[U-Boot] [PATCH 1/5] powerpc/85xx: Enable Errata command on MPC8572DS
Also removed duplicate CONFIG_CMD_IRQ define.
Signed-off-by: York Sun yorksun@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org --- include/configs/MPC8572DS.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index e6b60cf..8f333a6 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -654,12 +654,12 @@ */ #include <config_cmd_default.h>
+#define CONFIG_CMD_ERRATA #define CONFIG_CMD_IRQ #define CONFIG_CMD_PING #define CONFIG_CMD_I2C #define CONFIG_CMD_MII #define CONFIG_CMD_ELF -#define CONFIG_CMD_IRQ #define CONFIG_CMD_SETEXPR #define CONFIG_CMD_REGINFO
This polling loop is not required normally, unless specifically stated in workaround.
Signed-off-by: York Sun yorksun@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/ddr-gen3.c | 2 -- 1 files changed, 0 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/ddr-gen3.c b/arch/powerpc/cpu/mpc85xx/ddr-gen3.c index fa7e09f..b9502f7 100644 --- a/arch/powerpc/cpu/mpc85xx/ddr-gen3.c +++ b/arch/powerpc/cpu/mpc85xx/ddr-gen3.c @@ -199,8 +199,6 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, temp_sdram_cfg = in_be32(&ddr->sdram_cfg) & ~SDRAM_CFG_BI; out_be32(&ddr->sdram_cfg, temp_sdram_cfg | SDRAM_CFG_MEM_EN); asm volatile("sync;isync"); - while (!(in_be32(&ddr->debug[1]) & 0x2)) - ;
/* Poll DDR_SDRAM_CFG_2[D_INIT] bit until auto-data init is done. */ while (in_be32(&ddr->sdram_cfg_2) & 0x10) {
Use unique erratum number instead of platform number. Enable command that reports errata on MPC8572DS.
Signed-off-by: York Sun yorksun@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/cmd_errata.c | 4 +++- arch/powerpc/cpu/mpc85xx/ddr-gen3.c | 2 +- arch/powerpc/include/asm/config_mpc85xx.h | 1 + 3 files changed, 5 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cmd_errata.c b/arch/powerpc/cpu/mpc85xx/cmd_errata.c index 0cc8b1e..94a5876 100644 --- a/arch/powerpc/cpu/mpc85xx/cmd_errata.c +++ b/arch/powerpc/cpu/mpc85xx/cmd_errata.c @@ -71,7 +71,9 @@ static int do_errata(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #ifdef CONFIG_SYS_FSL_ERRATUM_DDR_A003 puts("Work-around for Erratum DDR-A003 enabled\n"); #endif - +#ifdef CONFIG_SYS_FSL_ERRATUM_DDR_115 + puts("Work-around for Erratum DDR115 enabled\n"); +#endif return 0; }
diff --git a/arch/powerpc/cpu/mpc85xx/ddr-gen3.c b/arch/powerpc/cpu/mpc85xx/ddr-gen3.c index b9502f7..35997f2 100644 --- a/arch/powerpc/cpu/mpc85xx/ddr-gen3.c +++ b/arch/powerpc/cpu/mpc85xx/ddr-gen3.c @@ -178,7 +178,7 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, * when operatiing in 32-bit bus mode with 4-beat bursts, * This erratum does not affect DDR3 mode, only for DDR2 mode. */ -#ifdef CONFIG_MPC8572 +#ifdef CONFIG_SYS_FSL_ERRATUM_DDR_115 if ((((in_be32(&ddr->sdram_cfg) >> 24) & 0x7) == SDRAM_TYPE_DDR2) && in_be32(&ddr->sdram_cfg) & 0x80000) { /* set DEBUG_1[31] */ diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 7a0af37..8ef9743 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -77,6 +77,7 @@ #define CONFIG_MAX_CPUS 2 #define CONFIG_SYS_FSL_NUM_LAWS 12 #define CONFIG_SYS_FSL_SEC_COMPAT 2 +#define CONFIG_SYS_FSL_ERRATUM_DDR_115
#elif defined(CONFIG_P1010) #define CONFIG_MAX_CPUS 1
Workaround for the following errata: DDR111 - MCKE signal may not function correctly at assertion of HRESET DDR134 - The automatic CAS-to-Preamble feature of the DDR controller can calibrate to incorrect values
These two workarounds must be implemented together because they touch common registers.
Signed-off-by: York Sun yorksun@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/cmd_errata.c | 4 + arch/powerpc/cpu/mpc85xx/ddr-gen3.c | 107 ++++++++++++++++++++++++++++- arch/powerpc/include/asm/config_mpc85xx.h | 1 + arch/powerpc/include/asm/fsl_ddr_sdram.h | 5 ++ 4 files changed, 116 insertions(+), 1 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cmd_errata.c b/arch/powerpc/cpu/mpc85xx/cmd_errata.c index 94a5876..feee36c 100644 --- a/arch/powerpc/cpu/mpc85xx/cmd_errata.c +++ b/arch/powerpc/cpu/mpc85xx/cmd_errata.c @@ -74,6 +74,10 @@ static int do_errata(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #ifdef CONFIG_SYS_FSL_ERRATUM_DDR_115 puts("Work-around for Erratum DDR115 enabled\n"); #endif +#ifdef CONFIG_SYS_FSL_ERRATUM_DDR111_DDR134 + puts("Work-around for Erratum DDR111 enabled\n"); + puts("Work-around for Erratum DDR134 enabled\n"); +#endif return 0; }
diff --git a/arch/powerpc/cpu/mpc85xx/ddr-gen3.c b/arch/powerpc/cpu/mpc85xx/ddr-gen3.c index 35997f2..73b320b 100644 --- a/arch/powerpc/cpu/mpc85xx/ddr-gen3.c +++ b/arch/powerpc/cpu/mpc85xx/ddr-gen3.c @@ -21,6 +21,10 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, unsigned int i; volatile ccsr_ddr_t *ddr; u32 temp_sdram_cfg; +#ifdef CONFIG_SYS_FSL_ERRATUM_DDR111_DDR134 + volatile ccsr_local_ecm_t *ecm = (void *)CONFIG_SYS_MPC85xx_ECM_ADDR; + u32 total_gb_size_per_controller; +#endif
switch (ctrl_num) { case 0: @@ -185,6 +189,26 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, setbits_be32(&ddr->debug[0], 1); } #endif +#ifdef CONFIG_SYS_FSL_ERRATUM_DDR111_DDR134 + /* + * This is the combined workaround for DDR111 and DDR134 + * following the published errata for MPC8572 + */ + + /* 1. Set EEBACR[3] */ + setbits_be32(&ecm->eebacr, 0x10000000); + debug("Setting EEBACR[3] to 0x%08x\n", in_be32(&ecm->eebacr)); + + /* 2. Set DINIT in SDRAM_CFG_2*/ + setbits_be32(&ddr->sdram_cfg_2, SDRAM_CFG2_D_INIT); + debug("Setting sdram_cfg_2[D_INIT] to 0x%08x\n", + in_be32(&ddr->sdram_cfg_2)); + + /* 3. Set DEBUG_3[21] */ + setbits_be32(&ddr->debug[2], 0x400); + debug("Setting DEBUG_3[21] to 0x%08x\n", in_be32(&ddr->debug[2])); + +#endif /* part 1 of the workaound */
/* * 500 painful micro-seconds must elapse between @@ -201,7 +225,88 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, asm volatile("sync;isync");
/* Poll DDR_SDRAM_CFG_2[D_INIT] bit until auto-data init is done. */ - while (in_be32(&ddr->sdram_cfg_2) & 0x10) { + while (in_be32(&ddr->sdram_cfg_2) & SDRAM_CFG2_D_INIT) udelay(10000); /* throttle polling rate */ + +#ifdef CONFIG_SYS_FSL_ERRATUM_DDR111_DDR134 + /* continue this workaround */ + + /* 4. Clear DEBUG3[21] */ + clrbits_be32(&ddr->debug[2], 0x400); + debug("Clearing D3[21] to 0x%08x\n", in_be32(&ddr->debug[2])); + + /* DDR134 workaround starts */ + /* A: Clear sdram_cfg_2[odt_cfg] */ + clrbits_be32(&ddr->sdram_cfg_2, SDRAM_CFG2_ODT_CFG_MASK); + debug("Clearing SDRAM_CFG2[ODT_CFG] to 0x%08x\n", + in_be32(&ddr->sdram_cfg_2)); + + /* B: Set DEBUG1[15] */ + setbits_be32(&ddr->debug[0], 0x10000); + debug("Setting D1[15] to 0x%08x\n", in_be32(&ddr->debug[0])); + + /* C: Set timing_cfg_2[cpo] to 0b11111 */ + setbits_be32(&ddr->timing_cfg_2, TIMING_CFG_2_CPO_MASK); + debug("Setting TMING_CFG_2[CPO] to 0x%08x\n", + in_be32(&ddr->timing_cfg_2)); + + /* D: Set D6 to 0x9f9f9f9f */ + out_be32(&ddr->debug[5], 0x9f9f9f9f); + debug("Setting D6 to 0x%08x\n", in_be32(&ddr->debug[5])); + + /* E: Set D7 to 0x9f9f9f9f */ + out_be32(&ddr->debug[6], 0x9f9f9f9f); + debug("Setting D7 to 0x%08x\n", in_be32(&ddr->debug[6])); + + /* F: Set D2[20] */ + setbits_be32(&ddr->debug[1], 0x800); + debug("Setting D2[20] to 0x%08x\n", in_be32(&ddr->debug[1])); + + /* G: Poll on D2[20] until cleared */ + while (in_be32(&ddr->debug[1]) & 0x800) + udelay(10000); /* throttle polling rate */ + + /* H: Clear D1[15] */ + clrbits_be32(&ddr->debug[0], 0x10000); + debug("Setting D1[15] to 0x%08x\n", in_be32(&ddr->debug[0])); + + /* I: Set sdram_cfg_2[odt_cfg] */ + setbits_be32(&ddr->sdram_cfg_2, + regs->ddr_sdram_cfg_2 & SDRAM_CFG2_ODT_CFG_MASK); + debug("Setting sdram_cfg_2 to 0x%08x\n", in_be32(&ddr->sdram_cfg_2)); + + /* Continuing with the DDR111 workaround */ + /* 5. Set D2[21] */ + setbits_be32(&ddr->debug[1], 0x400); + debug("Setting D2[21] to 0x%08x\n", in_be32(&ddr->debug[1])); + + /* 6. Poll D2[21] until its cleared */ + while (in_be32(&ddr->debug[1]) & 0x400) + udelay(10000); /* throttle polling rate */ + + /* 7. Wait for 400ms/GB */ + total_gb_size_per_controller = 0; + for (i = 0; i < CONFIG_CHIP_SELECTS_PER_CTRL; i++) { + total_gb_size_per_controller += + ((regs->cs[i].bnds & 0xFFFF) >> 6) + - (regs->cs[i].bnds >> 22) + 1; } + if (in_be32(&ddr->sdram_cfg) & 0x80000) + total_gb_size_per_controller <<= 1; + debug("Wait for %d ms\n", total_gb_size_per_controller * 400); + udelay(total_gb_size_per_controller * 400000); + + /* 8. Set sdram_cfg_2[dinit] if options requires */ + setbits_be32(&ddr->sdram_cfg_2, + regs->ddr_sdram_cfg_2 & SDRAM_CFG2_D_INIT); + debug("Setting sdram_cfg_2 to 0x%08x\n", in_be32(&ddr->sdram_cfg_2)); + + /* 9. Poll until dinit is cleared */ + while (in_be32(&ddr->sdram_cfg_2) & SDRAM_CFG2_D_INIT) + udelay(10000); + + /* 10. Clear EEBACR[3] */ + clrbits_be32(&ecm->eebacr, 10000000); + debug("Clearing EEBACR[3] to 0x%08x\n", in_be32(&ecm->eebacr)); +#endif /* CONFIG_SYS_FSL_ERRATUM_DDR111_DDR134 */ } diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 8ef9743..57d252c 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -78,6 +78,7 @@ #define CONFIG_SYS_FSL_NUM_LAWS 12 #define CONFIG_SYS_FSL_SEC_COMPAT 2 #define CONFIG_SYS_FSL_ERRATUM_DDR_115 +#define CONFIG_SYS_FSL_ERRATUM_DDR111_DDR134
#elif defined(CONFIG_P1010) #define CONFIG_MAX_CPUS 1 diff --git a/arch/powerpc/include/asm/fsl_ddr_sdram.h b/arch/powerpc/include/asm/fsl_ddr_sdram.h index 73bc023..b5b1efe 100644 --- a/arch/powerpc/include/asm/fsl_ddr_sdram.h +++ b/arch/powerpc/include/asm/fsl_ddr_sdram.h @@ -89,6 +89,11 @@ typedef ddr3_spd_eeprom_t generic_spd_eeprom_t; #define SDRAM_CFG_2T_EN 0x00008000 #define SDRAM_CFG_BI 0x00000001
+#define SDRAM_CFG2_D_INIT 0x00000010 +#define SDRAM_CFG2_ODT_CFG_MASK 0x00600000 + +#define TIMING_CFG_2_CPO_MASK 0x0F800000 + #if defined(CONFIG_P4080) #define RD_TO_PRE_MASK 0xf #define RD_TO_PRE_SHIFT 13
Using hwconfig to turn on/off ECC, without re-compiling.
Signed-off-by: York Sun yorksun@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org --- include/configs/MPC8572DS.h | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index 8f333a6..bf2fdd6 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -136,6 +136,7 @@ #define CONFIG_SPD_EEPROM /* Use SPD EEPROM for DDR setup */ #define CONFIG_DDR_SPD
+#define CONFIG_DDR_ECC #define CONFIG_ECC_INIT_VIA_DDRCONTROLLER #define CONFIG_MEM_INIT_VALUE 0xDeadBeef
applied to 85xx
- k
applied to 85xx
- k
applied to 85xx
- k
applied to 85xx
- k
applied to 85xx
- k
Kumar Gala
