[PATCH 1/2] fdt: Correct condition for receiving bloblist
The condition for receiving a bloblist from TPL is reversed. This was only noticed are the other fixes landed. Fix it.
lib/fdtdec.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/fdtdec.c b/lib/fdtdec.c index b0655988029..60e28173c03 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -1677,7 +1677,7 @@ int fdtdec_setup(void) */ if (CONFIG_IS_ENABLED(BLOBLIST) && (xpl_prev_phase() != PHASE_TPL || - !IS_ENABLED(CONFIG_TPL_BLOBLIST))) { + IS_ENABLED(CONFIG_TPL_BLOBLIST))) { ret = bloblist_maybe_init(); if (!ret) { gd->fdt_blob = bloblist_find(BLOBLISTT_CONTROL_FDT, 0);
This returns a devicetree and updates a parameter with an error code. Swap it, since this fits better with the way U-Boot normally works. It also (more easily) allows leaving the existing pointer unchanged.
No yaks were harmed in this change, but there is a very small code-size reduction.
arch/arm/mach-apple/board.c | 7 ++-- arch/arm/mach-snapdragon/board.c | 7 ++-- arch/arm/mach-stm32mp/boot_params.c | 19 ++++++----- arch/sandbox/cpu/cpu.c | 34 ++++++++----------- board/Marvell/octeontx/board-fdt.c | 12 +++---- board/Marvell/octeontx2/board-fdt.c | 12 +++---- board/Marvell/octeontx2/board.c | 2 +- board/andestech/ae350/ae350.c | 23 +++++++------ board/armltd/vexpress64/vexpress64.c | 31 ++++++++--------- board/broadcom/bcmstb/bcmstb.c | 7 ++-- board/emulation/qemu-arm/qemu-arm.c | 7 ++-- board/emulation/qemu-ppce500/qemu-ppce500.c | 12 +++---- board/emulation/qemu-riscv/qemu-riscv.c | 7 ++-- board/highbank/highbank.c | 7 ++-- board/raspberrypi/rpi/rpi.c | 13 ++++--- board/sifive/unleashed/unleashed.c | 9 ++--- board/sifive/unmatched/unmatched.c | 9 ++--- .../visionfive2/starfive_visionfive2.c | 9 ++--- board/xen/xenguest_arm64/xenguest_arm64.c | 14 ++++---- board/xilinx/common/board.c | 26 ++++++++------ include/fdtdec.h | 8 +++-- lib/fdtdec.c | 13 ++++--- 22 files changed, 146 insertions(+), 142 deletions(-)
diff --git a/arch/arm/mach-apple/board.c b/arch/arm/mach-apple/board.c index 0b6d290b8ac..2644a04a622 100644 --- a/arch/arm/mach-apple/board.c +++ b/arch/arm/mach-apple/board.c @@ -691,11 +691,12 @@ int dram_init_banksize(void)
extern long fw_dtb_pointer;
-void *board_fdt_blob_setup(int *err) +int board_fdt_blob_setup(void **fdtp) { /* Return DTB pointer passed by m1n1 */ - *err = 0; - return (void *)fw_dtb_pointer; + *fdtp = (void *)fw_dtb_pointer; + + return 0; }
void build_mem_map(void) diff --git a/arch/arm/mach-snapdragon/board.c b/arch/arm/mach-snapdragon/board.c index 2ab2ceb5138..7a7a36831c3 100644 --- a/arch/arm/mach-snapdragon/board.c +++ b/arch/arm/mach-snapdragon/board.c @@ -147,12 +147,11 @@ static void show_psci_version(void) * or for supporting quirky devices where it's easier to leave the downstream DT in place * to improve ABL compatibility. Otherwise, we use the DT provided by ABL. */ -void *board_fdt_blob_setup(int *err) +int board_fdt_blob_setup(void **fdtp) { struct fdt_header *fdt; bool internal_valid, external_valid;
- *err = 0; fdt = (struct fdt_header *)get_prev_bl_fdt_addr(); external_valid = fdt && !fdt_check_header(fdt); internal_valid = !fdt_check_header(gd->fdt_blob); @@ -170,7 +169,7 @@ void *board_fdt_blob_setup(int *err) } else { debug("Using external FDT\n"); /* So we can use it before returning */ - gd->fdt_blob = fdt; + *fdtp = fdt; }
/* @@ -179,7 +178,7 @@ void *board_fdt_blob_setup(int *err) */ qcom_parse_memory();
- return (void *)gd->fdt_blob; + return 0; }
void reset_cpu(void) diff --git a/arch/arm/mach-stm32mp/boot_params.c b/arch/arm/mach-stm32mp/boot_params.c index ebddf6a7dbc..2d058edc419 100644 --- a/arch/arm/mach-stm32mp/boot_params.c +++ b/arch/arm/mach-stm32mp/boot_params.c @@ -6,6 +6,7 @@ #define LOG_CATEGORY LOGC_ARCH
#include <config.h> +#include <errno.h> #include <log.h> #include <linux/libfdt.h> #include <asm/arch/sys_proto.h> @@ -16,20 +17,22 @@ * Use the saved FDT address provided by TF-A at boot time (NT_FW_CONFIG = * Non Trusted Firmware configuration file) when the pointer is valid */ -void *board_fdt_blob_setup(int *err) +int board_fdt_blob_setup(void **fdtp) { unsigned long nt_fw_dtb = get_stm32mp_bl2_dtb();
log_debug("%s: nt_fw_dtb=%lx\n", __func__, nt_fw_dtb);
- *err = 0; /* use external device tree only if address is valid */ - if (nt_fw_dtb >= STM32_DDR_BASE) { - if (fdt_magic(nt_fw_dtb) == FDT_MAGIC) - return (void *)nt_fw_dtb; - log_debug("%s: DTB not found.\n", __func__); + if (nt_fw_dtb < STM32_DDR_BASE || + fdt_magic(nt_fw_dtb) != FDT_MAGIC) { + log_debug("DTB not found.\n"); + log_debug("fall back to builtin DTB, %p\n", _end); + + return -EEXIST; } - log_debug("%s: fall back to builtin DTB, %p\n", __func__, _end);
- return (void *)_end; + *fdtp = (void *)nt_fw_dtb; + + return 0; } diff --git a/arch/sandbox/cpu/cpu.c b/arch/sandbox/cpu/cpu.c index 06f8c13fab9..55a430e4c90 100644 --- a/arch/sandbox/cpu/cpu.c +++ b/arch/sandbox/cpu/cpu.c @@ -355,7 +355,7 @@ static int setup_auto_tree(void *blob) return 0; }
-void *board_fdt_blob_setup(int *ret) +int board_fdt_blob_setup(void **fdtp) { struct sandbox_state *state = state_get_current(); const char *fname = state->fdt_fname; @@ -364,44 +364,40 @@ void *board_fdt_blob_setup(int *ret) int err; int fd;
- if (gd->fdt_blob) - return (void *)gd->fdt_blob; blob = map_sysmem(CONFIG_SYS_FDT_LOAD_ADDR, 0); - *ret = 0; if (!state->fdt_fname) { err = setup_auto_tree(blob); - if (!err) - goto done; - os_printf("Unable to create empty FDT: %s\n", fdt_strerror(err)); - *ret = -EINVAL; - goto fail; + if (err) { + os_printf("Unable to create empty FDT: %s\n", + fdt_strerror(err)); + return -EINVAL; + } + *fdtp = blob; + + return 0; }
err = os_get_filesize(fname, &size); if (err < 0) { os_printf("Failed to find FDT file '%s'\n", fname); - *ret = err; - goto fail; + return err; } fd = os_open(fname, OS_O_RDONLY); if (fd < 0) { os_printf("Failed to open FDT file '%s'\n", fname); - *ret = -EACCES; - goto fail; + return -EACCES; }
if (os_read(fd, blob, size) != size) { os_close(fd); os_printf("Failed to read FDT file '%s'\n", fname); - *ret = -EIO; - goto fail; + return -EIO; } os_close(fd);
-done: - return blob; -fail: - return NULL; + *fdtp = blob; + + return 0; }
ulong timer_get_boot_us(void) diff --git a/board/Marvell/octeontx/board-fdt.c b/board/Marvell/octeontx/board-fdt.c index 6642b167e19..9d913b959e0 100644 --- a/board/Marvell/octeontx/board-fdt.c +++ b/board/Marvell/octeontx/board-fdt.c @@ -296,13 +296,9 @@ int ft_board_setup(void *blob, struct bd_info *bd) return 0; }
-/** - * Return the FDT base address that was passed by ATF - * - * Return: FDT base address received from ATF in x1 register - */ -void *board_fdt_blob_setup(int *err) +int board_fdt_blob_setup(void **fdtp) { - *err = 0; - return (void *)fdt_base_addr; + *fdtp = (void *)fdt_base_addr; + + return 0; } diff --git a/board/Marvell/octeontx2/board-fdt.c b/board/Marvell/octeontx2/board-fdt.c index 04be9fb0a9a..e5a4db00bb7 100644 --- a/board/Marvell/octeontx2/board-fdt.c +++ b/board/Marvell/octeontx2/board-fdt.c @@ -210,13 +210,9 @@ int ft_board_setup(void *blob, struct bd_info *bd) return 0; }
-/** - * Return the FDT base address that was passed by ATF - * - * Return: FDT base address received from ATF in x1 register - */ -void *board_fdt_blob_setup(int *err) +int board_fdt_blob_setup(void **fdtp) { - *err = 0; - return (void *)fdt_base_addr; + *fdtp = (void *)fdt_base_addr; + + return 0; } diff --git a/board/Marvell/octeontx2/board.c b/board/Marvell/octeontx2/board.c index 974e9eb8200..170b4a89946 100644 --- a/board/Marvell/octeontx2/board.c +++ b/board/Marvell/octeontx2/board.c @@ -234,7 +234,7 @@ static int do_go_uboot(struct cmd_tbl *cmdtp, int flag, int argc, return CMD_RET_USAGE;
addr = hextoul(argv[1], NULL); - fdt = board_fdt_blob_setup(&err); + err = board_fdt_blob_setup(&fdt); entry = (uboot_entry_t)addr; flush_cache((ulong)addr, 1 << 20); /* 1MiB should be enough */ dcache_disable(); diff --git a/board/andestech/ae350/ae350.c b/board/andestech/ae350/ae350.c index 5ae5baed6ba..1d9d4a929c2 100644 --- a/board/andestech/ae350/ae350.c +++ b/board/andestech/ae350/ae350.c @@ -79,21 +79,24 @@ ulong board_flash_get_legacy(ulong base, int banknum, flash_info_t *info) }
#define ANDES_HW_DTB_ADDRESS 0xF2000000 -void *board_fdt_blob_setup(int *err) +int board_fdt_blob_setup(void **fdtp) { - *err = 0; - if (IS_ENABLED(CONFIG_OF_SEPARATE) || IS_ENABLED(CONFIG_OF_BOARD)) { - if (fdt_magic((uintptr_t)gd->arch.firmware_fdt_addr) == FDT_MAGIC) - return (void *)(ulong)gd->arch.firmware_fdt_addr; + if (fdt_magic((uintptr_t)gd->arch.firmware_fdt_addr) == + FDT_MAGIC) { + *fdtp = (void *)(ulong)gd->arch.firmware_fdt_addr; + + return 0; + } }
- if (fdt_magic(CONFIG_SYS_FDT_BASE) == FDT_MAGIC) - return (void *)CONFIG_SYS_FDT_BASE; - return (void *)ANDES_HW_DTB_ADDRESS; + if (fdt_magic(CONFIG_SYS_FDT_BASE) == FDT_MAGIC) { + *fdtp = (void *)CONFIG_SYS_FDT_BASE; + + return 0; + }
- *err = -EINVAL; - return NULL; + return -EINVAL; }
#ifdef CONFIG_SPL_BOARD_INIT diff --git a/board/armltd/vexpress64/vexpress64.c b/board/armltd/vexpress64/vexpress64.c index 0119f54f0df..14f9d98d879 100644 --- a/board/armltd/vexpress64/vexpress64.c +++ b/board/armltd/vexpress64/vexpress64.c @@ -168,42 +168,39 @@ static bool is_valid_dtb(uintptr_t dtb_ptr) return fdt_subnode_offset((void *)dtb_ptr, 0, "memory") >= 0; }
-void *board_fdt_blob_setup(int *err) +int board_fdt_blob_setup(void **fdtp) { #ifdef CONFIG_TARGET_VEXPRESS64_JUNO phys_addr_t fdt_rom_addr = find_dtb_in_nor_flash(CONFIG_JUNO_DTB_PART);
- *err = 0; - if (fdt_rom_addr == ~0UL) { - *err = -ENXIO; - return NULL; - } + if (fdt_rom_addr == ~0UL) + return -ENXIO;
- return (void *)fdt_rom_addr; + *fdtp = (void *)fdt_rom_addr; + return 0; #endif
#ifdef VEXPRESS_FDT_ADDR if (fdt_magic(VEXPRESS_FDT_ADDR) == FDT_MAGIC) { - *err = 0; - return (void *)VEXPRESS_FDT_ADDR; + *fdtp = (void *)VEXPRESS_FDT_ADDR; + return 0; } #endif
if (is_valid_dtb(prior_stage_fdt_address[1])) { - *err = 0; - return (void *)prior_stage_fdt_address[1]; + *fdtp = (void *)prior_stage_fdt_address[1]; + return 0; } else if (is_valid_dtb(prior_stage_fdt_address[0])) { - *err = 0; - return (void *)prior_stage_fdt_address[0]; + *fdtp = (void *)prior_stage_fdt_address[0]; + return 0; }
if (fdt_magic(gd->fdt_blob) == FDT_MAGIC) { - *err = 0; - return (void *)gd->fdt_blob; + *fdtp = (void *)gd->fdt_blob; + return 0; }
- *err = -ENXIO; - return NULL; + return -ENXIO; } #endif
diff --git a/board/broadcom/bcmstb/bcmstb.c b/board/broadcom/bcmstb/bcmstb.c index bc05aecc446..e655f610c84 100644 --- a/board/broadcom/bcmstb/bcmstb.c +++ b/board/broadcom/bcmstb/bcmstb.c @@ -130,9 +130,10 @@ int board_late_init(void) return 0; }
-void *board_fdt_blob_setup(int *err) +int board_fdt_blob_setup(void **fdtp) { - *err = 0; /* Stored the DTB address there during our init */ - return (void *)prior_stage_fdt_address; + *fdtp = (void *)prior_stage_fdt_address; + + return 0; } diff --git a/board/emulation/qemu-arm/qemu-arm.c b/board/emulation/qemu-arm/qemu-arm.c index 6095cb02b23..8476796f1c3 100644 --- a/board/emulation/qemu-arm/qemu-arm.c +++ b/board/emulation/qemu-arm/qemu-arm.c @@ -149,11 +149,12 @@ int dram_init_banksize(void) return 0; }
-void *board_fdt_blob_setup(int *err) +int board_fdt_blob_setup(void **fdtp) { - *err = 0; /* QEMU loads a generated DTB for us at the start of RAM. */ - return (void *)CFG_SYS_SDRAM_BASE; + *fdtp = (void *)CFG_SYS_SDRAM_BASE; + + return 0; }
void enable_caches(void) diff --git a/board/emulation/qemu-ppce500/qemu-ppce500.c b/board/emulation/qemu-ppce500/qemu-ppce500.c index 58e5d5eb942..40d295dbf06 100644 --- a/board/emulation/qemu-ppce500/qemu-ppce500.c +++ b/board/emulation/qemu-ppce500/qemu-ppce500.c @@ -334,15 +334,11 @@ u32 cpu_mask(void) return (1 << cpu_numcores()) - 1; }
-/** - * Return the virtual address of FDT that was passed by QEMU - * - * Return: virtual address of FDT received from QEMU in r3 register - */ -void *board_fdt_blob_setup(int *err) +int board_fdt_blob_setup(void **fdtp) { - *err = 0; - return get_fdt_virt(); + *fdtp = get_fdt_virt(); + + return 0; }
/* See CFG_SYS_NS16550_CLK in arch/powerpc/include/asm/config.h */ diff --git a/board/emulation/qemu-riscv/qemu-riscv.c b/board/emulation/qemu-riscv/qemu-riscv.c index e5193e31e37..a90222ea6a4 100644 --- a/board/emulation/qemu-riscv/qemu-riscv.c +++ b/board/emulation/qemu-riscv/qemu-riscv.c @@ -64,9 +64,10 @@ int board_fit_config_name_match(const char *name) } #endif
-void *board_fdt_blob_setup(int *err) +int board_fdt_blob_setup(void **fdtp) { - *err = 0; /* Stored the DTB address there during our init */ - return (void *)(ulong)gd->arch.firmware_fdt_addr; + *fdtp = (void *)(ulong)gd->arch.firmware_fdt_addr; + + return 0; } diff --git a/board/highbank/highbank.c b/board/highbank/highbank.c index f3df83ed6c9..0ec88447384 100644 --- a/board/highbank/highbank.c +++ b/board/highbank/highbank.c @@ -97,15 +97,16 @@ int ft_board_setup(void *fdt, struct bd_info *bd) } #endif
-void *board_fdt_blob_setup(int *err) +int board_fdt_blob_setup(void **fdtp) { - *err = 0; /* * The ECME management processor loads the DTB from NOR flash * into DRAM (at 4KB), where it gets patched to contain the * detected memory size. */ - return (void *)0x1000; + *fdtp = (void *)0x1000; + + return 0; }
static int is_highbank(void) diff --git a/board/raspberrypi/rpi/rpi.c b/board/raspberrypi/rpi/rpi.c index ab5ea85cf9f..5ce6bee7316 100644 --- a/board/raspberrypi/rpi/rpi.c +++ b/board/raspberrypi/rpi/rpi.c @@ -503,15 +503,14 @@ int board_init(void) /* * If the firmware passed a device tree use it for U-Boot. */ -void *board_fdt_blob_setup(int *err) +int board_fdt_blob_setup(void **fdtp) { - *err = 0; - if (fdt_magic(fw_dtb_pointer) != FDT_MAGIC) { - *err = -ENXIO; - return NULL; - } + if (fdt_magic(fw_dtb_pointer) != FDT_MAGIC) + return -ENXIO;
int copy_property(void *dst, void *src, char *path, char *property) diff --git a/board/sifive/unleashed/unleashed.c b/board/sifive/unleashed/unleashed.c index 3c5dd50c369..5c0ac6a0ae2 100644 --- a/board/sifive/unleashed/unleashed.c +++ b/board/sifive/unleashed/unleashed.c @@ -114,15 +114,16 @@ int misc_init_r(void)
#endif
-void *board_fdt_blob_setup(int *err) +int board_fdt_blob_setup(void **fdtp) { - *err = 0; if (IS_ENABLED(CONFIG_OF_SEPARATE) || IS_ENABLED(CONFIG_OF_BOARD)) { if (gd->arch.firmware_fdt_addr) - return (ulong *)(uintptr_t)gd->arch.firmware_fdt_addr; + *fdtp = (ulong *)(uintptr_t)gd->arch.firmware_fdt_addr; }
- return (ulong *)_end; + *fdtp = (ulong *)_end; + + return 0; }
int board_init(void) diff --git a/board/sifive/unmatched/unmatched.c b/board/sifive/unmatched/unmatched.c index c8696270ba2..2b4a74a10a7 100644 --- a/board/sifive/unmatched/unmatched.c +++ b/board/sifive/unmatched/unmatched.c @@ -10,15 +10,16 @@ #include <dm.h> #include <asm/sections.h>
int board_init(void) diff --git a/board/starfive/visionfive2/starfive_visionfive2.c b/board/starfive/visionfive2/starfive_visionfive2.c index f6114602f88..c88bd8192ae 100644 --- a/board/starfive/visionfive2/starfive_visionfive2.c +++ b/board/starfive/visionfive2/starfive_visionfive2.c @@ -115,15 +115,16 @@ int board_late_init(void) return 0; }
int ft_board_setup(void *blob, struct bd_info *bd) diff --git a/board/xen/xenguest_arm64/xenguest_arm64.c b/board/xen/xenguest_arm64/xenguest_arm64.c index 4c3b9c9e278..216a022aa15 100644 --- a/board/xen/xenguest_arm64/xenguest_arm64.c +++ b/board/xen/xenguest_arm64/xenguest_arm64.c @@ -44,14 +44,14 @@ int board_init(void) * x0 is the physical address of the device tree blob (dtb) in system RAM. * This is stored in rom_pointer during low level init. */ -void *board_fdt_blob_setup(int *err) +int board_fdt_blob_setup(void **fdtp) { - *err = 0; - if (fdt_magic(rom_pointer[0]) != FDT_MAGIC) { - *err = -ENXIO; - return NULL; - } - return (void *)rom_pointer[0]; + if (fdt_magic(rom_pointer[0]) != FDT_MAGIC) + return -ENXIO; + + *fdtp = (void *)rom_pointer[0]; + + return 0; }
/* diff --git a/board/xilinx/common/board.c b/board/xilinx/common/board.c index 38dd80533fa..f9421b9a988 100644 --- a/board/xilinx/common/board.c +++ b/board/xilinx/common/board.c @@ -357,17 +357,17 @@ __maybe_unused int xilinx_read_eeprom(void) }
#if defined(CONFIG_OF_BOARD) -void *board_fdt_blob_setup(int *err) +int board_fdt_blob_setup(void **fdtp) { void *fdt_blob;
- *err = 0; - if (IS_ENABLED(CONFIG_TARGET_XILINX_MBV)) { fdt_blob = (void *)CONFIG_XILINX_OF_BOARD_DTB_ADDR;
- if (fdt_magic(fdt_blob) == FDT_MAGIC) - return fdt_blob; + if (fdt_magic(fdt_blob) == FDT_MAGIC) { + *fdtp = fdt_blob; + return 0; + } }
if (!IS_ENABLED(CONFIG_XPL_BUILD) && @@ -375,8 +375,10 @@ void *board_fdt_blob_setup(int *err) !IS_ENABLED(CONFIG_ZYNQMP_NO_DDR)) { fdt_blob = (void *)CONFIG_XILINX_OF_BOARD_DTB_ADDR;
debug("DTB is not passed via %p\n", fdt_blob); } @@ -395,13 +397,15 @@ void *board_fdt_blob_setup(int *err) fdt_blob = (ulong *)_end; }
- if (fdt_magic(fdt_blob) == FDT_MAGIC) - return fdt_blob; + if (fdt_magic(fdt_blob) == FDT_MAGIC) { + *fdtp = fdt_blob; + + return 0; + }
debug("DTB is also not passed via %p\n", fdt_blob);
- *err = -EINVAL; - return NULL; + return -EINVAL; } #endif
diff --git a/include/fdtdec.h b/include/fdtdec.h index 555c9520379..9e36acc7e9b 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -1191,11 +1191,13 @@ int fdtdec_resetup(int *rescan); * * The existing devicetree is available at gd->fdt_blob * - * @err: 0 on success, -EEXIST if the devicetree is already correct, or other + * @fdtp: Existing devicetree blob pointer; update this and return 0 if a + * different devicetree should be used + * Return: 0 on success, -EEXIST if the devicetree is already correct, 0 to use + * *@fdtp as the new devicetree, or other * internal error code if we fail to setup a DTB - * @returns new devicetree blob pointer */ -void *board_fdt_blob_setup(int *err); +int board_fdt_blob_setup(void **fdtp);
/* * Decode the size of memory diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 60e28173c03..e876b17f9ad 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -1706,11 +1706,16 @@ int fdtdec_setup(void)
/* Allow the board to override the fdt address. */ if (IS_ENABLED(CONFIG_OF_BOARD)) { - gd->fdt_blob = board_fdt_blob_setup(&ret); - if (!ret) + void *blob; + + ret = board_fdt_blob_setup(&blob); + if (ret) { + if (ret != -EEXIST) + return ret; + } else { gd->fdt_src = FDTSRC_BOARD; - else if (ret != -EEXIST) - return ret; + gd->fdt_blob = blob; + } }
/* Allow the early environment to override the fdt address */
Hi Simon,
- or for supporting quirky devices where it's easier to leave the downstream DT in place
- to improve ABL compatibility. Otherwise, we use the DT provided by ABL.
gd->fdt_blob = fdt;
*fdtp = fdt;
I believe this is a breaking change. The qcom_parse_memory() call below expects gd->fdt_blob to point to the in-use FDT. This is a bit of a hack, but doing memory parsing this early simplifies things for us.
Additionally, this change doesn't make the function return -EEXIST when it should.
- The existing devicetree is available at gd->fdt_blob
- @err: 0 on success, -EEXIST if the devicetree is already correct, or other
- @fdtp: Existing devicetree blob pointer; update this and return 0 if a
It doesn't looks like this is initialised before calling board_fdt_blob_setup()?
Kind regards,
- different devicetree should be used
- Return: 0 on success, -EEXIST if the devicetree is already correct, 0 to use
- *@fdtp as the new devicetree, or other
- internal error code if we fail to setup a DTB
- @returns new devicetree blob pointer
- Decode the size of memory
if (!ret)
void *blob;
if (ret) {
if (ret != -EEXIST)
return ret;
return ret;
Hi Caleb,
On Mon, 21 Oct 2024 at 15:28, Caleb Connolly caleb.connolly@linaro.org wrote:
Hi Simon,
gd->fdt_blob = fdt;
*fdtp = fdt;
Hmm, OK, thanks. I wonder if there is another place where the memory can be parsed, rather than as a side-effect of this call. I will update this patch and try again.
Kind regards,
if (!ret)
void *blob;
if (ret) {
if (ret != -EEXIST)
return ret;
return ret;
} } /* Allow the early environment to override the fdt address */
-- // Caleb (they/them)
- If the firmware passed a device tree use it for U-Boot.
- *err = 0;
*err = -ENXIO;
return NULL;
return -ENXIO;
return 0; }
Reviewed-by: Matthias Brugger mbrugger@suse.com
Caleb Connolly
Matthias Brugger
