[U-Boot] [PATCH] armv7: add cacheline sizes where missing
Some armv7 targets are missing a cache line size declaration. In preparation for "arm: cache: Implement cache range check for v7" patch, add these declarations with the appropriate value for the target's SoC or CPU.
Signed-off-by: Albert ARIBAUD albert.u.boot@aribaud.net ---
include/configs/am3517_crane.h | 2 ++ include/configs/am3517_evm.h | 2 ++ include/configs/at91-sama5_common.h | 2 ++ include/configs/bcm_ep_board.h | 1 + include/configs/cm_t35.h | 2 ++ include/configs/cm_t3517.h | 2 ++ include/configs/colibri_vf.h | 2 ++ include/configs/kzm9g.h | 2 ++ include/configs/nokia_rx51.h | 2 ++ include/configs/pcm052.h | 2 ++ include/configs/rcar-gen2-common.h | 2 ++ include/configs/rk3036_common.h | 2 ++ include/configs/rk3288_common.h | 2 ++ include/configs/s5p_goni.h | 2 ++ include/configs/smdkc100.h | 2 ++ include/configs/tao3530.h | 2 ++ include/configs/ti814x_evm.h | 2 ++ include/configs/ti816x_evm.h | 2 ++ include/configs/ti_omap3_common.h | 5 +++++ include/configs/tricorder.h | 2 ++ include/configs/vexpress_common.h | 2 ++ include/configs/vf610twr.h | 2 ++ 22 files changed, 46 insertions(+)
diff --git a/include/configs/am3517_crane.h b/include/configs/am3517_crane.h index 4ed8e00..3cc2874 100644 --- a/include/configs/am3517_crane.h +++ b/include/configs/am3517_crane.h @@ -13,6 +13,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_SYS_CACHELINE_SIZE 64 + /* * High Level Configuration Options */ diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index 23457d6..4547d7f 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -13,6 +13,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_SYS_CACHELINE_SIZE 64 + /* * High Level Configuration Options */ diff --git a/include/configs/at91-sama5_common.h b/include/configs/at91-sama5_common.h index 9db4a4f..7b06601 100644 --- a/include/configs/at91-sama5_common.h +++ b/include/configs/at91-sama5_common.h @@ -12,6 +12,8 @@
#include <asm/hardware.h>
+#define CONFIG_SYS_CACHELINE_SIZE 64 + #define CONFIG_SYS_TEXT_BASE 0x26f00000
/* ARM asynchronous clock */ diff --git a/include/configs/bcm_ep_board.h b/include/configs/bcm_ep_board.h index 305864f..1d4869b 100644 --- a/include/configs/bcm_ep_board.h +++ b/include/configs/bcm_ep_board.h @@ -11,6 +11,7 @@
#define CONFIG_SKIP_LOWLEVEL_INIT
/* * Memory configuration diff --git a/include/configs/cm_t35.h b/include/configs/cm_t35.h index 2dc745e..24ae14d 100644 --- a/include/configs/cm_t35.h +++ b/include/configs/cm_t35.h @@ -17,6 +17,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_SYS_CACHELINE_SIZE 64 + /* * High Level Configuration Options */ diff --git a/include/configs/cm_t3517.h b/include/configs/cm_t3517.h index 0aefec8..7a07de4 100644 --- a/include/configs/cm_t3517.h +++ b/include/configs/cm_t3517.h @@ -10,6 +10,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_SYS_CACHELINE_SIZE 64 + /* * High Level Configuration Options */ diff --git a/include/configs/colibri_vf.h b/include/configs/colibri_vf.h index 5aed3a5..dd44462 100644 --- a/include/configs/colibri_vf.h +++ b/include/configs/colibri_vf.h @@ -12,6 +12,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_SYS_CACHELINE_SIZE 32 + #include <asm/arch/imx-regs.h>
#define CONFIG_VF610 diff --git a/include/configs/kzm9g.h b/include/configs/kzm9g.h index 94b0f03..d5cbb33 100644 --- a/include/configs/kzm9g.h +++ b/include/configs/kzm9g.h @@ -10,6 +10,8 @@
#undef DEBUG
+#define CONFIG_SYS_CACHELINE_SIZE 32 + #define CONFIG_SH73A0 #define CONFIG_KZM_A9_GT #define CONFIG_RMOBILE_BOARD_STRING "KMC KZM-A9-GT" diff --git a/include/configs/nokia_rx51.h b/include/configs/nokia_rx51.h index b11e43a..5c41405 100644 --- a/include/configs/nokia_rx51.h +++ b/include/configs/nokia_rx51.h @@ -19,6 +19,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_SYS_CACHELINE_SIZE 64 + /* * High Level Configuration Options */ diff --git a/include/configs/pcm052.h b/include/configs/pcm052.h index 891bdb0..2628dfa 100644 --- a/include/configs/pcm052.h +++ b/include/configs/pcm052.h @@ -9,6 +9,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
#define CONFIG_VF610 diff --git a/include/configs/rcar-gen2-common.h b/include/configs/rcar-gen2-common.h index f0a3a18..f750b53 100644 --- a/include/configs/rcar-gen2-common.h +++ b/include/configs/rcar-gen2-common.h @@ -9,6 +9,8 @@ #ifndef __RCAR_GEN2_COMMON_H #define __RCAR_GEN2_COMMON_H
+#define CONFIG_SYS_CACHELINE_SIZE 64 + #include <asm/arch/rmobile.h>
#define CONFIG_CMD_DFL diff --git a/include/configs/rk3036_common.h b/include/configs/rk3036_common.h index d22ea74..368d046 100644 --- a/include/configs/rk3036_common.h +++ b/include/configs/rk3036_common.h @@ -6,6 +6,8 @@ #ifndef __CONFIG_RK3036_COMMON_H #define __CONFIG_RK3036_COMMON_H
+#define CONFIG_SYS_CACHELINE_SIZE 32 + #include <asm/arch/hardware.h>
#define CONFIG_SYS_NO_FLASH diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_common.h index ebf1ab0..427ac4b 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -7,6 +7,8 @@ #ifndef __CONFIG_RK3288_COMMON_H #define __CONFIG_RK3288_COMMON_H
+#define CONFIG_SYS_CACHELINE_SIZE 64 + #include <asm/arch/hardware.h>
#define CONFIG_SYS_NO_FLASH diff --git a/include/configs/s5p_goni.h b/include/configs/s5p_goni.h index 8f65d7e..f92c23d 100644 --- a/include/configs/s5p_goni.h +++ b/include/configs/s5p_goni.h @@ -17,6 +17,8 @@ #define CONFIG_S5PC110 1 /* which is in a S5PC110 */ #define CONFIG_MACH_GONI 1 /* working with Goni */
+#define CONFIG_SYS_CACHELINE_SIZE 64 + #include <linux/sizes.h> #include <asm/arch/cpu.h> /* get chip and board defs */
diff --git a/include/configs/smdkc100.h b/include/configs/smdkc100.h index c36e444..db79e54 100644 --- a/include/configs/smdkc100.h +++ b/include/configs/smdkc100.h @@ -12,6 +12,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_SYS_CACHELINE_SIZE 64 + /* * High Level Configuration Options * (easy to change) diff --git a/include/configs/tao3530.h b/include/configs/tao3530.h index c1bd179..d5aba70 100644 --- a/include/configs/tao3530.h +++ b/include/configs/tao3530.h @@ -13,6 +13,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_SYS_CACHELINE_SIZE 64 + /* * High Level Configuration Options */ diff --git a/include/configs/ti814x_evm.h b/include/configs/ti814x_evm.h index e726040..3d0498d 100644 --- a/include/configs/ti814x_evm.h +++ b/include/configs/ti814x_evm.h @@ -16,6 +16,8 @@ #ifndef __CONFIG_TI814X_EVM_H #define __CONFIG_TI814X_EVM_H
+#define CONFIG_SYS_CACHELINE_SIZE 64 + #define CONFIG_TI81XX #define CONFIG_TI814X #define CONFIG_SYS_NO_FLASH diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index ba652ca..533fae7 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -10,6 +10,8 @@ #ifndef __CONFIG_TI816X_EVM_H #define __CONFIG_TI816X_EVM_H
+#define CONFIG_SYS_CACHELINE_SIZE 64 + #define CONFIG_TI81XX #define CONFIG_TI816X #define CONFIG_SYS_NO_FLASH diff --git a/include/configs/ti_omap3_common.h b/include/configs/ti_omap3_common.h index 02fdcdc..6a4868c 100644 --- a/include/configs/ti_omap3_common.h +++ b/include/configs/ti_omap3_common.h @@ -14,6 +14,11 @@ #ifndef __CONFIG_TI_OMAP3_COMMON_H__ #define __CONFIG_TI_OMAP3_COMMON_H__
+/* + * High Level Configuration Options + */ + +#define CONFIG_SYS_CACHELINE_SIZE 64
#include <asm/arch/cpu.h> #include <asm/arch/omap.h> diff --git a/include/configs/tricorder.h b/include/configs/tricorder.h index f5f5324..2ec2f01 100644 --- a/include/configs/tricorder.h +++ b/include/configs/tricorder.h @@ -16,6 +16,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#define CONFIG_SYS_CACHELINE_SIZE 64 + /* High Level Configuration Options */ #define CONFIG_SYS_THUMB_BUILD #define CONFIG_OMAP /* in a TI OMAP core */ diff --git a/include/configs/vexpress_common.h b/include/configs/vexpress_common.h index cec510c..d78ca0b 100644 --- a/include/configs/vexpress_common.h +++ b/include/configs/vexpress_common.h @@ -118,6 +118,8 @@ #define CONFIG_SYS_MEMTEST_START V2M_BASE #define CONFIG_SYS_MEMTEST_END 0x20000000
+#define CONFIG_SYS_CACHELINE_SIZE 64 + #define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS 1 #define CONFIG_SYS_L2CACHE_OFF 1 diff --git a/include/configs/vf610twr.h b/include/configs/vf610twr.h index dcfafaf..d100f73 100644 --- a/include/configs/vf610twr.h +++ b/include/configs/vf610twr.h @@ -9,6 +9,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
For the TI boards: Reviewed-by: Tom Rini trini@konsulko.com
I think SAMA5 is CortexA5 and that has 32B cachelines.
Best regards, Marek Vasut
Hello Marek,
Correct. V2 incoming.
Amicalement,
Albert ARIBAUD
