[U-Boot] [PATCH] imx: imx7d: remove CamelCase from ENET_xMHz macros
Update these macros to use all upper-case to avoid checkpatch warnings:
ENET_25MHz, ENET_50MHz, ENET_125MHz,
Signed-off-by: Eric Nelson eric@nelint.com --- arch/arm/include/asm/arch-mx7/clock.h | 6 +++--- arch/arm/mach-imx/mx7/clock.c | 2 +- board/freescale/mx7dsabresd/mx7dsabresd.c | 2 +- board/technexion/pico-imx7d/pico-imx7d.c | 2 +- board/toradex/colibri_imx7/colibri_imx7.c | 2 +- 5 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx7/clock.h b/arch/arm/include/asm/arch-mx7/clock.h index 688d236..3b115ad 100644 --- a/arch/arm/include/asm/arch-mx7/clock.h +++ b/arch/arm/include/asm/arch-mx7/clock.h @@ -318,9 +318,9 @@ struct clk_root_map { };
enum enet_freq { - ENET_25MHz, - ENET_50MHz, - ENET_125MHz, + ENET_25MHZ, + ENET_50MHZ, + ENET_125MHZ, };
u32 get_root_clk(enum clk_root_index clock_id); diff --git a/arch/arm/mach-imx/mx7/clock.c b/arch/arm/mach-imx/mx7/clock.c index 2cfde46..423d697 100644 --- a/arch/arm/mach-imx/mx7/clock.c +++ b/arch/arm/mach-imx/mx7/clock.c @@ -970,7 +970,7 @@ int set_clk_enet(enum enet_freq type) enet1_ref = ENET1_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK; enet2_ref = ENET2_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK; break; - case ENET_50MHz: + case ENET_50MHZ: enet1_ref = ENET1_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_50M_CLK; enet2_ref = ENET2_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_50M_CLK; break; diff --git a/board/freescale/mx7dsabresd/mx7dsabresd.c b/board/freescale/mx7dsabresd/mx7dsabresd.c index a681ece..5819b18 100644 --- a/board/freescale/mx7dsabresd/mx7dsabresd.c +++ b/board/freescale/mx7dsabresd/mx7dsabresd.c @@ -260,7 +260,7 @@ static int setup_fec(void) (IOMUXC_GPR_GPR1_GPR_ENET1_TX_CLK_SEL_MASK | IOMUXC_GPR_GPR1_GPR_ENET1_CLK_DIR_MASK), 0);
- return set_clk_enet(ENET_125MHz); + return set_clk_enet(ENET_125MHZ); }
diff --git a/board/technexion/pico-imx7d/pico-imx7d.c b/board/technexion/pico-imx7d/pico-imx7d.c index b4c9be7..67bab51 100644 --- a/board/technexion/pico-imx7d/pico-imx7d.c +++ b/board/technexion/pico-imx7d/pico-imx7d.c @@ -182,7 +182,7 @@ static int setup_fec(void) (IOMUXC_GPR_GPR1_GPR_ENET1_TX_CLK_SEL_MASK | IOMUXC_GPR_GPR1_GPR_ENET1_CLK_DIR_MASK), 0);
int board_phy_config(struct phy_device *phydev) diff --git a/board/toradex/colibri_imx7/colibri_imx7.c b/board/toradex/colibri_imx7/colibri_imx7.c index 5cb14b4..13b2b57 100644 --- a/board/toradex/colibri_imx7/colibri_imx7.c +++ b/board/toradex/colibri_imx7/colibri_imx7.c @@ -280,7 +280,7 @@ static int setup_fec(void) IOMUXC_GPR_GPR1_GPR_ENET1_TX_CLK_SEL_MASK); #endif
- return set_clk_enet(ENET_50MHz); + return set_clk_enet(ENET_50MHZ); }
Signed-off-by: Eric Nelson eric@nelint.com --- V2 fixes a couple of references in mx7/clock.c arch/arm/include/asm/arch-mx7/clock.h | 6 +++--- arch/arm/mach-imx/mx7/clock.c | 6 +++--- board/freescale/mx7dsabresd/mx7dsabresd.c | 2 +- board/technexion/pico-imx7d/pico-imx7d.c | 2 +- board/toradex/colibri_imx7/colibri_imx7.c | 2 +- 5 files changed, 9 insertions(+), 9 deletions(-)
u32 get_root_clk(enum clk_root_index clock_id); diff --git a/arch/arm/mach-imx/mx7/clock.c b/arch/arm/mach-imx/mx7/clock.c index 2cfde46..8150faa 100644 --- a/arch/arm/mach-imx/mx7/clock.c +++ b/arch/arm/mach-imx/mx7/clock.c @@ -966,15 +966,15 @@ int set_clk_enet(enum enet_freq type) clock_enable(CCGR_ENET2, 0);
switch (type) { - case ENET_125MHz: + case ENET_125MHZ: enet1_ref = ENET1_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK; enet2_ref = ENET2_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK; break; - case ENET_50MHz: + case ENET_50MHZ: enet1_ref = ENET1_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_50M_CLK; enet2_ref = ENET2_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_50M_CLK; break; - case ENET_25MHz: + case ENET_25MHZ: enet1_ref = ENET1_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_25M_CLK; enet2_ref = ENET2_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_25M_CLK; break; diff --git a/board/freescale/mx7dsabresd/mx7dsabresd.c b/board/freescale/mx7dsabresd/mx7dsabresd.c index a681ece..5819b18 100644 --- a/board/freescale/mx7dsabresd/mx7dsabresd.c +++ b/board/freescale/mx7dsabresd/mx7dsabresd.c @@ -260,7 +260,7 @@ static int setup_fec(void) (IOMUXC_GPR_GPR1_GPR_ENET1_TX_CLK_SEL_MASK | IOMUXC_GPR_GPR1_GPR_ENET1_CLK_DIR_MASK), 0);
Hi Eric,
enum enet_freq {
- ENET_25MHz,
- ENET_50MHz,
- ENET_125MHz,
- ENET_25MHZ,
- ENET_50MHZ,
- ENET_125MHZ,
switch (type) {
- case ENET_125MHz:
- case ENET_125MHZ: enet1_ref = ENET1_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK; enet2_ref = ENET2_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK; break;
- case ENET_50MHz:
- case ENET_50MHZ: enet1_ref = ENET1_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_50M_CLK; enet2_ref = ENET2_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_50M_CLK; break;
- case ENET_25MHz:
- case ENET_25MHZ: enet1_ref = ENET1_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_25M_CLK; enet2_ref = ENET2_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_25M_CLK; break;
- return set_clk_enet(ENET_125MHZ);
- return set_clk_enet(ENET_50MHZ);
Reviewed-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Eric Nelson
Stefano Babic
