[U-Boot] [PATCH-OMAP3] OMAP3: Enable command parser and add boot scripting
Enable "hush" command parser and set default environment to boot from MMC if a bootable card is present, otherwise boot from NAND.
Signed-off-by: Steve Sakoman sakoman@gmail.com Signed-off-by: Dirk Behme dirk.behme@googlemail.com
* This patch applies on top of last 6 pending OMAP3 patches (in this order):
http://lists.denx.de/pipermail/u-boot/2008-November/043771.html http://lists.denx.de/pipermail/u-boot/2008-November/043898.html http://lists.denx.de/pipermail/u-boot/2008-November/043899.html http://lists.denx.de/pipermail/u-boot/2008-November/044026.html http://lists.denx.de/pipermail/u-boot/2008-November/044027.html http://lists.denx.de/pipermail/u-boot/2008-December/044292.html
* Compile tested for Beagle, Overo, Panora and EVM. Boot tested on Beagle.
include/configs/omap3_beagle.h | 47 ++++++++++++++++++++++++++++++++-------- include/configs/omap3_evm.h | 41 ++++++++++++++++++++++++++++------ include/configs/omap3_overo.h | 46 ++++++++++++++++++++++++++++++++------- include/configs/omap3_pandora.h | 45 ++++++++++++++++++++++++++++++++------ 4 files changed, 148 insertions(+), 31 deletions(-)
Index: u-boot-arm/include/configs/omap3_beagle.h =================================================================== --- u-boot-arm.orig/include/configs/omap3_beagle.h +++ u-boot-arm/include/configs/omap3_beagle.h @@ -159,16 +159,43 @@ /* Environment information */ #define CONFIG_BOOTDELAY 10
-#define CONFIG_BOOTCOMMAND "nand read 80200000 280000 400000 ; " \ - "bootm 80200000" +#define CONFIG_EXTRA_ENV_SETTINGS \ + "loadaddr=0x82000000\0" \ + "console=ttyS2,115200n8\0" \ + "videomode=1024x768@60,vxres=1024,vyres=768\0" \ + "videospec=omapfb:vram:2M,vram:4M\0" \ + "mmcargs=setenv bootargs console=${console} " \ + "video=${videospec},mode:${videomode} " \ + "root=/dev/mmcblk0p2 rw " \ + "rootfstype=ext3 rootwait\0" \ + "nandargs=setenv bootargs console=${console} " \ + "video=${videospec},mode:${videomode} " \ + "root=/dev/mtdblock4 rw " \ + "rootfstype=jffs2\0" \ + "loadbootscript=fatload mmc 0 ${loadaddr} boot.script\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "autoscr ${loadaddr}\0" \ + "loaduimage=fatload mmc 0 ${loadaddr} uImage\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "bootm ${loadaddr}\0" \ + "nandboot=echo Booting from nand ...; " \ + "run nandargs; " \ + "nand read ${loadaddr} 280000 400000; " \ + "bootm ${loadaddr}\0" \ + +#define CONFIG_BOOTCOMMAND \ + "if mmcinit; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loaduimage; then " \ + "run mmcboot; " \ + "else run nandboot; " \ + "fi; " \ + "fi; " \ + "else run nandboot; fi"
-#define CONFIG_BOOTARGS "setenv bootargs console=ttyS2," \ - "115200n8 noinitrd " \ - "root=/dev/mtdblock4 " \ - "rw rootfstype=jffs2" - -#define CONFIG_NETMASK 255.255.254.0 -#define CONFIG_BOOTFILE "uImage" #define CONFIG_AUTO_COMPLETE 1 /* * Miscellaneous configurable options @@ -176,6 +203,8 @@ #define V_PROMPT "OMAP3 beagleboard.org # "
#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_SYS_PROMPT V_PROMPT #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ /* Print Buffer Size */ Index: u-boot-arm/include/configs/omap3_evm.h =================================================================== --- u-boot-arm.orig/include/configs/omap3_evm.h +++ u-boot-arm/include/configs/omap3_evm.h @@ -165,14 +165,39 @@ /* Environment information */ #define CONFIG_BOOTDELAY 10
-#define CONFIG_BOOTCOMMAND "onenand read 80200000 280000 400000 ; " \ - "bootm 80200000" +#define CONFIG_EXTRA_ENV_SETTINGS \ + "loadaddr=0x82000000\0" \ + "console=ttyS2,115200n8\0" \ + "mmcargs=setenv bootargs console=${console} " \ + "root=/dev/mmcblk0p2 rw " \ + "rootfstype=ext3 rootwait\0" \ + "nandargs=setenv bootargs console=${console} " \ + "root=/dev/mtdblock4 rw " \ + "rootfstype=jffs2\0" \ + "loadbootscript=fatload mmc 0 ${loadaddr} boot.script\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "autoscr ${loadaddr}\0" \ + "loaduimage=fatload mmc 0 ${loadaddr} uImage\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "bootm ${loadaddr}\0" \ + "nandboot=echo Booting from nand ...; " \ + "run nandargs; " \ + "onenand read ${loadaddr} 280000 400000; " \ + "bootm ${loadaddr}\0" \ + +#define CONFIG_BOOTCOMMAND \ + "if mmcinit; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loaduimage; then " \ + "run mmcboot; " \ + "else run nandboot; " \ + "fi; " \ + "fi; " \ + "else run nandboot; fi"
-#define CONFIG_BOOTARGS "setenv bootargs console=ttyS2,115200n8 noinitrd " \ - "root=/dev/mtdblock4 rw rootfstype=jffs2" - -#define CONFIG_NETMASK 255.255.254.0 -#define CONFIG_BOOTFILE "uImage" #define CONFIG_AUTO_COMPLETE 1 /* * Miscellaneous configurable options @@ -180,6 +205,8 @@ #define V_PROMPT "OMAP3_EVM # "
#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_SYS_PROMPT V_PROMPT #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ /* Print Buffer Size */ Index: u-boot-arm/include/configs/omap3_overo.h =================================================================== --- u-boot-arm.orig/include/configs/omap3_overo.h +++ u-boot-arm/include/configs/omap3_overo.h @@ -151,15 +151,43 @@ /* Environment information */ #define CONFIG_BOOTDELAY 5
-#define CONFIG_BOOTCOMMAND "mmcinit; fatload mmc 0 82000000 uImage; "\ - "bootm 82000000" +#define CONFIG_EXTRA_ENV_SETTINGS \ + "loadaddr=0x82000000\0" \ + "console=ttyS2,115200n8\0" \ + "videomode=1024x768@60,vxres=1024,vyres=768\0" \ + "videospec=omapfb:vram:2M,vram:4M\0" \ + "mmcargs=setenv bootargs console=${console} " \ + "video=${videospec},mode:${videomode} " \ + "root=/dev/mmcblk0p2 rw " \ + "rootfstype=ext3 rootwait\0" \ + "nandargs=setenv bootargs console=${console} " \ + "video=${videospec},mode:${videomode} " \ + "root=/dev/mtdblock4 rw " \ + "rootfstype=jffs2\0" \ + "loadbootscript=fatload mmc 0 ${loadaddr} boot.script\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "autoscr ${loadaddr}\0" \ + "loaduimage=fatload mmc 0 ${loadaddr} uImage\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "bootm ${loadaddr}\0" \ + "nandboot=echo Booting from nand ...; " \ + "run nandargs; " \ + "nand read ${loadaddr} 280000 400000; " \ + "bootm ${loadaddr}\0" \ + +#define CONFIG_BOOTCOMMAND \ + "if mmcinit; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loaduimage; then " \ + "run mmcboot; " \ + "else run nandboot; " \ + "fi; " \ + "fi; " \ + "else run nandboot; fi"
-#define CONFIG_BOOTARGS "setenv bootargs console=ttyS2,115200n8 " \ - "root=/dev/mmcblk0p2 rw rootfstype=ext3 " \ - "rootwait" - -#define CONFIG_NETMASK 255.255.254.0 -#define CONFIG_BOOTFILE "uImage" #define CONFIG_AUTO_COMPLETE 1 /* * Miscellaneous configurable options @@ -167,6 +195,8 @@ #define V_PROMPT "Overo # "
#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_SYS_PROMPT V_PROMPT #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ /* Print Buffer Size */ Index: u-boot-arm/include/configs/omap3_pandora.h =================================================================== --- u-boot-arm.orig/include/configs/omap3_pandora.h +++ u-boot-arm/include/configs/omap3_pandora.h @@ -151,14 +151,43 @@ /* Environment information */ #define CONFIG_BOOTDELAY 1
-#define CONFIG_BOOTCOMMAND "nand read 80200000 280000 400000 ; " \ - "bootm 80200000" +#define CONFIG_EXTRA_ENV_SETTINGS \ + "loadaddr=0x82000000\0" \ + "console=ttyS0,115200n8\0" \ + "videomode=1024x768@60,vxres=1024,vyres=768\0" \ + "videospec=omapfb:vram:2M,vram:4M\0" \ + "mmcargs=setenv bootargs console=${console} " \ + "video=${videospec},mode:${videomode} " \ + "root=/dev/mmcblk0p2 rw " \ + "rootfstype=ext3 rootwait\0" \ + "nandargs=setenv bootargs console=${console} " \ + "video=${videospec},mode:${videomode} " \ + "root=/dev/mtdblock4 rw " \ + "rootfstype=jffs2\0" \ + "loadbootscript=fatload mmc 0 ${loadaddr} boot.script\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "autoscr ${loadaddr}\0" \ + "loaduimage=fatload mmc 0 ${loadaddr} uImage\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "bootm ${loadaddr}\0" \ + "nandboot=echo Booting from nand ...; " \ + "run nandargs; " \ + "nand read ${loadaddr} 280000 400000; " \ + "bootm ${loadaddr}\0" \ + +#define CONFIG_BOOTCOMMAND \ + "if mmcinit; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loaduimage; then " \ + "run mmcboot; " \ + "else run nandboot; " \ + "fi; " \ + "fi; " \ + "else run nandboot; fi"
-#define CONFIG_BOOTARGS "console=ttyS0,115200n8 noinitrd " \ - "root=/dev/mtdblock4 rw rootfstype=jffs2" - -#define CONFIG_NETMASK 255.255.254.0 -#define CONFIG_BOOTFILE "uImage" #define CONFIG_AUTO_COMPLETE 1 /* * Miscellaneous configurable options @@ -166,6 +195,8 @@ #define V_PROMPT "Pandora # "
Is it possible to rename boot.script to boot.scr or something with an 8.3 filename, in case someone formats their SD card as msdos, rather than vfat?
- This patch applies on top of last 6 pending OMAP3 patches (in this
order):
- Compile tested for Beagle, Overo, Panora and EVM. Boot tested on
Beagle.
include/configs/omap3_beagle.h | 47 ++++++++++++++++++++++++++++++ ++-------- include/configs/omap3_evm.h | 41 +++++++++++++++++++++++++++ +------ include/configs/omap3_overo.h | 46 ++++++++++++++++++++++++++++++ ++------- include/configs/omap3_pandora.h | 45 ++++++++++++++++++++++++++++++ ++------ 4 files changed, 148 insertions(+), 31 deletions(-)
"bootm 80200000"
- "loadaddr=0x82000000\0" \
- "console=ttyS2,115200n8\0" \
- "videomode=1024x768@60,vxres=1024,vyres=768\0" \
- "videospec=omapfb:vram:2M,vram:4M\0" \
- "mmcargs=setenv bootargs console=${console} " \
- "nandargs=setenv bootargs console=${console} " \
- "loadbootscript=fatload mmc 0 ${loadaddr} boot.script\0" \
- "bootscript=echo Running bootscript from mmc ...; " \
- "loaduimage=fatload mmc 0 ${loadaddr} uImage\0" \
- "mmcboot=echo Booting from mmc ...; " \
"run mmcargs; " \
- "nandboot=echo Booting from nand ...; " \
"run nandargs; " \
- "if mmcinit; then " \
"else " \
"run mmcboot; " \
"fi; " \
"fi; " \
- "else run nandboot; fi"
- Miscellaneous configurable options
"bootm 80200000"
"run mmcargs; " \
"run nandargs; " \
"else " \
"run mmcboot; " \
"fi; " \
"fi; " \
"bootm 82000000"
"run mmcargs; " \
"run nandargs; " \
"else " \
"run mmcboot; " \
"fi; " \
"fi; " \
"rootwait"
"bootm 80200000"
- "console=ttyS0,115200n8\0" \
"run mmcargs; " \
"run nandargs; " \
"else " \
"run mmcboot; " \
"fi; " \
"fi; " \
#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_SYS_PROMPT V_PROMPT #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ /* Print Buffer Size */ _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Ack
Best Regards, J.
Dirk Behme
Jason Kridner
Jean-Christophe PLAGNIOL-VILLARD
