[U-Boot] [PATCH] cmd_bootm.c: Re-order bootm_load_os return check for ELDK4.2
With ELDK4.2 we were getting a warning that load_end may be used uninitialized in calling lmb_reserve. This could not be the case, however. If we re-order the checks (and make them slightly clearer as well) the warning goes away. bootm_load_os may only return 0 on success, BOOTM_ERR_OVERLAP in a non-fatal overlap (already covered in comments) or a fatal BOOTM_ERR that is covered in the error handler.
Signed-off-by: Tom Rini trini@ti.com --- common/cmd_bootm.c | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index 6caa0e9..d5b2a3c 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -650,12 +650,11 @@ static int do_bootm_states(cmd_tbl_t *cmdtp, int flag, int argc,
iflag = bootm_disable_interrupts(); ret = bootm_load_os(images, &load_end, 0); - if (ret && ret != BOOTM_ERR_OVERLAP) - goto err; - if (ret == 0) lmb_reserve(&images->lmb, images->os.load, (load_end - images->os.load)); + else if (ret && ret != BOOTM_ERR_OVERLAP) + goto err; else if (ret == BOOTM_ERR_OVERLAP) ret = 0; }
Applied to u-boot/master.
