[PATCH 0/2] Extend board_fdt_blob_setup() to support OF_SEPARATE
it is simply series which align board_fdt_blob_setup() with fdtdec with highest priority on default location where external DTB can be found.
Thanks, Michal
Michal Simek (2): arm64: zynqmp: Rename fw_dtb variable to fdt_blob arm64: zynqmp: Add support for OF_SEPARATE with board DTB
board/xilinx/Kconfig | 2 +- board/xilinx/common/board.c | 31 ++++++++++++++++++++++++------- 2 files changed, 25 insertions(+), 8 deletions(-)
The reason for this change is just get in sync with board_fdt_blob_setup() available at lib/fdtdec.c.
board/xilinx/common/board.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/board/xilinx/common/board.c b/board/xilinx/common/board.c index 1c28263cb889..62dafe0f9058 100644 --- a/board/xilinx/common/board.c +++ b/board/xilinx/common/board.c @@ -40,13 +40,13 @@ int zynq_board_read_rom_ethaddr(unsigned char *ethaddr) #if defined(CONFIG_OF_BOARD) void *board_fdt_blob_setup(void) { - static void *fw_dtb = (void *)CONFIG_XILINX_OF_BOARD_DTB_ADDR; + static void *fdt_blob = (void *)CONFIG_XILINX_OF_BOARD_DTB_ADDR;
- if (fdt_magic(fw_dtb) != FDT_MAGIC) { - printf("DTB is not passed via %p\n", fw_dtb); + if (fdt_magic(fdt_blob) != FDT_MAGIC) { + printf("DTB is not passed via %p\n", fdt_blob); return NULL; }
- return fw_dtb; + return fdt_blob; } #endif
OF_BOARD and OF_SEPARATE can use board specific board_fdt_blob_setup().
OF_BOARD option is mostly used for picking up DTB from certain location.
OF_SEPARATE option is used when DTB is appended after u-boot binary.
This board specific function is aligned with current version in lib/fdtdec.c with checking CONFIG_XILINX_OF_BOARD_DTB_ADDR address first.
board/xilinx/Kconfig | 2 +- board/xilinx/common/board.c | 29 +++++++++++++++++++++++------ 2 files changed, 24 insertions(+), 7 deletions(-)
diff --git a/board/xilinx/Kconfig b/board/xilinx/Kconfig index 7833b11767c4..73fc1be0141e 100644 --- a/board/xilinx/Kconfig +++ b/board/xilinx/Kconfig @@ -44,7 +44,7 @@ config XILINX_OF_BOARD_DTB_ADDR hex default 0x1000 if ARCH_VERSAL default 0x100000 if ARCH_ZYNQ || ARCH_ZYNQMP - depends on OF_BOARD + depends on OF_BOARD || OF_SEPARATE help Offset in the memory where the board configuration DTB is placed.
diff --git a/board/xilinx/common/board.c b/board/xilinx/common/board.c index 62dafe0f9058..03d836feff9a 100644 --- a/board/xilinx/common/board.c +++ b/board/xilinx/common/board.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <asm/sections.h> #include <dm/uclass.h> #include <i2c.h>
@@ -37,16 +38,32 @@ int zynq_board_read_rom_ethaddr(unsigned char *ethaddr) return ret; }
-#if defined(CONFIG_OF_BOARD) +#if defined(CONFIG_OF_BOARD) || defined(CONFIG_OF_SEPARATE) void *board_fdt_blob_setup(void) { static void *fdt_blob = (void *)CONFIG_XILINX_OF_BOARD_DTB_ADDR;
- if (fdt_magic(fdt_blob) != FDT_MAGIC) { - printf("DTB is not passed via %p\n", fdt_blob); - return NULL; - } + if (fdt_magic(fdt_blob) == FDT_MAGIC) + return fdt_blob;
- return fdt_blob; + debug("DTB is not passed via 0x%llx\n", (u64)fdt_blob); + +#ifdef CONFIG_SPL_BUILD + /* FDT is at end of BSS unless it is in a different memory region */ + if (IS_ENABLED(CONFIG_SPL_SEPARATE_BSS)) + fdt_blob = (ulong *)&_image_binary_end; + else + fdt_blob = (ulong *)&__bss_end; +#else + /* FDT is at end of image */ + fdt_blob = (ulong *)&_end; +#endif + + if (fdt_magic(fdt_blob) == FDT_MAGIC) + return fdt_blob; + + debug("DTB is also not passed via 0x%llx\n", (u64)fdt_blob); + + return NULL; } #endif
Michal Simek
