[U-Boot] [PATCH] mx51evk: Provide a proper reset for the Ethernet PHY
Provide a proper reset for the Ethernet PHY (LAN8700) on the MX51EVK.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/freescale/mx51evk/mx51evk.c | 4 ++++ 1 files changed, 4 insertions(+), 0 deletions(-)
diff --git a/board/freescale/mx51evk/mx51evk.c b/board/freescale/mx51evk/mx51evk.c index 75d642b..70cce55 100644 --- a/board/freescale/mx51evk/mx51evk.c +++ b/board/freescale/mx51evk/mx51evk.c @@ -261,6 +261,10 @@ static void power_init(void)
/* Reset the ethernet controller over GPIO */ writel(0x1, IOMUXC_BASE_ADDR + 0x0AC); + udelay(200); + reg = readl(GPIO2_BASE_ADDR + 0x0); + reg |= 0x4000; /* Set reset line to high*/ + writel(reg, GPIO2_BASE_ADDR + 0x0);
/* Enable VGEN3, VCAM, VAUDIO, VVIDEO, VSD regulators */ val = VGEN3EN | VGEN3CONFIG | VCAMEN | VCAMCONFIG |
Hi Fabio,
- udelay(200);
- reg = readl(GPIO2_BASE_ADDR + 0x0);
- reg |= 0x4000; /* Set reset line to high*/
- writel(reg, GPIO2_BASE_ADDR + 0x0);
I know I am responsible for this usage, because I forget to add some accessors for the gpio pins - as I see your patch, I have sent a patch to support it. However, a direct access to registers using offsets is not allowed in u-boot. If we use some kind of accessors, your code will be easier to read it. Everything could be changed as (0X4000 --> gpio 46, if I am not wrong):
udelay(200); mxc_gpio_set(46);
What do you think ?
Best regards, Stefano
Hi Stefano,
--- On Fri, 8/20/10, Stefano Babic sbabic@denx.de wrote: ...
What do you think ?
Yes, I agree. Do you plan to send a patch for mx51evk using this approach?
If you do, then I can re-submit my patch after your update.
Regards,
Fabio Estevam
Hi Stefano,
Hi Fabio,
This must be,
What do you think ?
I sent today a patch adding a common way to access gpios for i.MX31 and i.MX51:
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/83163
I have another issue. It seems to me that the lines you want to add are already in the code, only some lines later:
263 /* Enable VGEN3, VCAM, VAUDIO, VVIDEO, VSD regulators */ 264 val = VGEN3EN | VGEN3CONFIG | VCAMEN | VCAMCONFIG | 265 VVIDEOEN | VAUDIOEN | VSDEN; 266 pmic_reg_write(REG_MODE_1, val); 267 268 udelay(500); 269 270 reg = readl(GPIO2_BASE_ADDR + 0x0); 271 reg |= 0x4000; 272 writel(reg, GPIO2_BASE_ADDR + 0x0);
This is exactly what you want to add, only after setting the regulators. Why do we need to set the gpio twice ?
Best regards, Stefano Babic
You are right. Please disregard my patch.
Regards,
Fabio Estevam
Fabio Estevam
Stefano Babic
