[U-Boot] [PATCH] video: bcm2835: fix build issues
After merging LCD patches for v2013.04 the bcm2835 video driver building is broken due to removal of many global variables. Fix the driver.
Signed-off-by: Anatolij Gustschin agust@denx.de Cc: Stephen Warren swarren@wwwdotorg.org --- common/lcd.c | 12 ++++++++++++ drivers/video/bcm2835.c | 11 ----------- 2 files changed, 12 insertions(+), 11 deletions(-)
diff --git a/common/lcd.c b/common/lcd.c index b98eea6..b81be31 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -493,6 +493,18 @@ static int lcd_init(void *lcdbase) debug("[LCD] Initializing LCD frambuffer at %p\n", lcdbase);
lcd_ctrl_init(lcdbase); + + /* + * lcd_ctrl_init() of some drivers (i.e. bcm2835 on rpi_b) ignores + * the 'lcdbase' argument and uses custom lcd base address + * by setting up gd->fb_base. Check for this condition and fixup + * 'lcd_base' address. + */ + if ((unsigned long)lcdbase != gd->fb_base) + lcd_base = (void *)gd->fb_base; + + debug("[LCD] Using LCD frambuffer at %p\n", lcd_base); + lcd_get_size(&lcd_line_length); lcd_line_length = (panel_info.vl_col * NBITS(panel_info.vl_bpix)) / 8; lcd_is_enabled = 1; diff --git a/drivers/video/bcm2835.c b/drivers/video/bcm2835.c index 1e9a84a..0c77d17 100644 --- a/drivers/video/bcm2835.c +++ b/drivers/video/bcm2835.c @@ -23,17 +23,7 @@ DECLARE_GLOBAL_DATA_PTR;
/* Global variables that lcd.c expects to exist */ -int lcd_line_length; -int lcd_color_fg; -int lcd_color_bg; -void *lcd_base; -void *lcd_console_address; -short console_col; -short console_row; vidinfo_t panel_info; -char lcd_cursor_enabled; -ushort lcd_cursor_width; -ushort lcd_cursor_height;
struct msg_query { struct bcm2835_mbox_hdr hdr; @@ -119,7 +109,6 @@ void lcd_ctrl_init(void *lcdbase) panel_info.vl_bpix = LCD_COLOR16;
gd->fb_base = msg_setup->allocate_buffer.body.resp.fb_address; - lcd_base = (void *)gd->fb_base; }
void lcd_enable(void)
applied to u-boot-video/master.
Anatolij
FYI, I just tested these patches as they exist in u-boot/master, and the RPi "LCD" support still works fine after these patches. Thanks.
On Mon, 01 Apr 2013 20:54:25 -0600 Stephen Warren swarren@wwwdotorg.org wrote: ...
Thanks for testing!
Anatolij
Anatolij Gustschin
Stephen Warren
