[PATCH] common: Kconfig: Fix CMD_BMP/BMP dependency
Using `default y` will not select BMP when CMD_BMP has been enabled, if it was already configured.
By using `select`, if `CMD_BMP` is turned on, it will force the presence of `BMP`.
Fixes: 072b0e16c482114d242580dd7a3197db5966705f Signed-off-by: Samuel Dionne-Riel samuel@dionne-riel.com --- cmd/Kconfig | 1 + common/Kconfig | 2 +- 2 files changed, 2 insertions(+), 1 deletion(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 02e54f1e50..94c54b2359 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1988,6 +1988,7 @@ config CMD_2048 config CMD_BMP bool "Enable 'bmp' command" depends on VIDEO + select BMP help This provides a way to obtain information about a BMP-format image and to display it. BMP (which presumably stands for BitMaP) is a diff --git a/common/Kconfig b/common/Kconfig index bbabadb35e..d0117e3dc8 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -1157,7 +1157,7 @@ config IO_TRACE
config BMP bool "Enable bmp image display" - default y if CMD_BMP + default n help Enable bmp functions to display bmp image and get bmp info.
The fixes tag should be the "git log -n1 --oneline" version of the commit, btw.
- select BMP help This provides a way to obtain information about a BMP-format image and to display it. BMP (which presumably stands for BitMaP) is a
- default n help Enable bmp functions to display bmp image and get bmp info.
Since this is something that can be resolved by correcting the resulting .config file (or storing a new defconfig in your build system, or what have you) I'm not grabbing this for the release I'll be doing later today. Also in a v2, "default n" is the default. And I'm not entirely sure if BMP (and SPL_BMP) end up being things that should be asked, or should be select'd because they're library functions. Finally, this should perhaps be part of https://patchwork.ozlabs.org/project/uboot/list/?series=360683&state=* but I'm not sure and will wait for Nikhil to chime in.
@Samuel, is it okay if I pick this patch and send it as a patch as part of my above mentioned series with the changes suggested by Tom?
Please do!
Nikhil M Jain
Samuel Dionne-Riel
