[PATCH 1/1] test: test_efi_fit: fix pylint warnings
Fix warnings issued by pylint:
* naming of variables * usage of commas and semicolons * indentation * placement of module description
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- test/py/tests/test_efi_fit.py | 77 ++++++++++++++++++----------------- 1 file changed, 39 insertions(+), 38 deletions(-)
diff --git a/test/py/tests/test_efi_fit.py b/test/py/tests/test_efi_fit.py index 6986b2d35c..beaf4a3c51 100644 --- a/test/py/tests/test_efi_fit.py +++ b/test/py/tests/test_efi_fit.py @@ -9,10 +9,6 @@ # # Test launching UEFI binaries from FIT images.
-import os.path -import pytest -import u_boot_utils as util - """ Note: This test relies on boardenv_* containing configuration values to define which network environment is available for testing. Without this, the parts @@ -57,8 +53,12 @@ env__efi_fit_tftp_file = { } """
+import os.path +import pytest +import u_boot_utils as util + # Define the parametrized ITS data to be used for FIT images generation. -its_data = ''' +ITS_DATA = ''' /dts-v1/;
/ { @@ -101,7 +101,7 @@ its_data = ''' '''
# Define the parametrized FDT data to be used for DTB images generation. -fdt_data = ''' +FDT_DATA = ''' /dts-v1/;
/ { @@ -199,16 +199,16 @@ def test_efi_fit_launch(u_boot_console): cons.run_command('setenv %s %s' % (var, val)) return True
- def make_fpath(fname): + def make_fpath(file_name): """Compute the path of a given (temporary) file.
Args: - fname: The name of a file within U-Boot build dir. + file_name: The name of a file within U-Boot build dir. Return: The computed file path. """
- return os.path.join(cons.config.build_dir, fname) + return os.path.join(cons.config.build_dir, file_name)
def make_efi(fname, comp): """Create an UEFI binary. @@ -225,7 +225,8 @@ def test_efi_fit_launch(u_boot_console):
bin_path = make_fpath(fname) util.run_and_log(cons, - ['cp', make_fpath('lib/efi_loader/helloworld.efi'), bin_path]) + ['cp', make_fpath('lib/efi_loader/helloworld.efi'), + bin_path]) if comp: util.run_and_log(cons, ['gzip', '-f', bin_path]) bin_path += '.gz' @@ -251,8 +252,8 @@ def test_efi_fit_launch(u_boot_console):
# Generate a test FDT file. dts = make_fpath('test-efi-fit-%s.dts' % fdt_type) - with open(dts, 'w') as fd: - fd.write(fdt_data % fdt_params) + with open(dts, 'w') as file: + file.write(FDT_DATA % fdt_params)
# Build the test FDT. dtb = make_fpath('test-efi-fit-%s.dtb' % fdt_type) @@ -284,65 +285,65 @@ def test_efi_fit_launch(u_boot_console):
# Generate a test ITS file. its_path = make_fpath('test-efi-fit-helloworld.its') - with open(its_path, 'w') as fd: - fd.write(its_data % its_params) + with open(its_path, 'w') as file: + file.write(ITS_DATA % its_params)
# Build the test ITS. fit_path = make_fpath('test-efi-fit-helloworld.fit') util.run_and_log( - cons, [make_fpath('tools/mkimage'), '-f', its_path, fit_path]) + cons, [make_fpath('tools/mkimage'), '-f', its_path, fit_path]) return fit_path
- def load_fit_from_host(f): + def load_fit_from_host(fit): """Load the FIT image using the 'host load' command and return its address.
Args: - f: Dictionary describing the FIT image to load, see env__efi_fit_test_file - in the comment at the beginning of this file. + fit: Dictionary describing the FIT image to load, see env__efi_fit_test_file + in the comment at the beginning of this file. Return: The address where the file has been loaded. """
- addr = f.get('addr', None) + addr = fit.get('addr', None) if not addr: addr = util.find_ram_base(cons)
output = cons.run_command( - 'host load hostfs - %x %s/%s' % (addr, f['dn'], f['fn'])) + 'host load hostfs - %x %s/%s' % (addr, fit['dn'], fit['fn'])) expected_text = ' bytes read' - sz = f.get('size', None) - if sz: - expected_text = '%d' % sz + expected_text - assert(expected_text in output) + size = fit.get('size', None) + if size: + expected_text = '%d' % size + expected_text + assert expected_text in output
return addr
- def load_fit_from_tftp(f): + def load_fit_from_tftp(fit): """Load the FIT image using the tftpboot command and return its address.
The file is downloaded from the TFTP server, its size and optionally its CRC32 are validated.
Args: - f: Dictionary describing the FIT image to load, see env__efi_fit_tftp_file - in the comment at the beginning of this file. + fit: Dictionary describing the FIT image to load, see env__efi_fit_tftp_file + in the comment at the beginning of this file. Return: The address where the file has been loaded. """
- fn = f['fn'] - output = cons.run_command('tftpboot %x %s' % (addr, fn)) + file_name = fit['fn'] + output = cons.run_command('tftpboot %x %s' % (addr, file_name)) expected_text = 'Bytes transferred = ' - sz = f.get('size', None) - if sz: - expected_text += '%d' % sz + size = fit.get('size', None) + if size: + expected_text += '%d' % size assert expected_text in output
- expected_crc = f.get('crc32', None) + expected_crc = fit.get('crc32', None) if not expected_crc: return addr
@@ -398,8 +399,8 @@ def test_efi_fit_launch(u_boot_console): if not fit: pytest.skip('No env__efi_fit_tftp_file binary specified in environment')
- sz = fit.get('size', None) - if not sz: + size = fit.get('size', None) + if not size: if not fit.get('dn', None): pytest.skip('Neither "size", nor "dn" info provided in env__efi_fit_tftp_file')
@@ -420,12 +421,12 @@ def test_efi_fit_launch(u_boot_console):
# Try booting. cons.run_command( - 'bootm %x#%s' % (addr, fit_config), wait_for_prompt=False) + 'bootm %x#%s' % (addr, fit_config), wait_for_prompt=False) if enable_fdt: cons.wait_for('Booting using the fdt blob') cons.wait_for('Hello, world') cons.wait_for('## Application terminated, r = 0') - cons.restart_uboot(); + cons.restart_uboot()
cons = u_boot_console # Array slice removes leading/trailing quotes. -- 2.24.1
