[U-Boot] [PATCH 2/2] common/cmd_source.c: Fix the source command failure under 64-bit platform
Modify the data pointer type from ulong* to u32*.
For arm64 type "ulong" could be 64-bit. Then in line 89 of common/cmd_source.c: "while (*data++);" data will point to the next 64 bits each time. As the uImage file generated by mkimage tool keeps the same data format in either 32-bit or 64-bit platform, the difference would cause failure in 64-bit platform.
Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com
diff --git a/common/cmd_source.c b/common/cmd_source.c index d2a881d..db7ab7e 100644 --- a/common/cmd_source.c +++ b/common/cmd_source.c @@ -33,7 +33,7 @@ source (ulong addr, const char *fit_uname) #if defined(CONFIG_IMAGE_FORMAT_LEGACY) const image_header_t *hdr; #endif - ulong *data; + u32 *data; int verify; void *buf; #if defined(CONFIG_FIT) @@ -74,7 +74,7 @@ source (ulong addr, const char *fit_uname) }
/* get length of script */ - data = (ulong *)image_get_data (hdr); + data = (u32 *)image_get_data (hdr);
if ((len = uimage_to_cpu (*data)) == 0) { puts ("Empty Script\n"); @@ -128,7 +128,7 @@ source (ulong addr, const char *fit_uname) return 1; }
- data = (ulong *)fit_data; + data = (u32 *)fit_data; len = (ulong)fit_len; break; #endif
Gong Qianyu
