[PATCH] caam: Fix crash in case caam_jr_probe failed
If probing caam_jr returns failure, the variable "dev" will not be initialized, so we can't use dev->name for the error print. Otherwise it will cause crash.
Signed-off-by: Ye Li ye.li@nxp.com Reviewed-by: Gaurav Jain gaurav.jain@nxp.com --- arch/arm/cpu/armv7/ls102xa/cpu.c | 2 +- arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 2 +- arch/arm/mach-imx/imx8/cpu.c | 2 +- arch/arm/mach-imx/imx8m/soc.c | 2 +- arch/arm/mach-imx/mx6/soc.c | 2 +- arch/arm/mach-imx/mx7/soc.c | 2 +- arch/arm/mach-imx/mx7ulp/soc.c | 2 +- arch/powerpc/cpu/mpc85xx/cpu_init.c | 2 +- board/freescale/imx8mm_evk/spl.c | 2 +- board/freescale/imx8mn_evk/spl.c | 2 +- board/freescale/imx8mp_evk/spl.c | 2 +- 11 files changed, 11 insertions(+), 11 deletions(-)
diff --git a/arch/arm/cpu/armv7/ls102xa/cpu.c b/arch/arm/cpu/armv7/ls102xa/cpu.c index 9fe1cd9048..0b3e3b2064 100644 --- a/arch/arm/cpu/armv7/ls102xa/cpu.c +++ b/arch/arm/cpu/armv7/ls102xa/cpu.c @@ -409,7 +409,7 @@ int arch_misc_init(void)
ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(caam_jr), &dev); if (ret) - printf("Failed to initialize %s: %d\n", dev->name, ret); + printf("Failed to initialize caam_jr: %d\n", ret); }
return 0; diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index a71ee636af..253008a9c1 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -1648,7 +1648,7 @@ int arch_misc_init(void)
ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(caam_jr), &dev); if (ret) - printf("Failed to initialize %s: %d\n", dev->name, ret); + printf("Failed to initialize caam_jr: %d\n", ret); } serdes_misc_init();
diff --git a/arch/arm/mach-imx/imx8/cpu.c b/arch/arm/mach-imx/imx8/cpu.c index 0858ea5f05..936c8f865a 100644 --- a/arch/arm/mach-imx/imx8/cpu.c +++ b/arch/arm/mach-imx/imx8/cpu.c @@ -100,7 +100,7 @@ int arch_misc_init(void)
return 0; diff --git a/arch/arm/mach-imx/imx8m/soc.c b/arch/arm/mach-imx/imx8m/soc.c index 8e23e6da32..66d6a21655 100644 --- a/arch/arm/mach-imx/imx8m/soc.c +++ b/arch/arm/mach-imx/imx8m/soc.c @@ -1410,7 +1410,7 @@ int arch_misc_init(void)
return 0; diff --git a/arch/arm/mach-imx/mx6/soc.c b/arch/arm/mach-imx/mx6/soc.c index 2434bcfa98..67bd991989 100644 --- a/arch/arm/mach-imx/mx6/soc.c +++ b/arch/arm/mach-imx/mx6/soc.c @@ -744,7 +744,7 @@ int arch_misc_init(void)
ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(caam_jr), &dev); if (ret) - printf("Failed to initialize %s: %d\n", dev->name, ret); + printf("Failed to initialize caam_jr: %d\n", ret); } setup_serial_number(); return 0; diff --git a/arch/arm/mach-imx/mx7/soc.c b/arch/arm/mach-imx/mx7/soc.c index dc9ac31eb0..c672be5d5d 100644 --- a/arch/arm/mach-imx/mx7/soc.c +++ b/arch/arm/mach-imx/mx7/soc.c @@ -361,7 +361,7 @@ int arch_misc_init(void) int ret; ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(caam_jr), &dev); if (ret) - printf("Failed to initialize %s: %d\n", dev->name, ret); + printf("Failed to initialize caam_jr: %d\n", ret); }
return 0; diff --git a/arch/arm/mach-imx/mx7ulp/soc.c b/arch/arm/mach-imx/mx7ulp/soc.c index 08bdc0c4af..217b7c4586 100644 --- a/arch/arm/mach-imx/mx7ulp/soc.c +++ b/arch/arm/mach-imx/mx7ulp/soc.c @@ -93,7 +93,7 @@ int arch_misc_init(void)
return 0; diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index 16981de244..5fa4234fd0 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -950,7 +950,7 @@ int arch_misc_init(void)
return 0; diff --git a/board/freescale/imx8mm_evk/spl.c b/board/freescale/imx8mm_evk/spl.c index 7eeec6c485..a2b95effad 100644 --- a/board/freescale/imx8mm_evk/spl.c +++ b/board/freescale/imx8mm_evk/spl.c @@ -57,7 +57,7 @@ void spl_board_init(void)
ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(caam_jr), &dev); if (ret) - printf("Failed to initialize %s: %d\n", dev->name, ret); + printf("Failed to initialize caam_jr: %d\n", ret); } puts("Normal Boot\n"); } diff --git a/board/freescale/imx8mn_evk/spl.c b/board/freescale/imx8mn_evk/spl.c index 63f335be3b..4b9683dff9 100644 --- a/board/freescale/imx8mn_evk/spl.c +++ b/board/freescale/imx8mn_evk/spl.c @@ -52,7 +52,7 @@ void spl_board_init(void) if (IS_ENABLED(CONFIG_FSL_CAAM)) { ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(caam_jr), &dev); if (ret) - printf("Failed to initialize %s: %d\n", dev->name, ret); + printf("Failed to initialize caam_jr: %d\n", ret); } puts("Normal Boot\n");
diff --git a/board/freescale/imx8mp_evk/spl.c b/board/freescale/imx8mp_evk/spl.c index 503a752ae9..36780ed520 100644 --- a/board/freescale/imx8mp_evk/spl.c +++ b/board/freescale/imx8mp_evk/spl.c @@ -43,7 +43,7 @@ void spl_board_init(void)
ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(caam_jr), &dev); if (ret) - printf("Failed to initialize %s: %d\n", dev->name, ret); + printf("Failed to initialize caam_jr: %d\n", ret); } /* * Set GIC clock to 500Mhz for OD VDD_SOC. Kernel driver does
From: Ye Li ye.li@nxp.com If probing caam_jr returns failure, the variable "dev" will not be initialized, so we can't use dev->name for the error print. Otherwise it will cause crash. Signed-off-by: Ye Li ye.li@nxp.com Reviewed-by: Gaurav Jain gaurav.jain@nxp.com
Best regards, Stefano Babic
Gaurav Jain
sbabic@denx.de
