[U-Boot] U-Boot: AM335x Booting with environment in NAND: ECC cause failures...
Trying to boot from NAND on an AM335x-EVM with environment in NAND
Have cloned "git://arago-project.org/git/projects/u-boot-am33x.git" and done some minor changes (see below)
All documentation I've read tell me to use "nandecc hw 2" before programming the NAND.
If I program the kernel and rootfs into the nand by
nandecc hw 2 nand.write ...
and then save the environment, it looks like the environment is saved with the same ECC algorithm.
This is no good, since U-Boot will always read the environment at boot, using the incompatible Hamming Mode, so the next reboot will fail.
This looks like a bug to me.
Methinks there should be a configuration item telling which ECC algorithm to use for the environment, and this is used when reading the environment at boot, and when using "saveenv".
Any other read/writes should use the user defined algorithm
Right now, you need to remember to set the ECC to Hamming before every saveenv
BR Ulf Samuelsson
----------------------------------------------------------------- diff --git a/boards.cfg b/boards.cfg index 55af69f..ec5480c 100644 --- a/boards.cfg +++ b/boards.cfg @@ -168,10 +168,11 @@ omap3_pandora arm armv7 pandora - igep0020 arm armv7 igep0020 isee omap3 igep0030 arm armv7 igep0030 isee omap3 am335x_evm arm armv7 am335x ti ti81xx -am335x_evm_restore_flash arm armv7 am335x ti ti81xx am335x_evm:RESTORE_FLASH -am335x_evm_spiboot arm armv7 am335x ti ti81xx am335x_evm:SPI_BOOT -am335x_evm_uart_usbspl arm armv7 am335x ti ti81xx am335x_evm:UART_THEN_USB_SPL -am335x_evm_restore_flash_usbspl arm armv7 am335x ti ti81xx am335x_evm:RESTORE_FLASH,UART_THEN_USB_SPL +am335x_evm_nandflash arm armv7 am335x ti ti81xx am335x_evm:NAND_BOOT +am335x_evm_restore_flash arm armv7 am335x ti ti81xx am335x_evm:RESTORE_FLASH +am335x_evm_spiboot arm armv7 am335x ti ti81xx am335x_evm:SPI_BOOT +am335x_evm_uart_usbspl arm armv7 am335x ti ti81xx am335x_evm:UART_THEN_USB_SPL +am335x_evm_restore_flash_usbspl arm armv7 am335x ti ti81xx am335x_evm:RESTORE_FLASH,UART_THEN_USB_SPL am3517_crane arm armv7 am3517crane ti omap3 am3517_evm arm armv7 am3517evm logicpd omap3 am3517_evm_norflash arm armv7 am3517evm logicpd omap3 am3517_evm:SYS_HAS_NORFLASH diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 3ae23b2..4cc5e43 100755 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -16,7 +16,12 @@ #define CONFIG_AM335X #define CONFIG_TI81XX #define CONFIG_SYS_NO_FLASH -#ifndef CONFIG_SPI_BOOT +#define kB << 10 +#if defined(CONFIG_NAND_BOOT) +#define CONFIG_NAND_ENV +#elif defined(CONFIG_SPI_BOOT) +#define CONFIG_NAND_ENV +#else #define CONFIG_NAND_ENV #endif
@@ -131,29 +136,44 @@ "tftp ${kloadaddr} ${bootfile}; " \ "run net_args; " \ "bootm ${kloadaddr}\0" \ + "reflash=mmc rescan ; " \ + "nand erase 0x0 0x280000 ; " \ + "saveenv ; " \ + "nandecc hw 2 ; " \ + "fatload mmc 0 0x81000000 MLO ; " \ + "nand write 0x81000000 0x0 0x20000 ; " \ + "nand write 0x81000000 0x20000 0x20000 ; " \ + "nand write 0x81000000 0x40000 0x20000 ; " \ + "nand write 0x81000000 0x60000 0x20000 ; " \ + "fatload mmc 0 0x81000000 u-boot.img ; " \ + "nand write 0x81000000 0x80000 0x1E0000\0" \ + "update=mmc rescan ; " \ + "fatload mmc ${mmc_dev} ${loadaddr} update.env ; " \ + "env import -t $loadaddr $filesize ; " \ + "run update\0" \ + "tiboot=if mmc rescan; then " \ + "echo SD/MMC found on device ${mmc_dev};" \ + "if run loadbootenv; then " \ + "echo Loaded environment from ${bootenv};" \ + "run importbootenv;" \ + "fi;" \ + "if test -n $uenvcmd; then " \ + "echo Running uenvcmd ...;" \ + "run uenvcmd;" \ + "fi;" \ + "if run mmc_load_uimage; then " \ + "run mmc_args;" \ + "bootm ${kloadaddr};" \ + "fi;" \ + "fi;" \ + "run nand_boot;\0" \ +
#ifndef CONFIG_RESTORE_FLASH /* set to negative value for no autoboot */ #define CONFIG_BOOTDELAY 3
-#define CONFIG_BOOTCOMMAND \ - "if mmc rescan; then " \ - "echo SD/MMC found on device ${mmc_dev};" \ - "if run loadbootenv; then " \ - "echo Loaded environment from ${bootenv};" \ - "run importbootenv;" \ - "fi;" \ - "if test -n $uenvcmd; then " \ - "echo Running uenvcmd ...;" \ - "run uenvcmd;" \ - "fi;" \ - "if run mmc_load_uimage; then " \ - "run mmc_args;" \ - "bootm ${kloadaddr};" \ - "fi;" \ - "fi;" \ - "run nand_boot;" \ - +#define CONFIG_BOOTCOMMAND "run nand_boot" #else #define CONFIG_BOOTDELAY 0
@@ -236,7 +256,7 @@ #define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/omap-common/u-boot-spl.lds"
/* NAND boot config */ -#ifndef CONFIG_SPI_BOOT +#ifdef CONFIG_NAND_BOOT #define CONFIG_SPL_NAND_SIMPLE #define CONFIG_SPL_NAND_SUPPORT #define CONFIG_SYS_NAND_5_ADDR_CYCLE @@ -267,6 +287,7 @@ #endif
/* SPI boot config */ +#ifdef CONFIG_SPI_BOOT #define CONFIG_SPL_SPI_SUPPORT #define CONFIG_SPL_SPI_FLASH_SUPPORT #define CONFIG_SPL_SPI_LOAD @@ -274,6 +295,7 @@ #define CONFIG_SPL_SPI_CS 0 #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000 #define CONFIG_SYS_SPI_U_BOOT_SIZE 0x40000 +#endif
/* * 1MB into the SDRAM to allow for SPL's bss at the beginning of SDRAM. @@ -361,6 +383,9 @@ #if defined(CONFIG_NAND_ENV) #undef CONFIG_ENV_IS_NOWHERE #define CONFIG_ENV_IS_IN_NAND +#undef CONFIG_ENV_SIZE +#define CONFIG_ENV_SIZE 0x20000 + #define CONFIG_SYS_MAX_FLASH_SECT 520 /* max no of sectors in a chip */ #define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max no of flash banks */ #define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */
This is not the right list for that tree.
[snip]
Yes. The series that adds NAND support for this SoC to mainline fixes the problem as well (a faulty nand read in the SPL case).
Ulf Samuelsson
