[U-Boot] buildman: using wrong libgcc.a
Hi Simon,
In my environment, buildman and MAKEALL are not producing the same results.
It seems that buildman is accidentally picking up the wrong libgcc.a ...
*** buildman ***
$ cat ~/.buildman [toolchain] eldk: /opt/eldk-5.4/armv7a/sysroots/i686-eldk-linux/usr/bin/armv7a-vfp-neon-linux-gnueabi
[toolchain-alias] $
$ tools/buildman/buildman --list-tool-chains No section: 'make-flags' Scanning for tool chains - scanning path '/opt/eldk-5.4/armv7a/sysroots/i686-eldk-linux/usr/bin/armv7a-vfp-neon-linux-gnueabi' - looking in '/opt/eldk-5.4/armv7a/sysroots/i686-eldk-linux/usr/bin/armv7a-vfp-neon-linux-gnueabi/.' - found '/opt/eldk-5.4/armv7a/sysroots/i686-eldk-linux/usr/bin/armv7a-vfp-neon-linux-gnueabi/./armv7a-gcc' Tool chain test: OK - found '/opt/eldk-5.4/armv7a/sysroots/i686-eldk-linux/usr/bin/armv7a-vfp-neon-linux-gnueabi/./arm-linux-gnueabi-gcc' Tool chain test: OK - looking in '/opt/eldk-5.4/armv7a/sysroots/i686-eldk-linux/usr/bin/armv7a-vfp-neon-linux-gnueabi/bin' - looking in '/opt/eldk-5.4/armv7a/sysroots/i686-eldk-linux/usr/bin/armv7a-vfp-neon-linux-gnueabi/usr/bin' List of available toolchains (2): arm : /opt/eldk-5.4/armv7a/sysroots/i686-eldk-linux/usr/bin/armv7a-vfp-neon-linux-gnueabi/./arm-linux-gnueabi-gcc armv7a : /opt/eldk-5.4/armv7a/sysroots/i686-eldk-linux/usr/bin/armv7a-vfp-neon-linux-gnueabi/./armv7a-gcc $
$ tools/buildman/buildman bcm28155_ap -x bcm28155_w1d -fk No section: 'make-flags' WARNING: no status info for 'Ippo_q8h' WARNING: no maintainers for 'Ippo_q8h' Building current source for 1 boards (1 thread, 8 jobs per thread) 1 0 0 /1 bcm28155_ap $
$ head -14 ../current/current/bcm28155_ap/u-boot.map Archive member included because of file (symbol)
/usr/lib/gcc/arm-linux-gnueabi/4.6/libgcc.a(_udivsi3.o) arch/arm/cpu/armv7/bcm281xx/built-in.o (__aeabi_uidiv) /usr/lib/gcc/arm-linux-gnueabi/4.6/libgcc.a(_divsi3.o) common/built-in.o (__aeabi_idiv) /usr/lib/gcc/arm-linux-gnueabi/4.6/libgcc.a(_lshrdi3.o) lib/built-in.o (__aeabi_llsr) /usr/lib/gcc/arm-linux-gnueabi/4.6/libgcc.a(_ashldi3.o) drivers/mmc/built-in.o (__aeabi_llsl) /usr/lib/gcc/arm-linux-gnueabi/4.6/libgcc.a(_dvmd_lnx.o)
/usr/lib/gcc/arm-linux-gnueabi/4.6/libgcc.a(_udivsi3.o) (__aeabi_idiv0)
Discarded input sections $
*** MAKEALL ***
$ CROSS_COMPILE_ARM=/opt/eldk-5.4/armv7a/sysroots/i686-eldk-linux/usr/bin/armv7a-vfp-neon-linux-gnueabi/arm-linux-gnueabi- ./MAKEALL -b bcm28155_ap $
$ head -14 u-boot.map Archive member included because of file (symbol)
/opt/eldk-5.4/armv7a/sysroots/armv7a-vfp-neon-linux-gnueabi/usr/lib/arm-linux-gnueabi/4.7.2/libgcc.a(_udivsi3.o) arch/arm/cpu/armv7/bcm281xx/built-in.o (__aeabi_uidiv) /opt/eldk-5.4/armv7a/sysroots/armv7a-vfp-neon-linux-gnueabi/usr/lib/arm-linux-gnueabi/4.7.2/libgcc.a(_divsi3.o) common/built-in.o (__aeabi_idiv) /opt/eldk-5.4/armv7a/sysroots/armv7a-vfp-neon-linux-gnueabi/usr/lib/arm-linux-gnueabi/4.7.2/libgcc.a(_lshrdi3.o) lib/built-in.o (__aeabi_llsr) /opt/eldk-5.4/armv7a/sysroots/armv7a-vfp-neon-linux-gnueabi/usr/lib/arm-linux-gnueabi/4.7.2/libgcc.a(_ashldi3.o) drivers/mmc/built-in.o (__aeabi_llsl) /opt/eldk-5.4/armv7a/sysroots/armv7a-vfp-neon-linux-gnueabi/usr/lib/arm-linux-gnueabi/4.7.2/libgcc.a(_dvmd_lnx.o)
/opt/eldk-5.4/armv7a/sysroots/armv7a-vfp-neon-linux-gnueabi/usr/lib/arm-linux-gnueabi/4.7.2/libgcc.a(_udivsi3.o) (__aeabi_idiv0)
Hmmmm -- maybe it would be better to specify the entire path for the CROSS_COMPILE, and not rely on the PATH to find the cross compile tools:
diff --git a/tools/buildman/toolchain.py b/tools/buildman/toolchain.py index 27dc318..58c7b1f 100644 --- a/tools/buildman/toolchain.py +++ b/tools/buildman/toolchain.py @@ -33,6 +33,7 @@ class Toolchain: self.cross = os.path.basename(fname)[:-3] pos = self.cross.find('-') self.arch = self.cross[:pos] if pos != -1 else 'sandbox' + self.cross = fname[:-3]
env = self.MakeEnvironment()
@@ -82,7 +83,6 @@ class Toolchain: """ env = dict(os.environ) env['CROSS_COMPILE'] = self.cross - env['PATH'] += (':' + self.path) return env
On 14-10-30 09:57 AM, Steve Rae wrote:
Hi Simon,
*** buildman ***
[toolchain-alias] $
- looking in
- found
- looking in
*** MAKEALL ***
Hello Steve,
A bit off topic, but is it possible to stop adding these magic 3 constants. strlen("clang") != 3. strlen("cc") isn't either. Anyway I am aware buildman is already full with it, so I am fine with one more (for now).
Regards, Jeroen
On 30 October 2014 14:57, Jeroen Hofstee jeroen@myspectrum.nl wrote:
Hello Steve,
This should be isolated to Toolchain. I'd be happy to have a fix that solves this once and for all. What is needed?
Hello Steve,
( back to the original issue ) diff --git a/tools/buildman/toolchain.py b/tools/buildman/toolchain.py index 27dc318..58c7b1f 100644 --- a/tools/buildman/toolchain.py +++ b/tools/buildman/toolchain.py @@ -33,6 +33,7 @@ class Toolchain: self.cross = os.path.basename(fname)[:-3] pos = self.cross.find('-') self.arch = self.cross[:pos] if pos != -1 else 'sandbox' + self.cross = fname[:-3]
This solves my problem, however, I have only built "arm" and "armv8" targets.... So I don't know whether it breaks any other environments. How can we proceed? Thanks, Steve
Hello Simon,
Hello Steve,
not that much I think. What would be needed is to store the compiler name in the toolchain object and use the python strlen equivalent on that instead of the hardcoded threes. And eventually pass the correct values to CC and HOSTCC.
When I tried that, subprocess was barfing some (at least for me not easily, [no I don't recall which one exactly] explainable) error, so I gave up and created a script called *-gcc invoking clang and all was fine again ;)
So yes, it would be nice if buildman did not make such an assumption. It is not strictly clang related as well, at least on FreeBSD you can install many gcc compilers, which will be named gcc44, gcc45.. gcc5 etc.
As already mentioned, it is not related to this patch, it adds just another hardcoded magic 3 value.
Regards, Jeroen
On 14-11-05 10:46 AM, Jeroen Hofstee wrote:
Hello Simon,
Hello Steve,
Regards, Jeroen
( updated the subject line for this discussion topic... ) In my experience, we would normally set the CROSS_COMPILE variable to the "prefix" of the cross compiler toolchain, for example:
CROSS_COMPILE=/opt/eldk-5.4/armv7a/sysroots/i686-eldk-linux/usr/bin/armv7a-vfp-neon-linux-gnueabi/arm-linux-gnueabi- Perhaps if the "~/.buildman" defined these "prefixes" (rather than "directories"), then maybe it would be more consistent and simpler.... [ and I suspect that this magic "-3" would go away; isn't this "-3" because we need to strip "gcc" off the end of the string ?!?!?! ] Thanks, Steve
Dear Steve,
Actually we should have only
CROSS_COMPILE=arm-linux-gnueabi-
and make the PATH take care of where to pick the tools from.
On 14-11-05 11:09 AM, Wolfgang Denk wrote:
Dear Steve,
Actually, that would be unfortunate, because I currently have: - /usr/bin/arm-linux-gnueabi-gcc - /opt/eldk-5.4/armv7a/sysroots/i686-eldk-linux/usr/bin/armv7a-vfp-neon-linux-gnueabi/arm-linux-gnueabi-gcc - (and others) installed on my machine.... If $PATH" was to "take care of it", then somehow $PATH would need to be constantly "rearranged" so that the desired compiler is selected correctly. IMO it would be best to specify the "absolute path to the prefix" completely, and not rely on PATH at all! Thanks, Steve
Dear Steve,
- (and others)
This is pretty normal.
Yes, this is what is supposed to happen, for a variety of reasons. Often you select not only the compilers, but more o tools from a specific "SDK" that way.
Usually there will be scripts that do all this for you; with ELDK, that would be "eldk-switch".
No, this is bound to fail.
Jeroen Hofstee
Steve Rae
