[U-Boot] [RESEND][PATCH] power: regulator: denied disable on always-on regulator
Don't disable regulator which are tagged as "regulator-always-on" in DT.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Jack Mitchell jack@embed.me.uk Tested-by: Jack Mitchell jack@embed.me.uk Signed-off-by: Patrice Chotard patrice.chotard@st.com ---
drivers/power/regulator/regulator-uclass.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/drivers/power/regulator/regulator-uclass.c b/drivers/power/regulator/regulator-uclass.c index 4da8e43259fc..4511625ff251 100644 --- a/drivers/power/regulator/regulator-uclass.c +++ b/drivers/power/regulator/regulator-uclass.c @@ -106,10 +106,15 @@ int regulator_get_enable(struct udevice *dev) int regulator_set_enable(struct udevice *dev, bool enable) { const struct dm_regulator_ops *ops = dev_get_driver_ops(dev); + struct dm_regulator_uclass_platdata *uc_pdata;
if (!ops || !ops->set_enable) return -ENOSYS;
+ uc_pdata = dev_get_uclass_platdata(dev); + if (!enable && uc_pdata->always_on) + return -EACCES; + return ops->set_enable(dev, enable); }
On Thu, Nov 15, 2018 at 1:46 PM Patrice Chotard patrice.chotard@st.com wrote:
Reviewed-by: Richard Röjfors richard@puffinpack.se Tested-by: Richard Röjfors richard@puffinpack.se
Reviewed-by: Felix Brack fb@ltec.ch Tested-by: Felix Brack fb@ltec.ch
return -EACCES;
This patch has been around since May 2018 (albeit superseded). A request from Patrice Chotard to Jaehoon Chung about the patch status change never got answered. Looking Patchwork I don't see any post from Jaehoon after May 8. 2018. Please don't get me wrong: I just want to make sure this patch doesn't get forgotten, knowing very well, that it was posted (resent) just 2 weeks ago. Expecting quite a few board maintainers to enable DM_MMC in the coming weeks and months this patch might get important to more people as it prevents powering off the MMC supply voltage during power cycling. If the patch is on someones radar that's fine with me.
regards, Felix
I'm happy to pick it up if that helps.
Please, thanks!
Hello Simon,
Excellent! Thank you very much for taking care.
Regards, Felix
Hi Simon
Thank you ;-)
On Tue, 4 Dec 2018 at 01:02, Patrice CHOTARD patrice.chotard@st.com wrote:
Hi Simon
Thank you ;-)
Applied to u-boot-dm, thanks!
participants (6)
Felix Brack
Patrice CHOTARD
Patrice Chotard
Richard Röjfors
