[PATCH 00/13] Add support for Ethernet boot on AM62p-SK and AM68-SK
This series enables Ethernet boot on AM62p-SK and AM68-SK.
This series is based on commit '6d41f0a39d6423c8e57e92ebbe9f8c0333a63f72' of origin/master branch of U-Boot.
Logs: AM62p-SK Ethernet boot: https://gist.github.com/chintan013/cd622d329b0a5b894808daff3191bb9f AM68-SK Etherent boot: https://gist.github.com/chintan013/39e67a173327bcbdae1724c35341b445
Andreas Dannenberg (3): arm: mach-k3: am62p: Update SoC auto-gen data to enable CPSW boot board: ti: am62px: evm: Enable cache for AM62p configs: am62p: Add configs for enabling ETHBOOT in R5SPL
Chintan Vankar (10): net: tftp: Increase TFTP pkt string length to include null character arm: mach-k3: j721s2: Update SoC auto-gen data to enable Ethernet boot arm: mach-k3: j721s2_spl: Alias Ethernet boot to CPGMAC arm: mach-k3: j721s2_init: Probe AM65 CPSW NUSS for R5/A72 SPL configs: am68: Add configs for enabling Ethboot in R5SPL configs: am68: Enable configs required for Ethernet boot arm: dts: k3-am68-sk-base-board-u-boot: Add bootph-all property to necessary nodes arm: mach-k3: am62p5_init: Probe AM65 CPSW NUSS for R5/A53 SPL configs: am62p: Enable configs required for Ethboot arch: arm: dts: k3-am62p5-sk-u-boot: Add bootph-all property to necessary nodes
arch/arm/dts/k3-am62p5-sk-u-boot.dtsi | 32 ++++++++ .../arm/dts/k3-am68-sk-base-board-u-boot.dtsi | 28 +++++++ arch/arm/mach-k3/am62px/am62p5_init.c | 10 +++ arch/arm/mach-k3/include/mach/j721s2_spl.h | 1 + arch/arm/mach-k3/j721s2/j721s2_init.c | 10 +++ arch/arm/mach-k3/r5/am62px/clk-data.c | 44 +++++++++- arch/arm/mach-k3/r5/am62px/dev-data.c | 24 +++--- arch/arm/mach-k3/r5/j721s2/clk-data.c | 58 +++++++++++++- arch/arm/mach-k3/r5/j721s2/dev-data.c | 3 +- board/ti/am62px/evm.c | 8 ++ configs/am62px_evm_a53_ethboot_defconfig | 17 ++++ configs/am62px_evm_r5_ethboot_defconfig | 35 ++++++++ configs/am68_sk_a72_ethboot_defconfig | 18 +++++ configs/am68_sk_r5_ethboot_defconfig | 80 +++++++++++++++++++ net/tftp.c | 6 +- 15 files changed, 353 insertions(+), 21 deletions(-) create mode 100644 configs/am62px_evm_a53_ethboot_defconfig create mode 100644 configs/am62px_evm_r5_ethboot_defconfig create mode 100644 configs/am68_sk_a72_ethboot_defconfig create mode 100644 configs/am68_sk_r5_ethboot_defconfig
'sprintf()' function defined in 'tiny-printf.c' is returning length of the string excluding null character. Fix this by increasing TFTP pkt length by 1 to avoid TFTP error of request being not-null terminated while requesting length of packet.
Signed-off-by: Chintan Vankar c-vankar@ti.com --- net/tftp.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/net/tftp.c b/net/tftp.c index 704b20b4ff8..db1d4aacb0e 100644 --- a/net/tftp.c +++ b/net/tftp.c @@ -347,11 +347,11 @@ static void tftp_send(void) pkt += strlen((char *)pkt) + 1; #ifdef CONFIG_TFTP_TSIZE pkt += sprintf((char *)pkt, "tsize%c%u%c", - 0, net_boot_file_size, 0); + 0, net_boot_file_size, 0) + 1; #endif /* try for more effic. blk size */ pkt += sprintf((char *)pkt, "blksize%c%d%c", - 0, tftp_block_size_option, 0); + 0, tftp_block_size_option, 0) + 1;
/* try for more effic. window size. * Implemented only for tftp get. @@ -359,7 +359,7 @@ static void tftp_send(void) */ if (tftp_state == STATE_SEND_RRQ && tftp_window_size_option > 1) pkt += sprintf((char *)pkt, "windowsize%c%d%c", - 0, tftp_window_size_option, 0); + 0, tftp_window_size_option, 0) + 1; len = pkt - xp; break;
Erm, if tiny-printf's sprintf doesn't work like lib/vsprintf.c's sprintf in this regard, we should be fixing tiny-printf.
Hello Tom, I have observed that 'sprintf()' defined in lib/vsprintf.c at here: https://github.com/torvalds/linux/blob/master/lib/vsprintf.c#L3035 also behaves the same way, that returns length of the string excluding null character.
Then please rework the commit message, thanks.
Update dev-data and clk-data generated using ksswtool-autogen to include CPSW device which is required for Ethernet Boot, also use ARRAY_SIZE() MACRO to avoid hard-coding array size.
Signed-off-by: Chintan Vankar c-vankar@ti.com --- arch/arm/mach-k3/r5/j721s2/clk-data.c | 58 +++++++++++++++++++++++++-- arch/arm/mach-k3/r5/j721s2/dev-data.c | 3 +- 2 files changed, 57 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-k3/r5/j721s2/clk-data.c b/arch/arm/mach-k3/r5/j721s2/clk-data.c index 0c5c321c1eb..0130c9c4b86 100644 --- a/arch/arm/mach-k3/r5/j721s2/clk-data.c +++ b/arch/arm/mach-k3/r5/j721s2/clk-data.c @@ -5,7 +5,7 @@ * This file is auto generated. Please do not hand edit and report any issues * to Dave Gerlach d-gerlach@ti.com. * - * Copyright (C) 2020-2021 Texas Instruments Incorporated - https://www.ti.com/ + * Copyright (C) 2020-2025 Texas Instruments Incorporated - https://www.ti.com/ */
#include <linux/clk-provider.h> @@ -55,6 +55,32 @@ static const char * const mcu_ospi_ref_clk_sel_out1_parents[] = { "hsdiv4_16fft_mcu_2_hsdivout4_clk", };
+static const char * const wkup_gpio0_clksel_out0_parents[] = { + "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk", + "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk", + "j7am_wakeup_16ff_wkup_0_wkup_rcosc_32k_clk", + "j7am_wakeup_16ff_wkup_0_wkup_rcosc_12p5m_clk", +}; + +static const char * const cpsw2g_cpts_rclk_sel_out0_parents[] = { + "hsdiv4_16fft_main_3_hsdivout1_clk", + "postdiv3_16fft_main_0_hsdivout6_clk", + "board_0_mcu_cpts0_rft_clk_out", + "board_0_cpts0_rft_clk_out", + "board_0_mcu_ext_refclk0_out", + "board_0_ext_refclk1_out", + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + NULL, + "hsdiv4_16fft_mcu_2_hsdivout1_clk", + "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk", +}; + static const char * const mcu_usart_clksel_out0_parents[] = { "hsdiv4_16fft_mcu_1_hsdivout3_clk", "postdiv3_16fft_main_1_hsdivout5_clk", @@ -174,7 +200,11 @@ static const struct clk_data clk_list[] = { CLK_FIXED_RATE("board_0_hfosc1_clk_out", 0, 0), CLK_FIXED_RATE("board_0_mcu_ospi0_dqs_out", 0, 0), CLK_FIXED_RATE("board_0_mcu_ospi1_dqs_out", 0, 0), + CLK_FIXED_RATE("board_0_mcu_rgmii1_rxc_out", 0, 0), + CLK_FIXED_RATE("board_0_mcu_rmii1_ref_clk_out", 0, 0), CLK_FIXED_RATE("board_0_wkup_i2c0_scl_out", 0, 0), + CLK_FIXED_RATE("cpsw_2guss_mcu_0_mdio_mdclk_o", 0, 0), + CLK_FIXED_RATE("cpsw_2guss_mcu_0_rgmii1_txc_o", 0, 0), CLK_FIXED_RATE("fss_mcu_0_hyperbus1p0_0_hpb_out_clk_n", 0, 0), CLK_FIXED_RATE("fss_mcu_0_hyperbus1p0_0_hpb_out_clk_p", 0, 0), CLK_FIXED_RATE("fss_mcu_0_ospi_0_ospi_oclk_clk", 0, 0), @@ -199,6 +229,8 @@ static const struct clk_data clk_list[] = { CLK_DIV("k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk", "k3_pll_ctrl_wrap_wkup_0_sysclkout_clk", 0x42010118, 0, 5, 0, 0), CLK_MUX("mcu_ospi_ref_clk_sel_out0", mcu_ospi_ref_clk_sel_out0_parents, 2, 0x40f08030, 0, 1, 0), CLK_MUX("mcu_ospi_ref_clk_sel_out1", mcu_ospi_ref_clk_sel_out1_parents, 2, 0x40f08034, 0, 1, 0), + CLK_MUX("wkup_gpio0_clksel_out0", wkup_gpio0_clksel_out0_parents, 4, 0x43008070, 0, 2, 0), + CLK_MUX("cpsw2g_cpts_rclk_sel_out0", cpsw2g_cpts_rclk_sel_out0_parents, 16, 0x40f08050, 8, 4, 0), CLK_MUX("mcu_usart_clksel_out0", mcu_usart_clksel_out0_parents, 2, 0x40f081c0, 0, 1, 0), CLK_MUX("wkup_i2c_mcupll_bypass_out0", wkup_i2c_mcupll_bypass_out0_parents, 2, 0x43008060, 0, 1, 0), CLK_MUX("main_pll_hfosc_sel_out0", main_pll_hfosc_sel_out0_parents, 2, 0x43008080, 0, 1, 0), @@ -275,6 +307,24 @@ static const struct dev_clk soc_dev_clk_data[] = { DEV_CLK(4, 0, "hsdiv0_16fft_main_8_hsdivout0_clk"), DEV_CLK(4, 1, "hsdiv0_16fft_main_7_hsdivout0_clk"), DEV_CLK(4, 2, "k3_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(29, 3, "cpsw2g_cpts_rclk_sel_out0"), + DEV_CLK(29, 4, "hsdiv4_16fft_main_3_hsdivout1_clk"), + DEV_CLK(29, 5, "postdiv3_16fft_main_0_hsdivout6_clk"), + DEV_CLK(29, 6, "board_0_mcu_cpts0_rft_clk_out"), + DEV_CLK(29, 7, "board_0_cpts0_rft_clk_out"), + DEV_CLK(29, 8, "board_0_mcu_ext_refclk0_out"), + DEV_CLK(29, 9, "board_0_ext_refclk1_out"), + DEV_CLK(29, 18, "hsdiv4_16fft_mcu_2_hsdivout1_clk"), + DEV_CLK(29, 19, "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk"), + DEV_CLK(29, 20, "hsdiv4_16fft_mcu_2_hsdivout0_clk"), + DEV_CLK(29, 21, "hsdiv4_16fft_mcu_2_hsdivout0_clk"), + DEV_CLK(29, 22, "board_0_mcu_rgmii1_rxc_out"), + DEV_CLK(29, 26, "board_0_mcu_rmii1_ref_clk_out"), + DEV_CLK(29, 28, "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk"), + DEV_CLK(29, 29, "hsdiv4_16fft_mcu_2_hsdivout0_clk"), + DEV_CLK(29, 30, "hsdiv4_16fft_mcu_2_hsdivout0_clk"), + DEV_CLK(29, 32, "hsdiv4_16fft_mcu_2_hsdivout0_clk"), + DEV_CLK(29, 33, "hsdiv4_16fft_mcu_2_hsdivout0_clk"), DEV_CLK(43, 0, "postdiv3_16fft_main_0_hsdivout8_clk"), DEV_CLK(43, 1, "hsdiv4_16fft_main_0_hsdivout3_clk"), DEV_CLK(43, 2, "gluelogic_hfosc0_clkout"), @@ -367,6 +417,7 @@ static const struct dev_clk soc_dev_clk_data[] = { DEV_CLK(157, 187, "fss_mcu_0_ospi_1_ospi_oclk_clk"), DEV_CLK(157, 194, "emmcsd4ss_main_0_emmcsdss_io_clk_o"), DEV_CLK(157, 197, "j7am_ddr_ew_wrap_dv_wrap_main_0_ddrss_io_ck_n"), + DEV_CLK(157, 207, "cpsw_2guss_mcu_0_mdio_mdclk_o"), DEV_CLK(157, 208, "j7am_ddr_ew_wrap_dv_wrap_main_1_ddrss_io_ck_n"), DEV_CLK(157, 214, "fss_mcu_0_hyperbus1p0_0_hpb_out_clk_p"), DEV_CLK(157, 221, "mcu_clkout_mux_out0"), @@ -374,6 +425,7 @@ static const struct dev_clk soc_dev_clk_data[] = { DEV_CLK(157, 223, "hsdiv4_16fft_mcu_2_hsdivout0_clk"), DEV_CLK(157, 225, "emmc8ss_16ffc_main_0_emmcss_io_clk"), DEV_CLK(157, 231, "fss_mcu_0_hyperbus1p0_0_hpb_out_clk_n"), + DEV_CLK(157, 244, "cpsw_2guss_mcu_0_rgmii1_txc_o"), DEV_CLK(157, 352, "dpi0_ext_clksel_out0"), DEV_CLK(180, 0, "gluelogic_hfosc0_clkout"), DEV_CLK(180, 2, "k3_pll_ctrl_wrap_wkup_0_chip_div1_clk_clk"), @@ -400,7 +452,7 @@ static const struct dev_clk soc_dev_clk_data[] = {
const struct ti_k3_clk_platdata j721s2_clk_platdata = { .clk_list = clk_list, - .clk_list_cnt = 105, + .clk_list_cnt = ARRAY_SIZE(clk_list), .soc_dev_clk_data = soc_dev_clk_data, - .soc_dev_clk_data_cnt = 124, + .soc_dev_clk_data_cnt = ARRAY_SIZE(soc_dev_clk_data), }; diff --git a/arch/arm/mach-k3/r5/j721s2/dev-data.c b/arch/arm/mach-k3/r5/j721s2/dev-data.c index df70c5e5d7c..b78550707c5 100644 --- a/arch/arm/mach-k3/r5/j721s2/dev-data.c +++ b/arch/arm/mach-k3/r5/j721s2/dev-data.c @@ -5,7 +5,7 @@ * This file is auto generated. Please do not hand edit and report any issues * to Dave Gerlach d-gerlach@ti.com. * - * Copyright (C) 2020-2021 Texas Instruments Incorporated - https://www.ti.com/ + * Copyright (C) 2020-2025 Texas Instruments Incorporated - https://www.ti.com/ */
#include "k3-dev.h" @@ -47,6 +47,7 @@ static struct ti_lpsc soc_lpsc_list[] = { };
static struct ti_dev soc_dev_list[] = { + PSC_DEV(29, &soc_lpsc_list[0]), PSC_DEV(35, &soc_lpsc_list[0]), PSC_DEV(108, &soc_lpsc_list[0]), PSC_DEV(109, &soc_lpsc_list[0]),
On January 7, 2025 thus sayeth Chintan Vankar:
Reviewed-by: Bryan Brattlof bb@ti.com
~Bryan
This is required to enable spl_net boot on AM68-SK.
Signed-off-by: Chintan Vankar c-vankar@ti.com --- arch/arm/mach-k3/include/mach/j721s2_spl.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/mach-k3/include/mach/j721s2_spl.h b/arch/arm/mach-k3/include/mach/j721s2_spl.h index d8fae2c8b45..47a61281d94 100644 --- a/arch/arm/mach-k3/include/mach/j721s2_spl.h +++ b/arch/arm/mach-k3/include/mach/j721s2_spl.h @@ -12,6 +12,7 @@ #define BOOT_DEVICE_OSPI 0x01 #define BOOT_DEVICE_QSPI 0x02 #define BOOT_DEVICE_SPI 0x03 +#define BOOT_DEVICE_CPGMAC 0x04 #define BOOT_DEVICE_ETHERNET 0x04 #define BOOT_DEVICE_I2C 0x06 #define BOOT_DEVICE_UART 0x07
To support Ethernet boot on AM68-SK, probe AM65 CPSW NUSS driver in board_init_f().
Signed-off-by: Chintan Vankar c-vankar@ti.com --- arch/arm/mach-k3/j721s2/j721s2_init.c | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/arch/arm/mach-k3/j721s2/j721s2_init.c b/arch/arm/mach-k3/j721s2/j721s2_init.c index 6ce3eb87efb..7208bee5785 100644 --- a/arch/arm/mach-k3/j721s2/j721s2_init.c +++ b/arch/arm/mach-k3/j721s2/j721s2_init.c @@ -329,6 +329,16 @@ void board_init_f(ulong dummy)
setup_qos();
+ if (IS_ENABLED(CONFIG_SPL_ETH) && IS_ENABLED(CONFIG_TI_AM65_CPSW_NUSS) && + spl_boot_device() == BOOT_DEVICE_ETHERNET) { + struct udevice *cpswdev; + + ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(am65_cpsw_nuss), + &cpswdev); + if (ret) + printf("Failed to probe am65_cpsw_nuss driver..\n"); + } + if (IS_ENABLED(CONFIG_CPU_V7R) && IS_ENABLED(CONFIG_K3_AVS0)) { ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(k3_avs), &dev);
setup_qos();
- if (IS_ENABLED(CONFIG_SPL_ETH) && IS_ENABLED(CONFIG_TI_AM65_CPSW_NUSS) &&
&cpswdev);
if (ret)
This looks like a hack. Please find out why the Ethernet driver is not being probed when SPL tries to load image over net.
We have the following defined at the am65-cpsw-nuss driver.
U_BOOT_DRIVER(am65_cpsw_nuss) = { .name = "am65_cpsw_nuss", .id = UCLASS_MISC, .of_match = am65_cpsw_nuss_ids, .probe = am65_cpsw_probe_nuss, .priv_auto = sizeof(struct am65_cpsw_common), };
U_BOOT_DRIVER(am65_cpsw_nuss_port) = { .name = "am65_cpsw_nuss_port", .id = UCLASS_ETH, .probe = am65_cpsw_port_probe, .ops = &am65_cpsw_ops, .priv_auto = sizeof(struct am65_cpsw_priv), .plat_auto = sizeof(struct eth_pdata), .flags = DM_FLAG_ALLOC_PRIV_DMA | DM_FLAG_OS_PREPARE, };
It looks like am65_cpsw_probe_nuss() is not being invoked for you.
Can you please check if am65_cpsw_port_probe() was invoked? If yes but am65_cpsw_probe_nuss() was not then we need to fix the DM hierarchy for AM65_CPSW?
setup_qos();
&cpswdev);
if (ret)
Hello Roger,
The driver is defined as UCLASS_MISC which should be probed explicitly, I have discussed the same with Nishanth in following thread: https://lore.kernel.org/all/ee1d16fd-b99b-4b07-97bb-a896e179157a@ti.com/
None of the probe function is getting invoked here, since we need Ethernet functionality here we need to probe function in board_init_f(). We have discussed the same at here: https://lore.kernel.org/r/d68c8045-116a-49c0-9e74-d6a366e6f008@kernel.org/#t
+Vignesh & Siddharth
diff --git a/arch/arm/mach-k3/j721s2/j721s2_init.c b/arch/arm/mach-k3/j721s2/j721s2_init.c index 6ce3eb87efb..7208bee5785 100644 --- a/arch/arm/mach-k3/j721s2/j721s2_init.c +++ b/arch/arm/mach-k3/j721s2/j721s2_init.c @@ -329,6 +329,16 @@ void board_init_f(ulong dummy) setup_qos(); + if (IS_ENABLED(CONFIG_SPL_ETH) && IS_ENABLED(CONFIG_TI_AM65_CPSW_NUSS) && + spl_boot_device() == BOOT_DEVICE_ETHERNET) { + struct udevice *cpswdev;
Hello Roger,
The driver was originally built without UCLASS_MISC, but
commit 38922b1f4acc ("net: ti: am65-cpsw: Add support for multi port independent MAC mode")
Added UCLASS_MISC and states there that " Since top level driver is now UCLASS_MISC, board files would need to instantiate this driver explicitly."
Not an elegant solution. So we need to fix something in the am65-cpuss driver.
Looking at drivers/net/mvpp2.c we can see a possible solution. 1) don't define .probe for the parent driver (UCLASS_MISC). Instead define .bind that will scan the device tree for ports and bind the port device and driver. e.g. see mvpp2_base_bind() 2) in port driver .probe (UCLASS_ETH), if parent has not been probed then call the parent probe (am65_cpsw_probe_nuss) . Also set a flag so parent probe only gets called once. 3) update all board files no not explicitly probe the am65-cpsw UCLASS_MISC driver.
Siddharth / Vignesh do you see any issues with this solution?
That is strange. am65_cpsw_probe_nuss() should be called at least for port 0 since it is defined as UCLASS_ETH.
On 23/01/25 15:10, Roger Quadros wrote:
Hello Roger,
- don't define .probe for the parent driver (UCLASS_MISC). Instead define .bind
I like this idea. It may need bit more than moving probe to bind as there are some reg accesses which shouldn't ideally be done at bind phase. But should be feasible to drop them.
Hello Roger,
Hello Roger, I have tried to understand your approach, I will work on that. But for now, is it possible to merge the seris with the existing approach ?
am65_cpsw_probe_nuss() is defined as UCLASS_MISC and not UCLASS_ETH, it will get invoked if declared as UCLASS_ETH, as per your suggestion above it will need driver changes to invoke the probe function without being called explicitly and work properly.
Hello Roger,
Hi Chintan,
I'm afraid that if we allow this for one board it will set a wrong example for others. It is a very simple solution and shouldn't take much time. In case you are stuck me or Siddharth could help. Thanks!
Add configs for enabling Ethernet boot in R5SPL.
Signed-off-by: Chintan Vankar c-vankar@ti.com --- configs/am68_sk_r5_ethboot_defconfig | 80 ++++++++++++++++++++++++++++ 1 file changed, 80 insertions(+) create mode 100644 configs/am68_sk_r5_ethboot_defconfig
diff --git a/configs/am68_sk_r5_ethboot_defconfig b/configs/am68_sk_r5_ethboot_defconfig new file mode 100644 index 00000000000..9bfbb5a3bfe --- /dev/null +++ b/configs/am68_sk_r5_ethboot_defconfig @@ -0,0 +1,80 @@ +#include <configs/am68_sk_r5_defconfig> + +CONFIG_ARM=y +CONFIG_ARCH_K3=y +CONFIG_SOC_K3_J721S2=y +CONFIG_TARGET_J721S2_R5_EVM=y +CONFIG_DEFAULT_DEVICE_TREE="k3-am68-sk-r5-base-board" +CONFIG_SPL_GPIO=y +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x200000 +CONFIG_SPL_DMA=y +CONFIG_SPL_ENV_SUPPORT=y +CONFIG_SPL_ETH=y +CONFIG_SPL_I2C=y +CONFIG_SPL_NET=y +CONFIG_SPL_NET_VCI_STRING="AM68 U-Boot R5 SPL" +CONFIG_CMD_DHCP=y +CONFIG_SPL_SYSCON=y +CONFIG_DMA_CHANNELS=y +CONFIG_TI_K3_NAVSS_UDMA=y +CONFIG_DM_I2C=y +CONFIG_PHY_TI_DP83867=y +CONFIG_TI_AM65_CPSW_NUSS=y +CONFIG_SPI=n +CONFIG_SPL_SPI=n +CONFIG_DM_SPI=n +CONFIG_SPL_DM_SPI=n +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPI_MEM=n +CONFIG_CMD_FAT=n +CONFIG_FS_FAT=n +CONFIG_SPL_FS_FAT=n +CONFIG_MMC_SDHCI=n +CONFIG_MTD=n +CONFIG_CMD_FAT=n +CONFIG_SYS_RELOC_GD_ENV_ADD=y +CONFIG_SPL_DM_SPI_FLASH=n +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=n +CONFIG_HUSH_PARSER=n +CONFIG_CMD_DFU=n +CONFIG_CMD_GPT=n +CONFIG_SPL_YMODEM_SUPPORT=n +CONFIG_ARCH_FIXUP_FDT_MEMORY=n +CONFIG_SPL_ENV_IS_NOWHERE=y +CONFIG_DM_EVENT=y +CONFIG_INPUT=n +CONFIG_ESM_K3=y +CONFIG_SPL_LOAD_BLOCK=y +CONFIG_DFU=n +CONFIG_SPL_DFU=n +CONFIG_TI_I2C_BOARD_DETECT=y +CONFIG_K3_EARLY_CONS=n +CONFIG_K3_QOS=n +CONFIG_USE_BOOTCOMMAND=n +CONFIG_SPL_MTD=n +CONFIG_SPL_NAND_SPI_SUPPORT=n +CONFIG_BOOTDEV_ETH=y +CONFIG_USB=n +CONFIG_FS_LOADER=n +CONFIG_SPL_FS_LOADER=n +CONFIG_SPL_DM_SPI=y +CONFIG_PINCTRL_GENERIC=n +CONFIG_PINMUX=n +CONFIG_SPL_PINCTRL_GENERIC=n +CONFIG_SPL_PINMUX=n +CONFIG_DM_REGULATOR=n +CONFIG_TI_SCI_POWER_DOMAIN=n +CONFIG_CMD_REMOTEPROC=y +CONFIG_SYSRESET=n +CONFIG_LAST_STAGE_INIT=y +CONFIG_OF_UPSTREAM=n +CONFIG_K3_DM_FW=y +CONFIG_SPL_SPI_LOAD=n +CONFIG_SPL_DM_SPI=n +CONFIG_NOR_SUPPORT=n +CONFIG_SPL_NOR_SUPPORT=n +CONFIG_SPL_DM_SPI=n +CONFIG_SYS_MALLOC_CLEAR_ON_INIT=n +CONFIG_SPL_SYS_MALLOC_CLEAR_ON_INIT=n +CONFIG_BOOTDEV_ETH=n
Please don't add duplicates that are already included in configs/am68_sk_r5_defconfig or configs/j721s2_evm_r5_defconfig
Please explain in commit log why you are setting many of the options to "n". Is it due to memory limitation?
Why no OF_UPSTREAM?
Hello Roger, These config options are required despite of they are present in the file that is being included for buildman to work, you can refer to Tom's comment at here: https://lore.kernel.org/r/20240705153721.GF38804@bill-the-cat/ after which I included the same while posting config file for AM62x-SK.
Yes, that is because of memory limitation, we have faced the same limitation while working with AM62x Ethernet boot.
Why no OF_UPSTREAM?
Device tree files are not in-sync with upstream linux for AM68, getting compile time errors for the same, that's the reason I have disabled this config option.
Understood. Thanks!
Why no OF_UPSTREAM?
I suggest to do a sync and not disable CONFIG_OF_UPSTREAM.
Enable config options needed to support Ethernet boot on AM68-SK.
Signed-off-by: Chintan Vankar c-vankar@ti.com --- configs/am68_sk_a72_ethboot_defconfig | 18 ++++++++++++++++++ 1 file changed, 18 insertions(+) create mode 100644 configs/am68_sk_a72_ethboot_defconfig
diff --git a/configs/am68_sk_a72_ethboot_defconfig b/configs/am68_sk_a72_ethboot_defconfig new file mode 100644 index 00000000000..42469861961 --- /dev/null +++ b/configs/am68_sk_a72_ethboot_defconfig @@ -0,0 +1,18 @@ +#include <configs/am68_sk_a72_defconfig> + +CONFIG_ARM=y +CONFIG_ARCH_K3=y +CONFIG_SOC_K3_J721S2=y +CONFIG_TARGET_J721S2_A72_EVM=y +CONFIG_DEFAULT_DEVICE_TREE="ti/k3-am68-sk-base-board" +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_DMA=y +CONFIG_SPL_ENV_SUPPORT=y +CONFIG_SPL_ETH=y +CONFIG_SPL_NET=y +CONFIG_SPL_NET_VCI_STRING="AM68 U-Boot A72 SPL" +CONFIG_SPL_SYSCON=y +CONFIG_SPL_RAW_IMAGE_SUPPORT=y +CONFIG_OF_UPSTREAM=y +CONFIG_SPL_STACK_R_ADDR=0x83000000
Please avoid duplicates already in configs/am68_sk_a72_defconfig or configs/j721s2_evm_a72_defconfig
Add "bootph-all" property to necessary nodes required for Ethernet boot starting from R5 SPL stage.
The changed made by this patch can be dropped in the future when the DT-sync is performed with upstream linux.
Linux patch for the same is posted at: https://lore.kernel.org/r/20250106123122.3531845-2-c-vankar@ti.com/
.../arm/dts/k3-am68-sk-base-board-u-boot.dtsi | 28 +++++++++++++++++++ 1 file changed, 28 insertions(+)
diff --git a/arch/arm/dts/k3-am68-sk-base-board-u-boot.dtsi b/arch/arm/dts/k3-am68-sk-base-board-u-boot.dtsi index 4b8d73a92d6..ccf0c4c7a0c 100644 --- a/arch/arm/dts/k3-am68-sk-base-board-u-boot.dtsi +++ b/arch/arm/dts/k3-am68-sk-base-board-u-boot.dtsi @@ -41,6 +41,34 @@ bootph-all; };
+&cpsw_mac_syscon { + bootph-all; +}; + +&cpsw_port1 { + bootph-all; +}; + +&mcu_cpsw { + bootph-all; +}; + +&mcu_cpsw_pins_default { + bootph-all; +}; + +&mcu_mdio_pins_default { + bootph-all; +}; + +&phy0 { + bootph-all; +}; + +&phy_gmii_sel { + bootph-all; +}; + &secure_proxy_main { bootph-all; };
This data was generated using the ksswtool-autogen project with the followig commit:
cd9dfa5 ("soc: am62px: Add cpsw_3guss_am67_main_0 id to the dev list")
Signed-off-by: Andreas Dannenberg dannenberg@ti.com Signed-off-by: Chintan Vankar c-vankar@ti.com --- arch/arm/mach-k3/r5/am62px/clk-data.c | 44 +++++++++++++++++++++++++-- arch/arm/mach-k3/r5/am62px/dev-data.c | 24 ++++++++------- 2 files changed, 54 insertions(+), 14 deletions(-)
diff --git a/arch/arm/mach-k3/r5/am62px/clk-data.c b/arch/arm/mach-k3/r5/am62px/clk-data.c index 4b9892fe051..24e912f2e25 100644 --- a/arch/arm/mach-k3/r5/am62px/clk-data.c +++ b/arch/arm/mach-k3/r5/am62px/clk-data.c @@ -5,7 +5,7 @@ * This file is auto generated. Please do not hand edit and report any issues * to Bryan Brattlof bb@ti.com. * - * Copyright (C) 2020-2023 Texas Instruments Incorporated - https://www.ti.com/ + * Copyright (C) 2020-2025 Texas Instruments Incorporated - https://www.ti.com/ */
#include <linux/clk-provider.h> @@ -62,6 +62,17 @@ static const char * const clkout0_ctrl_out0_parents[] = { "hsdiv4_16fft_main_2_hsdivout1_clk", };
+static const char * const main_cp_gemac_cpts_clk_sel_out0_parents[] = { + "postdiv4_16ff_main_2_hsdivout5_clk", + "postdiv4_16ff_main_0_hsdivout6_clk", + "board_0_cp_gemac_cpts0_rft_clk_out", + NULL, + "board_0_mcu_ext_refclk0_out", + "board_0_ext_refclk1_out", + NULL, + "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk", +}; + static const char * const main_emmcsd0_refclk_sel_out0_parents[] = { "postdiv4_16ff_main_0_hsdivout5_clk", "hsdiv4_16fft_main_2_hsdivout2_clk", @@ -99,8 +110,8 @@ static const char * const main_timerclkn_sel_out0_parents[] = { "board_0_cp_gemac_cpts0_rft_clk_out", "hsdiv4_16fft_main_1_hsdivout3_clk", "postdiv4_16ff_main_2_hsdivout6_clk", - NULL, - NULL, + "cpsw_3guss_am67_main_0_cpts_genf0", + "cpsw_3guss_am67_main_0_cpts_genf1", NULL, NULL, NULL, @@ -148,7 +159,12 @@ static const struct clk_data clk_list[] = { CLK_FIXED_RATE("board_0_mmc1_clk_out", 0, 0), CLK_FIXED_RATE("board_0_ospi0_dqs_out", 0, 0), CLK_FIXED_RATE("board_0_ospi0_lbclko_out", 0, 0), + CLK_FIXED_RATE("board_0_rmii1_ref_clk_out", 0, 0), + CLK_FIXED_RATE("board_0_rmii2_ref_clk_out", 0, 0), CLK_FIXED_RATE("board_0_tck_out", 0, 0), + CLK_FIXED_RATE("cpsw_3guss_am67_main_0_cpts_genf0", 0, 0), + CLK_FIXED_RATE("cpsw_3guss_am67_main_0_cpts_genf1", 0, 0), + CLK_FIXED_RATE("cpsw_3guss_am67_main_0_mdio_mdclk_o", 0, 0), CLK_FIXED_RATE("dmtimer_dmc1ms_main_0_timer_pwm", 0, 0), CLK_FIXED_RATE("emmcsd4ss_main_0_emmcsdss_io_clk_o", 0, 0), CLK_FIXED_RATE("fss_ul_main_0_ospi_0_ospi_oclk_clk", 0, 0), @@ -200,6 +216,7 @@ static const struct clk_data clk_list[] = { CLK_MUX_PLLCTRL("sam62_pll_ctrl_wrap_mcu_0_sysclkout_clk", sam62_pll_ctrl_wrap_mcu_0_sysclkout_clk_parents, 2, 0x4020000, 0), CLK_DIV("sam62_pll_ctrl_wrap_mcu_0_chip_div1_clk_clk", "sam62_pll_ctrl_wrap_mcu_0_sysclkout_clk", 0x4020118, 0, 5, 0, 0), CLK_MUX("clkout0_ctrl_out0", clkout0_ctrl_out0_parents, 2, 0x108010, 0, 1, 0), + CLK_MUX("main_cp_gemac_cpts_clk_sel_out0", main_cp_gemac_cpts_clk_sel_out0_parents, 8, 0x108140, 0, 3, 0), CLK_MUX("main_emmcsd0_refclk_sel_out0", main_emmcsd0_refclk_sel_out0_parents, 2, 0x108160, 0, 1, 0), CLK_MUX("main_emmcsd1_refclk_sel_out0", main_emmcsd1_refclk_sel_out0_parents, 2, 0x108168, 0, 1, 0), CLK_MUX("main_gtcclk_sel_out0", main_gtcclk_sel_out0_parents, 8, 0x43008030, 0, 3, 0), @@ -215,6 +232,24 @@ static const struct clk_data clk_list[] = { };
static const struct dev_clk soc_dev_clk_data[] = { + DEV_CLK(13, 0, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(13, 3, "main_cp_gemac_cpts_clk_sel_out0"), + DEV_CLK(13, 4, "postdiv4_16ff_main_2_hsdivout5_clk"), + DEV_CLK(13, 5, "postdiv4_16ff_main_0_hsdivout6_clk"), + DEV_CLK(13, 6, "board_0_cp_gemac_cpts0_rft_clk_out"), + DEV_CLK(13, 8, "board_0_mcu_ext_refclk0_out"), + DEV_CLK(13, 9, "board_0_ext_refclk1_out"), + DEV_CLK(13, 11, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(13, 13, "hsdiv4_16fft_main_2_hsdivout1_clk"), + DEV_CLK(13, 14, "hsdiv4_16fft_main_2_hsdivout1_clk"), + DEV_CLK(13, 15, "hsdiv4_16fft_main_2_hsdivout1_clk"), + DEV_CLK(13, 16, "hsdiv4_16fft_main_2_hsdivout1_clk"), + DEV_CLK(13, 17, "hsdiv4_16fft_main_2_hsdivout1_clk"), + DEV_CLK(13, 19, "hsdiv4_16fft_main_2_hsdivout1_clk"), + DEV_CLK(13, 20, "hsdiv4_16fft_main_2_hsdivout1_clk"), + DEV_CLK(13, 21, "hsdiv4_16fft_main_2_hsdivout1_clk"), + DEV_CLK(13, 22, "board_0_rmii1_ref_clk_out"), + DEV_CLK(13, 23, "board_0_rmii2_ref_clk_out"), DEV_CLK(16, 0, "hsdiv4_16fft_main_0_hsdivout1_clk"), DEV_CLK(16, 1, "hsdiv4_16fft_main_0_hsdivout2_clk"), DEV_CLK(16, 2, "hsdiv4_16fft_main_0_hsdivout3_clk"), @@ -239,6 +274,8 @@ static const struct dev_clk soc_dev_clk_data[] = { DEV_CLK(36, 10, "board_0_cp_gemac_cpts0_rft_clk_out"), DEV_CLK(36, 11, "hsdiv4_16fft_main_1_hsdivout3_clk"), DEV_CLK(36, 12, "postdiv4_16ff_main_2_hsdivout6_clk"), + DEV_CLK(36, 13, "cpsw_3guss_am67_main_0_cpts_genf0"), + DEV_CLK(36, 14, "cpsw_3guss_am67_main_0_cpts_genf1"), DEV_CLK(57, 1, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), DEV_CLK(57, 2, "main_emmcsd0_refclk_sel_out0"), DEV_CLK(57, 3, "postdiv4_16ff_main_0_hsdivout5_clk"), @@ -285,6 +322,7 @@ static const struct dev_clk soc_dev_clk_data[] = { DEV_CLK(157, 40, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), DEV_CLK(157, 54, "mshsi2c_main_0_porscl"), DEV_CLK(157, 91, "sam62_pll_ctrl_wrap_mcu_0_sysclkout_clk"), + DEV_CLK(157, 96, "cpsw_3guss_am67_main_0_mdio_mdclk_o"), DEV_CLK(157, 101, "emmcsd4ss_main_0_emmcsdss_io_clk_o"), DEV_CLK(157, 103, "emmcsd4ss_main_0_emmcsdss_io_clk_o"), DEV_CLK(157, 143, "fss_ul_main_0_ospi_0_ospi_oclk_clk"), diff --git a/arch/arm/mach-k3/r5/am62px/dev-data.c b/arch/arm/mach-k3/r5/am62px/dev-data.c index 3cc211ea202..63e6beb4d57 100644 --- a/arch/arm/mach-k3/r5/am62px/dev-data.c +++ b/arch/arm/mach-k3/r5/am62px/dev-data.c @@ -5,7 +5,7 @@ * This file is auto generated. Please do not hand edit and report any issues * to Bryan Brattlof bb@ti.com. * - * Copyright (C) 2020-2023 Texas Instruments Incorporated - https://www.ti.com/ + * Copyright (C) 2020-2025 Texas Instruments Incorporated - https://www.ti.com/ */
#include "k3-dev.h" @@ -31,11 +31,12 @@ static struct ti_lpsc soc_lpsc_list[] = { [6] = PSC_LPSC(24, &soc_psc_list[0], &soc_pd_list[0], &soc_lpsc_list[8]), [7] = PSC_LPSC(28, &soc_psc_list[0], &soc_pd_list[0], &soc_lpsc_list[8]), [8] = PSC_LPSC(34, &soc_psc_list[0], &soc_pd_list[0], &soc_lpsc_list[8]), - [9] = PSC_LPSC(53, &soc_psc_list[0], &soc_pd_list[1], &soc_lpsc_list[8]), - [10] = PSC_LPSC(56, &soc_psc_list[0], &soc_pd_list[2], &soc_lpsc_list[9]), - [11] = PSC_LPSC(72, &soc_psc_list[0], &soc_pd_list[3], &soc_lpsc_list[8]), - [12] = PSC_LPSC(73, &soc_psc_list[0], &soc_pd_list[3], &soc_lpsc_list[11]), - [13] = PSC_LPSC(74, &soc_psc_list[0], &soc_pd_list[3], &soc_lpsc_list[12]), + [9] = PSC_LPSC(42, &soc_psc_list[0], &soc_pd_list[0], &soc_lpsc_list[8]), + [10] = PSC_LPSC(53, &soc_psc_list[0], &soc_pd_list[1], &soc_lpsc_list[8]), + [11] = PSC_LPSC(56, &soc_psc_list[0], &soc_pd_list[2], &soc_lpsc_list[10]), + [12] = PSC_LPSC(72, &soc_psc_list[0], &soc_pd_list[3], &soc_lpsc_list[8]), + [13] = PSC_LPSC(73, &soc_psc_list[0], &soc_pd_list[3], &soc_lpsc_list[12]), + [14] = PSC_LPSC(74, &soc_psc_list[0], &soc_pd_list[3], &soc_lpsc_list[13]), };
static struct ti_dev soc_dev_list[] = { @@ -52,11 +53,12 @@ static struct ti_dev soc_dev_list[] = { PSC_DEV(36, &soc_lpsc_list[8]), PSC_DEV(102, &soc_lpsc_list[8]), PSC_DEV(146, &soc_lpsc_list[8]), - PSC_DEV(166, &soc_lpsc_list[9]), - PSC_DEV(135, &soc_lpsc_list[10]), - PSC_DEV(170, &soc_lpsc_list[11]), - PSC_DEV(177, &soc_lpsc_list[12]), - PSC_DEV(55, &soc_lpsc_list[13]), + PSC_DEV(13, &soc_lpsc_list[9]), + PSC_DEV(166, &soc_lpsc_list[10]), + PSC_DEV(135, &soc_lpsc_list[11]), + PSC_DEV(170, &soc_lpsc_list[12]), + PSC_DEV(177, &soc_lpsc_list[13]), + PSC_DEV(55, &soc_lpsc_list[14]), };
const struct ti_k3_pd_platdata am62px_pd_platdata = {
Unfortunately because these scripts are so closely tied to our HW designs tools they will never be seen by anyone outside of TI. We should probably update this commit message for Andreas.
Or find a way to publish these scripts ;)
~Bryan
~Bryan
In order to support Ethernet boot on AM62p, probe AM65 CPSW NUSS driver in board_init_f().
Signed-off-by: Chintan Vankar c-vankar@ti.com --- arch/arm/mach-k3/am62px/am62p5_init.c | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/arch/arm/mach-k3/am62px/am62p5_init.c b/arch/arm/mach-k3/am62px/am62p5_init.c index 34ed01cd78c..f8e98b09402 100644 --- a/arch/arm/mach-k3/am62px/am62p5_init.c +++ b/arch/arm/mach-k3/am62px/am62p5_init.c @@ -159,6 +159,16 @@ void board_init_f(ulong dummy) }
spl_enable_cache(); + + if (IS_ENABLED(CONFIG_SPL_ETH) && IS_ENABLED(CONFIG_TI_AM65_CPSW_NUSS) && + spl_boot_device() == BOOT_DEVICE_ETHERNET) { + struct udevice *cpswdev; + + if (uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(am65_cpsw_nuss), + &cpswdev)) + printf("Failed to probe am65_cpsw_nuss driver\n"); + } + debug("am62px_init: %s done\n", __func__); }
Hi Chintan!
spl_enable_cache();
&cpswdev))
- debug("am62px_init: %s done\n", __func__);
Unfortunately with all the release activities we now have a simple merge conflict with -next merging into -master.
~Bryan
spl_enable_cache();
&cpswdev))
Why do you need to do this?
from drivers/net/ti/am65-cpsw-nuss.c
Isn't am65_cpsw_port_probe() and am65_cpsw_probe_nuss() getting called? If not, you need to identify why and fix it the proper way. Not by hacking it like you do now.
Enable cache to support Ethernet boot for AM62p-SK.
Signed-off-by: Andreas Dannenberg dannenberg@ti.com Signed-off-by: Chintan Vankar c-vankar@ti.com --- board/ti/am62px/evm.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/board/ti/am62px/evm.c b/board/ti/am62px/evm.c index 7362fa4520a..2a85af980c7 100644 --- a/board/ti/am62px/evm.c +++ b/board/ti/am62px/evm.c @@ -9,6 +9,7 @@ #include <efi_loader.h> #include <asm/arch/hardware.h> #include <asm/io.h> +#include <cpu_func.h> #include <dm/uclass.h> #include <env.h> #include <fdt_support.h> @@ -53,6 +54,13 @@ int board_init(void) return 0; }
+#if IS_ENABLED(CONFIG_SPL_BUILD) +void spl_board_init(void) +{ + enable_caches(); +} +#endif + int dram_init(void) { return fdtdec_setup_mem_size_base();
Please give more details in commit log.
What happens to Ethernet boot if you don't enable cache? Is this a requirement by Ethernet hardware?
- enable_caches();
+} +#endif
Ethernet boot is working fine even without enabling cache, enabling cache will optimize the performance of CPU to access data from memory.
Since this is not a requirement from Ethernet hardware, I will modify the commit message accordingly.
- enable_caches();
+} +#endif
- int dram_init(void) { return fdtdec_setup_mem_size_base();
Add configs for enabling ETHBOOT in R5SPL.
Signed-off-by: Andreas Dannenberg dannenberg@ti.com Signed-off-by: Chintan Vankar c-vankar@ti.com --- configs/am62px_evm_r5_ethboot_defconfig | 35 +++++++++++++++++++++++++ 1 file changed, 35 insertions(+) create mode 100644 configs/am62px_evm_r5_ethboot_defconfig
diff --git a/configs/am62px_evm_r5_ethboot_defconfig b/configs/am62px_evm_r5_ethboot_defconfig new file mode 100644 index 00000000000..d97b2b73680 --- /dev/null +++ b/configs/am62px_evm_r5_ethboot_defconfig @@ -0,0 +1,35 @@ +#include<configs/am62px_evm_r5_defconfig> + +CONFIG_ARM=y +CONFIG_ARCH_K3=y +CONFIG_SOC_K3_AM62P5=y +CONFIG_TARGET_AM62P5_R5_EVM=y +CONFIG_DEFAULT_DEVICE_TREE="k3-am62p5-r5-sk" +CONFIG_SPL_MMC=n +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x300000 +CONFIG_SPL_DMA=y +CONFIG_SPL_ENV_SUPPORT=y +CONFIG_SPL_ETH=y +CONFIG_SPL_I2C=y +CONFIG_SPL_NET=y +CONFIG_SPL_NET_VCI_STRING="AM62PX U-Boot R5 SPL" +CONFIG_CMD_DHCP=y +CONFIG_SPL_SYSCON=y +CONFIG_DMA_CHANNELS=y +CONFIG_TI_K3_NAVSS_UDMA=y +CONFIG_DM_I2C=y +CONFIG_PHY_TI_DP83867=y +CONFIG_TI_AM65_CPSW_NUSS=y +CONFIG_NET=y +CONFIG_SPL_SPI=n +CONFIG_SPL_MTD_LOAD=n +CONFIG_SPL_NAND_SPI_SUPPORT=n +CONFIG_SPL_DM_DEVICE_REMOVE=n +CONFIG_DM_MTD=n +CONFIG_MTD_SPI_NAND=n +CONFIG_DM_SPI_FLASH=n +CONFIG_SPI=n +CONFIG_DM_SPI=n +CONFIG_CADENCE_QSPI=n +CONFIG_SPL_DRIVERS_MISC=y
Enable config options needed to support Ethernet boot on AM62p SK.
Signed-off-by: Chintan Vankar c-vankar@ti.com --- configs/am62px_evm_a53_ethboot_defconfig | 17 +++++++++++++++++ 1 file changed, 17 insertions(+) create mode 100644 configs/am62px_evm_a53_ethboot_defconfig
diff --git a/configs/am62px_evm_a53_ethboot_defconfig b/configs/am62px_evm_a53_ethboot_defconfig new file mode 100644 index 00000000000..8f9b0c4b755 --- /dev/null +++ b/configs/am62px_evm_a53_ethboot_defconfig @@ -0,0 +1,17 @@ +#include <configs/am62px_evm_a53_defconfig> + +CONFIG_ARM=y +CONFIG_ARCH_K3=y +CONFIG_SOC_K3_AM62P5=y +CONFIG_TARGET_AM62P5_A53_EVM=y +CONFIG_DEFAULT_DEVICE_TREE="ti/k3-am62p5-sk" +CONFIG_SPL_STACK_R_ADDR=0x83000000 +CONFIG_SPL_DRIVERS_MISC=y +#CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_DMA=y +CONFIG_SPL_ENV_SUPPORT=y +CONFIG_SPL_ETH=y +CONFIG_SPL_NET=y +CONFIG_SPL_NET_VCI_STRING="AM62PX U-Boot A53 SPL" +CONFIG_SPL_SYSCON=y +CONFIG_REMOTEPROC_TI_K3_R5F=y
Are we trying to turn this off?
~Bryan
Linux patch for the same is posted at: https://lore.kernel.org/r/20250106123122.3531845-3-c-vankar@ti.com/
arch/arm/dts/k3-am62p5-sk-u-boot.dtsi | 32 +++++++++++++++++++++++++++ 1 file changed, 32 insertions(+)
diff --git a/arch/arm/dts/k3-am62p5-sk-u-boot.dtsi b/arch/arm/dts/k3-am62p5-sk-u-boot.dtsi index cf087c6e343..be62cac7694 100644 --- a/arch/arm/dts/k3-am62p5-sk-u-boot.dtsi +++ b/arch/arm/dts/k3-am62p5-sk-u-boot.dtsi @@ -16,3 +16,35 @@ &dmsc { bootph-pre-ram; }; + +&cpsw_mac_syscon { + bootph-all; +}; + +&cpsw_port1 { + bootph-all; +}; + +&main_pktdma { + bootph-all; +}; + +&main_rgmii1_pins_default { + bootph-all; +}; + +&main_mdio1_pins_default { + bootph-all; +}; + +&cpsw3g_phy0 { + bootph-all; +}; + +&cpsw3g_mdio { + bootph-all; +}; + +&phy_gmii_sel { + bootph-all; +};
participants (6)
Bryan Brattlof
Chintan Vankar
Roger Quadros
Vankar, Chintan
Vignesh Raghavendra
