[U-Boot] [PATCH] e1000: fix unused variable waring for e1000 driver
Fix the following build warning in drivers/net/e1000.c
e1000.c: In function 'e1000_reset_hw': e1000.c:1373:11: warning: variable 'icr' set but not used [-Wunused-but-set-variable] e1000.c: In function 'e1000_phy_init_script': e1000.c:4395:11: warning: variable 'ret_val' set but not used [-Wunused-but-set-variable]
Signed-off-by: Roy Zang tie-fei.zang@freescale.com Cc: Wolfgang Denk wd@denx.de Cc: Kyle Moffett Kyle.D.Moffett@boeing.com --- drivers/net/e1000.c | 6 +++--- 1 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/net/e1000.c b/drivers/net/e1000.c index 6eab7b2..6b71bd9 100644 --- a/drivers/net/e1000.c +++ b/drivers/net/e1000.c @@ -1370,7 +1370,6 @@ e1000_reset_hw(struct e1000_hw *hw) { uint32_t ctrl; uint32_t ctrl_ext; - uint32_t icr; uint32_t manc; uint32_t pba = 0;
@@ -1443,7 +1442,7 @@ e1000_reset_hw(struct e1000_hw *hw) E1000_WRITE_REG(hw, IMC, 0xffffffff);
/* Clear any pending interrupt events. */ - icr = E1000_READ_REG(hw, ICR); + E1000_READ_REG(hw, ICR);
/* If MWI was previously enabled, reenable it. */ if (hw->mac_type == e1000_82542_rev2_0) { @@ -4447,7 +4446,8 @@ e1000_phy_init_script(struct e1000_hw *hw) mdelay(20);
/* Now enable the transmitter */ - e1000_write_phy_reg(hw, 0x2F5B, phy_saved_data); + if (!ret_val) + e1000_write_phy_reg(hw, 0x2F5B, phy_saved_data);
if (hw->mac_type == e1000_82547) { uint16_t fused, fine, coarse;
Dear Roy Zang,
In message 1320654156-3240-1-git-send-email-tie-fei.zang@freescale.com you wrote:
Applied, thanks.
Roy Zang
