[U-Boot] [PATCH v2 0/8] Add workaround for USB PHY errata
The patch set implement USB PHY errata workaround which are required for LS series of freescale platforms which have Synopsis UTMI PHY
Suresh Gupta (8): armv8: Add workaround for USB erratum A-009008 armv8: Add workaround for USB erratum A-009798 armv8: Add workaround for USB erratum A-008997 armv8: Add workaround for USB erratum A-009007 armv7: Add workaround for USB erratum A-009008 armv7: Add workaround for USB erratum A-009798 armv7: Add workaround for USB erratum A-008997 armv7: Add workaround for USB erratum A-009007
arch/arm/cpu/armv7/ls102xa/Kconfig | 16 +++ arch/arm/cpu/armv7/ls102xa/soc.c | 51 +++++++++ arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 24 +++++ arch/arm/cpu/armv8/fsl-layerscape/soc.c | 117 +++++++++++++++++++++ .../include/asm/arch-fsl-layerscape/immap_lsch2.h | 20 ++++ .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 13 +++ arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h | 19 ++++ 7 files changed, 260 insertions(+)
USB High Speed (HS) EYE Height Adjustment USB HS speed eye diagram fails with the default value at many corners, particularly at a high temperature
Optimal eye at TXVREFTUNE value to 1001 is observed, change set the same vale.
Signed-off-by: Sriram Dash sriram.dash@nxp.com Signed-off-by: Rajesh Bhagat rajesh.bhagat@nxp.com Signed-off-by: Suresh Gupta suresh.gupta@nxp.com --- Changes in v2: None
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 6 ++++++ arch/arm/cpu/armv8/fsl-layerscape/soc.c | 25 ++++++++++++++++++++++ .../include/asm/arch-fsl-layerscape/immap_lsch2.h | 6 ++++++ .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 1 + 4 files changed, 38 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index de0b580..666a3d1 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -18,6 +18,7 @@ config ARCH_LS1043A select SYS_FSL_ERRATUM_A009942 select SYS_FSL_ERRATUM_A010315 select SYS_FSL_ERRATUM_A010539 + select SYS_FSL_ERRATUM_A009008 select SYS_FSL_HAS_DDR3 select SYS_FSL_HAS_DDR4
@@ -33,6 +34,7 @@ config ARCH_LS1046A select SYS_FSL_ERRATUM_A009942 select SYS_FSL_ERRATUM_A010165 select SYS_FSL_ERRATUM_A010539 + select SYS_FSL_ERRATUM_A009008 select SYS_FSL_HAS_DDR4 select SYS_FSL_SRDS_2
@@ -58,6 +60,7 @@ config ARCH_LS2080A select SYS_FSL_ERRATUM_A009803 select SYS_FSL_ERRATUM_A009942 select SYS_FSL_ERRATUM_A010165 + select SYS_FSL_ERRATUM_A009008
config FSL_LSCH2 bool @@ -102,6 +105,9 @@ config SYS_FSL_ERRATUM_A010315 config SYS_FSL_ERRATUM_A010539 bool "Workaround for PIN MUX erratum A010539"
+config SYS_FSL_ERRATUM_A009008 + bool "Workaround for USB PHY erratum A009008" + config MAX_CPUS int "Maximum number of CPUs permitted for Layerscape" default 4 if ARCH_LS1043A diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index 2f54625..951ccba 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -52,6 +52,29 @@ bool soc_has_aiop(void) return false; }
+static void erratum_a009008(void) +{ +#ifdef CONFIG_SYS_FSL_ERRATUM_A009008 +#if defined(CONFIG_LS1043A) || defined(CONFIG_LS1046A) + u32 __iomem *scfg = (u32 __iomem *)SCFG_BASE; + u32 val = scfg_in32(scfg + SCFG_USB3PRM1CR_USB1 / 4); + val &= ~(0xF << 6); + scfg_out32(scfg + SCFG_USB3PRM1CR_USB1 / 4, val|(USB_TXVREFTUNE << 6)); + val = scfg_in32(scfg + SCFG_USB3PRM1CR_USB2 / 4); + val &= ~(0xF << 6); + scfg_out32(scfg + SCFG_USB3PRM1CR_USB2 / 4, val|(USB_TXVREFTUNE << 6)); + val = scfg_in32(scfg + SCFG_USB3PRM1CR_USB3 / 4); + val &= ~(0xF << 6); + scfg_out32(scfg + SCFG_USB3PRM1CR_USB3 / 4, val|(USB_TXVREFTUNE << 6)); +#elif defined(CONFIG_LS2080A) || defined(CONFIG_LS2085A) + u32 __iomem *scfg = (u32 __iomem *)SCFG_BASE; + u32 val = scfg_in32(scfg + SCFG_USB3PRM1CR / 4); + val &= ~(0xF << 6); + scfg_out32(scfg + SCFG_USB3PRM1CR / 4, val|(USB_TXVREFTUNE << 6)); +#endif +#endif /* CONFIG_SYS_FSL_ERRATUM_A009008 */ +} + #if defined(CONFIG_FSL_LSCH3) /* * This erratum requires setting a value to eddrtqcr1 to @@ -194,6 +217,7 @@ void fsl_lsch3_early_init_f(void) erratum_a009203(); erratum_a008514(); erratum_a008336(); + erratum_a009008(); #ifdef CONFIG_CHAIN_OF_TRUST /* In case of Secure Boot, the IBR configures the SMMU * to allow only Secure transactions. @@ -370,6 +394,7 @@ void fsl_lsch2_early_init_f(void) erratum_a009929(); erratum_a009660(); erratum_a010539(); + erratum_a009008(); } #endif
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index b3cfd89..fe37bc1 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -336,6 +336,12 @@ struct ccsr_gur { #define SCFG_USBPWRFAULT_USB2_SHIFT 2 #define SCFG_USBPWRFAULT_USB1_SHIFT 0
+#define SCFG_BASE 0x01570000 +#define SCFG_USB3PRM1CR_USB1 0x070 +#define SCFG_USB3PRM1CR_USB2 0x07C +#define SCFG_USB3PRM1CR_USB3 0x088 +#define USB_TXVREFTUNE 0x9 + #define SCFG_SNPCNFGCR_SECRDSNP 0x80000000 #define SCFG_SNPCNFGCR_SECWRSNP 0x40000000 #define SCFG_SNPCNFGCR_SATARDSNP 0x00800000 diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h index e18dcbd..9aad471 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h @@ -137,6 +137,7 @@ #define SCFG_BASE 0x01fc0000 #define SCFG_USB3PRM1CR 0x000 #define SCFG_USB3PRM1CR_INIT 0x27672b2a +#define USB_TXVREFTUNE 0x9 #define SCFG_QSPICLKCTLR 0x10
#define TP_ITYP_AV 0x00000001 /* Initiator available */
The default setting for USB High Speed Squelch Threshold results in a threshold close to or lower than 100mV. This leads to Receiver Compliance test failure for a 100mV threshold.
The changes shift the threshold from ~100mV towards ~130mV resulting in passing of USB High Speed Receiver Sensitivity Compliance test
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 6 ++++++ arch/arm/cpu/armv8/fsl-layerscape/soc.c | 21 +++++++++++++++++++++ .../include/asm/arch-fsl-layerscape/immap_lsch2.h | 1 + .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 1 + 4 files changed, 29 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 666a3d1..10daaa2 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -19,6 +19,7 @@ config ARCH_LS1043A select SYS_FSL_ERRATUM_A010315 select SYS_FSL_ERRATUM_A010539 select SYS_FSL_ERRATUM_A009008 + select SYS_FSL_ERRATUM_A009798 select SYS_FSL_HAS_DDR3 select SYS_FSL_HAS_DDR4
@@ -35,6 +36,7 @@ config ARCH_LS1046A select SYS_FSL_ERRATUM_A010165 select SYS_FSL_ERRATUM_A010539 select SYS_FSL_ERRATUM_A009008 + select SYS_FSL_ERRATUM_A009798 select SYS_FSL_HAS_DDR4 select SYS_FSL_SRDS_2
@@ -61,6 +63,7 @@ config ARCH_LS2080A select SYS_FSL_ERRATUM_A009942 select SYS_FSL_ERRATUM_A010165 select SYS_FSL_ERRATUM_A009008 + select SYS_FSL_ERRATUM_A009798
config FSL_LSCH2 bool @@ -108,6 +111,9 @@ config SYS_FSL_ERRATUM_A010539 config SYS_FSL_ERRATUM_A009008 bool "Workaround for USB PHY erratum A009008"
+config SYS_FSL_ERRATUM_A009798 + bool "Workaround for USB PHY erratum A009798" + config MAX_CPUS int "Maximum number of CPUs permitted for Layerscape" default 4 if ARCH_LS1043A diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index 951ccba..910f345 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -75,6 +75,25 @@ static void erratum_a009008(void) #endif /* CONFIG_SYS_FSL_ERRATUM_A009008 */ }
+static void erratum_a009798(void) +{ +#ifdef CONFIG_SYS_FSL_ERRATUM_A009798 +#if defined(CONFIG_LS1043A) || defined(CONFIG_LS1046A) + u32 __iomem *scfg = (u32 __iomem *)SCFG_BASE; + u32 val = scfg_in32(scfg + SCFG_USB3PRM1CR_USB1 / 4); + scfg_out32(scfg + SCFG_USB3PRM1CR_USB1 / 4 , val & USB_SQRXTUNE); + val = gur_in32(scfg + SCFG_USB3PRM1CR_USB2 / 4); + scfg_out32(scfg + SCFG_USB3PRM1CR_USB2 / 4 , val & USB_SQRXTUNE); + val = scfg_in32(scfg + SCFG_USB3PRM1CR_USB3 / 4); + scfg_out32(scfg + SCFG_USB3PRM1CR_USB3 / 4 , val & USB_SQRXTUNE); +#elif defined(CONFIG_LS2080A) || defined(CONFIG_LS2085A) + u32 __iomem *scfg = (u32 __iomem *)SCFG_BASE; + u32 val = scfg_in32(scfg + SCFG_USB3PRM1CR / 4); + scfg_out32(scfg + SCFG_USB3PRM1CR / 4, val & USB_SQRXTUNE); +#endif +#endif /* CONFIG_SYS_FSL_ERRATUM_A009798 */ +} + #if defined(CONFIG_FSL_LSCH3) /* * This erratum requires setting a value to eddrtqcr1 to @@ -218,6 +237,7 @@ void fsl_lsch3_early_init_f(void) erratum_a008514(); erratum_a008336(); erratum_a009008(); + erratum_a009798(); #ifdef CONFIG_CHAIN_OF_TRUST /* In case of Secure Boot, the IBR configures the SMMU * to allow only Secure transactions. @@ -395,6 +415,7 @@ void fsl_lsch2_early_init_f(void) erratum_a009660(); erratum_a010539(); erratum_a009008(); + erratum_a009798(); } #endif
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index fe37bc1..ca4a31fe 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -341,6 +341,7 @@ struct ccsr_gur { #define SCFG_USB3PRM1CR_USB2 0x07C #define SCFG_USB3PRM1CR_USB3 0x088 #define USB_TXVREFTUNE 0x9 +#define USB_SQRXTUNE 0xFC7FFFFF
#define SCFG_SNPCNFGCR_SECRDSNP 0x80000000 #define SCFG_SNPCNFGCR_SECWRSNP 0x40000000 diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h index 9aad471..d726256 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h @@ -138,6 +138,7 @@ #define SCFG_USB3PRM1CR 0x000 #define SCFG_USB3PRM1CR_INIT 0x27672b2a #define USB_TXVREFTUNE 0x9 +#define USB_SQRXTUNE 0xFC7FFFFF #define SCFG_QSPICLKCTLR 0x10
Rx Compliance tests may fail intermittently at high jitter frequencies using default register values
Changes identified in test setup makes the Rx compliance test pass
Signed-off-by: Sriram Dash sriram.dash@nxp.com Signed-off-by: Rajesh Bhagat rajesh.bhagat@nxp.com Signed-off-by: Suresh Gupta suresh.gupta@nxp.com --- Changes in v2: Clean up the code after Scott comments, Previously in v1, we was defining the pointer as u32, then casting it to u8, and then passing it to a 16-bit accessor.
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 6 ++++ arch/arm/cpu/armv8/fsl-layerscape/soc.c | 42 ++++++++++++++++++++++ .../include/asm/arch-fsl-layerscape/immap_lsch2.h | 9 +++++ .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 9 +++++ 4 files changed, 66 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 537d721..935a3c1 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -21,6 +21,7 @@ config ARCH_LS1043A select SYS_FSL_ERRATUM_A009008 select SYS_FSL_ERRATUM_A009798 select SYS_FSL_ERRATUM_A008997 + select SYS_FSL_ERRATUM_A009007 select SYS_FSL_HAS_DDR3 select SYS_FSL_HAS_DDR4
@@ -39,6 +40,7 @@ config ARCH_LS1046A select SYS_FSL_ERRATUM_A009008 select SYS_FSL_ERRATUM_A009798 select SYS_FSL_ERRATUM_A008997 + select SYS_FSL_ERRATUM_A009007 select SYS_FSL_HAS_DDR4 select SYS_FSL_SRDS_2
@@ -67,6 +69,7 @@ config ARCH_LS2080A select SYS_FSL_ERRATUM_A009008 select SYS_FSL_ERRATUM_A009798 select SYS_FSL_ERRATUM_A008997 + select SYS_FSL_ERRATUM_A009007
config FSL_LSCH2 bool @@ -120,6 +123,9 @@ config SYS_FSL_ERRATUM_A009798 config SYS_FSL_ERRATUM_A008997 bool "Workaround for USB PHY erratum A008997"
+config SYS_FSL_ERRATUM_A009007 + bool "Workaround for USB PHY erratum A009007" + config MAX_CPUS int "Maximum number of CPUs permitted for Layerscape" default 4 if ARCH_LS1043A diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index d01b957..49181c8 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -120,6 +120,46 @@ static void erratum_a008997(void) #endif #endif /* CONFIG_SYS_FSL_ERRATUM_A008997 */ } +static void erratum_a009007(void) +{ +/* TODO:implement the out_be16 instead of writew which is taking +little endian style */ +#if defined(CONFIG_LS1043A) || defined(CONFIG_LS1046A) + void __iomem *usb_phy = (void __iomem *)USB_PHY1; + writew(USB_PHY_RX_EQ_VAL_1, usb_phy + USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_2, usb_phy + USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_3, usb_phy + USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_4, usb_phy + USB_PHY_RX_OVRD_IN_HI); + usb_phy = (void __iomem *)USB_PHY2; + writew(USB_PHY_RX_EQ_VAL_1, usb_phy + USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_2, usb_phy + USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_3, usb_phy + USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_4, usb_phy + USB_PHY_RX_OVRD_IN_HI); + usb_phy = (void __iomem *)USB_PHY3; + writew(USB_PHY_RX_EQ_VAL_1, usb_phy + USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_2, usb_phy + USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_3, usb_phy + USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_4, usb_phy + USB_PHY_RX_OVRD_IN_HI); +#elif defined(CONFIG_LS2080A) || defined(CONFIG_LS2085A) + void __iomem *dcsr = (void __iomem *)DCSR_BASE; + writew(USB_PHY_RX_EQ_VAL_1, + dcsr + DCSR_USB_PHY1 + DCSR_USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_2, + dcsr + DCSR_USB_PHY1 + DCSR_USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_3, + dcsr + DCSR_USB_PHY1 + DCSR_USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_4, + dcsr + DCSR_USB_PHY1 + DCSR_USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_1, + dcsr + DCSR_USB_PHY2 + DCSR_USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_2, + dcsr + DCSR_USB_PHY2 + DCSR_USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_3, + dcsr + DCSR_USB_PHY2 + DCSR_USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_4, + dcsr + DCSR_USB_PHY2 + DCSR_USB_PHY_RX_OVRD_IN_HI); +#endif /* CONFIG_SYS_FSL_ERRATUM_A009007 */ +}
#if defined(CONFIG_FSL_LSCH3) /* @@ -266,6 +306,7 @@ void fsl_lsch3_early_init_f(void) erratum_a009008(); erratum_a009798(); erratum_a008997(); + erratum_a009007(); #ifdef CONFIG_CHAIN_OF_TRUST /* In case of Secure Boot, the IBR configures the SMMU * to allow only Secure transactions. @@ -445,6 +486,7 @@ void fsl_lsch2_early_init_f(void) erratum_a009008(); erratum_a009798(); erratum_a008997(); + erratum_a009007(); } #endif
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index 964cf3c..dcb1dc3 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -346,6 +346,15 @@ struct ccsr_gur { #define USB_TXVREFTUNE 0x9 #define USB_SQRXTUNE 0xFC7FFFFF #define USB_PCSTXSWINGFULL 0x47 +#define USB_PHY1 0x084F0000 +#define USB_PHY2 0x08500000 +#define USB_PHY3 0x08510000 +#define USB_PHY_RX_OVRD_IN_HI 0x200c +/* TODO : make it generic */ +#define USB_PHY_RX_EQ_VAL_1 0x0000 +#define USB_PHY_RX_EQ_VAL_2 0x8000 +#define USB_PHY_RX_EQ_VAL_3 0x8003 +#define USB_PHY_RX_EQ_VAL_4 0x800b
#define SCFG_SNPCNFGCR_SECRDSNP 0x80000000 #define SCFG_SNPCNFGCR_SECWRSNP 0x40000000 diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h index 731c0ae..6d82e6d 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h @@ -141,6 +141,15 @@ #define USB_TXVREFTUNE 0x9 #define USB_SQRXTUNE 0xFC7FFFFF #define USB_PCSTXSWINGFULL 0x47 +#define DCSR_BASE 0x700000000ULL +#define DCSR_USB_PHY1 0x4600000 +#define DCSR_USB_PHY2 0x4610000 +#define DCSR_USB_PHY_RX_OVRD_IN_HI 0x1006 +#define USB_PHY_RX_EQ_VAL_1 0x0000 +#define USB_PHY_RX_EQ_VAL_2 0x0080 +#define USB_PHY_RX_EQ_VAL_3 0x0380 +#define USB_PHY_RX_EQ_VAL_4 0x0b80 + #define SCFG_QSPICLKCTLR 0x10
Optimal eye at TXVREFTUNE value to 1001 is observed, change set the same value.
Signed-off-by: Sriram Dash sriram.dash@nxp.com Signed-off-by: Suresh Gupta suresh.gupta@nxp.com --- Changes in v2: None
arch/arm/cpu/armv7/ls102xa/Kconfig | 4 ++++ arch/arm/cpu/armv7/ls102xa/soc.c | 13 +++++++++++++ arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h | 4 ++++ 3 files changed, 21 insertions(+)
diff --git a/arch/arm/cpu/armv7/ls102xa/Kconfig b/arch/arm/cpu/armv7/ls102xa/Kconfig index 9ffb90e..40c6782 100644 --- a/arch/arm/cpu/armv7/ls102xa/Kconfig +++ b/arch/arm/cpu/armv7/ls102xa/Kconfig @@ -5,6 +5,7 @@ config ARCH_LS1021A select SYS_FSL_ERRATUM_A009663 select SYS_FSL_ERRATUM_A009942 select SYS_FSL_ERRATUM_A010315 + select SYS_FSL_ERRATUM_A009008 select SYS_FSL_SRDS_1 select SYS_HAS_SERDES select SYS_FSL_DDR_BE if SYS_FSL_DDR @@ -42,6 +43,9 @@ config SECURE_BOOT config SYS_FSL_ERRATUM_A010315 bool "Workaround for PCIe erratum A010315"
+config SYS_FSL_ERRATUM_A009008 + bool "Workaround for USB PHY erratum A009008" + config SYS_FSL_SRDS_1 bool
diff --git a/arch/arm/cpu/armv7/ls102xa/soc.c b/arch/arm/cpu/armv7/ls102xa/soc.c index 52fb6f8..ee27b0c 100644 --- a/arch/arm/cpu/armv7/ls102xa/soc.c +++ b/arch/arm/cpu/armv7/ls102xa/soc.c @@ -60,6 +60,16 @@ unsigned int get_soc_major_rev(void) return major; }
+static void erratum_a009008(void) +{ +#ifdef CONFIG_SYS_FSL_ERRATUM_A009008 + u32 __iomem *scfg = (u32 __iomem *)SCFG_BASE; + u32 val = in_be32(scfg + SCFG_USB3PRM1CR / 4); + val &= ~(0xF << 6); + out_be32(scfg + SCFG_USB3PRM1CR / 4, val|(USB_TXVREFTUNE << 6)); +#endif /* CONFIG_SYS_FSL_ERRATUM_A009008 */ +} + void s_init(void) { } @@ -146,6 +156,9 @@ int arch_soc_init(void) */ out_be32(&scfg->eddrtqcfg, 0x63b20042);
+ /* Erratum */ + erratum_a009008(); + return 0; }
diff --git a/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h b/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h index c34fd63..6ea8c4b 100644 --- a/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h +++ b/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h @@ -173,6 +173,10 @@ struct ccsr_gur { #define SCFG_PMCINTECR_ETSECERRG1 0x00040000 #define SCFG_CLUSTERPMCR_WFIL2EN 0x80000000
+#define SCFG_BASE 0x01570000 +#define SCFG_USB3PRM1CR 0x070 +#define USB_TXVREFTUNE 0x9 + /* Supplemental Configuration Unit */ struct ccsr_scfg { u32 dpslpcr;
The default setting for USB High Speed Squelch Threshold results in a threshold close to or lower than 100mV. This leads to Receive Compliance test failure for a 100mV threshold.
arch/arm/cpu/armv7/ls102xa/Kconfig | 4 ++++ arch/arm/cpu/armv7/ls102xa/soc.c | 10 ++++++++++ arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h | 1 + 3 files changed, 15 insertions(+)
diff --git a/arch/arm/cpu/armv7/ls102xa/Kconfig b/arch/arm/cpu/armv7/ls102xa/Kconfig index 40c6782..b7e6e96 100644 --- a/arch/arm/cpu/armv7/ls102xa/Kconfig +++ b/arch/arm/cpu/armv7/ls102xa/Kconfig @@ -6,6 +6,7 @@ config ARCH_LS1021A select SYS_FSL_ERRATUM_A009942 select SYS_FSL_ERRATUM_A010315 select SYS_FSL_ERRATUM_A009008 + select SYS_FSL_ERRATUM_A009798 select SYS_FSL_SRDS_1 select SYS_HAS_SERDES select SYS_FSL_DDR_BE if SYS_FSL_DDR @@ -46,6 +47,9 @@ config SYS_FSL_ERRATUM_A010315 config SYS_FSL_ERRATUM_A009008 bool "Workaround for USB PHY erratum A009008"
+config SYS_FSL_ERRATUM_A009798 + bool "Workaround for USB PHY erratum A009798" + config SYS_FSL_SRDS_1 bool
diff --git a/arch/arm/cpu/armv7/ls102xa/soc.c b/arch/arm/cpu/armv7/ls102xa/soc.c index ee27b0c..7ae5b29 100644 --- a/arch/arm/cpu/armv7/ls102xa/soc.c +++ b/arch/arm/cpu/armv7/ls102xa/soc.c @@ -70,6 +70,15 @@ static void erratum_a009008(void) #endif /* CONFIG_SYS_FSL_ERRATUM_A009008 */ }
+static void erratum_a009798(void) +{ +#ifdef CONFIG_SYS_FSL_ERRATUM_A009798 + u32 __iomem *scfg = (u32 __iomem *)SCFG_BASE; + u32 val = in_be32(scfg + SCFG_USB3PRM1CR / 4); + out_be32(scfg + SCFG_USB3PRM1CR / 4, val & USB_SQRXTUNE); +#endif /* CONFIG_SYS_FSL_ERRATUM_A009798 */ +} + void s_init(void) { } @@ -158,6 +167,7 @@ int arch_soc_init(void)
/* Erratum */ erratum_a009008(); + erratum_a009798();
return 0; } diff --git a/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h b/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h index 6ea8c4b..8cafa07 100644 --- a/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h +++ b/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h @@ -176,6 +176,7 @@ struct ccsr_gur { #define SCFG_BASE 0x01570000 #define SCFG_USB3PRM1CR 0x070 #define USB_TXVREFTUNE 0x9 +#define USB_SQRXTUNE 0xFC7FFFFF
Low Frequency Periodic Signaling (LFPS) Peak-to-Peak Differential Output Voltage Test Compliance fails using default transmitter settings
Change settings required for transmitter signal swings to pass compliance tests.
arch/arm/cpu/armv7/ls102xa/Kconfig | 4 ++++ arch/arm/cpu/armv7/ls102xa/soc.c | 16 ++++++++++++++++ arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h | 9 +++++++++ 3 files changed, 29 insertions(+)
diff --git a/arch/arm/cpu/armv7/ls102xa/Kconfig b/arch/arm/cpu/armv7/ls102xa/Kconfig index b7e6e96..a68674f 100644 --- a/arch/arm/cpu/armv7/ls102xa/Kconfig +++ b/arch/arm/cpu/armv7/ls102xa/Kconfig @@ -7,6 +7,7 @@ config ARCH_LS1021A select SYS_FSL_ERRATUM_A010315 select SYS_FSL_ERRATUM_A009008 select SYS_FSL_ERRATUM_A009798 + select SYS_FSL_ERRATUM_A008997 select SYS_FSL_SRDS_1 select SYS_HAS_SERDES select SYS_FSL_DDR_BE if SYS_FSL_DDR @@ -50,6 +51,9 @@ config SYS_FSL_ERRATUM_A009008 config SYS_FSL_ERRATUM_A009798 bool "Workaround for USB PHY erratum A009798"
+config SYS_FSL_ERRATUM_A008997 + bool "Workaround for USB PHY erratum A008997" + config SYS_FSL_SRDS_1 bool
diff --git a/arch/arm/cpu/armv7/ls102xa/soc.c b/arch/arm/cpu/armv7/ls102xa/soc.c index 7ae5b29..3d6cc5f 100644 --- a/arch/arm/cpu/armv7/ls102xa/soc.c +++ b/arch/arm/cpu/armv7/ls102xa/soc.c @@ -79,6 +79,21 @@ static void erratum_a009798(void) #endif /* CONFIG_SYS_FSL_ERRATUM_A009798 */ }
+static void erratum_a008997(void) +{ +#ifdef CONFIG_SYS_FSL_ERRATUM_A008997 + void __iomem *usb_phy = (void __iomem *)USB_PHY_BASE; + writew(USB_PHY_TX_OVRD_DRV_LO_VAL, + usb_phy + USB_PHY_TX_OVRD_DRV_LO); + writew(USB_PHY_MPLL_OVRD_IN_HI_VAL, + usb_phy + USB_PHY_MPLL_OVRD_IN_HI); + writew(USB_PHY_LEVEL_OVRD_IN_VAL, + usb_phy + USB_PHY_LEVEL_OVRD_IN); + writew(USB_PHY_TX_OVRD_IN_HI_VAL, + usb_phy + USB_PHY_TX_OVRD_IN_HI); +#endif /* CONFIG_SYS_FSL_ERRATUM_A008997 */ +} + void s_init(void) { } @@ -168,6 +183,7 @@ int arch_soc_init(void) /* Erratum */ erratum_a009008(); erratum_a009798(); + erratum_a008997();
return 0; } diff --git a/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h b/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h index 8cafa07..c0e4372 100644 --- a/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h +++ b/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h @@ -177,6 +177,15 @@ struct ccsr_gur { #define SCFG_USB3PRM1CR 0x070 #define USB_TXVREFTUNE 0x9 #define USB_SQRXTUNE 0xFC7FFFFF +#define USB_PHY_BASE 0x08510000 +#define USB_PHY_TX_OVRD_DRV_LO 0x2004 +#define USB_PHY_MPLL_OVRD_IN_HI 0x0024 +#define USB_PHY_LEVEL_OVRD_IN 0x002a +#define USB_PHY_TX_OVRD_IN_HI 0x2002 +#define USB_PHY_TX_OVRD_DRV_LO_VAL 0x784C +#define USB_PHY_MPLL_OVRD_IN_HI_VAL 0x0080 +#define USB_PHY_LEVEL_OVRD_IN_VAL 0xA9A5 +#define USB_PHY_TX_OVRD_IN_HI_VAL 0x0003
arch/arm/cpu/armv7/ls102xa/Kconfig | 4 ++++ arch/arm/cpu/armv7/ls102xa/soc.c | 12 ++++++++++++ arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h | 5 +++++ 3 files changed, 21 insertions(+)
diff --git a/arch/arm/cpu/armv7/ls102xa/Kconfig b/arch/arm/cpu/armv7/ls102xa/Kconfig index a68674f..b7d785e 100644 --- a/arch/arm/cpu/armv7/ls102xa/Kconfig +++ b/arch/arm/cpu/armv7/ls102xa/Kconfig @@ -8,6 +8,7 @@ config ARCH_LS1021A select SYS_FSL_ERRATUM_A009008 select SYS_FSL_ERRATUM_A009798 select SYS_FSL_ERRATUM_A008997 + select SYS_FSL_ERRATUM_A009007 select SYS_FSL_SRDS_1 select SYS_HAS_SERDES select SYS_FSL_DDR_BE if SYS_FSL_DDR @@ -54,6 +55,9 @@ config SYS_FSL_ERRATUM_A009798 config SYS_FSL_ERRATUM_A008997 bool "Workaround for USB PHY erratum A008997"
+config SYS_FSL_ERRATUM_A009007 + bool "Workaround for USB PHY erratum A009007" + config SYS_FSL_SRDS_1 bool
diff --git a/arch/arm/cpu/armv7/ls102xa/soc.c b/arch/arm/cpu/armv7/ls102xa/soc.c index 3d6cc5f..edb64d5 100644 --- a/arch/arm/cpu/armv7/ls102xa/soc.c +++ b/arch/arm/cpu/armv7/ls102xa/soc.c @@ -94,6 +94,17 @@ static void erratum_a008997(void) #endif /* CONFIG_SYS_FSL_ERRATUM_A008997 */ }
+static void erratum_a009007(void) +{ +#ifdef CONFIG_SYS_FSL_ERRATUM_A009007 + void __iomem *usb_phy = (void __iomem *)USB_PHY_BASE; + writew(USB_PHY_RX_EQ_VAL_1, usb_phy + USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_2, usb_phy + USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_3, usb_phy + USB_PHY_RX_OVRD_IN_HI); + writew(USB_PHY_RX_EQ_VAL_4, usb_phy + USB_PHY_RX_OVRD_IN_HI); +#endif /* CONFIG_SYS_FSL_ERRATUM_A009007 */ +} + void s_init(void) { } @@ -184,6 +195,7 @@ int arch_soc_init(void) erratum_a009008(); erratum_a009798(); erratum_a008997(); + erratum_a009007();
return 0; } diff --git a/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h b/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h index c0e4372..9c4c926 100644 --- a/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h +++ b/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h @@ -182,10 +182,15 @@ struct ccsr_gur { #define USB_PHY_MPLL_OVRD_IN_HI 0x0024 #define USB_PHY_LEVEL_OVRD_IN 0x002a #define USB_PHY_TX_OVRD_IN_HI 0x2002 +#define USB_PHY_RX_OVRD_IN_HI 0x200c #define USB_PHY_TX_OVRD_DRV_LO_VAL 0x784C #define USB_PHY_MPLL_OVRD_IN_HI_VAL 0x0080 #define USB_PHY_LEVEL_OVRD_IN_VAL 0xA9A5 #define USB_PHY_TX_OVRD_IN_HI_VAL 0x0003 +#define USB_PHY_RX_EQ_VAL_1 0x0000 +#define USB_PHY_RX_EQ_VAL_2 0x8000 +#define USB_PHY_RX_EQ_VAL_3 0x8004 +#define USB_PHY_RX_EQ_VAL_4 0x800C
Suresh Gupta
