Suggestion: Revert commit c7fad78ec0ee ("Convert CONFIG_SYS_BR0_PRELIM et al to Kconfig")
Hello! I would suggest to revert commit c7fad78ec0ee ("Convert CONFIG_SYS_BR0_PRELIM et al to Kconfig").
The reason is that this commit made configuration, understanding, maintenance and debugging of the powerpc/mpc85xx Local Bus Controller hard, mainly impossible.
This commit completely removed usage of named macros, to easily check address and size of the LBC memory banks. Removal was done also for explaining comments of configuration options.
It is just a mess what this commit introduced and took me really long time to debug and understand what is happening here... until I reverted this commit manually in my tree.
Any opinions?
Btw, current values are wrong.
Any opinions?
AFAICT, the current values match what was in use prior. But, these should probably not be in CONFIG namespace at all and pulled from either device tree or some other non-board.h header file.
Any opinions?
I'm not going to verify that these values really match as playing with those magic numbers is a pain.
But some of these values were wrong even before that commit. And this can be verified easier (just checking that size does not match to expected value in DTS or documentation).
Well, they do not belong to defconfig. These values are not user configurable and are board wiring dependent. So should have never appeared in menu config.
This is probably the correct place. But you need to know e.g. values for NAND or NOR for accessing these storages and therefore also for loading and reading device tree blob from NAND/NOR.
So they cannot be stored in device tree (unless you parse device tree at compile time and put the constants into appropriate u-boot bin location available prior loading device tree blob).
Unfortunately, these values define configuration for LocalBus Controller which are board dependent and therefore must be in board header file or some other board dependent code (exported to other u-boot subsystem, powerpc/mpc init code and drivers).
Any opinions?
Right. It's been a while since I linked it, but: https://patchwork.ozlabs.org/project/uboot/patch/1500407318-7977-1-git-send-... is what I use for migrating non-obvious values to Kconfig. So I used that to print out all of these, I'm pretty sure before and after.
So some bitrot, probably then, sigh.
So they shouldn't be asked and should be: config SYS_FOO hex default 0xBEEF
in the board Kconfig files. And the help part of drivers/ddr/fsl/Kconfig updated to explain where/how to figure out or find the appropriate values.
Any opinions?
Ok. I guess that this should generate same values for _default_ configuration. But modification via menu config does not have to produce correct values...
The point is that now with magic hex values, it is impossible to detect that constants are not correct.
Previously when constants were defined via named macros, it was lot of easier.
So, if I see that previously Option Register for NAND bank was initialized to value
(OR_AM_32KB | OR_FCM_PGS | OR_FCM_CSCT | OR_FCM_CST | OR_FCM_CHT | OR_FCM_SCY_1 | OR_FCM_TRLX | OR_FCM_EHTR)
I could easily detect that this values is incorrect for NANDs with large paging, which needs 256 kB window.
But now if I see just magic value 0xFFFF8396 I do not spot that this value encodes 32 kB instead of 256 kB.
This is the way how to hide issues and possible bugs.
Having value in board Kconfig file _without_ help text (to make config option _not_ user selectable) is a little bit better. But it lacks help text and still does not solve the problem with magic constants which just hide issues.
For this one particular case for *PRELIM* macros, I'm thinking if it would not be better idea to move all these constants into global variables / arrays, defined in board source files. Like are already defined configuration to TLB entries or LAWs. See files: board/freescale/p1_p2_rdb_pc/law.c board/freescale/p1_p2_rdb_pc/tlb.c Code which needs these values just access (global) variable/array, see how those files are used.
Any opinions?
So, part of the problem is that you shouldn't do what we do today of duplicating "config FOO" in multiple places. Copy/pasting that help probably won't break things, but isn't I think an improvement. There's lots of cases where I suggest / just tell people to have: config FOO hex default 0x100 if A default 0x200 if B || C and so on, and that's also not ideal, but I think does help lead to consolidation down the line. That won't be the case here, since these are board-specific and I can see objections to default 0xBEEF if TARGET_BAR and so on. And as you note above, these should be constructed in many / most cases.
I agree that what's there now isn't ideal. But "leave things in the board.h files until someone can do a clever conversion for these harder problems" hasn't worked. I am quite open to moving forward with better suggestions, especially since there's quite likely more cases of magic values needing to be moved out of where they are and not being really user-configurable either.
Any opinions?
-- Tom
In any case, if I'm looking at these PRELIM macros correctly, they are not DDR-related, so I do not understand why they are defined in drivers/ddr subtree. They are purely LBC specific and required for correct preliminary access to local bus, specially NAND or NOR.
> Hello! I would suggest to revert commit c7fad78ec0ee ("Convert > CONFIG_SYS_BR0_PRELIM et al to Kconfig"). > > The reason is that this commit made configuration, understanding, > maintenance and debugging of the powerpc/mpc85xx Local Bus Controller > hard, mainly impossible. > > This commit completely removed usage of named macros, to easily check > address and size of the LBC memory banks. Removal was done also for > explaining comments of configuration options. > > It is just a mess what this commit introduced and took me really long > time to debug and understand what is happening here... until I reverted > this commit manually in my tree. > > Any opinions? > > Btw, current values are wrong.
Some value I was checking on, I think, was referenced under there, so that's where I put it. Moving it all elsewhere the makes more sense is also totally fine and appropriate.
Pali Rohár
