[PATCH v2] efi_loader: Rename and correct values for ARM_SMC_MM_*
Instead of adding the definition for the specific MM SVC used in StandAloneMM we added the one used in the standard SMC calls. So change the value from -4 to -5 to match the correct one defined in EDK2 and rename them to avoid future confusion
Fixes 23a397d2e2fb: ("efi_loader: Add headers for EDK2 StandAloneMM communication") Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- Changes since v1: - v1 was efi_loader: Correct value for ARM_SMC_MM_RET_NO_MEMORY - Renamed all the definitions according to EDK2 include/mm_communication.h | 16 ++++++++-------- lib/efi_loader/efi_variable_tee.c | 8 ++++---- 2 files changed, 12 insertions(+), 12 deletions(-)
diff --git a/include/mm_communication.h b/include/mm_communication.h index f9c05bb7f104..e464cbb48e22 100644 --- a/include/mm_communication.h +++ b/include/mm_communication.h @@ -52,14 +52,14 @@ struct efi_mm_communicate_header { #define MM_COMMUNICATE_HEADER_SIZE \ (sizeof(struct efi_mm_communicate_header))
-/* Defined in EDK2 ArmPkg/Include/IndustryStandard/ArmStdSmc.h */ - -/* MM return error codes */ -#define ARM_SMC_MM_RET_SUCCESS 0 -#define ARM_SMC_MM_RET_NOT_SUPPORTED -1 -#define ARM_SMC_MM_RET_INVALID_PARAMS -2 -#define ARM_SMC_MM_RET_DENIED -3 -#define ARM_SMC_MM_RET_NO_MEMORY -4 +/* Defined in EDK2 ArmPkg/Include/IndustryStandard/ArmMmSvc.h */ + +/* SPM return error codes */ +#define ARM_SVC_SPM_RET_SUCCESS 0 +#define ARM_SVC_SPM_RET_NOT_SUPPORTED -1 +#define ARM_SVC_SPM_RET_INVALID_PARAMS -2 +#define ARM_SVC_SPM_RET_DENIED -3 +#define ARM_SVC_SPM_RET_NO_MEMORY -5
/* Defined in EDK2 MdeModulePkg/Include/Guid/SmmVariableCommon.h */
diff --git a/lib/efi_loader/efi_variable_tee.c b/lib/efi_loader/efi_variable_tee.c index c0423489388a..5f4aae60bf23 100644 --- a/lib/efi_loader/efi_variable_tee.c +++ b/lib/efi_loader/efi_variable_tee.c @@ -106,19 +106,19 @@ static efi_status_t optee_mm_communicate(void *comm_buf, ulong dsize) tee_close_session(conn.tee, conn.session);
switch (param[1].u.value.a) { - case ARM_SMC_MM_RET_SUCCESS: + case ARM_SVC_SPM_RET_SUCCESS: ret = EFI_SUCCESS; break;
- case ARM_SMC_MM_RET_INVALID_PARAMS: + case ARM_SVC_SPM_RET_INVALID_PARAMS: ret = EFI_INVALID_PARAMETER; break;
- case ARM_SMC_MM_RET_DENIED: + case ARM_SVC_SPM_RET_DENIED: ret = EFI_ACCESS_DENIED; break;
- case ARM_SMC_MM_RET_NO_MEMORY: + case ARM_SVC_SPM_RET_NO_MEMORY: ret = EFI_OUT_OF_RESOURCES; break;
Fixes 23a397d2e2fb: ("efi_loader: Add headers for EDK2 StandAloneMM communication")> Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
Ilias Apalodimas
