[U-Boot] [PATCH v12 1/3] Consolidating UDP header functions.
To make it possible to add TCP versions of the same, while reusing IP portions. This patch should not change any behavior.
All references to TCP removed Used most recent version of u-boot June 22 13, 2918 Series to fix patman errors over Licensing declaration END
Series-notes TCP with Selective Acknowledgment (SACK) is currently the protocol with highest speed transfers, for fast multi-hop networks. END
Signed-off-by: Duncan Hare DH@Synoia.com Signed-off-by: Duncan Hare DuncanCHare@yahoo.com ---
include/net.h | 6 +++++- net/net.c | 34 ++++++++++++++++++++++++---------- net/ping.c | 7 +------ 3 files changed, 30 insertions(+), 17 deletions(-)
diff --git a/include/net.h b/include/net.h index 5760685556..a54160fff6 100644 --- a/include/net.h +++ b/include/net.h @@ -593,7 +593,8 @@ int net_set_ether(uchar *xet, const uchar *dest_ethaddr, uint prot); int net_update_ether(struct ethernet_hdr *et, uchar *addr, uint prot);
/* Set IP header */ -void net_set_ip_header(uchar *pkt, struct in_addr dest, struct in_addr source); +void net_set_ip_header(uchar *pkt, struct in_addr dest, struct in_addr source, + u16 pkt_len, u8 proto); void net_set_udp_header(uchar *pkt, struct in_addr dest, int dport, int sport, int len);
@@ -667,6 +668,9 @@ static inline void net_send_packet(uchar *pkt, int len) * @param sport Source UDP port * @param payload_len Length of data after the UDP header */ +int net_send_ip_packet(uchar *ether, struct in_addr dest, int dport, int sport, + int payload_len, int proto, u8 action, u32 tcp_seq_num, + u32 tcp_ack_num); int net_send_udp_packet(uchar *ether, struct in_addr dest, int dport, int sport, int payload_len);
diff --git a/net/net.c b/net/net.c index b4563a4cab..f831c34599 100644 --- a/net/net.c +++ b/net/net.c @@ -786,6 +786,14 @@ void net_set_timeout_handler(ulong iv, thand_f *f) int net_send_udp_packet(uchar *ether, struct in_addr dest, int dport, int sport, int payload_len) { +return net_send_ip_packet(ether, dest, dport, sport, payload_len, + IPPROTO_UDP, 0, 0, 0); +} + +int net_send_ip_packet(uchar *ether, struct in_addr dest, int dport, int sport, + int payload_len, int proto, u8 action, u32 tcp_seq_num, + u32 tcp_ack_num) +{ uchar *pkt; int eth_hdr_size; int pkt_hdr_size; @@ -806,9 +814,15 @@ int net_send_udp_packet(uchar *ether, struct in_addr dest, int dport, int sport, pkt = (uchar *)net_tx_packet;
eth_hdr_size = net_set_ether(pkt, ether, PROT_IP); - pkt += eth_hdr_size; - net_set_udp_header(pkt, dest, dport, sport, payload_len); - pkt_hdr_size = eth_hdr_size + IP_UDP_HDR_SIZE; + + switch (proto) { + case IPPROTO_UDP: + net_set_udp_header(pkt + eth_hdr_size, dest, + dport, sport, payload_len); + pkt_hdr_size = eth_hdr_size + IP_UDP_HDR_SIZE; + break; + default: return -EINVAL; + }
/* if MAC address was not discovered yet, do an ARP request */ if (memcmp(ether, net_null_ethaddr, 6) == 0) { @@ -1434,7 +1448,8 @@ int net_update_ether(struct ethernet_hdr *et, uchar *addr, uint prot) } }
-void net_set_ip_header(uchar *pkt, struct in_addr dest, struct in_addr source) +void net_set_ip_header(uchar *pkt, struct in_addr dest, struct in_addr source, + u16 pkt_len, u8 proto) { struct ip_udp_hdr *ip = (struct ip_udp_hdr *)pkt;
@@ -1444,11 +1459,12 @@ void net_set_ip_header(uchar *pkt, struct in_addr dest, struct in_addr source) /* IP_HDR_SIZE / 4 (not including UDP) */ ip->ip_hl_v = 0x45; ip->ip_tos = 0; - ip->ip_len = htons(IP_HDR_SIZE); + ip->ip_len = htons(pkt_len); + ip->ip_p = proto; ip->ip_id = htons(net_ip_id++); ip->ip_off = htons(IP_FLAGS_DFRAG); /* Don't fragment */ ip->ip_ttl = 255; - ip->ip_sum = 0; + ip->ip_sum = compute_ip_checksum(ip, IP_HDR_SIZE); /* already in network byte order */ net_copy_ip((void *)&ip->ip_src, &source); /* already in network byte order */ @@ -1468,10 +1484,8 @@ void net_set_udp_header(uchar *pkt, struct in_addr dest, int dport, int sport, if (len & 1) pkt[IP_UDP_HDR_SIZE + len] = 0;
- net_set_ip_header(pkt, dest, net_ip); - ip->ip_len = htons(IP_UDP_HDR_SIZE + len); - ip->ip_p = IPPROTO_UDP; - ip->ip_sum = compute_ip_checksum(ip, IP_HDR_SIZE); + net_set_ip_header(pkt, dest, net_ip, IP_UDP_HDR_SIZE + len, + IPPROTO_UDP);
ip->udp_src = htons(sport); ip->udp_dst = htons(dport); diff --git a/net/ping.c b/net/ping.c index 3e5461a36a..d5d914bf2a 100644 --- a/net/ping.c +++ b/net/ping.c @@ -22,14 +22,9 @@ static void set_icmp_header(uchar *pkt, struct in_addr dest) /* * Construct an IP and ICMP header. */ - struct ip_hdr *ip = (struct ip_hdr *)pkt; struct icmp_hdr *icmp = (struct icmp_hdr *)(pkt + IP_HDR_SIZE);
- net_set_ip_header(pkt, dest, net_ip); - - ip->ip_len = htons(IP_ICMP_HDR_SIZE); - ip->ip_p = IPPROTO_ICMP; - ip->ip_sum = compute_ip_checksum(ip, IP_HDR_SIZE); + net_set_ip_header(pkt, dest, net_ip, IP_ICMP_HDR_SIZE, IPPROTO_ICMP);
icmp->type = ICMP_ECHO_REQUEST; icmp->code = 0;
Currently file transfers are done using tftp or NFS both over udp. This requires a request to be sent from client (u-boot) to the boot server.
The current standard is TCP with selective acknowledgment.
In our testing we have reduce kernel transmission time to around 0.4 seconds for a 4Mbyte kernel, with a 100 Mbps downlink.
Series-Changes 11 - Add TCP with SACK - Clean formatting - Remove buffer search and print routines
Series-Changes 12 - Fix License statement
include/net.h | 11 +- include/net/tcp.h | 227 ++++++++++++++++++ net/Kconfig | 6 + net/Makefile | 1 + net/net.c | 33 +++ net/tcp.c | 700 ++++++++++++++++++++++++++++++++++++++++++++++++++++++ 6 files changed, 977 insertions(+), 1 deletion(-) create mode 100644 include/net/tcp.h create mode 100644 net/tcp.c
diff --git a/include/net.h b/include/net.h index a54160fff6..ba96267eb8 100644 --- a/include/net.h +++ b/include/net.h @@ -26,6 +26,9 @@ * */
+#if defined(CONFIG_TCP) /* Protected UDP uses less bufferes than TCP */ +#define CONFIG_SYS_RX_ETH_BUFFER 12 +#endif #ifdef CONFIG_SYS_RX_ETH_BUFFER # define PKTBUFSRX CONFIG_SYS_RX_ETH_BUFFER #else @@ -350,6 +353,7 @@ struct vlan_ethernet_hdr { #define PROT_PPP_SES 0x8864 /* PPPoE session messages */
#define IPPROTO_ICMP 1 /* Internet Control Message Protocol */ +#define IPPROTO_TCP 6 /* Transmission Control Protocol */ #define IPPROTO_UDP 17 /* User Datagram Protocol */
/* @@ -659,7 +663,7 @@ static inline void net_send_packet(uchar *pkt, int len) }
/* - * Transmit "net_tx_packet" as UDP packet, performing ARP request if needed + * Transmit "net_tx_packet" as UDP or TCPpacket, send ARP request if needed * (ether will be populated) * * @param ether Raw packet buffer @@ -667,10 +671,15 @@ static inline void net_send_packet(uchar *pkt, int len) * @param dport Destination UDP port * @param sport Source UDP port * @param payload_len Length of data after the UDP header + * @param action TCP action to be performed + * @param tcp_seq_num TCP sequence number of this transmission + * @param tcp_ack_num TCP stream acknolegement number */ int net_send_ip_packet(uchar *ether, struct in_addr dest, int dport, int sport, int payload_len, int proto, u8 action, u32 tcp_seq_num, u32 tcp_ack_num); +int net_send_tcp_packet(int payload_len, int dport, int sport, u8 action, + u32 tcp_seq_num, u32 tcp_ack_num); int net_send_udp_packet(uchar *ether, struct in_addr dest, int dport, int sport, int payload_len);
diff --git a/include/net/tcp.h b/include/net/tcp.h new file mode 100644 index 0000000000..d0e90e07dd --- /dev/null +++ b/include/net/tcp.h @@ -0,0 +1,227 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * TCP Support with SACK for file transfer. + * + * Copyright 2017 Duncan Hare, All rights reserved. + */ + +#define TCP_ACTIVITY 127 /* Number of packets received */ + /* before console progress mark */ + +struct ip_tcp_hdr { + u8 ip_hl_v; /* header length and version */ + u8 ip_tos; /* type of service */ + u16 ip_len; /* total length */ + u16 ip_id; /* identification */ + u16 ip_off; /* fragment offset field */ + u8 ip_ttl; /* time to live */ + u8 ip_p; /* protocol */ + u16 ip_sum; /* checksum */ + struct in_addr ip_src; /* Source IP address */ + struct in_addr ip_dst; /* Destination IP address */ + u16 tcp_src; /* TCP source port */ + u16 tcp_dst; /* TCP destination port */ + u32 tcp_seq; /* TCP sequence number */ + u32 tcp_ack; /* TCP Acknowledgment number */ + u8 tcp_hlen; /* 4 bits TCP header Length/4 */ + /* 4 bits Reserved */ + /* 2 more bits reserved */ + u8 tcp_flags; /* see defines */ + u16 tcp_win; /* TCP windows size */ + u16 tcp_xsum; /* Checksum */ + u16 tcp_ugr; /* Pointer to urgent data */ +} __packed; + +#define IP_TCP_HDR_SIZE (sizeof(struct ip_tcp_hdr)) +#define TCP_HDR_SIZE (IP_TCP_HDR_SIZE - IP_HDR_SIZE) + +#define TCP_DATA 0x00 /* Data Packet - internal use only */ +#define TCP_FIN 0x01 /* Finish flag */ +#define TCP_SYN 0x02 /* Synch (start) flag */ +#define TCP_RST 0x04 /* reset flag */ +#define TCP_PUSH 0x08 /* Push - Notify app */ +#define TCP_ACK 0x10 /* Acknowledgment of data received */ +#define TCP_URG 0x20 /* Urgent */ +#define TCP_ECE 0x40 /* Congestion control */ +#define TCP_CWR 0x80 /* Congestion Control */ + +/* + * TCP header options, Seq, MSS, and SACK + */ + +#define TCP_SACK 32 /* Number of packets analyzed */ + /* on leading edge of stream */ + +#define TCP_O_END 0x00 /* End of option list */ +#define TCP_1_NOP 0x01 /* Single padding NOP */ +#define TCP_O_NOP 0x01010101 /* NOPs pad to 32 bit boundary */ +#define TCP_O_MSS 0x02 /* MSS Size option */ +#define TCP_O_SCL 0x03 /* Window Scale option */ +#define TCP_P_SACK 0x04 /* SACK permitted */ +#define TCP_V_SACK 0x05 /* SACK values */ +#define TCP_O_TS 0x08 /* Timestamp option */ +#define TCP_OPT_LEN_2 0x02 +#define TCP_OPT_LEN_3 0x03 +#define TCP_OPT_LEN_4 0x04 +#define TCP_OPT_LEN_6 0x06 +#define TCP_OPT_LEN_8 0x08 +#define TCP_OPT_LEN_A 0x0a /* Timestamp Length */ + +/* + * Please review the warning in net.c about these two parameters. + * They are part of a promise of RX buffer size to the sending TCP + */ + +#define TCP_MSS 1460 /* Max segment size */ +#define TCP_SCALE 0x01 /* Scale */ + +struct tcp_mss { /* TCP Max Segment size */ + u8 kind; /* Field ID */ + u8 len; /* Field length */ + u16 mss; /* Segment size value */ +} __packed; + +struct tcp_scale { /* TCP Windows Scale */ + u8 kind; /* Field ID */ + u8 len; /* Filed length */ + u8 scale; /* windows shift value used for */ + /* networks with many hops */ + /* Typically 4 or more hops */ + +} __packed; + +struct tcp_sack_p { /* SACK permitted */ + u8 kind; /* Field Id */ + u8 len; /* Field length */ +} __packed; + + /* Terse definitions used */ + /* long definitions make the */ + /* indented code overflow line */ + /* length linits */ +struct sack_edges { + u32 l; /* Left edge of stream */ + u32 r; /* right edge of stream */ +} __packed; + +#define TCP_SACK_SIZE (sizeof(struct sack_edges)) + +/* + * A TCP stream has holes when packets are missing or disordered. + * A hill is the inverese of a hole, and is data received. + * TCP receiveds hills (a sequence of data), and inferrs Holes + * from the "hills" or packets received. + */ + +#define TCP_SACK_HILLS 4 + +struct tcp_sack_v { + u8 kind; /* Field ID */ + u8 len; /* Field Length */ + struct sack_edges hill[TCP_SACK_HILLS]; /* L & R window edges */ +} __packed; + +struct tcp_t_opt { /* TCP time stamps option */ + u8 kind; /* Field id */ + u8 len; /* Field length */ + u32 t_snd; /* Sender timestamp */ + u32 t_rcv; /* Receiver timestamp */ +} __packed; + +#define TCP_TSOPT_SIZE (sizeof(struct tcp_t_opt)) + +/* + * ip tcp structure with options + */ + +struct ip_tcp_hdr_o { + struct ip_tcp_hdr hdr; + struct tcp_mss mss; + struct tcp_scale scale; + struct tcp_sack_p sack_p; + struct tcp_t_opt t_opt; + u8 end; +} __packed; + +#define IP_TCP_O_SIZE (sizeof(struct ip_tcp_hdr_o)) + +struct ip_tcp_hdr_s { + struct ip_tcp_hdr hdr; + struct tcp_t_opt t_opt; + struct tcp_sack_v sack_v; + u8 end; +} __packed; + +#define IP_TCP_SACK_SIZE (sizeof(struct ip_tcp_hdr_s)) + +/* + * TCP pseudo header definitions + */ +#define PSEUDO_PAD_SIZE 8 + +struct pseudo_hdr { + u8 padding[PSEUDO_PAD_SIZE]; /* pseudo hdr size = ip_tcp hdr size */ + struct in_addr p_src; + struct in_addr p_dst; + u8 rsvd; + u8 p; + u16 len; +} __packed; + +#define PSEUDO_HDR_SIZE (sizeof(struct pseudo_hdr)) - PSEUDO_PAD_SIZE + +/* + * union for building TCP/IP packet. Build Pseudo header in packed buffer + * first, calculate TCP checksum, then build IP header in packed buffer. + */ + +union tcp_build_pkt { + struct pseudo_hdr ph; + struct ip_tcp_hdr_o ip; + struct ip_tcp_hdr_s sack; + uchar raw[1600]; +} __packed; + +/* + * TCP State machine states for connection + */ + +enum TCP_STATE { + TCP_CLOSED, /* Need to send SYN to connect */ + TCP_SYN_SENT, /* Trying to connect, waiting for SYN ACK */ + TCP_ESTABLISHED, /* both server & client have a connection */ + TCP_CLOSE_WAIT, /* Rec FIN, passed to app for FIN, ACK rsp*/ + TCP_CLOSING, /* Rec FIN, sent FIN, ACK waiting for ACK */ + TCP_FIN_WAIT_1, /* Sent FIN waiting for response */ + TCP_FIN_WAIT_2 /* Rec ACK from FIN sent, waiting for FIN */ +}; + +enum TCP_STATE tcp_get_tcp_state(void); +void tcp_set_tcp_state(enum TCP_STATE new_state); +int tcp_set_tcp_header(uchar *pkt, int dport, int sport, int payload_len, + u8 action, u32 tcp_seq_num, u32 tcp_ack_num); + +/* + * An incoming packet handler. + * @param pkt pointer to the application packet + * @param dport destination UDP port + * @param sip source IP address + * @param sport source UDP port + * @param len packet length + */ +typedef void rxhand_tcp(uchar *pkt, unsigned int dport, + struct in_addr sip, unsigned int sport, + unsigned int len); +void tcp_set_tcp_handler(rxhand_tcp *f); + +void rxhand_tcp_f(union tcp_build_pkt *b, unsigned int len); + +/* + * An incoming TCP packet handler for the TCP protocol. + * There is also a dynamic function pointer for TCP based commands to + * receive incoming traffic after the TCP protocol code has done its work. + */ + +void rxhand_action(u8 tcp_action, int payload_len, u32 tcp_seq_num, + u32 tcp_ack_num, unsigned int pkt_len, + union tcp_build_pkt *b); diff --git a/net/Kconfig b/net/Kconfig index f2363e5256..77ab683eb8 100644 --- a/net/Kconfig +++ b/net/Kconfig @@ -22,4 +22,10 @@ config NETCONSOLE Support the 'nc' input/output device for networked console. See README.NetConsole for details.
+config TCP + bool "TCP stack" + help + TCP protocol support with SACK for wget. Selecting this will provide + the fastest file transfer possible. + endif # if NET diff --git a/net/Makefile b/net/Makefile index 07466879f5..237023407f 100644 --- a/net/Makefile +++ b/net/Makefile @@ -24,6 +24,7 @@ obj-$(CONFIG_CMD_RARP) += rarp.o obj-$(CONFIG_CMD_SNTP) += sntp.o obj-$(CONFIG_CMD_TFTPBOOT) += tftp.o obj-$(CONFIG_UDP_FUNCTION_FASTBOOT) += fastboot.o +obj-$(CONFIG_TCP) += tcp.o
# Disable this warning as it is triggered by: # sprintf(buf, index ? "foo%d" : "foo", index) diff --git a/net/net.c b/net/net.c index f831c34599..8ac1ff050f 100644 --- a/net/net.c +++ b/net/net.c @@ -108,6 +108,7 @@ #if defined(CONFIG_CMD_SNTP) #include "sntp.h" #endif +#include <net/tcp.h>
/** BOOTP EXTENTIONS **/
@@ -380,6 +381,9 @@ void net_init(void)
/* Only need to setup buffer pointers once. */ first_call = 0; +#if defined(CONFIG_TCP) + tcp_set_tcp_state(TCP_CLOSED); +#endif }
net_init_loop(); @@ -790,6 +794,16 @@ return net_send_ip_packet(ether, dest, dport, sport, payload_len, IPPROTO_UDP, 0, 0, 0); }
+#if defined(CONFIG_TCP) +int net_send_tcp_packet(int payload_len, int dport, int sport, u8 action, + u32 tcp_seq_num, u32 tcp_ack_num) +{ + return net_send_ip_packet(net_server_ethaddr, net_server_ip, dport, + sport, payload_len, IPPROTO_TCP, action, + tcp_seq_num, tcp_ack_num); +} +#endif + int net_send_ip_packet(uchar *ether, struct in_addr dest, int dport, int sport, int payload_len, int proto, u8 action, u32 tcp_seq_num, u32 tcp_ack_num) @@ -821,6 +835,15 @@ int net_send_ip_packet(uchar *ether, struct in_addr dest, int dport, int sport, dport, sport, payload_len); pkt_hdr_size = eth_hdr_size + IP_UDP_HDR_SIZE; break; +#if defined(CONFIG_TCP) + case IPPROTO_TCP: + pkt_hdr_size = eth_hdr_size + + tcp_set_tcp_header(pkt + eth_hdr_size, dport, sport, + payload_len, action, tcp_seq_num, + tcp_ack_num); + break; +#endif + default: return -EINVAL; }
@@ -1229,6 +1252,16 @@ void net_process_received_packet(uchar *in_packet, int len) if (ip->ip_p == IPPROTO_ICMP) { receive_icmp(ip, len, src_ip, et); return; +#if defined(CONFIG_TCP) + } else if (ip->ip_p == IPPROTO_TCP) { + debug_cond(DEBUG_DEV_PKT, + "TCP PH (to=%pI4, from=%pI4, len=%d)\n", + &dst_ip, &src_ip, len); + + rxhand_tcp_f((union tcp_build_pkt *)ip, len); + return; +#endif + } else if (ip->ip_p != IPPROTO_UDP) { /* Only UDP packets */ return; } diff --git a/net/tcp.c b/net/tcp.c new file mode 100644 index 0000000000..12fa0a72cd --- /dev/null +++ b/net/tcp.c @@ -0,0 +1,700 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright 2017 Duncan Hare, all rights reserved. + */ + +/* + * General Desription: + * + * TCP support for the wget command, for fast file downloading. + * + * HTTP/TCP Receiver: + * + * Prequeisites: - own ethernet address + * - own IP address + * - Server IP address + * - Server with TCP + * - TCP application (eg wget) + * Next Step HTTPS? + */ +#include <common.h> +#include <command.h> +#include <console.h> +#include <environment.h> +#include <errno.h> +#include <net.h> +#include <net/tcp.h> + +/* + * TCP sliding window control used by us to request re-TX + */ + +static struct tcp_sack_v tcp_lost; + +/* TCP option timestamp */ +static u32 loc_timestamp; +static u32 rmt_timestamp; + +u32 tcp_seq_init; +u32 tcp_ack_edge; +u32 tcp_seq_max; + +int tcp_activity_count; + +/* + * Search for TCP_SACK and review the comments before the code section + * TCP_SACK is the number of packets at the front of the stream + */ + +enum pkt_state {PKT, NOPKT}; +struct sack_r { + struct sack_edges se; + enum pkt_state st; +}; + +struct sack_r edge_a[TCP_SACK]; +unsigned int sack_idx; +unsigned int prev_len; + +/* TCP connection state */ +static enum TCP_STATE tcp_state; + +/* + * An incoming TCP packet handler for the TCP protocol. + * There is also a dynamic function pointer for TCP based commands to + * receive incoming traffic after the TCP protocol code has done its work. + */ + +/* Current TCP RX packet handler */ +static rxhand_tcp *tcp_packet_handler; + +enum TCP_STATE tcp_get_tcp_state(void) +{ + return tcp_state; +} + +void tcp_set_tcp_state(enum TCP_STATE new_state) +{ + tcp_state = new_state; +} + +static void dummy_handler(uchar *pkt, unsigned int dport, + struct in_addr sip, unsigned int sport, + unsigned int len) +{ +} + +void tcp_set_tcp_handler(rxhand_tcp *f) +{ + debug_cond(DEBUG_INT_STATE, "--- net_loop TCP handler set (%p)\n", f); + if (!f) + tcp_packet_handler = dummy_handler; + else + tcp_packet_handler = f; +} + +u16 tcp_set_pseudo_header(uchar *pkt, struct in_addr src, struct in_addr dest, + int tcp_len, int pkt_len) +{ + union tcp_build_pkt *b = (union tcp_build_pkt *)pkt; + int checksum_len; + + /* + * Pseudo header + * + * Zero the byte after the last byte so that the header checksum + * will always work. + */ + + pkt[pkt_len] = 0x00; + + net_copy_ip((void *)&b->ph.p_src, &src); + net_copy_ip((void *)&b->ph.p_dst, &dest); + b->ph.rsvd = 0x00; + b->ph.p = IPPROTO_TCP; + b->ph.len = htons(tcp_len); + checksum_len = tcp_len + PSEUDO_HDR_SIZE; + + debug_cond(DEBUG_DEV_PKT, + "TCP Pesudo Header (to=%pI4, from=%pI4, Len=%d)\n", + &b->ph.p_dst, &b->ph.p_src, checksum_len); + + return compute_ip_checksum(pkt + PSEUDO_PAD_SIZE, checksum_len); +} + +int net_set_ack_options(union tcp_build_pkt *b) +{ + b->sack.hdr.tcp_hlen = (TCP_HDR_SIZE >> 2) << 4; + + b->sack.t_opt.kind = TCP_O_TS; + b->sack.t_opt.len = TCP_OPT_LEN_A; + b->sack.t_opt.t_snd = htons(loc_timestamp); + b->sack.t_opt.t_rcv = rmt_timestamp; + b->sack.sack_v.kind = TCP_1_NOP; + b->sack.sack_v.len = 0x00; + + if (tcp_lost.len > TCP_OPT_LEN_2) { + debug_cond(DEBUG_DEV_PKT, "TCP ack opt lost.len %x\n", + tcp_lost.len); + b->sack.sack_v.len = tcp_lost.len; + b->sack.sack_v.kind = TCP_V_SACK; + b->sack.sack_v.hill[0].l = htonl(tcp_lost.hill[0].l); + b->sack.sack_v.hill[0].r = htonl(tcp_lost.hill[0].r); + + /* + * These SACK structures are initialized with NOPs to + * provide TCP header alignment padding. There are 4 + * SACK structures used for both header padding and + * internally. + */ + + b->sack.sack_v.hill[1].l = htonl(tcp_lost.hill[1].l); + b->sack.sack_v.hill[1].r = htonl(tcp_lost.hill[1].r); + b->sack.sack_v.hill[2].l = htonl(tcp_lost.hill[2].l); + b->sack.sack_v.hill[2].r = htonl(tcp_lost.hill[2].r); + b->sack.sack_v.hill[3].l = TCP_O_NOP; + b->sack.sack_v.hill[3].r = TCP_O_NOP; + } + + /* + * TCP lengths are stored as a rounded up number of 32 bit words + * Add 3 to length round up, rounded, then divided into the length + * in 32 bit words. + */ + + b->sack.hdr.tcp_hlen = (((TCP_HDR_SIZE + TCP_TSOPT_SIZE + + tcp_lost.len + 3) >> 2) << 4); + + /* + * This returns the actual rounded up length of the + * TCP header to add to the total packet length + */ + + return b->sack.hdr.tcp_hlen >> 2; +} + +void net_set_syn_options(union tcp_build_pkt *b) +{ + tcp_lost.len = 0; + b->ip.hdr.tcp_hlen = 0xa0; + + b->ip.mss.kind = TCP_O_MSS; + b->ip.mss.len = TCP_OPT_LEN_4; + b->ip.mss.mss = htons(TCP_MSS); + b->ip.scale.kind = TCP_O_SCL; + b->ip.scale.scale = TCP_SCALE; + b->ip.scale.len = TCP_OPT_LEN_3; + b->ip.sack_p.kind = TCP_P_SACK; + b->ip.sack_p.len = TCP_OPT_LEN_2; + b->ip.t_opt.kind = TCP_O_TS; + b->ip.t_opt.len = TCP_OPT_LEN_A; + loc_timestamp = get_ticks(); + rmt_timestamp = 0x00000000; + b->ip.t_opt.t_snd = 0; + b->ip.t_opt.t_rcv = 0x00000000; + b->ip.end = TCP_O_END; +} + +int tcp_set_tcp_header(uchar *pkt, int dport, int sport, int payload_len, + u8 action, u32 tcp_seq_num, u32 tcp_ack_num) +{ + union tcp_build_pkt *b = (union tcp_build_pkt *)pkt; + int pkt_hdr_len; + int pkt_len; + int tcp_len; + +/* + * Header: 5 32 bit words. 4 bits TCP header Length, 4 bits reserved options + */ + b->ip.hdr.tcp_flags = action; + pkt_hdr_len = IP_TCP_HDR_SIZE; + b->ip.hdr.tcp_hlen = 0x50; + + switch (action) { + case TCP_SYN: + debug_cond(DEBUG_DEV_PKT, + "TCP Hdr:SYN (%pI4, %pI4, sq=%d, ak=%d)\n", + &net_server_ip, &net_ip, + tcp_seq_num, tcp_ack_num); + tcp_activity_count = 0; + net_set_syn_options(b); + tcp_seq_num = 0; + tcp_ack_num = 0; + pkt_hdr_len = IP_TCP_O_SIZE; + if (tcp_state == TCP_SYN_SENT) { /* Too many SYNs */ + action = TCP_FIN; + tcp_state = TCP_FIN_WAIT_1; + } else { + tcp_state = TCP_SYN_SENT; + } + break; + case TCP_ACK: + pkt_hdr_len = IP_HDR_SIZE + + net_set_ack_options(b); + b->ip.hdr.tcp_flags = action; + debug_cond(DEBUG_DEV_PKT, + "TCP Hdr:ACK (%pI4, %pI4, s=%d, a=%d, A=%x)\n", + &net_server_ip, &net_ip, tcp_seq_num, tcp_ack_num, + action); + break; + case TCP_FIN: + debug_cond(DEBUG_DEV_PKT, + "TCP Hdr:FIN (%pI4, %pI4, s=%d, a=%d)\n", + &net_server_ip, &net_ip, tcp_seq_num, tcp_ack_num); + payload_len = 0; + pkt_hdr_len = IP_TCP_HDR_SIZE; + tcp_state = TCP_FIN_WAIT_1; + + break; + + /* Notify connection closing */ + + case (TCP_FIN | TCP_ACK): + case ((TCP_FIN | TCP_ACK) | TCP_PUSH): + if (tcp_state == TCP_CLOSE_WAIT) + tcp_state = TCP_CLOSING; + tcp_ack_edge++; + debug_cond(DEBUG_DEV_PKT, + "TCP Hdr:FIN ACK PSH(%pI4, %pI4, s=%d, a=%d, A=%x)\n", + &net_server_ip, &net_ip, + tcp_seq_num, tcp_ack_edge, action); + /* FALLTHRU */ + default: + pkt_hdr_len = IP_HDR_SIZE + + net_set_ack_options(b); + b->ip.hdr.tcp_flags = action | TCP_PUSH | TCP_ACK; + debug_cond(DEBUG_DEV_PKT, + "TCP Hdr:dft (%pI4, %pI4, s=%d, a=%d, A=%x)\n", + &net_server_ip, &net_ip, + tcp_seq_num, tcp_ack_num, action); + } + + pkt_len = pkt_hdr_len + payload_len; + tcp_len = pkt_len - IP_HDR_SIZE; + + /* TCP Header */ + b->ip.hdr.tcp_ack = htonl(tcp_ack_edge); + b->ip.hdr.tcp_src = htons(sport); + b->ip.hdr.tcp_dst = htons(dport); + b->ip.hdr.tcp_seq = htonl(tcp_seq_num); + tcp_seq_num = tcp_seq_num + payload_len; + + /* + * TCP window size - TCP header variable tcp_win. + * Change tcp_win only if you have an understanding of network + * overrun, congestion, TCP segment sizes, TCP windows, TCP scale, + * queuing theory and packet buffering. If there are too few buffers, + * there will be data loss, recovery may work or the sending TCP, + * the server, could abort the stream transmission. + * MSS is governed by maximum Ethernet frame length. + * The number of buffers is governed by the desire to have a queue of + * full buffers to be processed at the destination to maximize + * throughput. Temporary memory use for the boot phase on modern + * SOCs is may not be considered a constraint to buffer space, if + * it is, then the u-boot tftp or nfs kernel netboot should be + * considered. + */ + + b->ip.hdr.tcp_win = htons(PKTBUFSRX * TCP_MSS >> TCP_SCALE); + + b->ip.hdr.tcp_xsum = 0x0000; + b->ip.hdr.tcp_ugr = 0x0000; + + b->ip.hdr.tcp_xsum = tcp_set_pseudo_header(pkt, net_ip, net_server_ip, + tcp_len, pkt_len); + + net_set_ip_header((uchar *)&b->ip, net_server_ip, net_ip, + pkt_len, IPPROTO_TCP); + + return pkt_hdr_len; +} + +/* + * Selective Acknowledgment (Essential for fast stream transfer) + */ + +void tcp_hole(u32 tcp_seq_num, u32 len, u32 tcp_seq_max) +{ + unsigned int idx_sack; + unsigned int sack_end = TCP_SACK - 1; + unsigned int sack_in; + unsigned int hill = 0; + enum pkt_state expect = PKT; + + u32 seq = tcp_seq_num - tcp_seq_init; + u32 hol_l = tcp_ack_edge - tcp_seq_init; + u32 hol_r = 0; + + /* Place new seq number in correct place in receive array */ + + if (prev_len == 0) + prev_len = len; + idx_sack = sack_idx + ((tcp_seq_num - tcp_ack_edge) / prev_len); + if (idx_sack < TCP_SACK) { + edge_a[idx_sack].se.l = tcp_seq_num; + edge_a[idx_sack].se.r = tcp_seq_num + len; + edge_a[idx_sack].st = PKT; + +/* + * The fin (last) packet is not the same length as data packets, and if it's + * length is recorded and used for array index calculation, calculation breaks. + */ + if (prev_len < len) + prev_len = len; + } + + debug_cond(DEBUG_DEV_PKT, + "TCP 1 seq %d, edg %d, len %d, sack_idx %d, sack_end %d\n", + seq, hol_l, len, sack_idx, sack_end); + + /* Right edge of contiguous stream, is the left edge of first hill */ + + hol_l = tcp_seq_num - tcp_seq_init; + hol_r = hol_l + len; + + tcp_lost.len = TCP_OPT_LEN_2; + + debug_cond(DEBUG_DEV_PKT, + "TCP 1 in %d, seq %d, pkt_l %d, pkt_r %d, sack_idx %d, sack_end %d\n", + idx_sack, seq, hol_l, hol_r, sack_idx, sack_end); + + for (sack_in = sack_idx; sack_in < sack_end && hill < TCP_SACK_HILLS; + sack_in++) { + switch (expect) { + case NOPKT: + switch (edge_a[sack_in].st) { + case NOPKT: + debug_cond(DEBUG_INT_STATE, "N"); + break; + case PKT: + debug_cond(DEBUG_INT_STATE, "n"); + tcp_lost.hill[hill].l = + edge_a[sack_in].se.l; + tcp_lost.hill[hill].r = + edge_a[sack_in].se.r; + expect = PKT; + break; + } + break; + case PKT: + switch (edge_a[sack_in].st) { + case NOPKT: + debug_cond(DEBUG_INT_STATE, "p"); + if (sack_in > sack_idx && + hill < TCP_SACK_HILLS) { + hill++; + tcp_lost.len += TCP_OPT_LEN_8; + } + expect = NOPKT; + break; + case PKT: + debug_cond(DEBUG_INT_STATE, "P"); + + if (tcp_ack_edge == edge_a[sack_in].se.l) { + tcp_ack_edge = edge_a[sack_in].se.r; + edge_a[sack_in].st = NOPKT; + sack_idx++; + } else { + if (hill < TCP_SACK_HILLS) + tcp_lost.hill[hill].r = + edge_a[sack_in].se.r; + if (sack_in == sack_end - 1) + tcp_lost.hill[hill].r = + edge_a[sack_in].se.r; + } + break; + } + break; + } + } + debug_cond(DEBUG_INT_STATE, "\n"); + if (tcp_lost.len <= TCP_OPT_LEN_2) + sack_idx = 0; +} + +void tcp_parse_options(uchar *o, int o_len) +{ + struct tcp_t_opt *tsopt; + uchar *p = o; +/* + * NOPs are options with a zero length, and thus are special. + * All other options have length fields. + */ + + for (p = o; p < (o + o_len); p = p + p[1]) { + if (p[1] != 0) { + switch (p[0]) { + case TCP_O_END: + return; /* Finished processing options */ + case TCP_O_MSS: + case TCP_O_SCL: + case TCP_P_SACK: + case TCP_V_SACK: + break; /* Continue to process options */ + case TCP_O_TS: + tsopt = (struct tcp_t_opt *)p; + rmt_timestamp = tsopt->t_snd; + return; + break; + } /* End switch, process optional NOPs */ + + if (p[0] == TCP_O_NOP) + p++; + } else { + return; /* Finished processing options */ + } + } +} + +u8 tcp_state_machine(u8 tcp_flags, u32 *tcp_seq_num, int payload_len) +{ + u8 tcp_fin = tcp_flags & TCP_FIN; + u8 tcp_syn = tcp_flags & TCP_SYN; + u8 tcp_rst = tcp_flags & TCP_RST; + u8 tcp_push = tcp_flags & TCP_PUSH; + u8 tcp_ack = tcp_flags & TCP_ACK; + u8 action = TCP_DATA; + int i; + + /* + * tcp_flags are examined to determine TX action in a given state + * tcp_push is interpreted to mean "inform the app" + * urg, ece, cer and nonce flags are not supported. + * + * exe and crw are use to signal and confirm knowledge of congestion. + * This TCP only sends a file request and acks. If it generates + * congestion, the network is broken. + */ + + debug_cond(DEBUG_INT_STATE, "TCP STATE ENTRY %x\n", action); + if (tcp_rst) { + action = TCP_DATA; + tcp_state = TCP_CLOSED; + net_set_state(NETLOOP_FAIL); + debug_cond(DEBUG_INT_STATE, "TCP Reset %x\n", tcp_flags); + return TCP_RST; + } + + switch (tcp_state) { + case TCP_CLOSED: + debug_cond(DEBUG_INT_STATE, "TCP CLOSED %x\n", tcp_flags); + if (tcp_fin) + action = TCP_DATA; + if (tcp_syn) + action = TCP_RST; + if (tcp_ack) + action = TCP_DATA; + break; + case TCP_SYN_SENT: + debug_cond(DEBUG_INT_STATE, "TCP_SYN_SENT %x, %d\n", + tcp_flags, *tcp_seq_num); + if (tcp_fin) { + action = action | TCP_PUSH; + tcp_state = TCP_CLOSE_WAIT; + } + if (tcp_syn) { + action = action | TCP_ACK | TCP_PUSH; + if (tcp_ack) { + tcp_seq_init = *tcp_seq_num; + *tcp_seq_num = *tcp_seq_num + 1; + tcp_seq_max = *tcp_seq_num; + tcp_ack_edge = *tcp_seq_num; + sack_idx = 0; + edge_a[sack_idx].se.l = *tcp_seq_num; + edge_a[sack_idx].se.r = *tcp_seq_num; + prev_len = 0; + tcp_state = TCP_ESTABLISHED; + for (i = 0; i < TCP_SACK; i++) + edge_a[i].st = NOPKT; + } + } else { + if (tcp_ack) + action = TCP_DATA; + } + break; + case TCP_ESTABLISHED: + debug_cond(DEBUG_INT_STATE, + "TCP_ESTABLISHED %x\n", tcp_flags); + if (*tcp_seq_num > tcp_seq_max) + tcp_seq_max = *tcp_seq_num; + if (payload_len > 0) { + tcp_hole(*tcp_seq_num, payload_len, tcp_seq_max); + tcp_fin = TCP_DATA; /* cause standalone FIN */ + } + + if ((tcp_fin) && tcp_lost.len <= TCP_OPT_LEN_2) { + action = action | TCP_FIN | TCP_PUSH | TCP_ACK; + tcp_state = TCP_CLOSE_WAIT; + } else { + if (tcp_ack) + action = TCP_DATA; + } + if (tcp_push) + action = action | TCP_PUSH; + if (tcp_syn) + action = TCP_ACK + TCP_RST; + break; + case TCP_CLOSE_WAIT: + debug_cond(DEBUG_INT_STATE, "TCP_CLOSE_WAIT (%x)\n", tcp_flags); + action = TCP_DATA; /* Wait for app */ + break; + case TCP_FIN_WAIT_2: + debug_cond(DEBUG_INT_STATE, "TCP_FIN_WAIT_2 (%x)\n", tcp_flags); + if (tcp_fin) + action = TCP_DATA; + if (tcp_syn) + action = TCP_DATA; + if (tcp_ack) { + action = TCP_PUSH | TCP_ACK; + tcp_state = TCP_CLOSED; + puts("\n"); + } + break; + case TCP_FIN_WAIT_1: + debug_cond(DEBUG_INT_STATE, "TCP_FIN_WAIT_1 (%x)\n", tcp_flags); + if (tcp_fin) { + action = TCP_ACK | TCP_FIN; + tcp_state = TCP_FIN_WAIT_2; + } + if (tcp_syn) + action = TCP_RST; + if (tcp_ack) { + tcp_state = TCP_CLOSED; + tcp_seq_num = tcp_seq_num + 1; + } + break; + case TCP_CLOSING: + debug_cond(DEBUG_INT_STATE, "TCP_CLOSING (%x)\n", tcp_flags); + if (tcp_fin) + action = TCP_DATA; + if (tcp_syn) + action = TCP_RST; + if (tcp_ack) { + action = TCP_PUSH; + tcp_state = TCP_CLOSED; + puts("\n"); + } + break; + } + return action; +} + +void rxhand_tcp_f(union tcp_build_pkt *b, unsigned int pkt_len) +{ + int tcp_len = pkt_len - IP_HDR_SIZE; + u16 tcp_rx_xsum = b->ip.hdr.ip_sum; + u8 tcp_action = TCP_DATA; + u32 tcp_seq_num; + u32 tcp_ack_num; + struct in_addr action_and_state; + + int tcp_hdr_len; + int payload_len; + + /* + * Verify IP header + */ + debug_cond(DEBUG_DEV_PKT, + "TCP RX in RX Sum (to=%pI4, from=%pI4, len=%d)\n", + &b->ip.hdr.ip_src, &b->ip.hdr.ip_dst, pkt_len); + + debug_cond(DEBUG_DEV_PKT, + "In__________________________________________\n"); + + b->ip.hdr.ip_src = net_server_ip; + b->ip.hdr.ip_dst = net_ip; + b->ip.hdr.ip_sum = 0x0000; + if (tcp_rx_xsum != compute_ip_checksum(b, IP_HDR_SIZE)) { + debug_cond(DEBUG_DEV_PKT, + "TCP RX IP xSum Error (%pI4, =%pI4, len=%d)\n", + &net_ip, &net_server_ip, pkt_len); + return; + } + + /* + * Build pseudo header and verify TCP header + */ + tcp_rx_xsum = b->ip.hdr.tcp_xsum; + b->ip.hdr.tcp_xsum = 0x0000; + if (tcp_rx_xsum != tcp_set_pseudo_header((uchar *)b, b->ip.hdr.ip_src, + b->ip.hdr.ip_dst, tcp_len, + pkt_len)) { + debug_cond(DEBUG_DEV_PKT, + "TCP RX TCP xSum Error (%pI4, %pI4, len=%d)\n", + &net_ip, &net_server_ip, tcp_len); + return; + } + + tcp_hdr_len = (b->ip.hdr.tcp_hlen >> 2); + payload_len = tcp_len - tcp_hdr_len; + + if (tcp_hdr_len > TCP_HDR_SIZE) + tcp_parse_options((uchar *)b + IP_TCP_HDR_SIZE, + tcp_hdr_len - TCP_HDR_SIZE); + /* + * Incoming sequence and ack numbers are server's view of the numbers. + * The app must swap the numbers when responding. + */ + + tcp_seq_num = ntohl(b->ip.hdr.tcp_seq); + tcp_ack_num = ntohl(b->ip.hdr.tcp_ack); + + /* Packets are not ordered. Send to app as received. */ + + tcp_action = tcp_state_machine(b->ip.hdr.tcp_flags, + &tcp_seq_num, payload_len); + + /* + * State-altering command to be sent. + * The packet sequence and ack numbers are in the tcp_seq_num + * and tcp_ack_num variables. The current packet, its position + * in the data stream, is the in the range of those variables. + * + * In the "application push" invocation, the TCP header with all + * its information is pointed to by the packet pointer. + * + * In the typedef + * void rxhand_tcp(uchar *pkt, unsigned int dport, + * struct in_addr sip, unsigned int sport, + * unsigned int len); + * *pkt is the pointer to the payload + * dport is used for tcp_seg_num + * action_and_state.s_addr is used for TCP state + * sport is used for tcp_ack_num (which is unused by the app) + * pkt_ length is the payload length. + * + * TCP_PUSH from the state machine with a payload length of 0 is a + * connect or disconnect event + */ + + tcp_activity_count++; + if (tcp_activity_count > TCP_ACTIVITY) { + puts("| "); + tcp_activity_count = 0; + } + + if ((tcp_action & TCP_PUSH) || payload_len > 0) { + debug_cond(DEBUG_DEV_PKT, + "TCP Notify (action=%x, Seq=%d,Ack=%d,Pay%d)\n", + tcp_action, tcp_seq_num, tcp_ack_num, payload_len); + + action_and_state.s_addr = tcp_action; + (*tcp_packet_handler) ((uchar *)b + pkt_len - payload_len, + tcp_seq_num, action_and_state, + tcp_ack_num, payload_len); + + } else if (tcp_action != TCP_DATA) { + debug_cond(DEBUG_DEV_PKT, + "TCP Action (action=%x,Seq=%d,Ack=%d,Pay=%d)\n", + tcp_action, tcp_seq_num, tcp_ack_num, payload_len); + + /* + * Warning: Incoming Ack & Seq sequence numbers are transposed + * here to outgoing Seq & Ack sequence numbers + */ + net_send_tcp_packet(0, ntohs(b->ip.hdr.tcp_src), + ntohs(b->ip.hdr.tcp_dst), + (tcp_action & (~TCP_PUSH)), + tcp_seq_num, tcp_ack_num); + } +}
Am Mo., 25. Juni 2018 um 00:42 Uhr schrieb DH@synoia.com:
Series-Changes 11
- Add TCP with SACK
- Clean formatting
Series-Changes 12
- Transmit "net_tx_packet" as UDP packet, performing ARP request if needed
- Transmit "net_tx_packet" as UDP or TCPpacket, send ARP request if needed
missing space - should be * Transmit "net_tx_packet" as UDP or TCP packet, send ARP request if needed
- (ether will be populated)
- @param ether Raw packet buffer
- @param dport Destination UDP port
- @param sport Source UDP port
- @param payload_len Length of data after the UDP header
- @param action TCP action to be performed
- @param tcp_seq_num TCP sequence number of this transmission
- @param tcp_ack_num TCP stream acknolegement number
- TCP Support with SACK for file transfer.
- Copyright 2017 Duncan Hare, All rights reserved.
+} __packed;
- TCP header options, Seq, MSS, and SACK
- Please review the warning in net.c about these two parameters.
- They are part of a promise of RX buffer size to the sending TCP
+} __packed;
extra empty line needed?
+} __packed;
+} __packed;
/* length linits */
wrong/funny indentation?
+} __packed;
- A TCP stream has holes when packets are missing or disordered.
- A hill is the inverese of a hole, and is data received.
Should be A hill is the inverse of a ..
- TCP receiveds hills (a sequence of data), and inferrs Holes
Should be TCP received hills ..
- from the "hills" or packets received.
+} __packed;
+} __packed;
- ip tcp structure with options
struct tcp_mss mss;
u8 end;
+} __packed;
u8 end;
+} __packed;
- TCP pseudo header definitions
u8 rsvd;
u8 p;
u16 len;
+} __packed;
- union for building TCP/IP packet. Build Pseudo header in packed buffer
- first, calculate TCP checksum, then build IP header in packed buffer.
uchar raw[1600];
+} __packed;
- TCP State machine states for connection
+enum TCP_STATE {
- An incoming packet handler.
- @param pkt pointer to the application packet
- @param dport destination UDP port
- @param sip source IP address
- @param sport source UDP port
- @param len packet length
unsigned int len);
- An incoming TCP packet handler for the TCP protocol.
- There is also a dynamic function pointer for TCP based commands to
- receive incoming traffic after the TCP protocol code has done its work.
+config TCP
bool "TCP stack"
help
+#endif }
net_init_loop();
+} +#endif
case IPPROTO_TCP:
tcp_ack_num);
break;
return;
- Copyright 2017 Duncan Hare, all rights reserved.
- General Desription:
- TCP support for the wget command, for fast file downloading.
- HTTP/TCP Receiver:
Should be * Prerequisites: - own ethernet address
- own IP address
- Server IP address
- Server with TCP
Next Step HTTPS?
- TCP sliding window control used by us to request re-TX
- Search for TCP_SACK and review the comments before the code section
- TCP_SACK is the number of packets at the front of the stream
enum pkt_state st;
return tcp_state;
unsigned int len)
if (!f)
else
int checksum_len;
* Pseudo header
* will always work.
b->ph.rsvd = 0x00;
tcp_lost.len);
* internally.
* in 32 bit words.
tcp_lost.len = 0;
int pkt_hdr_len;
int pkt_len;
int tcp_len;
- Header: 5 32 bit words. 4 bits TCP header Length, 4 bits reserved options
switch (action) {
case TCP_SYN:
tcp_seq_num = 0;
tcp_ack_num = 0;
action = TCP_FIN;
} else {
break;
case TCP_ACK:
Do we need the extraces spaes before = and do we need to move net_set_ack_options(..) to next line?
action);
break;
case TCP_FIN:
payload_len = 0;
break;
tcp_ack_edge++;
/* FALLTHRU */
default:
/* TCP Header */
* considered.
tcp_len, pkt_len);
return pkt_hdr_len;
- Selective Acknowledgment (Essential for fast stream transfer)
u32 hol_r = 0;
if (prev_len == 0)
prev_len = len;
- The fin (last) packet is not the same length as data packets, and if it's
- length is recorded and used for array index calculation, calculation breaks.
if (prev_len < len)
prev_len = len;
sack_in++) {
switch (expect) {
case NOPKT:
case NOPKT:
break;
case PKT:
expect = PKT;
break;
break;
case PKT:
case NOPKT:
hill++;
expect = NOPKT;
break;
case PKT:
sack_idx++;
} else {
break;
break;
sack_idx = 0;
uchar *p = o;
if (p[1] != 0) {
switch (p[0]) {
case TCP_O_END:
case TCP_O_MSS:
case TCP_O_SCL:
case TCP_P_SACK:
case TCP_V_SACK:
case TCP_O_TS:
return;
break;
p++;
} else {
int i;
if (tcp_rst) {
action = TCP_DATA;
return TCP_RST;
case TCP_CLOSED:
if (tcp_fin)
action = TCP_DATA;
if (tcp_syn)
action = TCP_RST;
if (tcp_ack)
action = TCP_DATA;
break;
case TCP_SYN_SENT:
if (tcp_fin) {
if (tcp_syn) {
if (tcp_ack) {
sack_idx = 0;
prev_len = 0;
} else {
if (tcp_ack)
action = TCP_DATA;
break;
} else {
if (tcp_ack)
action = TCP_DATA;
if (tcp_push)
if (tcp_syn)
break;
break;
if (tcp_fin)
action = TCP_DATA;
if (tcp_syn)
action = TCP_DATA;
if (tcp_ack) {
puts("\n");
break;
if (tcp_fin) {
if (tcp_syn)
action = TCP_RST;
if (tcp_ack) {
break;
case TCP_CLOSING:
if (tcp_fin)
action = TCP_DATA;
if (tcp_syn)
action = TCP_RST;
if (tcp_ack) {
action = TCP_PUSH;
puts("\n");
break;
return action;
u32 tcp_seq_num;
u32 tcp_ack_num;
int tcp_hdr_len;
int payload_len;
* Verify IP header
return;
pkt_len)) {
return;
* In the typedef
puts("| ");
Overall this does not look too bad - hopefully it will land during this year.
Commit-notes All the code is new, and not copied from any source
Test wget
wget is a general purpose TCP/IP program. There is a Linux/unix version of wget, which enables server verification without running u-boot.
1. The python distribution include a simple http request handler. To use it with u-boot and Linux wget start the python server in the directory which contains your test files.
sudo python -m SimplleHTTPServer 80
sudo becuse the port number used is lower than 1,000. Leave this window open.
Then test the server, in a directory different from your directory containing test file, assuming a test file named "test file.name" at a Linux command prompt enter:
wget localhost/testfile.name
and the file should be transferred to the receiving directory.
The server verification is now complete.
2. wget in u-boot needs a load address, server ip address, an ip address, optional file path, and file name.
The server and u-boot ip address can be 127.0.0.1. The routing is then between the u-boot test environment and the server in the same machine.
u-boot script example
env set ipaddr 127.0.0.1; env set loadaddr 0x8000000; wget 127.0.0.1 testfile.name
or
env set ipaddr 127.0.0.1; env set loadaddr 0x8000000; wget 127.0.0.1 pathname/testfile.name
wget prints a progress "|" every 127 packets, and at the end of transfer prints a message of success or fail, and bytes transferred.
When testing u-boot, we first did a large file transfer with wget and then modified tftp to download the same file and verify wget's transfer was both complete and correct, with a strcmp function replacing the copy to kernel area code fragment. END
Cover-letter Add TCP and WGET This is a limited implementation of a TCP, a receiver, with selective acknowledgment (SACK), and wget as a transfer protocol over TCP.
TCP with SACK provides maximum transfer rates over fast and fast multi-hop networks. TCP continues stream transfer if packets are dropped, and then recoveres dropped packed asynchronously.
WGET is a very efficient file transfer protocol running over TCP. There is a single request for each file transferred, irrespective of file size. END
cmd/Kconfig | 7 + cmd/net.c | 13 ++ include/net.h | 2 +- include/net/wget.h | 19 +++ net/Makefile | 2 +- net/net.c | 9 +- net/wget.c | 426 +++++++++++++++++++++++++++++++++++++++++++++++++++++ 7 files changed, 475 insertions(+), 3 deletions(-) create mode 100644 include/net/wget.h create mode 100644 net/wget.c
diff --git a/cmd/Kconfig b/cmd/Kconfig index 45c83359ad..fb9c894363 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1192,6 +1192,13 @@ config CMD_NFS help Boot image via network using NFS protocol.
+config CMD_WGET + bool "wget" + select TCP + help + Download kernel, or other files, from a web server over TCP. + Fast file transfer over networks with latenc + config CMD_MII bool "mii" help diff --git a/cmd/net.c b/cmd/net.c index f83839c35e..f5fde849c4 100644 --- a/cmd/net.c +++ b/cmd/net.c @@ -113,6 +113,19 @@ U_BOOT_CMD( ); #endif
+#if defined(CONFIG_CMD_WGET) +static int do_wget(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + return netboot_common(WGET, cmdtp, argc, argv); +} + +U_BOOT_CMD( + wget, 3, 1, do_wget, + "boot image via network using HTTP protocol", + "[loadAddress] [[hostIPaddr:]path and image name]" +); +#endif + static void netboot_update_env(void) { char tmp[22]; diff --git a/include/net.h b/include/net.h index ba96267eb8..14b013083d 100644 --- a/include/net.h +++ b/include/net.h @@ -539,7 +539,7 @@ extern int net_restart_wrap; /* Tried all network devices */
enum proto_t { BOOTP, RARP, ARP, TFTPGET, DHCP, PING, DNS, NFS, CDP, NETCONS, SNTP, - TFTPSRV, TFTPPUT, LINKLOCAL, FASTBOOT + TFTPSRV, TFTPPUT, LINKLOCAL, FASTBOOT, WGET };
extern char net_boot_file_name[1024];/* Boot File name */ diff --git a/include/net/wget.h b/include/net/wget.h new file mode 100644 index 0000000000..61bdd851f9 --- /dev/null +++ b/include/net/wget.h @@ -0,0 +1,19 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Duncan Hare Copyright 2017 + */ + +void wget_start(void); /* Begin wget */ + +enum WGET_STATE { + WGET_CLOSED, + WGET_CONNECTING, + WGET_CONNECTED, + WGET_TRANSFERRING, + WGET_TRANSFERRED +}; + +#define DEBUG_WGET 0 /* Set to 1 for debug messges */ +#define SERVER_PORT 80 +#define WGET_RETRY_COUNT 30 +#define WGET_TIMEOUT 2000UL diff --git a/net/Makefile b/net/Makefile index 237023407f..882af145aa 100644 --- a/net/Makefile +++ b/net/Makefile @@ -23,8 +23,8 @@ obj-$(CONFIG_CMD_PING) += ping.o obj-$(CONFIG_CMD_RARP) += rarp.o obj-$(CONFIG_CMD_SNTP) += sntp.o obj-$(CONFIG_CMD_TFTPBOOT) += tftp.o -obj-$(CONFIG_UDP_FUNCTION_FASTBOOT) += fastboot.o obj-$(CONFIG_TCP) += tcp.o +obj-$(CONFIG_CMD_WGET) += wget.o
# Disable this warning as it is triggered by: # sprintf(buf, index ? "foo%d" : "foo", index) diff --git a/net/net.c b/net/net.c index 8ac1ff050f..39707d5b18 100644 --- a/net/net.c +++ b/net/net.c @@ -109,6 +109,7 @@ #include "sntp.h" #endif #include <net/tcp.h> +#include <net/wget.h>
@@ -494,6 +495,11 @@ restart: nfs_start(); break; #endif +#if defined(CONFIG_CMD_WGET) + case WGET: + wget_start(); + break; +#endif #if defined(CONFIG_CMD_CDP) case CDP: cdp_start(); @@ -1540,7 +1546,8 @@ void copy_filename(char *dst, const char *src, int size)
#if defined(CONFIG_CMD_NFS) || \ defined(CONFIG_CMD_SNTP) || \ - defined(CONFIG_CMD_DNS) + defined(CONFIG_CMD_DNS) || \ + defined(CONFIG_CMD_WGET) /* * make port a little random (1024-17407) * This keeps the math somewhat trivial to compute, and seems to work with diff --git a/net/wget.c b/net/wget.c new file mode 100644 index 0000000000..8238ec52c4 --- /dev/null +++ b/net/wget.c @@ -0,0 +1,426 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * WGET/HTTP support driver based on U-BOOT's nfs.c + * Copyright Duncan Hare dh@synoia.com 2017 + */ + +#include <common.h> +#include <command.h> +#include <mapmem.h> +#include <net.h> +#include <net/wget.h> +#include <net/tcp.h> + +const char bootfile1[] = "GET "; +const char bootfile3[] = " HTTP/1.0\r\n\r\n"; +const char http_eom[] = "\r\n\r\n"; +const char http_ok[] = "200"; +const char content_len[] = "Content-Length"; +const char linefeed[] = "\r\n"; +static struct in_addr web_server_ip; +static int our_port; +static int wget_timeout_count; + +struct pkt_qd { + uchar *pkt; + unsigned int tcp_seq_num; + unsigned int len; +}; + +/* + * This is a control structure for out of order packets received. + * The actual packet bufers are in the kernel space, and are + * expected to be overwritten by the downloaded image. + */ + +static struct pkt_qd pkt_q[PKTBUFSRX / 4]; +static int pkt_q_idx; +static unsigned long content_length; +static unsigned int packets; + +static unsigned int initial_data_seq_num; + +static enum WGET_STATE wget_state; + +static char *image_url; +static unsigned int wget_timeout = WGET_TIMEOUT; + +static void wget_timeout_handler(void); + +static enum net_loop_state wget_loop_state; + +/* Timeout retry parameters */ +static u8 retry_action; +static unsigned int retry_tcp_ack_num; +static unsigned int retry_tcp_seq_num; +static int retry_len; + +static inline int store_block(uchar *src, unsigned int offset, unsigned int len) +{ + ulong newsize = offset + len; + uchar *ptr; + +#ifdef CONFIG_SYS_DIRECT_FLASH_WGET + int i, rc = 0; + + for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; i++) { + /* start address in flash? */ + if (load_addr + offset >= flash_info[i].start[0]) { + rc = 1; + break; + } + } + + if (rc) { /* Flash is destination for this packet */ + rc = flash_write((uchar *)src, + (ulong)(load_addr + offset), len); + if (rc) { + flash_perror(rc); + return -1; + } + } else { +#endif /* CONFIG_SYS_DIRECT_FLASH_WGET */ + + ptr = map_sysmem(load_addr + offset, len); + memcpy(ptr, src, len); + unmap_sysmem(ptr); + +#ifdef CONFIG_SYS_DIRECT_FLASH_WGET + } +#endif + if (net_boot_file_size < (offset + len)) + net_boot_file_size = newsize; + return 0; +} + +/* + * wget response dispatcher + * WARNING, This, and only this, is the place in wget.c where + * SEQUENCE NUMBERS are swapped between incoming (RX) + * and outgoing (TX). + * Procedure wget_handler() is correct for RX traffic. + */ +static void wget_send_stored(void) +{ + u8 action = retry_action; + unsigned int tcp_ack_num = retry_tcp_ack_num; + unsigned int tcp_seq_num = retry_tcp_seq_num; + int len = retry_len; + uchar *ptr; + uchar *offset; + + tcp_ack_num = tcp_ack_num + len; + + switch (wget_state) { + case WGET_CLOSED: + debug_cond(DEBUG_WGET, "wget: send SYN\n"); + wget_state = WGET_CONNECTING; + net_send_tcp_packet(0, SERVER_PORT, our_port, action, + tcp_seq_num, tcp_ack_num); + packets = 0; + break; + case WGET_CONNECTING: + pkt_q_idx = 0; + net_send_tcp_packet(0, SERVER_PORT, our_port, action, + tcp_seq_num, tcp_ack_num); + + ptr = net_tx_packet + net_eth_hdr_size() + + IP_TCP_HDR_SIZE + TCP_TSOPT_SIZE + 2; + offset = ptr; + + memcpy(offset, &bootfile1, strlen(bootfile1)); + offset = offset + strlen(bootfile1); + + memcpy(offset, image_url, strlen(image_url)); + offset = offset + strlen(image_url); + + memcpy(offset, &bootfile3, strlen(bootfile3)); + offset = offset + strlen(bootfile3); + net_send_tcp_packet((offset - ptr), SERVER_PORT, our_port, + TCP_PUSH, tcp_seq_num, tcp_ack_num); + wget_state = WGET_CONNECTED; + break; + case WGET_CONNECTED: + case WGET_TRANSFERRING: + case WGET_TRANSFERRED: + net_send_tcp_packet(0, SERVER_PORT, our_port, action, + tcp_seq_num, tcp_ack_num); + break; + } +} + +static void wget_send(u8 action, unsigned int tcp_ack_num, + unsigned int tcp_seq_num, int len) +{ + retry_action = action; + retry_tcp_ack_num = tcp_ack_num; + retry_tcp_seq_num = tcp_seq_num; + retry_len = len; + wget_send_stored(); +} + +void wget_fail(char *error_message, unsigned int tcp_seq_num, + unsigned int tcp_ack_num, u8 action) +{ + printf("%s", error_message); + printf("%s", "wget: Transfer Fail\n"); + net_set_timeout_handler(0, NULL); + wget_send(action, tcp_seq_num, tcp_ack_num, 0); +} + +void wget_success(u8 action, unsigned int tcp_seq_num, + unsigned int tcp_ack_num, int len, int packets) +{ + printf("Packets received %d, Transfer Successful\n", packets); + wget_send(action, tcp_seq_num, tcp_ack_num, len); +} + +/* + * Interfaces of U-BOOT + */ +static void wget_timeout_handler(void) +{ + if (++wget_timeout_count > WGET_RETRY_COUNT) { + puts("\nRetry count exceeded; starting again\n"); + wget_send(TCP_RST, 0, 0, 0); + net_start_again(); + } else { + puts("T "); + net_set_timeout_handler(wget_timeout + + WGET_TIMEOUT * wget_timeout_count, + wget_timeout_handler); + wget_send_stored(); + } +} + +static void wget_connected(uchar *pkt, unsigned int tcp_seq_num, + struct in_addr action_and_state, + unsigned int tcp_ack_num, unsigned int len) +{ + u8 action = action_and_state.s_addr; + uchar *pkt_in_q; + char *pos; + int hlen; + int i; + + pkt[len] = '\0'; + pos = strstr((char *)pkt, http_eom); + + if (pos == 0) { + debug_cond(DEBUG_WGET, + "wget: Connected, data before Header %p\n", pkt); + pkt_in_q = (void *)load_addr + 0x20000 + (pkt_q_idx * 0x800); + memcpy(pkt_in_q, pkt, len); + pkt_q[pkt_q_idx].pkt = pkt_in_q; + pkt_q[pkt_q_idx].tcp_seq_num = tcp_seq_num; + pkt_q[pkt_q_idx].len = len; + pkt_q_idx++; + } else { + debug_cond(DEBUG_WGET, "wget: Connected HTTP Header %p\n", pkt); + hlen = pos - (char *)pkt + sizeof(http_eom) - 1; + pos = strstr((char *)pkt, linefeed); + if (pos > 0) + i = pos - (char *)pkt; + else + i = hlen; + printf("%.*s", i, pkt); + + wget_state = WGET_TRANSFERRING; + + if (strstr((char *)pkt, http_ok) == 0) { + debug_cond(DEBUG_WGET, + "wget: Connected Bad Xfer\n"); + wget_loop_state = NETLOOP_FAIL; + wget_send(action, tcp_seq_num, tcp_ack_num, len); + } else { + debug_cond(DEBUG_WGET, + "wget: Connctd pkt %p hlen %x\n", + pkt, hlen); + initial_data_seq_num = tcp_seq_num + hlen; + + pos = strstr((char *)pkt, content_len); + if (!pos) { + content_length = -1; + } else { + pos = pos + sizeof(content_len) + 2; + strict_strtoul(pos, 10, &content_length); + debug_cond(DEBUG_WGET, + "wget: Connected Len %lu\n", + content_length); + } + + net_boot_file_size = 0; + + if (len > hlen) + store_block(pkt + hlen, 0, len - hlen); + debug_cond(DEBUG_WGET, + "wget: Connected Pkt %p hlen %x\n", + pkt, hlen); + + for (i = 0; i < pkt_q_idx; i++) { + store_block(pkt_q[i].pkt, + pkt_q[i].tcp_seq_num - + initial_data_seq_num, + pkt_q[i].len); + debug_cond(DEBUG_WGET, + "wget: Connctd pkt Q %p len %x\n", + pkt_q[i].pkt, pkt_q[i].len); + } + } + } + wget_send(action, tcp_seq_num, tcp_ack_num, len); +} + + /* + * In the "application push" invocation, the TCP header with all + * its information is pointed to by the packet pointer. + * + * in the typedef + * void rxhand_tcp(uchar *pkt, unsigned int dport, + * struct in_addr sip, unsigned int sport, + * unsigned int len); + * *pkt is the pointer to the payload + * dport is used for tcp_seg_num + * action_and_state.s_addr is used for TCP state + * sport is used for tcp_ack_num (which is unused by the app) + * pkt_ length is the payload length. + */ +static void wget_handler(uchar *pkt, unsigned int tcp_seq_num, + struct in_addr action_and_state, + unsigned int tcp_ack_num, unsigned int len) +{ + enum TCP_STATE wget_tcp_state = tcp_get_tcp_state(); + u8 action = action_and_state.s_addr; + + net_set_timeout_handler(wget_timeout, wget_timeout_handler); + packets++; + + switch (wget_state) { + case WGET_CLOSED: + debug_cond(DEBUG_WGET, "wget: Handler: Error!, State wrong\n"); + break; + case WGET_CONNECTING: + debug_cond(DEBUG_WGET, + "wget: Connecting In len=%x, Seq=%x, Ack=%x\n", + len, tcp_seq_num, tcp_ack_num); + if (len == 0) { + if (wget_tcp_state == TCP_ESTABLISHED) { + debug_cond(DEBUG_WGET, + "wget: Cting, send, len=%x\n", len); + wget_send(action, tcp_seq_num, tcp_ack_num, + len); + } else { + printf("%.*s", len, pkt); + wget_fail("wget: Handler Connected Fail\n", + tcp_seq_num, tcp_ack_num, action); + } + } + break; + case WGET_CONNECTED: + debug_cond(DEBUG_WGET, "wget: Connected seq=%x, len=%x\n", + tcp_seq_num, len); + if (len == 0) { + wget_fail("Image not found, no data returned\n", + tcp_seq_num, tcp_ack_num, action); + } else { + wget_connected(pkt, tcp_seq_num, action_and_state, + tcp_ack_num, len); + } + break; + case WGET_TRANSFERRING: + debug_cond(DEBUG_WGET, + "wget: Transferring, seq=%x, ack=%x,len=%x\n", + tcp_seq_num, tcp_ack_num, len); + + if (store_block(pkt, + tcp_seq_num - initial_data_seq_num, len) != 0) { + wget_fail("wget: store error\n", + tcp_seq_num, tcp_ack_num, action); + return; + } + + switch (wget_tcp_state) { + case TCP_FIN_WAIT_2: + wget_send(TCP_ACK, tcp_seq_num, tcp_ack_num, len); + case TCP_SYN_SENT: + case TCP_CLOSING: + case TCP_FIN_WAIT_1: + case TCP_CLOSED: + net_set_state(NETLOOP_FAIL); + break; + case TCP_ESTABLISHED: + wget_send(TCP_ACK, tcp_seq_num, tcp_ack_num, + len); + wget_loop_state = NETLOOP_SUCCESS; + break; + case TCP_CLOSE_WAIT: /* End of transfer */ + wget_state = WGET_TRANSFERRED; + wget_send(action | TCP_ACK | TCP_FIN, + tcp_seq_num, tcp_ack_num, len); + break; + } + break; + case WGET_TRANSFERRED: + printf("Packets received %d, Transfer Successful\n", packets); + net_set_state(wget_loop_state); + break; + } +} + +void wget_start(void) +{ + debug_cond(DEBUG_WGET, "%s\n", __func__); + + image_url = strchr(net_boot_file_name, ':'); + if (image_url > 0) { + web_server_ip = string_to_ip(net_boot_file_name); + ++image_url; + } else { + web_server_ip = net_server_ip; + image_url = net_boot_file_name; + } + + debug_cond(DEBUG_WGET, + "wget: Transfer HTTP Server %pI4; our IP %pI4\n", + &web_server_ip, &net_ip); + + /* Check if we need to send across this subnet */ + if (net_gateway.s_addr && net_netmask.s_addr) { + struct in_addr our_net; + struct in_addr server_net; + + our_net.s_addr = net_ip.s_addr & net_netmask.s_addr; + server_net.s_addr = net_server_ip.s_addr & net_netmask.s_addr; + if (our_net.s_addr != server_net.s_addr) + debug_cond(DEBUG_WGET, + "wget: sending through gateway %pI4", + &net_gateway); + } + debug_cond(DEBUG_WGET, "URL '%s\n", image_url); + + if (net_boot_file_expected_size_in_blocks) { + debug_cond(DEBUG_WGET, "wget: Size is 0x%x Bytes = ", + net_boot_file_expected_size_in_blocks << 9); + print_size(net_boot_file_expected_size_in_blocks << 9, ""); + } + debug_cond(DEBUG_WGET, + "\nwget:Load address: 0x%lx\nLoading: *\b", load_addr); + + net_set_timeout_handler(wget_timeout, wget_timeout_handler); + tcp_set_tcp_handler(wget_handler); + + wget_timeout_count = 0; + wget_state = WGET_CLOSED; + + our_port = random_port(); + + /* + * Zero out server ether to forece apr resolution in case + * the server ip for the previous u-boot commsnd, for exanple dns + * is not the same as the web server ip. + */ + + memset(net_server_ethaddr, 0, 6); + + wget_send(TCP_SYN, 0, 0, 0); +}
Test wget
- The python distribution include a simple http request handler.
- wget in u-boot needs a load address, server ip address, an ip
or
+config CMD_WGET
bool "wget"
select TCP
help
+U_BOOT_CMD(
+); +#endif
- Duncan Hare Copyright 2017
+enum WGET_STATE {
WGET_CLOSED,
WGET_CONNECTING,
WGET_CONNECTED,
WGET_TRANSFERRING,
WGET_TRANSFERRED
case WGET:
wget_start();
break;
- make port a little random (1024-17407)
- This keeps the math somewhat trivial to compute, and seems to work with
- WGET/HTTP support driver based on U-BOOT's nfs.c
- Copyright Duncan Hare dh@synoia.com 2017
Make all of them static const char ... ?
+struct pkt_qd {
uchar *pkt;
unsigned int len;
- This is a control structure for out of order packets received.
- The actual packet bufers are in the kernel space, and are
- expected to be overwritten by the downloaded image.
uchar *ptr;
int i, rc = 0;
rc = 1;
break;
if (rc) {
flash_perror(rc);
return -1;
} else {
unmap_sysmem(ptr);
- wget response dispatcher
- WARNING, This, and only this, is the place in wget.c where
- SEQUENCE NUMBERS are swapped between incoming (RX)
- and outgoing (TX).
- Procedure wget_handler() is correct for RX traffic.
uchar *ptr;
uchar *offset;
case WGET_CLOSED:
packets = 0;
break;
pkt_q_idx = 0;
offset = ptr;
break;
break;
retry_len = len;
wget_send_stored();
- Interfaces of U-BOOT
net_start_again();
} else {
puts("T ");
wget_send_stored();
uchar *pkt_in_q;
char *pos;
int hlen;
int i;
pkt[len] = '\0';
if (pos == 0) {
pkt_q_idx++;
} else {
if (pos > 0)
else
i = hlen;
} else {
pkt, hlen);
if (!pos) {
} else {
content_length);
if (len > hlen)
pkt, hlen);
pkt_q[i].len);
* in the typedef
interesting indentation...
packets++;
case WGET_CLOSED:
break;
if (len == 0) {
len);
} else {
break;
tcp_seq_num, len);
if (len == 0) {
} else {
tcp_ack_num, len);
break;
return;
case TCP_SYN_SENT:
case TCP_CLOSING:
case TCP_CLOSED:
break;
len);
break;
break;
break;
break;
++image_url;
} else {
&net_gateway);
2.11.0
As I am interested in tcp support for u-boot recently I will try to review your patches :)
u32 tcp_ack_num);
Missing tab before return net_...
u32 tcp_ack_num)
switch (proto) {
case IPPROTO_UDP:
break;
} /* if MAC address was not discovered yet, do an ARP request */ if (memcmp(ether, net_null_ethaddr, 6) == 0) {
ip->ip_sum = 0;
IPPROTO_UDP); ip->udp_src = htons(sport); ip->udp_dst = htons(dport);
net_set_ip_header(pkt, dest, net_ip, IP_ICMP_HDR_SIZE, IPPROTO_ICMP); icmp->type = ICMP_ECHO_REQUEST; icmp->code = 0;
-- 2.11.0
Series-notes
See how it didn't work? It's still in this patch log instead of below "---". Missing colon. Why so opposed to a dry run? You are having such trouble using the patman tool properly, it seems so much time is spent saying the same things over and over.
I have tested this patch and it breaks UDP functionality. I have fixed the regression. I have also fixed formatting issues that I've asked you to fix and you have not.
With your permission I will pull in the fixed version of this patch. Or if you prefer, I can send it to the list.
-Joe
Hi Duncan,
https://patchwork.ozlabs.org/patch/934006/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
Christian Gmeiner
DH@synoia.com
Joe Hershberger
