[U-Boot] [PATCH] sh: Add support for SH2A freestanding build
SH2A toolchains often only provide an fdpic version of libgcc. This can't be used with bare-metal software like U-Boot, so this patch provides the necessary functions extracted from libgcc.
Signed-off-by: Phil Edworthy phil.edworthy@renesas.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- arch/sh/cpu/sh2/config.mk | 2 +- arch/sh/lib/Makefile | 22 ++++ arch/sh/lib/ashiftlt.S | 192 ++++++++++++++++++++++++++++++++++++ arch/sh/lib/ashiftrt.S | 149 ++++++++++++++++++++++++++++ arch/sh/lib/ashldi3.c | 25 +++++ arch/sh/lib/libgcc.h | 25 +++++ arch/sh/lib/lshiftrt.S | 192 ++++++++++++++++++++++++++++++++++++ arch/sh/lib/lshrdi3.c | 25 +++++ arch/sh/lib/movmem.S | 238 +++++++++++++++++++++++++++++++++++++++++++++ 9 files changed, 869 insertions(+), 1 deletions(-) create mode 100644 arch/sh/lib/ashiftlt.S create mode 100644 arch/sh/lib/ashiftrt.S create mode 100644 arch/sh/lib/ashldi3.c create mode 100644 arch/sh/lib/libgcc.h create mode 100644 arch/sh/lib/lshiftrt.S create mode 100644 arch/sh/lib/lshrdi3.c create mode 100644 arch/sh/lib/movmem.S
diff --git a/arch/sh/cpu/sh2/config.mk b/arch/sh/cpu/sh2/config.mk index f2d40aa..42206e6 100644 --- a/arch/sh/cpu/sh2/config.mk +++ b/arch/sh/cpu/sh2/config.mk @@ -23,6 +23,6 @@ # ENDIANNESS += -EB
-PLATFORM_CPPFLAGS += -m3e -mb +PLATFORM_CPPFLAGS += -m2a -m2a-nofpu -mb -mno-fdpic -ffreestanding PLATFORM_RELFLAGS += -ffixed-r13 PLATFORM_LDFLAGS += $(ENDIANNESS) diff --git a/arch/sh/lib/Makefile b/arch/sh/lib/Makefile index c0670cb..6aaf55a 100644 --- a/arch/sh/lib/Makefile +++ b/arch/sh/lib/Makefile @@ -21,8 +21,15 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(ARCH).o +LIBGCC = $(obj)libgcc.o
SOBJS-y += +GLSOBJS += ashiftrt.o +GLSOBJS += ashiftlt.o +GLSOBJS += lshiftrt.o +GLSOBJS += ashldi3.o +GLSOBJS += lshrdi3.o +GLSOBJS += movmem.o
COBJS-y += board.o COBJS-y += bootm.o @@ -37,10 +44,25 @@ endif
SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) +LGOBJS := $(addprefix $(obj),$(GLSOBJS)) \ + $(addprefix $(obj),$(GLCOBJS)) + +# Always build libsh.o +TARGETS := $(LIB) + +# Build private libgcc only when asked for +ifdef USE_PRIVATE_LIBGCC +TARGETS += $(LIBGCC) +endif + +all: $(TARGETS)
$(LIB): $(obj).depend $(OBJS) $(call cmd_link_o_target, $(OBJS))
+$(LIBGCC): $(obj).depend $(LGOBJS) + $(call cmd_link_o_target, $(LGOBJS)) + #########################################################################
# defines $(obj).depend target diff --git a/arch/sh/lib/ashiftlt.S b/arch/sh/lib/ashiftlt.S new file mode 100644 index 0000000..4940a87 --- /dev/null +++ b/arch/sh/lib/ashiftlt.S @@ -0,0 +1,192 @@ +/* Copyright (C) 1994, 1995, 1997, 1998, 1999, 2000, 2001, 2002, 2003, + 2004, 2005, 2006 + Free Software Foundation, Inc. + +This file is free software; you can redistribute it and/or modify it +under the terms of the GNU General Public License as published by the +Free Software Foundation; either version 2, or (at your option) any +later version. + +In addition to the permissions in the GNU General Public License, the +Free Software Foundation gives you unlimited permission to link the +compiled version of this file into combinations with other programs, +and to distribute those combinations without any restriction coming +from the use of this file. (The General Public License restrictions +do apply in other respects; for example, they cover modification of +the file, and distribution when not linked into a combine +executable.) + +This file is distributed in the hope that it will be useful, but +WITHOUT ANY WARRANTY; without even the implied warranty of +MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU +General Public License for more details. + +You should have received a copy of the GNU General Public License +along with this program; see the file COPYING. If not, write to +the Free Software Foundation, 51 Franklin Street, Fifth Floor, +Boston, MA 02110-1301, USA. */ + +!! libgcc routines for the Renesas / SuperH SH CPUs. +!! Contributed by Steve Chamberlain. +!! sac@cygnus.com + +!! ashiftrt_r4_x, ___ashrsi3, ___ashlsi3, ___lshrsi3 routines +!! recoded in assembly by Toshiyasu Morita +!! tm@netcom.com + +/* SH2 optimizations for ___ashrsi3, ___ashlsi3, ___lshrsi3 and + ELF local label prefixes by J"orn Rennecke + amylaar@cygnus.com */ + +! +! GLOBAL(ashlsi3) +! +! Entry: +! +! r4: Value to shift +! r5: Shifts +! +! Exit: +! +! r0: Result +! +! Destroys: +! +! (none) +! + .global __ashlsi3 + .align 2 +__ashlsi3: + mov #31,r0 + and r0,r5 + mova __ashlsi3_table,r0 + mov.b @(r0,r5),r5 +#ifdef __sh1__ + add r5,r0 + jmp @r0 +#else + braf r5 +#endif + mov r4,r0 + + .align 2 +__ashlsi3_table: + .byte __ashlsi3_0-__ashlsi3_table + .byte __ashlsi3_1-__ashlsi3_table + .byte __ashlsi3_2-__ashlsi3_table + .byte __ashlsi3_3-__ashlsi3_table + .byte __ashlsi3_4-__ashlsi3_table + .byte __ashlsi3_5-__ashlsi3_table + .byte __ashlsi3_6-__ashlsi3_table + .byte __ashlsi3_7-__ashlsi3_table + .byte __ashlsi3_8-__ashlsi3_table + .byte __ashlsi3_9-__ashlsi3_table + .byte __ashlsi3_10-__ashlsi3_table + .byte __ashlsi3_11-__ashlsi3_table + .byte __ashlsi3_12-__ashlsi3_table + .byte __ashlsi3_13-__ashlsi3_table + .byte __ashlsi3_14-__ashlsi3_table + .byte __ashlsi3_15-__ashlsi3_table + .byte __ashlsi3_16-__ashlsi3_table + .byte __ashlsi3_17-__ashlsi3_table + .byte __ashlsi3_18-__ashlsi3_table + .byte __ashlsi3_19-__ashlsi3_table + .byte __ashlsi3_20-__ashlsi3_table + .byte __ashlsi3_21-__ashlsi3_table + .byte __ashlsi3_22-__ashlsi3_table + .byte __ashlsi3_23-__ashlsi3_table + .byte __ashlsi3_24-__ashlsi3_table + .byte __ashlsi3_25-__ashlsi3_table + .byte __ashlsi3_26-__ashlsi3_table + .byte __ashlsi3_27-__ashlsi3_table + .byte __ashlsi3_28-__ashlsi3_table + .byte __ashlsi3_29-__ashlsi3_table + .byte __ashlsi3_30-__ashlsi3_table + .byte __ashlsi3_31-__ashlsi3_table + +__ashlsi3_6: + shll2 r0 +__ashlsi3_4: + shll2 r0 +__ashlsi3_2: + rts + shll2 r0 + +__ashlsi3_7: + shll2 r0 +__ashlsi3_5: + shll2 r0 +__ashlsi3_3: + shll2 r0 +__ashlsi3_1: + rts + shll r0 + +__ashlsi3_14: + shll2 r0 +__ashlsi3_12: + shll2 r0 +__ashlsi3_10: + shll2 r0 +__ashlsi3_8: + rts + shll8 r0 + +__ashlsi3_15: + shll2 r0 +__ashlsi3_13: + shll2 r0 +__ashlsi3_11: + shll2 r0 +__ashlsi3_9: + shll8 r0 + rts + shll r0 + +__ashlsi3_22: + shll2 r0 +__ashlsi3_20: + shll2 r0 +__ashlsi3_18: + shll2 r0 +__ashlsi3_16: + rts + shll16 r0 + +__ashlsi3_23: + shll2 r0 +__ashlsi3_21: + shll2 r0 +__ashlsi3_19: + shll2 r0 +__ashlsi3_17: + shll16 r0 + rts + shll r0 + +__ashlsi3_30: + shll2 r0 +__ashlsi3_28: + shll2 r0 +__ashlsi3_26: + shll2 r0 +__ashlsi3_24: + shll16 r0 + rts + shll8 r0 + +__ashlsi3_31: + shll2 r0 +__ashlsi3_29: + shll2 r0 +__ashlsi3_27: + shll2 r0 +__ashlsi3_25: + shll16 r0 + shll8 r0 + rts + shll r0 + +__ashlsi3_0: + rts + nop diff --git a/arch/sh/lib/ashiftrt.S b/arch/sh/lib/ashiftrt.S new file mode 100644 index 0000000..45ce865 --- /dev/null +++ b/arch/sh/lib/ashiftrt.S @@ -0,0 +1,149 @@ +/* Copyright (C) 1994, 1995, 1997, 1998, 1999, 2000, 2001, 2002, 2003, + 2004, 2005, 2006 + Free Software Foundation, Inc. + +This file is free software; you can redistribute it and/or modify it +under the terms of the GNU General Public License as published by the +Free Software Foundation; either version 2, or (at your option) any +later version. + +In addition to the permissions in the GNU General Public License, the +Free Software Foundation gives you unlimited permission to link the +compiled version of this file into combinations with other programs, +and to distribute those combinations without any restriction coming +from the use of this file. (The General Public License restrictions +do apply in other respects; for example, they cover modification of +the file, and distribution when not linked into a combine +executable.) + +This file is distributed in the hope that it will be useful, but +WITHOUT ANY WARRANTY; without even the implied warranty of +MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU +General Public License for more details. + +You should have received a copy of the GNU General Public License +along with this program; see the file COPYING. If not, write to +the Free Software Foundation, 51 Franklin Street, Fifth Floor, +Boston, MA 02110-1301, USA. */ + +!! libgcc routines for the Renesas / SuperH SH CPUs. +!! Contributed by Steve Chamberlain. +!! sac@cygnus.com + +!! ashiftrt_r4_x, ___ashrsi3, ___ashlsi3, ___lshrsi3 routines +!! recoded in assembly by Toshiyasu Morita +!! tm@netcom.com + +/* SH2 optimizations for ___ashrsi3, ___ashlsi3, ___lshrsi3 and + ELF local label prefixes by J"orn Rennecke + amylaar@cygnus.com */ + + .global __ashiftrt_r4_0 + .global __ashiftrt_r4_1 + .global __ashiftrt_r4_2 + .global __ashiftrt_r4_3 + .global __ashiftrt_r4_4 + .global __ashiftrt_r4_5 + .global __ashiftrt_r4_6 + .global __ashiftrt_r4_7 + .global __ashiftrt_r4_8 + .global __ashiftrt_r4_9 + .global __ashiftrt_r4_10 + .global __ashiftrt_r4_11 + .global __ashiftrt_r4_12 + .global __ashiftrt_r4_13 + .global __ashiftrt_r4_14 + .global __ashiftrt_r4_15 + .global __ashiftrt_r4_16 + .global __ashiftrt_r4_17 + .global __ashiftrt_r4_18 + .global __ashiftrt_r4_19 + .global __ashiftrt_r4_20 + .global __ashiftrt_r4_21 + .global __ashiftrt_r4_22 + .global __ashiftrt_r4_23 + .global __ashiftrt_r4_24 + .global __ashiftrt_r4_25 + .global __ashiftrt_r4_26 + .global __ashiftrt_r4_27 + .global __ashiftrt_r4_28 + .global __ashiftrt_r4_29 + .global __ashiftrt_r4_30 + .global __ashiftrt_r4_31 + .global __ashiftrt_r4_32 + + .align 1 +__ashiftrt_r4_32: +__ashiftrt_r4_31: + rotcl r4 + rts + subc r4,r4 +__ashiftrt_r4_30: + shar r4 +__ashiftrt_r4_29: + shar r4 +__ashiftrt_r4_28: + shar r4 +__ashiftrt_r4_27: + shar r4 +__ashiftrt_r4_26: + shar r4 +__ashiftrt_r4_25: + shar r4 +__ashiftrt_r4_24: + shlr16 r4 + shlr8 r4 + rts + exts.b r4,r4 +__ashiftrt_r4_23: + shar r4 +__ashiftrt_r4_22: + shar r4 +__ashiftrt_r4_21: + shar r4 +__ashiftrt_r4_20: + shar r4 +__ashiftrt_r4_19: + shar r4 +__ashiftrt_r4_18: + shar r4 +__ashiftrt_r4_17: + shar r4 +__ashiftrt_r4_16: + shlr16 r4 + rts + exts.w r4,r4 +__ashiftrt_r4_15: + shar r4 +__ashiftrt_r4_14: + shar r4 +__ashiftrt_r4_13: + shar r4 +__ashiftrt_r4_12: + shar r4 +__ashiftrt_r4_11: + shar r4 +__ashiftrt_r4_10: + shar r4 +__ashiftrt_r4_9: + shar r4 +__ashiftrt_r4_8: + shar r4 +__ashiftrt_r4_7: + shar r4 +__ashiftrt_r4_6: + shar r4 +__ashiftrt_r4_5: + shar r4 +__ashiftrt_r4_4: + shar r4 +__ashiftrt_r4_3: + shar r4 +__ashiftrt_r4_2: + shar r4 +__ashiftrt_r4_1: + rts + shar r4 +__ashiftrt_r4_0: + rts + nop diff --git a/arch/sh/lib/ashldi3.c b/arch/sh/lib/ashldi3.c new file mode 100644 index 0000000..9b50d86 --- /dev/null +++ b/arch/sh/lib/ashldi3.c @@ -0,0 +1,25 @@ +#include "libgcc.h" + +long long __ashldi3(long long u, word_type b) +{ + DWunion uu, w; + word_type bm; + + if (b == 0) + return u; + + uu.ll = u; + bm = 32 - b; + + if (bm <= 0) { + w.s.low = 0; + w.s.high = (unsigned int) uu.s.low << -bm; + } else { + const unsigned int carries = (unsigned int) uu.s.low >> bm; + + w.s.low = (unsigned int) uu.s.low << b; + w.s.high = ((unsigned int) uu.s.high << b) | carries; + } + + return w.ll; +} diff --git a/arch/sh/lib/libgcc.h b/arch/sh/lib/libgcc.h new file mode 100644 index 0000000..05909d5 --- /dev/null +++ b/arch/sh/lib/libgcc.h @@ -0,0 +1,25 @@ +#ifndef __ASM_LIBGCC_H +#define __ASM_LIBGCC_H + +#include <asm/byteorder.h> + +typedef int word_type __attribute__ ((mode (__word__))); + +#ifdef __BIG_ENDIAN +struct DWstruct { + int high, low; +}; +#elif defined(__LITTLE_ENDIAN) +struct DWstruct { + int low, high; +}; +#else +#error I feel sick. +#endif + +typedef union { + struct DWstruct s; + long long ll; +} DWunion; + +#endif /* __ASM_LIBGCC_H */ diff --git a/arch/sh/lib/lshiftrt.S b/arch/sh/lib/lshiftrt.S new file mode 100644 index 0000000..e6fc1cf --- /dev/null +++ b/arch/sh/lib/lshiftrt.S @@ -0,0 +1,192 @@ +/* Copyright (C) 1994, 1995, 1997, 1998, 1999, 2000, 2001, 2002, 2003, + 2004, 2005, 2006 + Free Software Foundation, Inc. + +This file is free software; you can redistribute it and/or modify it +under the terms of the GNU General Public License as published by the +Free Software Foundation; either version 2, or (at your option) any +later version. + +In addition to the permissions in the GNU General Public License, the +Free Software Foundation gives you unlimited permission to link the +compiled version of this file into combinations with other programs, +and to distribute those combinations without any restriction coming +from the use of this file. (The General Public License restrictions +do apply in other respects; for example, they cover modification of +the file, and distribution when not linked into a combine +executable.) + +This file is distributed in the hope that it will be useful, but +WITHOUT ANY WARRANTY; without even the implied warranty of +MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU +General Public License for more details. + +You should have received a copy of the GNU General Public License +along with this program; see the file COPYING. If not, write to +the Free Software Foundation, 51 Franklin Street, Fifth Floor, +Boston, MA 02110-1301, USA. */ + +!! libgcc routines for the Renesas / SuperH SH CPUs. +!! Contributed by Steve Chamberlain. +!! sac@cygnus.com + +!! ashiftrt_r4_x, ___ashrsi3, ___ashlsi3, ___lshrsi3 routines +!! recoded in assembly by Toshiyasu Morita +!! tm@netcom.com + +/* SH2 optimizations for ___ashrsi3, ___ashlsi3, ___lshrsi3 and + ELF local label prefixes by J"orn Rennecke + amylaar@cygnus.com */ + +! +! __lshrsi3) +! +! Entry: +! +! r4: Value to shift +! r5: Shifts +! +! Exit: +! +! r0: Result +! +! Destroys: +! +! (none) +! + .global __lshrsi3 + .align 2 +__lshrsi3: + mov #31,r0 + and r0,r5 + mova __lshrsi3_table,r0 + mov.b @(r0,r5),r5 +#ifdef __sh1__ + add r5,r0 + jmp @r0 +#else + braf r5 +#endif + mov r4,r0 + + .align 2 +__lshrsi3_table: + .byte __lshrsi3_0-__lshrsi3_table + .byte __lshrsi3_1-__lshrsi3_table + .byte __lshrsi3_2-__lshrsi3_table + .byte __lshrsi3_3-__lshrsi3_table + .byte __lshrsi3_4-__lshrsi3_table + .byte __lshrsi3_5-__lshrsi3_table + .byte __lshrsi3_6-__lshrsi3_table + .byte __lshrsi3_7-__lshrsi3_table + .byte __lshrsi3_8-__lshrsi3_table + .byte __lshrsi3_9-__lshrsi3_table + .byte __lshrsi3_10-__lshrsi3_table + .byte __lshrsi3_11-__lshrsi3_table + .byte __lshrsi3_12-__lshrsi3_table + .byte __lshrsi3_13-__lshrsi3_table + .byte __lshrsi3_14-__lshrsi3_table + .byte __lshrsi3_15-__lshrsi3_table + .byte __lshrsi3_16-__lshrsi3_table + .byte __lshrsi3_17-__lshrsi3_table + .byte __lshrsi3_18-__lshrsi3_table + .byte __lshrsi3_19-__lshrsi3_table + .byte __lshrsi3_20-__lshrsi3_table + .byte __lshrsi3_21-__lshrsi3_table + .byte __lshrsi3_22-__lshrsi3_table + .byte __lshrsi3_23-__lshrsi3_table + .byte __lshrsi3_24-__lshrsi3_table + .byte __lshrsi3_25-__lshrsi3_table + .byte __lshrsi3_26-__lshrsi3_table + .byte __lshrsi3_27-__lshrsi3_table + .byte __lshrsi3_28-__lshrsi3_table + .byte __lshrsi3_29-__lshrsi3_table + .byte __lshrsi3_30-__lshrsi3_table + .byte __lshrsi3_31-__lshrsi3_table + +__lshrsi3_6: + shlr2 r0 +__lshrsi3_4: + shlr2 r0 +__lshrsi3_2: + rts + shlr2 r0 + +__lshrsi3_7: + shlr2 r0 +__lshrsi3_5: + shlr2 r0 +__lshrsi3_3: + shlr2 r0 +__lshrsi3_1: + rts + shlr r0 + +__lshrsi3_14: + shlr2 r0 +__lshrsi3_12: + shlr2 r0 +__lshrsi3_10: + shlr2 r0 +__lshrsi3_8: + rts + shlr8 r0 + +__lshrsi3_15: + shlr2 r0 +__lshrsi3_13: + shlr2 r0 +__lshrsi3_11: + shlr2 r0 +__lshrsi3_9: + shlr8 r0 + rts + shlr r0 + +__lshrsi3_22: + shlr2 r0 +__lshrsi3_20: + shlr2 r0 +__lshrsi3_18: + shlr2 r0 +__lshrsi3_16: + rts + shlr16 r0 + +__lshrsi3_23: + shlr2 r0 +__lshrsi3_21: + shlr2 r0 +__lshrsi3_19: + shlr2 r0 +__lshrsi3_17: + shlr16 r0 + rts + shlr r0 + +__lshrsi3_30: + shlr2 r0 +__lshrsi3_28: + shlr2 r0 +__lshrsi3_26: + shlr2 r0 +__lshrsi3_24: + shlr16 r0 + rts + shlr8 r0 + +__lshrsi3_31: + shlr2 r0 +__lshrsi3_29: + shlr2 r0 +__lshrsi3_27: + shlr2 r0 +__lshrsi3_25: + shlr16 r0 + shlr8 r0 + rts + shlr r0 + +__lshrsi3_0: + rts + nop diff --git a/arch/sh/lib/lshrdi3.c b/arch/sh/lib/lshrdi3.c new file mode 100644 index 0000000..bb340ac --- /dev/null +++ b/arch/sh/lib/lshrdi3.c @@ -0,0 +1,25 @@ +#include "libgcc.h" + +long long __lshrdi3(long long u, word_type b) +{ + DWunion uu, w; + word_type bm; + + if (b == 0) + return u; + + uu.ll = u; + bm = 32 - b; + + if (bm <= 0) { + w.s.high = 0; + w.s.low = (unsigned int) uu.s.high >> -bm; + } else { + const unsigned int carries = (unsigned int) uu.s.high << bm; + + w.s.high = (unsigned int) uu.s.high >> b; + w.s.low = ((unsigned int) uu.s.low >> b) | carries; + } + + return w.ll; +} diff --git a/arch/sh/lib/movmem.S b/arch/sh/lib/movmem.S new file mode 100644 index 0000000..c7efd40 --- /dev/null +++ b/arch/sh/lib/movmem.S @@ -0,0 +1,238 @@ +/* Copyright (C) 1994, 1995, 1997, 1998, 1999, 2000, 2001, 2002, 2003, + 2004, 2005, 2006 + Free Software Foundation, Inc. + +This file is free software; you can redistribute it and/or modify it +under the terms of the GNU General Public License as published by the +Free Software Foundation; either version 2, or (at your option) any +later version. + +In addition to the permissions in the GNU General Public License, the +Free Software Foundation gives you unlimited permission to link the +compiled version of this file into combinations with other programs, +and to distribute those combinations without any restriction coming +from the use of this file. (The General Public License restrictions +do apply in other respects; for example, they cover modification of +the file, and distribution when not linked into a combine +executable.) + +This file is distributed in the hope that it will be useful, but +WITHOUT ANY WARRANTY; without even the implied warranty of +MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU +General Public License for more details. + +You should have received a copy of the GNU General Public License +along with this program; see the file COPYING. If not, write to +the Free Software Foundation, 51 Franklin Street, Fifth Floor, +Boston, MA 02110-1301, USA. */ + +!! libgcc routines for the Renesas / SuperH SH CPUs. +!! Contributed by Steve Chamberlain. +!! sac@cygnus.com + +!! ashiftrt_r4_x, ___ashrsi3, ___ashlsi3, ___lshrsi3 routines +!! recoded in assembly by Toshiyasu Morita +!! tm@netcom.com + +/* SH2 optimizations for ___ashrsi3, ___ashlsi3, ___lshrsi3 and + ELF local label prefixes by J"orn Rennecke + amylaar@cygnus.com */ + + .text + .balign 4 + .global __movmem + .global __movstr + .set __movstr, __movmem + /* This would be a lot simpler if r6 contained the byte count + minus 64, and we wouldn't be called here for a byte count of 64. */ +__movmem: + sts.l pr,@-r15 + shll2 r6 + bsr __movmemSI52+2 + mov.l @(48,r5),r0 + .balign 4 +movmem_loop: /* Reached with rts */ + mov.l @(60,r5),r0 + add #-64,r6 + mov.l r0,@(60,r4) + tst r6,r6 + mov.l @(56,r5),r0 + bt movmem_done + mov.l r0,@(56,r4) + cmp/pl r6 + mov.l @(52,r5),r0 + add #64,r5 + mov.l r0,@(52,r4) + add #64,r4 + bt __movmemSI52 +! done all the large groups, do the remainder +! jump to movmem+ + mova __movmemSI4+4,r0 + add r6,r0 + jmp @r0 +movmem_done: ! share slot insn, works out aligned. + lds.l @r15+,pr + mov.l r0,@(56,r4) + mov.l @(52,r5),r0 + rts + mov.l r0,@(52,r4) + .balign 4 + + .global __movmemSI64 + .global __movstrSI64 + .set __movstrSI64, __movmemSI64 +__movmemSI64: + mov.l @(60,r5),r0 + mov.l r0,@(60,r4) + .global __movmemSI60 + .global __movstrSI60 + .set __movstrSI60, __movmemSI60 +__movmemSI60: + mov.l @(56,r5),r0 + mov.l r0,@(56,r4) + .global __movmemSI56 + .global __movstrSI56 + .set __movstrSI56, __movmemSI56 +__movmemSI56: + mov.l @(52,r5),r0 + mov.l r0,@(52,r4) + .global __movmemSI52 + .global __movstrSI52 + .set __movstrSI52, __movmemSI52 +__movmemSI52: + mov.l @(48,r5),r0 + mov.l r0,@(48,r4) + .global __movmemSI48 + .global __movstrSI48 + .set __movstrSI48, __movmemSI48 +__movmemSI48: + mov.l @(44,r5),r0 + mov.l r0,@(44,r4) + .global __movmemSI44 + .global __movstrSI44 + .set __movstrSI44, __movmemSI44 +__movmemSI44: + mov.l @(40,r5),r0 + mov.l r0,@(40,r4) + .global __movmemSI40 + .global __movstrSI40 + .set __movstrSI40, __movmemSI40 +__movmemSI40: + mov.l @(36,r5),r0 + mov.l r0,@(36,r4) + .global __movmemSI36 + .global __movstrSI36 + .set __movstrSI36, __movmemSI36 +__movmemSI36: + mov.l @(32,r5),r0 + mov.l r0,@(32,r4) + .global __movmemSI32 + .global __movstrSI32 + .set __movstrSI32, __movmemSI32 +__movmemSI32: + mov.l @(28,r5),r0 + mov.l r0,@(28,r4) + .global __movmemSI28 + .global __movstrSI28 + .set __movstrSI28, __movmemSI28 +__movmemSI28: + mov.l @(24,r5),r0 + mov.l r0,@(24,r4) + .global __movmemSI24 + .global __movstrSI24 + .set __movstrSI24, __movmemSI24 +__movmemSI24: + mov.l @(20,r5),r0 + mov.l r0,@(20,r4) + .global __movmemSI20 + .global __movstrSI20 + .set __movstrSI20, __movmemSI20 +__movmemSI20: + mov.l @(16,r5),r0 + mov.l r0,@(16,r4) + .global __movmemSI16 + .global __movstrSI16 + .set __movstrSI16, __movmemSI16 +__movmemSI16: + mov.l @(12,r5),r0 + mov.l r0,@(12,r4) + .global __movmemSI12 + .global __movstrSI12 + .set __movstrSI12, __movmemSI12 +__movmemSI12: + mov.l @(8,r5),r0 + mov.l r0,@(8,r4) + .global __movmemSI8 + .global __movstrSI8 + .set __movstrSI8, __movmemSI8 +__movmemSI8: + mov.l @(4,r5),r0 + mov.l r0,@(4,r4) + .global __movmemSI4 + .global __movstrSI4 + .set __movstrSI4, __movmemSI4 +__movmemSI4: + mov.l @(0,r5),r0 + rts + mov.l r0,@(0,r4) + + .global __movmem_i4_even + .global __movstr_i4_even + .set __movstr_i4_even, __movmem_i4_even + + .global __movmem_i4_odd + .global __movstr_i4_odd + .set __movstr_i4_odd, __movmem_i4_odd + + .global __movmemSI12_i4 + .global __movstrSI12_i4 + .set __movstrSI12_i4, __movmemSI12_i4 + + .p2align 5 +L_movmem_2mod4_end: + mov.l r0,@(16,r4) + rts + mov.l r1,@(20,r4) + + .p2align 2 + +__movmem_i4_even: + mov.l @r5+,r0 + bra L_movmem_start_even + mov.l @r5+,r1 + +__movmem_i4_odd: + mov.l @r5+,r1 + add #-4,r4 + mov.l @r5+,r2 + mov.l @r5+,r3 + mov.l r1,@(4,r4) + mov.l r2,@(8,r4) + +L_movmem_loop: + mov.l r3,@(12,r4) + dt r6 + mov.l @r5+,r0 + bt/s L_movmem_2mod4_end + mov.l @r5+,r1 + add #16,r4 +L_movmem_start_even: + mov.l @r5+,r2 + mov.l @r5+,r3 + mov.l r0,@r4 + dt r6 + mov.l r1,@(4,r4) + bf/s L_movmem_loop + mov.l r2,@(8,r4) + rts + mov.l r3,@(12,r4) + + .p2align 4 +__movmemSI12_i4: + mov.l @r5,r0 + mov.l @(4,r5),r1 + mov.l @(8,r5),r2 + mov.l r0,@r4 + mov.l r1,@(4,r4) + rts + mov.l r2,@(8,r4)
Signed-off-by: Phil Edworthy phil.edworthy@renesas.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- Changes for v2: - Removed changes to PLATFORM_CPPFLAGS. These are independent of the patch functionality.
arch/sh/lib/Makefile | 22 +++++ arch/sh/lib/ashiftlt.S | 192 ++++++++++++++++++++++++++++++++++++++ arch/sh/lib/ashiftrt.S | 149 ++++++++++++++++++++++++++++++ arch/sh/lib/ashldi3.c | 25 +++++ arch/sh/lib/libgcc.h | 25 +++++ arch/sh/lib/lshiftrt.S | 192 ++++++++++++++++++++++++++++++++++++++ arch/sh/lib/lshrdi3.c | 25 +++++ arch/sh/lib/movmem.S | 238 ++++++++++++++++++++++++++++++++++++++++++++++++ 8 files changed, 868 insertions(+), 0 deletions(-) create mode 100644 arch/sh/lib/ashiftlt.S create mode 100644 arch/sh/lib/ashiftrt.S create mode 100644 arch/sh/lib/ashldi3.c create mode 100644 arch/sh/lib/libgcc.h create mode 100644 arch/sh/lib/lshiftrt.S create mode 100644 arch/sh/lib/lshrdi3.c create mode 100644 arch/sh/lib/movmem.S
# defines $(obj).depend target diff --git a/arch/sh/lib/ashiftlt.S b/arch/sh/lib/ashiftlt.S new file mode 100644 index 0000000..4940a87 --- /dev/null +++ b/arch/sh/lib/ashiftlt.S @@ -0,0 +1,192 @@ +/* Copyright (C) 1994, 1995, 1997, 1998, 1999, 2000, 2001, 2002, 2003, + 2004, 2005, 2006 + Free Software Foundation, Inc. + +This file is free software; you can redistribute it and/or modify it +under the terms of the GNU General Public License as published by the +Free Software Foundation; either version 2, or (at your option) any +later version. + +In addition to the permissions in the GNU General Public License, the +Free Software Foundation gives you unlimited permission to link the +compiled version of this file into combinations with other programs, +and to distribute those combinations without any restriction coming +from the use of this file. (The General Public License restrictions +do apply in other respects; for example, they cover modification of +the file, and distribution when not linked into a combine +executable.) + +This file is distributed in the hope that it will be useful, but +WITHOUT ANY WARRANTY; without even the implied warranty of +MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU +General Public License for more details. + +You should have received a copy of the GNU General Public License +along with this program; see the file COPYING. If not, write to +the Free Software Foundation, 51 Franklin Street, Fifth Floor, +Boston, MA 02110-1301, USA. */ + +!! libgcc routines for the Renesas / SuperH SH CPUs. +!! Contributed by Steve Chamberlain. +!! sac@cygnus.com + +!! ashiftrt_r4_x, ___ashrsi3, ___ashlsi3, ___lshrsi3 routines +!! recoded in assembly by Toshiyasu Morita +!! tm@netcom.com + +/* SH2 optimizations for ___ashrsi3, ___ashlsi3, ___lshrsi3 and + ELF local label prefixes by J"orn Rennecke + amylaar@cygnus.com */ + +! +! GLOBAL(ashlsi3) +! +! Entry: +! +! r4: Value to shift +! r5: Shifts +! +! Exit: +! +! r0: Result +! +! Destroys: +! +! (none) +! + .global __ashlsi3 + .align 2 +__ashlsi3: + mov #31,r0 + and r0,r5 + mova __ashlsi3_table,r0 + mov.b @(r0,r5),r5 +#ifdef __sh1__ + add r5,r0 + jmp @r0 +#else + braf r5 +#endif + mov r4,r0 + + .align 2 +__ashlsi3_table: + .byte __ashlsi3_0-__ashlsi3_table + .byte __ashlsi3_1-__ashlsi3_table + .byte __ashlsi3_2-__ashlsi3_table + .byte __ashlsi3_3-__ashlsi3_table + .byte __ashlsi3_4-__ashlsi3_table + .byte __ashlsi3_5-__ashlsi3_table + .byte __ashlsi3_6-__ashlsi3_table + .byte __ashlsi3_7-__ashlsi3_table + .byte __ashlsi3_8-__ashlsi3_table + .byte __ashlsi3_9-__ashlsi3_table + .byte __ashlsi3_10-__ashlsi3_table + .byte __ashlsi3_11-__ashlsi3_table + .byte __ashlsi3_12-__ashlsi3_table + .byte __ashlsi3_13-__ashlsi3_table + .byte __ashlsi3_14-__ashlsi3_table + .byte __ashlsi3_15-__ashlsi3_table + .byte __ashlsi3_16-__ashlsi3_table + .byte __ashlsi3_17-__ashlsi3_table + .byte __ashlsi3_18-__ashlsi3_table + .byte __ashlsi3_19-__ashlsi3_table + .byte __ashlsi3_20-__ashlsi3_table + .byte __ashlsi3_21-__ashlsi3_table + .byte __ashlsi3_22-__ashlsi3_table + .byte __ashlsi3_23-__ashlsi3_table + .byte __ashlsi3_24-__ashlsi3_table + .byte __ashlsi3_25-__ashlsi3_table + .byte __ashlsi3_26-__ashlsi3_table + .byte __ashlsi3_27-__ashlsi3_table + .byte __ashlsi3_28-__ashlsi3_table + .byte __ashlsi3_29-__ashlsi3_table + .byte __ashlsi3_30-__ashlsi3_table + .byte __ashlsi3_31-__ashlsi3_table + +__ashlsi3_6: + shll2 r0 +__ashlsi3_4: + shll2 r0 +__ashlsi3_2: + rts + shll2 r0 + +__ashlsi3_7: + shll2 r0 +__ashlsi3_5: + shll2 r0 +__ashlsi3_3: + shll2 r0 +__ashlsi3_1: + rts + shll r0 + +__ashlsi3_14: + shll2 r0 +__ashlsi3_12: + shll2 r0 +__ashlsi3_10: + shll2 r0 +__ashlsi3_8: + rts + shll8 r0 + +__ashlsi3_15: + shll2 r0 +__ashlsi3_13: + shll2 r0 +__ashlsi3_11: + shll2 r0 +__ashlsi3_9: + shll8 r0 + rts + shll r0 + +__ashlsi3_22: + shll2 r0 +__ashlsi3_20: + shll2 r0 +__ashlsi3_18: + shll2 r0 +__ashlsi3_16: + rts + shll16 r0 + +__ashlsi3_23: + shll2 r0 +__ashlsi3_21: + shll2 r0 +__ashlsi3_19: + shll2 r0 +__ashlsi3_17: + shll16 r0 + rts + shll r0 + +__ashlsi3_30: + shll2 r0 +__ashlsi3_28: + shll2 r0 +__ashlsi3_26: + shll2 r0 +__ashlsi3_24: + shll16 r0 + rts + shll8 r0 + +__ashlsi3_31: + shll2 r0 +__ashlsi3_29: + shll2 r0 +__ashlsi3_27: + shll2 r0 +__ashlsi3_25: + shll16 r0 + shll8 r0 + rts + shll r0 + +__ashlsi3_0: + rts + nop diff --git a/arch/sh/lib/ashiftrt.S b/arch/sh/lib/ashiftrt.S new file mode 100644 index 0000000..45ce865 --- /dev/null +++ b/arch/sh/lib/ashiftrt.S @@ -0,0 +1,149 @@ +/* Copyright (C) 1994, 1995, 1997, 1998, 1999, 2000, 2001, 2002, 2003, + 2004, 2005, 2006 + Free Software Foundation, Inc. + +This file is free software; you can redistribute it and/or modify it +under the terms of the GNU General Public License as published by the +Free Software Foundation; either version 2, or (at your option) any +later version. + +In addition to the permissions in the GNU General Public License, the +Free Software Foundation gives you unlimited permission to link the +compiled version of this file into combinations with other programs, +and to distribute those combinations without any restriction coming +from the use of this file. (The General Public License restrictions +do apply in other respects; for example, they cover modification of +the file, and distribution when not linked into a combine +executable.) + +This file is distributed in the hope that it will be useful, but +WITHOUT ANY WARRANTY; without even the implied warranty of +MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU +General Public License for more details. + +You should have received a copy of the GNU General Public License +along with this program; see the file COPYING. If not, write to +the Free Software Foundation, 51 Franklin Street, Fifth Floor, +Boston, MA 02110-1301, USA. */ + +!! libgcc routines for the Renesas / SuperH SH CPUs. +!! Contributed by Steve Chamberlain. +!! sac@cygnus.com + +!! ashiftrt_r4_x, ___ashrsi3, ___ashlsi3, ___lshrsi3 routines +!! recoded in assembly by Toshiyasu Morita +!! tm@netcom.com + +/* SH2 optimizations for ___ashrsi3, ___ashlsi3, ___lshrsi3 and + ELF local label prefixes by J"orn Rennecke + amylaar@cygnus.com */ + + .global __ashiftrt_r4_0 + .global __ashiftrt_r4_1 + .global __ashiftrt_r4_2 + .global __ashiftrt_r4_3 + .global __ashiftrt_r4_4 + .global __ashiftrt_r4_5 + .global __ashiftrt_r4_6 + .global __ashiftrt_r4_7 + .global __ashiftrt_r4_8 + .global __ashiftrt_r4_9 + .global __ashiftrt_r4_10 + .global __ashiftrt_r4_11 + .global __ashiftrt_r4_12 + .global __ashiftrt_r4_13 + .global __ashiftrt_r4_14 + .global __ashiftrt_r4_15 + .global __ashiftrt_r4_16 + .global __ashiftrt_r4_17 + .global __ashiftrt_r4_18 + .global __ashiftrt_r4_19 + .global __ashiftrt_r4_20 + .global __ashiftrt_r4_21 + .global __ashiftrt_r4_22 + .global __ashiftrt_r4_23 + .global __ashiftrt_r4_24 + .global __ashiftrt_r4_25 + .global __ashiftrt_r4_26 + .global __ashiftrt_r4_27 + .global __ashiftrt_r4_28 + .global __ashiftrt_r4_29 + .global __ashiftrt_r4_30 + .global __ashiftrt_r4_31 + .global __ashiftrt_r4_32 + + .align 1 +__ashiftrt_r4_32: +__ashiftrt_r4_31: + rotcl r4 + rts + subc r4,r4 +__ashiftrt_r4_30: + shar r4 +__ashiftrt_r4_29: + shar r4 +__ashiftrt_r4_28: + shar r4 +__ashiftrt_r4_27: + shar r4 +__ashiftrt_r4_26: + shar r4 +__ashiftrt_r4_25: + shar r4 +__ashiftrt_r4_24: + shlr16 r4 + shlr8 r4 + rts + exts.b r4,r4 +__ashiftrt_r4_23: + shar r4 +__ashiftrt_r4_22: + shar r4 +__ashiftrt_r4_21: + shar r4 +__ashiftrt_r4_20: + shar r4 +__ashiftrt_r4_19: + shar r4 +__ashiftrt_r4_18: + shar r4 +__ashiftrt_r4_17: + shar r4 +__ashiftrt_r4_16: + shlr16 r4 + rts + exts.w r4,r4 +__ashiftrt_r4_15: + shar r4 +__ashiftrt_r4_14: + shar r4 +__ashiftrt_r4_13: + shar r4 +__ashiftrt_r4_12: + shar r4 +__ashiftrt_r4_11: + shar r4 +__ashiftrt_r4_10: + shar r4 +__ashiftrt_r4_9: + shar r4 +__ashiftrt_r4_8: + shar r4 +__ashiftrt_r4_7: + shar r4 +__ashiftrt_r4_6: + shar r4 +__ashiftrt_r4_5: + shar r4 +__ashiftrt_r4_4: + shar r4 +__ashiftrt_r4_3: + shar r4 +__ashiftrt_r4_2: + shar r4 +__ashiftrt_r4_1: + rts + shar r4 +__ashiftrt_r4_0: + rts + nop diff --git a/arch/sh/lib/ashldi3.c b/arch/sh/lib/ashldi3.c new file mode 100644 index 0000000..9b50d86 --- /dev/null +++ b/arch/sh/lib/ashldi3.c @@ -0,0 +1,25 @@ +#include "libgcc.h" + +long long __ashldi3(long long u, word_type b) +{ + DWunion uu, w; + word_type bm; + + if (b == 0) + return u; + + uu.ll = u; + bm = 32 - b; + + if (bm <= 0) { + w.s.low = 0; + w.s.high = (unsigned int) uu.s.low << -bm; + } else { + const unsigned int carries = (unsigned int) uu.s.low >> bm; + + w.s.low = (unsigned int) uu.s.low << b; + w.s.high = ((unsigned int) uu.s.high << b) | carries; + } + + return w.ll; +} diff --git a/arch/sh/lib/libgcc.h b/arch/sh/lib/libgcc.h new file mode 100644 index 0000000..05909d5 --- /dev/null +++ b/arch/sh/lib/libgcc.h @@ -0,0 +1,25 @@ +#ifndef __ASM_LIBGCC_H +#define __ASM_LIBGCC_H + +#include <asm/byteorder.h> + +typedef int word_type __attribute__ ((mode (__word__))); + +#ifdef __BIG_ENDIAN +struct DWstruct { + int high, low; +}; +#elif defined(__LITTLE_ENDIAN) +struct DWstruct { + int low, high; +}; +#else +#error I feel sick. +#endif + +typedef union { + struct DWstruct s; + long long ll; +} DWunion; + +#endif /* __ASM_LIBGCC_H */ diff --git a/arch/sh/lib/lshiftrt.S b/arch/sh/lib/lshiftrt.S new file mode 100644 index 0000000..e6fc1cf --- /dev/null +++ b/arch/sh/lib/lshiftrt.S @@ -0,0 +1,192 @@ +/* Copyright (C) 1994, 1995, 1997, 1998, 1999, 2000, 2001, 2002, 2003, + 2004, 2005, 2006 + Free Software Foundation, Inc. + +This file is free software; you can redistribute it and/or modify it +under the terms of the GNU General Public License as published by the +Free Software Foundation; either version 2, or (at your option) any +later version. + +In addition to the permissions in the GNU General Public License, the +Free Software Foundation gives you unlimited permission to link the +compiled version of this file into combinations with other programs, +and to distribute those combinations without any restriction coming +from the use of this file. (The General Public License restrictions +do apply in other respects; for example, they cover modification of +the file, and distribution when not linked into a combine +executable.) + +This file is distributed in the hope that it will be useful, but +WITHOUT ANY WARRANTY; without even the implied warranty of +MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU +General Public License for more details. + +You should have received a copy of the GNU General Public License +along with this program; see the file COPYING. If not, write to +the Free Software Foundation, 51 Franklin Street, Fifth Floor, +Boston, MA 02110-1301, USA. */ + +!! libgcc routines for the Renesas / SuperH SH CPUs. +!! Contributed by Steve Chamberlain. +!! sac@cygnus.com + +!! ashiftrt_r4_x, ___ashrsi3, ___ashlsi3, ___lshrsi3 routines +!! recoded in assembly by Toshiyasu Morita +!! tm@netcom.com + +/* SH2 optimizations for ___ashrsi3, ___ashlsi3, ___lshrsi3 and + ELF local label prefixes by J"orn Rennecke + amylaar@cygnus.com */ + +! +! __lshrsi3) +! +! Entry: +! +! r4: Value to shift +! r5: Shifts +! +! Exit: +! +! r0: Result +! +! Destroys: +! +! (none) +! + .global __lshrsi3 + .align 2 +__lshrsi3: + mov #31,r0 + and r0,r5 + mova __lshrsi3_table,r0 + mov.b @(r0,r5),r5 +#ifdef __sh1__ + add r5,r0 + jmp @r0 +#else + braf r5 +#endif + mov r4,r0 + + .align 2 +__lshrsi3_table: + .byte __lshrsi3_0-__lshrsi3_table + .byte __lshrsi3_1-__lshrsi3_table + .byte __lshrsi3_2-__lshrsi3_table + .byte __lshrsi3_3-__lshrsi3_table + .byte __lshrsi3_4-__lshrsi3_table + .byte __lshrsi3_5-__lshrsi3_table + .byte __lshrsi3_6-__lshrsi3_table + .byte __lshrsi3_7-__lshrsi3_table + .byte __lshrsi3_8-__lshrsi3_table + .byte __lshrsi3_9-__lshrsi3_table + .byte __lshrsi3_10-__lshrsi3_table + .byte __lshrsi3_11-__lshrsi3_table + .byte __lshrsi3_12-__lshrsi3_table + .byte __lshrsi3_13-__lshrsi3_table + .byte __lshrsi3_14-__lshrsi3_table + .byte __lshrsi3_15-__lshrsi3_table + .byte __lshrsi3_16-__lshrsi3_table + .byte __lshrsi3_17-__lshrsi3_table + .byte __lshrsi3_18-__lshrsi3_table + .byte __lshrsi3_19-__lshrsi3_table + .byte __lshrsi3_20-__lshrsi3_table + .byte __lshrsi3_21-__lshrsi3_table + .byte __lshrsi3_22-__lshrsi3_table + .byte __lshrsi3_23-__lshrsi3_table + .byte __lshrsi3_24-__lshrsi3_table + .byte __lshrsi3_25-__lshrsi3_table + .byte __lshrsi3_26-__lshrsi3_table + .byte __lshrsi3_27-__lshrsi3_table + .byte __lshrsi3_28-__lshrsi3_table + .byte __lshrsi3_29-__lshrsi3_table + .byte __lshrsi3_30-__lshrsi3_table + .byte __lshrsi3_31-__lshrsi3_table + +__lshrsi3_6: + shlr2 r0 +__lshrsi3_4: + shlr2 r0 +__lshrsi3_2: + rts + shlr2 r0 + +__lshrsi3_7: + shlr2 r0 +__lshrsi3_5: + shlr2 r0 +__lshrsi3_3: + shlr2 r0 +__lshrsi3_1: + rts + shlr r0 + +__lshrsi3_14: + shlr2 r0 +__lshrsi3_12: + shlr2 r0 +__lshrsi3_10: + shlr2 r0 +__lshrsi3_8: + rts + shlr8 r0 + +__lshrsi3_15: + shlr2 r0 +__lshrsi3_13: + shlr2 r0 +__lshrsi3_11: + shlr2 r0 +__lshrsi3_9: + shlr8 r0 + rts + shlr r0 + +__lshrsi3_22: + shlr2 r0 +__lshrsi3_20: + shlr2 r0 +__lshrsi3_18: + shlr2 r0 +__lshrsi3_16: + rts + shlr16 r0 + +__lshrsi3_23: + shlr2 r0 +__lshrsi3_21: + shlr2 r0 +__lshrsi3_19: + shlr2 r0 +__lshrsi3_17: + shlr16 r0 + rts + shlr r0 + +__lshrsi3_30: + shlr2 r0 +__lshrsi3_28: + shlr2 r0 +__lshrsi3_26: + shlr2 r0 +__lshrsi3_24: + shlr16 r0 + rts + shlr8 r0 + +__lshrsi3_31: + shlr2 r0 +__lshrsi3_29: + shlr2 r0 +__lshrsi3_27: + shlr2 r0 +__lshrsi3_25: + shlr16 r0 + shlr8 r0 + rts + shlr r0 + +__lshrsi3_0: + rts + nop diff --git a/arch/sh/lib/lshrdi3.c b/arch/sh/lib/lshrdi3.c new file mode 100644 index 0000000..bb340ac --- /dev/null +++ b/arch/sh/lib/lshrdi3.c @@ -0,0 +1,25 @@ +#include "libgcc.h" + +long long __lshrdi3(long long u, word_type b) +{ + DWunion uu, w; + word_type bm; + + if (b == 0) + return u; + + uu.ll = u; + bm = 32 - b; + + if (bm <= 0) { + w.s.high = 0; + w.s.low = (unsigned int) uu.s.high >> -bm; + } else { + const unsigned int carries = (unsigned int) uu.s.high << bm; + + w.s.high = (unsigned int) uu.s.high >> b; + w.s.low = ((unsigned int) uu.s.low >> b) | carries; + } + + return w.ll; +} diff --git a/arch/sh/lib/movmem.S b/arch/sh/lib/movmem.S new file mode 100644 index 0000000..c7efd40 --- /dev/null +++ b/arch/sh/lib/movmem.S @@ -0,0 +1,238 @@ +/* Copyright (C) 1994, 1995, 1997, 1998, 1999, 2000, 2001, 2002, 2003, + 2004, 2005, 2006 + Free Software Foundation, Inc. + +This file is free software; you can redistribute it and/or modify it +under the terms of the GNU General Public License as published by the +Free Software Foundation; either version 2, or (at your option) any +later version. + +In addition to the permissions in the GNU General Public License, the +Free Software Foundation gives you unlimited permission to link the +compiled version of this file into combinations with other programs, +and to distribute those combinations without any restriction coming +from the use of this file. (The General Public License restrictions +do apply in other respects; for example, they cover modification of +the file, and distribution when not linked into a combine +executable.) + +This file is distributed in the hope that it will be useful, but +WITHOUT ANY WARRANTY; without even the implied warranty of +MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU +General Public License for more details. + +You should have received a copy of the GNU General Public License +along with this program; see the file COPYING. If not, write to +the Free Software Foundation, 51 Franklin Street, Fifth Floor, +Boston, MA 02110-1301, USA. */ + +!! libgcc routines for the Renesas / SuperH SH CPUs. +!! Contributed by Steve Chamberlain. +!! sac@cygnus.com + +!! ashiftrt_r4_x, ___ashrsi3, ___ashlsi3, ___lshrsi3 routines +!! recoded in assembly by Toshiyasu Morita +!! tm@netcom.com + +/* SH2 optimizations for ___ashrsi3, ___ashlsi3, ___lshrsi3 and + ELF local label prefixes by J"orn Rennecke + amylaar@cygnus.com */ + + .text + .balign 4 + .global __movmem + .global __movstr + .set __movstr, __movmem + /* This would be a lot simpler if r6 contained the byte count + minus 64, and we wouldn't be called here for a byte count of 64. */ +__movmem: + sts.l pr,@-r15 + shll2 r6 + bsr __movmemSI52+2 + mov.l @(48,r5),r0 + .balign 4 +movmem_loop: /* Reached with rts */ + mov.l @(60,r5),r0 + add #-64,r6 + mov.l r0,@(60,r4) + tst r6,r6 + mov.l @(56,r5),r0 + bt movmem_done + mov.l r0,@(56,r4) + cmp/pl r6 + mov.l @(52,r5),r0 + add #64,r5 + mov.l r0,@(52,r4) + add #64,r4 + bt __movmemSI52 +! done all the large groups, do the remainder +! jump to movmem+ + mova __movmemSI4+4,r0 + add r6,r0 + jmp @r0 +movmem_done: ! share slot insn, works out aligned. + lds.l @r15+,pr + mov.l r0,@(56,r4) + mov.l @(52,r5),r0 + rts + mov.l r0,@(52,r4) + .balign 4 + + .global __movmemSI64 + .global __movstrSI64 + .set __movstrSI64, __movmemSI64 +__movmemSI64: + mov.l @(60,r5),r0 + mov.l r0,@(60,r4) + .global __movmemSI60 + .global __movstrSI60 + .set __movstrSI60, __movmemSI60 +__movmemSI60: + mov.l @(56,r5),r0 + mov.l r0,@(56,r4) + .global __movmemSI56 + .global __movstrSI56 + .set __movstrSI56, __movmemSI56 +__movmemSI56: + mov.l @(52,r5),r0 + mov.l r0,@(52,r4) + .global __movmemSI52 + .global __movstrSI52 + .set __movstrSI52, __movmemSI52 +__movmemSI52: + mov.l @(48,r5),r0 + mov.l r0,@(48,r4) + .global __movmemSI48 + .global __movstrSI48 + .set __movstrSI48, __movmemSI48 +__movmemSI48: + mov.l @(44,r5),r0 + mov.l r0,@(44,r4) + .global __movmemSI44 + .global __movstrSI44 + .set __movstrSI44, __movmemSI44 +__movmemSI44: + mov.l @(40,r5),r0 + mov.l r0,@(40,r4) + .global __movmemSI40 + .global __movstrSI40 + .set __movstrSI40, __movmemSI40 +__movmemSI40: + mov.l @(36,r5),r0 + mov.l r0,@(36,r4) + .global __movmemSI36 + .global __movstrSI36 + .set __movstrSI36, __movmemSI36 +__movmemSI36: + mov.l @(32,r5),r0 + mov.l r0,@(32,r4) + .global __movmemSI32 + .global __movstrSI32 + .set __movstrSI32, __movmemSI32 +__movmemSI32: + mov.l @(28,r5),r0 + mov.l r0,@(28,r4) + .global __movmemSI28 + .global __movstrSI28 + .set __movstrSI28, __movmemSI28 +__movmemSI28: + mov.l @(24,r5),r0 + mov.l r0,@(24,r4) + .global __movmemSI24 + .global __movstrSI24 + .set __movstrSI24, __movmemSI24 +__movmemSI24: + mov.l @(20,r5),r0 + mov.l r0,@(20,r4) + .global __movmemSI20 + .global __movstrSI20 + .set __movstrSI20, __movmemSI20 +__movmemSI20: + mov.l @(16,r5),r0 + mov.l r0,@(16,r4) + .global __movmemSI16 + .global __movstrSI16 + .set __movstrSI16, __movmemSI16 +__movmemSI16: + mov.l @(12,r5),r0 + mov.l r0,@(12,r4) + .global __movmemSI12 + .global __movstrSI12 + .set __movstrSI12, __movmemSI12 +__movmemSI12: + mov.l @(8,r5),r0 + mov.l r0,@(8,r4) + .global __movmemSI8 + .global __movstrSI8 + .set __movstrSI8, __movmemSI8 +__movmemSI8: + mov.l @(4,r5),r0 + mov.l r0,@(4,r4) + .global __movmemSI4 + .global __movstrSI4 + .set __movstrSI4, __movmemSI4 +__movmemSI4: + mov.l @(0,r5),r0 + rts + mov.l r0,@(0,r4) + + .global __movmem_i4_even + .global __movstr_i4_even + .set __movstr_i4_even, __movmem_i4_even + + .global __movmem_i4_odd + .global __movstr_i4_odd + .set __movstr_i4_odd, __movmem_i4_odd + + .global __movmemSI12_i4 + .global __movstrSI12_i4 + .set __movstrSI12_i4, __movmemSI12_i4 + + .p2align 5 +L_movmem_2mod4_end: + mov.l r0,@(16,r4) + rts + mov.l r1,@(20,r4) + + .p2align 2 + +__movmem_i4_even: + mov.l @r5+,r0 + bra L_movmem_start_even + mov.l @r5+,r1 + +__movmem_i4_odd: + mov.l @r5+,r1 + add #-4,r4 + mov.l @r5+,r2 + mov.l @r5+,r3 + mov.l r1,@(4,r4) + mov.l r2,@(8,r4) + +L_movmem_loop: + mov.l r3,@(12,r4) + dt r6 + mov.l @r5+,r0 + bt/s L_movmem_2mod4_end + mov.l @r5+,r1 + add #16,r4 +L_movmem_start_even: + mov.l @r5+,r2 + mov.l @r5+,r3 + mov.l r0,@r4 + dt r6 + mov.l r1,@(4,r4) + bf/s L_movmem_loop + mov.l r2,@(8,r4) + rts + mov.l r3,@(12,r4) + + .p2align 4 +__movmemSI12_i4: + mov.l @r5,r0 + mov.l @(4,r5),r1 + mov.l @(8,r5),r2 + mov.l r0,@r4 + mov.l r1,@(4,r4) + rts + mov.l r2,@(8,r4) -- 1.7.0.4
Hi, Phil.
Applied to next branch.
Thanks!
Nobuhiro
2011/6/3 Phil Edworthy PHIL.EDWORTHY@renesas.com:
- $(addprefix $(obj),$(GLCOBJS))
+all: $(TARGETS)
- $(call cmd_link_o_target, $(LGOBJS))
- 2004, 2005, 2006
- Free Software Foundation, Inc.
- ELF local label prefixes by J"orn Rennecke
- amylaar@cygnus.com */
- .global __ashlsi3
- .align 2
+__ashlsi3:
- mov #31,r0
- and r0,r5
- mova __ashlsi3_table,r0
- mov.b @(r0,r5),r5
+#ifdef __sh1__
- add r5,r0
- jmp @r0
+#else
- braf r5
- mov r4,r0
- .align 2
+__ashlsi3_table:
- .byte __ashlsi3_0-__ashlsi3_table
- .byte __ashlsi3_1-__ashlsi3_table
- .byte __ashlsi3_2-__ashlsi3_table
- .byte __ashlsi3_3-__ashlsi3_table
- .byte __ashlsi3_4-__ashlsi3_table
- .byte __ashlsi3_5-__ashlsi3_table
- .byte __ashlsi3_6-__ashlsi3_table
- .byte __ashlsi3_7-__ashlsi3_table
- .byte __ashlsi3_8-__ashlsi3_table
- .byte __ashlsi3_9-__ashlsi3_table
- .byte __ashlsi3_10-__ashlsi3_table
- .byte __ashlsi3_11-__ashlsi3_table
- .byte __ashlsi3_12-__ashlsi3_table
- .byte __ashlsi3_13-__ashlsi3_table
- .byte __ashlsi3_14-__ashlsi3_table
- .byte __ashlsi3_15-__ashlsi3_table
- .byte __ashlsi3_16-__ashlsi3_table
- .byte __ashlsi3_17-__ashlsi3_table
- .byte __ashlsi3_18-__ashlsi3_table
- .byte __ashlsi3_19-__ashlsi3_table
- .byte __ashlsi3_20-__ashlsi3_table
- .byte __ashlsi3_21-__ashlsi3_table
- .byte __ashlsi3_22-__ashlsi3_table
- .byte __ashlsi3_23-__ashlsi3_table
- .byte __ashlsi3_24-__ashlsi3_table
- .byte __ashlsi3_25-__ashlsi3_table
- .byte __ashlsi3_26-__ashlsi3_table
- .byte __ashlsi3_27-__ashlsi3_table
- .byte __ashlsi3_28-__ashlsi3_table
- .byte __ashlsi3_29-__ashlsi3_table
- .byte __ashlsi3_30-__ashlsi3_table
- .byte __ashlsi3_31-__ashlsi3_table
+__ashlsi3_6:
- shll2 r0
+__ashlsi3_4:
- shll2 r0
+__ashlsi3_2:
- rts
- shll2 r0
+__ashlsi3_7:
- shll2 r0
+__ashlsi3_5:
- shll2 r0
+__ashlsi3_3:
- shll2 r0
+__ashlsi3_1:
- rts
- shll r0
+__ashlsi3_14:
- shll2 r0
+__ashlsi3_12:
- shll2 r0
+__ashlsi3_10:
- shll2 r0
+__ashlsi3_8:
- rts
- shll8 r0
+__ashlsi3_15:
- shll2 r0
+__ashlsi3_13:
- shll2 r0
+__ashlsi3_11:
- shll2 r0
+__ashlsi3_9:
- shll8 r0
- rts
- shll r0
+__ashlsi3_22:
- shll2 r0
+__ashlsi3_20:
- shll2 r0
+__ashlsi3_18:
- shll2 r0
+__ashlsi3_16:
- rts
- shll16 r0
+__ashlsi3_23:
- shll2 r0
+__ashlsi3_21:
- shll2 r0
+__ashlsi3_19:
- shll2 r0
+__ashlsi3_17:
- shll16 r0
- rts
- shll r0
+__ashlsi3_30:
- shll2 r0
+__ashlsi3_28:
- shll2 r0
+__ashlsi3_26:
- shll2 r0
+__ashlsi3_24:
- shll16 r0
- rts
- shll8 r0
+__ashlsi3_31:
- shll2 r0
+__ashlsi3_29:
- shll2 r0
+__ashlsi3_27:
- shll2 r0
+__ashlsi3_25:
- shll16 r0
- shll8 r0
- rts
- shll r0
+__ashlsi3_0:
- rts
- nop
- 2004, 2005, 2006
- .global __ashiftrt_r4_0
- .global __ashiftrt_r4_1
- .global __ashiftrt_r4_2
- .global __ashiftrt_r4_3
- .global __ashiftrt_r4_4
- .global __ashiftrt_r4_5
- .global __ashiftrt_r4_6
- .global __ashiftrt_r4_7
- .global __ashiftrt_r4_8
- .global __ashiftrt_r4_9
- .global __ashiftrt_r4_10
- .global __ashiftrt_r4_11
- .global __ashiftrt_r4_12
- .global __ashiftrt_r4_13
- .global __ashiftrt_r4_14
- .global __ashiftrt_r4_15
- .global __ashiftrt_r4_16
- .global __ashiftrt_r4_17
- .global __ashiftrt_r4_18
- .global __ashiftrt_r4_19
- .global __ashiftrt_r4_20
- .global __ashiftrt_r4_21
- .global __ashiftrt_r4_22
- .global __ashiftrt_r4_23
- .global __ashiftrt_r4_24
- .global __ashiftrt_r4_25
- .global __ashiftrt_r4_26
- .global __ashiftrt_r4_27
- .global __ashiftrt_r4_28
- .global __ashiftrt_r4_29
- .global __ashiftrt_r4_30
- .global __ashiftrt_r4_31
- .global __ashiftrt_r4_32
- .align 1
- rotcl r4
- rts
- subc r4,r4
+__ashiftrt_r4_30:
- shar r4
+__ashiftrt_r4_29:
- shar r4
+__ashiftrt_r4_28:
- shar r4
+__ashiftrt_r4_27:
- shar r4
+__ashiftrt_r4_26:
- shar r4
+__ashiftrt_r4_25:
- shar r4
+__ashiftrt_r4_24:
- shlr16 r4
- shlr8 r4
- rts
- exts.b r4,r4
+__ashiftrt_r4_23:
- shar r4
+__ashiftrt_r4_22:
- shar r4
+__ashiftrt_r4_21:
- shar r4
+__ashiftrt_r4_20:
- shar r4
+__ashiftrt_r4_19:
- shar r4
+__ashiftrt_r4_18:
- shar r4
+__ashiftrt_r4_17:
- shar r4
+__ashiftrt_r4_16:
- shlr16 r4
- rts
- exts.w r4,r4
+__ashiftrt_r4_15:
- shar r4
+__ashiftrt_r4_14:
- shar r4
+__ashiftrt_r4_13:
- shar r4
+__ashiftrt_r4_12:
- shar r4
+__ashiftrt_r4_11:
- shar r4
+__ashiftrt_r4_10:
- shar r4
+__ashiftrt_r4_9:
- shar r4
+__ashiftrt_r4_8:
- shar r4
+__ashiftrt_r4_7:
- shar r4
+__ashiftrt_r4_6:
- shar r4
+__ashiftrt_r4_5:
- shar r4
+__ashiftrt_r4_4:
- shar r4
+__ashiftrt_r4_3:
- shar r4
+__ashiftrt_r4_2:
- shar r4
+__ashiftrt_r4_1:
- rts
- shar r4
+__ashiftrt_r4_0:
- rts
- nop
- DWunion uu, w;
- word_type bm;
- if (b == 0)
- return u;
- uu.ll = u;
- bm = 32 - b;
- if (bm <= 0) {
- w.s.low = 0;
- w.s.high = (unsigned int) uu.s.low << -bm;
- } else {
- const unsigned int carries = (unsigned int) uu.s.low >> bm;
- w.s.low = (unsigned int) uu.s.low << b;
- w.s.high = ((unsigned int) uu.s.high << b) | carries;
- return w.ll;
- int high, low;
- int low, high;
+typedef union {
- struct DWstruct s;
- long long ll;
+} DWunion;
- 2004, 2005, 2006
- .global __lshrsi3
- .align 2
+__lshrsi3:
- mov #31,r0
- and r0,r5
- mova __lshrsi3_table,r0
- mov.b @(r0,r5),r5
+#ifdef __sh1__
- add r5,r0
- jmp @r0
+#else
- braf r5
- mov r4,r0
- .align 2
+__lshrsi3_table:
- .byte __lshrsi3_0-__lshrsi3_table
- .byte __lshrsi3_1-__lshrsi3_table
- .byte __lshrsi3_2-__lshrsi3_table
- .byte __lshrsi3_3-__lshrsi3_table
- .byte __lshrsi3_4-__lshrsi3_table
- .byte __lshrsi3_5-__lshrsi3_table
- .byte __lshrsi3_6-__lshrsi3_table
- .byte __lshrsi3_7-__lshrsi3_table
- .byte __lshrsi3_8-__lshrsi3_table
- .byte __lshrsi3_9-__lshrsi3_table
- .byte __lshrsi3_10-__lshrsi3_table
- .byte __lshrsi3_11-__lshrsi3_table
- .byte __lshrsi3_12-__lshrsi3_table
- .byte __lshrsi3_13-__lshrsi3_table
- .byte __lshrsi3_14-__lshrsi3_table
- .byte __lshrsi3_15-__lshrsi3_table
- .byte __lshrsi3_16-__lshrsi3_table
- .byte __lshrsi3_17-__lshrsi3_table
- .byte __lshrsi3_18-__lshrsi3_table
- .byte __lshrsi3_19-__lshrsi3_table
- .byte __lshrsi3_20-__lshrsi3_table
- .byte __lshrsi3_21-__lshrsi3_table
- .byte __lshrsi3_22-__lshrsi3_table
- .byte __lshrsi3_23-__lshrsi3_table
- .byte __lshrsi3_24-__lshrsi3_table
- .byte __lshrsi3_25-__lshrsi3_table
- .byte __lshrsi3_26-__lshrsi3_table
- .byte __lshrsi3_27-__lshrsi3_table
- .byte __lshrsi3_28-__lshrsi3_table
- .byte __lshrsi3_29-__lshrsi3_table
- .byte __lshrsi3_30-__lshrsi3_table
- .byte __lshrsi3_31-__lshrsi3_table
+__lshrsi3_6:
- shlr2 r0
+__lshrsi3_4:
- shlr2 r0
+__lshrsi3_2:
- rts
- shlr2 r0
+__lshrsi3_7:
- shlr2 r0
+__lshrsi3_5:
- shlr2 r0
+__lshrsi3_3:
- shlr2 r0
+__lshrsi3_1:
- rts
- shlr r0
+__lshrsi3_14:
- shlr2 r0
+__lshrsi3_12:
- shlr2 r0
+__lshrsi3_10:
- shlr2 r0
+__lshrsi3_8:
- rts
- shlr8 r0
+__lshrsi3_15:
- shlr2 r0
+__lshrsi3_13:
- shlr2 r0
+__lshrsi3_11:
- shlr2 r0
+__lshrsi3_9:
- shlr8 r0
- rts
- shlr r0
+__lshrsi3_22:
- shlr2 r0
+__lshrsi3_20:
- shlr2 r0
+__lshrsi3_18:
- shlr2 r0
+__lshrsi3_16:
- rts
- shlr16 r0
+__lshrsi3_23:
- shlr2 r0
+__lshrsi3_21:
- shlr2 r0
+__lshrsi3_19:
- shlr2 r0
+__lshrsi3_17:
- shlr16 r0
- rts
- shlr r0
+__lshrsi3_30:
- shlr2 r0
+__lshrsi3_28:
- shlr2 r0
+__lshrsi3_26:
- shlr2 r0
+__lshrsi3_24:
- shlr16 r0
- rts
- shlr8 r0
+__lshrsi3_31:
- shlr2 r0
+__lshrsi3_29:
- shlr2 r0
+__lshrsi3_27:
- shlr2 r0
+__lshrsi3_25:
- shlr16 r0
- shlr8 r0
- rts
- shlr r0
+__lshrsi3_0:
- rts
- nop
- DWunion uu, w;
- word_type bm;
- if (b == 0)
- return u;
- uu.ll = u;
- bm = 32 - b;
- if (bm <= 0) {
- w.s.high = 0;
- w.s.low = (unsigned int) uu.s.high >> -bm;
- } else {
- const unsigned int carries = (unsigned int) uu.s.high << bm;
- w.s.high = (unsigned int) uu.s.high >> b;
- w.s.low = ((unsigned int) uu.s.low >> b) | carries;
- return w.ll;
- 2004, 2005, 2006
- .text
- .balign 4
- .global __movmem
- .global __movstr
- .set __movstr, __movmem
- /* This would be a lot simpler if r6 contained the byte count
- minus 64, and we wouldn't be called here for a byte count of 64. */
+__movmem:
- sts.l pr,@-r15
- shll2 r6
- bsr __movmemSI52+2
- mov.l @(48,r5),r0
- .balign 4
- mov.l @(60,r5),r0
- add #-64,r6
- mov.l r0,@(60,r4)
- tst r6,r6
- mov.l @(56,r5),r0
- bt movmem_done
- mov.l r0,@(56,r4)
- cmp/pl r6
- mov.l @(52,r5),r0
- add #64,r5
- mov.l r0,@(52,r4)
- add #64,r4
- bt __movmemSI52
- mova __movmemSI4+4,r0
- add r6,r0
- jmp @r0
- lds.l @r15+,pr
- mov.l r0,@(56,r4)
- mov.l @(52,r5),r0
- rts
- mov.l r0,@(52,r4)
- .balign 4
- .global __movmemSI64
- .global __movstrSI64
- .set __movstrSI64, __movmemSI64
+__movmemSI64:
- mov.l @(60,r5),r0
- mov.l r0,@(60,r4)
- .global __movmemSI60
- .global __movstrSI60
- .set __movstrSI60, __movmemSI60
+__movmemSI60:
- mov.l @(56,r5),r0
- mov.l r0,@(56,r4)
- .global __movmemSI56
- .global __movstrSI56
- .set __movstrSI56, __movmemSI56
+__movmemSI56:
- mov.l @(52,r5),r0
- mov.l r0,@(52,r4)
- .global __movmemSI52
- .global __movstrSI52
- .set __movstrSI52, __movmemSI52
+__movmemSI52:
- mov.l @(48,r5),r0
- mov.l r0,@(48,r4)
- .global __movmemSI48
- .global __movstrSI48
- .set __movstrSI48, __movmemSI48
+__movmemSI48:
- mov.l @(44,r5),r0
- mov.l r0,@(44,r4)
- .global __movmemSI44
- .global __movstrSI44
- .set __movstrSI44, __movmemSI44
+__movmemSI44:
- mov.l @(40,r5),r0
- mov.l r0,@(40,r4)
- .global __movmemSI40
- .global __movstrSI40
- .set __movstrSI40, __movmemSI40
+__movmemSI40:
- mov.l @(36,r5),r0
- mov.l r0,@(36,r4)
- .global __movmemSI36
- .global __movstrSI36
- .set __movstrSI36, __movmemSI36
+__movmemSI36:
- mov.l @(32,r5),r0
- mov.l r0,@(32,r4)
- .global __movmemSI32
- .global __movstrSI32
- .set __movstrSI32, __movmemSI32
+__movmemSI32:
- mov.l @(28,r5),r0
- mov.l r0,@(28,r4)
- .global __movmemSI28
- .global __movstrSI28
- .set __movstrSI28, __movmemSI28
+__movmemSI28:
- mov.l @(24,r5),r0
- mov.l r0,@(24,r4)
- .global __movmemSI24
- .global __movstrSI24
- .set __movstrSI24, __movmemSI24
+__movmemSI24:
- mov.l @(20,r5),r0
- mov.l r0,@(20,r4)
- .global __movmemSI20
- .global __movstrSI20
- .set __movstrSI20, __movmemSI20
+__movmemSI20:
- mov.l @(16,r5),r0
- mov.l r0,@(16,r4)
- .global __movmemSI16
- .global __movstrSI16
- .set __movstrSI16, __movmemSI16
+__movmemSI16:
- mov.l @(12,r5),r0
- mov.l r0,@(12,r4)
- .global __movmemSI12
- .global __movstrSI12
- .set __movstrSI12, __movmemSI12
+__movmemSI12:
- mov.l @(8,r5),r0
- mov.l r0,@(8,r4)
- .global __movmemSI8
- .global __movstrSI8
- .set __movstrSI8, __movmemSI8
+__movmemSI8:
- mov.l @(4,r5),r0
- mov.l r0,@(4,r4)
- .set __movstrSI4, __movmemSI4
+__movmemSI4:
- mov.l @(0,r5),r0
- rts
- mov.l r0,@(0,r4)
- .global __movmem_i4_even
- .global __movstr_i4_even
- .set __movstr_i4_even, __movmem_i4_even
- .global __movmem_i4_odd
- .global __movstr_i4_odd
- .set __movstr_i4_odd, __movmem_i4_odd
- .global __movmemSI12_i4
- .global __movstrSI12_i4
- .set __movstrSI12_i4, __movmemSI12_i4
- .p2align 5
- mov.l r0,@(16,r4)
- rts
- mov.l r1,@(20,r4)
- .p2align 2
+__movmem_i4_even:
- mov.l @r5+,r0
- bra L_movmem_start_even
- mov.l @r5+,r1
+__movmem_i4_odd:
- mov.l @r5+,r1
- add #-4,r4
- mov.l @r5+,r2
- mov.l @r5+,r3
- mov.l r1,@(4,r4)
- mov.l r2,@(8,r4)
+L_movmem_loop:
- mov.l r3,@(12,r4)
- dt r6
- mov.l @r5+,r0
- bt/s L_movmem_2mod4_end
- mov.l @r5+,r1
- add #16,r4
- mov.l @r5+,r2
- mov.l @r5+,r3
- mov.l r0,@r4
- dt r6
- mov.l r1,@(4,r4)
- bf/s L_movmem_loop
- mov.l r2,@(8,r4)
- rts
- mov.l r3,@(12,r4)
- .p2align 4
+__movmemSI12_i4:
- mov.l @r5,r0
- mov.l @(4,r5),r1
- mov.l @(8,r5),r2
- mov.l r0,@r4
- mov.l r1,@(4,r4)
- rts
- mov.l r2,@(8,r4)
-- 1.7.0.4
Nobuhiro Iwamatsu
Phil Edworthy
