[U-Boot] [PATCH V2 0/3] Add support for MB86R0x SoCs
This patchset adds support for MB86R0x SoC familiy from Fujitsu, its built in lcd controller and a first board using the MB86R01.
Changes since V2 - Rebased to current u-boot next branch
Changes since V1 - Used C structs for addressing instead of base + offset - Moved offsets for assmebler code to asm-offsets.h - Moved some dublicated sections of code to functions
Matthias Weisser (3): arm: Add support for MB86R0x SoCs video: add support for display controller in MB86R0x SoCs arm: Add support for jadecpu board based on MB86R01 SoC
MAINTAINERS | 4 + MAKEALL | 1 + arch/arm/cpu/arm926ejs/mb86r0x/Makefile | 47 ++ arch/arm/cpu/arm926ejs/mb86r0x/reset.c | 40 ++ arch/arm/cpu/arm926ejs/mb86r0x/timer.c | 139 ++++++ arch/arm/include/asm/arch-mb86r0x/asm-offsets.h | 74 +++ arch/arm/include/asm/arch-mb86r0x/hardware.h | 31 ++ arch/arm/include/asm/arch-mb86r0x/mb86r0x.h | 561 +++++++++++++++++++++++ board/syteco/jadecpu/Makefile | 55 +++ board/syteco/jadecpu/config.mk | 1 + board/syteco/jadecpu/jadecpu.c | 171 +++++++ board/syteco/jadecpu/lowlevel_init.S | 266 +++++++++++ boards.cfg | 1 + common/serial.c | 6 +- drivers/video/Makefile | 1 + drivers/video/mb86r0xgdc.c | 186 ++++++++ include/configs/jadecpu.h | 283 ++++++++++++ include/serial.h | 6 +- tools/Makefile | 3 + tools/logos/syteco.bmp | Bin 0 -> 11414 bytes 20 files changed, 1870 insertions(+), 6 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/mb86r0x/Makefile create mode 100644 arch/arm/cpu/arm926ejs/mb86r0x/reset.c create mode 100644 arch/arm/cpu/arm926ejs/mb86r0x/timer.c create mode 100644 arch/arm/include/asm/arch-mb86r0x/asm-offsets.h create mode 100644 arch/arm/include/asm/arch-mb86r0x/hardware.h create mode 100644 arch/arm/include/asm/arch-mb86r0x/mb86r0x.h create mode 100644 board/syteco/jadecpu/Makefile create mode 100644 board/syteco/jadecpu/config.mk create mode 100644 board/syteco/jadecpu/jadecpu.c create mode 100644 board/syteco/jadecpu/lowlevel_init.S create mode 100644 drivers/video/mb86r0xgdc.c create mode 100644 include/configs/jadecpu.h create mode 100644 tools/logos/syteco.bmp
This patch adds support for MB86R0x SoCs from Fujitsu
Signed-off-by: Matthias Weisser weisserm@arcor.de --- arch/arm/cpu/arm926ejs/mb86r0x/Makefile | 47 ++ arch/arm/cpu/arm926ejs/mb86r0x/reset.c | 40 ++ arch/arm/cpu/arm926ejs/mb86r0x/timer.c | 139 ++++++ arch/arm/include/asm/arch-mb86r0x/asm-offsets.h | 74 +++ arch/arm/include/asm/arch-mb86r0x/hardware.h | 31 ++ arch/arm/include/asm/arch-mb86r0x/mb86r0x.h | 561 +++++++++++++++++++++++ common/serial.c | 6 +- include/serial.h | 6 +- 8 files changed, 898 insertions(+), 6 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/mb86r0x/Makefile create mode 100644 arch/arm/cpu/arm926ejs/mb86r0x/reset.c create mode 100644 arch/arm/cpu/arm926ejs/mb86r0x/timer.c create mode 100644 arch/arm/include/asm/arch-mb86r0x/asm-offsets.h create mode 100644 arch/arm/include/asm/arch-mb86r0x/hardware.h create mode 100644 arch/arm/include/asm/arch-mb86r0x/mb86r0x.h
diff --git a/arch/arm/cpu/arm926ejs/mb86r0x/Makefile b/arch/arm/cpu/arm926ejs/mb86r0x/Makefile new file mode 100644 index 0000000..360f046 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/mb86r0x/Makefile @@ -0,0 +1,47 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).a + +COBJS = timer.o reset.o +SOBJS = + +SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) +START := $(addprefix $(obj),$(START)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/arch/arm/cpu/arm926ejs/mb86r0x/reset.c b/arch/arm/cpu/arm926ejs/mb86r0x/reset.c new file mode 100644 index 0000000..e7f0f67 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/mb86r0x/reset.c @@ -0,0 +1,40 @@ +/* + * (C) Copyright 2010 + * Matthias Weisser weisserm@arcor.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/hardware.h> + +/* + * Reset the cpu by setting software reset request bit + */ +void reset_cpu(ulong ignored) +{ + struct mb86r0x_crg * crg = (struct mb86r0x_crg *) + MB86R0x_CRG_BASE; + + writel(MB86R0x_CRSR_SWRSTREQ, &crg->crsr); + while (1) + /* NOP */; + /* Never reached */ +} diff --git a/arch/arm/cpu/arm926ejs/mb86r0x/timer.c b/arch/arm/cpu/arm926ejs/mb86r0x/timer.c new file mode 100644 index 0000000..eb6c47c --- /dev/null +++ b/arch/arm/cpu/arm926ejs/mb86r0x/timer.c @@ -0,0 +1,139 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * (C) Copyright 2010 + * Matthias Weisser, Graf-Syteco weisserm@arcor.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <div64.h> +#include <common.h> +#include <asm/io.h> +#include <asm/arch/hardware.h> + +#define TIMER_LOAD_VAL 0xffffffff +#define TIMER_FREQ (CONFIG_MB86R0x_IOCLK / 256) + +static unsigned long long timestamp; +static ulong lastdec; + +static inline unsigned long long tick_to_time(unsigned long long tick) +{ + tick *= CONFIG_SYS_HZ; + do_div(tick, TIMER_FREQ); + + return tick; +} + +static inline unsigned long long usec_to_tick(unsigned long long usec) +{ + usec *= TIMER_FREQ; + do_div(usec, 1000000); + + return usec; +} + +/* nothing really to do with interrupts, just starts up a counter. */ +int timer_init(void) +{ + struct mb86r0x_timer * timer = (struct mb86r0x_timer *) + MB86R0x_TIMER_BASE; + ulong ctrl = readl(&timer->control); + + writel(TIMER_LOAD_VAL, &timer->load); + + ctrl |= MB86R0x_TIMER_ENABLE | MB86R0x_TIMER_PRS_8S | + MB86R0x_TIMER_SIZE_32; + + writel(ctrl, &timer->control); + + reset_timer_masked(); + + return 0; +} + +/* + * timer without interrupts + */ +unsigned long long get_ticks(void) +{ + struct mb86r0x_timer * timer = (struct mb86r0x_timer *) + MB86R0x_TIMER_BASE; + ulong now = readl(&timer->value); + + if (now <= lastdec) /* normal mode (non roll) */ + /* move stamp forward with absolut diff ticks */ + timestamp += lastdec - now; + else /* we have rollover of incrementer */ + timestamp += lastdec + TIMER_LOAD_VAL - now; + lastdec = now; + return timestamp; +} + +void reset_timer_masked(void) +{ + struct mb86r0x_timer * timer = (struct mb86r0x_timer *) + MB86R0x_TIMER_BASE; + + /* capture current value time */ + lastdec = readl(&timer->value); + timestamp = 0; /* start "advancing" time stamp from 0 */ +} + +ulong get_timer_masked(void) +{ + return tick_to_time(get_ticks()); +} + +void __udelay(unsigned long usec) +{ + unsigned long long tmp; + ulong tmo; + + tmo = usec_to_tick(usec); + tmp = get_ticks() + tmo; /* get current timestamp */ + + while (get_ticks() < tmp) /* loop till event */ + /*NOP*/; +} + +void reset_timer(void) +{ + reset_timer_masked(); +} + +ulong get_timer(ulong base) +{ + return get_timer_masked() - base; +} + +/* + * This function is derived from PowerPC code (timebase clock frequency). + * On ARM it returns the number of timer ticks per second. + */ +ulong get_tbclk(void) +{ + ulong tbclk; + + tbclk = TIMER_FREQ; + return tbclk; +} diff --git a/arch/arm/include/asm/arch-mb86r0x/asm-offsets.h b/arch/arm/include/asm/arch-mb86r0x/asm-offsets.h new file mode 100644 index 0000000..0bc5279 --- /dev/null +++ b/arch/arm/include/asm/arch-mb86r0x/asm-offsets.h @@ -0,0 +1,74 @@ +/* + * (C) Copyright 2010 + * Matthias Weisser weisserm@arcor.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef ASM_OFFSETS_H +#define ASM_OFFSETS_H + +/* + * Offset definitions for DDR controller + */ +#define DDR2_DRIC 0x00 +#define DDR2_DRIC1 0x02 +#define DDR2_DRIC2 0x04 +#define DDR2_DRCA 0x06 +#define DDR2_DRCM 0x08 +#define DDR2_DRCST1 0x0a +#define DDR2_DRCST2 0x0c +#define DDR2_DRCR 0x0e +#define DDR2_DRCF 0x20 +#define DDR2_DRASR 0x30 +#define DDR2_DRIMS 0x50 +#define DDR2_DROS 0x60 +#define DDR2_DRIBSODT1 0x64 +#define DDR2_DROABA 0x70 +#define DDR2_DROBS 0x84 + +/* + * Offset definitions Chip Control Module + */ +#define CCNT_CDCRC 0xec + +/* + * Offset definitions clock reset generator + */ +#define CRG_CRPR 0x00 +#define CRG_CRHA 0x18 +#define CRG_CRPA 0x1c +#define CRG_CRPB 0x20 +#define CRG_CRHB 0x24 +#define CRG_CRAM 0x28 + +/* + * Offset definitions External bus interface + */ +#define MEMC_MCFMODE0 0x00 +#define MEMC_MCFMODE2 0x08 +#define MEMC_MCFMODE4 0x10 +#define MEMC_MCFTIM0 0x20 +#define MEMC_MCFTIM2 0x28 +#define MEMC_MCFTIM4 0x30 +#define MEMC_MCFAREA0 0x40 +#define MEMC_MCFAREA2 0x48 +#define MEMC_MCFAREA4 0x50 + +#endif /* ASM_OFFSETS_H */ diff --git a/arch/arm/include/asm/arch-mb86r0x/hardware.h b/arch/arm/include/asm/arch-mb86r0x/hardware.h new file mode 100644 index 0000000..d1e57c0 --- /dev/null +++ b/arch/arm/include/asm/arch-mb86r0x/hardware.h @@ -0,0 +1,31 @@ +/* + * (C) Copyright 2007 + * + * Author : Carsten Schneider, mycable GmbH + * cs@mycable.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef __ASM_ARCH_HARDWARE_H +#define __ASM_ARCH_HARDWARE_H + +#include <asm/sizes.h> +#include <asm/arch/mb86r0x.h> + +#endif diff --git a/arch/arm/include/asm/arch-mb86r0x/mb86r0x.h b/arch/arm/include/asm/arch-mb86r0x/mb86r0x.h new file mode 100644 index 0000000..c3894b4 --- /dev/null +++ b/arch/arm/include/asm/arch-mb86r0x/mb86r0x.h @@ -0,0 +1,561 @@ +/* + * (C) Copyright 2007 + * + * mb86r0x definitions + * + * Author : Carsten Schneider, mycable GmbH + * cs@mycable.de + * + * (C) Copyright 2010 + * Matthias Weisser weisserm@arcor.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef MB86R0X_H +#define MB86R0X_H + +#ifndef __ASSEMBLY__ + +/* GPIO registers */ +struct mb86r0x_gpio { + uint32_t gpdr0; + uint32_t gpdr1; + uint32_t gpdr2; + uint32_t res; + uint32_t gpddr0; + uint32_t gpddr1; + uint32_t gpddr2; +}; + +/* PWM registers */ +struct mb86r0x_pwm { + uint32_t bcr; + uint32_t tpr; + uint32_t pr; + uint32_t dr; + uint32_t cr; + uint32_t sr; + uint32_t ccr; + uint32_t ir; +}; + +/* The mb86r0x chip control (CCNT) register set. */ +struct mb86r0x_ccnt { + uint32_t ccid; + uint32_t csrst; + uint32_t pad0[2]; + uint32_t cist; + uint32_t cistm; + uint32_t cgpio_ist; + uint32_t cgpio_istm; + uint32_t cgpio_ip; + uint32_t cgpio_im; + uint32_t caxi_bw; + uint32_t caxi_ps; + uint32_t cmux_md; + uint32_t cex_pin_st; + uint32_t cmlb; + uint32_t pad1[1]; + uint32_t cusb; + uint32_t pad2[41]; + uint32_t cbsc; + uint32_t cdcrc; + uint32_t cmsr0; + uint32_t cmsr1; + uint32_t pad3[2]; +}; + +/* The mb86r0x clock reset generator */ +struct mb86r0x_crg { + uint32_t crpr; + uint32_t pad0; + uint32_t crwr; + uint32_t crsr; + uint32_t crda; + uint32_t crdb; + uint32_t crha; + uint32_t crpa; + uint32_t crpb; + uint32_t crhb; + uint32_t cram; +}; + +/* The mb86r0x timer */ +struct mb86r0x_timer { + uint32_t load; + uint32_t value; + uint32_t control; + uint32_t intclr; + uint32_t ris; + uint32_t mis; + uint32_t bgload; +}; + +/* mb86r0x gdc display controller */ +struct mb86r0x_gdc_dsp { + /* Display settings */ + uint32_t dcm0; + uint16_t pad00; + uint16_t htp; + uint16_t hdp; + uint16_t hdb; + uint16_t hsp; + uint8_t hsw; + uint8_t vsw; + uint16_t pad01; + uint16_t vtr; + uint16_t vsp; + uint16_t vdp; + uint16_t wx; + uint16_t wy; + uint16_t ww; + uint16_t wh; + + /* Layer 0 */ + uint32_t l0m; + uint32_t l0oa; + uint32_t l0da; + uint16_t l0dx; + uint16_t l0dy; + + /* Layer 1 */ + uint32_t l1m; + uint32_t cbda0; + uint32_t cbda1; + uint32_t pad02; + + /* Layer 2 */ + uint32_t l2m; + uint32_t l2oa0; + uint32_t l2da0; + uint32_t l2oa1; + uint32_t l2da1; + uint16_t l2dx; + uint16_t l2dy; + + /* Layer 3 */ + uint32_t l3m; + uint32_t l3oa0; + uint32_t l3da0; + uint32_t l3oa1; + uint32_t l3da1; + uint16_t l3dx; + uint16_t l3dy; + + /* Layer 4 */ + uint32_t l4m; + uint32_t l4oa0; + uint32_t l4da0; + uint32_t l4oa1; + uint32_t l4da1; + uint16_t l4dx; + uint16_t l4dy; + + /* Layer 5 */ + uint32_t l5m; + uint32_t l5oa0; + uint32_t l5da0; + uint32_t l5oa1; + uint32_t l5da1; + uint16_t l5dx; + uint16_t l5dy; + + /* Cursor */ + uint16_t cutc; + uint8_t cpm; + uint8_t csize; + uint32_t cuoa0; + uint16_t cux0; + uint16_t cuy0; + uint32_t cuoa1; + uint16_t cux1; + uint16_t cuy1; + + /* Layer blending */ + uint32_t l0bld; + uint32_t pad03; + uint32_t l0tc; + uint16_t l3tc; + uint16_t l2tc; + uint32_t pad04[15]; + + /* Display settings */ + uint32_t dcm1; + uint32_t dcm2; + uint32_t dcm3; + uint32_t pad05; + + /* Layer 0 extended */ + uint32_t l0em; + uint16_t l0wx; + uint16_t l0wy; + uint16_t l0ww; + uint16_t l0wh; + uint32_t pad06; + + /* Layer 1 extended */ + uint32_t l1em; + uint16_t l1wx; + uint16_t l1wy; + uint16_t l1ww; + uint16_t l1wh; + uint32_t pad07; + + /* Layer 2 extended */ + uint32_t l2em; + uint16_t l2wx; + uint16_t l2wy; + uint16_t l2ww; + uint16_t l2wh; + uint32_t pad08; + + /* Layer 3 extended */ + uint32_t l3em; + uint16_t l3wx; + uint16_t l3wy; + uint16_t l3ww; + uint16_t l3wh; + uint32_t pad09; + + /* Layer 4 extended */ + uint32_t l4em; + uint16_t l4wx; + uint16_t l4wy; + uint16_t l4ww; + uint16_t l4wh; + uint32_t pad10; + + /* Layer 5 extended */ + uint32_t l5em; + uint16_t l5wx; + uint16_t l5wy; + uint16_t l5ww; + uint16_t l5wh; + uint32_t pad11; + + /* Multi screen control */ + uint32_t msc; + uint32_t pad12[3]; + uint32_t dls; + uint32_t dbgc; + + /* Layer blending */ + uint32_t l1bld; + uint32_t l2bld; + uint32_t l3bld; + uint32_t l4bld; + uint32_t l5bld; + uint32_t pad13; + + /* Extended transparency control */ + uint32_t l0etc; + uint32_t l1etc; + uint32_t l2etc; + uint32_t l3etc; + uint32_t l4etc; + uint32_t l5etc; + uint32_t pad14[10]; + + /* YUV coefficients */ + uint32_t l1ycr0; + uint32_t l1ycr1; + uint32_t l1ycg0; + uint32_t l1ycg1; + uint32_t l1ycb0; + uint32_t l1ycb1; + uint32_t pad15[130]; + + /* Layer palletes */ + uint32_t l0pal[256]; + uint32_t l1pal[256]; + uint32_t pad16[256]; + uint32_t l2pal[256]; + uint32_t l3pal[256]; + uint32_t pad17[256]; + + /* PWM settings */ + uint32_t vpwmm; + uint16_t vpwms; + uint16_t vpwme; + uint32_t vpwmc; + uint32_t pad18[253]; +}; + +/* mb86r0x gdc capture controller */ +struct mb86r0x_gdc_cap { + uint32_t vcm; + uint32_t csc; + uint32_t vcs; + uint32_t pad01; + + uint32_t cbm; + uint32_t cboa; + uint32_t cbla; + uint16_t cihstr; + uint16_t civstr; + uint16_t cihend; + uint16_t civend; + uint32_t pad02; + + uint32_t chp; + uint32_t cvp; + uint32_t pad03[4]; + + uint32_t clpf; + uint32_t pad04; + uint32_t cmss; + uint32_t cmds; + uint32_t pad05[12]; + + uint32_t rgbhc; + uint32_t rgbhen; + uint32_t rgbven; + uint32_t pad06; + uint32_t rgbs; + uint32_t pad07[11]; + + uint32_t rgbcmy; + uint32_t rgbcmcb; + uint32_t rgbcmcr; + uint32_t rgbcmb; + uint32_t pad08[12 + 1984]; +}; + +/* mb86r0x gdc draw */ +struct mb86r0x_gdc_draw { + uint32_t ys; + uint32_t xs; + uint32_t dxdy; + uint32_t xus; + uint32_t dxudy; + uint32_t xls; + uint32_t dxldy; + uint32_t usn; + uint32_t lsn; + uint32_t pad01[7]; + uint32_t rs; + uint32_t drdx; + uint32_t drdy; + uint32_t gs; + uint32_t dgdx; + uint32_t dgdy; + uint32_t bs; + uint32_t dbdx; + uint32_t dbdy; + uint32_t pad02[7]; + uint32_t zs; + uint32_t dzdx; + uint32_t dzdy; + uint32_t pad03[13]; + uint32_t ss; + uint32_t dsdx; + uint32_t dsdy; + uint32_t ts; + uint32_t dtdx; + uint32_t dtdy; + uint32_t qs; + uint32_t dqdx; + uint32_t dqdy; + uint32_t pad04[23]; + uint32_t lpn; + uint32_t lxs; + uint32_t lxde; + uint32_t lys; + uint32_t lyde; + uint32_t lzs; + uint32_t lzde; + uint32_t pad05[13]; + uint32_t pxdc; + uint32_t pydc; + uint32_t pzdc; + uint32_t pad06[25]; + uint32_t rxs; + uint32_t rys; + uint32_t rsizex; + uint32_t rsizey; + uint32_t pad07[12]; + uint32_t saddr; + uint32_t sstride; + uint32_t srx; + uint32_t sry; + uint32_t daddr; + uint32_t dstride; + uint32_t drx; + uint32_t dry; + uint32_t brsizex; + uint32_t brsizey; + uint32_t tcolor; + uint32_t pad08[93]; + uint32_t blpo; + uint32_t pad09[7]; + uint32_t ctr; + uint32_t ifsr; + uint32_t ifcnt; + uint32_t sst; + uint32_t ds; + uint32_t pst; + uint32_t est; + uint32_t pad10; + uint32_t mdr0; + uint32_t mdr1; + uint32_t mdr2; + uint32_t mdr3; + uint32_t mdr4; + uint32_t pad14[2]; + uint32_t mdr7; + uint32_t fbr; + uint32_t xres; + uint32_t zbr; + uint32_t tbr; + uint32_t pfbr; + uint32_t cxmin; + uint32_t cxmax; + uint32_t cymin; + uint32_t cymax; + uint32_t txs; + uint32_t tis; + uint32_t toa; + uint32_t sho; + uint32_t abr; + uint32_t pad15[2]; + uint32_t fc; + uint32_t bc; + uint32_t alf; + uint32_t blp; + uint32_t pad16; + uint32_t tbc; + uint32_t pad11[42]; + uint32_t lx0dc; + uint32_t ly0dc; + uint32_t lx1dc; + uint32_t ly1dc; + uint32_t pad12[12]; + uint32_t x0dc; + uint32_t y0dc; + uint32_t x1dc; + uint32_t y1dc; + uint32_t x2dc; + uint32_t y2dc; + uint32_t pad13[666]; +}; + +/* mb86r0x gdc geometry engine */ +struct mb86r0x_gdc_geom { + uint32_t gctr; + uint32_t pad00[15]; + uint32_t gmdr0; + uint32_t gmdr1; + uint32_t gmdr2; + uint32_t pad01[237]; + uint32_t dfifog; + uint32_t pad02[767]; +}; + +/* mb86r0x gdc */ +struct mb86r0x_gdc { + uint32_t pad00[2]; + uint32_t lts; + uint32_t pad01; + uint32_t lsta; + uint32_t pad02[3]; + uint32_t ist; + uint32_t imask; + uint32_t pad03[6]; + uint32_t lsa; + uint32_t lco; + uint32_t lreq; + + uint32_t pad04[16*1024 - 19]; + struct mb86r0x_gdc_dsp dsp0; + struct mb86r0x_gdc_dsp dsp1; + uint32_t pad05[4*1024 - 2]; + uint32_t vccc; + uint32_t vcsr; + struct mb86r0x_gdc_cap cap0; + struct mb86r0x_gdc_cap cap1; + uint32_t pad06[4*1024]; + uint32_t texture_base[16*1024]; + struct mb86r0x_gdc_draw draw; + uint32_t pad07[7*1024]; + struct mb86r0x_gdc_geom geom; + uint32_t pad08[7*1024]; +}; + +#endif /* __ASSEMBLY__ */ + +/* + * Physical Address Defines + */ +#define MB86R0x_DDR2_BASE 0xf3000000 +#define MB86R0x_GDC_BASE 0xf1fc0000 +#define MB86R0x_CCNT_BASE 0xfff42000 +#define MB86R0x_CAN0_BASE 0xfff54000 +#define MB86R0x_CAN1_BASE 0xfff55000 +#define MB86R0x_I2C0_BASE 0xfff56000 +#define MB86R0x_I2C1_BASE 0xfff57000 +#define MB86R0x_EHCI_BASE 0xfff80000 +#define MB86R0x_OHCI_BASE 0xfff81000 +#define MB86R0x_IRC1_BASE 0xfffb0000 +#define MB86R0x_MEMC_BASE 0xfffc0000 +#define MB86R0x_TIMER_BASE 0xfffe0000 +#define MB86R0x_UART0_BASE 0xfffe1000 +#define MB86R0x_UART1_BASE 0xfffe2000 +#define MB86R0x_IRCE_BASE 0xfffe4000 +#define MB86R0x_CRG_BASE 0xfffe7000 +#define MB86R0x_IRC0_BASE 0xfffe8000 +#define MB86R0x_GPIO_BASE 0xfffe9000 +#define MB86R0x_PWM0_BASE 0xfff41000 +#define MB86R0x_PWM1_BASE 0xfff41100 + +#define MB86R0x_CRSR_SWRSTREQ (1 << 1) + +/* + * Timer register bits + */ +#define MB86R0x_TIMER_ENABLE (1 << 7) +#define MB86R0x_TIMER_MODE_MSK (1 << 6) +#define MB86R0x_TIMER_MODE_FR (0 << 6) +#define MB86R0x_TIMER_MODE_PD (1 << 6) + +#define MB86R0x_TIMER_INT_EN (1 << 5) +#define MB86R0x_TIMER_PRS_MSK (3 << 2) +#define MB86R0x_TIMER_PRS_4S (1 << 2) +#define MB86R0x_TIMER_PRS_8S (1 << 3) +#define MB86R0x_TIMER_SIZE_32 (1 << 1) +#define MB86R0x_TIMER_ONE_SHT (1 << 0) + +/* + * Clock reset generator bits + */ +#define MB86R0x_CRG_CRPR_PLLRDY (1 << 8) + +/* + * DDR2 controller bits + */ +#define MB86R0x_DDR2_DRCI_DRINI (1 << 15) +#define MB86R0x_DDR2_DRCI_CKEN (1 << 14) +#define MB86R0x_DDR2_DRCI_DRCMD (1 << 0) +#define MB86R0x_DDR2_DRCI_CMD (MB86R0x_DDR2_DRCI_DRINI | \ + MB86R0x_DDR2_DRCI_CKEN | \ + MB86R0x_DDR2_DRCI_DRCMD) +#define MB86R0x_DDR2_DRCI_INIT (MB86R0x_DDR2_DRCI_DRINI | \ + MB86R0x_DDR2_DRCI_CKEN) +#define MB86R0x_DDR2_DRCI_NORMAL MB86R0x_DDR2_DRCI_CKEN +#endif /* MB86R0X_H */ diff --git a/common/serial.c b/common/serial.c index fceabfa..6718648 100644 --- a/common/serial.c +++ b/common/serial.c @@ -40,9 +40,9 @@ struct serial_device *__default_serial_console (void) return &serial_scc_device; #elif defined(CONFIG_405GP) || defined(CONFIG_405CR) || defined(CONFIG_440) \ || defined(CONFIG_405EP) || defined(CONFIG_405EZ) || defined(CONFIG_405EX) \ - || defined(CONFIG_MPC5xxx) || defined(CONFIG_MPC83xx) \ - || defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) \ - || defined(CONFIG_SYS_SC520) + || defined(CONFIG_MB86R0x) || defined(CONFIG_MPC5xxx) \ + || defined(CONFIG_MPC83xx) || defined(CONFIG_MPC85xx) \ + || defined(CONFIG_MPC86xx) || defined(CONFIG_SYS_SC520) #if defined(CONFIG_CONS_INDEX) && defined(CONFIG_SYS_NS16550_SERIAL) #if (CONFIG_CONS_INDEX==1) return &eserial1_device; diff --git a/include/serial.h b/include/serial.h index 6513d8e..fc38469 100644 --- a/include/serial.h +++ b/include/serial.h @@ -25,9 +25,9 @@ extern struct serial_device * default_serial_console (void);
#if defined(CONFIG_405GP) || defined(CONFIG_405CR) || defined(CONFIG_440) || \ defined(CONFIG_405EP) || defined(CONFIG_405EZ) || defined(CONFIG_405EX) || \ - defined(CONFIG_MPC5xxx) || defined(CONFIG_MPC83xx) || \ - defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) || \ - defined(CONFIG_SYS_SC520) + defined(CONFIG_MB86R0x) || defined(CONFIG_MPC5xxx) || \ + defined(CONFIG_MPC83xx) || defined(CONFIG_MPC85xx) || \ + defined(CONFIG_MPC86xx) || defined(CONFIG_SYS_SC520) extern struct serial_device serial0_device; extern struct serial_device serial1_device; #if defined(CONFIG_SYS_NS16550_SERIAL)
This patch adds support for the display controller in the MB86R0x SoCs.
Signed-off-by: Matthias Weisser weisserm@arcor.de --- drivers/video/Makefile | 1 + drivers/video/mb86r0xgdc.c | 186 ++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 187 insertions(+), 0 deletions(-) create mode 100644 drivers/video/mb86r0xgdc.c
diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 7d84fc7..4be82e7 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -32,6 +32,7 @@ COBJS-$(CONFIG_S6E63D6) += s6e63d6.o COBJS-$(CONFIG_VIDEO_AMBA) += amba.o COBJS-$(CONFIG_VIDEO_CT69000) += ct69000.o videomodes.o COBJS-$(CONFIG_VIDEO_MB862xx) += mb862xx.o videomodes.o +COBJS-$(CONFIG_VIDEO_MB86R0xGDC) += mb86r0xgdc.o videomodes.o COBJS-$(CONFIG_VIDEO_MX3) += mx3fb.o COBJS-$(CONFIG_VIDEO_SED13806) += sed13806.o COBJS-$(CONFIG_SED156X) += sed156x.o diff --git a/drivers/video/mb86r0xgdc.c b/drivers/video/mb86r0xgdc.c new file mode 100644 index 0000000..3bdc1db --- /dev/null +++ b/drivers/video/mb86r0xgdc.c @@ -0,0 +1,186 @@ +/* + * (C) Copyright 2010 + * Matthias Weisser weisserm@arcor.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * mb86r0xgdc.c - Graphic interface for Fujitsu MB86R0x integrated graphic + * controller. + */ + +#include <common.h> + +#include <malloc.h> +#include <asm/io.h> +#include <asm/arch/hardware.h> +#include <video_fb.h> +#include "videomodes.h" + +/* + * 4MB (at the end of system RAM) + */ +#define VIDEO_MEM_SIZE 0x400000 + +#define FB_SYNC_CLK_INV (1<<16) /* pixel clock inverted */ + +/* + * Graphic Device + */ +static GraphicDevice mb86r0x; + +static void dsp_init(struct mb86r0x_gdc_dsp *dsp, char *modestr, + u32 *videomem) +{ + struct ctfb_res_modes var_mode; + u32 dcm1, dcm2, dcm3; + u16 htp, hdp, hdb, hsp, vtr, vsp, vdp; + u8 hsw, vsw; + u32 l2m, l2em, l2oa0, l2da0, l2oa1, l2da1; + u16 l2dx, l2dy, l2wx, l2wy, l2ww, l2wh; + unsigned long div; + int bpp; + u32 i; + + bpp = video_get_params(&var_mode, modestr); + + if (bpp == 0) { + var_mode.xres = 640; + var_mode.yres = 480; + var_mode.pixclock = 39721; /* 25MHz */ + var_mode.left_margin = 48; + var_mode.right_margin = 16; + var_mode.upper_margin = 33; + var_mode.lower_margin = 10; + var_mode.hsync_len = 96; + var_mode.vsync_len = 2; + var_mode.sync = 0; + var_mode.vmode = 0; + bpp = 15; + } + + /* Fill memory with white */ + for (i = 0; i < var_mode.xres * var_mode.yres / 2; i++) + *videomem++ = 0xFFFFFFFF; + + mb86r0x.winSizeX = var_mode.xres; + mb86r0x.winSizeY = var_mode.yres; + + /* LCD base clock is ~ 660MHZ. We do calculations in kHz */ + div = 660000 / (1000000000L / var_mode.pixclock); + if (div > 64) + div = 64; + if (0 == div) + div = 1; + + dcm1 = (div - 1) << 8; + dcm2 = 0x00000000; + if (var_mode.sync & FB_SYNC_CLK_INV) + dcm3 = 0x00000100; + else + dcm3 = 0x00000000; + + htp = var_mode.left_margin + var_mode.xres + + var_mode.hsync_len + var_mode.right_margin; + hdp = var_mode.xres; + hdb = var_mode.xres; + hsp = var_mode.xres + var_mode.right_margin; + hsw = var_mode.hsync_len; + + vsw = var_mode.vsync_len; + vtr = var_mode.upper_margin + var_mode.yres + + var_mode.vsync_len + var_mode.lower_margin; + vsp = var_mode.yres + var_mode.lower_margin; + vdp = var_mode.yres; + + l2m = ((var_mode.yres - 1) << (0)) | + (((var_mode.xres * 2) / 64) << (16)) | + ((1) << (31)); + + l2em = (1 << 0) | (1 << 1); + + l2oa0 = mb86r0x.frameAdrs; + l2da0 = mb86r0x.frameAdrs; + l2oa1 = mb86r0x.frameAdrs; + l2da1 = mb86r0x.frameAdrs; + l2dx = 0; + l2dy = 0; + l2wx = 0; + l2wy = 0; + l2ww = var_mode.xres; + l2wh = var_mode.yres - 1; + + writel(dcm1, &dsp->dcm1); + writel(dcm2, &dsp->dcm2); + writel(dcm3, &dsp->dcm3); + + writew(htp, &dsp->htp); + writew(hdp, &dsp->hdp); + writew(hdb, &dsp->hdb); + writew(hsp, &dsp->hsp); + writeb(hsw, &dsp->hsw); + + writeb(vsw, &dsp->vsw); + writew(vtr, &dsp->vtr); + writew(vsp, &dsp->vsp); + writew(vdp, &dsp->vdp); + + writel(l2m, &dsp->l2m); + writel(l2em, &dsp->l2em); + writel(l2oa0, &dsp->l2oa0); + writel(l2da0, &dsp->l2da0); + writel(l2oa1, &dsp->l2oa1); + writel(l2da1, &dsp->l2da1); + writew(l2dx, &dsp->l2dx); + writew(l2dy, &dsp->l2dy); + writew(l2wx, &dsp->l2wx); + writew(l2wy, &dsp->l2wy); + writew(l2ww, &dsp->l2ww); + writew(l2wh, &dsp->l2wh); + + writel(dcm1 | (1 << 18) | (1 << 31), &dsp->dcm1); +} + +void *video_hw_init(void) +{ + struct mb86r0x_gdc *gdc = (struct mb86r0x_gdc *) MB86R0x_GDC_BASE; + GraphicDevice *pGD = &mb86r0x; + char *s; + u32 *vid; + + memset(pGD, 0, sizeof(GraphicDevice)); + + pGD->gdfIndex = GDF_15BIT_555RGB; + pGD->gdfBytesPP = 2; + pGD->memSize = VIDEO_MEM_SIZE; + pGD->frameAdrs = PHYS_SDRAM + PHYS_SDRAM_SIZE - VIDEO_MEM_SIZE; + + vid = (u32 *)pGD->frameAdrs; + + s = getenv("videomode"); + if (s != NULL) + dsp_init(&gdc->dsp0, s, vid); + + s = getenv("videomode1"); + if (s != NULL) + dsp_init(&gdc->dsp1, s, vid); + + return pGD; +}
Dear Matthias,
Acked-by: Anatolij Gustschin agust@denx.de
Since this patch is in the patch series for arm tree, I'm okay if it goes via the arm tree.
Thanks, Anatolij
This patch adds support for the jadecpu board using the MB86R01 'Jade' SoC from Fujitsu.
Signed-off-by: Matthias Weisser weisserm@arcor.de --- MAINTAINERS | 4 + MAKEALL | 1 + board/syteco/jadecpu/Makefile | 55 +++++++ board/syteco/jadecpu/config.mk | 1 + board/syteco/jadecpu/jadecpu.c | 171 ++++++++++++++++++++ board/syteco/jadecpu/lowlevel_init.S | 266 ++++++++++++++++++++++++++++++++ boards.cfg | 1 + include/configs/jadecpu.h | 283 ++++++++++++++++++++++++++++++++++ tools/Makefile | 3 + tools/logos/syteco.bmp | Bin 0 -> 11414 bytes 10 files changed, 785 insertions(+), 0 deletions(-) create mode 100644 board/syteco/jadecpu/Makefile create mode 100644 board/syteco/jadecpu/config.mk create mode 100644 board/syteco/jadecpu/jadecpu.c create mode 100644 board/syteco/jadecpu/lowlevel_init.S create mode 100644 include/configs/jadecpu.h create mode 100644 tools/logos/syteco.bmp
diff --git a/MAINTAINERS b/MAINTAINERS index d7aec98..cd6e489 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -801,6 +801,10 @@ Prafulla Wadaskar prafulla@marvell.com rd6281a ARM926EJS (Kirkwood SoC) sheevaplug ARM926EJS (Kirkwood SoC)
+Matthias Weisser matthias.weisser@graf-syteco.de + + jadecpu ARM926EJS (MB86R01 SoC) + Richard Woodruff r-woodruff2@ti.com
omap2420h4 ARM1136EJS diff --git a/MAKEALL b/MAKEALL index d6d5f5b..319687a 100755 --- a/MAKEALL +++ b/MAKEALL @@ -573,6 +573,7 @@ LIST_ARM9=" \ edminiv2 \ guruplug \ imx27lite \ + jadecpu \ lpd7a400 \ magnesium \ mv88f6281gtw_ge \ diff --git a/board/syteco/jadecpu/Makefile b/board/syteco/jadecpu/Makefile new file mode 100644 index 0000000..87d2234 --- /dev/null +++ b/board/syteco/jadecpu/Makefile @@ -0,0 +1,55 @@ +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2008 +# Stelian Pop stelian.pop@leadtechdesign.com +# Lead Tech Design <www.leadtechdesign.com> +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS-y += jadecpu.o +SOBJS := lowlevel_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/syteco/jadecpu/config.mk b/board/syteco/jadecpu/config.mk new file mode 100644 index 0000000..c661f0b --- /dev/null +++ b/board/syteco/jadecpu/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0x46000000 diff --git a/board/syteco/jadecpu/jadecpu.c b/board/syteco/jadecpu/jadecpu.c new file mode 100644 index 0000000..a090fed --- /dev/null +++ b/board/syteco/jadecpu/jadecpu.c @@ -0,0 +1,171 @@ +/* + * (c) 2010 Graf-Syteco, Matthias Weisser + * weisserm@arcor.de + * + * (C) Copyright 2007, mycable GmbH + * Carsten Schneider cs@mycable.de, Alexander Bigga ab@mycable.de + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <netdev.h> +#include <asm/io.h> +#include <asm/arch/mb86r0x.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Miscellaneous platform dependent initialisations + */ +int board_init(void) +{ + struct mb86r0x_ccnt * ccnt = (struct mb86r0x_ccnt *) + MB86R0x_CCNT_BASE; + + /* We select mode 0 for group 2 and mode 1 for group 4 */ + writel(0x00000010, &ccnt->cmux_md); + + gd->flags = 0; + gd->bd->bi_arch_number = MACH_TYPE_JADECPU; + gd->bd->bi_boot_params = PHYS_SDRAM + PHYS_SDRAM_SIZE - 0x10000; + + icache_enable(); + + return 0; +} + +static void setup_display_power(uint32_t pwr_bit, char *pwm_opts, + unsigned long pwm_base) +{ + struct mb86r0x_gpio *gpio = (struct mb86r0x_gpio *) + MB86R0x_GPIO_BASE; + struct mb86r0x_pwm *pwm = (struct mb86r0x_pwm *) pwm_base; + const char *e; + + writel(readl(&gpio->gpdr2) | pwr_bit, &gpio->gpdr2); + + e = getenv(pwm_opts); + if (e != NULL) { + const char *s; + uint32_t freq, init; + + freq = 0; + init = 0; + + s = strchr(e, 'f'); + if (s != NULL) + freq = simple_strtol(s + 2, NULL, 0); + + s = strchr(e, 'i'); + if (s != NULL) + init = simple_strtol(s + 2, NULL, 0); + + if (freq > 0) { + writel(CONFIG_MB86R0x_IOCLK / 1000 / freq, + &pwm->bcr); + writel(1002, &pwm->tpr); + writel(1, &pwm->pr); + writel(init * 10 + 1, &pwm->dr); + writel(1, &pwm->cr); + writel(1, &pwm->sr); + } + } +} + +int board_late_init(void) +{ + struct mb86r0x_gpio *gpio = (struct mb86r0x_gpio *) + MB86R0x_GPIO_BASE; + uint32_t in_word; + +#ifdef CONFIG_VIDEO_MB86R0xGDC + /* Check if we have valid display settings and turn on power if so */ + /* Display 0 */ + if (getenv("gs_dsp_0_param") || getenv("videomode")) + setup_display_power((1 << 3), "gs_dsp_0_pwm", + MB86R0x_PWM0_BASE); + + /* The corresponding GPIO is always an output */ + writel(readl(&gpio->gpddr2) | (1 << 3), &gpio->gpddr2); + + /* Display 1 */ + if (getenv("gs_dsp_1_param") || getenv("videomode1")) + setup_display_power((1 << 4), "gs_dsp_1_pwm", + MB86R0x_PWM1_BASE); + + /* The corresponding GPIO is always an output */ + writel(readl(&gpio->gpddr2) | (1 << 4), &gpio->gpddr2); +#endif /* CONFIG_VIDEO_MB86R0xGDC */ + + /* 5V enable */ + writel(readl(&gpio->gpdr1) & ~(1 << 5), &gpio->gpdr1); + writel(readl(&gpio->gpddr1) | (1 << 5), &gpio->gpddr1); + + /* We have special boot options if told by GPIOs */ + in_word = readl(&gpio->gpdr1); + + if ((in_word & 0xC0) == 0xC0) { + setenv("stdin", "serial"); + setenv("stdout", "serial"); + setenv("stderr", "serial"); + setenv("preboot", "run gs_slow_boot"); + } else if ((in_word & 0xC0) != 0) { + setenv("stdout", "vga"); + setenv("gs_bootcmd", "mw.l 0x40000000 0 1024; usb start;" + "fatls usb 0; fatload usb 0 0x40000000 mcq5resq.bin;" + "bootelf 0x40000000; bootelf 0x10080000"); + setenv("preboot", "run gs_slow_boot"); + } else { + setenv("stdin", "serial"); + setenv("stdout", "serial"); + setenv("stderr", "serial"); + if (getenv("gs_devel")) { + setenv("preboot", "run gs_slow_boot"); + } else { + setenv("gs_bootcmd", "bootelf 0x10080000"); + setenv("preboot", "run gs_fast_boot"); + } + } + + return 0; +} + +int misc_init_r(void) +{ + return 0; +} + +/* + * DRAM configuration + */ +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM; + gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE; + + return 0; +} + +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_SMC911X + rc = smc911x_initialize(0, CONFIG_SMC911X_BASE); +#endif + return rc; +} + diff --git a/board/syteco/jadecpu/lowlevel_init.S b/board/syteco/jadecpu/lowlevel_init.S new file mode 100644 index 0000000..288cdd1 --- /dev/null +++ b/board/syteco/jadecpu/lowlevel_init.S @@ -0,0 +1,266 @@ +/* + * Board specific setup info + * + * (C) Copyright 2007, mycable GmbH + * Carsten Schneider cs@mycable.de, Alexander Bigga ab@mycable.de + * + * (C) Copyright 2003, ARM Ltd. + * Philippe Robin, philippe.robin@arm.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <version.h> +#include <asm/macro.h> +#include <asm/arch/mb86r0x.h> +#include <asm/arch/asm-offsets.h> + +/* Set up the platform, once the cpu has been initialized */ +.globl lowlevel_init +lowlevel_init: +/* + * Initialize Clock Reset Generator (CRG) + */ + + ldr r0, =MB86R0x_CRG_BASE + + /* Not change the initial value that is set by external pin.*/ +WAIT_PLL: + ldr r2, [r0, #CRG_CRPR] /* Wait for PLLREADY */ + tst r2, #MB86R0x_CRG_CRPR_PLLRDY + beq WAIT_PLL + + /* Set clock gate control */ + ldr r1, =CONFIG_SYS_CRG_CRHA_INIT + str r1, [r0, #CRG_CRHA] + ldr r1, =CONFIG_SYS_CRG_CRPA_INIT + str r1, [r0, #CRG_CRPA] + ldr r1, =CONFIG_SYS_CRG_CRPB_INIT + str r1, [r0, #CRG_CRPB] + ldr r1, =CONFIG_SYS_CRG_CRHB_INIT + str r1, [r0, #CRG_CRHB] + ldr r1, =CONFIG_SYS_CRG_CRAM_INIT + str r1, [r0, #CRG_CRAM] + +/* + * Initialize External Bus Interface + */ + ldr r0, =MB86R0x_MEMC_BASE + + ldr r1, =CONFIG_SYS_MEMC_MCFMODE0_INIT + str r1, [r0, #MEMC_MCFMODE0] + ldr r1, =CONFIG_SYS_MEMC_MCFMODE2_INIT + str r1, [r0, #MEMC_MCFMODE2] + ldr r1, =CONFIG_SYS_MEMC_MCFMODE4_INIT + str r1, [r0, #MEMC_MCFMODE4] + + ldr r1, =CONFIG_SYS_MEMC_MCFTIM0_INIT + str r1, [r0, #MEMC_MCFTIM0] + ldr r1, =CONFIG_SYS_MEMC_MCFTIM2_INIT + str r1, [r0, #MEMC_MCFTIM2] + ldr r1, =CONFIG_SYS_MEMC_MCFTIM4_INIT + str r1, [r0, #MEMC_MCFTIM4] + + ldr r1, =CONFIG_SYS_MEMC_MCFAREA0_INIT + str r1, [r0, #MEMC_MCFAREA0] + ldr r1, =CONFIG_SYS_MEMC_MCFAREA2_INIT + str r1, [r0, #MEMC_MCFAREA2] + ldr r1, =CONFIG_SYS_MEMC_MCFAREA4_INIT + str r1, [r0, #MEMC_MCFAREA4] + +/* + * Initialize DDR2 Controller + */ + + /* Wait for PLL LOCK up time or more */ + wait_timer 20 + + /* + * (2) Initialize DDRIF + */ + ldr r0, =MB86R0x_DDR2_BASE + ldr r1, =CONFIG_SYS_DDR2_DRIMS_INIT + strh r1, [r0, #DDR2_DRIMS] + + /* + * (3) Wait for 20MCKPs(120nsec) or more + */ + wait_timer 20 + + /* + * (4) IRESET/IUSRRST release + */ + ldr r0, =MB86R0x_CCNT_BASE + ldr r1, =CONFIG_SYS_CCNT_CDCRC_INIT_1 + str r1, [r0, #CCNT_CDCRC] + + /* + * (5) Wait for 20MCKPs(120nsec) or more + */ + wait_timer 20 + + /* + * (6) IDLLRST release + */ + ldr r0, =MB86R0x_CCNT_BASE + ldr r1, =CONFIG_SYS_CCNT_CDCRC_INIT_2 + str r1, [r0, #CCNT_CDCRC] + + /* + * (7+8) Wait for 200us(=200000ns) or more (DDR2 Spec) + */ + wait_timer 33536 + + /* + * (9) MCKE ON + */ + ldr r0, =MB86R0x_DDR2_BASE + ldr r1, =CONFIG_SYS_DDR2_DRIC1_INIT + strh r1, [r0, #DDR2_DRIC1] + ldr r1, =CONFIG_SYS_DDR2_DRIC2_INIT + strh r1, [r0, #DDR2_DRIC2] + ldr r1, =CONFIG_SYS_DDR2_DRCA_INIT + strh r1, [r0, #DDR2_DRCA] + ldr r1, =MB86R0x_DDR2_DRCI_INIT + strh r1, [r0, #DDR2_DRIC] + + /* + * (10) Initialize SDRAM + */ + + ldr r1, =MB86R0x_DDR2_DRCI_CMD + strh r1, [r0, #DDR2_DRIC] + + wait_timer 67 /* 400ns wait */ + + ldr r1, =CONFIG_SYS_DDR2_INIT_DRIC1_1 + strh r1, [r0, #DDR2_DRIC1] + ldr r1, =CONFIG_SYS_DDR2_INIT_DRIC2_1 + strh r1, [r0, #DDR2_DRIC2] + ldr r1, =MB86R0x_DDR2_DRCI_CMD + strh r1, [r0, #DDR2_DRIC] + + ldr r1, =CONFIG_SYS_DDR2_INIT_DRIC1_2 + strh r1, [r0, #DDR2_DRIC1] + ldr r1, =CONFIG_SYS_DDR2_INIT_DRIC2_2 + strh r1, [r0, #DDR2_DRIC2] + ldr r1, =MB86R0x_DDR2_DRCI_CMD + strh r1, [r0, #DDR2_DRIC] + + ldr r1, =CONFIG_SYS_DDR2_INIT_DRIC1_3 + strh r1, [r0, #DDR2_DRIC1] + ldr r1, =CONFIG_SYS_DDR2_INIT_DRIC2_3 + strh r1, [r0, #DDR2_DRIC2] + ldr r1, =MB86R0x_DDR2_DRCI_CMD + strh r1, [r0, #DDR2_DRIC] + + ldr r1, =CONFIG_SYS_DDR2_INIT_DRIC1_4 + strh r1, [r0, #DDR2_DRIC1] + ldr r1, =CONFIG_SYS_DDR2_INIT_DRIC2_4 + strh r1, [r0, #DDR2_DRIC2] + ldr r1, =MB86R0x_DDR2_DRCI_CMD + strh r1, [r0, #DDR2_DRIC] + + ldr r1, =CONFIG_SYS_DDR2_INIT_DRIC1_5 + strh r1, [r0, #DDR2_DRIC1] + ldr r1, =CONFIG_SYS_DDR2_INIT_DRIC2_5 + strh r1, [r0, #DDR2_DRIC2] + ldr r1, =MB86R0x_DDR2_DRCI_CMD + strh r1, [r0, #DDR2_DRIC] + + wait_timer 200 + + ldr r1, =CONFIG_SYS_DDR2_INIT_DRIC1_6 + strh r1, [r0, #DDR2_DRIC1] + ldr r1, =CONFIG_SYS_DDR2_INIT_DRIC2_6 + strh r1, [r0, #DDR2_DRIC2] + ldr r1, =MB86R0x_DDR2_DRCI_CMD + strh r1, [r0, #DDR2_DRIC] + + ldr r1, =CONFIG_SYS_DDR2_INIT_DRIC1_7 + strh r1, [r0, #DDR2_DRIC1] + ldr r1, =CONFIG_SYS_DDR2_INIT_DRIC2_7 + strh r1, [r0, #DDR2_DRIC2] + ldr r1, =MB86R0x_DDR2_DRCI_CMD + strh r1, [r0, #DDR2_DRIC] + + wait_timer 18 /* 105ns wait */ + + ldr r1, =CONFIG_SYS_DDR2_INIT_DRIC1_8 + strh r1, [r0, #DDR2_DRIC1] + ldr r1, =CONFIG_SYS_DDR2_INIT_DRIC2_8 + strh r1, [r0, #DDR2_DRIC2] + ldr r1, =MB86R0x_DDR2_DRCI_CMD + strh r1, [r0, #DDR2_DRIC] + + wait_timer 200 /* MRS to OCD: 200clock */ + + ldr r1, =CONFIG_SYS_DDR2_INIT_DRIC1_9 + strh r1, [r0, #DDR2_DRIC1] + ldr r1, =CONFIG_SYS_DDR2_INIT_DRIC2_9 + strh r1, [r0, #DDR2_DRIC2] + ldr r1, =MB86R0x_DDR2_DRCI_CMD + strh r1, [r0, #DDR2_DRIC] + + ldr r1, =CONFIG_SYS_DDR2_INIT_DRIC1_10 + strh r1, [r0, #DDR2_DRIC1] + ldr r1, =CONFIG_SYS_DDR2_INIT_DRIC2_10 + strh r1, [r0, #DDR2_DRIC2] + ldr r1, =MB86R0x_DDR2_DRCI_CMD + strh r1, [r0, #DDR2_DRIC] + + ldr r1, =CONFIG_SYS_DDR2_DRCM_INIT + strh r1, [r0, #DDR2_DRCM] + + ldr r1, =CONFIG_SYS_DDR2_DRCST1_INIT + strh r1, [r0, #DDR2_DRCST1] + + ldr r1, =CONFIG_SYS_DDR2_DRCST2_INIT + strh r1, [r0, #DDR2_DRCST2] + + ldr r1, =CONFIG_SYS_DDR2_DRCR_INIT + strh r1, [r0, #DDR2_DRCR] + + ldr r1, =CONFIG_SYS_DDR2_DRCF_INIT + strh r1, [r0, #DDR2_DRCF] + + ldr r1, =CONFIG_SYS_DDR2_DRASR_INIT + strh r1, [r0, #DDR2_DRASR] + + /* + * (11) ODT setting + */ + ldr r1, =CONFIG_SYS_DDR2_DROBS_INIT + strh r1, [r0, #DDR2_DROBS] + ldr r1, =CONFIG_SYS_DDR2_DROABA_INIT + strh r1, [r0, #DDR2_DROABA] + ldr r1, =CONFIG_SYS_DDR2_DRIBSODT1_INIT + strh r1, [r0, #DDR2_DRIBSODT1] + + /* + * (12) Shift to ODTCONT ON (SDRAM side) and DDR2 usual operation mode + */ + ldr r1, =CONFIG_SYS_DDR2_DROS_INIT + strh r1, [r0, #DDR2_DROS] + ldr r1, =MB86R0x_DDR2_DRCI_NORMAL + strh r1, [r0, #DDR2_DRIC] + + mov pc, lr + diff --git a/boards.cfg b/boards.cfg index 1a5cfb1..a1f1e8c 100644 --- a/boards.cfg +++ b/boards.cfg @@ -45,6 +45,7 @@ pm9261 arm arm926ejs - ronetix at91 pm9263 arm arm926ejs - ronetix at91 suen3 arm arm926ejs km_arm keymile kirkwood rd6281a arm arm926ejs - Marvell kirkwood +jadecpu arm arm926ejs jadecpu syteco mb86r0x mx51evk arm arm_cortexa8 mx51evk freescale mx51 actux1 arm ixp actux2 arm ixp diff --git a/include/configs/jadecpu.h b/include/configs/jadecpu.h new file mode 100644 index 0000000..8a3b8c8 --- /dev/null +++ b/include/configs/jadecpu.h @@ -0,0 +1,283 @@ +/* + * (C) Copyright 2010 + * Matthias Weisser weisserm@arcor.de + * + * Configuation settings for the jadecpu board + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_MB86R0x +#define CONFIG_MB86R0x_IOCLK (41164767) +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_ARM926EJS 1 /* This is an ARM926EJS Core */ +#undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 +#define BOARD_LATE_INIT 1 + +/* + * Hardware drivers + */ + +/* + * Serial + */ +#define CONFIG_SERIAL_MULTI +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE (-4) +#define CONFIG_SYS_NS16550_CLK CONFIG_MB86R0x_IOCLK +#define CONFIG_SYS_NS16550_COM1 0xfffe1000 /* UART 0 */ +#define CONFIG_SYS_NS16550_COM2 0xfff50000 /* UART 2 */ +#define CONFIG_SYS_NS16550_COM3 0xfff51000 /* UART 3 */ +#define CONFIG_SYS_NS16550_COM4 0xfff43000 /* UART 4 */ + +#define CONFIG_CONS_INDEX 4 + +/* + * Ethernet + */ +#define CONFIG_NET_MULTI +#define CONFIG_SMC911X +#define CONFIG_SMC911X_BASE 0x02000000 +#define CONFIG_SMC911X_16_BIT + +/* + * CAN + */ +#define CONFIG_CAN_CCAN +#define CONFIG_CAN_CCAN_BASE 0xfff54000 +#define CONFIG_CAN_CCAN_CLOCK CONFIG_MB86R0x_IOCLK +/* + * Video + */ +#define CONFIG_VIDEO +#define CONFIG_VIDEO_MB86R0xGDC +#define CONFIG_SYS_WHITE_ON_BLACK +#define CONFIG_CFB_CONSOLE +#define CONFIG_SYS_CONSOLE_IS_IN_ENV +#define CONFIG_SYS_CONSOLE_ENV_OVERWRITE +#define CONFIG_VIDEO_LOGO +#define CONFIG_SPLASH_SCREEN +#define CONFIG_SPLASH_SCREEN_ALIGN +#define CONFIG_VIDEO_BMP_LOGO +#define CONFIG_VIDEO_BMP_GZIP +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE (800*480 + 256*4 + 10*1024) +#define VIDEO_FB_16BPP_WORD_SWAP +#define VIDEO_KBD_INIT_FCT 0 +#define VIDEO_TSTC_FCT serial_tstc +#define VIDEO_GETC_FCT serial_getc + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE 1 +#define CONFIG_BOOTP_BOOTPATH 1 +#define CONFIG_BOOTP_GATEWAY 1 +#define CONFIG_BOOTP_HOSTNAME 1 + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_IMI +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_SOURCE +#undef CONFIG_CMD_NFS +#undef CONFIG_CMD_XIMG + +#define CONFIG_CMD_BMP 1 +#define CONFIG_CMD_CAN 1 +#define CONFIG_CMD_DHCP 1 +#define CONFIG_CMD_ELF 1 +#define CONFIG_CMD_FAT 1 +#define CONFIG_CMD_IMI 1 +#define CONFIG_CMD_PING 1 +#define CONFIG_CMD_USB 1 + +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +/* USB */ +#define CONFIG_USB_OHCI_NEW +#define CONFIG_SYS_USB_OHCI_REGS_BASE 0xFFF81000 +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "mb86r0x" +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 1 +#define CONFIG_USB_STORAGE +#define CONFIG_DOS_PARTITION + +/* SDRAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM 0x40000000 /* Start address of DDRRAM */ +#define PHYS_SDRAM_SIZE 0x08000000 /* 128 megs */ + +/* + * FLASH and environment organization + */ +#define CONFIG_SYS_FLASH_BASE 0x10000000 +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 256 +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE + +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x00040000) +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_SECT_SIZE (128 * 1024) +#define CONFIG_ENV_SIZE (128 * 1024) + +/* + * CFI FLASH driver setup + */ +#define CONFIG_SYS_FLASH_CFI 1 +#define CONFIG_FLASH_CFI_DRIVER 1 +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 /* ~10x faster */ + +#define CONFIG_SYS_LOAD_ADDR 0x40000000 /* load address */ + +#define CONFIG_SYS_MEMTEST_START (PHYS_SDRAM + (512*1024)) +#define CONFIG_SYS_MEMTEST_END (PHYS_SDRAM + PHYS_SDRAM_SIZE) + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {115200, 19200, 38400, 57600, 9600 } + +#define CONFIG_SYS_PROMPT "jade> " +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_LONGHELP 1 +#define CONFIG_CMDLINE_EDITING 1 + +#define CONFIG_PREBOOT "" + +#define CONFIG_BOOTDELAY 5 +#define CONFIG_AUTOBOOT_KEYED +#define CONFIG_AUTOBOOT_PROMPT "boot in %d s\n", bootdelay +#define CONFIG_AUTOBOOT_DELAY_STR "delaygs" +#define CONFIG_AUTOBOOT_STOP_STR "stopgs" + +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN (0x400000 - 0x8000) +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* 128 bytes for initial data */ + +#define CONFIG_STACKSIZE (32*1024) /* regular stack */ + +/* + * Clock reset generator init + */ +#define CONFIG_SYS_CRG_CRHA_INIT 0xffff +#define CONFIG_SYS_CRG_CRPA_INIT 0xffff +#define CONFIG_SYS_CRG_CRPB_INIT 0xfffe +#define CONFIG_SYS_CRG_CRHB_INIT 0xffff +#define CONFIG_SYS_CRG_CRAM_INIT 0xffef + +/* + * Memory controller settings + */ +#define CONFIG_SYS_MEMC_MCFMODE0_INIT 0x00000001 /* 16bit */ +#define CONFIG_SYS_MEMC_MCFMODE2_INIT 0x00000001 /* 16bit */ +#define CONFIG_SYS_MEMC_MCFMODE4_INIT 0x00000021 /* 16bit, Page*/ +#define CONFIG_SYS_MEMC_MCFTIM0_INIT 0x16191008 +#define CONFIG_SYS_MEMC_MCFTIM2_INIT 0x03061008 +#define CONFIG_SYS_MEMC_MCFTIM4_INIT 0x03061804 +#define CONFIG_SYS_MEMC_MCFAREA0_INIT 0x000000c0 /* 0x0c000000 1MB */ +#define CONFIG_SYS_MEMC_MCFAREA2_INIT 0x00000020 /* 0x02000000 1MB */ +#define CONFIG_SYS_MEMC_MCFAREA4_INIT 0x001f0000 /* 0x10000000 32 MB */ + +/* + * DDR2 controller init settings + */ +#define CONFIG_SYS_DDR2_DRIMS_INIT 0x5555 +#define CONFIG_SYS_CCNT_CDCRC_INIT_1 0x00000002 +#define CONFIG_SYS_CCNT_CDCRC_INIT_2 0x00000003 +#define CONFIG_SYS_DDR2_DRIC1_INIT 0x003f +#define CONFIG_SYS_DDR2_DRIC2_INIT 0x0000 +#define CONFIG_SYS_DDR2_DRCA_INIT 0xc124 /* 512Mbit DDR2SDRAM x 2 */ +#define CONFIG_SYS_DDR2_DRCM_INIT 0x0032 +#define CONFIG_SYS_DDR2_DRCST1_INIT 0x3418 +#define CONFIG_SYS_DDR2_DRCST2_INIT 0x6e32 +#define CONFIG_SYS_DDR2_DRCR_INIT 0x0141 +#define CONFIG_SYS_DDR2_DRCF_INIT 0x0002 +#define CONFIG_SYS_DDR2_DRASR_INIT 0x0001 +#define CONFIG_SYS_DDR2_DROBS_INIT 0x0001 +#define CONFIG_SYS_DDR2_DROABA_INIT 0x0103 +#define CONFIG_SYS_DDR2_DRIBSODT1_INIT 0x003F +#define CONFIG_SYS_DDR2_DROS_INIT 0x0001 + +/* + * DRAM init sequence + */ + +/* PALL Command */ +#define CONFIG_SYS_DDR2_INIT_DRIC1_1 0x0017 +#define CONFIG_SYS_DDR2_INIT_DRIC2_1 0x0400 + +/* EMR(2) command */ +#define CONFIG_SYS_DDR2_INIT_DRIC1_2 0x0006 +#define CONFIG_SYS_DDR2_INIT_DRIC2_2 0x0000 + +/* EMR(3) command */ +#define CONFIG_SYS_DDR2_INIT_DRIC1_3 0x0007 +#define CONFIG_SYS_DDR2_INIT_DRIC2_3 0x0000 + +/* EMR(1) command */ +#define CONFIG_SYS_DDR2_INIT_DRIC1_4 0x0005 +#define CONFIG_SYS_DDR2_INIT_DRIC2_4 0x0000 + +/* MRS command */ +#define CONFIG_SYS_DDR2_INIT_DRIC1_5 0x0004 +#define CONFIG_SYS_DDR2_INIT_DRIC2_5 0x0532 + +/* PALL command */ +#define CONFIG_SYS_DDR2_INIT_DRIC1_6 0x0017 +#define CONFIG_SYS_DDR2_INIT_DRIC2_6 0x0400 + +/* REF command 1 */ +#define CONFIG_SYS_DDR2_INIT_DRIC1_7 0x000f +#define CONFIG_SYS_DDR2_INIT_DRIC2_7 0x0000 + +/* MRS command */ +#define CONFIG_SYS_DDR2_INIT_DRIC1_8 0x0004 +#define CONFIG_SYS_DDR2_INIT_DRIC2_8 0x0432 + +/* EMR(1) command */ +#define CONFIG_SYS_DDR2_INIT_DRIC1_9 0x0005 +#define CONFIG_SYS_DDR2_INIT_DRIC2_9 0x0380 + +/* EMR(1) command */ +#define CONFIG_SYS_DDR2_INIT_DRIC1_10 0x0005 +#define CONFIG_SYS_DDR2_INIT_DRIC2_10 0x0002 + +#ifdef CONFIG_USE_IRQ +#error CONFIG_USE_IRQ not supported +#endif + +#endif /* __CONFIG_H */ diff --git a/tools/Makefile b/tools/Makefile index 749d994..b2e73b2 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -118,6 +118,9 @@ endif ifeq ($(VENDOR),ronetix) LOGO_BMP= logos/ronetix.bmp endif +ifeq ($(VENDOR),syteco) +LOGO_BMP= logos/syteco.bmp +endif
# now $(obj) is defined HOSTSRCS += $(addprefix $(SRCTREE)/,$(EXT_OBJ_FILES-y:.o=.c)) diff --git a/tools/logos/syteco.bmp b/tools/logos/syteco.bmp new file mode 100644 index 0000000000000000000000000000000000000000..9a994fe3e3812bdc2d63f7045d2740d931b2a42a GIT binary patch literal 11414 zcmeI0%Z=PH42HG#1PG8ua@cbU$T=w@oy;*6q@L+)mXs`;FTE_mvj`+$Vm-;vzbIOp zpTGaTJ70d>ocj*7zwrA7zc=^Q_v1f*zJ*`xcs`%*@pwS<xpm#${eIu-^Dz~e3QPqq zP~cWsoRbp=!%6e0_7xyYP4OUX;&?@v`BY<qNM)uXM3F5j;XIMfWw|<7cYm)1ac^7M zc`7S$9X#t+$oJ&xgPAoJxGGi`HnkfBtwoA;ZR9u>;?jzeRD@&naCCtPjCEmR=eG!^ zQa#o$6?*72<zqx*tjm)3O-Cii`K?hHog62(Mq~7HoB}a0x;ak7h=tM3(H<iv#sH4S zt-*xFPF-j;ofqc}3yq2ZhcZIby>Za#nZ-J!3uVH0wB!+kgJR%EA9Aq12N0O(PQ6eZ z$UlR1&A~BJAO?q0Ht&BQ^&pBvVkAH;4hgb*DpU|ea%c>HA5&XnatM%u`(qfa3l0mz z0>RTB%VAF#qXYSRB?sP6xgtpp8mxKWY_v`ft;lE&fTC{zc{EXkA}`|*TXPu)+dZQZ zgA|@|G<1>F8VBm0_P&(XUdBNj6{-<geK6xd-7}#_!8sX@ZYD<%W$HnK1FD!>u)I1x zeAfRI96^!S>k$<B3>>J)NRItNOh05iELAIfp)pd)w*{-%RbN;>-EZcML*E7Dy$EK2 z$8j8R?b=?CzP9E7ul#}*K<eLK&t!U_dGEEL2fqGb5W%s56gg}Vs-k}7Y>(s!AY~2{ zgq@kJTQ#USJV*tH0RpQ?tSVR84!UwXYWVjRRoIBr5JVzIL=MTiRfCLU2dUx^iU^FJ z{1KDSt&W3%NQ^#?xSH;Z($MZ;!O@pbG0K9I29A9yiP6K5&8&OnTX<urac$YB3XG_% zc4_xmAdMW7Ahd0F>0Se*g#-Qz+~i0*OpRzmO&p8Kk#d&nS0HU1i=ju(U3yG{baTYZ zbK0dnB0zdMFzwrpO1&JUlOuePN-phj2GYk7Fh(fS#St;if{=@D566LV9^}}v+N=(L v-!AOjQj8HG2a<6m=FVaZmJGf;QwXdp^U*bbS~I1ozV-x>`b|atPencepjJ52
literal 0 HcmV?d00001
Dear Matthias,
This patch doesn't apply on top of current master. Please fix and resubmit.
Thanks, Anatolij
Anatolij Gustschin
Matthias Weisser
