt__bitmap *result, stbtt__edge *e, int s; // vertical subsample index unsigned char scanline_data[512], *scanline;
- if (result->w > 512) + if (result->w > 512) { scanline = (unsigned char *) STBTT_malloc(result->w, userdata); - else + if (!scanline) + return; + } else { scanline = scanline_data; + }
y = off_y * vsubsample; e[n].y0 = (off_y + result->h) * (float) vsubsample + 1; @@ -1821,6 +1824,8 @@ static void stbtt__rasterize_sorted_edges(stbtt__bitmap *result, stbtt__edge *e, while (e->y0 <= scan_y) { if (e->y1 > scan_y) { stbtt__active_edge *z = stbtt__new_active(&hh, e, off_x, scan_y, userdata); + if (!z) + return; // find insertion point if (active == NULL) active = z; @@ -2068,10 +2073,13 @@ static void stbtt__rasterize_sorted_edges(stbtt__bitmap *result, stbtt__edge *e, int y,j=0, i; float scanline_data[129], *scanline, *scanline2;
- if (result->w > 64) + if (result->w > 64) { scanline = (float *) STBTT_malloc((result->w*2+1) * sizeof(float), userdata); - else + if (!scanline) + return; + } else { scanline = scanline_data; + }
scanline2 = scanline + result->w;
@@ -2105,6 +2113,8 @@ static void stbtt__rasterize_sorted_edges(stbtt__bitmap *result, stbtt__edge *e, while (e->y0 <= scan_y_bottom) { if (e->y0 != e->y1) { stbtt__active_edge *z = stbtt__new_active(&hh, e, off_x, scan_y_top, userdata); + if (!z) + return; STBTT_assert(z->ey >= scan_y_top); // insert at front z->next = active;
applied to u-boot-video/master, thanks!
-- Anatolij
Anatolij Gustschin
Bin Meng
