[U-Boot] [PATCH 0/6] driver model bring-up of sata device on dra72 and dra74 evm
This patch series enables sata driver to adopt driver model. This has been tested on the following evms (logs [1]) by loading kernel and dtb from sata hard-disk. * dra72 evm * dra74 evm
Also pushed a branch for testing [2]
[1] - http://pastebin.ubuntu.com/14565924/ [2] - git://git.ti.com/~mugunthanvnm/ti-u-boot/mugunth-ti-u-boot.git dm-sata
Mugunthan V N (6): arm: omap: sata: move enable sata clocks to enable_basic_clocks() dm: implement a SATA uclass arm: omap-common: sata: prepare driver for DM conversion drivers: block: dwc_ahci: Implement a driver for Synopsys DWC sata device defconfig: dra74_evm: enable sata driver model defconfig: dra72_evm: enable sata driver model
arch/arm/cpu/armv7/omap-common/sata.c | 38 ++++++------------- arch/arm/cpu/armv7/omap5/hw_data.c | 12 ++++++ configs/dra72_evm_defconfig | 2 + configs/dra74_evm_defconfig | 2 + drivers/block/Kconfig | 17 +++++++++ drivers/block/Makefile | 3 ++ drivers/block/dwc_ahci.c | 71 +++++++++++++++++++++++++++++++++++ drivers/block/sata-uclass.c | 69 ++++++++++++++++++++++++++++++++++ include/dm/uclass-id.h | 1 + include/sata.h | 2 + 10 files changed, 190 insertions(+), 27 deletions(-) create mode 100644 drivers/block/dwc_ahci.c create mode 100644 drivers/block/sata-uclass.c
All the clocks which has to be enabled has to be done in enable_basic_clocks(), so moving enable sata clock to common clocks enable function.
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- arch/arm/cpu/armv7/omap-common/sata.c | 23 ----------------------- arch/arm/cpu/armv7/omap5/hw_data.c | 12 ++++++++++++ 2 files changed, 12 insertions(+), 23 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap-common/sata.c b/arch/arm/cpu/armv7/omap-common/sata.c index 2c2d1bc..0c82689 100644 --- a/arch/arm/cpu/armv7/omap-common/sata.c +++ b/arch/arm/cpu/armv7/omap-common/sata.c @@ -37,29 +37,6 @@ int init_sata(int dev) int ret; u32 val;
- u32 const clk_domains_sata[] = { - 0 - }; - - u32 const clk_modules_hw_auto_sata[] = { - (*prcm)->cm_l3init_ocp2scp3_clkctrl, - 0 - }; - - u32 const clk_modules_explicit_en_sata[] = { - (*prcm)->cm_l3init_sata_clkctrl, - 0 - }; - - do_enable_clocks(clk_domains_sata, - clk_modules_hw_auto_sata, - clk_modules_explicit_en_sata, - 0); - - /* Enable optional functional clock for SATA */ - setbits_le32((*prcm)->cm_l3init_sata_clkctrl, - SATA_CLKCTRL_OPTFCLKEN_MASK); - sata_phy.power_reg = (void __iomem *)(*ctrl)->control_phy_power_sata;
/* Power up the PHY */ diff --git a/arch/arm/cpu/armv7/omap5/hw_data.c b/arch/arm/cpu/armv7/omap5/hw_data.c index 7f8c0a4..2e554bd 100644 --- a/arch/arm/cpu/armv7/omap5/hw_data.c +++ b/arch/arm/cpu/armv7/omap5/hw_data.c @@ -460,6 +460,9 @@ void enable_basic_clocks(void) (*prcm)->cm_l4per_gpio6_clkctrl, (*prcm)->cm_l4per_gpio7_clkctrl, (*prcm)->cm_l4per_gpio8_clkctrl, +#ifdef CONFIG_SCSI_AHCI_PLAT + (*prcm)->cm_l3init_ocp2scp3_clkctrl, +#endif 0 };
@@ -478,6 +481,9 @@ void enable_basic_clocks(void) #ifdef CONFIG_TI_QSPI (*prcm)->cm_l4per_qspi_clkctrl, #endif +#ifdef CONFIG_SCSI_AHCI_PLAT + (*prcm)->cm_l3init_sata_clkctrl, +#endif 0 };
@@ -510,6 +516,12 @@ void enable_basic_clocks(void) setbits_le32((*prcm)->cm_l4per_qspi_clkctrl, (1<<24)); #endif
+#ifdef CONFIG_SCSI_AHCI_PLAT + /* Enable optional functional clock for SATA */ + setbits_le32((*prcm)->cm_l3init_sata_clkctrl, + SATA_CLKCTRL_OPTFCLKEN_MASK); +#endif + /* Enable SCRM OPT clocks for PER and CORE dpll */ setbits_le32((*prcm)->cm_wkupaon_scrm_clkctrl, OPTFCLKEN_SCRM_PER_MASK);
Implement a SATA uclass that can represent a SATA controller.
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- drivers/block/Kconfig | 10 +++++++ drivers/block/Makefile | 2 ++ drivers/block/sata-uclass.c | 69 +++++++++++++++++++++++++++++++++++++++++++++ include/dm/uclass-id.h | 1 + 4 files changed, 82 insertions(+) create mode 100644 drivers/block/sata-uclass.c
diff --git a/drivers/block/Kconfig b/drivers/block/Kconfig index e69de29..44d8a6b 100644 --- a/drivers/block/Kconfig +++ b/drivers/block/Kconfig @@ -0,0 +1,10 @@ +menu "SATA Device Support" + +config SATA + bool "Enable driver model for SATA drivers" + depends on DM + help + Enable driver model for block devices like SCSI. It uses the + same API as block, but now implemented by the uclass. + +endmenu diff --git a/drivers/block/Makefile b/drivers/block/Makefile index eb8bda9..c2dae17 100644 --- a/drivers/block/Makefile +++ b/drivers/block/Makefile @@ -5,6 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
+obj-$(CONFIG_SATA) += sata-uclass.o + obj-$(CONFIG_SCSI_AHCI) += ahci.o obj-$(CONFIG_DWC_AHSATA) += dwc_ahsata.o obj-$(CONFIG_FSL_SATA) += fsl_sata.o diff --git a/drivers/block/sata-uclass.c b/drivers/block/sata-uclass.c new file mode 100644 index 0000000..62773b6 --- /dev/null +++ b/drivers/block/sata-uclass.c @@ -0,0 +1,69 @@ +/* + * SATA device U-Class driver + * + * (C) Copyright 2016 + * Texas Instruments Incorporated, <www.ti.com> + * + * Author: Mugunthan V N mugunthanvnm@ti.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <dm/uclass-internal.h> +#include <dm/device-internal.h> +#include <errno.h> +#include <scsi.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * struct mmc_uclass_priv - Holds information about a device used by the uclass + */ +struct sata_uclass_priv { + struct block_dev_desc_t *block_dev; +}; + +int scsi_get_device(int index, struct udevice **devp) +{ + struct udevice *dev; + int ret; + + ret = uclass_find_device(UCLASS_SATA, index, &dev); + if (ret || !dev) { + printf("%d device not found\n", index); + return ret; + } + + ret = device_probe(dev); + if (ret) { + error("device probe error\n"); + return ret; + } + + *devp = dev; + + return ret; +} + +void scsi_init(void) +{ + struct udevice *dev; + int ret; + + ret = scsi_get_device(0, &dev); + if (ret || !dev) { + error("scsi device not found\n"); + return; + } + + scsi_scan(1); +} + +UCLASS_DRIVER(sata) = { + .id = UCLASS_SATA, + .name = "sata", + .flags = DM_UC_FLAG_SEQ_ALIAS, + .per_device_auto_alloc_size = sizeof(struct sata_uclass_priv), +}; diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index 27fa0b6..80977ca 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -55,6 +55,7 @@ enum uclass_id { UCLASS_RESET, /* Reset device */ UCLASS_REMOTEPROC, /* Remote Processor device */ UCLASS_RTC, /* Real time clock device */ + UCLASS_SATA, /* SATA devices */ UCLASS_SERIAL, /* Serial UART */ UCLASS_SPI, /* SPI bus */ UCLASS_SPI_FLASH, /* SPI flash */
+Simon
+config SATA
depends on DM
help
- SATA device U-Class driver
- (C) Copyright 2016
- Author: Mugunthan V N mugunthanvnm@ti.com
- struct mmc_uclass_priv - Holds information about a device used by the uclass
Please use single-line comment when it fits just one line. Also it's not mmc.
int ret;
if (ret || !dev) {
return ret;
if (ret) {
return ret;
*devp = dev;
return ret;
int ret;
if (ret || !dev) {
return;
scsi_scan(1);
.id = UCLASS_SATA,
.name = "sata",
I would like to see a full DM conversion of the SCSI codes. But this patch looks to me it's just a place holder?
Regards, Bin
On Monday 18 January 2016 02:53 PM, Bin Meng wrote:
+Simon
+config SATA
depends on DM
help
Will fix it in next version.
int ret;
if (ret || !dev) {
return ret;
if (ret) {
return ret;
*devp = dev;
return ret;
int ret;
if (ret || !dev) {
return;
scsi_scan(1);
.id = UCLASS_SATA,
.name = "sata",
Ultimately that will be the final goal, now this is just a place holder to move towards DM conversion.
Regards Mugunthan V N
+Simon
+config SATA
depends on DM
help
int ret;
if (ret || !dev) {
return ret;
if (ret) {
return ret;
*devp = dev;
return ret;
int ret;
if (ret || !dev) {
return;
scsi_scan(1);
.id = UCLASS_SATA,
.name = "sata",
I have a series which adds a disk uclass. It was using AHCI (=SATA) but Bin pointed out that this might be too specific.
So perhaps you should use that?
http://patchwork.ozlabs.org/patch/569381/
Prepare sata driver for DM conversion by abstracting sata phy init to seperate function.
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- arch/arm/cpu/armv7/omap-common/sata.c | 13 +++++++++---- include/sata.h | 2 ++ 2 files changed, 11 insertions(+), 4 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap-common/sata.c b/arch/arm/cpu/armv7/omap-common/sata.c index 0c82689..5ebd799 100644 --- a/arch/arm/cpu/armv7/omap-common/sata.c +++ b/arch/arm/cpu/armv7/omap-common/sata.c @@ -32,15 +32,20 @@ struct omap_pipe3 sata_phy = { .dpll_map = dpll_map_sata, };
+int enable_sata_phy(void) +{ + sata_phy.power_reg = (void __iomem *)(*ctrl)->control_phy_power_sata; + + /* Power up the PHY */ + return phy_pipe3_power_on(&sata_phy); +} + int init_sata(int dev) { int ret; u32 val;
- sata_phy.power_reg = (void __iomem *)(*ctrl)->control_phy_power_sata; - - /* Power up the PHY */ - phy_pipe3_power_on(&sata_phy); + enable_sata_phy();
/* Enable SATA module, No Idle, No Standby */ val = TI_SATA_IDLE_NO | TI_SATA_STANDBY_NO; diff --git a/include/sata.h b/include/sata.h index fa61da8..c2b5360 100644 --- a/include/sata.h +++ b/include/sata.h @@ -16,4 +16,6 @@ int sata_port_status(int dev, int port);
extern block_dev_desc_t sata_dev_desc[];
+int enable_sata_phy(void); + #endif
Implement a sata driver for Synopsys DWC sata device based on U-boot driver model.
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- arch/arm/cpu/armv7/omap-common/sata.c | 2 + drivers/block/Kconfig | 7 ++++ drivers/block/Makefile | 1 + drivers/block/dwc_ahci.c | 71 +++++++++++++++++++++++++++++++++++ 4 files changed, 81 insertions(+) create mode 100644 drivers/block/dwc_ahci.c
diff --git a/arch/arm/cpu/armv7/omap-common/sata.c b/arch/arm/cpu/armv7/omap-common/sata.c index 5ebd799..e47e01b 100644 --- a/arch/arm/cpu/armv7/omap-common/sata.c +++ b/arch/arm/cpu/armv7/omap-common/sata.c @@ -40,6 +40,7 @@ int enable_sata_phy(void) return phy_pipe3_power_on(&sata_phy); }
+#ifndef CONFIG_SATA int init_sata(int dev) { int ret; @@ -73,3 +74,4 @@ void scsi_bus_reset(void) ahci_reset((void __iomem *)DWC_AHSATA_BASE); ahci_init((void __iomem *)DWC_AHSATA_BASE); } +#endif diff --git a/drivers/block/Kconfig b/drivers/block/Kconfig index 44d8a6b..6b94c3f 100644 --- a/drivers/block/Kconfig +++ b/drivers/block/Kconfig @@ -7,4 +7,11 @@ config SATA Enable driver model for block devices like SCSI. It uses the same API as block, but now implemented by the uclass.
+config DWC_AHCI + bool "Enable Synopsys DWC AHCI driver support" + depends on SATA + help + Enable this driver to support Sata devices through + Synopsys DWC AHCI module. + endmenu diff --git a/drivers/block/Makefile b/drivers/block/Makefile index c2dae17..189d17f 100644 --- a/drivers/block/Makefile +++ b/drivers/block/Makefile @@ -6,6 +6,7 @@ #
obj-$(CONFIG_SATA) += sata-uclass.o +obj-$(CONFIG_DWC_AHCI) += dwc_ahci.o
obj-$(CONFIG_SCSI_AHCI) += ahci.o obj-$(CONFIG_DWC_AHSATA) += dwc_ahsata.o diff --git a/drivers/block/dwc_ahci.c b/drivers/block/dwc_ahci.c new file mode 100644 index 0000000..b6c3bba --- /dev/null +++ b/drivers/block/dwc_ahci.c @@ -0,0 +1,71 @@ +/* + * DWC SATA platform driver + * + * (C) Copyright 2016 + * Texas Instruments Incorporated, <www.ti.com> + * + * Author: Mugunthan V N mugunthanvnm@ti.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <ahci.h> +#include <sata.h> +#include <asm/arch/sata.h> +#include <asm/io.h> + +struct dwc_ahci_priv { + void *base; + void *wrapper_base; +}; + +static int dwc_ahci_ofdata_to_platdata(struct udevice *dev) +{ + struct dwc_ahci_priv *priv = dev_get_priv(dev); + fdt_addr_t addr; + + priv->base = (void *)dev_get_addr(dev); + + addr = dev_get_addr_index(dev, 1); + priv->wrapper_base = (addr != FDT_ADDR_T_NONE) ? (void *)addr : NULL; + + return 0; +} + +static int dwc_ahci_probe(struct udevice *dev) +{ + struct dwc_ahci_priv *priv = dev_get_priv(dev); + int ret; + + if (priv->wrapper_base) { + u32 val = TI_SATA_IDLE_NO | TI_SATA_STANDBY_NO; + + /* Enable SATA module, No Idle, No Standby */ + writel(val, priv->wrapper_base + TI_SATA_SYSCONFIG); + } + + ret = enable_sata_phy(); + if (ret) { + error("Sata phy enable failed\n"); + return ret; + } + + return ahci_init(priv->base); +} + +static const struct udevice_id dwc_ahci_ids[] = { + { .compatible = "snps,dwc-ahci" }, + { } +}; + +U_BOOT_DRIVER(dwc_ahci) = { + .name = "dwc_ahci", + .id = UCLASS_SATA, + .of_match = dwc_ahci_ids, + .ofdata_to_platdata = dwc_ahci_ofdata_to_platdata, + .probe = dwc_ahci_probe, + .priv_auto_alloc_size = sizeof(struct dwc_ahci_priv), + .flags = DM_FLAG_ALLOC_PRIV_DMA, +};
Enable sata driver model for dra74_evm as dwc_ahci supports driver model
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- configs/dra74_evm_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/dra74_evm_defconfig b/configs/dra74_evm_defconfig index 6e5a705..18bb950 100644 --- a/configs/dra74_evm_defconfig +++ b/configs/dra74_evm_defconfig @@ -21,3 +21,5 @@ CONFIG_SYS_NS16550=y CONFIG_TI_QSPI=y CONFIG_DM_SPI=y CONFIG_DM_SPI_FLASH=y +CONFIG_SATA=y +CONFIG_DWC_AHCI=y
Enable sata driver model for dra72_evm as dwc_ahci supports driver model
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- configs/dra72_evm_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/dra72_evm_defconfig b/configs/dra72_evm_defconfig index b57ecca..b22438e 100644 --- a/configs/dra72_evm_defconfig +++ b/configs/dra72_evm_defconfig @@ -22,3 +22,5 @@ CONFIG_SYS_NS16550=y CONFIG_TI_QSPI=y CONFIG_DM_SPI=y CONFIG_DM_SPI_FLASH=y +CONFIG_SATA=y +CONFIG_DWC_AHCI=y
Bin Meng
Mugunthan V N
