[U-Boot] [PATCH 1/1] efi_selftest: do not write to linker generated array
Linker generated arrays may be stored in code sections of memory that are not writable. So let's allocate setup_ok as an array at runtime.
This avoids an illegal memory access observed in the sandbox.
Reported-by: Simon Glass sjg@chromium.org Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- include/efi_selftest.h | 2 -- lib/efi_selftest/efi_selftest.c | 31 ++++++++++++++++++++++--------- 2 files changed, 22 insertions(+), 11 deletions(-)
diff --git a/include/efi_selftest.h b/include/efi_selftest.h index 56beac305e..49d3d6d0b4 100644 --- a/include/efi_selftest.h +++ b/include/efi_selftest.h @@ -129,7 +129,6 @@ u16 efi_st_get_key(void); * @setup: set up the unit test * @teardown: tear down the unit test * @execute: execute the unit test - * @setup_ok: setup was successful (set at runtime) * @on_request: test is only executed on request */ struct efi_unit_test { @@ -139,7 +138,6 @@ struct efi_unit_test { const struct efi_system_table *systable); int (*execute)(void); int (*teardown)(void); - int setup_ok; bool on_request; };
diff --git a/lib/efi_selftest/efi_selftest.c b/lib/efi_selftest/efi_selftest.c index dd338db687..fc7866365d 100644 --- a/lib/efi_selftest/efi_selftest.c +++ b/lib/efi_selftest/efi_selftest.c @@ -18,6 +18,7 @@ static const struct efi_boot_services *boottime; static const struct efi_runtime_services *runtime; static efi_handle_t handle; static u16 reset_message[] = L"Selftest completed"; +static int *setup_ok;
/* * Exit the boot services. @@ -74,20 +75,20 @@ void efi_st_exit_boot_services(void) */ static int setup(struct efi_unit_test *test, unsigned int *failures) { - if (!test->setup) { - test->setup_ok = EFI_ST_SUCCESS; + int ret; + + if (!test->setup) return EFI_ST_SUCCESS; - } efi_st_printc(EFI_LIGHTBLUE, "\nSetting up '%s'\n", test->name); - test->setup_ok = test->setup(handle, systable); - if (test->setup_ok != EFI_ST_SUCCESS) { + ret = test->setup(handle, systable); + if (ret != EFI_ST_SUCCESS) { efi_st_error("Setting up '%s' failed\n", test->name); ++*failures; } else { efi_st_printc(EFI_LIGHTGREEN, "Setting up '%s' succeeded\n", test->name); } - return test->setup_ok; + return ret; }
/* @@ -186,18 +187,20 @@ static void list_all_tests(void) void efi_st_do_tests(const u16 *testname, unsigned int phase, unsigned int steps, unsigned int *failures) { + int i = 0; struct efi_unit_test *test;
for (test = ll_entry_start(struct efi_unit_test, efi_unit_test); - test < ll_entry_end(struct efi_unit_test, efi_unit_test); ++test) { + test < ll_entry_end(struct efi_unit_test, efi_unit_test); + ++test, ++i) { if (testname ? efi_st_strcmp_16_8(testname, test->name) : test->on_request) continue; if (test->phase != phase) continue; if (steps & EFI_ST_SETUP) - setup(test, failures); - if (steps & EFI_ST_EXECUTE && test->setup_ok == EFI_ST_SUCCESS) + setup_ok[i] = setup(test, failures); + if (steps & EFI_ST_EXECUTE && setup_ok[i] == EFI_ST_SUCCESS) execute(test, failures); if (steps & EFI_ST_TEARDOWN) teardown(test, failures); @@ -271,6 +274,16 @@ efi_status_t EFIAPI efi_selftest(efi_handle_t image_handle, ll_entry_count(struct efi_unit_test, efi_unit_test));
+ /* Allocate buffer for setup results */ + ret = boottime->allocate_pool(EFI_RUNTIME_SERVICES_DATA, sizeof(int) * + ll_entry_count(struct efi_unit_test, + efi_unit_test), + (void **)&setup_ok); + if (ret != EFI_SUCCESS) { + efi_st_error("Allocate pool failed\n"); + return ret; + } + /* Execute boottime tests */ efi_st_do_tests(testname, EFI_EXECUTE_BEFORE_BOOTTIME_EXIT, EFI_ST_SETUP | EFI_ST_EXECUTE | EFI_ST_TEARDOWN,
Hi Heinrich,
Thanks for doing this!
- @setup: set up the unit test
- @teardown: tear down the unit test
- @execute: execute the unit test
- @setup_ok: setup was successful (set at runtime)
I'm not keen on the name setup_ok, which suggests a bool which would be true if it is OK.
How about setup_err or setup_ret?
- @on_request: test is only executed on request
- Exit the boot services.
if (!test->setup) {
int ret;
return ret;
int i = 0; struct efi_unit_test *test; for (test = ll_entry_start(struct efi_unit_test, efi_unit_test);
efi_unit_test),
Isn't this calling the code you are trying to test and messing with the memory allocation tables? I wonder if you should allocate this in the caller or as part of the setup.
Hmmm but I suppose you don't want to, since this is sort-of an EFI app?
return ret;
-- 2.19.1
On 10/22/2018 07:49 PM, Simon Glass wrote:
Hi Heinrich,
if (!test->setup) {
int ret;
return ret;
efi_unit_test),
I would prefer to keep efi_selftest self-sufficient so that one day we can compile it as an app like we do with helloworld.efi.
Best regards
Heinrich
return ret;
-- 2.19.1
Hi Heinrich,
Hi Heinrich,
if (!test->setup) {
int ret;
return ret;
efi_unit_test),
OK, but understand there are big benefits to running it within sandbox (mainly debuggability, valgrind, etc).
