[U-Boot-Users] setenv handeling on OSK
Hi I am having similar problems with the osk to Jean-Marc 2005-09-14 01:38. I also used an = in setenv ie. setenv ipaddr=192.168.1.21. then I tried using tftpboot ie. tftpboot 0x10000000 u-boot.bin with u-boot.bin in the /tftpboot dir on the host.I get the error, ERROR 'ipaddr' not set I saw something about not using the = sign so I set the env variables again. All changed accordingly except ipaddr, which now has two entries. Still tftpboot does not work. I am going to use the flash recovery utility, but was wondering 1.) is this normal operation or is this just the factory installed u-boot operation? 2.) is there any way of removing environment variables?
OMAP5912 OSK # printenv baudrate=115200 bootcmd=bootm 0x100000 bootfile=uImage bootdelay=10 ethaddr=00-0E-99-02-06-46 ipaddr=192.168.1.21 severip=0 ipaddr=192.168.1.11 stdin=serial stdout=serial stderr=serial netmask=255.255.254.0 serverip=192.168.1.6 bootargs=console=ttyS0,115200n8 noinitrd rw ip=off root=/dev/mtdblock4 mem=30
Any advice would be much appreciated :)
_________________________________________________________________ Sell your car for $9 on carpoint.com.au http://www.carpoint.com.au/sellyourcar
You probably want:
=> setenv ipaddr 192.168.1.1
=> setenv ipaddr
This will delete the ipaddr variable from memory.
Carl Blair
Graham Wilson
